Date/Time: Mon, 29 Apr 2024 14:31:26 +0000
Data Not Loading
View Count: 581
[2023-02-01 16:35:17] |
User800605 - Posts: 7 |
I am not receiving any data at all when connected to Teton (Dorman Clearing). I switched to SCData and was able to get quotes but Teton is not working, I have gone through the normal troubleshooting process and cannot figure out why I am not receiving data. Thanks. |
[2023-02-01 18:52:35] |
Are you getting data for any symbols? Note that you are only setup to get real-time data for the CME exchange (not the full CME Group). Please let us know one symbol for which you are having an issue and then get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-01 19:25:39] |
I had been set up for the to get real-time data for the full CME Group until about an hour ago when I was on a call with one of your support technicians. I trade NQ/MNQ. The current ticker symbol is NQH23_FUT_CME. Message log is pasted below. Software version: 2479 64-bit | 2023-02-01 14:21:55.781 Primary Thread ID: 14708 | 2023-02-01 14:21:55.781 Usage end date: 2023-02-08 | 2023-02-01 14:21:55.781 Enabled for: Advanced Features 2. | 2023-02-01 14:21:55.781 Enabled for: Sierra Chart Historical Data Service. | 2023-02-01 14:21:55.781 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-02-01 14:21:55.781 Enabled for: Delayed Denali Exchange Data Feed. | 2023-02-01 14:21:55.781 Enabled for exchange2: CME | 2023-02-01 14:21:55.781 Enabled for exchange2: fairx_exchange.data | 2023-02-01 14:21:55.781 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-02-01 14:21:55.781 Current selected Data/Trading service: Teton CME Order Routing | 2023-02-01 14:21:55.781 Custom symbol settings values: enabled | 2023-02-01 14:21:55.781 Chart Update Interval: 250 | 2023-02-01 14:21:55.781 Intraday Data Storage Time Unit: 0 | 2023-02-01 14:21:55.781 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-02-01 14:21:55.781 2023-02-01 19:21:55 Local computer time in UTC | 2023-02-01 14:21:55.781 2023-02-01 14:21:55 Local computer time in SC Time Zone | 2023-02-01 14:21:55.781 2023-02-01 18:33:51 Server time in UTC | 2023-02-01 14:21:55.781 Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-02-01 14:21:55.781 Program path: C:\SierraChart\ | 2023-02-01 14:21:55.781 Data Files path: C:\SierraChart\Data\ | 2023-02-01 14:21:55.781 OS Version Number: 10.0 | 2023-02-01 14:21:55.781 Locale Setting: C | 2023-02-01 14:21:55.781 DLLs: mcV-rejection.dll, OrderFlowLabs.com.beta_64.dll, OrderFlowLabs.com_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2023-02-01 14:21:55.782 Allowed protected custom studies: OrderFlowLabs.com | 2023-02-01 14:21:55.782 Crash reporter started: true | 2023-02-01 14:21:55.782 NQH23_FUT_CME 1 Min #1 | Reloading chart. | 2023-02-01 14:23:10.291 File >> Disconnect selected. | 2023-02-01 14:23:51.674 Teton CME Order Routing | Waiting for socket receive thread to end | 2023-02-01 14:23:51.680 DTC Client socket (1) | CloseSocket call. | 2023-02-01 14:23:51.680 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-02-01 14:23:51.680 DTC Client socket (1) | Max send buffer size during socket life: 236 | 2023-02-01 14:23:51.680 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-01 14:23:51.680 Denali Data Feed | Waiting for socket receive thread to end | 2023-02-01 14:23:51.680 DTC Client socket (2) | CloseSocket call. | 2023-02-01 14:23:51.681 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-01 14:23:51.681 Denali Data Feed | Disconnected from the server. | 2023-02-01 14:23:51.681 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2023-02-01 14:23:51.681 DTC Client socket (5) | CloseSocket call. | 2023-02-01 14:23:51.681 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-01 14:23:51.681 SC DTC Delayed Exchange Data | Disconnected from the server. | 2023-02-01 14:23:51.681 Teton CME Order Routing | Disconnected. | 2023-02-01 14:23:51.681 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-02-01 14:23:51.724 DTC Client socket (1) | Closed. | 2023-02-01 14:23:51.724 DTC Client socket (5) | Socket gracefully closed by remote side. | 2023-02-01 14:23:51.740 DTC Client socket (5) | Closed. | 2023-02-01 14:23:51.740 Teton CME Order Routing | Firm: Dorman | 2023-02-01 14:24:00.157 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-02-01 14:24:00.157 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-02-01 14:24:00.226 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-02-01 14:24:00.226 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2023-02-01 14:24:00.226 Teton CME Order Routing | Network connection to server complete. | 2023-02-01 14:24:00.271 Teton CME Order Routing | Starting socket receive thread. | 2023-02-01 14:24:00.271 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-02-01 14:24:00.271 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-02-01 14:24:00.407 Teton CME Order Routing | Sending logon request message. | 2023-02-01 14:24:00.407 Teton CME Order Routing | Received logon response. | 2023-02-01 14:24:00.916 Teton CME Order Routing | Server Name: SC DTC Server. Build=44641. | 2023-02-01 14:24:00.916 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-02-01 14:24:00.916 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-02-01 14:24:00.916 Teton CME Order Routing | Trading is supported. | 2023-02-01 14:24:00.916 Teton CME Order Routing | Order cancel and replace is supported. | 2023-02-01 14:24:00.916 Teton CME Order Routing | OCO Orders supported. | 2023-02-01 14:24:00.916 Teton CME Order Routing | Bracket Orders supported. | 2023-02-01 14:24:00.916 Teton CME Order Routing | Connected to server complete. | 2023-02-01 14:24:00.916 Triggering next historical data download in queue. | 2023-02-01 14:24:00.917 Triggering next historical data download in queue. | 2023-02-01 14:24:00.917 Triggering next historical data download in queue. | 2023-02-01 14:24:00.917 Triggering next historical data download in queue. | 2023-02-01 14:24:00.917 Updated verified funded futures trading account ending date to: 2023-03-03 19:24:00 | 2023-02-01 14:24:00.917 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-02-01 14:24:00.923 No download requests in the queue to start downloads for. | 2023-02-01 14:24:00.923 No download requests in the queue to start downloads for. | 2023-02-01 14:24:00.923 No download requests in the queue to start downloads for. | 2023-02-01 14:24:00.923 No download requests in the queue to start downloads for. | 2023-02-01 14:24:00.923 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-02-01 14:40:25.938012 | 2023-02-01 14:24:00.931 Using symbol data fast lookup vector | 2023-02-01 14:24:00.931 Teton CME Order Routing | Starting real-time market data updates for: NQH23_FUT_CME. ID: 1 | 2023-02-01 14:24:00.932 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: NQH23_FUT_CME | 2023-02-01 14:24:00.932 Teton CME Order Routing | Requesting security definition data for: NQH23_FUT_CME. ID: 1 | 2023-02-01 14:24:00.932 Mapping MNQH23_FUT_CME to MNQH23. Service code: cme | 2023-02-01 14:24:00.932 Denali Data Feed | Starting real-time market data updates for: MNQH23_FUT_CME (MNQH23). ID: 2 Service code: cme | 2023-02-01 14:24:00.932 Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443 | 2023-02-01 14:24:00.932 Denali Data Feed | Requesting security definition data for: MNQH23_FUT_CME (MNQH23). ID: 2 | 2023-02-01 14:24:00.932 No historical data client is currently set to download historical Intraday data for NQH23_FUT_CME. | 2023-02-01 14:24:00.932 Real-time Intraday chart data file updates started for NQH23_FUT_CME | 2023-02-01 14:24:00.932 Intraday chart data file opened for NQH23_FUT_CME | 2023-02-01 14:24:00.932 DTC Client socket (3) | Creating socket. | 2023-02-01 14:24:00.932 DTC Client socket (3) | New receive buffer size: 5242880 | 2023-02-01 14:24:00.932 DTC Client socket (3) | Connecting to IP: 142.215.17.188. | 2023-02-01 14:24:00.932 Updated verified funded futures trading account ending date to: 2023-03-03 19:24:00 | 2023-02-01 14:24:00.967 Denali Data Feed | Network connection to server complete. | 2023-02-01 14:24:00.975 Denali Data Feed | Starting socket receive thread. | 2023-02-01 14:24:00.975 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-01 14:24:00.975 Teton CME Order Routing | Received security definition for symbol NQH23_FUT_CME | 2023-02-01 14:24:00.976 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=E3775 | 2023-02-01 14:24:00.977 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQH23_FUT_CME | 2023-02-01 14:24:01.019 Teton CME Order Routing | Received security definition for symbol MNQH23_FUT_CME | 2023-02-01 14:24:01.019 Mapping VXH23-CFE to VXH23_FUT_CFE. Service code: cfe_exchange.data | 2023-02-01 14:24:01.025 SC DTC Delayed Exchange Data | Starting real-time market data updates for: VXH23-CFE (VXH23_FUT_CFE). ID: 3 Service code: cfe_exchange.data | 2023-02-01 14:24:01.025 SC DTC Delayed Exchange Data | Connecting to the server ds25.sierracharts.com. Port 10043 | 2023-02-01 14:24:01.025 SC DTC Delayed Exchange Data | Requesting security definition data for: VXH23-CFE (VXH23_FUT_CFE). ID: 3 | 2023-02-01 14:24:01.025 Added historical Intraday data request for VXH23-CFE to the queue. | 2023-02-01 14:24:01.025 Intraday data recording state for symbol VXH23-CFE is set to download 'Pending'. | 2023-02-01 14:24:01.025 Triggering next historical data download in queue. | 2023-02-01 14:24:01.025 Delaying start of download for VXH23-CFE. | 2023-02-01 14:24:01.026 DTC Client socket (4) | Creating socket. | 2023-02-01 14:24:01.026 DTC Client socket (4) | New receive buffer size: 5242880 | 2023-02-01 14:24:01.026 DTC Client socket (4) | Connecting to IP: 38.65.8.115. | 2023-02-01 14:24:01.026 Added historical Intraday data request for MNQH23_FUT_CME to the queue. | 2023-02-01 14:24:01.032 Intraday data recording state for symbol MNQH23_FUT_CME is set to download 'Pending'. | 2023-02-01 14:24:01.032 Triggering next historical data download in queue. | 2023-02-01 14:24:01.032 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-02-01 14:24:01.042 Denali Data Feed | Sending logon request message. | 2023-02-01 14:24:01.042 SC DTC Delayed Exchange Data | Network connection to server complete. | 2023-02-01 14:24:01.093 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2023-02-01 14:24:01.093 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2023-02-01 14:24:01.093 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2023-02-01 14:24:01.175 SC DTC Delayed Exchange Data | Sending logon request message. | 2023-02-01 14:24:01.175 SC DTC Delayed Exchange Data | Received logon response. | 2023-02-01 14:24:01.769 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2023-02-01 14:24:01.769 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2023-02-01 14:24:01.769 SC DTC Delayed Exchange Data | Successfully connected. | 2023-02-01 14:24:01.769 SC DTC Delayed Exchange Data | Trading is not supported. | 2023-02-01 14:24:01.769 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: VXH23-CFE -> VXH23_FUT_CFE | 2023-02-01 14:24:01.769 Denali Data Feed | Received logon response. | 2023-02-01 14:24:01.822 Denali Data Feed | Server Name: SC Realtime Server. | 2023-02-01 14:24:01.822 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-02-01 14:24:01.822 Denali Data Feed | Successfully connected. | 2023-02-01 14:24:01.822 Denali Data Feed | Trading is not supported. | 2023-02-01 14:24:01.822 Denali Data Feed | Restarting real-time data updates for symbol: MNQH23_FUT_CME -> MNQH23 | 2023-02-01 14:24:01.822 SC DTC Delayed Exchange Data | Received security definition for symbol VXH23-CFE | 2023-02-01 14:24:01.926 Denali Data Feed | Received security definition for symbol MNQH23_FUT_CME | 2023-02-01 14:24:01.948 Requesting market depth updates for: NQH23_FUT_CME if supported. | 2023-02-01 14:24:05.912 Separate subscription for market depth updates not supported. NQH23_FUT_CME | 2023-02-01 14:24:05.912 HD Request # 6 | Downloading Intraday chart data for VXH23-CFE to the file VXH23-CFE.scid. Service: cfe_exchange.data | 2023-02-01 14:24:06.191 HD Request # 6 | Download start date-time: 2023-02-01 14:13:45.000000. File last date-time: 2023-02-01 14:13:45.727000 | 2023-02-01 14:24:06.191 HD Request # 6 | Using server: ds25.sierracharts.com port 10150 | 2023-02-01 14:24:06.191 Socket (5) | Creating socket. | 2023-02-01 14:24:06.192 Socket (5) | New receive buffer size: 5242880 | 2023-02-01 14:24:06.192 Socket (5) | Connecting to IP: 38.65.8.115. | 2023-02-01 14:24:06.192 HD Request # 6 | Setting DTC encoding to Binary VLS | 2023-02-01 14:24:06.321 HD Request # 6 | Sending historical data logon request message. | 2023-02-01 14:24:06.321 HD Request # 6 | Requesting Intraday data. Start date-time: 2023-02-01 14:13:45. Record interval: 0. Symbol: VXH23_FUT_CFE | 2023-02-01 14:24:06.793 HD Request # 6 | Decompressing data. | 2023-02-01 14:24:06.853 HD Request # 6 | Receiving Intraday data for VXH23-CFE starting at 2023-02-01 14:13:45.727000 | 2023-02-01 14:24:06.853 Socket (5) | CloseSocket call. | 2023-02-01 14:24:06.853 Socket (5) | Shutdown started. Waiting for graceful close. | 2023-02-01 14:24:06.853 Historical data download thread signaled to stop. | 2023-02-01 14:24:06.853 HD Request # 6 | Timestamp of first Intraday data file record written: 2023-02-01 14:13:50.865000. | 2023-02-01 14:24:06.853 HD Request # 6 | Received 5 Intraday data records from 2023-02-01 14:13:45.727000 to 2023-02-01 14:14:01.984001 (16.3 seconds) and wrote 4 records for VXH23-CFE | 2023-02-01 14:24:06.853 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2023-02-01 19:14:01.984001 | 2023-02-01 14:24:06.857 HD Request # 6 | Completion time: 0s. | 2023-02-01 14:24:06.857 HD Request # 6 | Intraday data download complete for VXH23-CFE. Unique request ID: 6 | 2023-02-01 14:24:06.857 Removing historical data download ID 6. | 2023-02-01 14:24:06.857 Real-time Intraday chart data file updates started for VXH23-CFE | 2023-02-01 14:24:06.857 Intraday chart data file opened for VXH23-CFE | 2023-02-01 14:24:06.857 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2023-02-01 14:24:06.857 Triggering next historical data download in queue. | 2023-02-01 14:24:06.857 HD Request # 7 | Downloading Intraday chart data for MNQH23_FUT_CME to the file MNQH23_FUT_CME.scid. Service: cme | 2023-02-01 14:24:06.857 HD Request # 7 | Download start date-time: 2023-02-01 14:23:50.000000. File last date-time: 2023-02-01 14:23:50.531000 | 2023-02-01 14:24:06.857 HD Request # 7 | Using server: ds26.sierracharts.com port 10149 | 2023-02-01 14:24:06.857 Socket (6) | Creating socket. | 2023-02-01 14:24:06.857 Socket (6) | New receive buffer size: 5242880 | 2023-02-01 14:24:06.858 Socket (6) | Connecting to IP: 142.215.17.188. | 2023-02-01 14:24:06.858 Socket (5) | Socket gracefully closed by remote side. | 2023-02-01 14:24:06.912 Socket (5) | Closed. | 2023-02-01 14:24:06.912 HD Request # 7 | Setting DTC encoding to Binary VLS | 2023-02-01 14:24:06.946 HD Request # 7 | Sending historical data logon request message. | 2023-02-01 14:24:06.946 HD Request # 7 | Requesting Intraday data. Start date-time: 2023-02-01 14:23:50. Record interval: 0. Symbol: MNQH23 | 2023-02-01 14:24:07.504 HD Request # 7 | Decompressing data. | 2023-02-01 14:24:07.547 HD Request # 7 | Receiving Intraday data for MNQH23_FUT_CME starting at 2023-02-01 14:23:50.093000 | 2023-02-01 14:24:07.548 Socket (6) | CloseSocket call. | 2023-02-01 14:24:07.548 Historical data download thread signaled to stop. | 2023-02-01 14:24:07.548 Socket (6) | Shutdown started. Waiting for graceful close. | 2023-02-01 14:24:07.548 HD Request # 7 | Timestamp of first Intraday data file record written: 2023-02-01 14:23:50.918000. | 2023-02-01 14:24:07.548 HD Request # 7 | Received 425 Intraday data records from 2023-02-01 14:23:50.093000 to 2023-02-01 14:24:03.473000 (13.4 seconds) and wrote 419 records for MNQH23_FUT_CME | 2023-02-01 14:24:07.548 HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2023-02-01 19:24:03.473000 | 2023-02-01 14:24:07.552 Added 138 Time and Sales records to Intraday data file for MNQH23_FUT_CME after download. | 2023-02-01 14:24:07.552 HD Request # 7 | Completion time: 1s. | 2023-02-01 14:24:07.552 HD Request # 7 | Intraday data download complete for MNQH23_FUT_CME. Unique request ID: 7 | 2023-02-01 14:24:07.552 Removing historical data download ID 7. | 2023-02-01 14:24:07.552 Real-time Intraday chart data file updates started for MNQH23_FUT_CME | 2023-02-01 14:24:07.552 Intraday chart data file opened for MNQH23_FUT_CME | 2023-02-01 14:24:07.552 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2023-02-01 14:24:07.552 Triggering next historical data download in queue. | 2023-02-01 14:24:07.552 No download requests in the queue to start downloads for. | 2023-02-01 14:24:07.552 Socket (6) | Socket gracefully closed by remote side. | 2023-02-01 14:24:07.590 Socket (6) | Closed. | 2023-02-01 14:24:07.590 Chart #8 has tagged chart #22 for full recalculation. Chartbook: JWZ DeltaMap.Cht | 2023-02-01 14:24:07.775 NQH23_FUT_CME/MNQH23_FUT_CME [CBV-D][M] 750 Volume #22 | Performing a full recalculation because it has been tagged. Chartbook: JWZ DeltaMap.Cht | 2023-02-01 14:24:07.787 Opened cached Intraday file: C:\SierraChart\Data\MNQH23_FUT_CME.scid. Thread ID: 6756 | 2023-02-01 14:24:11.457 Opened cached Intraday file: C:\SierraChart\Data\VXH23-CFE.scid. Thread ID: 9220 | 2023-02-01 14:24:32.202 |
[2023-02-01 23:00:47] |
We are not seeing anything that shows an issue related to NQ or MNQ. We do see you have a chart for VX, which will only be the delayed streaming data. What exactly are you seeing, or not seeing? Have you checked your Session Times to ensure that they cover the full period and you are not seeing new data due to how these are set? For other things to look at, refer to the following: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-01 23:29:12] |
The issue is that the charts in my chartbook, all of which are NQ or MNQ charts except for one VIX chart, are not loading any data. The DOM is frozen. There is nothing transacting on time and sales. The bar charts haven't moved since yesterday evening. I haven't changed session times, and everything was working fine until yesterday after RTH. I changed nothing...they just stopped working. All service packages for live data are paid up and active. Going through the troubleshooting in the link you provided: 1) the symbols are valid; 2) session times are unchanged for many months...the session start time is 17:00:00 and end time is 16:59:59, with evening session start time of 17:00 and evening session end time of 08:30:00; 3) I have checked and rechecked to ensure that my service package includes real-time data and that I am connected to the data feed; 4) I am scrolled to the end of the chart. Please advise on next steps now that I have troubleshot those indicated in your link.
[2023-02-01 23:32:59] |
We really do not understand why there would be an issue, but please exit from Sierra Chart and start it again. Let us know if you then get the updated data or if you are still having a problem.
[2023-02-01 23:40:42] |
Thanks, John. I exited SC and restarted. Also ensured that I was running most recent version. No change. Data is still stuck at globex start yesterday. Is it possible that there is a large data download going on in the background that is getting in front my real-time data? Is there a way to check? I'm grasping for answers because I don't want to lose another day to this.
[2023-02-02 00:28:27] |
Sierra_Chart Engineering - Posts: 14137 |
We want you to disable the use of custom symbol settings values: Global Symbol Settings: Disabling Custom Symbol Settings And be sure to follow the step to reconnect to the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-02 01:24:30] |
And for the record this is the message, which indicates the problem: Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: NQH23_FUT_CME | 2023-02-01 14:24:00.932 And the lack of restarting updates for NQ: Denali Data Feed | Restarting real-time data updates for symbol: MNQH23_FUT_CME -> MNQH23 | 2023-02-01 14:24:01.822 The cause of this must be that the symbol settings on your installation of Sierra Chart were changed that affects market data routing for the symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-02 01:25:28
[2023-02-02 15:29:03] |
That fixed the problem. No idea how it happened in the first place, but it's fixed now. Thank you.
[2023-04-07 17:31:39] |
User129986 - Posts: 3 |
I have the same problem, only symbol that work is MESM23 the others does not. I tried to do all the procedure to delete the Custom Symbols but I didn't solve the situation. Can someone help me? This is the log text: Reading Internal Order ID file. | 2023-04-07 17:21:18.977 Reading Trade Orders file. | 2023-04-07 17:21:19.066 Reading Trade Positions file. | 2023-04-07 17:21:19.066 Reading Trade Account Data files. | 2023-04-07 17:21:19.067 Software version: 2488 64-bit | 2023-04-07 17:21:19.068 Primary Thread ID: 13568 | 2023-04-07 17:21:19.068 Usage end date: 2023-04-19 | 2023-04-07 17:21:19.068 Enabled for: Advanced Features 2. | 2023-04-07 17:21:19.068 Enabled for: Sierra Chart Historical Data Service. | 2023-04-07 17:21:19.068 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-04-07 17:21:19.068 Enabled for: Delayed Denali Exchange Data Feed. | 2023-04-07 17:21:19.068 Enabled for exchange2: fairx_exchange.data | 2023-04-07 17:21:19.068 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-04-07 17:21:19.068 Current selected Data/Trading service: SC Data - All Services | 2023-04-07 17:21:19.069 Custom symbol settings values: disabled | 2023-04-07 17:21:19.069 Chart Update Interval: 500 | 2023-04-07 17:21:19.069 Intraday Data Storage Time Unit: 0 | 2023-04-07 17:21:19.069 Time Zone: +00:00:00 (UTC+00) | 2023-04-07 17:21:19.069 2023-04-07 17:21:19 Local computer time in UTC | 2023-04-07 17:21:19.069 2023-04-07 17:21:19 Local computer time in SC Time Zone | 2023-04-07 17:21:19.069 2023-04-07 17:21:16 Server time in UTC | 2023-04-07 17:21:19.069 Local computer UTC time and Server UTC time difference: 2 seconds. | 2023-04-07 17:21:19.069 Program path: C:\SierraChart\ | 2023-04-07 17:21:19.069 Data Files path: C:\SierraChart\Data\ | 2023-04-07 17:21:19.069 OS Version Number: 10.0 | 2023-04-07 17:21:19.069 Locale Setting: C | 2023-04-07 17:21:19.069 DLLs: UserContributedStudies_64.dll | 2023-04-07 17:21:19.069 Allowed protected custom studies: | 2023-04-07 17:21:19.069 Crash reporter started: true | 2023-04-07 17:21:19.069 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2023-04-07 17:21:19.070 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-04-07 17:21:19.137 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-04-07 17:21:19.191 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-04-07 17:21:19.191 Received 5 login tokens. | 2023-04-07 17:21:19.257 Symbol settings MD5 received. Request ID: 1. | 2023-04-07 17:21:20.746 Symbol settings are up-to-date for scdataallservices. | 2023-04-07 17:21:20.746 SC Data - All Services | Connected to server complete. | 2023-04-07 17:21:25.378 Triggering next historical data download in queue. | 2023-04-07 17:21:25.378 Triggering next historical data download in queue. | 2023-04-07 17:21:25.378 Triggering next historical data download in queue. | 2023-04-07 17:21:25.378 Triggering next historical data download in queue. | 2023-04-07 17:21:25.378 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2023-04-07 17:21:25.378 No download requests in the queue to start downloads for. | 2023-04-07 17:21:25.379 No download requests in the queue to start downloads for. | 2023-04-07 17:21:25.379 No download requests in the queue to start downloads for. | 2023-04-07 17:21:25.379 No download requests in the queue to start downloads for. | 2023-04-07 17:21:25.380 Searching for files containing WriteMBO returned empty result. | 2023-04-07 17:21:41.501 * Error loading: C:\SierraChart\Data\WriteMBO.dll. File not found or may be missing SCDLLName line. | 2023-04-07 17:21:41.501 ESm23-CME/mESM23-CME 4000 Trades #1 | Reloading chart. | 2023-04-07 17:21:41.513 ESM23-CME/mESM23-CME #4 | Reloading chart. | 2023-04-07 17:21:41.523 ESM23-CME 5 Min #2 | Reloading chart. | 2023-04-07 17:21:41.551 ESM23-CME [CBV] #5 | Reloading chart. | 2023-04-07 17:21:41.564 ESM23-CME [CBV] #5 | Performing continuous chart historical Daily data download for symbol ESM23-CME starting at last date in file. | 2023-04-07 17:21:41.569 Unable to determine transition date based on volume from files: ESH23-CME.dly, ESM23-CME.dly | 2023-04-07 17:21:41.571 The ESM23-CME.dly symbol may not be the active contract month. | 2023-04-07 17:21:41.571 ESM23-CME [CBV] #5 | Error while getting daily settlement price with date 2023-03-20 from file. C:\SierraChart\Data\ESH23-CME.dly. Error: No Data for read. End of file. | 2023-04-07 17:21:41.575 ESM23-CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\ESM23-CME.dly. Error: No Data for read. End of file. | 2023-04-07 17:21:41.575 ESM23-CME/MESM23-CME 5.00 Range #3 | Reloading chart. | 2023-04-07 17:21:41.596 ESM23-CME/MESM23-CME 2.00 Range #7 | Reloading chart. | 2023-04-07 17:21:41.612 Loading market depth data. | 2023-04-07 17:21:41.617 ESM23-CME/MESM23-CME [CBV] 30 Min #10 | Reloading chart. | 2023-04-07 17:21:41.625 Unable to determine transition date based on volume from files: ESH23-CME.dly, ESM23-CME.dly | 2023-04-07 17:21:41.629 The ESM23-CME.dly symbol may not be the active contract month. | 2023-04-07 17:21:41.629 ESM23-CME/MESM23-CME [CBV] 30 Min #10 | Error while getting daily settlement price with date 2023-03-20 from file. C:\SierraChart\Data\ESH23-CME.dly. Error: No Data for read. End of file. | 2023-04-07 17:21:41.632 ESM23-CME/MESM23-CME [CBV] 30 Min #10 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\ESM23-CME.dly. Error: No Data for read. End of file. | 2023-04-07 17:21:41.632 ESM23-CME/MESM23-CME [CBV] Renko 4t #6 | Reloading chart. | 2023-04-07 17:21:41.644 Unable to determine transition date based on volume from files: ESH23-CME.dly, ESM23-CME.dly | 2023-04-07 17:21:41.647 The ESM23-CME.dly symbol may not be the active contract month. | 2023-04-07 17:21:41.647 ESM23-CME/MESM23-CME [CBV] Renko 4t #6 | Error while getting daily settlement price with date 2023-03-20 from file. C:\SierraChart\Data\ESH23-CME.dly. Error: No Data for read. End of file. | 2023-04-07 17:21:41.650 ESM23-CME/MESM23-CME [CBV] Renko 4t #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\ESM23-CME.dly. Error: No Data for read. End of file. | 2023-04-07 17:21:41.650 ESm23-CME/mESM23-CME 4000 Trades #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESm23-CME.scid | 2023-04-07 17:21:41.665 ESM23-CME/mESM23-CME #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-04-07 17:21:41.690 ESM23-CME 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM23-CME.scid | 2023-04-07 17:21:41.696 ESM23-CME [CBV] #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM23-CME.scid | 2023-04-07 17:21:41.699 ESM23-CME/MESM23-CME 5.00 Range #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM23-CME.scid | 2023-04-07 17:21:41.701 ESM23-CME/MESM23-CME 2.00 Range #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM23-CME.scid | 2023-04-07 17:21:41.704 ESM23-CME/MESM23-CME [CBV] 30 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM23-CME.scid | 2023-04-07 17:21:41.707 ESM23-CME/MESM23-CME [CBV] Renko 4t #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM23-CME.scid | 2023-04-07 17:21:41.709 Mapping mESM23-CME to MESM23. Service code: cme | 2023-04-07 17:21:41.738 Using symbol data fast lookup vector | 2023-04-07 17:21:41.738 SC DTC Delayed Exchange Data | Starting real-time market data updates for: mESM23-CME (MESM23). ID: 1 Service code: cme | 2023-04-07 17:21:41.738 SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-04-07 17:21:41.738 SC DTC Delayed Exchange Data | Requesting security definition data for: mESM23-CME (MESM23). ID: 1 | 2023-04-07 17:21:41.740 DTC Client socket (1) | Creating socket. | 2023-04-07 17:21:41.756 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-04-07 17:21:41.756 DTC Client socket (1) | Connecting to IP: 142.215.18.147. | 2023-04-07 17:21:41.756 SC DTC Delayed Exchange Data | Network connection to server complete. | 2023-04-07 17:21:41.873 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2023-04-07 17:21:41.873 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2023-04-07 17:21:41.873 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2023-04-07 17:21:42.024 SC DTC Delayed Exchange Data | Sending logon request message. | 2023-04-07 17:21:42.024 Requesting market depth updates for: mESM23-CME if supported. | 2023-04-07 17:21:42.117 Separate subscription for market depth updates not supported. mESM23-CME | 2023-04-07 17:21:42.117 SC DTC Delayed Exchange Data | Received logon response. | 2023-04-07 17:21:42.774 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2023-04-07 17:21:42.774 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2023-04-07 17:21:42.774 SC DTC Delayed Exchange Data | Successfully connected. | 2023-04-07 17:21:42.774 SC DTC Delayed Exchange Data | Trading is not supported. | 2023-04-07 17:21:42.774 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: mESM23-CME -> MESM23. Market Depth data restarted. | 2023-04-07 17:21:42.774 SC DTC Delayed Exchange Data | Clearing market depth for mESM23-CME | 2023-04-07 17:21:42.995 SC DTC Delayed Exchange Data | Received security definition for symbol mESM23-CME | 2023-04-07 17:21:42.995 Screen image: https://drive.google.com/file/d/1mcoGtA8ePV2rb18NUkBNzSfDgbe8qvHQ/view?usp=sharing |
[2023-04-07 18:59:34] |
What symbol are you having an issue with? Also be aware that the markets are closed at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-07 18:59:41
[2023-04-07 19:17:04] |
I know markets are closed, but the issue were at the first installation. All CME except Micro E-Mini ES500 (MESM23-CME), the only symbol I can download the data feed.
[2023-04-07 21:21:12] |
That is because your account was on the standard trial. Refer to the information here: Sierra Chart Trial Account and Account Activation: Introduction We have activated your trial now, so you will now have access to all the available symbols. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-07 22:37:51] |
Thank you, I missed this part!
[2023-04-09 22:47:24] |
kimyeoman - Posts: 2 |
I've been struggling with this same problem for a couple weeks now. I was finally able to get connected to my Interactive Brokers account, and historical data to load, but tonight's session is not showing up at all. Zero access to real time data, and absolutely at a loss for how to obtain it.
[2023-04-10 04:36:01] |
What symbol are you referring to?
[2023-04-10 12:05:22] |
The /es and /nq. I tried restarting SC, and rebooting my pc after a windows update. No change. Then SC crashed, and upon restarting, suddenly started working. So I have no idea what the problem was, or how it fixed itself, but appears to be working perfectly this morning. |
[2023-04-10 12:15:30] |
Ok if you have any performance issues or abnormal shutdowns then refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-10 12:15:44
[2023-04-13 11:53:28] |
User826280 - Posts: 4 |
Dear support , i experience an issue similar to user 800605 to download historical data. I tried to apply the recommended procedure described above but it did not work. i'm using Rithmic service DTC with server beeing APEX chicago area non aggregated and suscribed to Denali market Data feed in combination with Rithmic (Denali package CME E-mini, for users without a trading account at 69$) in the menu common setting, the box "allow support for sierra chart data feed is set to "YES" In the menu main settings, the market data as well as the historical data username and paswords were left blank (to use denali market data) In the menu global settings / symbol settings, the box "use custom symbol settings value" is un-validated. i'm currently trading the symbol ESM3-CME- Real time market data is working fine, only historical data does not download. here is the message log i received HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2023-04-13 07:20:07.279 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2023-04-13 07:20:07.279 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2023-04-13 07:20:07.279 Reading Internal Order ID file. | 2023-04-13 07:20:07.327 Reading Trade Orders file. | 2023-04-13 07:20:07.387 Reading Trade Positions file. | 2023-04-13 07:20:07.387 Reading Trade Account Data files. | 2023-04-13 07:20:07.387 Software version: 2491 64-bit | 2023-04-13 07:20:07.388 Primary Thread ID: 7880 | 2023-04-13 07:20:07.388 Usage end date: 2023-04-28 | 2023-04-13 07:20:07.388 Enabled for: Advanced Features 2. | 2023-04-13 07:20:07.388 Enabled for: Sierra Chart Historical Data Service. | 2023-04-13 07:20:07.388 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-04-13 07:20:07.388 Enabled for: Delayed Denali Exchange Data Feed. | 2023-04-13 07:20:07.388 Enabled for exchange2: CME | 2023-04-13 07:20:07.388 Enabled for exchange2: fairx_exchange.data | 2023-04-13 07:20:07.388 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-04-13 07:20:07.388 Current selected Data/Trading service: Rithmic Direct - DTC | 2023-04-13 07:20:07.388 Custom symbol settings values: enabled | 2023-04-13 07:20:07.388 Chart Update Interval: 500 | 2023-04-13 07:20:07.388 Intraday Data Storage Time Unit: 0 | 2023-04-13 07:20:07.388 Time Zone: +00:00:00 (UTC+00) | 2023-04-13 07:20:07.388 2023-04-13 07:20:07 Local computer time in UTC | 2023-04-13 07:20:07.388 2023-04-13 07:20:07 Local computer time in SC Time Zone | 2023-04-13 07:20:07.388 2023-04-13 07:20:04 Server time in UTC | 2023-04-13 07:20:07.388 Local computer UTC time and Server UTC time difference: 3 seconds. | 2023-04-13 07:20:07.388 Program path: C:\SierraChart\ | 2023-04-13 07:20:07.388 Data Files path: C:\SierraChart\Data\ | 2023-04-13 07:20:07.388 OS Version Number: 10.0 | 2023-04-13 07:20:07.389 Locale Setting: C | 2023-04-13 07:20:07.389 DLLs: UserContributedStudies_64.dll | 2023-04-13 07:20:07.389 Allowed protected custom studies: | 2023-04-13 07:20:07.389 Crash reporter started: true | 2023-04-13 07:20:07.389 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2023-04-13 07:20:07.401 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-04-13 07:20:07.437 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-04-13 07:20:07.868 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-04-13 07:20:07.868 Received 5 login tokens. | 2023-04-13 07:20:08.090 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2023-04-13 07:20:08.741 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2023-04-13 07:20:08.742 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-04-13 07:20:08.742 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2023-04-13 07:20:08.742 Symbol settings MD5 received. Request ID: 1. | 2023-04-13 07:20:09.493 Symbol settings are up-to-date for rithmic_v2.trading. | 2023-04-13 07:20:09.493 Files to Open on Startup | Opening file: NICO_Footprint.Cht | 2023-04-13 07:20:11.918 ESM3.CME #5 | Reloading chart. | 2023-04-13 07:20:12.044 ESM3.CME #4 | Reloading chart. | 2023-04-13 07:20:12.053 ESM3.CME 5 Min #1 | Reloading chart. | 2023-04-13 07:20:12.176 ESM3.CME 1 Min #3 | Reloading chart. | 2023-04-13 07:20:12.300 ESM3.CME 5 Min #2 | Reloading chart. | 2023-04-13 07:20:12.309 ESM3.CME 5 Min #9 | Reloading chart. | 2023-04-13 07:20:12.317 ESM3.CME 15 Min #6 | Reloading chart. | 2023-04-13 07:20:12.326 ESM3.CME 60 Min #7 | Reloading chart. | 2023-04-13 07:20:12.335 ESM3.CME 240 Min #8 | Reloading chart. | 2023-04-13 07:20:12.370 ESM3.CME #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-04-13 07:20:12.388 Loading market depth data. | 2023-04-13 07:20:12.440 Loaded depth data records for ESM3.CME 2023-04-11 from 2023-04-11 20:11:16.000000 to 2023-04-11 20:22:48.309311. | 2023-04-13 07:20:12.444 ESM3.CME 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-04-13 07:20:12.451 ESM3.CME 15 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-04-13 07:20:12.544 Loaded depth data records for ESM3.CME 2023-04-12 from 2023-04-12 20:26:05.629000 to 2023-04-12 23:21:37.864850. | 2023-04-13 07:20:12.547 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\ESM3.CME.2023-04-13.depth. This may take a while. | 2023-04-13 07:20:12.548 File compression enabled. C:\SierraChart\Data\MarketDepthData\ESM3.CME.2023-04-13.depth. CompressionState=2 | 2023-04-13 07:20:12.548 Loaded depth data records for ESM3.CME 2023-04-13 from 2023-04-13 09:18:46.868000 to 2023-04-13 09:19:40.685000. | 2023-04-13 07:20:12.550 ESM3.CME 5 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-04-13 07:20:12.571 ESM3.CME 60 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-04-13 07:20:12.582 ESM3.CME 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-04-13 07:20:12.610 ESM3.CME 240 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-04-13 07:20:12.655 ESM3.CME 1 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-04-13 07:20:12.677 Mapping ESM3.CME to ESM23. Service code: cme | 2023-04-13 07:20:12.757 Using symbol data fast lookup vector | 2023-04-13 07:20:12.757 Starting DelayedDownloadMonitoringTimer | 2023-04-13 07:20:12.757 Starting HDTimeoutTimer | 2023-04-13 07:20:12.757 Added historical Intraday data request for ESM3.CME to the queue. | 2023-04-13 07:20:12.757 Intraday data recording state for symbol ESM3.CME is set to download 'Pending'. | 2023-04-13 07:20:12.757 Triggering next historical data download in queue. | 2023-04-13 07:20:12.757 HD Request # 1 | Downloading Intraday chart data for ESM3.CME to the file ESM3.CME.scid. Service: cme | 2023-04-13 07:20:12.762 HD Request # 1 | Download start date-time: 2023-04-13 07:19:40.000000. File last date-time: 2023-04-13 07:19:40.685001 | 2023-04-13 07:20:12.763 HD Request # 1 | Using server: ds26.sierracharts.com port 10150 | 2023-04-13 07:20:12.763 Socket (1) | Creating socket. | 2023-04-13 07:20:12.767 Socket (1) | New receive buffer size: 5242880 | 2023-04-13 07:20:12.767 Socket (1) | Connecting to IP: 142.215.17.188. | 2023-04-13 07:20:12.767 HD Request # 1 | Setting DTC encoding to Binary VLS | 2023-04-13 07:20:13.085 HD Request # 1 | Sending historical data logon request message. | 2023-04-13 07:20:13.085 HD Request # 1 | Requesting Intraday data. Start date-time: 2023-04-13 07:19:40. Record interval: 0. Symbol: ESM23 | 2023-04-13 07:20:13.741 HD Request # 1 | Decompressing data. | 2023-04-13 07:20:13.891 HD Request # 1 | Receiving Intraday data for ESM3.CME starting at 2023-04-13 07:19:40.685000 | 2023-04-13 07:20:13.892 Socket (1) | CloseSocket call. | 2023-04-13 07:20:13.892 Socket (1) | Shutdown started. Waiting for graceful close. | 2023-04-13 07:20:13.892 Historical data download thread signaled to stop. | 2023-04-13 07:20:13.892 HD Request # 1 | Timestamp of first Intraday data file record written: 2023-04-13 07:19:46.397000. | 2023-04-13 07:20:13.893 HD Request # 1 | Received 129 Intraday data records from 2023-04-13 07:19:40.685000 to 2023-04-13 07:20:07.032005 (26.3 seconds. Delay: 6.9 seconds) and wrote 127 records for ESM3.CME | 2023-04-13 07:20:13.893 HD Request # 1 | Completion time: 1s. | 2023-04-13 07:20:13.893 HD Request # 1 | Intraday data download complete for ESM3.CME. Unique request ID: 1 | 2023-04-13 07:20:13.893 Removing historical data download ID 1. | 2023-04-13 07:20:13.893 Real-time Intraday chart data file updates started for ESM3.CME | 2023-04-13 07:20:13.893 Intraday chart data file opened for ESM3.CME | 2023-04-13 07:20:13.893 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2023-04-13 07:20:13.893 Triggering next historical data download in queue. | 2023-04-13 07:20:13.893 Historical data for ESM3.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-04-13 07:20:13.893 No download requests in the queue to start downloads for. | 2023-04-13 07:20:13.893 Socket (1) | Socket gracefully closed by remote side. | 2023-04-13 07:20:14.034 Socket (1) | Closed. | 2023-04-13 07:20:14.034 Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-04-13 07:20:14.376 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-04-13 07:20:14.377 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-04-13 07:20:14.377 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-04-13 07:20:14.378 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-04-13 07:20:14.378 Rithmic Direct - DTC | Network connection to server complete. | 2023-04-13 07:20:14.519 Rithmic Direct - DTC | Starting socket receive thread. | 2023-04-13 07:20:14.519 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-04-13 07:20:14.519 Rithmic Direct - DTC | Sending logon request message. | 2023-04-13 07:20:14.519 Rithmic Direct - DTC | Received logon response. | 2023-04-13 07:20:14.960 Rithmic Direct - DTC | Server Name: . | 2023-04-13 07:20:14.960 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-04-13 07:20:14.960 Rithmic Direct - DTC | Successfully connected. | 2023-04-13 07:20:14.960 Rithmic Direct - DTC | Trading is supported. | 2023-04-13 07:20:14.960 Rithmic Direct - DTC | Order cancel and replace is supported. | 2023-04-13 07:20:14.960 Rithmic Direct - DTC | OCO Orders supported. | 2023-04-13 07:20:14.960 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-04-13 07:20:14.960 Rithmic Direct - DTC | Connected to server complete. | 2023-04-13 07:20:14.960 Triggering next historical data download in queue. | 2023-04-13 07:20:14.961 Triggering next historical data download in queue. | 2023-04-13 07:20:14.961 Triggering next historical data download in queue. | 2023-04-13 07:20:14.961 Triggering next historical data download in queue. | 2023-04-13 07:20:14.961 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2023-04-13 07:20:14.961 No download requests in the queue to start downloads for. | 2023-04-13 07:20:14.965 No download requests in the queue to start downloads for. | 2023-04-13 07:20:14.965 No download requests in the queue to start downloads for. | 2023-04-13 07:20:14.965 No download requests in the queue to start downloads for. | 2023-04-13 07:20:14.965 Mapping ESM3.CME to ESM23. Service code: cme | 2023-04-13 07:20:15.033 Using symbol data fast lookup vector | 2023-04-13 07:20:15.033 Denali Data Feed | Starting real-time market data updates for: ESM3.CME (ESM23). ID: 1 Service code: cme | 2023-04-13 07:20:15.034 Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-04-13 07:20:15.034 DTC Client socket (2) | Creating socket. | 2023-04-13 07:20:15.034 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-04-13 07:20:15.034 DTC Client socket (2) | Connecting to IP: 142.215.18.147. | 2023-04-13 07:20:15.034 Denali Data Feed | Requesting security definition data for: ESM3.CME (ESM23). ID: 1 | 2023-04-13 07:20:15.035 Added historical Intraday data request for ESM3.CME to the queue. | 2023-04-13 07:20:15.036 Intraday data recording state for symbol ESM3.CME is set to download 'Pending'. | 2023-04-13 07:20:15.036 Triggering next historical data download in queue. | 2023-04-13 07:20:15.036 Delaying start of download for ESM3.CME. | 2023-04-13 07:20:15.041 Denali Data Feed | Network connection to server complete. | 2023-04-13 07:20:15.066 Denali Data Feed | Starting socket receive thread. | 2023-04-13 07:20:15.066 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-04-13 07:20:15.066 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-04-13 07:20:15.325 Denali Data Feed | Sending logon request message. | 2023-04-13 07:20:15.325 Requesting market depth updates for: ESM3.CME if supported. | 2023-04-13 07:20:15.338 Separate subscription for market depth updates not supported. ESM3.CME | 2023-04-13 07:20:15.338 Denali Data Feed | Received logon response. | 2023-04-13 07:20:16.238 Denali Data Feed | Server Name: SC Realtime Server. | 2023-04-13 07:20:16.238 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-04-13 07:20:16.238 Denali Data Feed | Successfully connected. | 2023-04-13 07:20:16.238 Denali Data Feed | Trading is not supported. | 2023-04-13 07:20:16.238 Denali Data Feed | Restarting real-time data updates for symbol: ESM3.CME -> ESM23. Market Depth data restarted. | 2023-04-13 07:20:16.238 Denali Data Feed | Clearing market depth for ESM3.CME | 2023-04-13 07:20:16.458 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM3.CME.2023-04-13.depth | 2023-04-13 07:20:16.459 Denali Data Feed | Received security definition for symbol ESM3.CME | 2023-04-13 07:20:16.459 HD Request # 2 | Downloading Intraday chart data for ESM3.CME to the file ESM3.CME.scid. Service: cme | 2023-04-13 07:20:21.769 HD Request # 2 | Download start date-time: 2023-04-13 07:20:07.000000. File last date-time: 2023-04-13 07:20:07.032005 | 2023-04-13 07:20:21.770 HD Request # 2 | Using server: ds28.sierracharts.com port 10149 | 2023-04-13 07:20:21.770 Socket (3) | Creating socket. | 2023-04-13 07:20:21.770 Socket (3) | New receive buffer size: 5242880 | 2023-04-13 07:20:21.770 Socket (3) | Connecting to IP: 142.215.18.147. | 2023-04-13 07:20:21.770 HD Request # 2 | Setting DTC encoding to Binary VLS | 2023-04-13 07:20:22.084 HD Request # 2 | Sending historical data logon request message. | 2023-04-13 07:20:22.084 HD Request # 2 | Requesting Intraday data. Start date-time: 2023-04-13 07:20:07. Record interval: 0. Symbol: ESM23 | 2023-04-13 07:20:22.768 HD Request # 2 | Decompressing data. | 2023-04-13 07:20:22.893 HD Request # 2 | Receiving Intraday data for ESM3.CME starting at 2023-04-13 07:20:07.032000 | 2023-04-13 07:20:22.893 Socket (3) | CloseSocket call. | 2023-04-13 07:20:22.894 Socket (3) | Shutdown started. Waiting for graceful close. | 2023-04-13 07:20:22.894 Historical data download thread signaled to stop. | 2023-04-13 07:20:22.894 HD Request # 2 | Timestamp of first Intraday data file record written: 2023-04-13 07:20:12.104000. | 2023-04-13 07:20:22.895 HD Request # 2 | Received 32 Intraday data records from 2023-04-13 07:20:07.032000 to 2023-04-13 07:20:18.767000 (11.7 seconds. Delay: 4.1 seconds) and wrote 26 records for ESM3.CME | 2023-04-13 07:20:22.895 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2023-04-13 07:20:18.767000 | 2023-04-13 07:20:22.896 HD Request # 2 | Completion time: 1s. | 2023-04-13 07:20:22.896 HD Request # 2 | Intraday data download complete for ESM3.CME. Unique request ID: 2 | 2023-04-13 07:20:22.896 Removing historical data download ID 2. | 2023-04-13 07:20:22.896 Real-time Intraday chart data file updates started for ESM3.CME | 2023-04-13 07:20:22.896 Intraday chart data file opened for ESM3.CME | 2023-04-13 07:20:22.896 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2023-04-13 07:20:22.896 Thanks again for your help |
[2023-04-13 14:16:52] |
We are not seeing any issue with historical data downloads in your log, in fact, quite the opposite - we are seeing historical data be requested and downloaded. Our first question is whether you have this setup as a "Continuous Futures Contract Chart"? Refer to the following: Continuous Futures Contract Charts And also how much data are you trying to download? You can only get about 5 years of data due to the single digit year used by Rithmic. Refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Single Digit Year Limitation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-13 15:10:42] |
Dear support thank you for your help, it allowed me to find the root cause. An explanation as well for other readers. i changed parameters to NO for continuous futures contract chart i checked the days to download which were ok (only 90 days for 240, 60 mn and TPO charts) but i first missed the fact the field "date range in file from" (menu data limiting of the chart settings) began on the 2023-04-12 , that is to say the date when i first set up Rithmic DTC as the "current selected service" on sierra chart. I did not realize at first as i swapped from SC service all data (with delayed data) to Rithmic with the same chatbook and i assumed that the parameters would remain the same. Thanks again for your pro active answer and help. |
