Date/Time: Tue, 20 Oct 2026 18:29:21 +0000
Real-time CME data not activating (Delayed Data Feed: Yes despite exchange enabled)
View Count: 835
| [2026-04-06 18:52:23] |
| User169323 - Posts: 15 |
Sierra Chart version: 2891 Service: Teton CME Routing (Ironbeam) Denali supported: Yes Denali Authorized Realtime Exchanges: CME Verified Trading Account active through May CME with Market Depth (Non-Professional) activated Charts still show delayed About panel shows: Delayed Data Feed: Yes Restart/reconnect done Symbols corrected (no [M]) Request: 👉 Please check whether my CME real-time data is fully activated on Denali. |
| [2026-04-06 21:31:45] |
| John - SC Support - Posts: 48273 |
Everything on your account looks fine in terms of getting real-time data for the CME exchange, as you have the "CME with Market Depth for Non-Professional Trading Accounts" exchange active. Note that this is the CME exchange of the CME Group, so you only have access to real-time data for symbols traded on the CME exchange. Other symbols will be the delayed streaming data. What is one symbol for which you are having an issue? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-06 22:36:16] |
John, I opened a brand new chart using the direct CME symbol: ESM26_FUT_CME It still shows “Delayed”. This eliminates symbol issues, chartbook issues, and continuous contracts. It appears my Sierra Chart session is not authenticating real-time data even though the CME exchange is active. Can you please check whether my session is correctly authorized for real-time Denali data? |
| [2026-04-07 14:59:00] |
Please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-07 18:13:05] |
After closing all chartbooks. I opened ESM26_FUT_CME. I disconnected (File>Disconnect), then reconnected (File>Connect to Data Feed). Here is the message log. 2026-04-07 11:07:07.440 | Software version: 2891 64-bit 2026-04-07 11:07:07.440 | OpenGL enabled (NVIDIA Corporation/NVIDIA T400 4GB/PCIe/SSE2) 2026-04-07 11:07:07.440 | Primary Thread ID: 32036 2026-04-07 11:07:07.440 | Usage end date: 2026-04-25 2026-04-07 11:07:07.440 | Enabled for: Advanced Features 2. 2026-04-07 11:07:07.440 | Enabled for: Sierra Chart Historical Data Service. 2026-04-07 11:07:07.440 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-04-07 11:07:07.440 | Enabled for: Delayed Denali Exchange Data Feed. 2026-04-07 11:07:07.440 | Enabled for exchange2: CME 2026-04-07 11:07:07.440 | Allow Support for Sierra Chart Data Feeds is disabled. 2026-04-07 11:07:07.440 | Current selected Data/Trading service: Teton CME Routing 2026-04-07 11:07:07.440 | Custom symbol settings values: disabled 2026-04-07 11:07:07.440 | Chart Update Interval: 50 2026-04-07 11:07:07.440 | Intraday Data Storage Time Unit: 0 2026-04-07 11:07:07.440 | Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-04-07 11:07:07.440 | 2026-04-07 18:07:07 Local computer time in UTC 2026-04-07 11:07:07.440 | 2026-04-07 11:07:07 Local computer time in SC Time Zone 2026-04-07 11:07:07.440 | 2026-04-07 18:06:27 Server time in UTC 2026-04-07 11:07:07.440 | Local computer UTC time and Server UTC time difference: 3 seconds. 2026-04-07 11:07:07.440 | Program path: C:\SierraChart\ 2026-04-07 11:07:07.440 | Data Files path: C:\SierraChart\Data\ 2026-04-07 11:07:07.440 | OS Version Number: 10.0 2026-04-07 11:07:07.440 | Locale Setting: C 2026-04-07 11:07:07.440 | Crash reporter started: true 2026-04-07 11:07:07.440 | 2026-04-07 11:07:24.767 | Unsubscribed from market depth data for MESM26_FUT_CME 2026-04-07 11:07:24.767 | Delayed Data Feed (Market Orders Data) | Stopping market orders updates for: MESM26. Service code: cme 2026-04-07 11:07:39.915 | ESM26_FUT_CME 1 Min #1 | Reloading chart. 2026-04-07 11:07:40.840 | ESM26_FUT_CME[M] 1 Min #1 | Chart data loading complete. 2026-04-07 11:07:52.698 | File >> Disconnect selected. 2026-04-07 11:07:52.698 | Teton CME Routing | Waiting for socket receive thread to end 2026-04-07 11:07:52.698 | DTC Client socket (1) | CloseSocket call. 2026-04-07 11:07:52.698 | DTC Client socket (1) | Max send buffers used during socket life: 3 2026-04-07 11:07:52.698 | DTC Client socket (1) | Max send buffer size during socket life: 233 2026-04-07 11:07:52.698 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 11:07:52.698 | Delayed Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-04-07 11:07:52.698 | DTC Client socket (3) | CloseSocket call. 2026-04-07 11:07:52.698 | Delayed Data Feed (Market Orders Data) | Disconnected from the server. 2026-04-07 11:07:52.698 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-07 11:07:52.698 | Delayed Data Feed | Waiting for socket receive thread to end 2026-04-07 11:07:52.698 | DTC Client socket (2) | CloseSocket call. 2026-04-07 11:07:52.698 | Delayed Data Feed | Disconnected from the server. 2026-04-07 11:07:52.698 | Teton CME Routing | Disconnected. 2026-04-07 11:07:52.698 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-04-07 11:07:52.755 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 11:07:52.755 | DTC Client socket (1) | Closed. 2026-04-07 11:07:52.775 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-07 11:07:52.775 | DTC Client socket (3) | Closed. 2026-04-07 11:07:52.904 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-04-07 11:07:52.904 | DTC Client socket (2) | Closed. 2026-04-07 11:08:21.590 | 2026-04-07 11:08:21.590 | Teton CME Routing | Firm: IronBeam 2026-04-07 11:08:21.590 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2026-04-07 11:08:21.594 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 11:08:21.594 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 11:08:21.594 | DTC Client socket (1) | Connecting to IP: 216.200.108.154. 2026-04-07 11:08:21.651 | Teton CME Routing | Network connection to server complete. 2026-04-07 11:08:21.651 | Teton CME Routing | Starting socket receive thread. 2026-04-07 11:08:21.651 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-04-07 11:08:21.824 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-04-07 11:08:21.824 | Teton CME Routing | Sending logon request message. 2026-04-07 11:08:21.932 | Teton CME Routing | Received logon response. 2026-04-07 11:08:21.932 | Teton CME Routing | Server Name: SC DTC Server. Build=55065. 2026-04-07 11:08:21.932 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-04-07 11:08:21.932 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-04-07 11:08:21.932 | Teton CME Routing | Trading is supported. 2026-04-07 11:08:21.932 | Teton CME Routing | Order cancel and replace is supported. 2026-04-07 11:08:21.932 | Teton CME Routing | OCO Orders supported. 2026-04-07 11:08:21.932 | Teton CME Routing | Bracket Orders supported. 2026-04-07 11:08:21.932 | Teton CME Routing | MarketDepthIsSupported: 1 2026-04-07 11:08:21.932 | Teton CME Routing | Connection to server complete. 2026-04-07 11:08:21.932 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-07 11:08:21.932 | Updated verified funded futures trading account ending date to: 2026-05-07 18:08:21 2026-04-07 11:08:21.932 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-04-07 11:08:21.933 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-04-06 18:52:00.813377 2026-04-07 11:08:21.988 | Updated verified funded futures trading account ending date to: 2026-05-07 18:08:21 2026-04-07 11:08:22.104 | Mapping ESM26_FUT_CME to ESM26. Service code: cme 2026-04-07 11:08:22.104 | Using symbol data fast lookup vector 2026-04-07 11:08:22.104 | Delayed Data Feed | Starting real-time market data updates for: ESM26_FUT_CME (ESM26). ID: 1 Service code: cme 2026-04-07 11:08:22.104 | Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 2026-04-07 11:08:22.104 | Delayed Data Feed | Requesting security definition data for: ESM26_FUT_CME (ESM26). ID: 1 2026-04-07 11:08:22.104 | Added historical Intraday data request for ESM26_FUT_CME to the queue. 2026-04-07 11:08:22.104 | Intraday data recording state for symbol ESM26_FUT_CME is set to download 'Pending'. 2026-04-07 11:08:22.104 | Triggering next historical data download in queue. 2026-04-07 11:08:22.106 | Delaying start of download for ESM26_FUT_CME. 2026-04-07 11:08:22.151 | DTC Client socket (2) | Creating socket. 2026-04-07 11:08:22.151 | DTC Client socket (2) | New receive buffer size: 0 2026-04-07 11:08:22.151 | DTC Client socket (2) | Connecting to IP: 67.214.125.6. 2026-04-07 11:08:22.233 | Delayed Data Feed | Network connection to server complete. 2026-04-07 11:08:22.233 | Delayed Data Feed | Starting socket receive thread. 2026-04-07 11:08:22.233 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-07 11:08:22.346 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-04-07 11:08:22.346 | Delayed Data Feed | Sending logon request message. 2026-04-07 11:08:22.845 | Delayed Data Feed | Received logon response. 2026-04-07 11:08:22.845 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-04-07 11:08:22.845 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-07 11:08:22.845 | Delayed Data Feed | Successfully connected. 2026-04-07 11:08:22.845 | Delayed Data Feed | Trading is not supported. 2026-04-07 11:08:22.845 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-04-07 11:08:22.845 | Delayed Data Feed | Restarting real-time data updates for symbol: ESM26_FUT_CME -> ESM26 2026-04-07 11:08:23.033 | Delayed Data Feed | Setting external service identifier for symbol ESM26_FUT_CME to 42140864 2026-04-07 11:08:23.033 | Delayed Data Feed | Received security definition for symbol ESM26_FUT_CME 2026-04-07 11:08:28.242 | HD Request # 3 | Downloading Intraday chart data for ESM26_FUT_CME to the file ESM26_FUT_CME.scid. Service: cme 2026-04-07 11:08:28.242 | HD Request # 3 | Download start date-time: 2026-04-07 11:06:42.000000. File last date-time: 2026-04-07 11:06:42.629001 2026-04-07 11:08:28.242 | HD Request # 3 | Using server: ds32.sierracharts.com port 10149 2026-04-07 11:08:28.242 | Socket (3) | Creating socket. 2026-04-07 11:08:28.243 | Socket (3) | New receive buffer size: 0 2026-04-07 11:08:28.243 | Socket (3) | Connecting to IP: 69.39.70.248. 2026-04-07 11:08:28.405 | HD Request # 3 | Setting DTC encoding to Binary VLS 2026-04-07 11:08:28.405 | HD Request # 3 | Sending historical data logon request message. 2026-04-07 11:08:28.513 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-04-07 11:06:42. Record interval: 0. Symbol: ESM26 2026-04-07 11:08:28.592 | HD Request # 3 | Decompressing data. 2026-04-07 11:08:28.677 | HD Request # 3 | Receiving Intraday data for ESM26_FUT_CME starting at 2026-04-07 11:06:42.001000 2026-04-07 11:08:28.677 | Socket (3) | CloseSocket call. 2026-04-07 11:08:28.677 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-07 11:08:28.677 | Historical data download thread signaled to stop. 2026-04-07 11:08:28.678 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-04-07 11:06:42.641000. 2026-04-07 11:08:28.678 | HD Request # 3 | Received 2396 Intraday data records from 2026-04-07 11:06:42.001000 to 2026-04-07 11:08:25.121006 (103.1 seconds. Delay: 3.6 seconds) and wrote 2343 records for ESM26_FUT_CME 2026-04-07 11:08:28.678 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-04-07 18:08:25.121006 2026-04-07 11:08:28.678 | HD Request # 3 | Completion time: 0s. 2026-04-07 11:08:28.678 | HD Request # 3 | Intraday data download complete for ESM26_FUT_CME. Unique request ID: 3 2026-04-07 11:08:28.678 | Removing historical data download ID 3. 2026-04-07 11:08:28.678 | Real-time Intraday chart data file updates started for ESM26_FUT_CME 2026-04-07 11:08:28.678 | Intraday chart data file opened for ESM26_FUT_CME 2026-04-07 11:08:28.678 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2026-04-07 11:08:28.678 | 2026-04-07 11:08:28.678 | No download requests in the queue to start downloads for. 2026-04-07 11:08:28.759 | Socket (3) | Socket gracefully closed by remote side. 2026-04-07 11:08:28.759 | Socket (3) | Closed. 2026-04-07 11:08:28.940 | Opened cached Intraday file: C:\SierraChart\Data\ESM26_FUT_CME.scid. Thread ID: 7848 |
| [2026-04-07 20:02:06] |
The following from your log is the issue: 2026-04-07 11:07:07.440 | Allow Support for Sierra Chart Data Feeds is disabled.
You need to set the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to "Yes". After you do this, and select OK to close that window, you will need to select "File >> Reconnect". After that, you will be fine. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-07 20:17:37] |
I enabled “Allow Support for Sierra Chart Data Feeds” as instructed, clicked OK, and performed a full disconnect/reconnect. However, the charts are still receiving delayed data only. The real-time Denali feed is still not connecting. The Message Log continues to show connections only to the Delayed Data Feed servers, and there is no real-time authorization handshake. Can you please check my real-time session authorization on the backend? It appears the session is still not being issued a real-time token. |
| [2026-04-07 20:35:23] |
Please ensure that the "Data Delay" is displayed in your Chart Header. If not, then please add it by following these instructions: Working With Charts: Region Data Line / Chart Header Once that is added, then you will see it in the Chart Header with the abbreviation of "DD:". Please choose a specific chart, and let us know the symbol of that chart (exactly as it is entered in "Chart >> Chart Settings >> Symbol >> Symbol") and the value of DD: in the chart header. Getting us an image of the chart would be even better with that DD: value visible. Then also get us your Message Log by following these instructions for the same symbol you used above: Follow the instructions here to clear the Message Log:
| [2026-04-07 21:33:08] |
I added Data Delay through Global Settings, but it did not show up in the header. The Symbol is ESM26_FUT_CME. The chart is still receiving delayed data only. Can you please check my real‑time session authorization on the backend? It appears the session is still not being issued a real‑time token. https://www.sierrachart.com/image.php?Image=1775597016365.png 2026-04-07 14:28:36.630 | Software version: 2891 64-bit 2026-04-07 14:28:36.630 | OpenGL enabled (NVIDIA Corporation/NVIDIA T400 4GB/PCIe/SSE2) 2026-04-07 14:28:36.630 | Primary Thread ID: 32036 2026-04-07 14:28:36.630 | Usage end date: 2026-04-25 2026-04-07 14:28:36.630 | Enabled for: Advanced Features 2. 2026-04-07 14:28:36.630 | Enabled for: Sierra Chart Historical Data Service. 2026-04-07 14:28:36.630 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-04-07 14:28:36.630 | Enabled for: Delayed Denali Exchange Data Feed. 2026-04-07 14:28:36.630 | Enabled for exchange2: CME 2026-04-07 14:28:36.630 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-04-07 14:28:36.630 | Current selected Data/Trading service: Teton CME Routing 2026-04-07 14:28:36.630 | Custom symbol settings values: disabled 2026-04-07 14:28:36.630 | Chart Update Interval: 50 2026-04-07 14:28:36.630 | Intraday Data Storage Time Unit: 0 2026-04-07 14:28:36.630 | Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-04-07 14:28:36.630 | 2026-04-07 21:28:36 Local computer time in UTC 2026-04-07 14:28:36.630 | 2026-04-07 14:28:36 Local computer time in SC Time Zone 2026-04-07 14:28:36.630 | 2026-04-07 18:06:27 Server time in UTC 2026-04-07 14:28:36.630 | Local computer UTC time and Server UTC time difference: 3 seconds. 2026-04-07 14:28:36.630 | Program path: C:\SierraChart\ 2026-04-07 14:28:36.630 | Data Files path: C:\SierraChart\Data\ 2026-04-07 14:28:36.630 | OS Version Number: 10.0 2026-04-07 14:28:36.630 | Locale Setting: C 2026-04-07 14:28:36.630 | Crash reporter started: true 2026-04-07 14:28:36.630 | 2026-04-07 14:29:16.388 | ESM26_FUT_CME 1 Min #1 | Reloading chart. 2026-04-07 14:29:17.336 | ESM26_FUT_CME[M] 1 Min #1 | Chart data loading complete. 2026-04-07 14:29:35.890 | ESM26_FUT_CME 1 Min #1 | Reloading chart. 2026-04-07 14:29:36.841 | ESM26_FUT_CME[M] 1 Min #1 | Chart data loading complete. 2026-04-07 14:29:49.530 | File >> Disconnect selected. 2026-04-07 14:29:49.530 | Teton CME Routing | Waiting for socket receive thread to end 2026-04-07 14:29:49.530 | DTC Client socket (1) | CloseSocket call. 2026-04-07 14:29:49.530 | DTC Client socket (1) | Max send buffers used during socket life: 3 2026-04-07 14:29:49.530 | DTC Client socket (1) | Max send buffer size during socket life: 233 2026-04-07 14:29:49.530 | Denali Data Feed | Waiting for socket receive thread to end 2026-04-07 14:29:49.530 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 14:29:49.530 | DTC Client socket (2) | CloseSocket call. 2026-04-07 14:29:49.530 | Denali Data Feed | Disconnected from the server. 2026-04-07 14:29:49.530 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-04-07 14:29:49.530 | Teton CME Routing | Disconnected. 2026-04-07 14:29:49.589 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 14:29:49.589 | DTC Client socket (1) | Closed. 2026-04-07 14:29:49.614 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-04-07 14:29:49.614 | DTC Client socket (2) | Closed. 2026-04-07 14:29:53.191 | 2026-04-07 14:29:53.191 | Teton CME Routing | Firm: IronBeam 2026-04-07 14:29:53.191 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2026-04-07 14:29:53.234 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 14:29:53.234 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 14:29:53.234 | DTC Client socket (1) | Connecting to IP: 216.200.108.154. 2026-04-07 14:29:53.290 | Teton CME Routing | Network connection to server complete. 2026-04-07 14:29:53.290 | Teton CME Routing | Starting socket receive thread. 2026-04-07 14:29:53.291 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-04-07 14:29:53.461 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-04-07 14:29:53.461 | Teton CME Routing | Sending logon request message. 2026-04-07 14:29:53.568 | Teton CME Routing | Received logon response. 2026-04-07 14:29:53.568 | Teton CME Routing | Server Name: SC DTC Server. Build=55065. 2026-04-07 14:29:53.568 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-04-07 14:29:53.568 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-04-07 14:29:53.568 | Teton CME Routing | Trading is supported. 2026-04-07 14:29:53.568 | Teton CME Routing | Order cancel and replace is supported. 2026-04-07 14:29:53.568 | Teton CME Routing | OCO Orders supported. 2026-04-07 14:29:53.568 | Teton CME Routing | Bracket Orders supported. 2026-04-07 14:29:53.568 | Teton CME Routing | MarketDepthIsSupported: 1 2026-04-07 14:29:53.568 | Teton CME Routing | Connection to server complete. 2026-04-07 14:29:53.569 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-07 14:29:53.569 | Updated verified funded futures trading account ending date to: 2026-05-07 21:29:53 2026-04-07 14:29:53.569 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-04-07 14:29:53.569 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-04-07 18:52:00.862777 2026-04-07 14:29:53.624 | Updated verified funded futures trading account ending date to: 2026-05-07 21:29:53 2026-04-07 14:29:53.765 | Mapping ESM26_FUT_CME to ESM26. Service code: cme 2026-04-07 14:29:53.765 | Using symbol data fast lookup vector 2026-04-07 14:29:53.765 | Denali Data Feed | Starting real-time market data updates for: ESM26_FUT_CME (ESM26). ID: 1 Service code: cme 2026-04-07 14:29:53.765 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2026-04-07 14:29:53.765 | Denali Data Feed | Requesting security definition data for: ESM26_FUT_CME (ESM26). ID: 1 2026-04-07 14:29:53.765 | Added historical Intraday data request for ESM26_FUT_CME to the queue. 2026-04-07 14:29:53.765 | Intraday data recording state for symbol ESM26_FUT_CME is set to download 'Pending'. 2026-04-07 14:29:53.765 | Triggering next historical data download in queue. 2026-04-07 14:29:53.767 | Delaying start of download for ESM26_FUT_CME. 2026-04-07 14:29:53.798 | DTC Client socket (2) | Creating socket. 2026-04-07 14:29:53.798 | DTC Client socket (2) | New receive buffer size: 0 2026-04-07 14:29:53.798 | DTC Client socket (2) | Connecting to IP: 67.214.125.6. 2026-04-07 14:29:53.820 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM26_FUT_CME 2026-04-07 14:29:53.820 | Teton CME Routing | Setting external service identifier for symbol ESM26_FUT_CME to 42140864 2026-04-07 14:29:53.820 | Teton CME Routing | Received security definition for symbol ESM26_FUT_CME 2026-04-07 14:29:53.879 | Denali Data Feed | Network connection to server complete. 2026-04-07 14:29:53.879 | Denali Data Feed | Starting socket receive thread. 2026-04-07 14:29:53.879 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-07 14:29:53.986 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-07 14:29:53.986 | Denali Data Feed | Sending logon request message. 2026-04-07 14:29:54.485 | Denali Data Feed | Received logon response. 2026-04-07 14:29:54.485 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-07 14:29:54.485 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-07 14:29:54.485 | Denali Data Feed | Successfully connected. 2026-04-07 14:29:54.485 | Denali Data Feed | Trading is not supported. 2026-04-07 14:29:54.485 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-07 14:29:54.485 | Denali Data Feed | Restarting real-time data updates for symbol: ESM26_FUT_CME -> ESM26 2026-04-07 14:29:54.672 | Denali Data Feed | Setting external service identifier for symbol ESM26_FUT_CME to 42140864 2026-04-07 14:29:54.672 | Denali Data Feed | Received security definition for symbol ESM26_FUT_CME 2026-04-07 14:29:59.324 | HD Request # 8 | Downloading Intraday chart data for ESM26_FUT_CME to the file ESM26_FUT_CME.scid. Service: cme 2026-04-07 14:29:59.324 | HD Request # 8 | Download start date-time: 2026-04-07 13:59:59.000000. File last date-time: 2026-04-07 13:59:59.785004 2026-04-07 14:29:59.324 | HD Request # 8 | Using server: ds28.sierracharts.com port 10149 2026-04-07 14:29:59.324 | Socket (3) | Creating socket. 2026-04-07 14:29:59.324 | Socket (3) | New receive buffer size: 0 2026-04-07 14:29:59.324 | Socket (3) | Connecting to IP: 67.214.125.5. 2026-04-07 14:29:59.757 | HD Request # 8 | Setting DTC encoding to Binary VLS 2026-04-07 14:29:59.757 | HD Request # 8 | Sending historical data logon request message. 2026-04-07 14:29:59.878 | HD Request # 8 | Requesting Intraday data. Start date-time: 2026-04-07 13:59:59. Record interval: 0. Symbol: ESM26 2026-04-07 14:29:59.958 | HD Request # 8 | Decompressing data. 2026-04-07 14:30:00.038 | HD Request # 8 | Receiving Intraday data for ESM26_FUT_CME starting at 2026-04-07 13:59:59.001000 2026-04-07 14:30:00.038 | Socket (3) | CloseSocket call. 2026-04-07 14:30:00.038 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-07 14:30:00.038 | Historical data download thread signaled to stop. 2026-04-07 14:30:00.038 | HD Request # 8 | Received 23 Intraday data records from 2026-04-07 13:59:59.001000 to 2026-04-07 13:59:59.785004 (0.8 seconds. Delay: 30.0 minutes) and wrote 0 records for ESM26_FUT_CME 2026-04-07 14:30:00.039 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2026-04-07 20:59:59.785004 2026-04-07 14:30:00.039 | HD Request # 8 | Completion time: 1s. 2026-04-07 14:30:00.039 | HD Request # 8 | Intraday data download complete for ESM26_FUT_CME. Unique request ID: 8 2026-04-07 14:30:00.039 | Removing historical data download ID 8. 2026-04-07 14:30:00.039 | Real-time Intraday chart data file updates started for ESM26_FUT_CME 2026-04-07 14:30:00.039 | Intraday chart data file opened for ESM26_FUT_CME 2026-04-07 14:30:00.039 | HD Request # 8 | Enabling Intraday chart updating for symbol. 2026-04-07 14:30:00.039 | 2026-04-07 14:30:00.039 | No download requests in the queue to start downloads for. 2026-04-07 14:30:00.119 | Socket (3) | Socket gracefully closed by remote side. 2026-04-07 14:30:00.120 | Socket (3) | Closed. |
| [2026-04-07 21:40:54] |
Here is the full window image. https://www.sierrachart.com/image.php?Image=1775598005762.png |
| [2026-04-08 13:28:38] |
It appears the session is still not being issued a real‑time token. This is not how it works. You are setup for the real-time data. Everything we see says that you are getting the real-time data. The following from your log in particular: 2026-04-07 14:30:00.039 | Real-time Intraday chart data file updates started for ESM26_FUT_CME
We would need to see that "Data Delay" item in your Chart Header to say with absolute certainty. But we do not know why you are not seeing the information for the chart header. What exactly are you seeing that makes you think you are getting delayed data at this time? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-08 15:31:22] |
Here is what I am seeing on my side, with references from the current Message Log: The symbol header shows the delayed‑feed mapping: ESM26_FUT_CME[M] The “Data Delay” field does not appear in the chart header The chart updates are delayed compared to real‑time The Message Log does not show any real‑time authorization handshake There is no line indicating a successful real‑time connection to the CME real‑time Denali feed From the log (copied below): Multiple entries show explicit delay measurements, for example: “(8.0 hours. Delay: 2.7 seconds)” and “(4.3 seconds. Delay: 2.4 seconds)” These only appear when the feed is delayed. The symbol is repeatedly mapped with the [M] suffix, for example: “ESM26_FUT_CME[M]/MESM26_FUT_CME[M] 400 Trades #3 | Chart data loading complete.” The real‑time authorization handshake is missing. The line “Real-time Intraday chart data file updates started” appears even when the feed is delayed and does not indicate entitlement. If the DD field is missing and the [M] tag is present, the feed is delayed. Please check the entitlement and session token on your backend. If needed, I can initiate Remote Assistance so you can see the issue directly. Attached is the fresh Message Log and a full‑window screenshot showing the [M] tag and missing DD field. There is no line indicating a successful real‑time connection to the Denali server Here is this morning's message log of a new chart initiated. 2026-04-08 08:18:11.989 | Trade activity files set size: 23 2026-04-08 08:18:12.082 | Created the DTC Protocol server. 2026-04-08 08:18:12.082 | DTC Protocol Server listening on port 11099. Address: 0.0.0.0 2026-04-08 08:18:12.082 | Reading Internal Order ID file. 2026-04-08 08:18:12.096 | Reading Trade Orders file. 2026-04-08 08:18:12.096 | Reading Trade Positions file. 2026-04-08 08:18:12.096 | Reading Trade Account Data files. 2026-04-08 08:18:12.098 | NTP Client | Service successfully started. 2026-04-08 08:18:12.098 | Software version: 2891 64-bit 2026-04-08 08:18:12.098 | OpenGL enabled (NVIDIA Corporation/NVIDIA T400 4GB/PCIe/SSE2) 2026-04-08 08:18:12.098 | Primary Thread ID: 33604 2026-04-08 08:18:12.098 | Usage end date: 2026-04-25 2026-04-08 08:18:12.098 | Enabled for: Advanced Features 2. 2026-04-08 08:18:12.098 | Enabled for: Sierra Chart Historical Data Service. 2026-04-08 08:18:12.098 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-04-08 08:18:12.098 | Enabled for: Delayed Denali Exchange Data Feed. 2026-04-08 08:18:12.098 | Enabled for exchange2: CME 2026-04-08 08:18:12.098 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-04-08 08:18:12.098 | Current selected Data/Trading service: Teton CME Routing 2026-04-08 08:18:12.098 | Custom symbol settings values: disabled 2026-04-08 08:18:12.098 | Chart Update Interval: 50 2026-04-08 08:18:12.098 | Intraday Data Storage Time Unit: 0 2026-04-08 08:18:12.098 | Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-04-08 08:18:12.098 | 2026-04-08 15:18:12 Local computer time in UTC 2026-04-08 08:18:12.098 | 2026-04-08 08:18:12 Local computer time in SC Time Zone 2026-04-08 08:18:12.098 | 2026-04-08 15:18:09 Server time in UTC 2026-04-08 08:18:12.098 | Local computer UTC time and Server UTC time difference: 2 seconds. 2026-04-08 08:18:12.098 | Program path: C:\SierraChart\ 2026-04-08 08:18:12.098 | Data Files path: C:\SierraChart\Data\ 2026-04-08 08:18:12.098 | OS Version Number: 10.0 2026-04-08 08:18:12.098 | Locale Setting: C 2026-04-08 08:18:12.098 | Crash reporter started: true 2026-04-08 08:18:12.098 | 2026-04-08 08:18:12.106 | Created the DTC Protocol historical data server. 2026-04-08 08:18:12.107 | HD Server Manager | Listening on port 11098. 2026-04-08 08:18:12.107 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2026-04-08 08:18:12.156 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-04-08 08:18:12.238 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2026-04-08 08:18:12.238 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-04-08 08:18:12.358 | Received 5 login tokens. 2026-04-08 08:18:12.498 | Symbol settings MD5 received. Request ID: 1. 2026-04-08 08:18:12.498 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2026-04-08 08:18:14.612 | Requested user files to download. 2026-04-08 08:18:19.839 | Files to Open on Startup | Opening file: ES.Cht 2026-04-08 08:18:19.864 | ESM26_FUT_CME/MESM26_FUT_CME 2500 Trades #1 | Reloading chart. 2026-04-08 08:18:20.096 | ESM26_FUT_CME/MESM26_FUT_CME 400 Trades #3 | Reloading chart. 2026-04-08 08:18:20.133 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Reloading chart. 2026-04-08 08:18:20.157 | 2026-04-08 08:18:20.157 | Teton CME Routing | Firm: IronBeam 2026-04-08 08:18:20.157 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2026-04-08 08:18:20.157 | Starting DelayedDownloadMonitoringTimer 2026-04-08 08:18:20.157 | Starting HDTimeoutTimer 2026-04-08 08:18:20.158 | Added historical Intraday data request for ESM26_FUT_CME to the queue. 2026-04-08 08:18:20.158 | Triggering next historical data download in queue. 2026-04-08 08:18:20.159 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Performing continuous chart historical Daily data download for symbol ESM26_FUT_CME starting at last date in file. 2026-04-08 08:18:20.159 | Starting DelayedDownloadMonitoringTimer 2026-04-08 08:18:20.159 | Starting HDTimeoutTimer 2026-04-08 08:18:20.159 | Added historical Daily data request for ESM26_FUT_CME to the queue. 2026-04-08 08:18:20.159 | Triggering next historical data download in queue. 2026-04-08 08:18:20.181 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Waiting for historical downloads to complete with the IDs: 1, 2, 2026-04-08 08:18:20.216 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-08 08:18:20.216 | DTC Client socket (1) | New receive buffer size: 0 2026-04-08 08:18:20.216 | DTC Client socket (1) | Connecting to IP: 216.200.108.154. 2026-04-08 08:18:20.248 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 60 Min #6 | Reloading chart. 2026-04-08 08:18:20.312 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 60 Min #6 | Waiting for historical downloads to complete with the IDs: 1, 2, 2026-04-08 08:18:20.350 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Reloading chart. 2026-04-08 08:18:20.363 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2, 2026-04-08 08:18:20.409 | ESM26_FUT_CME/MESM26_FUT_CME 300 Trades #8 | Reloading chart. 2026-04-08 08:18:20.481 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Reloading chart. 2026-04-08 08:18:20.495 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Waiting for historical downloads to complete with the IDs: 1, 2, 2026-04-08 08:18:20.715 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] Daily #4 | Reloading chart. 2026-04-08 08:18:20.953 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] Daily #4 | Waiting for historical downloads to complete with the IDs: 2, 2026-04-08 08:18:20.979 | Mapping MESM26_FUT_CME to MESM26. Service code: cme 2026-04-08 08:18:20.979 | Using symbol data fast lookup vector 2026-04-08 08:18:20.979 | Mapping ESM26_FUT_CME to ESM26. Service code: cme 2026-04-08 08:18:20.980 | HD Request # 1 | Downloading Intraday chart data for ESM26_FUT_CME to the file ESM26_FUT_CME.scid. Service: cme 2026-04-08 08:18:20.980 | HD Request # 1 | Download start date-time: 2026-04-08 00:18:44.000000. File last date-time: 2026-04-08 00:18:44.352003 2026-04-08 08:18:20.980 | HD Request # 1 | Using server: ds26.sierracharts.com port 10150 2026-04-08 08:18:20.981 | HD Request # 2 | Downloading Historical Daily chart data for ESM26_FUT_CME. Starting date: 2026-04-03. Service: sc_futures_direct.dtc.trading 2026-04-08 08:18:20.982 | Teton CME Routing | Network connection to server complete. 2026-04-08 08:18:20.982 | Teton CME Routing | Starting socket receive thread. 2026-04-08 08:18:20.982 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-04-08 08:18:21.031 | Socket (2) | Creating socket. 2026-04-08 08:18:21.031 | Socket (2) | New receive buffer size: 0 2026-04-08 08:18:21.031 | Socket (2) | Connecting to IP: 64.152.155.17. 2026-04-08 08:18:21.158 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-04-08 08:18:21.158 | Teton CME Routing | Sending logon request message. 2026-04-08 08:18:21.194 | HD Request # 1 | Setting DTC encoding to Binary VLS 2026-04-08 08:18:21.194 | HD Request # 1 | Sending historical data logon request message. 2026-04-08 08:18:21.264 | Teton CME Routing | Received logon response. 2026-04-08 08:18:21.264 | Teton CME Routing | Server Name: SC DTC Server. Build=55065. 2026-04-08 08:18:21.264 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-04-08 08:18:21.264 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-04-08 08:18:21.264 | Teton CME Routing | Trading is supported. 2026-04-08 08:18:21.264 | Teton CME Routing | Order cancel and replace is supported. 2026-04-08 08:18:21.264 | Teton CME Routing | OCO Orders supported. 2026-04-08 08:18:21.264 | Teton CME Routing | Bracket Orders supported. 2026-04-08 08:18:21.264 | Teton CME Routing | MarketDepthIsSupported: 1 2026-04-08 08:18:21.264 | Teton CME Routing | Connection to server complete. 2026-04-08 08:18:21.264 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-08 08:18:21.264 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-04-08 08:18:21.265 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-04-07 18:52:00.862777 2026-04-08 08:18:21.308 | HD Request # 1 | Requesting Intraday data. Start date-time: 2026-04-08 00:18:44. Record interval: 0. Symbol: ESM26 2026-04-08 08:18:21.319 | Updated verified funded futures trading account ending date to: 2026-05-08 15:18:21 2026-04-08 08:18:21.364 | Mapping MESM26_FUT_CME to MESM26. Service code: cme 2026-04-08 08:18:21.364 | Using symbol data fast lookup vector 2026-04-08 08:18:21.364 | Denali Data Feed | Starting real-time market data updates for: MESM26_FUT_CME (MESM26). ID: 1 Service code: cme 2026-04-08 08:18:21.364 | Denali Data Feed | Connecting to the server ds7.sierracharts.com. Port 443 2026-04-08 08:18:21.364 | Denali Data Feed | Requesting security definition data for: MESM26_FUT_CME (MESM26). ID: 1 2026-04-08 08:18:21.364 | Mapping ESM26_FUT_CME to ESM26. Service code: cme 2026-04-08 08:18:21.364 | Denali Data Feed | Starting real-time market data updates for: ESM26_FUT_CME (ESM26). ID: 2 Service code: cme 2026-04-08 08:18:21.364 | Denali Data Feed | Requesting security definition data for: ESM26_FUT_CME (ESM26). ID: 2 2026-04-08 08:18:21.387 | HD Request # 1 | Decompressing data. 2026-04-08 08:18:21.412 | DTC Client socket (4) | Creating socket. 2026-04-08 08:18:21.412 | DTC Client socket (4) | New receive buffer size: 0 2026-04-08 08:18:21.412 | DTC Client socket (4) | Connecting to IP: 69.39.70.253. 2026-04-08 08:18:21.417 | HD Request # 2 | Requesting historical Daily data for ESM26 starting at 2026-04-02. SC External HD service. 2026-04-08 08:18:21.419 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESM26_FUT_CME 2026-04-08 08:18:21.419 | Teton CME Routing | Setting external service identifier for symbol MESM26_FUT_CME to 42005163 2026-04-08 08:18:21.419 | Teton CME Routing | Received security definition for symbol MESM26_FUT_CME 2026-04-08 08:18:21.433 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM26_FUT_CME 2026-04-08 08:18:21.433 | Teton CME Routing | Setting external service identifier for symbol ESM26_FUT_CME to 42140864 2026-04-08 08:18:21.433 | Teton CME Routing | Received security definition for symbol ESM26_FUT_CME 2026-04-08 08:18:21.475 | HD Request # 1 | Receiving Intraday data for ESM26_FUT_CME starting at 2026-04-08 00:18:44.148000 2026-04-08 08:18:21.496 | Denali Data Feed | Network connection to server complete. 2026-04-08 08:18:21.496 | Denali Data Feed | Starting socket receive thread. 2026-04-08 08:18:21.496 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-08 08:18:21.603 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-04-08 08:18:21.603 | Denali Data Feed | Sending logon request message. 2026-04-08 08:18:21.679 | HD Request # 2 | Receiving historical Daily data for ESM26_FUT_CME starting at 2026-04-03. 2026-04-08 08:18:21.679 | HD Request # 2 | Writing historical Daily data to the file ESM26_FUT_CME.dly. 2026-04-08 08:18:21.682 | HD Request # 2 | Bytes received: 294 2026-04-08 08:18:21.682 | HD Request # 2 | Received 5 Daily data records from 2026-04-03 00:00:00 to 2026-04-08 00:00:00 (6.0 days) and wrote 4 records for ESM26_FUT_CME 2026-04-08 08:18:21.682 | HD Request # 2 | Completion time: 1s. 2026-04-08 08:18:21.682 | HD Request # 2 | Daily data download complete for ESM26_FUT_CME. Unique request ID: 2 2026-04-08 08:18:21.682 | Removing historical data download ID 2. 2026-04-08 08:18:21.682 | 2026-04-08 08:18:21.682 | No download requests in the queue to start downloads for. 2026-04-08 08:18:21.698 | HD Request # 1 | Timestamp of first Intraday data file record written: 2026-04-08 00:18:45.341000. 2026-04-08 08:18:21.868 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] Daily #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 08:18:21.869 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] Daily #4 | Reloading chart. 2026-04-08 08:18:22.138 | ESM26_FUT_CME[M]/MESM26_FUT_CME[M] 400 Trades #3 | Chart data loading complete. 2026-04-08 08:18:22.149 | ESM26_FUT_CME[M]/MESM26_FUT_CME[M] 2500 Trades #1 | Chart data loading complete. 2026-04-08 08:18:22.157 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] Daily #4 | Chart data loading complete. 2026-04-08 08:18:22.158 | Denali Data Feed | Received logon response. 2026-04-08 08:18:22.158 | Denali Data Feed | Server Name: SC Realtime Server. 2026-04-08 08:18:22.158 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-04-08 08:18:22.158 | Denali Data Feed | Successfully connected. 2026-04-08 08:18:22.158 | Denali Data Feed | Trading is not supported. 2026-04-08 08:18:22.158 | Denali Data Feed | MarketDepthIsSupported: 1 2026-04-08 08:18:22.158 | Denali Data Feed | Restarting real-time data updates for symbol: ESM26_FUT_CME -> ESM26 2026-04-08 08:18:22.158 | Denali Data Feed | Restarting real-time data updates for symbol: MESM26_FUT_CME -> MESM26 2026-04-08 08:18:22.322 | Denali Data Feed | Setting external service identifier for symbol ESM26_FUT_CME to 42140864 2026-04-08 08:18:22.322 | Denali Data Feed | Received security definition for symbol ESM26_FUT_CME 2026-04-08 08:18:22.322 | Denali Data Feed | Setting external service identifier for symbol MESM26_FUT_CME to 42005163 2026-04-08 08:18:22.322 | Denali Data Feed | Received security definition for symbol MESM26_FUT_CME 2026-04-08 08:18:22.390 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] Daily #4 | Reloading chart. 2026-04-08 08:18:22.818 | ESM26_FUT_CME[M]/MESM26_FUT_CME[M] 300 Trades #8 | Chart data loading complete. 2026-04-08 08:18:22.825 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] Daily #4 | Chart data loading complete. 2026-04-08 08:18:22.994 | Socket (2) | CloseSocket call. 2026-04-08 08:18:22.994 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-08 08:18:22.994 | Historical data download thread signaled to stop. 2026-04-08 08:18:22.995 | HD Request # 1 | Received 671928 Intraday data records from 2026-04-08 00:18:44.148000 to 2026-04-08 08:18:20.329002 (8.0 hours. Delay: 2.7 seconds) and wrote 671917 records for ESM26_FUT_CME 2026-04-08 08:18:22.995 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2026-04-08 15:18:20.329002 2026-04-08 08:18:22.995 | Added 67 Time and Sales records to Intraday data file for ESM26_FUT_CME after download. 2026-04-08 08:18:22.995 | HD Request # 1 | Completion time: 2s. 2026-04-08 08:18:22.995 | HD Request # 1 | Intraday data download complete for ESM26_FUT_CME. Unique request ID: 1 2026-04-08 08:18:22.995 | Removing historical data download ID 1. 2026-04-08 08:18:22.995 | Real-time Intraday chart data file updates started for ESM26_FUT_CME 2026-04-08 08:18:22.995 | Intraday chart data file opened for ESM26_FUT_CME 2026-04-08 08:18:22.995 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2026-04-08 08:18:22.995 | 2026-04-08 08:18:22.995 | No download requests in the queue to start downloads for. 2026-04-08 08:18:22.995 | Initiating new historical data download for ESM26_FUT_CME to get the latest data since the download was started while not connected to primary service. 2026-04-08 08:18:22.995 | Added historical Intraday data request for ESM26_FUT_CME to the queue. 2026-04-08 08:18:22.995 | Intraday data recording state for symbol ESM26_FUT_CME is set to download 'Pending'. 2026-04-08 08:18:22.995 | Triggering next historical data download in queue. 2026-04-08 08:18:22.995 | Delaying start of download for ESM26_FUT_CME. 2026-04-08 08:18:23.076 | Socket (2) | Socket gracefully closed by remote side. 2026-04-08 08:18:23.076 | Socket (2) | Closed. 2026-04-08 08:18:23.164 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 08:18:23.164 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Reloading chart. 2026-04-08 08:18:23.187 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 60 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 08:18:23.187 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 60 Min #6 | Reloading chart. 2026-04-08 08:18:23.210 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 08:18:23.211 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Reloading chart. 2026-04-08 08:18:23.240 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 08:18:23.240 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Reloading chart. 2026-04-08 08:18:23.637 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Reloading chart. 2026-04-08 08:18:23.714 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Waiting for historical downloads to complete with the IDs: 3, 2026-04-08 08:18:23.717 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 60 Min #6 | Reloading chart. 2026-04-08 08:18:23.811 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 60 Min #6 | Waiting for historical downloads to complete with the IDs: 3, 2026-04-08 08:18:23.812 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Reloading chart. 2026-04-08 08:18:23.840 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Waiting for historical downloads to complete with the IDs: 3, 2026-04-08 08:18:23.843 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Reloading chart. 2026-04-08 08:18:23.875 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Waiting for historical downloads to complete with the IDs: 3, 2026-04-08 08:18:24.281 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-08 08:18:24.547 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Chart data loading complete. 2026-04-08 08:18:25.847 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Chart data loading complete. 2026-04-08 08:18:26.279 | Requesting market depth updates for: MESM26_FUT_CME if supported. NumLevels=200 2026-04-08 08:18:26.279 | Denali Data Feed (Market Orders Data) | Connecting to the server ds7.sierracharts.com. Port 10060 2026-04-08 08:18:26.279 | DTC Client socket (2) | Creating socket. 2026-04-08 08:18:26.279 | DTC Client socket (2) | New receive buffer size: 0 2026-04-08 08:18:26.279 | DTC Client socket (2) | Connecting to IP: 69.39.70.253. 2026-04-08 08:18:26.360 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-04-08 08:18:26.360 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-04-08 08:18:26.360 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard 2026-04-08 08:18:26.418 | Denali Data Feed | Clearing market depth for MESM26_FUT_CME 2026-04-08 08:18:26.448 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-04-08 08:18:26.448 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-04-08 08:18:26.634 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-04-08 08:18:26.634 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-04-08 08:18:26.634 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-04-08 08:18:26.634 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-04-08 08:18:26.634 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-04-08 08:18:26.634 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-04-08 08:18:26.635 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: MESM26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-04-08 08:18:26.635 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: MESM26_FUT_CME -> MESM26 2026-04-08 08:18:26.822 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: MESM26_FUT_CME. Market orders request not authorized. 2026-04-08 08:18:27.208 | HD Request # 3 | Downloading Intraday chart data for ESM26_FUT_CME to the file ESM26_FUT_CME.scid. Service: cme 2026-04-08 08:18:27.208 | HD Request # 3 | Download start date-time: 2026-04-08 08:18:21.000000. File last date-time: 2026-04-08 08:18:21.409000 2026-04-08 08:18:27.208 | HD Request # 3 | Using server: ds32.sierracharts.com port 10149 2026-04-08 08:18:27.272 | Socket (3) | Creating socket. 2026-04-08 08:18:27.272 | Socket (3) | New receive buffer size: 0 2026-04-08 08:18:27.272 | Socket (3) | Connecting to IP: 69.39.70.248. 2026-04-08 08:18:27.435 | HD Request # 3 | Setting DTC encoding to Binary VLS 2026-04-08 08:18:27.435 | HD Request # 3 | Sending historical data logon request message. 2026-04-08 08:18:27.540 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-04-08 08:18:21. Record interval: 0. Symbol: ESM26 2026-04-08 08:18:27.621 | HD Request # 3 | Decompressing data. 2026-04-08 08:18:27.701 | HD Request # 3 | Receiving Intraday data for ESM26_FUT_CME starting at 2026-04-08 08:18:21.013000 2026-04-08 08:18:27.701 | Socket (3) | CloseSocket call. 2026-04-08 08:18:27.701 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-08 08:18:27.701 | Historical data download thread signaled to stop. 2026-04-08 08:18:27.701 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-04-08 08:18:21.564000. 2026-04-08 08:18:27.701 | HD Request # 3 | Received 195 Intraday data records from 2026-04-08 08:18:21.013000 to 2026-04-08 08:18:25.337000 (4.3 seconds. Delay: 2.4 seconds) and wrote 148 records for ESM26_FUT_CME 2026-04-08 08:18:27.701 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-04-08 15:18:25.337000 2026-04-08 08:18:27.701 | Added 27 Time and Sales records to Intraday data file for ESM26_FUT_CME after download. 2026-04-08 08:18:27.701 | HD Request # 3 | Completion time: 0s. 2026-04-08 08:18:27.701 | HD Request # 3 | Intraday data download complete for ESM26_FUT_CME. Unique request ID: 3 2026-04-08 08:18:27.701 | Removing historical data download ID 3. 2026-04-08 08:18:27.701 | Real-time Intraday chart data file updates started for ESM26_FUT_CME 2026-04-08 08:18:27.701 | Intraday chart data file opened for ESM26_FUT_CME 2026-04-08 08:18:27.701 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2026-04-08 08:18:27.701 | 2026-04-08 08:18:27.701 | No download requests in the queue to start downloads for. 2026-04-08 08:18:27.782 | Socket (3) | Socket gracefully closed by remote side. 2026-04-08 08:18:27.782 | Socket (3) | Closed. 2026-04-08 08:18:28.176 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 08:18:28.176 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Reloading chart. 2026-04-08 08:18:28.199 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 60 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 08:18:28.199 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 60 Min #6 | Reloading chart. 2026-04-08 08:18:28.223 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 08:18:28.223 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Reloading chart. 2026-04-08 08:18:28.236 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 08:18:28.236 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Reloading chart. 2026-04-08 08:18:28.694 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 1 Day #2 | Reloading chart. 2026-04-08 08:18:28.775 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 60 Min #6 | Reloading chart. 2026-04-08 08:18:28.827 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] 5 Min #7 | Reloading chart. 2026-04-08 08:18:28.855 | ESM26_FUT_CME/MESM26_FUT_CME [CBV] #9 | Reloading chart. 2026-04-08 08:18:29.288 | ESM26_FUT_CME[M]/MESM26_FUT_CME [CBV][M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-08 08:18:29.289 | ESM26_FUT_CME[M]/MESM26_FUT_CME [CBV][M] #9 | Chart data loading complete. 2026-04-08 08:18:30.571 | ESM26_FUT_CME[M]/MESM26_FUT_CME [CBV][M] 5 Min #7 | Chart data loading complete. 2026-04-08 08:18:32.129 | Opened cached Intraday file: C:\SierraChart\Data\ESM26_FUT_CME.scid. Thread ID: 34540 2026-04-08 08:18:34.000 | ESM26_FUT_CME[M]/MESM26_FUT_CME [CBV][M] 60 Min #6 | Chart data loading complete. 2026-04-08 08:18:36.906 | ESM26_FUT_CME[M]/MESM26_FUT_CME [CBV][M] 1 Day #2 | Chart data loading complete. 2026-04-08 08:18:41.331 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-04-08 08:18:41.741 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-05-06"}. Success=true 2026-04-08 08:18:56.615 | ESM26_FUT_CME[M]/MESM26_FUT_CME [CBV][M] #9 | StartDateTimeForLoadingOrderFills: 2025-04-01 00:00:00 2026-04-08 08:19:16.363 | Unsubscribed from market depth data for MESM26_FUT_CME 2026-04-08 08:19:16.363 | Denali Data Feed (Market Orders Data) | Stopping market orders updates for: MESM26. Service code: cme 2026-04-08 08:19:24.408 | ESM26_FUT_CME 1 Min #1 | Reloading chart. 2026-04-08 08:19:25.382 | ESM26_FUT_CME[M] 1 Min #1 | Chart data loading complete. https://www.sierrachart.com/image.php?Image=177566190956.png |
| [2026-04-08 18:47:58] |
To start with, do NOT use AI to troubleshoot issues. Nearly everything you stated is completely wrong. The symbol header shows the delayed‑feed mapping: ESM26_FUT_CME[M]
ESM26_FUT_CME is the symbol used when you are connected to the "Teton CME Routing" service. The [M] showing after it means that you are getting the data from our Denali Exchange Data Feed. The Message Log does not show any real‑time authorization handshake
There is no line indicating a successful real‑time connection to the CME real‑time Denali feed There is nothing in the log that would show this specifically. There are some clues, such as the following: Denali Data Feed | Server Name: SC Realtime Server. Which indicates that you are connecting to the real-time server. There are also no mentions of being connected to the delayed servers. Multiple entries show explicit delay measurements, for example:
“(8.0 hours. Delay: 2.7 seconds)” and “(4.3 seconds. Delay: 2.4 seconds)” These only appear when the feed is delayed. Those are the amount of time for which missing data needs to be downloaded. It has absolutely no bearing on whether you are on a delayed feed or not. The real‑time authorization handshake is missing. The line
“Real-time Intraday chart data file updates started” appears even when the feed is delayed and does not indicate entitlement. The line that shows "entitlement" is the following: Enabled for: Denali Real-Time Exchange Data Feed. But it is not completely indicitive of the situation, as there are other factors that have to be considered. ----- What exactly are you seeing that makes you think the data is delayed, outside of the log. Everything we see says that you should be fine. We really would like to see the "DD:" in the header, although we do not understand why you are not able to view this. Please check your "Chart Text" coloring in the Graphics Settings. Keep in mind that you need to see if you are using the Global Graphics settings or the Chart Specific graphics settings and adjust the proper coloring in that item. Refer to the following: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts Make sure that Chart Text coloring is not set to be the same as your background. Another thing to try, is in the "Chart Header" option, select the "Data Delay" entry and select the button on the right for "Reverse Color". This will help this item stand out. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-08 20:18:45] |
The issue is now resolved. I had previously observed “Delayed” in the chart header, indicating a data entitlement or session issue at that time. After reconnecting and reloading symbols, the feed is now functioning in real time (continuous DOM updates, smooth Time & Sales/footprint, normal DD latency). The exact trigger for the correction is unclear, but the data is currently working as expected. No further assistance needed. Thank you. |
| [2026-04-09 01:24:25] |
I spoke too soon. I have 3 subinstances connected to the main instance, each sub has a dedicated, linked future. And each subinstance is 10 minutes delayed. It shows it in the label but it also shows it in the Time & Sales. Here is the message log. Please advise. 2026-04-08 18:12:10.981 | Trade activity files set size: 11 2026-04-08 18:12:11.077 | Created the DTC Protocol server. 2026-04-08 18:12:11.077 | DTC Protocol Server listening on port 11112. Address: 0.0.0.0 2026-04-08 18:12:11.077 | Reading Internal Order ID file. 2026-04-08 18:12:11.078 | Reading Trade Orders file. 2026-04-08 18:12:11.078 | Reading Trade Positions file. 2026-04-08 18:12:11.078 | Reading Trade Account Data files. 2026-04-08 18:12:11.091 | Software version: 2891 64-bit 2026-04-08 18:12:11.091 | Sub Instance 2026-04-08 18:12:11.092 | OpenGL enabled (NVIDIA Corporation/NVIDIA T400 4GB/PCIe/SSE2) 2026-04-08 18:12:11.092 | Primary Thread ID: 30268 2026-04-08 18:12:11.092 | Usage end date: 2026-04-25 2026-04-08 18:12:11.092 | Enabled for: Advanced Features 2. 2026-04-08 18:12:11.092 | Enabled for: Sierra Chart Historical Data Service. 2026-04-08 18:12:11.092 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-04-08 18:12:11.092 | Enabled for: Delayed Denali Exchange Data Feed. 2026-04-08 18:12:11.092 | Enabled for exchange2: CME 2026-04-08 18:12:11.092 | Allow Support for Sierra Chart Data Feeds is disabled. 2026-04-08 18:12:11.092 | Current selected Data/Trading service: DTC - Sub Instance 2026-04-08 18:12:11.092 | Custom symbol settings values: disabled 2026-04-08 18:12:11.092 | Chart Update Interval: 50 2026-04-08 18:12:11.092 | Intraday Data Storage Time Unit: 0 2026-04-08 18:12:11.092 | Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-04-08 18:12:11.092 | 2026-04-09 01:12:11 Local computer time in UTC 2026-04-08 18:12:11.092 | 2026-04-08 18:12:11 Local computer time in SC Time Zone 2026-04-08 18:12:11.092 | 2026-04-09 01:12:08 Server time in UTC 2026-04-08 18:12:11.092 | Local computer UTC time and Server UTC time difference: 2 seconds. 2026-04-08 18:12:11.092 | Program path: C:\SierraChart\SierraChartInstance_3\ 2026-04-08 18:12:11.092 | Data Files path: C:\SierraChart\SierraChartInstance_3\Data\ 2026-04-08 18:12:11.092 | OS Version Number: 10.0 2026-04-08 18:12:11.092 | Locale Setting: C 2026-04-08 18:12:11.092 | Crash reporter started: true 2026-04-08 18:12:11.092 | 2026-04-08 18:12:11.092 | Created the DTC Protocol historical data server. 2026-04-08 18:12:11.092 | HD Server Manager | Listening on port 11111. 2026-04-08 18:12:11.099 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-04-08 18:12:11.179 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2026-04-08 18:12:11.179 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-04-08 18:12:11.342 | Received 5 login tokens. 2026-04-08 18:12:13.615 | Requested user files to download. 2026-04-08 18:12:15.618 | 2026-04-08 18:12:15.619 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2026-04-08 18:12:15.620 | DTC Client socket (1) | Creating socket. 2026-04-08 18:12:15.620 | DTC Client socket (1) | New receive buffer size: 0 2026-04-08 18:12:15.620 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2026-04-08 18:12:15.620 | DTC - Sub Instance | Network connection to server complete. 2026-04-08 18:12:15.620 | DTC - Sub Instance | Starting socket receive thread. 2026-04-08 18:12:15.620 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2026-04-08 18:12:15.670 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2026-04-08 18:12:15.670 | DTC - Sub Instance | Sending logon request message. 2026-04-08 18:12:15.670 | DTC - Sub Instance | Received logon response. 2026-04-08 18:12:15.670 | DTC - Sub Instance | Server Name: SC DTC Server. Build=55966. 2026-04-08 18:12:15.670 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2026-04-08 18:12:15.670 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading. 2026-04-08 18:12:15.670 | DTC - Sub Instance | Trading is supported. 2026-04-08 18:12:15.670 | DTC - Sub Instance | Order cancel and replace is supported. 2026-04-08 18:12:15.670 | DTC - Sub Instance | OCO Orders supported. 2026-04-08 18:12:15.670 | DTC - Sub Instance | Bracket Orders supported. 2026-04-08 18:12:15.670 | DTC - Sub Instance | MarketDepthIsSupported: 1 2026-04-08 18:12:15.670 | DTC - Sub Instance | Connection to server complete. 2026-04-08 18:12:15.671 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-08 18:12:15.671 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2026-04-08 18:12:16.084 | Symbol settings MD5 received. Request ID: 1. 2026-04-08 18:12:16.084 | Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 2. 2026-04-08 18:12:16.717 | Symbol settings received. Request ID: 2. 2026-04-08 18:12:18.850 | Files to Open on Startup | Opening file: C:\Program Files\SierraChart\Data\CL.cht 2026-04-08 18:12:18.917 | CLK26_FUT_CME/MCLK26_FUT_CME 2000 Volume #1 | Reloading chart. 2026-04-08 18:12:19.179 | CLK26_FUT_CME/MCLK26_FUT_CME 300 Volume #3 | Reloading chart. 2026-04-08 18:12:19.237 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 1 Day #2 | Reloading chart. 2026-04-08 18:12:19.261 | Starting DelayedDownloadMonitoringTimer 2026-04-08 18:12:19.261 | Starting HDTimeoutTimer 2026-04-08 18:12:19.261 | Added historical Intraday data request for CLK26_FUT_CME to the queue. 2026-04-08 18:12:19.262 | Triggering next historical data download in queue. 2026-04-08 18:12:19.263 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 1 Day #2 | Performing continuous chart historical Daily data download for symbol CLK26_FUT_CME starting at last date in file. 2026-04-08 18:12:19.263 | Added historical Daily data request for CLK26_FUT_CME to the queue. 2026-04-08 18:12:19.291 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 1 Day #2 | Waiting for historical downloads to complete with the IDs: 1, 2, 2026-04-08 18:12:19.377 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 60 Min #6 | Reloading chart. 2026-04-08 18:12:19.432 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 60 Min #6 | Waiting for historical downloads to complete with the IDs: 1, 2, 2026-04-08 18:12:19.494 | CLK26_FUT_CME/MCLK26_FUT_CME 5 Min #7 | Reloading chart. 2026-04-08 18:12:19.534 | CLK26_FUT_CME/MCLK26_FUT_CME 300 Trades #8 | Reloading chart. 2026-04-08 18:12:19.598 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] #9 | Reloading chart. 2026-04-08 18:12:19.605 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] #9 | Waiting for historical downloads to complete with the IDs: 1, 2, 2026-04-08 18:12:19.832 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] Daily #4 | Reloading chart. 2026-04-08 18:12:20.152 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] Daily #4 | Waiting for historical downloads to complete with the IDs: 2, 2026-04-08 18:12:20.266 | CLK26_FUT_CME/MCLK26_FUT_CME 2000 Volume #1 | Chart data loading complete. 2026-04-08 18:12:20.273 | CLK26_FUT_CME/MCLK26_FUT_CME 300 Volume #3 | Chart data loading complete. 2026-04-08 18:12:20.457 | CLK26_FUT_CME/MCLK26_FUT_CME 5 Min #7 | Chart data loading complete. 2026-04-08 18:12:20.465 | CLK26_FUT_CME/MCLK26_FUT_CME 300 Trades #8 | Chart data loading complete. 2026-04-08 18:12:20.465 | Using symbol data fast lookup vector 2026-04-08 18:12:20.465 | HD Request # 1 | Downloading Intraday chart data for CLK26_FUT_CME to the file CLK26_FUT_CME.scid. Service: nymex 2026-04-08 18:12:20.465 | HD Request # 1 | Download start date-time: 2026-04-02 13:59:59.000000. File last date-time: 2026-04-02 13:59:59.824000 2026-04-08 18:12:20.465 | HD Request # 1 | Using server: ds26.sierracharts.com port 10150 2026-04-08 18:12:20.686 | DTC - Sub Instance | Starting real-time market data updates for: MCLK26_FUT_CME. ID: 2 2026-04-08 18:12:20.686 | DTC - Sub Instance | Requesting security definition data for: MCLK26_FUT_CME. ID: 2 2026-04-08 18:12:20.686 | Requesting market depth updates for: MCLK26_FUT_CME if supported. NumLevels=1400 2026-04-08 18:12:20.686 | DTC - Sub Instance | Starting market orders updates for: MCLK26_FUT_CME. MinimumMarketByOrderQuantity: 0 2026-04-08 18:12:20.686 | DTC - Sub Instance | Clearing market depth for MCLK26_FUT_CME | Number times message added: 1 2026-04-08 18:12:20.686 | DTC - Sub Instance | Setting external service identifier for symbol MCLK26_FUT_CME to 5 2026-04-08 18:12:20.686 | DTC - Sub Instance | Received security definition for symbol MCLK26_FUT_CME 2026-04-08 18:12:20.859 | DTC - Sub Instance | Setting external service identifier for symbol MCLK26_FUT_CME to 42024057 2026-04-08 18:12:20.859 | DTC - Sub Instance | Received security definition for symbol MCLK26_FUT_CME 2026-04-08 18:12:20.889 | DTC - Sub Instance | Starting real-time market data updates for: CLK26_FUT_CME. ID: 1 2026-04-08 18:12:20.889 | DTC - Sub Instance | Requesting security definition data for: CLK26_FUT_CME. ID: 1 2026-04-08 18:12:20.906 | DTC - Sub Instance | Setting external service identifier for symbol CLK26_FUT_CME to 6 2026-04-08 18:12:20.906 | DTC - Sub Instance | Received security definition for symbol CLK26_FUT_CME 2026-04-08 18:12:21.078 | DTC - Sub Instance | Setting external service identifier for symbol CLK26_FUT_CME to 169926 2026-04-08 18:12:21.078 | DTC - Sub Instance | Received security definition for symbol CLK26_FUT_CME 2026-04-08 18:12:21.469 | Socket (2) | Creating socket. 2026-04-08 18:12:21.469 | Socket (2) | New receive buffer size: 0 2026-04-08 18:12:21.469 | Socket (2) | Connecting to IP: 64.152.155.17. 2026-04-08 18:12:21.628 | HD Request # 1 | Setting DTC encoding to Binary VLS 2026-04-08 18:12:21.628 | HD Request # 1 | Sending historical data logon request message. 2026-04-08 18:12:21.744 | HD Request # 1 | Requesting Intraday data. Start date-time: 2026-04-02 13:59:59. Record interval: 0. Symbol: CLK26 2026-04-08 18:12:21.824 | HD Request # 1 | Decompressing data. 2026-04-08 18:12:21.991 | HD Request # 1 | Receiving Intraday data for CLK26_FUT_CME starting at 2026-04-02 13:59:59.033000 2026-04-08 18:12:22.219 | HD Request # 1 | Timestamp of first Intraday data file record written: 2026-04-05 15:00:00.000000. 2026-04-08 18:12:23.868 | Socket (2) | CloseSocket call. 2026-04-08 18:12:23.868 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-04-08 18:12:23.868 | Historical data download thread signaled to stop. 2026-04-08 18:12:23.868 | HD Request # 1 | Received 792894 Intraday data records from 2026-04-02 13:59:59.033000 to 2026-04-08 18:02:21.853000 (6.2 days. Delay: 10.0 minutes) and wrote 792887 records for CLK26_FUT_CME 2026-04-08 18:12:23.869 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2026-04-09 01:02:21.853000 2026-04-08 18:12:23.869 | HD Request # 1 | Completion time: 3s. 2026-04-08 18:12:23.869 | HD Request # 1 | Intraday data download complete for CLK26_FUT_CME. Unique request ID: 1 2026-04-08 18:12:23.869 | Removing historical data download ID 1. 2026-04-08 18:12:23.869 | Real-time Intraday chart data file updates started for CLK26_FUT_CME 2026-04-08 18:12:23.869 | Intraday chart data file opened for CLK26_FUT_CME 2026-04-08 18:12:23.869 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2026-04-08 18:12:23.869 | 2026-04-08 18:12:23.869 | Triggering next historical data download in queue. 2026-04-08 18:12:23.869 | HD Request # 2 | Downloading Historical Daily chart data for CLK26_FUT_CME. Starting date: 2026-03-31. Service: DTCSubInstance 2026-04-08 18:12:23.869 | HD Request # 2 | Using server: 127.0.0.1 port 11098 2026-04-08 18:12:23.870 | Socket (3) | Creating socket. 2026-04-08 18:12:23.870 | Socket (3) | New receive buffer size: 0 2026-04-08 18:12:23.870 | Socket (3) | Connecting to IP: 127.0.0.1. 2026-04-08 18:12:23.891 | HD Request # 2 | Setting DTC encoding to Binary VLS 2026-04-08 18:12:23.891 | HD Request # 2 | Sending historical data logon request message. 2026-04-08 18:12:23.892 | HD Request # 2 | Requesting historical Daily data starting at 2026-03-31. 2026-04-08 18:12:23.893 | HD Request # 2 | Data is being downloaded from a remote source. Download will start when this is done. 2026-04-08 18:12:23.950 | Socket (2) | Socket gracefully closed by remote side. 2026-04-08 18:12:23.950 | Socket (2) | Closed. 2026-04-08 18:12:24.536 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\CLK26_FUT_CME.scid. Thread ID: 5420 2026-04-08 18:12:24.904 | HD Request # 2 | Decompressing data. 2026-04-08 18:12:24.910 | HD Request # 2 | Receiving historical Daily data for CLK26_FUT_CME starting at 2026-03-31. 2026-04-08 18:12:24.910 | HD Request # 2 | Writing historical Daily data to the file CLK26_FUT_CME.dly. 2026-04-08 18:12:24.917 | Socket (3) | CloseSocket call. 2026-04-08 18:12:24.917 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-04-08 18:12:24.917 | Historical data download thread signaled to stop. 2026-04-08 18:12:24.917 | HD Request # 2 | Received 7 Daily data records from 2026-03-31 00:00:00 to 2026-04-09 00:00:00 (10.0 days) and wrote 7 records for CLK26_FUT_CME 2026-04-08 18:12:24.917 | HD Request # 2 | Completion time: 1s. 2026-04-08 18:12:24.917 | HD Request # 2 | Daily data download complete for CLK26_FUT_CME. Unique request ID: 2 2026-04-08 18:12:24.917 | Removing historical data download ID 2. 2026-04-08 18:12:24.917 | 2026-04-08 18:12:24.917 | No download requests in the queue to start downloads for. 2026-04-08 18:12:24.918 | Socket (3) | Socket gracefully closed by remote side. 2026-04-08 18:12:24.918 | Socket (3) | Closed. 2026-04-08 18:12:25.002 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 1 Day #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 18:12:25.002 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 1 Day #2 | Reloading chart. 2026-04-08 18:12:25.277 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 60 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 18:12:25.277 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 60 Min #6 | Reloading chart. 2026-04-08 18:12:25.488 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 18:12:25.488 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] #9 | Reloading chart. 2026-04-08 18:12:25.519 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] Daily #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-04-08 18:12:25.520 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] Daily #4 | Reloading chart. 2026-04-08 18:12:27.678 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-08 18:12:27.887 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] #9 | Chart data loading complete. 2026-04-08 18:12:27.976 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 60 Min #6 | Chart data loading complete. 2026-04-08 18:12:28.024 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 1 Day #2 | Chart data loading complete. 2026-04-08 18:12:28.042 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 1 Day #2 | Reloading chart. 2026-04-08 18:12:28.354 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 60 Min #6 | Reloading chart. 2026-04-08 18:12:28.579 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] #9 | Reloading chart. 2026-04-08 18:12:28.631 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] Daily #4 | Chart data loading complete. 2026-04-08 18:12:28.667 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-04-08 18:12:28.670 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] #9 | Chart data loading complete. 2026-04-08 18:12:29.055 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] Daily #4 | Reloading chart. 2026-04-08 18:12:31.477 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 60 Min #6 | Chart data loading complete. 2026-04-08 18:12:31.528 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] 1 Day #2 | Chart data loading complete. 2026-04-08 18:12:31.778 | CLK26_FUT_CME/MCLK26_FUT_CME [CBV] Daily #4 | Chart data loading complete.https://www.sierrachart.com/image.php?Image=1775697842126.png |
| [2026-04-09 01:51:16] |
| User169323 - Posts: 15 |
I tried changing Allow Support for Sierra Chart Data Feeds to Yes, disconnect, reconnect. It didn't work.
| [2026-04-09 04:32:54] |
I always open the subinstances from the main instance: File>Sub instances...
| [2026-04-09 14:35:17] |
| John - SC Support - Posts: 48273 |
After changing the "Allow Support For Sierra Chart Data Feeds" to "Yes" and reconnecting, you should have been fine. Please restart all of your Sierra Chart instances, including the Main Instance. Then restart and let us know if you continue to have an issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-09 17:48:28] |
I closed and restarted the main instance and all 3 sub instances. Only the main (ES) and sub 4 (NQ) were not delayed. Sub 4 had "Allow Support For Sierra Chart Data Feeds" set to No. So I tried changing sub 2 and sub 3 to No, turning everything off, and restarting, but it didn't work. Sub 3 & 4 are still delayed. It says so in the title line and the Time & Sales are delayed for both by 10 minutes. The Time & Sales for both the main and Sub 4 instances are real-time. I also tried changing Sub 4 to "Allow Support For Sierra Chart Data Feeds" to Yes, turned everything off, opened every instance, and got the same result. ES (main instance) & NQ (Sub 4) are real-time. GC & CL (Sub 2 & Sub 3) are delayed, as shown in the header and by the Time and Sales windows. |
| [2026-04-09 19:11:58] |
Please go through every instance and set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to "Yes". Then exit from all instances, including the main instance. Then start Sierra Chart again. This will ensure that your systems are set correctly. -- But - beyond the above, the reason you are not getting real-time data for GC and CL is that you do not have those exchanges active with our Denali Exchange Data Feed. GC is traded on COMEX and CL is traded on NYMEX, but you only have the CME exchange active. Refer to the following for how to change your exchange selections: Denali Exchange Data Feed: Changing Denali Exchange Data Feed Exchange Selections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
