Date/Time: Thu, 10 Jul 2025 02:52:12 +0000
New software update does not respond.
View Count: 1104
[2021-12-13 19:13:52] |
lovelivelaught - Posts: 70 |
Hello I downloaded a new version of software about couple hours hour ago but it did not work properly, it had delayed data. So I went to my previous 2292 version but it does not respond when the platform opens up. I tried to restart my computer few times but every time I log to my Sierra platform it is writing "Not Responding". I don't know what should I do now? |
[2021-12-13 22:57:39] |
I tried to download all previous software versions using SierraChartFileDownloader in SierraChart program folder on my computer but it keeps crushing my computer. I don't know what can be done here. I don't want to lose all my setups and studies by uninstalling the software. I attached a log file here for you to review. |
[2021-12-14 00:02:14] |
Enable Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode After that, refer to the information here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook (30.16 ) We recommend that you stay on the current version of Sierra Chart. We see you are using Rithmic. For Rithmic, we recommend the Denali Exchange Data Feed for data: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-14 00:03:34
[2021-12-14 02:42:28] |
Thank you. It looks like that after updating to new software version for some reasons there was a reset of all my chart settings. all intraday charts were reset to small tick size and 1 sec time frame. Most of my chartbooks I could fix except one where I used historical market depth study and in addition to small tick size and 1 sec time frame I assume it caused the freeze on start up. There is an error to connect to Rithmic. I had before a portal from Discount Trading to connect to Rithmic and it is gone now. I also sent a message log to you for your analysis. And here I copied as well: Rithmic Direct - DTC | Using server connection: | 2021-12-13 18:43:40.117 Rithmic Direct - DTC | Remote address is not set. | 2021-12-13 18:43:40.119 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-12-13 18:43:40.119 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-12-13 18:43:40.119 WSACleanup called. | 2021-12-13 18:43:40.132 DTC Client socket (0) | CloseSocket call. | 2021-12-13 18:43:40.133 Rithmic Direct - DTC | Disconnected. | 2021-12-13 18:43:40.133 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-12-13 18:43:40.133 I use Denali data feed for US stocks. |
[2021-12-14 14:37:54] |
Regarding the tick size, this probably is because the symbols were translated to the new Rithmic format and the tick size was reset to default. One way to avoid this issue is to enable this option: Chart Settings: Do Not Change Symbol Settings for Chart on Symbol Change (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) and 1 sec time frame That does not make sense to happen an update. There would be no reason for that.For help connecting to Rithmic, refer to: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-14 15:01:30] |
Please help me, I really dont know what is happening here. It is second day since I updated to a new software version and nothing is working. I went through all of your set up Data/Trade services pages yesterday and still no luck to get all data When I switch to SC data-all services I get US equities real data and 10 min delayed data on CME futures but when I switch to Rithnic Direct-DTC I don't get any data. I am with Discount Trading and I used to have a Rithmic portal connection appear on my dashboard when I open Sierra platform. I dont have it now, maybe this is a problem. Here is a message log: Created the DTC Protocol server. | 2021-12-14 07:12:40.120 DTC Protocol Server listening on port 11099. | 2021-12-14 07:12:40.121 Reading Internal Order ID file. | 2021-12-14 07:12:40.121 Reading Trade Orders file. | 2021-12-14 07:12:40.179 Reading Trade Positions file. | 2021-12-14 07:12:40.179 Reading Trade Account Data files. | 2021-12-14 07:12:40.180 UDPListener (1424). Port 22904 | Listening on UDP port 22904. | 2021-12-14 07:12:40.204 Software version: 2333 64-bit | 2021-12-14 07:12:40.204 Safe Mode enabled | 2021-12-14 07:12:40.204 Primary Thread ID: 1696 | 2021-12-14 07:12:40.204 Usage end date: 2022-01-03 | 2021-12-14 07:12:40.204 Enabled for: Advanced Features 2. | 2021-12-14 07:12:40.204 Enabled for: Sierra Chart Historical Data Service. | 2021-12-14 07:12:40.204 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-12-14 07:12:40.204 Enabled for: Delayed Denali Exchange Data Feed. | 2021-12-14 07:12:40.204 Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX) | 2021-12-14 07:12:40.204 Enabled for exchange: TSX Equities | 2021-12-14 07:12:40.204 Enabled for exchange: Euronext Equities Delayed | 2021-12-14 07:12:40.204 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-12-14 07:12:40.204 Current selected Data/Trading service: Rithmic Direct - DTC | 2021-12-14 07:12:40.204 Custom symbol settings values: disabled | 2021-12-14 07:12:40.204 Chart Update Interval: 100 | 2021-12-14 07:12:40.204 Intraday Data Storage Time Unit: 0 | 2021-12-14 07:12:40.204 Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-12-14 07:12:40.204 2021-12-14 14:12:40 Local computer time in UTC | 2021-12-14 07:12:40.204 2021-12-14 07:12:40 Local computer time in SC Time Zone | 2021-12-14 07:12:40.204 2021-12-14 14:12:39 Server time in UTC | 2021-12-14 07:12:40.204 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-12-14 07:12:40.205 Program path: C:\SierraChart\ | 2021-12-14 07:12:40.205 Data Files path: C:\SierraChart\Data\ | 2021-12-14 07:12:40.205 OS Version Number: 10.0 | 2021-12-14 07:12:40.205 Locale Setting: C | 2021-12-14 07:12:40.205 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll, zyp sierra free_64.dll | 2021-12-14 07:12:40.206 Allowed protected custom studies: zyp_download_free | 2021-12-14 07:12:40.206 Created the DTC Protocol historical data server. | 2021-12-14 07:12:40.229 HD Server Manager | Listening on port 11098. | 2021-12-14 07:12:40.230 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2021-12-14 07:12:40.230 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2021-12-14 07:12:40.260 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2021-12-14 07:12:40.260 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2021-12-14 07:12:40.260 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-12-14 07:12:40.294 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-12-14 07:12:40.456 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-12-14 07:12:40.456 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2021-12-14 07:12:40.594 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2021-12-14 07:12:40.595 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-12-14 07:12:40.595 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2021-12-14 07:12:40.595 Received 5 login tokens. | 2021-12-14 07:12:40.786 Symbol settings MD5 received. Request ID: 1. | 2021-12-14 07:12:41.007 Symbol settings are up-to-date for rithmic_v2.trading. | 2021-12-14 07:12:41.007 Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2021-12-14 07:12:46.983 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2021-12-14 07:12:46.987 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-12-14 07:12:47.055 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-14 07:12:47.055 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-12-14 07:12:47.055 Rithmic Direct - DTC | Network connection to server complete. | 2021-12-14 07:12:47.112 Rithmic Direct - DTC | Starting socket receive thread. | 2021-12-14 07:12:47.112 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-12-14 07:12:47.112 Rithmic Direct - DTC | Sending logon request message. | 2021-12-14 07:12:47.112 Rithmic Direct - DTC | Received logon response. | 2021-12-14 07:12:47.296 Rithmic Direct - DTC | Server Name: . | 2021-12-14 07:12:47.296 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 07:12:47.296 Rithmic Direct - DTC | Successfully connected. | 2021-12-14 07:12:47.296 Rithmic Direct - DTC | Trading is supported. | 2021-12-14 07:12:47.296 Rithmic Direct - DTC | Order cancel and replace is supported. | 2021-12-14 07:12:47.296 Rithmic Direct - DTC | OCO Orders supported. | 2021-12-14 07:12:47.296 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2021-12-14 07:12:47.296 Rithmic Direct - DTC | Connected to server complete. | 2021-12-14 07:12:47.296 Triggering next historical data download in queue. | 2021-12-14 07:12:47.297 Triggering next historical data download in queue. | 2021-12-14 07:12:47.297 Triggering next historical data download in queue. | 2021-12-14 07:12:47.297 Triggering next historical data download in queue. | 2021-12-14 07:12:47.297 Updated verified funded futures trading account ending date to: 2022-01-13 14:12:47 | 2021-12-14 07:12:47.304 No download requests in the queue to start downloads for. | 2021-12-14 07:12:47.304 No download requests in the queue to start downloads for. | 2021-12-14 07:12:47.304 No download requests in the queue to start downloads for. | 2021-12-14 07:12:47.304 No download requests in the queue to start downloads for. | 2021-12-14 07:12:47.304 Updated verified funded futures trading account ending date to: 2022-01-13 14:12:47 | 2021-12-14 07:12:47.366 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 07:12:48.280 NQZ1.CME [CV] 5 Min #2 | Performing continuous chart historical Daily data download for symbol NQZ1.CME starting at last date in file. | 2021-12-14 07:12:48.281 Starting DelayedDownloadMonitoringTimer | 2021-12-14 07:12:48.281 Starting HDTimeoutTimer | 2021-12-14 07:12:48.281 Added historical Daily data request for NQZ1.CME to the queue. | 2021-12-14 07:12:48.281 Triggering next historical data download in queue. | 2021-12-14 07:12:48.281 NQZ1.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 07:12:48.300 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 07:12:48.307 NQZ1.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 07:12:48.327 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 07:12:48.335 NQZ1.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 07:12:48.355 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 07:12:48.479 NQZ1.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 07:12:48.499 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 07:12:48.504 Starting DelayedDownloadMonitoringTimer | 2021-12-14 07:12:48.505 Starting HDTimeoutTimer | 2021-12-14 07:12:48.505 Added historical Intraday data request for NQZ1.CME to the queue. | 2021-12-14 07:12:48.505 Triggering next historical data download in queue. | 2021-12-14 07:12:48.505 Added historical Intraday data request for NQH2.CME to the queue. | 2021-12-14 07:12:48.507 NQH2.CME [CV] 1 Min #14 | Performing continuous chart historical Daily data download for symbol NQH2.CME starting at last date in file. | 2021-12-14 07:12:48.508 Added historical Daily data request for NQH2.CME to the queue. | 2021-12-14 07:12:48.508 NQH2.CME [CV] 1 Min #14 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 07:12:48.528 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 07:12:48.534 Added historical Intraday data request for NQU1.CME to the queue. | 2021-12-14 07:12:48.536 NQH2.CME [CV] 1 Sec #6 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, | 2021-12-14 07:12:48.598 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 07:12:48.610 NQH2.CME [CV] 60 Min #27 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 07:12:48.632 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 07:12:48.644 NQH2.CME [CV] 180 Min #29 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, | 2021-12-14 07:12:48.707 ESH2.CME [CV] 1 Min #9 | Reloading chart. | 2021-12-14 07:12:48.842 Added historical Intraday data request for ESZ1.CME to the queue. | 2021-12-14 07:12:48.842 Added historical Intraday data request for ESH2.CME to the queue. | 2021-12-14 07:12:48.844 ESH2.CME [CV] 1 Min #9 | Performing continuous chart historical Daily data download for symbol ESH2.CME starting at last date in file. | 2021-12-14 07:12:48.845 Added historical Daily data request for ESH2.CME to the queue. | 2021-12-14 07:12:48.845 ESH2.CME [CV] 1 Min #9 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 07:12:48.865 ESH2.CME [CV] 2 Min #12 | Reloading chart. | 2021-12-14 07:12:48.894 ESH2.CME [CV] 2 Min #12 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 07:12:48.916 ESH2.CME [CV] 5 Min #15 | Reloading chart. | 2021-12-14 07:12:48.931 ESH2.CME [CV] 5 Min #15 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 07:12:48.953 ESH2.CME [CV] 180 Min #16 | Reloading chart. | 2021-12-14 07:12:48.964 Added historical Intraday data request for ESU1.CME to the queue. | 2021-12-14 07:12:48.967 ESH2.CME [CV] 180 Min #16 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, | 2021-12-14 07:12:49.033 ESH2.CME [CV] 60 Min #22 | Reloading chart. | 2021-12-14 07:12:49.045 ESH2.CME [CV] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 07:12:49.068 ESH2.CME [CV] 15 Min #24 | Reloading chart. | 2021-12-14 07:12:49.081 ESH2.CME [CV] 15 Min #24 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 07:12:49.104 ESZ1.CME [CV] 5 Min #42 | Reloading chart. | 2021-12-14 07:12:49.112 ESZ1.CME [CV] 5 Min #42 | Performing continuous chart historical Daily data download for symbol ESZ1.CME starting at last date in file. | 2021-12-14 07:12:49.113 Added historical Daily data request for ESZ1.CME to the queue. | 2021-12-14 07:12:49.113 ESZ1.CME [CV] 5 Min #42 | Waiting for historical downloads to complete with the IDs: 6, 10, | 2021-12-14 07:12:49.131 ESZ1.CME [CV] #43 | Reloading chart. | 2021-12-14 07:12:49.137 ESZ1.CME [CV] #43 | Waiting for historical downloads to complete with the IDs: 6, 10, | 2021-12-14 07:12:49.157 ESH2.CME [CV] 1 Min #45 | Reloading chart. | 2021-12-14 07:12:49.162 ESH2.CME [CV] 1 Min #45 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 10, | 2021-12-14 07:12:49.185 ESH2.CME [CV] 1 Min #47 | Reloading chart. | 2021-12-14 07:12:49.191 ESH2.CME [CV] 1 Min #47 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, | 2021-12-14 07:12:49.253 ESH2.CME [CV] 1 Day #38 | Reloading chart. | 2021-12-14 07:12:49.264 Added historical Intraday data request for ESH1.CME to the queue. | 2021-12-14 07:12:49.266 Added historical Intraday data request for ESM1.CME to the queue. | 2021-12-14 07:12:49.268 ESH2.CME [CV] 1 Day #38 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, 11, 12, | 2021-12-14 07:12:49.365 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 07:12:49.378 ESH2.CME [CV] Weekly #40 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 07:12:49.378 ESH2.CME [CV] Weekly #40 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 07:12:49.378 ESH2.CME [CV] Weekly #40 | Waiting for historical downloads to complete with the IDs: 8, 10, | 2021-12-14 07:12:49.781 BTCZ1.CME [CV] #1 | Reloading chart. | 2021-12-14 07:12:49.790 Added historical Intraday data request for BTCX1.CME to the queue. | 2021-12-14 07:12:49.791 BTCZ1.CME [CV] #1 | Performing continuous chart historical Daily data download for symbol BTCZ1.CME starting at last date in file. | 2021-12-14 07:12:49.794 Added historical Daily data request for BTCZ1.CME to the queue. | 2021-12-14 07:12:49.794 BTCZ1.CME [CV] #1 | Waiting for historical downloads to complete with the IDs: 13, 14, | 2021-12-14 07:12:49.808 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 07:12:49.822 Added historical Intraday data request for NQH1.CME to the queue. | 2021-12-14 07:12:49.824 Added historical Intraday data request for NQM1.CME to the queue. | 2021-12-14 07:12:49.825 NQH2.CME [CV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 15, 16, | 2021-12-14 07:12:49.923 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 07:12:49.929 NQH2.CME [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 16, | 2021-12-14 07:12:49.991 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 07:12:50.004 NQH2.CME [CV] 15 Min #23 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 07:12:50.026 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 07:12:50.040 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 07:12:50.040 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 07:12:50.040 NQH2.CME [CV] Weekly #11 | Waiting for historical downloads to complete with the IDs: 1, 4, | 2021-12-14 07:12:50.429 NQH2.CME [CV] 1 Min #8 | Reloading chart. | 2021-12-14 07:12:50.599 NQH2.CME [CV] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 07:12:50.622 NQH2.CME [CV] 5 Min #13 | Reloading chart. | 2021-12-14 07:12:50.699 NQH2.CME [CV] 5 Min #13 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 07:12:50.721 NQH2.CME [CV] 2 Min #17 | Reloading chart. | 2021-12-14 07:12:50.757 NQH2.CME [CV] 2 Min #17 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 07:12:50.780 HD Request # 1 | Downloading Historical Daily chart data for NQZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 07:12:50.794 HD Request # 2 | Downloading Intraday chart data for NQZ1.CME to the file NQZ1.CME.scid. Service: rithmic.trading | 2021-12-14 07:12:50.796 HD Request # 2 | Download start date-time: 2021-09-09 14:05:57.000000. File last date-time: 2021-09-09 14:05:57.628001 | 2021-12-14 07:12:50.796 HD Request # 2 | Using server: rsc.rithmic.com port 50505. Use encryption. | 2021-12-14 07:12:50.797 Socket (3) | Creating socket. Using TLS 1.2. | 2021-12-14 07:12:50.797 Socket (3) | New receive buffer size: 5242880 | 2021-12-14 07:12:50.797 Socket (3) | Connecting to IP: 216.57.156.163. | 2021-12-14 07:12:50.797 HD Request # 2 | Sending historical data logon request message. | 2021-12-14 07:12:50.856 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-09-09 14:05:57. Record interval: 0. Symbol: NQZ1.CME | 2021-12-14 07:12:51.034 HD Request # 2 | Receiving Intraday data for NQZ1.CME starting at 2021-09-09 14:05:57.628000 | 2021-12-14 07:12:51.096 HD Request # 1 | Requesting historical Daily data for NQZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 07:12:51.554 HD Request # 1 | Receiving historical Daily data for NQZ1.CME starting at 2021-12-09 | 2021-12-14 07:12:51.910 HD Request # 1 | Writing historical Daily data to the file NQZ1.CME.dly | 2021-12-14 07:12:51.911 HD Request # 1 | Bytes received: 258 | 2021-12-14 07:12:51.913 HD Request # 1 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQZ1.CME | 2021-12-14 07:12:51.913 HD Request # 1 | Completion time: 1s | 2021-12-14 07:12:51.913 HD Request # 1 | Daily data download complete for NQZ1.CME. Unique request ID: 1 | 2021-12-14 07:12:51.913 Removing historical data download ID 1. | 2021-12-14 07:12:51.913 Triggering next historical data download in queue. | 2021-12-14 07:12:51.913 HD Request # 3 | Downloading Historical Daily chart data for NQH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 07:12:51.915 NQZ1.CME [CV] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:12:51.916 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 07:12:51.917 NQZ1.CME [CV] #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:12:51.920 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 07:12:51.921 NQZ1.CME [CV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:12:51.937 NQZ1.CME [CV] #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:12:52.012 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 07:12:52.012 NQZ1.CME [CV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:12:52.016 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 07:12:52.016 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 07:12:52.022 NQZ1.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 07:12:52.046 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 07:12:52.047 NQZ1.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 07:12:52.069 NQZ1.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:12:52.070 NQZ1.CME [CV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:12:52.073 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 07:12:52.142 NQZ1.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 07:12:52.162 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 07:12:52.163 NQZ1.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 07:12:52.184 Rithmic Direct - DTC | Starting real-time market data updates for: ESH2.CME. ID: 3 Service code: rithmic.trading | 2021-12-14 07:12:52.305 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50504 | 2021-12-14 07:12:52.305 Rithmic Direct - DTC | Requesting security definition data for: ESH2.CME. ID: 3 | 2021-12-14 07:12:52.305 Requesting market depth updates for: ESH2.CME if supported. | 2021-12-14 07:12:52.305 Separate subscription for market depth updates not supported. ESH2.CME | 2021-12-14 07:12:52.305 Rithmic Direct - DTC | Starting real-time market data updates for: NQH2.CME. ID: 2 Service code: rithmic.trading | 2021-12-14 07:12:52.305 Rithmic Direct - DTC | Requesting security definition data for: NQH2.CME. ID: 2 | 2021-12-14 07:12:52.305 Requesting market depth updates for: NQH2.CME if supported. | 2021-12-14 07:12:52.305 Separate subscription for market depth updates not supported. NQH2.CME | 2021-12-14 07:12:52.305 Rithmic Direct - DTC | Starting real-time market data updates for: NQZ1.CME. ID: 1 Service code: rithmic.trading | 2021-12-14 07:12:52.305 Rithmic Direct - DTC | Requesting security definition data for: NQZ1.CME. ID: 1 | 2021-12-14 07:12:52.305 Requesting market depth updates for: NQZ1.CME if supported. | 2021-12-14 07:12:52.305 Separate subscription for market depth updates not supported. NQZ1.CME | 2021-12-14 07:12:52.305 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-12-14 07:12:52.305 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-12-14 07:12:52.305 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-12-14 07:12:52.305 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2021-12-14 07:12:52.361 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2021-12-14 07:12:52.361 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2021-12-14 07:12:52.361 Rithmic Direct - DTC (Data) | Sending logon request message. | 2021-12-14 07:12:52.361 Rithmic Direct - DTC (Data) | Received logon response. | 2021-12-14 07:12:52.543 Rithmic Direct - DTC (Data) | Server Name: . | 2021-12-14 07:12:52.543 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 07:12:52.543 Rithmic Direct - DTC (Data) | Successfully connected. | 2021-12-14 07:12:52.543 Rithmic Direct - DTC (Data) | Trading is not supported. | 2021-12-14 07:12:52.543 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2021-12-14 07:12:52.543 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESH2.CME. Market Depth data restarted. | 2021-12-14 07:12:52.543 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQH2.CME. Market Depth data restarted. | 2021-12-14 07:12:52.543 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ1.CME. Market Depth data restarted. | 2021-12-14 07:12:52.543 Rithmic Direct - DTC (Data) | Received security definition for symbol ESH2.CME | 2021-12-14 07:12:52.610 Rithmic Direct - DTC (Data) | Clearing market depth for ESH2.CME | 2021-12-14 07:12:52.610 HD Request # 3 | Requesting historical Daily data for NQH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 07:12:52.731 HD Request # 3 | Receiving historical Daily data for NQH2.CME starting at 2021-12-09 | 2021-12-14 07:12:53.029 HD Request # 3 | Writing historical Daily data to the file NQH2.CME.dly | 2021-12-14 07:12:53.030 HD Request # 3 | Bytes received: 248 | 2021-12-14 07:12:53.032 HD Request # 3 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQH2.CME | 2021-12-14 07:12:53.032 HD Request # 3 | Completion time: 2s | 2021-12-14 07:12:53.032 HD Request # 3 | Daily data download complete for NQH2.CME. Unique request ID: 4 | 2021-12-14 07:12:53.032 Removing historical data download ID 4. | 2021-12-14 07:12:53.032 Triggering next historical data download in queue. | 2021-12-14 07:12:53.032 HD Request # 4 | Downloading Historical Daily chart data for ESH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 07:12:53.034 NQH2.CME [CV] Weekly #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:12:53.110 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 07:12:53.112 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 07:12:53.226 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 07:12:53.226 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 07:12:53.226 Restarting the loading process. | 2021-12-14 07:12:53.713 Rithmic Direct - DTC (Data) | Clearing market depth for NQH2.CME | 2021-12-14 07:12:53.714 Rithmic Direct - DTC (Data) | Clearing market depth for NQZ1.CME | 2021-12-14 07:12:53.715 Rithmic Direct - DTC (Data) | Received security definition for symbol NQH2.CME | 2021-12-14 07:12:53.715 Rithmic Direct - DTC (Data) | Received security definition for symbol NQZ1.CME | 2021-12-14 07:12:53.715 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:12:53.774 HD Request # 4 | Requesting historical Daily data for ESH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 07:12:53.811 HD Request # 4 | Receiving historical Daily data for ESH2.CME starting at 2021-12-09 | 2021-12-14 07:12:54.003 HD Request # 4 | Writing historical Daily data to the file ESH2.CME.dly | 2021-12-14 07:12:54.003 HD Request # 4 | Bytes received: 243 | 2021-12-14 07:12:54.005 HD Request # 4 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for ESH2.CME | 2021-12-14 07:12:54.005 HD Request # 4 | Completion time: 1s | 2021-12-14 07:12:54.005 HD Request # 4 | Daily data download complete for ESH2.CME. Unique request ID: 8 | 2021-12-14 07:12:54.005 Removing historical data download ID 8. | 2021-12-14 07:12:54.005 Triggering next historical data download in queue. | 2021-12-14 07:12:54.005 HD Request # 5 | Downloading Historical Daily chart data for ESZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 07:12:54.007 HD Request # 5 | Requesting historical Daily data for ESZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 07:12:54.783 HD Request # 5 | Receiving historical Daily data for ESZ1.CME starting at 2021-12-09 | 2021-12-14 07:12:55.072 HD Request # 5 | Writing historical Daily data to the file ESZ1.CME.dly | 2021-12-14 07:12:55.072 HD Request # 5 | Bytes received: 242 | 2021-12-14 07:12:55.075 HD Request # 5 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for ESZ1.CME | 2021-12-14 07:12:55.075 HD Request # 5 | Completion time: 1s | 2021-12-14 07:12:55.076 HD Request # 5 | Daily data download complete for ESZ1.CME. Unique request ID: 10 | 2021-12-14 07:12:55.076 Removing historical data download ID 10. | 2021-12-14 07:12:55.076 Triggering next historical data download in queue. | 2021-12-14 07:12:55.076 HD Request # 6 | Downloading Historical Daily chart data for BTCZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 07:12:55.078 ESH2.CME [CV] Weekly #40 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:12:55.078 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 07:12:55.079 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 07:12:55.198 ESH2.CME [CV] Weekly #40 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 07:12:55.198 ESH2.CME [CV] Weekly #40 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 07:12:55.198 Restarting the loading process. | 2021-12-14 07:12:55.713 ESH2.CME [CV] Weekly #40 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:12:55.780 HD Request # 6 | Requesting historical Daily data for BTZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 07:12:56.303 HD Request # 6 | Receiving historical Daily data for BTCZ1.CME starting at 2021-12-09 | 2021-12-14 07:12:56.530 HD Request # 6 | Writing historical Daily data to the file BTCZ1.CME.dly | 2021-12-14 07:12:56.530 HD Request # 6 | Bytes received: 204 | 2021-12-14 07:12:56.537 HD Request # 6 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for BTCZ1.CME | 2021-12-14 07:12:56.537 HD Request # 6 | Completion time: 1s | 2021-12-14 07:12:56.537 HD Request # 6 | Daily data download complete for BTCZ1.CME. Unique request ID: 14 | 2021-12-14 07:12:56.537 Removing historical data download ID 14. | 2021-12-14 07:12:56.537 Triggering next historical data download in queue. | 2021-12-14 07:12:56.537 No download requests in the queue to start downloads for. | 2021-12-14 07:12:56.537 NIO [CV] 1 Day #1 | Reloading chart. | 2021-12-14 07:19:01.305 NIO [CV] 1 Day #1 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.305 NIO [CV] 1 Day #1 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.305 NIO [CV] 180 Min #2 | Reloading chart. | 2021-12-14 07:19:01.425 NIO [CV] 180 Min #2 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.425 NIO [CV] 180 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.425 ABX.TO [CV] 1 Day #3 | Reloading chart. | 2021-12-14 07:19:01.432 ABX.TO [CV] 1 Day #3 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.432 ABX.TO [CV] 1 Day #3 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.432 ABX.TO [CV] 180 Min #4 | Reloading chart. | 2021-12-14 07:19:01.456 ABX.TO [CV] 180 Min #4 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.456 ABX.TO [CV] 180 Min #4 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.456 NIO [CV] Daily #5 | Reloading chart. | 2021-12-14 07:19:01.512 NIO [CV] Daily #5 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.512 NIO [CV] Daily #5 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.512 NIO [CV] 180 Min #6 | Reloading chart. | 2021-12-14 07:19:01.556 NIO [CV] 180 Min #6 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.556 NIO [CV] 180 Min #6 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.556 NIO [CV] 60 Min #7 | Reloading chart. | 2021-12-14 07:19:01.574 NIO [CV] 60 Min #7 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.574 NIO [CV] 60 Min #7 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.574 NIO [CV] 15 Min #8 | Reloading chart. | 2021-12-14 07:19:01.623 NIO [CV] 15 Min #8 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.623 NIO [CV] 15 Min #8 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.623 NIO [CV] Weekly #9 | Reloading chart. | 2021-12-14 07:19:01.647 NIO [CV] Weekly #9 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.647 NIO [CV] Weekly #9 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.647 NIO [CV] Monthly #10 | Reloading chart. | 2021-12-14 07:19:01.672 NIO [CV] Monthly #10 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.672 NIO [CV] Monthly #10 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.672 NIO [CV] 4000000 Volume #11 | Reloading chart. | 2021-12-14 07:19:01.699 NIO [CV] 4000000 Volume #11 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.699 NIO [CV] 4000000 Volume #11 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.699 ABX.TO [CV] Daily #12 | Reloading chart. | 2021-12-14 07:19:01.728 ABX.TO [CV] Daily #12 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.728 ABX.TO [CV] Daily #12 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.728 ABX.TO [CV] 180 Min #13 | Reloading chart. | 2021-12-14 07:19:01.758 ABX.TO [CV] 180 Min #13 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.758 ABX.TO [CV] 180 Min #13 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.758 ABX.TO [CV] 60 Min #14 | Reloading chart. | 2021-12-14 07:19:01.795 ABX.TO [CV] 60 Min #14 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.795 ABX.TO [CV] 60 Min #14 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.795 ABX.TO [CV] 25000000 Volume #15 | Reloading chart. | 2021-12-14 07:19:01.821 ABX.TO [CV] 25000000 Volume #15 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.822 ABX.TO [CV] 25000000 Volume #15 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.822 ABX.TO [CV] Weekly #16 | Reloading chart. | 2021-12-14 07:19:01.850 ABX.TO [CV] Weekly #16 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.850 ABX.TO [CV] Weekly #16 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.850 ABX.TO [CV] Monthly #17 | Reloading chart. | 2021-12-14 07:19:01.880 ABX.TO [CV] Monthly #17 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.880 ABX.TO [CV] Monthly #17 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.880 LI [CV] 1 Day #18 | Reloading chart. | 2021-12-14 07:19:01.899 LI [CV] 1 Day #18 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.899 LI [CV] 1 Day #18 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.899 WEED.TO [CV] 1 Day #19 | Reloading chart. | 2021-12-14 07:19:01.935 WEED.TO [CV] 1 Day #19 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.935 WEED.TO [CV] 1 Day #19 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.935 BITF [CV] 1 Day #21 | Reloading chart. | 2021-12-14 07:19:01.968 BITF [CV] 1 Day #21 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:01.968 BITF [CV] 1 Day #21 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:01.968 BITF [CV] 1 Day #22 | Reloading chart. | 2021-12-14 07:19:02.103 BITF [CV] 1 Day #22 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:02.103 BITF [CV] 1 Day #22 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:02.103 Mapping NOK to NOK. Service code: equities.us | 2021-12-14 07:19:02.137 SC Data - All Services | Starting real-time market data updates for: NOK (NOK). ID: 6 Service code: equities.us | 2021-12-14 07:19:02.137 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-14 07:19:02.137 SC Data - All Services | Requesting security definition data for: NOK (NOK). ID: 6 | 2021-12-14 07:19:02.137 Mapping MCHP to MCHP. Service code: equities.us | 2021-12-14 07:19:02.137 SC Data - All Services | Starting real-time market data updates for: MCHP (MCHP). ID: 7 Service code: equities.us | 2021-12-14 07:19:02.137 SC Data - All Services | Requesting security definition data for: MCHP (MCHP). ID: 7 | 2021-12-14 07:19:02.137 Mapping FCX to FCX. Service code: equities.us | 2021-12-14 07:19:02.137 SC Data - All Services | Starting real-time market data updates for: FCX (FCX). ID: 8 Service code: equities.us | 2021-12-14 07:19:02.137 SC Data - All Services | Requesting security definition data for: FCX (FCX). ID: 8 | 2021-12-14 07:19:02.137 Mapping CSCO to CSCO. Service code: equities.us | 2021-12-14 07:19:02.137 SC Data - All Services | Starting real-time market data updates for: CSCO (CSCO). ID: 9 Service code: equities.us | 2021-12-14 07:19:02.137 SC Data - All Services | Requesting security definition data for: CSCO (CSCO). ID: 9 | 2021-12-14 07:19:02.137 Mapping LUN.TO to LUN.TO. Service code: TSX.Exchange | 2021-12-14 07:19:02.138 SC Data - All Services | Starting real-time market data updates for: LUN.TO (LUN.TO). ID: 10 Service code: TSX.Exchange | 2021-12-14 07:19:02.138 SC Data - All Services | Requesting security definition data for: LUN.TO (LUN.TO). ID: 10 | 2021-12-14 07:19:02.138 Mapping CL to CL. Service code: equities.us | 2021-12-14 07:19:02.138 SC Data - All Services | Starting real-time market data updates for: CL (CL). ID: 11 Service code: equities.us | 2021-12-14 07:19:02.138 SC Data - All Services | Requesting security definition data for: CL (CL). ID: 11 | 2021-12-14 07:19:02.138 Mapping FTS.TO to FTS.TO. Service code: TSX.Exchange | 2021-12-14 07:19:02.138 SC Data - All Services | Starting real-time market data updates for: FTS.TO (FTS.TO). ID: 12 Service code: TSX.Exchange | 2021-12-14 07:19:02.138 SC Data - All Services | Requesting security definition data for: FTS.TO (FTS.TO). ID: 12 | 2021-12-14 07:19:02.138 Mapping INTC to INTC. Service code: equities.us | 2021-12-14 07:19:02.138 SC Data - All Services | Starting real-time market data updates for: INTC (INTC). ID: 13 Service code: equities.us | 2021-12-14 07:19:02.138 SC Data - All Services | Requesting security definition data for: INTC (INTC). ID: 13 | 2021-12-14 07:19:02.138 Mapping FISV to FISV. Service code: equities.us | 2021-12-14 07:19:02.138 SC Data - All Services | Starting real-time market data updates for: FISV (FISV). ID: 14 Service code: equities.us | 2021-12-14 07:19:02.138 SC Data - All Services | Requesting security definition data for: FISV (FISV). ID: 14 | 2021-12-14 07:19:02.138 Mapping ATUS to ATUS. Service code: equities.us | 2021-12-14 07:19:02.138 SC Data - All Services | Starting real-time market data updates for: ATUS (ATUS). ID: 15 Service code: equities.us | 2021-12-14 07:19:02.139 SC Data - All Services | Requesting security definition data for: ATUS (ATUS). ID: 15 | 2021-12-14 07:19:02.139 Mapping WCP.TO to WCP.TO. Service code: TSX.Exchange | 2021-12-14 07:19:02.139 SC Data - All Services | Starting real-time market data updates for: WCP.TO (WCP.TO). ID: 16 Service code: TSX.Exchange | 2021-12-14 07:19:02.139 SC Data - All Services | Requesting security definition data for: WCP.TO (WCP.TO). ID: 16 | 2021-12-14 07:19:02.139 DTC Client socket (4) | Creating socket. | 2021-12-14 07:19:02.146 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-12-14 07:19:02.146 DTC Client socket (4) | Connecting to IP: 8.18.161.135. | 2021-12-14 07:19:02.146 NIO [CV-D] Daily #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.160 NIO [CV-D] Weekly #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.236 NIO [CV-D] Monthly #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.256 ABX.TO [CV-D] Daily #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.271 ABX.TO [CV-D] 1 Day #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.357 ABX.TO [CV-D] 180 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.366 ABX.TO [CV-D] Weekly #16 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.371 ABX.TO [CV-D] Monthly #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.400 SC Data - All Services | Network connection to server complete. | 2021-12-14 07:19:02.609 SC Data - All Services | Starting socket receive thread. | 2021-12-14 07:19:02.609 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-12-14 07:19:02.609 BITF [CV-D] 1 Day #22 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.611 BITF [CV-D] 1 Day #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.614 WEED.TO [CV-D] 1 Day #19 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.619 ABX.TO [CV-D] 180 Min #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.641 ABX.TO [CV-D] 60 Min #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.761 Loading market depth data. | 2021-12-14 07:19:02.787 Loaded depth data records for ABX.TO 2021-12-07 from 2021-12-07 12:13:49.506000 to 2021-12-07 14:29:58.971000. | 2021-12-14 07:19:02.793 Loaded depth data records for ABX.TO 2021-12-08 from 2021-12-08 06:01:26.973000 to 2021-12-08 14:14:59.186000. | 2021-12-14 07:19:02.812 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-12-14 07:19:02.818 SC Data - All Services | Sending logon request message. | 2021-12-14 07:19:02.818 Loaded depth data records for ABX.TO 2021-12-09 from 2021-12-09 06:09:34.377000 to 2021-12-09 09:38:23.739872. | 2021-12-14 07:19:02.825 Loaded depth data records for ABX.TO 2021-12-10 from 2021-12-10 06:20:00.816000 to 2021-12-10 14:44:46.236288. | 2021-12-14 07:19:02.848 Loaded depth data records for ABX.TO 2021-12-13 from 2021-12-13 06:10:31.598000 to 2021-12-13 10:24:13.929286. | 2021-12-14 07:19:02.863 ABX.TO [CV-D] 25000000 Volume #15 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:02.874 Mapping NIO to NIO. Service code: equities.us | 2021-12-14 07:19:03.076 SC Data - All Services | Starting real-time market data updates for: NIO (NIO). ID: 17 Service code: equities.us | 2021-12-14 07:19:03.076 SC Data - All Services | Requesting security definition data for: NIO (NIO). ID: 17 | 2021-12-14 07:19:03.076 Added historical Intraday data request for NIO to the queue. | 2021-12-14 07:19:03.076 Intraday data recording state for symbol NIO is set to download 'Pending'. | 2021-12-14 07:19:03.076 Triggering next historical data download in queue. | 2021-12-14 07:19:03.076 Mapping ABX.TO to ABX.TO. Service code: TSX.Exchange | 2021-12-14 07:19:03.083 SC Data - All Services | Starting real-time market data updates for: ABX.TO (ABX.TO). ID: 18 Service code: TSX.Exchange | 2021-12-14 07:19:03.083 SC Data - All Services | Requesting security definition data for: ABX.TO (ABX.TO). ID: 18 | 2021-12-14 07:19:03.083 Added historical Intraday data request for ABX.TO to the queue. | 2021-12-14 07:19:03.083 Intraday data recording state for symbol ABX.TO is set to download 'Pending'. | 2021-12-14 07:19:03.083 Triggering next historical data download in queue. | 2021-12-14 07:19:03.083 Added historical Daily data request for NIO to the queue. | 2021-12-14 07:19:03.245 Triggering next historical data download in queue. | 2021-12-14 07:19:03.245 HD Request # 7 | Downloading Historical Daily chart data for NIO. Starting date: 2021-12-09. Service: equities.us | 2021-12-14 07:19:03.287 Requesting market depth updates for: NIO if supported. | 2021-12-14 07:19:03.376 Separate subscription for market depth updates not supported. NIO | 2021-12-14 07:19:03.376 Added historical Daily data request for ABX.TO to the queue. | 2021-12-14 07:19:03.377 Triggering next historical data download in queue. | 2021-12-14 07:19:03.377 SC Data - All Services | Received logon response. | 2021-12-14 07:19:03.520 SC Data - All Services | Server Name: SC Realtime Server. | 2021-12-14 07:19:03.520 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 07:19:03.520 SC Data - All Services | Successfully connected. | 2021-12-14 07:19:03.520 SC Data - All Services | Trading is not supported. | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: ABX.TO -> ABX.TO | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: ATUS -> ATUS | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: CL -> CL | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: CSCO -> CSCO | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: FCX -> FCX | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: FISV -> FISV | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: FTS.TO -> FTS.TO | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: INTC -> INTC | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: LUN.TO -> LUN.TO | 2021-12-14 07:19:03.520 SC Data - All Services | Restarting real-time data updates for symbol: MCHP -> MCHP | 2021-12-14 07:19:03.520 Real-time market depth file updates started for NIO | 2021-12-14 07:19:03.520 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NIO.2021-12-14.depth | 2021-12-14 07:19:03.521 SC Data - All Services | Restarting real-time data updates for symbol: NIO -> NIO. Market Depth data restarted. | 2021-12-14 07:19:03.521 SC Data - All Services | Restarting real-time data updates for symbol: NOK -> NOK | 2021-12-14 07:19:03.521 SC Data - All Services | Restarting real-time data updates for symbol: WCP.TO -> WCP.TO | 2021-12-14 07:19:03.521 SC Data - All Services | Received security definition for symbol ABX.TO | 2021-12-14 07:19:03.716 SC Data - All Services | Received security definition for symbol ATUS | 2021-12-14 07:19:03.716 SC Data - All Services | Received security definition for symbol CL | 2021-12-14 07:19:03.716 SC Data - All Services | Received security definition for symbol CSCO | 2021-12-14 07:19:03.716 SC Data - All Services | Received security definition for symbol FCX | 2021-12-14 07:19:03.716 SC Data - All Services | Received security definition for symbol FISV | 2021-12-14 07:19:03.717 SC Data - All Services | Received security definition for symbol FTS.TO | 2021-12-14 07:19:03.717 SC Data - All Services | Received security definition for symbol INTC | 2021-12-14 07:19:03.717 SC Data - All Services | Received security definition for symbol LUN.TO | 2021-12-14 07:19:03.717 SC Data - All Services | Received security definition for symbol MCHP | 2021-12-14 07:19:03.717 SC Data - All Services | Received security definition for symbol NIO | 2021-12-14 07:19:03.717 SC Data - All Services | Received security definition for symbol NOK | 2021-12-14 07:19:03.717 SC Data - All Services | Received security definition for symbol WCP.TO | 2021-12-14 07:19:03.717 ABX.TO [CV-D] 25000000 Volume #15 | Reloading chart. | 2021-12-14 07:19:03.928 ABX.TO [CV-D] 25000000 Volume #15 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:03.928 ABX.TO [CV-D] 25000000 Volume #15 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:03.928 Mapping LI to LI. Service code: equities.us | 2021-12-14 07:19:03.972 SC Data - All Services | Starting real-time market data updates for: LI (LI). ID: 19 Service code: equities.us | 2021-12-14 07:19:03.972 SC Data - All Services | Requesting security definition data for: LI (LI). ID: 19 | 2021-12-14 07:19:03.972 Added historical Intraday data request for LI to the queue. | 2021-12-14 07:19:03.972 Intraday data recording state for symbol LI is set to download 'Pending'. | 2021-12-14 07:19:03.972 Triggering next historical data download in queue. | 2021-12-14 07:19:03.973 Mapping WEED.TO to WEED.TO. Service code: TSX.Exchange | 2021-12-14 07:19:03.974 SC Data - All Services | Starting real-time market data updates for: WEED.TO (WEED.TO). ID: 20 Service code: TSX.Exchange | 2021-12-14 07:19:03.974 SC Data - All Services | Requesting security definition data for: WEED.TO (WEED.TO). ID: 20 | 2021-12-14 07:19:03.974 Added historical Intraday data request for WEED.TO to the queue. | 2021-12-14 07:19:03.974 Intraday data recording state for symbol WEED.TO is set to download 'Pending'. | 2021-12-14 07:19:03.974 Triggering next historical data download in queue. | 2021-12-14 07:19:03.974 Mapping BITF to BITF. Service code: equities.us | 2021-12-14 07:19:03.989 SC Data - All Services | Starting real-time market data updates for: BITF (BITF). ID: 21 Service code: equities.us | 2021-12-14 07:19:03.989 SC Data - All Services | Requesting security definition data for: BITF (BITF). ID: 21 | 2021-12-14 07:19:03.989 Added historical Intraday data request for BITF to the queue. | 2021-12-14 07:19:03.989 Intraday data recording state for symbol BITF is set to download 'Pending'. | 2021-12-14 07:19:03.989 Triggering next historical data download in queue. | 2021-12-14 07:19:03.989 Requesting market depth updates for: ABX.TO if supported. | 2021-12-14 07:19:03.998 Separate subscription for market depth updates not supported. ABX.TO | 2021-12-14 07:19:03.998 HD Request # 7 | Requesting historical Daily data for NIO starting at 2021-12-08. SC External HD service. | 2021-12-14 07:19:04.076 SC Data - All Services | Received security definition for symbol LI | 2021-12-14 07:19:04.130 SC Data - All Services | Received security definition for symbol WEED.TO | 2021-12-14 07:19:04.130 SC Data - All Services | Received security definition for symbol BITF | 2021-12-14 07:19:04.130 HD Request # 7 | Receiving historical Daily data for NIO starting at 2021-12-09 | 2021-12-14 07:19:04.401 HD Request # 7 | Writing historical Daily data to the file NIO.dly | 2021-12-14 07:19:04.402 HD Request # 7 | Bytes received: 190 | 2021-12-14 07:19:04.408 HD Request # 7 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NIO | 2021-12-14 07:19:04.408 HD Request # 7 | Completion time: 1s | 2021-12-14 07:19:04.409 HD Request # 7 | Daily data download complete for NIO. Unique request ID: 19 | 2021-12-14 07:19:04.409 Removing historical data download ID 19. | 2021-12-14 07:19:04.409 Triggering next historical data download in queue. | 2021-12-14 07:19:04.409 HD Request # 8 | Downloading Historical Daily chart data for ABX.TO. Starting date: 2021-12-09. Service: TSX.Exchange | 2021-12-14 07:19:04.410 Loading market depth data. | 2021-12-14 07:19:04.531 Loaded depth data records for ABX.TO 2021-12-07 from 2021-12-07 12:13:49.506000 to 2021-12-07 14:29:58.971000. | 2021-12-14 07:19:04.535 Loaded depth data records for ABX.TO 2021-12-08 from 2021-12-08 06:01:26.973000 to 2021-12-08 14:14:59.186000. | 2021-12-14 07:19:04.549 Loaded depth data records for ABX.TO 2021-12-09 from 2021-12-09 06:09:34.377000 to 2021-12-09 09:38:23.739872. | 2021-12-14 07:19:04.559 Loaded depth data records for ABX.TO 2021-12-10 from 2021-12-10 06:20:00.816000 to 2021-12-10 14:44:46.236288. | 2021-12-14 07:19:04.574 Loaded depth data records for ABX.TO 2021-12-13 from 2021-12-13 06:10:31.598000 to 2021-12-13 10:24:13.929286. | 2021-12-14 07:19:04.586 ABX.TO [CV-D] 25000000 Volume #15 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:04.595 NIO [CV-D][M] Daily #5 | Reloading chart. | 2021-12-14 07:19:04.669 NIO [CV-D][M] Daily #5 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:04.669 NIO [CV-D][M] Daily #5 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:04.669 NIO [CV-D][M] Weekly #9 | Reloading chart. | 2021-12-14 07:19:04.676 NIO [CV-D][M] Weekly #9 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:04.676 NIO [CV-D][M] Weekly #9 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:04.676 NIO [CV-D][M] Monthly #10 | Reloading chart. | 2021-12-14 07:19:04.687 NIO [CV-D][M] Monthly #10 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:04.687 NIO [CV-D][M] Monthly #10 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:04.687 NIO [CV-D][M] Daily #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:04.692 NIO [CV-D][M] Weekly #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:04.742 NIO [CV-D][M] Monthly #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:04.823 LI [CV-D][M] 1 Day #18 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:04.841 HD Request # 8 | Requesting historical Daily data for ABX.TO starting at 2021-12-08. SC External HD service. | 2021-12-14 07:19:05.178 HD Request # 8 | Receiving historical Daily data for ABX.TO starting at 2021-12-09 | 2021-12-14 07:19:05.425 HD Request # 8 | Writing historical Daily data to the file ABX.TO.dly | 2021-12-14 07:19:05.425 HD Request # 8 | Bytes received: 195 | 2021-12-14 07:19:05.467 HD Request # 8 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for ABX.TO | 2021-12-14 07:19:05.467 HD Request # 8 | Completion time: 1s | 2021-12-14 07:19:05.467 HD Request # 8 | Daily data download complete for ABX.TO. Unique request ID: 20 | 2021-12-14 07:19:05.467 Removing historical data download ID 20. | 2021-12-14 07:19:05.467 Triggering next historical data download in queue. | 2021-12-14 07:19:05.467 No download requests in the queue to start downloads for. | 2021-12-14 07:19:05.467 ABX.TO [CV-D][M] Daily #12 | Reloading chart. | 2021-12-14 07:19:05.528 ABX.TO [CV-D][M] Daily #12 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:05.528 ABX.TO [CV-D][M] Daily #12 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:05.528 ABX.TO [CV-D][M] Weekly #16 | Reloading chart. | 2021-12-14 07:19:05.535 ABX.TO [CV-D][M] Weekly #16 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:05.535 ABX.TO [CV-D][M] Weekly #16 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:05.535 ABX.TO [CV-D][M] Monthly #17 | Reloading chart. | 2021-12-14 07:19:05.544 ABX.TO [CV-D][M] Monthly #17 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:05.544 ABX.TO [CV-D][M] Monthly #17 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:05.544 ABX.TO [CV-D][M] Daily #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:05.604 ABX.TO [CV-D][M] Weekly #16 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:05.705 ABX.TO [CV-D][M] Monthly #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:05.722 NIO [CV-D][M] 1 Day #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:07.121 NIO [CV-D][M] 180 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:07.389 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NIO.2021-12-14.depth | 2021-12-14 07:19:08.944 NIO [CV-D][M] 60 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:12.659 NIO [CV-D][M] 180 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:12.746 NIO [CV-D][M] 15 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:12.853 Loading market depth data. | 2021-12-14 07:19:14.447 Loaded depth data records for NIO 2021-12-07 from 2021-12-07 08:15:35.608000 to 2021-12-07 16:59:13.031000. | 2021-12-14 07:19:14.534 Loaded depth data records for NIO 2021-12-08 from 2021-12-07 17:00:05.098000 to 2021-12-08 16:59:41.001000. | 2021-12-14 07:19:14.562 Loaded depth data records for NIO 2021-12-09 from 2021-12-08 17:00:12.241000 to 2021-12-09 09:38:23.739706. | 2021-12-14 07:19:14.615 Loaded depth data records for NIO 2021-12-10 from 2021-12-10 06:18:50.504000 to 2021-12-10 14:44:46.236090. | 2021-12-14 07:19:14.707 Loaded depth data records for NIO 2021-12-13 from 2021-12-13 06:08:22.379000 to 2021-12-13 10:24:13.929106. | 2021-12-14 07:19:14.759 Loaded depth data records for NIO 2021-12-14 from 2021-12-13 20:30:55.402045 to 2021-12-14 07:07:53.941000. | 2021-12-14 07:19:14.760 NIO [CV-D][M] 4000000 Volume #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:14.761 NIO [CV-D][M] 4000000 Volume #11 | Reloading chart. | 2021-12-14 07:19:14.913 NIO [CV-D][M] 4000000 Volume #11 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2021-12-14 07:19:14.913 NIO [CV-D][M] 4000000 Volume #11 | There are no continuous futures contract symbols. Loading data normally. | 2021-12-14 07:19:14.913 Loading market depth data. | 2021-12-14 07:19:24.328 Loaded depth data records for NIO 2021-12-07 from 2021-12-07 08:15:35.608000 to 2021-12-07 16:59:13.031000. | 2021-12-14 07:19:24.366 Loaded depth data records for NIO 2021-12-08 from 2021-12-07 17:00:05.098000 to 2021-12-08 16:59:41.001000. | 2021-12-14 07:19:24.377 Loaded depth data records for NIO 2021-12-09 from 2021-12-08 17:00:12.241000 to 2021-12-09 09:38:23.739706. | 2021-12-14 07:19:24.398 Loaded depth data records for NIO 2021-12-10 from 2021-12-10 06:18:50.504000 to 2021-12-10 14:44:46.236090. | 2021-12-14 07:19:24.444 Loaded depth data records for NIO 2021-12-13 from 2021-12-13 06:08:22.379000 to 2021-12-13 10:24:13.929106. | 2021-12-14 07:19:24.469 Loaded depth data records for NIO 2021-12-14 from 2021-12-13 20:30:55.402045 to 2021-12-14 07:07:53.941000. | 2021-12-14 07:19:24.469 NIO [CV-D][M] 4000000 Volume #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:19:24.470 Real-time market depth file updates started for ABX.TO | 2021-12-14 07:20:03.816 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ABX.TO.2021-12-14.depth | 2021-12-14 07:20:03.816 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ABX.TO.2021-12-14.depth | 2021-12-14 07:20:03.817 Saved Chartbook: Nasdaq.Cht. Time: 0.0697 seconds. | 2021-12-14 07:27:39.926 Saved Chartbook: Scanners.Cht. Time: 0.0669 seconds. | 2021-12-14 07:27:39.994 Saved Chartbook: Nasdaq.Cht. Time: 0.0379 seconds. | 2021-12-14 07:42:40.012 Saved Chartbook: Scanners.Cht. Time: 0.0642 seconds. | 2021-12-14 07:42:40.078 File >> Disconnect selected. | 2021-12-14 07:47:05.346 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2021-12-14 07:47:05.346 DTC Client socket (2) | CloseSocket call. | 2021-12-14 07:47:05.347 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-12-14 07:47:05.347 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2021-12-14 07:47:05.347 WSACleanup called. | 2021-12-14 07:47:05.347 Canceling queued historical data download request for NQH2.CME Intraday data. | 2021-12-14 07:47:05.347 Removing historical data download ID 3. | 2021-12-14 07:47:05.347 Canceling queued historical data download request for NQU1.CME Intraday data. | 2021-12-14 07:47:05.347 Removing historical data download ID 5. | 2021-12-14 07:47:05.347 Canceling queued historical data download request for ESZ1.CME Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 6. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for ESH2.CME Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 7. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for ESU1.CME Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 9. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for ESH1.CME Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 11. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for ESM1.CME Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 12. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for BTCX1.CME Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 13. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for NQH1.CME Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 15. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for NQM1.CME Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 16. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for NIO Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 17. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for ABX.TO Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 18. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for LI Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 21. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for WEED.TO Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 22. | 2021-12-14 07:47:05.348 Canceling queued historical data download request for BITF Intraday data. | 2021-12-14 07:47:05.348 Removing historical data download ID 23. | 2021-12-14 07:47:05.348 HD Request # 2 | Active download canceled. | 2021-12-14 07:47:05.348 Historical data download thread signaled to stop. | 2021-12-14 07:47:05.348 Socket (3) | CloseSocket call. | 2021-12-14 07:47:05.348 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-12-14 07:47:05.348 HD Request # 2 | Timestamp of first Intraday data file record written: 2021-09-09 14:05:57.773000 | 2021-12-14 07:47:05.348 HD Request # 2 | Received 10000 Intraday data records from 2021-09-09 14:05:57.628000 to 2021-09-09 21:30:23.268010 (7.4 hours) and wrote 9998 records for NQZ1.CME | 2021-12-14 07:47:05.348 HD Request # 2 | Completion time: 34m 15s | 2021-12-14 07:47:05.348 HD Request # 2 | Intraday data download complete for NQZ1.CME. Unique request ID: 2 | 2021-12-14 07:47:05.348 Removing historical data download ID 2. | 2021-12-14 07:47:05.348 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-12-14 07:47:05.348 Triggering next historical data download in queue. | 2021-12-14 07:47:05.349 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-12-14 07:47:05.356 DTC Client socket (1) | CloseSocket call. | 2021-12-14 07:47:05.357 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-12-14 07:47:05.357 SC Data - All Services | Waiting for socket receive thread to end | 2021-12-14 07:47:05.357 DTC Client socket (4) | CloseSocket call. | 2021-12-14 07:47:05.357 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2021-12-14 07:47:05.357 DTC Client socket (4) | Max send buffer size during socket life: 1080 | 2021-12-14 07:47:05.357 SC Data - All Services | Disconnected from the server. | 2021-12-14 07:47:05.357 Rithmic Direct - DTC | Disconnected. | 2021-12-14 07:47:05.357 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-12-14 07:47:05.357 No download requests in the queue to start downloads for. | 2021-12-14 07:47:05.357 NQH2.CME [CV] 1 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.379 NQH2.CME [CV] 1 Min #8 | Reloading chart. | 2021-12-14 07:47:05.380 NQH2.CME [CV] 1 Min #14 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.388 Loading market depth data. | 2021-12-14 07:47:05.389 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 07:47:05.389 NQH2.CME [CV] 1 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.397 NQH2.CME [CV] 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.399 NQH2.CME [CV] 60 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.399 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 07:47:05.399 Socket (3) | Socket gracefully closed by remote side. | 2021-12-14 07:47:05.404 Socket (3) | Closed. | 2021-12-14 07:47:05.404 NQZ1.CME [CV] #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.407 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 07:47:05.408 NQH2.CME [CV] 60 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.410 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-12-14 07:47:05.411 DTC Client socket (1) | Closed. | 2021-12-14 07:47:05.411 NQZ1.CME [CV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.412 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 07:47:05.413 NQZ1.CME [CV] #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.416 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 07:47:05.417 NQZ1.CME [CV] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.419 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 07:47:05.420 ESH2.CME [CV] 15 Min #24 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.424 ESH2.CME [CV] 15 Min #24 | Reloading chart. | 2021-12-14 07:47:05.425 ESH2.CME [CV] 1 Min #47 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.433 ESH2.CME [CV] 1 Min #47 | Reloading chart. | 2021-12-14 07:47:05.434 ESH2.CME [CV] 15 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:05.451 NQZ1.CME [CV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:47:05.495 NQZ1.CME [CV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:47:05.510 ESH2.CME [CV] 1 Min #47 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:05.544 NQZ1.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:47:05.545 NQH2.CME [CV] 1 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.596 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 07:47:05.597 NQH2.CME [CV] 180 Min #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.613 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 07:47:05.615 NQH2.CME [CV] 1 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.632 ESH2.CME [CV] 2 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.634 ESH2.CME [CV] 2 Min #12 | Reloading chart. | 2021-12-14 07:47:05.634 NQH2.CME [CV] 180 Min #29 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.642 ESZ1.CME [CV] 5 Min #42 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.643 Loading market depth data. | 2021-12-14 07:47:05.643 ESZ1.CME [CV] 5 Min #42 | Reloading chart. | 2021-12-14 07:47:05.644 ESH2.CME [CV] 2 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:05.646 NQH2.CME [CV] 2 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.648 NQH2.CME [CV] 2 Min #17 | Reloading chart. | 2021-12-14 07:47:05.648 ESZ1.CME [CV] 5 Min #42 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:47:05.656 Loading market depth data. | 2021-12-14 07:47:05.657 NQH2.CME [CV] 2 Min #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.668 ESZ1.CME [CV] #43 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.679 ESZ1.CME [CV] #43 | Reloading chart. | 2021-12-14 07:47:05.680 BTCZ1.CME [CV] #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.682 BTCZ1.CME [CV] #1 | Reloading chart. | 2021-12-14 07:47:05.683 NQH2.CME [CV] 15 Min #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.692 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 07:47:05.694 NQH2.CME [CV] 15 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.807 NQH2.CME [CV] 5 Min #13 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.807 NQH2.CME [CV] 5 Min #13 | Reloading chart. | 2021-12-14 07:47:05.808 ESH2.CME [CV] 1 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.816 Loading market depth data. | 2021-12-14 07:47:05.817 ESH2.CME [CV] 1 Min #9 | Reloading chart. | 2021-12-14 07:47:05.817 NQH2.CME [CV] 5 Min #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.824 Loading market depth data. | 2021-12-14 07:47:05.826 ESH2.CME [CV] 5 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.826 ESH2.CME [CV] 5 Min #15 | Reloading chart. | 2021-12-14 07:47:05.827 ESH2.CME [CV] 1 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:05.834 ESH2.CME [CV] 180 Min #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.835 Loading market depth data. | 2021-12-14 07:47:05.835 ESH2.CME [CV] 180 Min #16 | Reloading chart. | 2021-12-14 07:47:05.836 ESH2.CME [CV] 5 Min #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:05.852 ESH2.CME [CV] 60 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.854 ESH2.CME [CV] 60 Min #22 | Reloading chart. | 2021-12-14 07:47:05.854 ESH2.CME [CV] 180 Min #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:05.862 ESH2.CME [CV] 1 Min #45 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.863 ESH2.CME [CV] 1 Min #45 | Reloading chart. | 2021-12-14 07:47:05.863 ESH2.CME [CV] 60 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:05.870 ESH2.CME [CV] 1 Day #38 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.871 ESH2.CME [CV] 1 Day #38 | Reloading chart. | 2021-12-14 07:47:05.872 ESH2.CME [CV] 1 Min #45 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:05.897 NQH2.CME [CV] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.898 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 07:47:05.899 ESH2.CME [CV] 1 Day #38 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:05.924 NQH2.CME [CV] 1 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 07:47:05.926 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 07:47:05.927 NQH2.CME [CV] 1 Day #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.943 NQH2.CME [CV] 1 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:05.957 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 07:47:05.959 NQH2.CME [CV] 1 Min #8 | Reloading chart. | 2021-12-14 07:47:05.990 NQH2.CME [CV] 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:06.020 Loading market depth data. | 2021-12-14 07:47:06.020 NQH2.CME [CV] 1 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:06.021 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 07:47:06.027 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 07:47:06.059 NQH2.CME [CV] 60 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:06.081 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 07:47:06.083 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 07:47:06.106 NQZ1.CME [CV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:47:06.129 NQZ1.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:47:06.195 ESH2.CME [CV] 1 Min #47 | Reloading chart. | 2021-12-14 07:47:06.241 ESH2.CME [CV] 15 Min #24 | Reloading chart. | 2021-12-14 07:47:06.318 ESH2.CME [CV] 1 Min #47 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:06.347 ESH2.CME [CV] 15 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:06.349 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 07:47:06.349 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 07:47:06.377 NQZ1.CME [CV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:47:06.459 NQH2.CME [CV] 1 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:06.474 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 07:47:06.488 ESH2.CME [CV] 2 Min #12 | Reloading chart. | 2021-12-14 07:47:06.569 NQH2.CME [CV] 180 Min #29 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:06.599 Loading market depth data. | 2021-12-14 07:47:06.599 ESH2.CME [CV] 2 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:06.601 NQH2.CME [CV] 2 Min #17 | Reloading chart. | 2021-12-14 07:47:06.602 Loading market depth data. | 2021-12-14 07:47:06.632 ESZ1.CME [CV] 5 Min #42 | Reloading chart. | 2021-12-14 07:47:06.633 NQH2.CME [CV] 2 Min #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:06.654 BTCZ1.CME [CV] #1 | Reloading chart. | 2021-12-14 07:47:06.656 ESZ1.CME [CV] 5 Min #42 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 07:47:06.685 ESZ1.CME [CV] #43 | Reloading chart. | 2021-12-14 07:47:06.780 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 07:47:06.802 NQH2.CME [CV] 15 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:06.863 NQH2.CME [CV] 5 Min #13 | Reloading chart. | 2021-12-14 07:47:06.864 Loading market depth data. | 2021-12-14 07:47:06.894 ESH2.CME [CV] 1 Min #9 | Reloading chart. | 2021-12-14 07:47:06.895 NQH2.CME [CV] 5 Min #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:06.924 Loading market depth data. | 2021-12-14 07:47:06.924 ESH2.CME [CV] 1 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:06.925 ESH2.CME [CV] 180 Min #16 | Reloading chart. | 2021-12-14 07:47:06.926 ESH2.CME [CV] 5 Min #15 | Reloading chart. | 2021-12-14 07:47:07.003 ESH2.CME [CV] 180 Min #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:07.032 Loading market depth data. | 2021-12-14 07:47:07.033 ESH2.CME [CV] 5 Min #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:07.034 ESH2.CME [CV] 60 Min #22 | Reloading chart. | 2021-12-14 07:47:07.035 ESH2.CME [CV] 1 Day #38 | Reloading chart. | 2021-12-14 07:47:07.065 ESH2.CME [CV] 60 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:07.192 ESH2.CME [CV] 1 Min #45 | Reloading chart. | 2021-12-14 07:47:07.193 ESH2.CME [CV] 1 Day #38 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:07.224 ESH2.CME [CV] 1 Min #45 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 07:47:07.225 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 07:47:07.226 NQH2.CME [CV] 1 Day #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:07.356 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 07:47:07.358 NQH2.CME [CV] 1 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 07:47:07.441 Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2021-12-14 07:47:16.533 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2021-12-14 07:47:16.534 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-12-14 07:47:16.535 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-14 07:47:16.535 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-12-14 07:47:16.535 Rithmic Direct - DTC | Network connection to server complete. | 2021-12-14 07:47:16.591 Rithmic Direct - DTC | Starting socket receive thread. | 2021-12-14 07:47:16.591 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-12-14 07:47:16.591 Rithmic Direct - DTC | Sending logon request message. | 2021-12-14 07:47:16.591 Rithmic Direct - DTC | Received logon response. | 2021-12-14 07:47:16.782 Rithmic Direct - DTC | Server Name: . | 2021-12-14 07:47:16.782 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 07:47:16.782 Rithmic Direct - DTC | Successfully connected. | 2021-12-14 07:47:16.782 Rithmic Direct - DTC | Trading is supported. | 2021-12-14 07:47:16.782 Rithmic Direct - DTC | Order cancel and replace is supported. | 2021-12-14 07:47:16.782 Rithmic Direct - DTC | OCO Orders supported. | 2021-12-14 07:47:16.782 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2021-12-14 07:47:16.782 Rithmic Direct - DTC | Connected to server complete. | 2021-12-14 07:47:16.782 Triggering next historical data download in queue. | 2021-12-14 07:47:16.782 Triggering next historical data download in queue. | 2021-12-14 07:47:16.782 Triggering next historical data download in queue. | 2021-12-14 07:47:16.782 Triggering next historical data download in queue. | 2021-12-14 07:47:16.782 Updated verified funded futures trading account ending date to: 2022-01-13 14:47:16 | 2021-12-14 07:47:16.782 No download requests in the queue to start downloads for. | 2021-12-14 07:47:16.793 No download requests in the queue to start downloads for. | 2021-12-14 07:47:16.793 No download requests in the queue to start downloads for. | 2021-12-14 07:47:16.793 No download requests in the queue to start downloads for. | 2021-12-14 07:47:16.793 Rithmic Direct - DTC | Starting real-time market data updates for: ESH2.CME. ID: 1 Service code: rithmic.trading | 2021-12-14 07:47:16.793 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50504 | 2021-12-14 07:47:16.793 Rithmic Direct - DTC | Requesting security definition data for: ESH2.CME. ID: 1 | 2021-12-14 07:47:16.793 Added historical Intraday data request for ESH2.CME to the queue. | 2021-12-14 07:47:16.793 Intraday data recording state for symbol ESH2.CME is set to download 'Pending'. | 2021-12-14 07:47:16.794 Triggering next historical data download in queue. | 2021-12-14 07:47:16.794 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2021-12-14 07:47:16.794 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-12-14 07:47:16.794 DTC Client socket (3) | Connecting to IP: 216.57.156.163. | 2021-12-14 07:47:16.794 Delaying start of download for ESH2.CME | 2021-12-14 07:47:16.794 Rithmic Direct - DTC | Starting real-time market data updates for: NQH2.CME. ID: 2 Service code: rithmic.trading | 2021-12-14 07:47:16.799 Rithmic Direct - DTC | Requesting security definition data for: NQH2.CME. ID: 2 | 2021-12-14 07:47:16.799 Requesting market depth updates for: NQH2.CME if supported. | 2021-12-14 07:47:16.799 Separate subscription for market depth updates not supported. NQH2.CME | 2021-12-14 07:47:16.799 Added historical Intraday data request for NQH2.CME to the queue. | 2021-12-14 07:47:16.799 Intraday data recording state for symbol NQH2.CME is set to download 'Pending'. | 2021-12-14 07:47:16.799 Triggering next historical data download in queue. | 2021-12-14 07:47:16.799 Rithmic Direct - DTC | Starting real-time market data updates for: NQZ1.CME. ID: 3 Service code: rithmic.trading | 2021-12-14 07:47:16.803 Rithmic Direct - DTC | Requesting security definition data for: NQZ1.CME. ID: 3 | 2021-12-14 07:47:16.803 Added historical Intraday data request for NQZ1.CME to the queue. | 2021-12-14 07:47:16.803 Intraday data recording state for symbol NQZ1.CME is set to download 'Pending'. | 2021-12-14 07:47:16.803 Triggering next historical data download in queue. | 2021-12-14 07:47:16.803 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2021-12-14 07:47:16.853 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2021-12-14 07:47:16.853 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2021-12-14 07:47:16.853 Rithmic Direct - DTC (Data) | Sending logon request message. | 2021-12-14 07:47:16.853 Updated verified funded futures trading account ending date to: 2022-01-13 14:47:16 | 2021-12-14 07:47:16.853 Rithmic Direct - DTC | Starting real-time market data updates for: BTCZ1.CME. ID: 4 Service code: rithmic.trading | 2021-12-14 07:47:16.880 Rithmic Direct - DTC | Requesting security definition data for: BTCZ1.CME. ID: 4 | 2021-12-14 07:47:16.880 Added historical Intraday data request for BTCZ1.CME to the queue. | 2021-12-14 07:47:16.880 Intraday data recording state for symbol BTCZ1.CME is set to download 'Pending'. | 2021-12-14 07:47:16.880 Triggering next historical data download in queue. | 2021-12-14 07:47:16.880 Mapping NOK to NOK. Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: NOK (NOK). ID: 5 Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: NOK (NOK). ID: 5 | 2021-12-14 07:47:16.950 Mapping MCHP to MCHP. Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: MCHP (MCHP). ID: 6 Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: MCHP (MCHP). ID: 6 | 2021-12-14 07:47:16.950 Mapping FCX to FCX. Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: FCX (FCX). ID: 7 Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: FCX (FCX). ID: 7 | 2021-12-14 07:47:16.950 Mapping CSCO to CSCO. Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: CSCO (CSCO). ID: 8 Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: CSCO (CSCO). ID: 8 | 2021-12-14 07:47:16.950 Mapping LUN.TO to LUN.TO. Service code: TSX.Exchange | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: LUN.TO (LUN.TO). ID: 9 Service code: TSX.Exchange | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: LUN.TO (LUN.TO). ID: 9 | 2021-12-14 07:47:16.950 Mapping CL to CL. Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: CL (CL). ID: 10 Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: CL (CL). ID: 10 | 2021-12-14 07:47:16.950 Mapping FTS.TO to FTS.TO. Service code: TSX.Exchange | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: FTS.TO (FTS.TO). ID: 11 Service code: TSX.Exchange | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: FTS.TO (FTS.TO). ID: 11 | 2021-12-14 07:47:16.950 Mapping INTC to INTC. Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: INTC (INTC). ID: 12 Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: INTC (INTC). ID: 12 | 2021-12-14 07:47:16.950 Mapping FISV to FISV. Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: FISV (FISV). ID: 13 Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: FISV (FISV). ID: 13 | 2021-12-14 07:47:16.950 Mapping ATUS to ATUS. Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: ATUS (ATUS). ID: 14 Service code: equities.us | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: ATUS (ATUS). ID: 14 | 2021-12-14 07:47:16.950 Mapping WCP.TO to WCP.TO. Service code: TSX.Exchange | 2021-12-14 07:47:16.950 SC Data - All Services | Starting real-time market data updates for: WCP.TO (WCP.TO). ID: 15 Service code: TSX.Exchange | 2021-12-14 07:47:16.950 SC Data - All Services | Requesting security definition data for: WCP.TO (WCP.TO). ID: 15 | 2021-12-14 07:47:16.950 DTC Client socket (5) | Creating socket. | 2021-12-14 07:47:16.950 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-12-14 07:47:16.951 DTC Client socket (5) | Connecting to IP: 8.18.161.133. | 2021-12-14 07:47:16.951 Mapping NIO to NIO. Service code: equities.us | 2021-12-14 07:47:16.967 SC Data - All Services | Starting real-time market data updates for: NIO (NIO). ID: 16 Service code: equities.us | 2021-12-14 07:47:16.967 SC Data - All Services | Requesting security definition data for: NIO (NIO). ID: 16 | 2021-12-14 07:47:16.967 Added historical Intraday data request for NIO to the queue. | 2021-12-14 07:47:16.967 Intraday data recording state for symbol NIO is set to download 'Pending'. | 2021-12-14 07:47:16.967 Triggering next historical data download in queue. | 2021-12-14 07:47:16.967 Mapping LI to LI. Service code: equities.us | 2021-12-14 07:47:16.968 SC Data - All Services | Starting real-time market data updates for: LI (LI). ID: 17 Service code: equities.us | 2021-12-14 07:47:16.968 SC Data - All Services | Requesting security definition data for: LI (LI). ID: 17 | 2021-12-14 07:47:16.968 Added historical Intraday data request for LI to the queue. | 2021-12-14 07:47:16.968 Intraday data recording state for symbol LI is set to download 'Pending'. | 2021-12-14 07:47:16.968 Triggering next historical data download in queue. | 2021-12-14 07:47:16.968 Mapping ABX.TO to ABX.TO. Service code: TSX.Exchange | 2021-12-14 07:47:16.968 SC Data - All Services | Starting real-time market data updates for: ABX.TO (ABX.TO). ID: 18 Service code: TSX.Exchange | 2021-12-14 07:47:16.968 SC Data - All Services | Requesting security definition data for: ABX.TO (ABX.TO). ID: 18 | 2021-12-14 07:47:16.968 Added historical Intraday data request for ABX.TO to the queue. | 2021-12-14 07:47:16.968 Intraday data recording state for symbol ABX.TO is set to download 'Pending'. | 2021-12-14 07:47:16.968 Triggering next historical data download in queue. | 2021-12-14 07:47:16.968 Mapping WEED.TO to WEED.TO. Service code: TSX.Exchange | 2021-12-14 07:47:16.972 SC Data - All Services | Starting real-time market data updates for: WEED.TO (WEED.TO). ID: 19 Service code: TSX.Exchange | 2021-12-14 07:47:16.972 SC Data - All Services | Requesting security definition data for: WEED.TO (WEED.TO). ID: 19 | 2021-12-14 07:47:16.972 Added historical Intraday data request for WEED.TO to the queue. | 2021-12-14 07:47:16.972 Intraday data recording state for symbol WEED.TO is set to download 'Pending'. | 2021-12-14 07:47:16.972 Triggering next historical data download in queue. | 2021-12-14 07:47:16.972 Requesting market depth updates for: ABX.TO if supported. | 2021-12-14 07:47:16.973 Separate subscription for market depth updates not supported. ABX.TO | 2021-12-14 07:47:16.973 Mapping BITF to BITF. Service code: equities.us | 2021-12-14 07:47:16.973 SC Data - All Services | Starting real-time market data updates for: BITF (BITF). ID: 20 Service code: equities.us | 2021-12-14 07:47:16.973 SC Data - All Services | Requesting security definition data for: BITF (BITF). ID: 20 | 2021-12-14 07:47:16.973 Added historical Intraday data request for BITF to the queue. | 2021-12-14 07:47:16.973 Intraday data recording state for symbol BITF is set to download 'Pending'. | 2021-12-14 07:47:16.973 Triggering next historical data download in queue. | 2021-12-14 07:47:16.973 Requesting market depth updates for: NIO if supported. | 2021-12-14 07:47:16.974 Separate subscription for market depth updates not supported. NIO | 2021-12-14 07:47:16.974 Requesting market depth updates for: ESH2.CME if supported. | 2021-12-14 07:47:16.987 Separate subscription for market depth updates not supported. ESH2.CME | 2021-12-14 07:47:16.987 Rithmic Direct - DTC | Starting real-time market data updates for: ESZ1.CME. ID: 21 Service code: rithmic.trading | 2021-12-14 07:47:16.988 Rithmic Direct - DTC | Requesting security definition data for: ESZ1.CME. ID: 21 | 2021-12-14 07:47:16.988 Added historical Intraday data request for ESZ1.CME to the queue. | 2021-12-14 07:47:16.988 Intraday data recording state for symbol ESZ1.CME is set to download 'Pending'. | 2021-12-14 07:47:16.988 Triggering next historical data download in queue. | 2021-12-14 07:47:16.988 SC Data - All Services | Network connection to server complete. | 2021-12-14 07:47:17.016 SC Data - All Services | Starting socket receive thread. | 2021-12-14 07:47:17.016 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-12-14 07:47:17.016 Rithmic Direct - DTC (Data) | Received logon response. | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Server Name: . | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Successfully connected. | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Trading is not supported. | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BTCZ1.CME | 2021-12-14 07:47:17.027 Real-time market depth file updates started for ESH2.CME | 2021-12-14 07:47:17.027 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH2.CME.2021-12-14.depth | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESH2.CME. Market Depth data restarted. | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ1.CME | 2021-12-14 07:47:17.027 Real-time market depth file updates started for NQH2.CME | 2021-12-14 07:47:17.027 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQH2.CME.2021-12-14.depth | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQH2.CME. Market Depth data restarted. | 2021-12-14 07:47:17.027 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ1.CME | 2021-12-14 07:47:17.027 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-12-14 07:47:17.085 SC Data - All Services | Sending logon request message. | 2021-12-14 07:47:17.085 Rithmic Direct - DTC (Data) | Clearing market depth for ESH2.CME | 2021-12-14 07:47:17.101 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH2.CME.2021-12-14.depth | 2021-12-14 07:47:17.418 Rithmic Direct - DTC (Data) | Clearing market depth for NQH2.CME | 2021-12-14 07:47:17.418 Rithmic Direct - DTC (Data) | Received security definition for symbol BTCZ1.CME | 2021-12-14 07:47:17.418 Rithmic Direct - DTC (Data) | Received security definition for symbol ESH2.CME | 2021-12-14 07:47:17.418 Rithmic Direct - DTC (Data) | Received security definition for symbol ESZ1.CME | 2021-12-14 07:47:17.418 Rithmic Direct - DTC (Data) | Received security definition for symbol NQH2.CME | 2021-12-14 07:47:17.418 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQH2.CME.2021-12-14.depth | 2021-12-14 07:47:17.637 Rithmic Direct - DTC (Data) | Received security definition for symbol NQZ1.CME | 2021-12-14 07:47:17.637 SC Data - All Services | Received logon response. | 2021-12-14 07:47:17.855 SC Data - All Services | Server Name: SC Realtime Server. | 2021-12-14 07:47:17.855 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 07:47:17.855 SC Data - All Services | Successfully connected. | 2021-12-14 07:47:17.855 SC Data - All Services | Trading is not supported. | 2021-12-14 07:47:17.855 Real-time market depth file updates started for ABX.TO | 2021-12-14 07:47:17.855 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ABX.TO.2021-12-14.depth | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: ABX.TO -> ABX.TO. Market Depth data restarted. | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: ATUS -> ATUS | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: BITF -> BITF | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: CL -> CL | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: CSCO -> CSCO | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: FCX -> FCX | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: FISV -> FISV | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: FTS.TO -> FTS.TO | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: INTC -> INTC | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: LI -> LI | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: LUN.TO -> LUN.TO | 2021-12-14 07:47:17.855 SC Data - All Services | Restarting real-time data updates for symbol: MCHP -> MCHP | 2021-12-14 07:47:17.855 Real-time market depth file updates started for NIO | 2021-12-14 07:47:17.855 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NIO.2021-12-14.depth | 2021-12-14 07:47:17.856 SC Data - All Services | Restarting real-time data updates for symbol: NIO -> NIO. Market Depth data restarted. | 2021-12-14 07:47:17.856 SC Data - All Services | Restarting real-time data updates for symbol: NOK -> NOK | 2021-12-14 07:47:17.856 SC Data - All Services | Restarting real-time data updates for symbol: WCP.TO -> WCP.TO | 2021-12-14 07:47:17.856 SC Data - All Services | Restarting real-time data updates for symbol: WEED.TO -> WEED.TO | 2021-12-14 07:47:17.856 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NIO.2021-12-14.depth | 2021-12-14 07:47:18.074 SC Data - All Services | Received security definition for symbol ABX.TO | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol ATUS | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol BITF | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol CL | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol CSCO | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol FCX | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol FISV | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol FTS.TO | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol INTC | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol LI | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol LUN.TO | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol MCHP | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol NIO | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol NOK | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol WCP.TO | 2021-12-14 07:47:18.086 SC Data - All Services | Received security definition for symbol WEED.TO | 2021-12-14 07:47:18.086 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ABX.TO.2021-12-14.depth | 2021-12-14 07:47:18.238 Requesting market depth updates for: NQZ1.CME if supported. | 2021-12-14 07:47:21.886 Rithmic Direct - DTC (Data) | Clearing market depth for NQZ1.CME | 2021-12-14 07:47:22.017 HD Request # 9 | Downloading Intraday chart data for ESH2.CME to the file ESH2.CME.scid. Service: rithmic.trading | 2021-12-14 07:47:22.623 HD Request # 9 | Download start date-time: 2021-11-03 04:20:50.000000. File last date-time: 2021-11-03 04:20:50.576000 | 2021-12-14 07:47:22.623 HD Request # 9 | Using server: rsc.rithmic.com port 50505. Use encryption. | 2021-12-14 07:47:22.623 Socket (6) | Creating socket. Using TLS 1.2. | 2021-12-14 07:47:22.623 Socket (6) | New receive buffer size: 5242880 | 2021-12-14 07:47:22.624 Socket (6) | Connecting to IP: 216.57.156.163. | 2021-12-14 07:47:22.624 HD Request # 9 | Sending historical data logon request message. | 2021-12-14 07:47:22.683 HD Request # 9 | Requesting Intraday data. Start date-time: 2021-11-03 04:20:50. Record interval: 0. Symbol: ESH2.CME | 2021-12-14 07:47:22.863 HD Request # 9 | Receiving Intraday data for ESH2.CME starting at 2021-11-03 04:20:50.576000 | 2021-12-14 07:47:23.018 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-12-14 07:49:33.935 DTC Client socket (2) | Closed. | 2021-12-14 07:49:33.935 DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-12-14 07:49:33.935 DTC Client socket (4) | Closed. | 2021-12-14 07:49:33.935 DTC Client socket (2) | Deleting network socket now after delay. | 2021-12-14 07:50:03.938 DTC Client socket (4) | Deleting network socket now after delay. | 2021-12-14 07:50:03.938 Saved Chartbook: Nasdaq.Cht. Time: 0.0714 seconds. | 2021-12-14 07:57:40.221 Saved Chartbook: Scanners.Cht. Time: 0.0554 seconds. | 2021-12-14 07:57:40.278 |
[2021-12-14 15:11:01] |
When I switch to SC data-all services I get US equities real data and 10 min delayed data on CME futures but when I switch to Rithnic Direct-DTC I don't get any data. What you need to do is have a separate installation of Sierra Chart to use with the SC Exchange Data Feed. And then use your current installation for Rithmic. Or you can do it the other way around.Instructions to install another copy of Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart No this is not a problem: I am with Discount Trading and I used to have a Rithmic portal connection appear on my dashboard when I open Sierra platform. I dont have it now, maybe this is a problem. You are referring to the old bridge program which is no longer supported.Also, regarding Rithmic, you really should use the Denali Exchange Data Feed for CME Group data rather than getting it from Rithmic because there are historical data issues from Rithmic. Documentation for Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-14 15:24:26
[2021-12-14 17:28:30] |
lovelivelaught - Posts: 70 |
I tried to download a second copy Of Sierra Chart but I can not transfer data files from one to another because data files are too big and I don't have enough room in my Windows. And at this point I don not think that I really need it as I still cannot get Rithmic connection working. I am with Discount Trading and they provide lowest margin on the market ( which is $300 per contract) for Rithmic users. I will probably loose it if I switch to Denaly Exchange Data Feed for CME Group Data. I restarted my computer again, just in case, and open Sierra platform only with one Chartbook that I use for future contracts. It is 30 min past since I opened it but all charts are still in downloading Continuous Contract data mode. I don't know what is the problem. Here is a message log: HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2021-12-14 09:49:08.585 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2021-12-14 09:49:08.585 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2021-12-14 09:49:08.585 Created the DTC Protocol server. | 2021-12-14 09:49:08.617 DTC Protocol Server listening on port 11099. | 2021-12-14 09:49:08.619 Reading Internal Order ID file. | 2021-12-14 09:49:08.619 Reading Trade Orders file. | 2021-12-14 09:49:08.683 Reading Trade Positions file. | 2021-12-14 09:49:08.683 Reading Trade Account Data files. | 2021-12-14 09:49:08.683 UDPListener (1472). Port 22904 | Listening on UDP port 22904. | 2021-12-14 09:49:08.706 Software version: 2333 64-bit | 2021-12-14 09:49:08.706 Safe Mode enabled | 2021-12-14 09:49:08.706 Primary Thread ID: 16464 | 2021-12-14 09:49:08.706 Usage end date: 2022-01-03 | 2021-12-14 09:49:08.706 Enabled for: Advanced Features 2. | 2021-12-14 09:49:08.706 Enabled for: Sierra Chart Historical Data Service. | 2021-12-14 09:49:08.706 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-12-14 09:49:08.706 Enabled for: Delayed Denali Exchange Data Feed. | 2021-12-14 09:49:08.706 Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX) | 2021-12-14 09:49:08.706 Enabled for exchange: TSX Equities | 2021-12-14 09:49:08.706 Enabled for exchange: Euronext Equities Delayed | 2021-12-14 09:49:08.706 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-12-14 09:49:08.706 Current selected Data/Trading service: Rithmic Direct - DTC | 2021-12-14 09:49:08.706 Custom symbol settings values: disabled | 2021-12-14 09:49:08.706 Chart Update Interval: 100 | 2021-12-14 09:49:08.706 Intraday Data Storage Time Unit: 0 | 2021-12-14 09:49:08.706 Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-12-14 09:49:08.706 2021-12-14 16:49:08 Local computer time in UTC | 2021-12-14 09:49:08.706 2021-12-14 09:49:08 Local computer time in SC Time Zone | 2021-12-14 09:49:08.706 2021-12-14 16:49:08 Server time in UTC | 2021-12-14 09:49:08.706 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-12-14 09:49:08.706 Program path: C:\SierraChart\ | 2021-12-14 09:49:08.706 Data Files path: C:\SierraChart\Data\ | 2021-12-14 09:49:08.706 OS Version Number: 10.0 | 2021-12-14 09:49:08.706 Locale Setting: C | 2021-12-14 09:49:08.706 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll, zyp sierra free_64.dll | 2021-12-14 09:49:08.708 Allowed protected custom studies: zyp_download_free | 2021-12-14 09:49:08.708 Created the DTC Protocol historical data server. | 2021-12-14 09:49:08.727 HD Server Manager | Listening on port 11098. | 2021-12-14 09:49:08.729 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2021-12-14 09:49:08.729 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-12-14 09:49:08.794 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-12-14 09:49:08.958 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-12-14 09:49:08.958 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2021-12-14 09:49:09.011 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2021-12-14 09:49:09.011 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-12-14 09:49:09.011 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2021-12-14 09:49:09.011 Received 5 login tokens. | 2021-12-14 09:49:09.277 Symbol settings MD5 received. Request ID: 1. | 2021-12-14 09:49:09.489 Symbol settings are up-to-date for rithmic_v2.trading. | 2021-12-14 09:49:09.489 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 09:49:14.625 NQZ1.CME [CV] 5 Min #2 | Performing continuous chart historical Daily data download for symbol NQZ1.CME starting at last date in file. | 2021-12-14 09:49:14.627 Starting DelayedDownloadMonitoringTimer | 2021-12-14 09:49:14.627 Starting HDTimeoutTimer | 2021-12-14 09:49:14.627 Added historical Daily data request for NQZ1.CME to the queue. | 2021-12-14 09:49:14.627 Triggering next historical data download in queue. | 2021-12-14 09:49:14.627 NQZ1.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 09:49:14.645 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 09:49:14.651 NQZ1.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 09:49:14.671 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 09:49:14.678 NQZ1.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 09:49:14.698 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 09:49:14.828 NQZ1.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 09:49:14.848 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 09:49:14.853 Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2021-12-14 09:49:14.854 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2021-12-14 09:49:14.855 Starting DelayedDownloadMonitoringTimer | 2021-12-14 09:49:14.855 Starting HDTimeoutTimer | 2021-12-14 09:49:14.855 Added historical Intraday data request for NQZ1.CME to the queue. | 2021-12-14 09:49:14.855 Triggering next historical data download in queue. | 2021-12-14 09:49:14.855 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-12-14 09:49:14.855 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-14 09:49:14.855 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-12-14 09:49:14.855 Added historical Intraday data request for NQH2.CME to the queue. | 2021-12-14 09:49:14.857 NQH2.CME [CV] 1 Min #14 | Performing continuous chart historical Daily data download for symbol NQH2.CME starting at last date in file. | 2021-12-14 09:49:14.858 Added historical Daily data request for NQH2.CME to the queue. | 2021-12-14 09:49:14.858 NQH2.CME [CV] 1 Min #14 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:14.877 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 09:49:14.884 Added historical Intraday data request for NQU1.CME to the queue. | 2021-12-14 09:49:14.886 NQH2.CME [CV] 1 Sec #6 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, | 2021-12-14 09:49:14.948 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 09:49:14.959 NQH2.CME [CV] 60 Min #27 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:14.982 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 09:49:14.993 NQH2.CME [CV] 180 Min #29 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, | 2021-12-14 09:49:15.056 ESH2.CME [CV] 1 Min #9 | Reloading chart. | 2021-12-14 09:49:15.196 Added historical Intraday data request for ESZ1.CME to the queue. | 2021-12-14 09:49:15.196 Added historical Intraday data request for ESH2.CME to the queue. | 2021-12-14 09:49:15.198 ESH2.CME [CV] 1 Min #9 | Performing continuous chart historical Daily data download for symbol ESH2.CME starting at last date in file. | 2021-12-14 09:49:15.199 Added historical Daily data request for ESH2.CME to the queue. | 2021-12-14 09:49:15.199 ESH2.CME [CV] 1 Min #9 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.219 ESH2.CME [CV] 2 Min #12 | Reloading chart. | 2021-12-14 09:49:15.249 ESH2.CME [CV] 2 Min #12 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.272 ESH2.CME [CV] 5 Min #15 | Reloading chart. | 2021-12-14 09:49:15.289 ESH2.CME [CV] 5 Min #15 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.311 ESH2.CME [CV] 180 Min #16 | Reloading chart. | 2021-12-14 09:49:15.324 Added historical Intraday data request for ESU1.CME to the queue. | 2021-12-14 09:49:15.326 ESH2.CME [CV] 180 Min #16 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, | 2021-12-14 09:49:15.386 ESH2.CME [CV] 60 Min #22 | Reloading chart. | 2021-12-14 09:49:15.398 ESH2.CME [CV] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.421 ESH2.CME [CV] 15 Min #24 | Reloading chart. | 2021-12-14 09:49:15.434 ESH2.CME [CV] 15 Min #24 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.457 ESZ1.CME [CV] 5 Min #42 | Reloading chart. | 2021-12-14 09:49:15.465 ESZ1.CME [CV] 5 Min #42 | Performing continuous chart historical Daily data download for symbol ESZ1.CME starting at last date in file. | 2021-12-14 09:49:15.467 Added historical Daily data request for ESZ1.CME to the queue. | 2021-12-14 09:49:15.467 ESZ1.CME [CV] 5 Min #42 | Waiting for historical downloads to complete with the IDs: 6, 10, | 2021-12-14 09:49:15.485 ESZ1.CME [CV] #43 | Reloading chart. | 2021-12-14 09:49:15.492 ESZ1.CME [CV] #43 | Waiting for historical downloads to complete with the IDs: 6, 10, | 2021-12-14 09:49:15.511 ESH2.CME [CV] 1 Min #45 | Reloading chart. | 2021-12-14 09:49:15.517 ESH2.CME [CV] 1 Min #45 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 10, | 2021-12-14 09:49:15.539 ESH2.CME [CV] 1 Min #47 | Reloading chart. | 2021-12-14 09:49:15.546 ESH2.CME [CV] 1 Min #47 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, | 2021-12-14 09:49:15.608 ESH2.CME [CV] 1 Day #38 | Reloading chart. | 2021-12-14 09:49:15.619 Added historical Intraday data request for ESH1.CME to the queue. | 2021-12-14 09:49:15.621 Added historical Intraday data request for ESM1.CME to the queue. | 2021-12-14 09:49:15.623 ESH2.CME [CV] 1 Day #38 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, 11, 12, | 2021-12-14 09:49:15.720 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 09:49:15.732 ESH2.CME [CV] Weekly #40 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:15.732 ESH2.CME [CV] Weekly #40 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:15.732 ESH2.CME [CV] Weekly #40 | Waiting for historical downloads to complete with the IDs: 8, 10, | 2021-12-14 09:49:16.138 BTCZ1.CME [CV] #1 | Reloading chart. | 2021-12-14 09:49:16.146 Added historical Intraday data request for BTCX1.CME to the queue. | 2021-12-14 09:49:16.148 BTCZ1.CME [CV] #1 | Performing continuous chart historical Daily data download for symbol BTCZ1.CME starting at last date in file. | 2021-12-14 09:49:16.151 Added historical Daily data request for BTCZ1.CME to the queue. | 2021-12-14 09:49:16.151 BTCZ1.CME [CV] #1 | Waiting for historical downloads to complete with the IDs: 13, 14, | 2021-12-14 09:49:16.165 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 09:49:16.178 Added historical Intraday data request for NQH1.CME to the queue. | 2021-12-14 09:49:16.180 Added historical Intraday data request for NQM1.CME to the queue. | 2021-12-14 09:49:16.182 NQH2.CME [CV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 15, 16, | 2021-12-14 09:49:16.278 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 09:49:16.286 NQH2.CME [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 16, | 2021-12-14 09:49:16.347 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 09:49:16.362 NQH2.CME [CV] 15 Min #23 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:16.384 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 09:49:16.398 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:16.398 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:16.398 NQH2.CME [CV] Weekly #11 | Waiting for historical downloads to complete with the IDs: 1, 4, | 2021-12-14 09:49:16.802 NQH2.CME [CV] 1 Min #8 | Reloading chart. | 2021-12-14 09:49:16.985 NQH2.CME [CV] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:17.008 NQH2.CME [CV] 5 Min #13 | Reloading chart. | 2021-12-14 09:49:17.042 NQH2.CME [CV] 5 Min #13 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:17.065 NQH2.CME [CV] 2 Min #17 | Reloading chart. | 2021-12-14 09:49:17.100 NQH2.CME [CV] 2 Min #17 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:17.124 HD Request # 1 | Downloading Historical Daily chart data for NQZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:17.147 Rithmic Direct - DTC | Network connection to server complete. | 2021-12-14 09:49:17.148 Rithmic Direct - DTC | Starting socket receive thread. | 2021-12-14 09:49:17.148 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-12-14 09:49:17.148 Rithmic Direct - DTC | Sending logon request message. | 2021-12-14 09:49:17.148 Rithmic Direct - DTC | Received logon response. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Server Name: . | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Successfully connected. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Trading is supported. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Order cancel and replace is supported. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | OCO Orders supported. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Connected to server complete. | 2021-12-14 09:49:17.327 Triggering next historical data download in queue. | 2021-12-14 09:49:17.327 Triggering next historical data download in queue. | 2021-12-14 09:49:17.327 Triggering next historical data download in queue. | 2021-12-14 09:49:17.327 Triggering next historical data download in queue. | 2021-12-14 09:49:17.327 Updated verified funded futures trading account ending date to: 2022-01-13 16:49:17 | 2021-12-14 09:49:17.334 No download requests in the queue to start downloads for. | 2021-12-14 09:49:17.334 HD Request # 2 | Downloading Intraday chart data for NQZ1.CME to the file NQZ1.CME.scid. Service: rithmic.trading | 2021-12-14 09:49:17.334 HD Request # 2 | Download start date-time: 2021-09-10 06:33:34.000000. File last date-time: 2021-09-10 06:33:34.679000 | 2021-12-14 09:49:17.335 HD Request # 2 | Using server: rsc.rithmic.com port 50505. Use encryption. | 2021-12-14 09:49:17.335 No download requests in the queue to start downloads for. | 2021-12-14 09:49:17.335 Socket (3) | Creating socket. Using TLS 1.2. | 2021-12-14 09:49:17.335 Socket (3) | New receive buffer size: 5242880 | 2021-12-14 09:49:17.335 Socket (3) | Connecting to IP: 216.57.156.163. | 2021-12-14 09:49:17.335 HD Request # 2 | Sending historical data logon request message. | 2021-12-14 09:49:17.390 Updated verified funded futures trading account ending date to: 2022-01-13 16:49:17 | 2021-12-14 09:49:17.391 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-09-10 06:33:34. Record interval: 0. Symbol: NQZ1.CME | 2021-12-14 09:49:17.568 HD Request # 2 | Receiving Intraday data for NQZ1.CME starting at 2021-09-10 06:33:34.675000 | 2021-12-14 09:49:17.629 HD Request # 1 | Requesting historical Daily data for NQZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:17.917 HD Request # 1 | Receiving historical Daily data for NQZ1.CME starting at 2021-12-09 | 2021-12-14 09:49:18.263 HD Request # 1 | Writing historical Daily data to the file NQZ1.CME.dly | 2021-12-14 09:49:18.263 HD Request # 1 | Bytes received: 258 | 2021-12-14 09:49:18.268 HD Request # 1 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQZ1.CME | 2021-12-14 09:49:18.268 HD Request # 1 | Completion time: 1s | 2021-12-14 09:49:18.268 HD Request # 1 | Daily data download complete for NQZ1.CME. Unique request ID: 1 | 2021-12-14 09:49:18.268 Removing historical data download ID 1. | 2021-12-14 09:49:18.268 Triggering next historical data download in queue. | 2021-12-14 09:49:18.268 HD Request # 3 | Downloading Historical Daily chart data for NQH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:18.270 NQZ1.CME [CV] #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:18.270 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 09:49:18.271 NQZ1.CME [CV] #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:18.349 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 09:49:18.349 NQZ1.CME [CV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:18.353 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 09:49:18.354 NQZ1.CME [CV] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:18.357 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 09:49:18.359 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 09:49:18.377 NQZ1.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 09:49:18.396 NQZ1.CME [CV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:18.397 NQZ1.CME [CV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:18.412 NQZ1.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:18.488 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 09:49:18.496 NQZ1.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 09:49:18.515 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 09:49:18.516 NQZ1.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 09:49:18.536 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 09:49:18.537 NQZ1.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 09:49:18.556 HD Request # 3 | Requesting historical Daily data for NQH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:19.085 HD Request # 3 | Receiving historical Daily data for NQH2.CME starting at 2021-12-09 | 2021-12-14 09:49:19.364 HD Request # 3 | Writing historical Daily data to the file NQH2.CME.dly | 2021-12-14 09:49:19.365 HD Request # 3 | Bytes received: 248 | 2021-12-14 09:49:19.367 HD Request # 3 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQH2.CME | 2021-12-14 09:49:19.367 HD Request # 3 | Completion time: 1s | 2021-12-14 09:49:19.367 HD Request # 3 | Daily data download complete for NQH2.CME. Unique request ID: 4 | 2021-12-14 09:49:19.367 Removing historical data download ID 4. | 2021-12-14 09:49:19.367 Triggering next historical data download in queue. | 2021-12-14 09:49:19.367 HD Request # 4 | Downloading Historical Daily chart data for ESH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:19.369 NQH2.CME [CV] Weekly #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:19.454 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 09:49:19.457 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 09:49:19.567 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:19.567 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:19.567 Restarting the loading process. | 2021-12-14 09:49:20.049 Rithmic Direct - DTC | Starting real-time market data updates for: NQH2.CME. ID: 2 Service code: rithmic.trading | 2021-12-14 09:49:20.052 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50504 | 2021-12-14 09:49:20.052 Rithmic Direct - DTC | Requesting security definition data for: NQH2.CME. ID: 2 | 2021-12-14 09:49:20.052 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-12-14 09:49:20.052 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-12-14 09:49:20.052 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-12-14 09:49:20.052 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:20.110 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2021-12-14 09:49:20.136 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2021-12-14 09:49:20.136 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2021-12-14 09:49:20.137 Rithmic Direct - DTC (Data) | Sending logon request message. | 2021-12-14 09:49:20.137 HD Request # 4 | Requesting historical Daily data for ESH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:20.148 Rithmic Direct - DTC (Data) | Received logon response. | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Server Name: . | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Successfully connected. | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Trading is not supported. | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQH2.CME | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Received security definition for symbol NQH2.CME | 2021-12-14 09:49:20.407 HD Request # 4 | Receiving historical Daily data for ESH2.CME starting at 2021-12-09 | 2021-12-14 09:49:20.409 HD Request # 4 | Writing historical Daily data to the file ESH2.CME.dly | 2021-12-14 09:49:20.409 HD Request # 4 | Bytes received: 243 | 2021-12-14 09:49:20.415 HD Request # 4 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for ESH2.CME | 2021-12-14 09:49:20.415 HD Request # 4 | Completion time: 1s | 2021-12-14 09:49:20.416 HD Request # 4 | Daily data download complete for ESH2.CME. Unique request ID: 8 | 2021-12-14 09:49:20.416 Removing historical data download ID 8. | 2021-12-14 09:49:20.416 Triggering next historical data download in queue. | 2021-12-14 09:49:20.416 HD Request # 5 | Downloading Historical Daily chart data for ESZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:20.420 HD Request # 5 | Requesting historical Daily data for ESZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:21.187 HD Request # 5 | Receiving historical Daily data for ESZ1.CME starting at 2021-12-09 | 2021-12-14 09:49:21.411 HD Request # 5 | Writing historical Daily data to the file ESZ1.CME.dly | 2021-12-14 09:49:21.412 HD Request # 5 | Bytes received: 242 | 2021-12-14 09:49:21.415 HD Request # 5 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for ESZ1.CME | 2021-12-14 09:49:21.415 HD Request # 5 | Completion time: 1s | 2021-12-14 09:49:21.415 HD Request # 5 | Daily data download complete for ESZ1.CME. Unique request ID: 10 | 2021-12-14 09:49:21.415 Removing historical data download ID 10. | 2021-12-14 09:49:21.415 Triggering next historical data download in queue. | 2021-12-14 09:49:21.415 HD Request # 6 | Downloading Historical Daily chart data for BTCZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:21.417 ESH2.CME [CV] Weekly #40 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:21.420 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 09:49:21.421 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 09:49:21.543 ESH2.CME [CV] Weekly #40 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:21.543 ESH2.CME [CV] Weekly #40 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:21.543 Restarting the loading process. | 2021-12-14 09:49:22.038 Rithmic Direct - DTC | Starting real-time market data updates for: ESH2.CME. ID: 3 Service code: rithmic.trading | 2021-12-14 09:49:22.052 Rithmic Direct - DTC | Requesting security definition data for: ESH2.CME. ID: 3 | 2021-12-14 09:49:22.052 ESH2.CME [CV] Weekly #40 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:22.098 Requesting market depth updates for: ESH2.CME if supported. | 2021-12-14 09:49:22.341 Requesting market depth updates for: NQH2.CME if supported. | 2021-12-14 09:49:22.341 Rithmic Direct - DTC | Starting real-time market data updates for: NQZ1.CME. ID: 1 Service code: rithmic.trading | 2021-12-14 09:49:22.341 Rithmic Direct - DTC | Requesting security definition data for: NQZ1.CME. ID: 1 | 2021-12-14 09:49:22.341 Requesting market depth updates for: NQZ1.CME if supported. | 2021-12-14 09:49:22.341 Rithmic Direct - DTC (Data) | Clearing market depth for ESH2.CME | 2021-12-14 09:49:22.441 HD Request # 6 | Requesting historical Daily data for BTZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:22.626 Rithmic Direct - DTC (Data) | Clearing market depth for NQH2.CME | 2021-12-14 09:49:22.759 HD Request # 6 | Receiving historical Daily data for BTCZ1.CME starting at 2021-12-09 | 2021-12-14 09:49:22.822 HD Request # 6 | Writing historical Daily data to the file BTCZ1.CME.dly | 2021-12-14 09:49:22.823 HD Request # 6 | Bytes received: 204 | 2021-12-14 09:49:22.830 HD Request # 6 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for BTCZ1.CME | 2021-12-14 09:49:22.830 HD Request # 6 | Completion time: 1s | 2021-12-14 09:49:22.830 HD Request # 6 | Daily data download complete for BTCZ1.CME. Unique request ID: 14 | 2021-12-14 09:49:22.830 Removing historical data download ID 14. | 2021-12-14 09:49:22.830 Triggering next historical data download in queue. | 2021-12-14 09:49:22.830 No download requests in the queue to start downloads for. | 2021-12-14 09:49:22.830 Rithmic Direct - DTC (Data) | Clearing market depth for NQZ1.CME | 2021-12-14 09:49:23.071 Saved Chartbook: Nasdaq.Cht. Time: 0.0695 seconds. | 2021-12-14 10:04:08.445 Saved Chartbook: Nasdaq.Cht. Time: 0.0669 seconds. | 2021-12-14 10:19:08.528 |
[2021-12-14 18:19:48] |
John - SC Support - Posts: 40812 |
The problem is that you can not use the Continuous Futures Contracts option with Rithmic data. They do not support the historical data for previous contracts, so you will never get out of the loop you are in - of the system trying to get the previous data, then failing. Remove the Continuous Futures Contract option from your charts and then let us know if you are still having an issue. For reference, here is the link to the documentation for setting the Continuous Contract: Chart Settings: Continuous Contract (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-14 19:16:55] |
I removed the Continuous Futures Contract option and replaced it with none. I did it with just 3 of my charts to see if it is working. Some data appeared right after I updated the chart as before it was complitely blank. For December contracts that are expiring on Friday charts were in "Waiting to Download Historical Data" mode and for March contracts charts were in "Downloading Historical Data, Bars may Not Appear until done" mode for a while. And still no real time data received. I wonder what can be done here so I can keep Rithmic lowest margin and have a good connection. I don not want to switch platforms as I am very happy with what I have with Sierra Chart and what Sierra Chart provides. Should I switch back to your older software version? Everything worked fine there. Here is a message log again if you need it: HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2021-12-14 09:49:08.585 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2021-12-14 09:49:08.585 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2021-12-14 09:49:08.585 Created the DTC Protocol server. | 2021-12-14 09:49:08.617 DTC Protocol Server listening on port 11099. | 2021-12-14 09:49:08.619 Reading Internal Order ID file. | 2021-12-14 09:49:08.619 Reading Trade Orders file. | 2021-12-14 09:49:08.683 Reading Trade Positions file. | 2021-12-14 09:49:08.683 Reading Trade Account Data files. | 2021-12-14 09:49:08.683 UDPListener (1472). Port 22904 | Listening on UDP port 22904. | 2021-12-14 09:49:08.706 Software version: 2333 64-bit | 2021-12-14 09:49:08.706 Safe Mode enabled | 2021-12-14 09:49:08.706 Primary Thread ID: 16464 | 2021-12-14 09:49:08.706 Usage end date: 2022-01-03 | 2021-12-14 09:49:08.706 Enabled for: Advanced Features 2. | 2021-12-14 09:49:08.706 Enabled for: Sierra Chart Historical Data Service. | 2021-12-14 09:49:08.706 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-12-14 09:49:08.706 Enabled for: Delayed Denali Exchange Data Feed. | 2021-12-14 09:49:08.706 Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX) | 2021-12-14 09:49:08.706 Enabled for exchange: TSX Equities | 2021-12-14 09:49:08.706 Enabled for exchange: Euronext Equities Delayed | 2021-12-14 09:49:08.706 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-12-14 09:49:08.706 Current selected Data/Trading service: Rithmic Direct - DTC | 2021-12-14 09:49:08.706 Custom symbol settings values: disabled | 2021-12-14 09:49:08.706 Chart Update Interval: 100 | 2021-12-14 09:49:08.706 Intraday Data Storage Time Unit: 0 | 2021-12-14 09:49:08.706 Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-12-14 09:49:08.706 2021-12-14 16:49:08 Local computer time in UTC | 2021-12-14 09:49:08.706 2021-12-14 09:49:08 Local computer time in SC Time Zone | 2021-12-14 09:49:08.706 2021-12-14 16:49:08 Server time in UTC | 2021-12-14 09:49:08.706 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-12-14 09:49:08.706 Program path: C:\SierraChart\ | 2021-12-14 09:49:08.706 Data Files path: C:\SierraChart\Data\ | 2021-12-14 09:49:08.706 OS Version Number: 10.0 | 2021-12-14 09:49:08.706 Locale Setting: C | 2021-12-14 09:49:08.706 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll, zyp sierra free_64.dll | 2021-12-14 09:49:08.708 Allowed protected custom studies: zyp_download_free | 2021-12-14 09:49:08.708 Created the DTC Protocol historical data server. | 2021-12-14 09:49:08.727 HD Server Manager | Listening on port 11098. | 2021-12-14 09:49:08.729 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2021-12-14 09:49:08.729 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-12-14 09:49:08.794 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-12-14 09:49:08.958 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-12-14 09:49:08.958 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2021-12-14 09:49:09.011 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2021-12-14 09:49:09.011 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-12-14 09:49:09.011 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2021-12-14 09:49:09.011 Received 5 login tokens. | 2021-12-14 09:49:09.277 Symbol settings MD5 received. Request ID: 1. | 2021-12-14 09:49:09.489 Symbol settings are up-to-date for rithmic_v2.trading. | 2021-12-14 09:49:09.489 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 09:49:14.625 NQZ1.CME [CV] 5 Min #2 | Performing continuous chart historical Daily data download for symbol NQZ1.CME starting at last date in file. | 2021-12-14 09:49:14.627 Starting DelayedDownloadMonitoringTimer | 2021-12-14 09:49:14.627 Starting HDTimeoutTimer | 2021-12-14 09:49:14.627 Added historical Daily data request for NQZ1.CME to the queue. | 2021-12-14 09:49:14.627 Triggering next historical data download in queue. | 2021-12-14 09:49:14.627 NQZ1.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 09:49:14.645 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 09:49:14.651 NQZ1.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 09:49:14.671 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 09:49:14.678 NQZ1.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 09:49:14.698 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 09:49:14.828 NQZ1.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 1, | 2021-12-14 09:49:14.848 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 09:49:14.853 Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2021-12-14 09:49:14.854 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2021-12-14 09:49:14.855 Starting DelayedDownloadMonitoringTimer | 2021-12-14 09:49:14.855 Starting HDTimeoutTimer | 2021-12-14 09:49:14.855 Added historical Intraday data request for NQZ1.CME to the queue. | 2021-12-14 09:49:14.855 Triggering next historical data download in queue. | 2021-12-14 09:49:14.855 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-12-14 09:49:14.855 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-14 09:49:14.855 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-12-14 09:49:14.855 Added historical Intraday data request for NQH2.CME to the queue. | 2021-12-14 09:49:14.857 NQH2.CME [CV] 1 Min #14 | Performing continuous chart historical Daily data download for symbol NQH2.CME starting at last date in file. | 2021-12-14 09:49:14.858 Added historical Daily data request for NQH2.CME to the queue. | 2021-12-14 09:49:14.858 NQH2.CME [CV] 1 Min #14 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:14.877 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 09:49:14.884 Added historical Intraday data request for NQU1.CME to the queue. | 2021-12-14 09:49:14.886 NQH2.CME [CV] 1 Sec #6 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, | 2021-12-14 09:49:14.948 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 09:49:14.959 NQH2.CME [CV] 60 Min #27 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:14.982 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 09:49:14.993 NQH2.CME [CV] 180 Min #29 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, | 2021-12-14 09:49:15.056 ESH2.CME [CV] 1 Min #9 | Reloading chart. | 2021-12-14 09:49:15.196 Added historical Intraday data request for ESZ1.CME to the queue. | 2021-12-14 09:49:15.196 Added historical Intraday data request for ESH2.CME to the queue. | 2021-12-14 09:49:15.198 ESH2.CME [CV] 1 Min #9 | Performing continuous chart historical Daily data download for symbol ESH2.CME starting at last date in file. | 2021-12-14 09:49:15.199 Added historical Daily data request for ESH2.CME to the queue. | 2021-12-14 09:49:15.199 ESH2.CME [CV] 1 Min #9 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.219 ESH2.CME [CV] 2 Min #12 | Reloading chart. | 2021-12-14 09:49:15.249 ESH2.CME [CV] 2 Min #12 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.272 ESH2.CME [CV] 5 Min #15 | Reloading chart. | 2021-12-14 09:49:15.289 ESH2.CME [CV] 5 Min #15 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.311 ESH2.CME [CV] 180 Min #16 | Reloading chart. | 2021-12-14 09:49:15.324 Added historical Intraday data request for ESU1.CME to the queue. | 2021-12-14 09:49:15.326 ESH2.CME [CV] 180 Min #16 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, | 2021-12-14 09:49:15.386 ESH2.CME [CV] 60 Min #22 | Reloading chart. | 2021-12-14 09:49:15.398 ESH2.CME [CV] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.421 ESH2.CME [CV] 15 Min #24 | Reloading chart. | 2021-12-14 09:49:15.434 ESH2.CME [CV] 15 Min #24 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, | 2021-12-14 09:49:15.457 ESZ1.CME [CV] 5 Min #42 | Reloading chart. | 2021-12-14 09:49:15.465 ESZ1.CME [CV] 5 Min #42 | Performing continuous chart historical Daily data download for symbol ESZ1.CME starting at last date in file. | 2021-12-14 09:49:15.467 Added historical Daily data request for ESZ1.CME to the queue. | 2021-12-14 09:49:15.467 ESZ1.CME [CV] 5 Min #42 | Waiting for historical downloads to complete with the IDs: 6, 10, | 2021-12-14 09:49:15.485 ESZ1.CME [CV] #43 | Reloading chart. | 2021-12-14 09:49:15.492 ESZ1.CME [CV] #43 | Waiting for historical downloads to complete with the IDs: 6, 10, | 2021-12-14 09:49:15.511 ESH2.CME [CV] 1 Min #45 | Reloading chart. | 2021-12-14 09:49:15.517 ESH2.CME [CV] 1 Min #45 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 10, | 2021-12-14 09:49:15.539 ESH2.CME [CV] 1 Min #47 | Reloading chart. | 2021-12-14 09:49:15.546 ESH2.CME [CV] 1 Min #47 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, | 2021-12-14 09:49:15.608 ESH2.CME [CV] 1 Day #38 | Reloading chart. | 2021-12-14 09:49:15.619 Added historical Intraday data request for ESH1.CME to the queue. | 2021-12-14 09:49:15.621 Added historical Intraday data request for ESM1.CME to the queue. | 2021-12-14 09:49:15.623 ESH2.CME [CV] 1 Day #38 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, 11, 12, | 2021-12-14 09:49:15.720 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 09:49:15.732 ESH2.CME [CV] Weekly #40 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:15.732 ESH2.CME [CV] Weekly #40 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:15.732 ESH2.CME [CV] Weekly #40 | Waiting for historical downloads to complete with the IDs: 8, 10, | 2021-12-14 09:49:16.138 BTCZ1.CME [CV] #1 | Reloading chart. | 2021-12-14 09:49:16.146 Added historical Intraday data request for BTCX1.CME to the queue. | 2021-12-14 09:49:16.148 BTCZ1.CME [CV] #1 | Performing continuous chart historical Daily data download for symbol BTCZ1.CME starting at last date in file. | 2021-12-14 09:49:16.151 Added historical Daily data request for BTCZ1.CME to the queue. | 2021-12-14 09:49:16.151 BTCZ1.CME [CV] #1 | Waiting for historical downloads to complete with the IDs: 13, 14, | 2021-12-14 09:49:16.165 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 09:49:16.178 Added historical Intraday data request for NQH1.CME to the queue. | 2021-12-14 09:49:16.180 Added historical Intraday data request for NQM1.CME to the queue. | 2021-12-14 09:49:16.182 NQH2.CME [CV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 15, 16, | 2021-12-14 09:49:16.278 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 09:49:16.286 NQH2.CME [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 16, | 2021-12-14 09:49:16.347 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 09:49:16.362 NQH2.CME [CV] 15 Min #23 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:16.384 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 09:49:16.398 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:16.398 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:16.398 NQH2.CME [CV] Weekly #11 | Waiting for historical downloads to complete with the IDs: 1, 4, | 2021-12-14 09:49:16.802 NQH2.CME [CV] 1 Min #8 | Reloading chart. | 2021-12-14 09:49:16.985 NQH2.CME [CV] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:17.008 NQH2.CME [CV] 5 Min #13 | Reloading chart. | 2021-12-14 09:49:17.042 NQH2.CME [CV] 5 Min #13 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:17.065 NQH2.CME [CV] 2 Min #17 | Reloading chart. | 2021-12-14 09:49:17.100 NQH2.CME [CV] 2 Min #17 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, | 2021-12-14 09:49:17.124 HD Request # 1 | Downloading Historical Daily chart data for NQZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:17.147 Rithmic Direct - DTC | Network connection to server complete. | 2021-12-14 09:49:17.148 Rithmic Direct - DTC | Starting socket receive thread. | 2021-12-14 09:49:17.148 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-12-14 09:49:17.148 Rithmic Direct - DTC | Sending logon request message. | 2021-12-14 09:49:17.148 Rithmic Direct - DTC | Received logon response. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Server Name: . | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Successfully connected. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Trading is supported. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Order cancel and replace is supported. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | OCO Orders supported. | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2021-12-14 09:49:17.327 Rithmic Direct - DTC | Connected to server complete. | 2021-12-14 09:49:17.327 Triggering next historical data download in queue. | 2021-12-14 09:49:17.327 Triggering next historical data download in queue. | 2021-12-14 09:49:17.327 Triggering next historical data download in queue. | 2021-12-14 09:49:17.327 Triggering next historical data download in queue. | 2021-12-14 09:49:17.327 Updated verified funded futures trading account ending date to: 2022-01-13 16:49:17 | 2021-12-14 09:49:17.334 No download requests in the queue to start downloads for. | 2021-12-14 09:49:17.334 HD Request # 2 | Downloading Intraday chart data for NQZ1.CME to the file NQZ1.CME.scid. Service: rithmic.trading | 2021-12-14 09:49:17.334 HD Request # 2 | Download start date-time: 2021-09-10 06:33:34.000000. File last date-time: 2021-09-10 06:33:34.679000 | 2021-12-14 09:49:17.335 HD Request # 2 | Using server: rsc.rithmic.com port 50505. Use encryption. | 2021-12-14 09:49:17.335 No download requests in the queue to start downloads for. | 2021-12-14 09:49:17.335 Socket (3) | Creating socket. Using TLS 1.2. | 2021-12-14 09:49:17.335 Socket (3) | New receive buffer size: 5242880 | 2021-12-14 09:49:17.335 Socket (3) | Connecting to IP: 216.57.156.163. | 2021-12-14 09:49:17.335 HD Request # 2 | Sending historical data logon request message. | 2021-12-14 09:49:17.390 Updated verified funded futures trading account ending date to: 2022-01-13 16:49:17 | 2021-12-14 09:49:17.391 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-09-10 06:33:34. Record interval: 0. Symbol: NQZ1.CME | 2021-12-14 09:49:17.568 HD Request # 2 | Receiving Intraday data for NQZ1.CME starting at 2021-09-10 06:33:34.675000 | 2021-12-14 09:49:17.629 HD Request # 1 | Requesting historical Daily data for NQZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:17.917 HD Request # 1 | Receiving historical Daily data for NQZ1.CME starting at 2021-12-09 | 2021-12-14 09:49:18.263 HD Request # 1 | Writing historical Daily data to the file NQZ1.CME.dly | 2021-12-14 09:49:18.263 HD Request # 1 | Bytes received: 258 | 2021-12-14 09:49:18.268 HD Request # 1 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQZ1.CME | 2021-12-14 09:49:18.268 HD Request # 1 | Completion time: 1s | 2021-12-14 09:49:18.268 HD Request # 1 | Daily data download complete for NQZ1.CME. Unique request ID: 1 | 2021-12-14 09:49:18.268 Removing historical data download ID 1. | 2021-12-14 09:49:18.268 Triggering next historical data download in queue. | 2021-12-14 09:49:18.268 HD Request # 3 | Downloading Historical Daily chart data for NQH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:18.270 NQZ1.CME [CV] #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:18.270 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 09:49:18.271 NQZ1.CME [CV] #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:18.349 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 09:49:18.349 NQZ1.CME [CV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:18.353 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 09:49:18.354 NQZ1.CME [CV] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:18.357 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 09:49:18.359 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 09:49:18.377 NQZ1.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 09:49:18.396 NQZ1.CME [CV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:18.397 NQZ1.CME [CV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:18.412 NQZ1.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:18.488 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 09:49:18.496 NQZ1.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 09:49:18.515 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 09:49:18.516 NQZ1.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 09:49:18.536 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 09:49:18.537 NQZ1.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 2, | 2021-12-14 09:49:18.556 HD Request # 3 | Requesting historical Daily data for NQH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:19.085 HD Request # 3 | Receiving historical Daily data for NQH2.CME starting at 2021-12-09 | 2021-12-14 09:49:19.364 HD Request # 3 | Writing historical Daily data to the file NQH2.CME.dly | 2021-12-14 09:49:19.365 HD Request # 3 | Bytes received: 248 | 2021-12-14 09:49:19.367 HD Request # 3 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQH2.CME | 2021-12-14 09:49:19.367 HD Request # 3 | Completion time: 1s | 2021-12-14 09:49:19.367 HD Request # 3 | Daily data download complete for NQH2.CME. Unique request ID: 4 | 2021-12-14 09:49:19.367 Removing historical data download ID 4. | 2021-12-14 09:49:19.367 Triggering next historical data download in queue. | 2021-12-14 09:49:19.367 HD Request # 4 | Downloading Historical Daily chart data for ESH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:19.369 NQH2.CME [CV] Weekly #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:19.454 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 09:49:19.457 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 09:49:19.567 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:19.567 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:19.567 Restarting the loading process. | 2021-12-14 09:49:20.049 Rithmic Direct - DTC | Starting real-time market data updates for: NQH2.CME. ID: 2 Service code: rithmic.trading | 2021-12-14 09:49:20.052 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50504 | 2021-12-14 09:49:20.052 Rithmic Direct - DTC | Requesting security definition data for: NQH2.CME. ID: 2 | 2021-12-14 09:49:20.052 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-12-14 09:49:20.052 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-12-14 09:49:20.052 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-12-14 09:49:20.052 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:20.110 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2021-12-14 09:49:20.136 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2021-12-14 09:49:20.136 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2021-12-14 09:49:20.137 Rithmic Direct - DTC (Data) | Sending logon request message. | 2021-12-14 09:49:20.137 HD Request # 4 | Requesting historical Daily data for ESH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:20.148 Rithmic Direct - DTC (Data) | Received logon response. | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Server Name: . | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Successfully connected. | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Trading is not supported. | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQH2.CME | 2021-12-14 09:49:20.318 Rithmic Direct - DTC (Data) | Received security definition for symbol NQH2.CME | 2021-12-14 09:49:20.407 HD Request # 4 | Receiving historical Daily data for ESH2.CME starting at 2021-12-09 | 2021-12-14 09:49:20.409 HD Request # 4 | Writing historical Daily data to the file ESH2.CME.dly | 2021-12-14 09:49:20.409 HD Request # 4 | Bytes received: 243 | 2021-12-14 09:49:20.415 HD Request # 4 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for ESH2.CME | 2021-12-14 09:49:20.415 HD Request # 4 | Completion time: 1s | 2021-12-14 09:49:20.416 HD Request # 4 | Daily data download complete for ESH2.CME. Unique request ID: 8 | 2021-12-14 09:49:20.416 Removing historical data download ID 8. | 2021-12-14 09:49:20.416 Triggering next historical data download in queue. | 2021-12-14 09:49:20.416 HD Request # 5 | Downloading Historical Daily chart data for ESZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:20.420 HD Request # 5 | Requesting historical Daily data for ESZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:21.187 HD Request # 5 | Receiving historical Daily data for ESZ1.CME starting at 2021-12-09 | 2021-12-14 09:49:21.411 HD Request # 5 | Writing historical Daily data to the file ESZ1.CME.dly | 2021-12-14 09:49:21.412 HD Request # 5 | Bytes received: 242 | 2021-12-14 09:49:21.415 HD Request # 5 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for ESZ1.CME | 2021-12-14 09:49:21.415 HD Request # 5 | Completion time: 1s | 2021-12-14 09:49:21.415 HD Request # 5 | Daily data download complete for ESZ1.CME. Unique request ID: 10 | 2021-12-14 09:49:21.415 Removing historical data download ID 10. | 2021-12-14 09:49:21.415 Triggering next historical data download in queue. | 2021-12-14 09:49:21.415 HD Request # 6 | Downloading Historical Daily chart data for BTCZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 09:49:21.417 ESH2.CME [CV] Weekly #40 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 09:49:21.420 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 09:49:21.421 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 09:49:21.543 ESH2.CME [CV] Weekly #40 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:21.543 ESH2.CME [CV] Weekly #40 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 09:49:21.543 Restarting the loading process. | 2021-12-14 09:49:22.038 Rithmic Direct - DTC | Starting real-time market data updates for: ESH2.CME. ID: 3 Service code: rithmic.trading | 2021-12-14 09:49:22.052 Rithmic Direct - DTC | Requesting security definition data for: ESH2.CME. ID: 3 | 2021-12-14 09:49:22.052 ESH2.CME [CV] Weekly #40 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 09:49:22.098 Requesting market depth updates for: ESH2.CME if supported. | 2021-12-14 09:49:22.341 Requesting market depth updates for: NQH2.CME if supported. | 2021-12-14 09:49:22.341 Rithmic Direct - DTC | Starting real-time market data updates for: NQZ1.CME. ID: 1 Service code: rithmic.trading | 2021-12-14 09:49:22.341 Rithmic Direct - DTC | Requesting security definition data for: NQZ1.CME. ID: 1 | 2021-12-14 09:49:22.341 Requesting market depth updates for: NQZ1.CME if supported. | 2021-12-14 09:49:22.341 Rithmic Direct - DTC (Data) | Clearing market depth for ESH2.CME | 2021-12-14 09:49:22.441 HD Request # 6 | Requesting historical Daily data for BTZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 09:49:22.626 Rithmic Direct - DTC (Data) | Clearing market depth for NQH2.CME | 2021-12-14 09:49:22.759 HD Request # 6 | Receiving historical Daily data for BTCZ1.CME starting at 2021-12-09 | 2021-12-14 09:49:22.822 HD Request # 6 | Writing historical Daily data to the file BTCZ1.CME.dly | 2021-12-14 09:49:22.823 HD Request # 6 | Bytes received: 204 | 2021-12-14 09:49:22.830 HD Request # 6 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for BTCZ1.CME | 2021-12-14 09:49:22.830 HD Request # 6 | Completion time: 1s | 2021-12-14 09:49:22.830 HD Request # 6 | Daily data download complete for BTCZ1.CME. Unique request ID: 14 | 2021-12-14 09:49:22.830 Removing historical data download ID 14. | 2021-12-14 09:49:22.830 Triggering next historical data download in queue. | 2021-12-14 09:49:22.830 No download requests in the queue to start downloads for. | 2021-12-14 09:49:22.830 Rithmic Direct - DTC (Data) | Clearing market depth for NQZ1.CME | 2021-12-14 09:49:23.071 Saved Chartbook: Nasdaq.Cht. Time: 0.0695 seconds. | 2021-12-14 10:04:08.445 Saved Chartbook: Nasdaq.Cht. Time: 0.0669 seconds. | 2021-12-14 10:19:08.528 Saved Chartbook: Nasdaq.Cht. Time: 0.0674 seconds. | 2021-12-14 10:34:08.605 Intraday data recording state for symbol NQH2.CME is set to download 'Pending'. | 2021-12-14 10:47:12.329 Historical Intraday data request for NQH2.CME is discarded because a matching download is already pending and the new one is not for earlier data. | 2021-12-14 10:47:12.329 Starting downloads for all open Historical Daily data charts. | 2021-12-14 10:47:19.578 Added historical Daily data request for ESH2.CME to the queue. | 2021-12-14 10:47:19.578 Triggering next historical data download in queue. | 2021-12-14 10:47:19.578 Added historical Daily data request for NQH2.CME to the queue. | 2021-12-14 10:47:19.578 HD Request # 7 | Downloading Historical Daily chart data for ESH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 10:47:19.580 HD Request # 7 | Requesting historical Daily data for ESH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 10:47:20.343 HD Request # 7 | Receiving historical Daily data for ESH2.CME starting at 2021-12-09 | 2021-12-14 10:47:21.004 HD Request # 7 | Writing historical Daily data to the file ESH2.CME.dly | 2021-12-14 10:47:21.005 HD Request # 7 | Bytes received: 243 | 2021-12-14 10:47:21.007 HD Request # 7 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for ESH2.CME | 2021-12-14 10:47:21.007 HD Request # 7 | Completion time: 2s | 2021-12-14 10:47:21.007 HD Request # 7 | Daily data download complete for ESH2.CME. Unique request ID: 18 | 2021-12-14 10:47:21.007 Removing historical data download ID 18. | 2021-12-14 10:47:21.007 Triggering next historical data download in queue. | 2021-12-14 10:47:21.007 HD Request # 8 | Downloading Historical Daily chart data for NQH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 10:47:21.009 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 10:47:21.047 ESH2.CME [CV] Weekly #40 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 10:47:21.047 ESH2.CME [CV] Weekly #40 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 10:47:21.047 ESH2.CME [CV] Weekly #40 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 10:47:21.601 Added historical Daily data request for ESH2.CME to the queue. | 2021-12-14 10:47:21.718 Triggering next historical data download in queue. | 2021-12-14 10:47:21.718 HD Request # 8 | Requesting historical Daily data for NQH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 10:47:22.123 HD Request # 8 | Receiving historical Daily data for NQH2.CME starting at 2021-12-09 | 2021-12-14 10:47:22.355 HD Request # 8 | Writing historical Daily data to the file NQH2.CME.dly | 2021-12-14 10:47:22.355 HD Request # 8 | Bytes received: 248 | 2021-12-14 10:47:22.357 HD Request # 8 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQH2.CME | 2021-12-14 10:47:22.357 HD Request # 8 | Completion time: 1s | 2021-12-14 10:47:22.357 HD Request # 8 | Daily data download complete for NQH2.CME. Unique request ID: 19 | 2021-12-14 10:47:22.357 Removing historical data download ID 19. | 2021-12-14 10:47:22.357 Triggering next historical data download in queue. | 2021-12-14 10:47:22.357 HD Request # 9 | Downloading Historical Daily chart data for ESH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 10:47:22.359 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 10:47:22.467 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 10:47:22.467 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 10:47:22.467 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 10:47:23.019 Added historical Daily data request for NQH2.CME to the queue. | 2021-12-14 10:47:23.139 Triggering next historical data download in queue. | 2021-12-14 10:47:23.139 HD Request # 9 | Requesting historical Daily data for ESH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 10:47:23.554 HD Request # 9 | Receiving historical Daily data for ESH2.CME starting at 2021-12-09 | 2021-12-14 10:47:23.945 HD Request # 9 | Writing historical Daily data to the file ESH2.CME.dly | 2021-12-14 10:47:23.945 HD Request # 9 | Bytes received: 243 | 2021-12-14 10:47:23.948 HD Request # 9 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for ESH2.CME | 2021-12-14 10:47:23.948 HD Request # 9 | Completion time: 1s | 2021-12-14 10:47:23.948 HD Request # 9 | Daily data download complete for ESH2.CME. Unique request ID: 20 | 2021-12-14 10:47:23.948 Removing historical data download ID 20. | 2021-12-14 10:47:23.948 Triggering next historical data download in queue. | 2021-12-14 10:47:23.948 HD Request # 10 | Downloading Historical Daily chart data for NQH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 10:47:23.951 ESH2.CME [CV] Weekly #40 | Reloading chart. | 2021-12-14 10:47:23.976 ESH2.CME [CV] Weekly #40 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 10:47:23.976 ESH2.CME [CV] Weekly #40 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 10:47:23.976 ESH2.CME [CV] Weekly #40 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 10:47:24.530 HD Request # 10 | Requesting historical Daily data for NQH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 10:47:25.056 HD Request # 10 | Receiving historical Daily data for NQH2.CME starting at 2021-12-09 | 2021-12-14 10:47:25.310 HD Request # 10 | Writing historical Daily data to the file NQH2.CME.dly | 2021-12-14 10:47:25.310 HD Request # 10 | Bytes received: 248 | 2021-12-14 10:47:25.313 HD Request # 10 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQH2.CME | 2021-12-14 10:47:25.313 HD Request # 10 | Completion time: 2s | 2021-12-14 10:47:25.314 HD Request # 10 | Daily data download complete for NQH2.CME. Unique request ID: 21 | 2021-12-14 10:47:25.314 Removing historical data download ID 21. | 2021-12-14 10:47:25.314 Triggering next historical data download in queue. | 2021-12-14 10:47:25.314 No download requests in the queue to start downloads for. | 2021-12-14 10:47:25.314 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 10:47:25.339 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 10:47:25.339 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 10:47:25.339 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 10:47:25.889 Saved Chartbook: Nasdaq.Cht. Time: 0.0695 seconds. | 2021-12-14 10:49:08.676 Saved Chartbook: Nasdaq.Cht. Time: 0.0709 seconds. | 2021-12-14 11:04:08.761 Saved Chartbook: Nasdaq.Cht. Time: 0.0701 seconds. | 2021-12-14 11:19:08.843 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2021-12-14 11:24:01.080 DTC Client socket (2) | CloseSocket call. | 2021-12-14 11:24:01.080 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-12-14 11:24:01.080 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2021-12-14 11:24:01.080 WSACleanup called. | 2021-12-14 11:24:01.080 Canceling queued historical data download request for NQH2.CME Intraday data. | 2021-12-14 11:24:01.080 Removing historical data download ID 3. | 2021-12-14 11:24:01.080 Canceling queued historical data download request for NQU1.CME Intraday data. | 2021-12-14 11:24:01.080 Removing historical data download ID 5. | 2021-12-14 11:24:01.080 Canceling queued historical data download request for ESZ1.CME Intraday data. | 2021-12-14 11:24:01.080 Removing historical data download ID 6. | 2021-12-14 11:24:01.080 Canceling queued historical data download request for ESH2.CME Intraday data. | 2021-12-14 11:24:01.080 Removing historical data download ID 7. | 2021-12-14 11:24:01.080 Canceling queued historical data download request for ESU1.CME Intraday data. | 2021-12-14 11:24:01.080 Removing historical data download ID 9. | 2021-12-14 11:24:01.080 Canceling queued historical data download request for ESH1.CME Intraday data. | 2021-12-14 11:24:01.080 Removing historical data download ID 11. | 2021-12-14 11:24:01.080 Canceling queued historical data download request for ESM1.CME Intraday data. | 2021-12-14 11:24:01.081 Removing historical data download ID 12. | 2021-12-14 11:24:01.081 Canceling queued historical data download request for BTCX1.CME Intraday data. | 2021-12-14 11:24:01.081 Removing historical data download ID 13. | 2021-12-14 11:24:01.081 Canceling queued historical data download request for NQH1.CME Intraday data. | 2021-12-14 11:24:01.081 Removing historical data download ID 15. | 2021-12-14 11:24:01.081 Canceling queued historical data download request for NQM1.CME Intraday data. | 2021-12-14 11:24:01.081 Removing historical data download ID 16. | 2021-12-14 11:24:01.081 HD Request # 2 | Active download canceled. | 2021-12-14 11:24:01.081 Historical data download thread signaled to stop. | 2021-12-14 11:24:01.081 Socket (3) | CloseSocket call. | 2021-12-14 11:24:01.081 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-12-14 11:24:01.081 HD Request # 2 | Timestamp of first Intraday data file record written: 2021-09-10 06:33:36.887000 | 2021-12-14 11:24:01.081 HD Request # 2 | Received 10000 Intraday data records from 2021-09-10 06:33:34.675000 to 2021-09-10 07:32:34.555002 (59.0 minutes) and wrote 9998 records for NQZ1.CME | 2021-12-14 11:24:01.081 HD Request # 2 | Completion time: 1h 34m 44s | 2021-12-14 11:24:01.081 HD Request # 2 | Intraday data download complete for NQZ1.CME. Unique request ID: 2 | 2021-12-14 11:24:01.081 Removing historical data download ID 2. | 2021-12-14 11:24:01.081 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-12-14 11:24:01.081 Triggering next historical data download in queue. | 2021-12-14 11:24:01.081 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-12-14 11:24:01.082 DTC Client socket (1) | CloseSocket call. | 2021-12-14 11:24:01.082 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-12-14 11:24:01.082 Rithmic Direct - DTC | Disconnected. | 2021-12-14 11:24:01.082 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-12-14 11:24:01.084 No download requests in the queue to start downloads for. | 2021-12-14 11:24:01.085 Socket (3) | Socket gracefully closed by remote side. | 2021-12-14 11:24:01.142 Socket (3) | Closed. | 2021-12-14 11:24:01.142 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-12-14 11:24:01.142 DTC Client socket (1) | Closed. | 2021-12-14 11:24:01.142 NQZ1.CME [CV] #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.264 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 11:24:01.264 ESZ1.CME [CV] 5 Min #42 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.268 ESZ1.CME [CV] 5 Min #42 | Reloading chart. | 2021-12-14 11:24:01.270 NQH2.CME [CV] 1 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.273 NQH2.CME [CV] 1 Min #8 | Reloading chart. | 2021-12-14 11:24:01.276 ESZ1.CME [CV] 5 Min #42 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:01.284 Loading market depth data. | 2021-12-14 11:24:01.285 NQH2.CME [CV] 1 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.307 NQZ1.CME [CV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:01.309 NQH2.CME [CV] 2 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.374 NQH2.CME [CV] 2 Min #17 | Reloading chart. | 2021-12-14 11:24:01.375 ESH2.CME [CV] 2 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.383 Loading market depth data. | 2021-12-14 11:24:01.385 ESH2.CME [CV] 2 Min #12 | Reloading chart. | 2021-12-14 11:24:01.386 NQH2.CME [CV] 2 Min #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.393 ESZ1.CME [CV] #43 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.395 Loading market depth data. | 2021-12-14 11:24:01.395 ESZ1.CME [CV] #43 | Reloading chart. | 2021-12-14 11:24:01.395 ESH2.CME [CV] 2 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:01.398 BTCZ1.CME [CV] #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.399 BTCZ1.CME [CV] #1 | Reloading chart. | 2021-12-14 11:24:01.400 NQH2.CME [CV] 15 Min #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.410 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:24:01.412 NQH2.CME [CV] 15 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.526 NQZ1.CME [CV] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.526 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 11:24:01.527 NQZ1.CME [CV] #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.530 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 11:24:01.533 NQZ1.CME [CV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.536 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 11:24:01.539 ESH2.CME [CV] 180 Min #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.541 ESH2.CME [CV] 180 Min #16 | Reloading chart. | 2021-12-14 11:24:01.546 NQZ1.CME [CV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:01.563 ESH2.CME [CV] 180 Min #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:01.588 NQZ1.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:01.631 ESH2.CME [CV] 15 Min #24 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.635 ESH2.CME [CV] 15 Min #24 | Reloading chart. | 2021-12-14 11:24:01.637 ESH2.CME [CV] 1 Min #47 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.644 ESH2.CME [CV] 1 Min #47 | Reloading chart. | 2021-12-14 11:24:01.645 ESH2.CME [CV] 15 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:01.662 NQH2.CME [CV] 1 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.663 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:24:01.664 ESH2.CME [CV] 1 Min #47 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:01.680 NQH2.CME [CV] 180 Min #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.681 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:24:01.684 NQH2.CME [CV] 1 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.700 ESH2.CME [CV] 5 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.701 ESH2.CME [CV] 5 Min #15 | Reloading chart. | 2021-12-14 11:24:01.704 NQH2.CME [CV] 180 Min #29 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.712 ESH2.CME [CV] 60 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.713 Loading market depth data. | 2021-12-14 11:24:01.714 ESH2.CME [CV] 60 Min #22 | Reloading chart. | 2021-12-14 11:24:01.714 ESH2.CME [CV] 5 Min #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:01.722 ESH2.CME [CV] 1 Day #38 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.723 ESH2.CME [CV] 1 Day #38 | Reloading chart. | 2021-12-14 11:24:01.724 ESH2.CME [CV] 60 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:01.750 NQH2.CME [CV] 5 Min #13 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.753 NQH2.CME [CV] 5 Min #13 | Reloading chart. | 2021-12-14 11:24:01.755 ESH2.CME [CV] 1 Day #38 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:01.762 NQH2.CME [CV] 1 Min #14 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.763 Loading market depth data. | 2021-12-14 11:24:01.763 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:24:01.763 NQH2.CME [CV] 5 Min #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.771 NQH2.CME [CV] 60 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.772 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:24:01.773 NQH2.CME [CV] 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.780 ESH2.CME [CV] 1 Min #45 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.781 ESH2.CME [CV] 1 Min #45 | Reloading chart. | 2021-12-14 11:24:01.782 NQH2.CME [CV] 60 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.789 NQH2.CME [CV] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.790 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:24:01.791 ESH2.CME [CV] 1 Min #45 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:01.817 NQH2.CME [CV] 1 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.818 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:24:01.819 NQH2.CME [CV] 1 Day #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.836 ESH2.CME [CV] 1 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:24:01.837 ESH2.CME [CV] 1 Min #9 | Reloading chart. | 2021-12-14 11:24:01.839 NQH2.CME [CV] 1 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.846 Loading market depth data. | 2021-12-14 11:24:01.848 NQH2.CME [CV] 1 Min #8 | Reloading chart. | 2021-12-14 11:24:01.849 ESH2.CME [CV] 1 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:01.878 Loading market depth data. | 2021-12-14 11:24:01.879 NQH2.CME [CV] 1 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:01.880 ESZ1.CME [CV] 5 Min #42 | Reloading chart. | 2021-12-14 11:24:01.881 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 11:24:01.903 ESZ1.CME [CV] 5 Min #42 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:01.926 ESH2.CME [CV] 2 Min #12 | Reloading chart. | 2021-12-14 11:24:01.950 NQZ1.CME [CV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:01.979 Loading market depth data. | 2021-12-14 11:24:01.980 ESH2.CME [CV] 2 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:02.011 NQH2.CME [CV] 2 Min #17 | Reloading chart. | 2021-12-14 11:24:02.044 Loading market depth data. | 2021-12-14 11:24:02.074 BTCZ1.CME [CV] #1 | Reloading chart. | 2021-12-14 11:24:02.075 NQH2.CME [CV] 2 Min #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:02.104 ESZ1.CME [CV] #43 | Reloading chart. | 2021-12-14 11:24:02.107 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:24:02.234 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 11:24:02.264 NQH2.CME [CV] 15 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:02.285 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 11:24:02.287 NQZ1.CME [CV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:02.310 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 11:24:02.335 NQZ1.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:02.358 ESH2.CME [CV] 180 Min #16 | Reloading chart. | 2021-12-14 11:24:02.363 ESH2.CME [CV] 180 Min #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:02.480 ESH2.CME [CV] 15 Min #24 | Reloading chart. | 2021-12-14 11:24:02.481 ESH2.CME [CV] 1 Min #47 | Reloading chart. | 2021-12-14 11:24:02.511 ESH2.CME [CV] 15 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:02.587 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:24:02.589 ESH2.CME [CV] 1 Min #47 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:02.665 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:24:02.666 NQH2.CME [CV] 1 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:02.743 ESH2.CME [CV] 60 Min #22 | Reloading chart. | 2021-12-14 11:24:02.745 NQH2.CME [CV] 180 Min #29 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:02.774 ESH2.CME [CV] 60 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:02.775 ESH2.CME [CV] 5 Min #15 | Reloading chart. | 2021-12-14 11:24:02.776 Loading market depth data. | 2021-12-14 11:24:02.805 ESH2.CME [CV] 1 Day #38 | Reloading chart. | 2021-12-14 11:24:02.806 ESH2.CME [CV] 5 Min #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:02.928 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:24:02.929 ESH2.CME [CV] 1 Day #38 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:02.958 NQH2.CME [CV] 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:02.959 NQH2.CME [CV] 5 Min #13 | Reloading chart. | 2021-12-14 11:24:02.960 Loading market depth data. | 2021-12-14 11:24:02.989 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:24:02.990 NQH2.CME [CV] 5 Min #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:03.019 NQH2.CME [CV] 60 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:03.020 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:24:03.021 ESH2.CME [CV] 1 Min #45 | Reloading chart. | 2021-12-14 11:24:03.147 NQH2.CME [CV] 1 Day #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:03.175 ESH2.CME [CV] 1 Min #45 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:03.176 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:24:03.177 ESH2.CME [CV] 1 Min #9 | Reloading chart. | 2021-12-14 11:24:03.255 NQH2.CME [CV] 1 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:24:03.284 Loading market depth data. | 2021-12-14 11:24:03.285 ESH2.CME [CV] 1 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH2.CME.scid | 2021-12-14 11:24:03.286 Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2021-12-14 11:24:05.076 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2021-12-14 11:24:05.078 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-12-14 11:24:05.185 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-14 11:24:05.186 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-12-14 11:24:05.186 Rithmic Direct - DTC | Network connection to server complete. | 2021-12-14 11:24:05.242 Rithmic Direct - DTC | Starting socket receive thread. | 2021-12-14 11:24:05.242 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-12-14 11:24:05.242 Rithmic Direct - DTC | Sending logon request message. | 2021-12-14 11:24:05.242 Rithmic Direct - DTC | Received logon response. | 2021-12-14 11:24:05.426 Rithmic Direct - DTC | Server Name: . | 2021-12-14 11:24:05.426 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 11:24:05.426 Rithmic Direct - DTC | Successfully connected. | 2021-12-14 11:24:05.426 Rithmic Direct - DTC | Trading is supported. | 2021-12-14 11:24:05.426 Rithmic Direct - DTC | Order cancel and replace is supported. | 2021-12-14 11:24:05.426 Rithmic Direct - DTC | OCO Orders supported. | 2021-12-14 11:24:05.427 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2021-12-14 11:24:05.427 Rithmic Direct - DTC | Connected to server complete. | 2021-12-14 11:24:05.427 Triggering next historical data download in queue. | 2021-12-14 11:24:05.427 Triggering next historical data download in queue. | 2021-12-14 11:24:05.427 Triggering next historical data download in queue. | 2021-12-14 11:24:05.427 Triggering next historical data download in queue. | 2021-12-14 11:24:05.427 Updated verified funded futures trading account ending date to: 2022-01-13 18:24:05 | 2021-12-14 11:24:05.427 No download requests in the queue to start downloads for. | 2021-12-14 11:24:05.433 No download requests in the queue to start downloads for. | 2021-12-14 11:24:05.433 No download requests in the queue to start downloads for. | 2021-12-14 11:24:05.433 No download requests in the queue to start downloads for. | 2021-12-14 11:24:05.433 Rithmic Direct - DTC | Starting real-time market data updates for: NQH2.CME. ID: 1 Service code: rithmic.trading | 2021-12-14 11:24:05.434 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50504 | 2021-12-14 11:24:05.434 Rithmic Direct - DTC | Requesting security definition data for: NQH2.CME. ID: 1 | 2021-12-14 11:24:05.434 Added historical Intraday data request for NQH2.CME to the queue. | 2021-12-14 11:24:05.434 Intraday data recording state for symbol NQH2.CME is set to download 'Pending'. | 2021-12-14 11:24:05.434 Triggering next historical data download in queue. | 2021-12-14 11:24:05.434 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2021-12-14 11:24:05.434 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-12-14 11:24:05.435 DTC Client socket (3) | Connecting to IP: 216.57.156.163. | 2021-12-14 11:24:05.435 Delaying start of download for NQH2.CME | 2021-12-14 11:24:05.435 Rithmic Direct - DTC | Starting real-time market data updates for: ESH2.CME. ID: 2 Service code: rithmic.trading | 2021-12-14 11:24:05.460 Rithmic Direct - DTC | Requesting security definition data for: ESH2.CME. ID: 2 | 2021-12-14 11:24:05.460 Added historical Intraday data request for ESH2.CME to the queue. | 2021-12-14 11:24:05.460 Intraday data recording state for symbol ESH2.CME is set to download 'Pending'. | 2021-12-14 11:24:05.460 Triggering next historical data download in queue. | 2021-12-14 11:24:05.460 Rithmic Direct - DTC | Starting real-time market data updates for: NQZ1.CME. ID: 3 Service code: rithmic.trading | 2021-12-14 11:24:05.465 Rithmic Direct - DTC | Requesting security definition data for: NQZ1.CME. ID: 3 | 2021-12-14 11:24:05.465 Added historical Intraday data request for NQZ1.CME to the queue. | 2021-12-14 11:24:05.465 Intraday data recording state for symbol NQZ1.CME is set to download 'Pending'. | 2021-12-14 11:24:05.465 Triggering next historical data download in queue. | 2021-12-14 11:24:05.465 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2021-12-14 11:24:05.510 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2021-12-14 11:24:05.510 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2021-12-14 11:24:05.510 Rithmic Direct - DTC (Data) | Sending logon request message. | 2021-12-14 11:24:05.510 Updated verified funded futures trading account ending date to: 2022-01-13 18:24:05 | 2021-12-14 11:24:05.511 Requesting market depth updates for: ESH2.CME if supported. | 2021-12-14 11:24:05.536 Separate subscription for market depth updates not supported. ESH2.CME | 2021-12-14 11:24:05.536 Requesting market depth updates for: NQH2.CME if supported. | 2021-12-14 11:24:05.558 Separate subscription for market depth updates not supported. NQH2.CME | 2021-12-14 11:24:05.558 Rithmic Direct - DTC | Starting real-time market data updates for: BTCZ1.CME. ID: 4 Service code: rithmic.trading | 2021-12-14 11:24:05.562 Rithmic Direct - DTC | Requesting security definition data for: BTCZ1.CME. ID: 4 | 2021-12-14 11:24:05.562 Added historical Intraday data request for BTCZ1.CME to the queue. | 2021-12-14 11:24:05.562 Intraday data recording state for symbol BTCZ1.CME is set to download 'Pending'. | 2021-12-14 11:24:05.562 Triggering next historical data download in queue. | 2021-12-14 11:24:05.562 Rithmic Direct - DTC | Starting real-time market data updates for: ESZ1.CME. ID: 5 Service code: rithmic.trading | 2021-12-14 11:24:05.633 Rithmic Direct - DTC | Requesting security definition data for: ESZ1.CME. ID: 5 | 2021-12-14 11:24:05.633 Added historical Intraday data request for ESZ1.CME to the queue. | 2021-12-14 11:24:05.633 Intraday data recording state for symbol ESZ1.CME is set to download 'Pending'. | 2021-12-14 11:24:05.633 Triggering next historical data download in queue. | 2021-12-14 11:24:05.633 Rithmic Direct - DTC (Data) | Received logon response. | 2021-12-14 11:24:05.706 Rithmic Direct - DTC (Data) | Server Name: . | 2021-12-14 11:24:05.706 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 11:24:05.706 Rithmic Direct - DTC (Data) | Successfully connected. | 2021-12-14 11:24:05.706 Rithmic Direct - DTC (Data) | Trading is not supported. | 2021-12-14 11:24:05.706 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2021-12-14 11:24:05.706 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BTCZ1.CME | 2021-12-14 11:24:05.706 Real-time market depth file updates started for ESH2.CME | 2021-12-14 11:24:05.706 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH2.CME.2021-12-14.depth | 2021-12-14 11:24:05.706 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESH2.CME. Market Depth data restarted. | 2021-12-14 11:24:05.706 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ1.CME | 2021-12-14 11:24:05.706 Real-time market depth file updates started for NQH2.CME | 2021-12-14 11:24:05.706 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQH2.CME.2021-12-14.depth | 2021-12-14 11:24:05.707 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQH2.CME. Market Depth data restarted. | 2021-12-14 11:24:05.707 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQZ1.CME | 2021-12-14 11:24:05.707 Rithmic Direct - DTC (Data) | Received security definition for symbol BTCZ1.CME | 2021-12-14 11:24:05.771 Rithmic Direct - DTC (Data) | Received security definition for symbol ESH2.CME | 2021-12-14 11:24:05.771 Rithmic Direct - DTC (Data) | Clearing market depth for ESH2.CME | 2021-12-14 11:24:05.772 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH2.CME.2021-12-14.depth | 2021-12-14 11:24:05.937 Rithmic Direct - DTC (Data) | Clearing market depth for NQH2.CME | 2021-12-14 11:24:05.937 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQH2.CME.2021-12-14.depth | 2021-12-14 11:24:06.038 Real-time market depth file updates started for ESZ1.CME | 2021-12-14 11:24:06.038 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ1.CME.2021-12-14.depth | 2021-12-14 11:24:06.039 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ1.CME.2021-12-14.depth | 2021-12-14 11:24:06.041 Real-time market depth file updates started for NQZ1.CME | 2021-12-14 11:24:06.041 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ1.CME.2021-12-14.depth | 2021-12-14 11:24:06.042 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ1.CME.2021-12-14.depth | 2021-12-14 11:24:06.043 Rithmic Direct - DTC (Data) | Received security definition for symbol ESZ1.CME | 2021-12-14 11:24:06.043 Rithmic Direct - DTC (Data) | Received security definition for symbol NQH2.CME | 2021-12-14 11:24:06.043 Rithmic Direct - DTC (Data) | Received security definition for symbol NQZ1.CME | 2021-12-14 11:24:06.043 Requesting market depth updates for: ESZ1.CME if supported. | 2021-12-14 11:24:10.565 Requesting market depth updates for: NQZ1.CME if supported. | 2021-12-14 11:24:10.565 Rithmic Direct - DTC (Data) | Clearing market depth for ESZ1.CME | 2021-12-14 11:24:10.634 Rithmic Direct - DTC (Data) | Clearing market depth for NQZ1.CME | 2021-12-14 11:24:11.165 HD Request # 11 | Downloading Intraday chart data for NQH2.CME to the file NQH2.CME.scid. Service: rithmic.trading | 2021-12-14 11:24:12.069 HD Request # 11 | Download start date-time: 2021-12-03 13:05:32.000000. File last date-time: 2021-12-03 13:05:32.830006 | 2021-12-14 11:24:12.069 HD Request # 11 | Using server: rsc.rithmic.com port 50505. Use encryption. | 2021-12-14 11:24:12.069 Socket (4) | Creating socket. Using TLS 1.2. | 2021-12-14 11:24:12.069 Socket (4) | New receive buffer size: 5242880 | 2021-12-14 11:24:12.070 Socket (4) | Connecting to IP: 216.57.156.163. | 2021-12-14 11:24:12.070 HD Request # 11 | Sending historical data logon request message. | 2021-12-14 11:24:12.126 HD Request # 11 | Requesting Intraday data. Start date-time: 2021-12-03 13:05:32. Record interval: 0. Symbol: NQH2.CME | 2021-12-14 11:24:12.314 HD Request # 11 | Receiving Intraday data for NQH2.CME starting at 2021-12-03 13:05:32.830000 | 2021-12-14 11:24:12.371 NQZ1.CME [CV] 2 Min #17 | Reloading chart. | 2021-12-14 11:24:34.005 NQZ1.CME [CV] 2 Min #17 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.024 NQZ1.CME [CV] 1 Min #8 | Reloading chart. | 2021-12-14 11:24:34.053 NQZ1.CME [CV] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.073 NQZ1.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:24:34.453 NQZ1.CME [CV] 15 Min #23 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.472 NQZ1.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:24:34.508 NQZ1.CME [CV] 180 Min #29 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.566 NQZ1.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:24:34.568 NQZ1.CME [CV] 60 Min #27 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.587 NQZ1.CME [CV] 5 Min #13 | Reloading chart. | 2021-12-14 11:24:34.623 NQZ1.CME [CV] 5 Min #13 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.642 NQZ1.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:24:34.644 NQZ1.CME [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.701 NQZ1.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:24:34.714 NQZ1.CME [CV] 1 Min #14 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.733 NQZ1.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:24:34.735 NQZ1.CME [CV] 1 Sec #6 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.792 NQZ1.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:24:34.795 NQZ1.CME [CV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:24:34.891 NQZ1.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:24:34.906 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:24:34.906 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:24:34.906 NQZ1.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:35.452 Added historical Daily data request for NQZ1.CME to the queue. | 2021-12-14 11:24:36.151 Triggering next historical data download in queue. | 2021-12-14 11:24:36.151 HD Request # 12 | Downloading Historical Daily chart data for NQZ1.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 11:24:36.165 HD Request # 12 | Requesting historical Daily data for NQZ21 starting at 2021-12-08. SC External HD service. | 2021-12-14 11:24:36.936 HD Request # 12 | Receiving historical Daily data for NQZ1.CME starting at 2021-12-09 | 2021-12-14 11:24:37.663 HD Request # 12 | Writing historical Daily data to the file NQZ1.CME.dly | 2021-12-14 11:24:37.663 HD Request # 12 | Bytes received: 258 | 2021-12-14 11:24:37.665 HD Request # 12 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQZ1.CME | 2021-12-14 11:24:37.665 HD Request # 12 | Completion time: 1s | 2021-12-14 11:24:37.666 HD Request # 12 | Daily data download complete for NQZ1.CME. Unique request ID: 27 | 2021-12-14 11:24:37.666 Removing historical data download ID 27. | 2021-12-14 11:24:37.666 Triggering next historical data download in queue. | 2021-12-14 11:24:37.666 No download requests in the queue to start downloads for. | 2021-12-14 11:24:37.666 NQZ1.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:24:37.731 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:24:37.731 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:24:37.731 NQZ1.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:38.307 NQZ1.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:24:44.970 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:24:44.970 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:24:44.970 NQZ1.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:24:45.522 NQH2.CME [CV] 2 Min #17 | Reloading chart. | 2021-12-14 11:25:00.079 NQH2.CME [CV] 2 Min #17 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:00.102 NQH2.CME [CV] #5 | Reloading chart. | 2021-12-14 11:25:00.130 NQH2.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:00.155 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:25:00.158 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:25:00.158 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:25:00.158 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:25:00.665 NQH2.CME [CV] 15 Min #23 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:00.689 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:25:00.691 NQH2.CME [CV] 60 Min #27 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:00.715 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:25:00.717 NQH2.CME [CV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:00.822 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:25:00.823 NQH2.CME [CV] 1 Min #8 | Reloading chart. | 2021-12-14 11:25:00.890 NQH2.CME [CV] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:00.913 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:25:00.915 NQH2.CME [CV] 1 Min #14 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:00.938 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:25:00.940 NQH2.CME [CV] 180 Min #29 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:01.002 NQH2.CME [CV] 5 Min #13 | Reloading chart. | 2021-12-14 11:25:01.004 NQH2.CME [CV] 5 Min #13 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:01.027 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:25:01.029 NQH2.CME [CV] 1 Sec #6 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:01.090 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:25:01.092 NQH2.CME [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:01.153 NQH2.CME [CV] #10 | Reloading chart. | 2021-12-14 11:25:01.155 NQH2.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:01.177 NQH2.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 11:25:01.190 NQH2.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:01.212 NQH2.CME [CV] #4 | Reloading chart. | 2021-12-14 11:25:01.286 NQH2.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:25:01.309 Added historical Daily data request for NQH2.CME to the queue. | 2021-12-14 11:25:01.583 Triggering next historical data download in queue. | 2021-12-14 11:25:01.583 HD Request # 13 | Downloading Historical Daily chart data for NQH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 11:25:01.609 HD Request # 13 | Requesting historical Daily data for NQH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 11:25:02.480 HD Request # 13 | Receiving historical Daily data for NQH2.CME starting at 2021-12-09 | 2021-12-14 11:25:02.803 HD Request # 13 | Writing historical Daily data to the file NQH2.CME.dly | 2021-12-14 11:25:02.803 HD Request # 13 | Bytes received: 248 | 2021-12-14 11:25:02.805 HD Request # 13 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQH2.CME | 2021-12-14 11:25:02.805 HD Request # 13 | Completion time: 1s | 2021-12-14 11:25:02.805 HD Request # 13 | Daily data download complete for NQH2.CME. Unique request ID: 28 | 2021-12-14 11:25:02.805 Removing historical data download ID 28. | 2021-12-14 11:25:02.805 Triggering next historical data download in queue. | 2021-12-14 11:25:02.805 No download requests in the queue to start downloads for. | 2021-12-14 11:25:02.805 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:25:02.848 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:25:02.848 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:25:02.848 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:25:03.433 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:25:10.187 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:25:10.187 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:25:10.187 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:25:10.766 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-12-14 11:26:03.448 DTC Client socket (2) | Closed. | 2021-12-14 11:26:03.448 DTC Client socket (2) | Deleting network socket now after delay. | 2021-12-14 11:26:33.454 NQH2.CME 2 Min #17 | Reloading chart. | 2021-12-14 11:27:57.956 Loading market depth data. | 2021-12-14 11:27:57.980 NQH2.CME 2 Min #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:27:57.988 NQH2.CME 2 Min #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:28:03.876 NQH2.CME 5 Min #13 | Reloading chart. | 2021-12-14 11:28:10.936 Loading market depth data. | 2021-12-14 11:28:10.957 NQH2.CME 5 Min #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:28:10.972 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:28:10.995 NQH2.CME 2 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:28:11.113 NQH2.CME 1 Min #8 | Reloading chart. | 2021-12-14 11:28:28.174 Loading market depth data. | 2021-12-14 11:28:28.201 NQH2.CME 1 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:28:28.205 NQH2.CME 1 Min #8 | Reloading chart. | 2021-12-14 11:28:28.497 Loading market depth data. | 2021-12-14 11:28:28.524 NQH2.CME 1 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:28:28.544 NQH2.CME 1 Min #8 | Reloading chart. | 2021-12-14 11:28:30.183 Loading market depth data. | 2021-12-14 11:28:30.209 NQH2.CME 1 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:28:30.213 NQZ1.CME 2 Min #17 | Reloading chart. | 2021-12-14 11:30:13.165 NQZ1.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:30:13.201 Loading market depth data. | 2021-12-14 11:30:13.215 NQZ1.CME [CV] 180 Min #29 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.258 NQZ1.CME 2 Min #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:13.259 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:13.307 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 11:30:13.397 NQZ1.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.415 NQZ1.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:30:13.427 NQZ1.CME [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.483 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 11:30:13.496 NQZ1.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.515 NQZ1.CME 5 Min #13 | Reloading chart. | 2021-12-14 11:30:13.517 NQZ1.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:30:13.522 Loading market depth data. | 2021-12-14 11:30:13.561 NQZ1.CME [CV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.618 NQZ1.CME 5 Min #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:13.620 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:13.639 Chart #13 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:13.639 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 11:30:13.702 NQZ1.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.721 NQZ1.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:30:13.722 NQZ1.CME [CV] 1 Min #14 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.741 NQZ1.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:30:13.743 NQZ1.CME [CV] 1 Sec #6 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.800 NQZ1.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:30:13.802 NQZ1.CME [CV] 60 Min #27 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.821 NQZ1.CME 1 Min #8 | Reloading chart. | 2021-12-14 11:30:13.855 NQZ1.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:30:13.861 NQZ1.CME [CV] 15 Min #23 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.880 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 11:30:13.882 NQZ1.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 24, | 2021-12-14 11:30:13.901 NQZ1.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:30:13.904 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:30:13.904 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:30:13.904 Loading market depth data. | 2021-12-14 11:30:13.906 NQZ1.CME 1 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:14.384 NQZ1.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:14.556 NQZ1.CME 2 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:14.592 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:14.638 NQZ1.CME 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:15.029 NQZ1.CME 2 Min #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:18.852 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:18.896 NQZ1.CME 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:19.013 NQZ1.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:30:23.960 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:30:23.960 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:30:23.960 NQZ1.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:24.495 NQH2.CME 2 Min #17 | Reloading chart. | 2021-12-14 11:30:56.829 Loading market depth data. | 2021-12-14 11:30:56.854 NQH2.CME 2 Min #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:56.861 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:56.911 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:30:57.006 NQH2.CME [CV] 60 Min #27 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:57.028 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:30:57.030 NQH2.CME [CV] 15 Min #23 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:57.051 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:30:57.053 NQH2.CME [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:57.112 NQH2.CME [CV] #5 | Reloading chart. | 2021-12-14 11:30:57.114 NQH2.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:57.135 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:30:57.138 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:30:57.138 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:30:57.138 NQH2.CME [CV] #10 | Reloading chart. | 2021-12-14 11:30:57.621 NQH2.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:57.643 NQH2.CME [CV] #4 | Reloading chart. | 2021-12-14 11:30:57.645 NQH2.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:57.667 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:57.688 NQH2.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 11:30:57.716 NQH2.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:57.737 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:30:57.810 NQH2.CME [CV] 1 Min #14 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:57.831 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:30:57.861 NQH2.CME [CV] 1 Sec #6 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:57.920 NQH2.CME 1 Min #8 | Reloading chart. | 2021-12-14 11:30:57.924 Loading market depth data. | 2021-12-14 11:30:57.953 NQH2.CME 1 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:57.973 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:30:58.394 NQH2.CME [CV] 180 Min #29 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:58.453 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:30:58.455 NQH2.CME [CV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 22, 24, | 2021-12-14 11:30:58.551 NQH2.CME 5 Min #13 | Reloading chart. | 2021-12-14 11:30:58.554 Loading market depth data. | 2021-12-14 11:30:58.573 NQH2.CME 5 Min #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:30:58.584 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:58.603 Chart #13 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:58.603 NQH2.CME 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:58.727 NQH2.CME 2 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:58.812 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:58.858 NQH2.CME 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:30:59.029 NQH2.CME 2 Min #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:31:03.759 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:31:03.806 NQH2.CME 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:31:03.950 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:31:07.201 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:31:07.201 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:31:07.201 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:31:07.749 File >> Disconnect selected. | 2021-12-14 11:32:16.105 Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end | 2021-12-14 11:32:16.105 DTC Client socket (3) | CloseSocket call. | 2021-12-14 11:32:16.105 DTC Client socket (3) | Max send buffers used during socket life: 3 | 2021-12-14 11:32:16.105 DTC Client socket (3) | Max send buffer size during socket life: 1199 | 2021-12-14 11:32:16.105 Rithmic Direct - DTC (Data) | Disconnected from the server. | 2021-12-14 11:32:16.105 WSACleanup called. | 2021-12-14 11:32:16.105 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-12-14 11:32:16.105 Canceling queued historical data download request for ESH2.CME Intraday data. | 2021-12-14 11:32:16.105 Removing historical data download ID 23. | 2021-12-14 11:32:16.105 Canceling queued historical data download request for NQZ1.CME Intraday data. | 2021-12-14 11:32:16.105 Removing historical data download ID 24. | 2021-12-14 11:32:16.105 Canceling queued historical data download request for BTCZ1.CME Intraday data. | 2021-12-14 11:32:16.105 Removing historical data download ID 25. | 2021-12-14 11:32:16.105 Canceling queued historical data download request for ESZ1.CME Intraday data. | 2021-12-14 11:32:16.105 Removing historical data download ID 26. | 2021-12-14 11:32:16.105 HD Request # 11 | Active download canceled. | 2021-12-14 11:32:16.105 Historical data download thread signaled to stop. | 2021-12-14 11:32:16.105 Socket (4) | CloseSocket call. | 2021-12-14 11:32:16.105 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-12-14 11:32:16.106 HD Request # 11 | Timestamp of first Intraday data file record written: 2021-12-03 13:06:39.528000 | 2021-12-14 11:32:16.106 HD Request # 11 | Received 10000 Intraday data records from 2021-12-03 13:05:32.830000 to 2021-12-07 01:50:39.008000 (3.5 days) and wrote 9993 records for NQH2.CME | 2021-12-14 11:32:16.106 HD Request # 11 | Completion time: 8m 4s | 2021-12-14 11:32:16.106 HD Request # 11 | Intraday data download complete for NQH2.CME. Unique request ID: 22 | 2021-12-14 11:32:16.106 Removing historical data download ID 22. | 2021-12-14 11:32:16.106 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2021-12-14 11:32:16.106 Triggering next historical data download in queue. | 2021-12-14 11:32:16.107 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:32:16.112 Chart #13 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:32:16.112 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:32:16.114 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-12-14 11:32:16.114 DTC Client socket (1) | CloseSocket call. | 2021-12-14 11:32:16.114 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-12-14 11:32:16.114 Rithmic Direct - DTC | Disconnected. | 2021-12-14 11:32:16.114 No download requests in the queue to start downloads for. | 2021-12-14 11:32:16.114 Socket (4) | Socket gracefully closed by remote side. | 2021-12-14 11:32:16.167 Socket (4) | Closed. | 2021-12-14 11:32:16.167 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-12-14 11:32:16.174 DTC Client socket (1) | Closed. | 2021-12-14 11:32:16.174 NQH2.CME [CV] 60 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.294 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:32:16.295 NQH2.CME [CV] #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.302 NQH2.CME [CV] #5 | Reloading chart. | 2021-12-14 11:32:16.303 NQH2.CME [CV] 60 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.310 NQH2.CME [CV] #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.311 NQH2.CME [CV] #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.312 NQH2.CME [CV] #4 | Reloading chart. | 2021-12-14 11:32:16.312 NQH2.CME [CV] 1 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.319 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:32:16.320 NQH2.CME [CV] #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.336 NQH2.CME [CV] 1 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.367 NQH2.CME [CV] 15 Min #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.368 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:32:16.368 NQH2.CME [CV] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.376 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:32:16.377 NQH2.CME [CV] 15 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.402 NQH2.CME [CV] 1 Min #14 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.404 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:32:16.404 NQH2.CME [CV] 1 Day #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.411 NQH2.CME [CV] 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.413 NQH2.CME 2 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:32:16.418 NQH2.CME [CV] 1 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.495 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:32:16.495 NQH2.CME [CV] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.512 NQH2.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 11:32:16.513 NQH2.CME [CV] 1 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.521 NQH2.CME [CV] 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.522 NQH2.CME 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:32:16.528 NQH2.CME [CV] 180 Min #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.627 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:32:16.628 NQH2.CME [CV] 180 Min #29 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.657 NQH2.CME [CV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-12-14 11:32:16.659 NQH2.CME [CV] #10 | Reloading chart. | 2021-12-14 11:32:16.659 NQH2.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:32:16.669 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:32:16.673 NQH2.CME [CV] #4 | Reloading chart. | 2021-12-14 11:32:16.703 NQH2.CME [CV] 60 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.732 NQH2.CME [CV] #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.733 NQH2.CME [CV] #5 | Reloading chart. | 2021-12-14 11:32:16.734 NQH2.CME [CV] #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.788 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:32:16.789 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:32:16.866 NQH2.CME [CV] 1 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.895 NQH2.CME [CV] 15 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:16.897 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:32:16.898 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:32:17.023 NQH2.CME [CV] 1 Day #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:17.052 NQH2.CME [CV] 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:17.053 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:32:17.077 NQH2.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 11:32:17.153 NQH2.CME [CV] 1 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:17.181 NQH2.CME [CV] 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:17.182 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:32:17.200 NQH2.CME [CV] 180 Min #29 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH2.CME.scid | 2021-12-14 11:32:17.286 NQH2.CME [CV] #10 | Reloading chart. | 2021-12-14 11:32:17.288 NQH2.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:32:17.318 Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated | 2021-12-14 11:32:32.975 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 | 2021-12-14 11:32:32.977 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-12-14 11:32:32.982 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-14 11:32:32.982 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-12-14 11:32:32.982 Rithmic Direct - DTC | Network connection to server complete. | 2021-12-14 11:32:33.046 Rithmic Direct - DTC | Starting socket receive thread. | 2021-12-14 11:32:33.046 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-12-14 11:32:33.046 Rithmic Direct - DTC | Sending logon request message. | 2021-12-14 11:32:33.046 Rithmic Direct - DTC | Received logon response. | 2021-12-14 11:32:33.246 Rithmic Direct - DTC | Server Name: . | 2021-12-14 11:32:33.246 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 11:32:33.246 Rithmic Direct - DTC | Successfully connected. | 2021-12-14 11:32:33.246 Rithmic Direct - DTC | Trading is supported. | 2021-12-14 11:32:33.246 Rithmic Direct - DTC | Order cancel and replace is supported. | 2021-12-14 11:32:33.246 Rithmic Direct - DTC | OCO Orders supported. | 2021-12-14 11:32:33.246 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2021-12-14 11:32:33.246 Rithmic Direct - DTC | Connected to server complete. | 2021-12-14 11:32:33.246 Triggering next historical data download in queue. | 2021-12-14 11:32:33.246 Triggering next historical data download in queue. | 2021-12-14 11:32:33.246 Triggering next historical data download in queue. | 2021-12-14 11:32:33.246 Triggering next historical data download in queue. | 2021-12-14 11:32:33.246 Updated verified funded futures trading account ending date to: 2022-01-13 18:32:33 | 2021-12-14 11:32:33.246 No download requests in the queue to start downloads for. | 2021-12-14 11:32:33.251 No download requests in the queue to start downloads for. | 2021-12-14 11:32:33.251 No download requests in the queue to start downloads for. | 2021-12-14 11:32:33.251 No download requests in the queue to start downloads for. | 2021-12-14 11:32:33.251 Rithmic Direct - DTC | Starting real-time market data updates for: NQH2.CME. ID: 1 Service code: rithmic.trading | 2021-12-14 11:32:33.251 Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50504 | 2021-12-14 11:32:33.251 Rithmic Direct - DTC | Requesting security definition data for: NQH2.CME. ID: 1 | 2021-12-14 11:32:33.251 Requesting market depth updates for: NQH2.CME if supported. | 2021-12-14 11:32:33.251 Separate subscription for market depth updates not supported. NQH2.CME | 2021-12-14 11:32:33.251 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-12-14 11:32:33.252 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-12-14 11:32:33.252 DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2021-12-14 11:32:33.252 Added historical Intraday data request for NQH2.CME to the queue. | 2021-12-14 11:32:33.252 Intraday data recording state for symbol NQH2.CME is set to download 'Pending'. | 2021-12-14 11:32:33.252 Triggering next historical data download in queue. | 2021-12-14 11:32:33.252 Delaying start of download for NQH2.CME | 2021-12-14 11:32:33.270 Rithmic Direct - DTC (Data) | Network connection to server complete. | 2021-12-14 11:32:33.315 Rithmic Direct - DTC (Data) | Starting socket receive thread. | 2021-12-14 11:32:33.315 Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary | 2021-12-14 11:32:33.315 Rithmic Direct - DTC (Data) | Sending logon request message. | 2021-12-14 11:32:33.315 Updated verified funded futures trading account ending date to: 2022-01-13 18:32:33 | 2021-12-14 11:32:33.315 Rithmic Direct - DTC | Starting real-time market data updates for: ESH2.CME. ID: 2 Service code: rithmic.trading | 2021-12-14 11:32:33.326 Rithmic Direct - DTC | Requesting security definition data for: ESH2.CME. ID: 2 | 2021-12-14 11:32:33.326 Requesting market depth updates for: ESH2.CME if supported. | 2021-12-14 11:32:33.326 Separate subscription for market depth updates not supported. ESH2.CME | 2021-12-14 11:32:33.326 Added historical Intraday data request for ESH2.CME to the queue. | 2021-12-14 11:32:33.326 Intraday data recording state for symbol ESH2.CME is set to download 'Pending'. | 2021-12-14 11:32:33.326 Triggering next historical data download in queue. | 2021-12-14 11:32:33.326 Rithmic Direct - DTC | Starting real-time market data updates for: ESZ1.CME. ID: 3 Service code: rithmic.trading | 2021-12-14 11:32:33.331 Rithmic Direct - DTC | Requesting security definition data for: ESZ1.CME. ID: 3 | 2021-12-14 11:32:33.331 Added historical Intraday data request for ESZ1.CME to the queue. | 2021-12-14 11:32:33.331 Intraday data recording state for symbol ESZ1.CME is set to download 'Pending'. | 2021-12-14 11:32:33.331 Triggering next historical data download in queue. | 2021-12-14 11:32:33.331 Rithmic Direct - DTC | Starting real-time market data updates for: BTCZ1.CME. ID: 4 Service code: rithmic.trading | 2021-12-14 11:32:33.384 Rithmic Direct - DTC | Requesting security definition data for: BTCZ1.CME. ID: 4 | 2021-12-14 11:32:33.384 Added historical Intraday data request for BTCZ1.CME to the queue. | 2021-12-14 11:32:33.384 Intraday data recording state for symbol BTCZ1.CME is set to download 'Pending'. | 2021-12-14 11:32:33.384 Triggering next historical data download in queue. | 2021-12-14 11:32:33.384 Rithmic Direct - DTC (Data) | Received logon response. | 2021-12-14 11:32:33.500 Rithmic Direct - DTC (Data) | Server Name: . | 2021-12-14 11:32:33.500 Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2021-12-14 11:32:33.500 Rithmic Direct - DTC (Data) | Successfully connected. | 2021-12-14 11:32:33.500 Rithmic Direct - DTC (Data) | Trading is not supported. | 2021-12-14 11:32:33.500 Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . | 2021-12-14 11:32:33.500 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BTCZ1.CME | 2021-12-14 11:32:33.500 Real-time market depth file updates started for ESH2.CME | 2021-12-14 11:32:33.500 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH2.CME.2021-12-14.depth | 2021-12-14 11:32:33.500 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESH2.CME. Market Depth data restarted. | 2021-12-14 11:32:33.500 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ1.CME | 2021-12-14 11:32:33.500 Real-time market depth file updates started for NQH2.CME | 2021-12-14 11:32:33.500 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQH2.CME.2021-12-14.depth | 2021-12-14 11:32:33.500 Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQH2.CME. Market Depth data restarted. | 2021-12-14 11:32:33.501 Rithmic Direct - DTC (Data) | Clearing market depth for ESH2.CME | 2021-12-14 11:32:33.568 Rithmic Direct - DTC (Data) | Received security definition for symbol BTCZ1.CME | 2021-12-14 11:32:33.568 Rithmic Direct - DTC (Data) | Received security definition for symbol ESH2.CME | 2021-12-14 11:32:33.568 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH2.CME.2021-12-14.depth | 2021-12-14 11:32:33.731 Rithmic Direct - DTC (Data) | Clearing market depth for NQH2.CME | 2021-12-14 11:32:33.731 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQH2.CME.2021-12-14.depth | 2021-12-14 11:32:33.808 Real-time market depth file updates started for ESZ1.CME | 2021-12-14 11:32:33.808 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ1.CME.2021-12-14.depth | 2021-12-14 11:32:33.808 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ1.CME.2021-12-14.depth | 2021-12-14 11:32:33.808 Rithmic Direct - DTC (Data) | Received security definition for symbol ESZ1.CME | 2021-12-14 11:32:33.808 Rithmic Direct - DTC (Data) | Received security definition for symbol NQH2.CME | 2021-12-14 11:32:33.808 Requesting market depth updates for: ESZ1.CME if supported. | 2021-12-14 11:32:38.246 Rithmic Direct - DTC (Data) | Clearing market depth for ESZ1.CME | 2021-12-14 11:32:38.315 HD Request # 14 | Downloading Intraday chart data for NQH2.CME to the file NQH2.CME.scid. Service: rithmic.trading | 2021-12-14 11:32:38.393 HD Request # 14 | Download start date-time: 2021-12-07 01:50:39.000000. File last date-time: 2021-12-07 01:50:39.008000 | 2021-12-14 11:32:38.393 HD Request # 14 | Using server: rsc.rithmic.com port 50505. Use encryption. | 2021-12-14 11:32:38.393 Socket (4) | Creating socket. Using TLS 1.2. | 2021-12-14 11:32:38.393 Socket (4) | New receive buffer size: 5242880 | 2021-12-14 11:32:38.393 Socket (4) | Connecting to IP: 216.57.156.163. | 2021-12-14 11:32:38.393 HD Request # 14 | Sending historical data logon request message. | 2021-12-14 11:32:38.449 HD Request # 14 | Requesting Intraday data. Start date-time: 2021-12-07 01:50:39. Record interval: 0. Symbol: NQH2.CME | 2021-12-14 11:32:38.633 HD Request # 14 | Receiving Intraday data for NQH2.CME starting at 2021-12-07 01:50:39.008000 | 2021-12-14 11:32:38.694 Saved Chartbook: Nasdaq.Cht. Time: 0.0733 seconds. | 2021-12-14 11:34:08.944 DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-12-14 11:34:33.581 DTC Client socket (3) | Closed. | 2021-12-14 11:34:33.581 DTC Client socket (3) | Deleting network socket now after delay. | 2021-12-14 11:35:03.593 NQZ1.CME 2 Min #17 | Reloading chart. | 2021-12-14 11:37:29.124 NQZ1.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:37:29.160 Loading market depth data. | 2021-12-14 11:37:29.172 NQZ1.CME 2 Min #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:29.182 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:29.228 NQZ1.CME [CV] 15 Min #23 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:29.319 Chart #23 has tagged chart #13 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:29.329 Chart #23 has tagged chart #17 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:29.329 Chart #23 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:29.329 NQZ1.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:37:29.375 NQZ1.CME [CV] #10 | Reloading chart. | 2021-12-14 11:37:29.446 NQZ1.CME [CV] 180 Min #29 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQZ1.CME.scid | 2021-12-14 11:37:29.467 NQZ1.CME [CV] #5 | Reloading chart. | 2021-12-14 11:37:29.470 NQZ1.CME 5 Min #13 | Reloading chart. | 2021-12-14 11:37:29.494 NQZ1.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:37:29.499 Loading market depth data. | 2021-12-14 11:37:29.537 NQZ1.CME [CV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:29.569 NQZ1.CME [CV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:29.572 NQZ1.CME 5 Min #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:29.604 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:29.625 Chart #13 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:29.625 NQZ1.CME [CV] 1 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQZ1.CME.scid | 2021-12-14 11:37:29.647 NQZ1.CME 1 Min #8 | Reloading chart. | 2021-12-14 11:37:29.725 NQZ1.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:37:29.730 Loading market depth data. | 2021-12-14 11:37:29.776 NQZ1.CME 1 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:29.801 NQZ1.CME [CV] 1 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQZ1.CME.scid | 2021-12-14 11:37:29.890 NQZ1.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:37:29.977 NQZ1.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:37:30.094 NQZ1.CME [CV] 1 Day #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQZ1.CME.scid | 2021-12-14 11:37:30.116 NQZ1.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:37:30.120 NQZ1.CME [CV] 60 Min #27 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:30.142 Chart #27 has tagged chart #13 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:30.145 Chart #27 has tagged chart #17 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:30.145 Chart #27 has tagged chart #23 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:30.145 Chart #27 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:30.145 NQZ1.CME [CV] 1 Min #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:30.192 NQZ1.CME [CV] #4 | Reloading chart. | 2021-12-14 11:37:30.209 NQZ1.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 11:37:30.233 NQZ1.CME [CV] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:30.318 NQZ1.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:37:30.413 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:37:30.413 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:37:30.413 Rithmic Direct - DTC | Starting real-time market data updates for: NQZ1.CME. ID: 5 Service code: rithmic.trading | 2021-12-14 11:37:30.907 Rithmic Direct - DTC | Requesting security definition data for: NQZ1.CME. ID: 5 | 2021-12-14 11:37:30.907 Requesting market depth updates for: NQZ1.CME if supported. | 2021-12-14 11:37:30.907 Real-time market depth file updates started for NQZ1.CME | 2021-12-14 11:37:30.907 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ1.CME.2021-12-14.depth | 2021-12-14 11:37:30.908 Added historical Intraday data request for NQZ1.CME to the queue. | 2021-12-14 11:37:30.908 Intraday data recording state for symbol NQZ1.CME is set to download 'Pending'. | 2021-12-14 11:37:30.908 Triggering next historical data download in queue. | 2021-12-14 11:37:30.908 NQZ1.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:30.938 Rithmic Direct - DTC (Data) | Clearing market depth for NQZ1.CME | 2021-12-14 11:37:30.979 NQZ1.CME [CV] 15 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:31.111 Chart #23 has tagged chart #13 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:31.120 Chart #23 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:31.120 NQZ1.CME 5 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:31.144 Chart #13 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:31.163 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ1.CME.2021-12-14.depth | 2021-12-14 11:37:31.286 NQZ1.CME 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:31.589 NQZ1.CME 2 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:31.876 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:31.921 NQZ1.CME 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:37:32.013 NQZ1.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:37:40.673 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:37:40.673 NQZ1.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:37:40.673 NQZ1.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:37:41.229 NQH2.CME 2 Min #17 | Reloading chart. | 2021-12-14 11:42:46.837 Loading market depth data. | 2021-12-14 11:42:46.864 NQH2.CME 2 Min #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:42:46.869 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:42:46.921 NQH2.CME [CV] 1 Sec #6 | Reloading chart. | 2021-12-14 11:42:47.016 NQH2.CME [CV] 1 Sec #6 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:47.077 NQH2.CME 1 Min #8 | Reloading chart. | 2021-12-14 11:42:47.080 NQH2.CME [CV] 1 Day #3 | Reloading chart. | 2021-12-14 11:42:47.086 Loading market depth data. | 2021-12-14 11:42:47.112 NQH2.CME [CV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:47.185 NQH2.CME 1 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:42:47.187 NQH2.CME [CV] 5 Min #2 | Reloading chart. | 2021-12-14 11:42:47.464 NQH2.CME [CV] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:47.486 NQH2.CME [CV] #10 | Reloading chart. | 2021-12-14 11:42:47.882 NQH2.CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:47.904 NQH2.CME [CV] 60 Min #27 | Reloading chart. | 2021-12-14 11:42:47.906 NQH2.CME [CV] 60 Min #27 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:47.928 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:42:47.931 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:42:47.931 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:42:47.931 NQH2.CME [CV] 1 Min #14 | Reloading chart. | 2021-12-14 11:42:48.428 NQH2.CME [CV] 1 Min #14 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:48.451 NQH2.CME [CV] #4 | Reloading chart. | 2021-12-14 11:42:48.454 NQH2.CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:48.477 NQH2.CME [CV] 15 Min #23 | Reloading chart. | 2021-12-14 11:42:48.481 NQH2.CME [CV] 15 Min #23 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:48.503 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:42:48.504 NQH2.CME [CV] 180 Min #29 | Reloading chart. | 2021-12-14 11:42:48.532 NQH2.CME [CV] 180 Min #29 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:48.593 NQH2.CME [CV] 1 Min #7 | Reloading chart. | 2021-12-14 11:42:48.595 NQH2.CME [CV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:48.656 NQH2.CME 5 Min #13 | Reloading chart. | 2021-12-14 11:42:48.658 NQH2.CME [CV] #5 | Reloading chart. | 2021-12-14 11:42:48.663 Loading market depth data. | 2021-12-14 11:42:48.681 NQH2.CME [CV] #5 | Waiting for historical downloads to complete with the IDs: 29, 33, | 2021-12-14 11:42:48.685 NQH2.CME 5 Min #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:42:48.686 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:42:48.706 Chart #13 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:42:48.706 NQH2.CME 2 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:42:48.767 Chart #17 has tagged chart #8 for full recalculation. Chartbook: Nasdaq.Cht | 2021-12-14 11:42:48.815 NQH2.CME 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Nasdaq.Cht | 2021-12-14 11:42:48.837 Added historical Daily data request for NQH2.CME to the queue. | 2021-12-14 11:42:49.574 Triggering next historical data download in queue. | 2021-12-14 11:42:49.574 HD Request # 15 | Downloading Historical Daily chart data for NQH2.CME. Starting date: 2021-12-09. Service: rithmic.trading | 2021-12-14 11:42:49.587 HD Request # 15 | Requesting historical Daily data for NQH22 starting at 2021-12-08. SC External HD service. | 2021-12-14 11:42:50.417 HD Request # 15 | Receiving historical Daily data for NQH2.CME starting at 2021-12-09 | 2021-12-14 11:42:50.877 HD Request # 15 | Writing historical Daily data to the file NQH2.CME.dly | 2021-12-14 11:42:50.877 HD Request # 15 | Bytes received: 248 | 2021-12-14 11:42:50.880 HD Request # 15 | Received 4 Daily data records from 2021-12-09 00:00:00 to 2021-12-13 00:00:00 (5.0 days) and wrote 3 records for NQH2.CME | 2021-12-14 11:42:50.880 HD Request # 15 | Completion time: 1s | 2021-12-14 11:42:50.880 HD Request # 15 | Daily data download complete for NQH2.CME. Unique request ID: 34 | 2021-12-14 11:42:50.880 Removing historical data download ID 34. | 2021-12-14 11:42:50.880 Triggering next historical data download in queue. | 2021-12-14 11:42:50.880 No download requests in the queue to start downloads for. | 2021-12-14 11:42:50.880 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:42:50.936 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:42:50.936 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:42:50.936 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:42:51.495 NQH2.CME [CV] Weekly #11 | Reloading chart. | 2021-12-14 11:42:58.012 NQH2.CME [CV] Weekly #11 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:42:58.013 NQH2.CME [CV] Weekly #11 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-12-14 11:42:58.013 NQH2.CME [CV] Weekly #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-12-14 11:42:58.570 Saved Chartbook: Nasdaq.Cht. Time: 0.0717 seconds. | 2021-12-14 11:49:09.153 |
[2021-12-14 19:28:30] |
John - SC Support - Posts: 40812 |
You should not switch to the older software. There are lots of updates and fixes for things that go into the recent versions. The reason you are continuing to have issues is simply due to the lack of historical data from Rithmic. The next thing to do is to limit the amount of data that you are requesting down to no more than 5 days of data. In other words, change the Number of Days to Load to 5 (or less). Refer to the following for information on this setting: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad Be sure to remove the Continuous Futures option for your other charts as well. Also, refer to the following post for more information on this issue with Rithmic historical data: Historical Data on the New Rithmic Connection The best solution would be to use the Denali Exchange Data Feed for your data rather than Rithmic. Refer to the information at the following link, which includes Setup Instructions: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-14 20:32:37] |
lovelivelaught - Posts: 70 |
All above helped and I got real time data. I wish i would not re download all data as it affected longer time frames, they look like a mess now. And I use cumulative delta study and it does not look right I also looked at the link you provided about Denali Exchange and here what I read : The Denali Exchange Data Feed, is not specific to any particular broker or clearing firm. It is a Sierra Chart data feed which you can subscribe to and pay for directly from your own Sierra Chart account without any involvement of a broker. It provides market data only. It can be used with any Trading service including the Sierra Chart Order Routing Service. And now please I would ask you to explain me what it means. I apologize but I found it is very confusing and very hard for me to understand all that data feeds you are taking about and all that connections you provide. For my Rithmic service to function properly should I get Denali Exchange Data Feed? |
[2021-12-14 22:20:45] |
It is related to my previous post and question: For my Rithmic service to function properly should I get Denali Exchange Data Feed? If yes will it solve all the issues that I have with receiving historic data? And also if previous answer was yes, should I activate CME exchange? I pay Rithmic $11 for CME level 2 with my broker. I use Denali Exchange Data Feed for US equities, is it different? |
[2021-12-14 23:36:33] |
The Denali Exchange Data Feed will definitely solve your issues with the historical data that you are not able to get with Rithmic. The information you posted in post #12 about the Denali Feed working with any trading service is just what it states. We are just pointing out that you can use our data (Denali Exchange Data Feed or the Sierra Chart Exchange Data Feed) with any trading service. In other words, you can get our data and trade with Rithmic without any issue. As to the particular exchange you would want to activate with the Denali Exchange Data Feed, it depends on what exchanges on the CME Group you need data and whether you need Market Depth Data or not. If you let us know, then we can point you to the proper option. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-15 02:11:36] |
Thank you. I upgraded for service package 11 and I understand it was updated instantly by prorating what I have left on my account and I have now Denali data. I followed integration with trading services page for proper set up. I don't have a letter [M] after NQ and ES symbol but there is a letter [C] after the symbol. According to my charts I still don't have historical data. I updated my charts back to continuous contract mode to see if I get a historical data and it did not do anything either. I have a letter [M] after US equities symbol and I have a historical data for US equities. I trade future indexes, particularly NQ and ES and US equities. I am paying monthly for Denali Data Feed to trade US stocks and I pay for US exchange here. Rithmic is my trading servise and I pay $11 for CME level 2 data to my broker. I was satisfied with what I had here before the update and I wonder what else I need to get to have everything working again? And how much will it cost? |
[2021-12-15 15:30:50] |
You are missing a few pieces to the Denali setup. Go through the Setup Instructions for the Denali Exchange Data Feed, which are at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* In the process of doing the above, you will select the exchanges that you want to activate. That is where the primary cost will come from. But, once you are getting the data from us, you can cancel the data from Rithmic (unless you need it for another reason). The costs for the exchanges should be about the same. The only other cost is the additional $10 for Package 11 over Package 5. This is the data feed fee. You can reduce this amount by purchasing multiple months up-front. This would be the only additional fee you will have to pay. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-15 21:36:03] |
I completed the Denali set up and activated CME exchange with Market depth data. It looks like everything is finally working now. Thank you. I have a few questions though: 1. I noticed that if I switch charts on longer time frames to "Continues contracts" I get less historical data. Should I keep it to "None". Will I get continues data flow from one contract month to another? 2. I made changes according to this link you sent me Historical Data on the New Rithmic Connection Should I change it back to what it was before? 3. I use Cumulative Delta Tick and Volume indicators and after starting up the platform this morning it didn't print correct data over night. But it started printing sufficient data after that. Same thing happen after I restarted the platform this afternoon. It erased all data that was printed during a day. I attached a screen shot for you to look at it. Even after duplicating chart for screen shot for you all the Cumulative Volume Delta that was there since restarting the platform was gone. There are only last few minutes of the day of Delta was printed there. It seams like that I have this problem only on 1m and 2m Charts. It looks better on 5m chart. And it does not look that there is anything wrong with it on 1h and 3h chars. https://www.sierrachart.com/image.php?Image=1639603211543.png 4. I use Large Volume Trade Indicator and it did not show any data today, despite that it was a FED reserve volatility day today . The indicator was working fine before the software update. 5. I am paying for Denali every month to get data for US stocks. I updated for package 11 with Denali data. Do I still have to pay for Denali data for stocks or package 11 will cover everything? Thank you in advance for all your help, I am very happy and relieved that everything is starting to work again after 2 stressful days . |
[2021-12-16 16:11:48] |
1) You should definitely not get "less" historical data. You should just get the number of days that you have specified in Chart Settings. This may be related to #2. 2) You can ignore that thread. That issue no longer applies to you since you are now using the Denali Exchange Data Feed instead of Rithmic data. 3)This is probably related to the old data that you had from Rithmic. Go to a chart for each symbol and select Edit >> Delete All Data And Download. If you are asked what contracts to delete, then select all of them. Do this for each symbol, not for each chart (i.e. you only need to do it once for the ES data, once for CL, etc., not once on each ES chart). 4) Perform the steps in #3 first and then let us know if you are still having issues with the Large Volume Trade Indicator. 5) You are actually using the Sierra Chart Exchange Data Feed for the U.S. Stocks and the Denali Exchange Data Feed for the CME Group data. They are separate data feeds, but can work together. The point being that you will continue to pay what you have been for each of these. So you will pay $35.50 per calendar month for the Sierra Chart Exchange Data Feed fees and you will pay $10.40 each calendar month for the Denali Exchange Data Feed exchange fee and the Sierra Chart Package fee when that comes due. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-16 17:24:27] |
Thank you for answering all questions. And to continue with some questions: 3. Edit >> Delete All Data And Download didn't work. After I did it, the data on Cumulative Delta Volume was erased again as it was yesterday and this morning after I started up the platform. I just checked the Cumulative Delta Volume on US stocks and it has same problem on smaller time frames. 4. Still there is no data on chart for the Large Volume Trade Indicator. I tried to change Volume Threshold number to 1 and there was no change. Every time I was changing Volume Threshold number, it was erasing all Cumulative Delta Volume data that was printed prior to the update. Basically every time chat got updated it was erasing all previous data for Cumulative Delta Volume. This indicator works fine on US stocks side. |
[2021-12-16 18:27:47] |
Please get us a copy of the chart that is showing these issues and we will take a look. Refer to the following for how to get us the chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-16 18:56:08] |
Here it is.
![]() Attachment Deleted. |
[2021-12-16 21:20:31] |
Everything looks fine when we open the chart. Attached is an image of what we see when we open your chart. Let us know when we can connect to your system and take a look. It will have to be tomorrow sometime or after, we do not have time this afternoon - be sure you specify the time zone along with a time for us to call. Make sure the phone number listed at the following link is correct, as this will be the number we call: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-16 22:58:21] |
Hello That is strange. I opened that chartbook and changed a time frame on that chart from 1m to 2m and again I got same problem. I live in Calgary Alberta, Mountain Standard Time (GMT-7). You have all my information correct. We can connect tomorrow 2 hours after US Market opens.It would be 9.30am Calgary time. So anytime after that you can call me. Thank you in advance. |
[2021-12-17 14:40:47] |
We will give you a call at 09:30 MST. Note that we call using Skype so there will not be an incoming number. Please ensure that you pick up at that time, even if it shows as a Spam call. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-17 15:27:20] |
I will be waiting for the call at 9.30am my time. I recently changed cell phone provider and sometimes some calls for some reason does not come through. If I will not pick up a phone it means the call didn't go through. Please try couple times. And if, still, there is no reply please try to call on my Skype contact, you will find me there as "yuliabusova" Thank you |
