Date/Time: Wed, 01 May 2024 22:01:11 +0000
No Live data feed
View Count: 1104
[2021-02-06 16:26:49] |
User680868 - Posts: 6 |
Hi, I can't get intraday live data feed with any symbol. I've tried every possible fixes from the website. Every time I open an Intraday Chart, the loading box says : "loading historical chart" I noticed that in : Chart Settings > Date Range In Files, it is set to yesterday's date. I can't change the date because the box is locked. I tried to fix it with the "Use date Range" setting, but nothing... My data/trade service is : Trading Evaluator and I'm trying to simulate Eurex :FGBL Thanks for helping me |
[2021-02-07 03:34:06] |
User183724 - Posts: 183 |
im having the same problem. do you use AMP? Ive been talking to them for a week and cant get my issue resolved. only hlep SC gives is sending me to a website to sift through. AMP says im good to go... never had this type of problem with my charting so im struggling. if you get anywhere pls share and i will too. |
[2021-02-07 09:46:56] |
Regarding post #1, and post #2, we will determine what the problem is in each case and help you definitively today. Just please follow through the instructions here. We will get this done for you. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-07 09:47:49
[2021-02-07 09:50:12] |
Regarding post #2, we see this thread from you: chart isn't updating Based on the description of your problem, you are receiving the data, but the chart bars are not updating. So our response is the correct response. Most likely it is due to the Session Times not being set correctly: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.3 - Session Start Time and End Time not Covering Current Time But in any case give us the Message Log. So at least we can make sure you are indeed getting the real-time data. It could also be this: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.7 Delayed Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-07 12:14:29] |
Software version: 2226 64-bit | 2021-02-07 12:57:42.379 Primary Thread ID: 9036 | 2021-02-07 12:57:42.379 Usage end date: 2021-03-05 | 2021-02-07 12:57:42.379 Enabled for: Advanced Features 2. | 2021-02-07 12:57:42.379 Enabled for: Sierra Chart Historical Data Service. | 2021-02-07 12:57:42.379 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-02-07 12:57:42.379 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-07 12:57:42.379 Enabled for exchange: Eurex with Market Depth | 2021-02-07 12:57:42.379 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-07 12:57:42.379 Current selected Data/Trading service: Trading Evaluator | 2021-02-07 12:57:42.379 Custom symbol settings values: enabled | 2021-02-07 12:57:42.379 Chart Update Interval: 500 | 2021-02-07 12:57:42.379 Intraday Data Storage Time Unit: 1 | 2021-02-07 12:57:42.379 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2021-02-07 12:57:42.379 2021-02-07 11:57:42 Local computer time in UTC | 2021-02-07 12:57:42.379 2021-02-07 12:57:42 Local computer time in SC Time Zone | 2021-02-07 12:57:42.379 2021-02-07 11:56:50 Server time in UTC | 2021-02-07 12:57:42.379 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-02-07 12:57:42.379 Program path: C:\SierraChart\ | 2021-02-07 12:57:42.379 Data Files path: C:\SierraChart\Data\ | 2021-02-07 12:57:42.379 OS Version Number: 10.0 | 2021-02-07 12:57:42.379 Locale Setting: C | 2021-02-07 12:57:42.379 DLLs: UserContributedStudies_64.dll | 2021-02-07 12:57:42.379 Allowed protected custom studies: | 2021-02-07 12:57:42.379 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11250 | 2021-02-07 12:57:45.209 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2021-02-07 12:57:45.210 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-02-07 12:57:45.210 DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2021-02-07 12:57:45.210 Trading Evaluator | Network connection to server complete. | 2021-02-07 12:57:45.316 Trading Evaluator | Starting socket receive thread. | 2021-02-07 12:57:45.316 Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2021-02-07 12:57:45.316 Trading Evaluator | Setting DTC encoding to Binary VLS | 2021-02-07 12:57:45.634 Trading Evaluator | Sending logon request message. | 2021-02-07 12:57:45.634 Trading Evaluator | Received logon response. | 2021-02-07 12:57:45.741 Trading Evaluator | Server Name: SC DTC Server. | 2021-02-07 12:57:45.741 Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2021-02-07 12:57:45.741 Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2021-02-07 12:57:45.741 Trading Evaluator | Trading is supported. | 2021-02-07 12:57:45.741 Trading Evaluator | Order cancel and replace is supported. | 2021-02-07 12:57:45.741 Trading Evaluator | OCO Orders supported. | 2021-02-07 12:57:45.741 Trading Evaluator | Bracket Orders supported. | 2021-02-07 12:57:45.741 Trading Evaluator | Connected to server complete. | 2021-02-07 12:57:45.741 Triggering next historical data download in queue. | 2021-02-07 12:57:45.741 Triggering next historical data download in queue. | 2021-02-07 12:57:45.741 Triggering next historical data download in queue. | 2021-02-07 12:57:45.741 Triggering next historical data download in queue. | 2021-02-07 12:57:45.741 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-02-07 12:57:45.741 No download requests in the queue to start downloads for. | 2021-02-07 12:57:45.741 No download requests in the queue to start downloads for. | 2021-02-07 12:57:45.741 No download requests in the queue to start downloads for. | 2021-02-07 12:57:45.741 No download requests in the queue to start downloads for. | 2021-02-07 12:57:45.741 |
[2021-02-07 12:18:51] |
Just noticed about the CME thing... I'll fill up the agreements as I have an AMP account and CQG
Date Time Of Last Edit: 2021-02-07 12:21:36
[2021-02-07 15:36:37] |
My issue started when i changed over to Denali feed. Only need CME. Ive had an on going conversion with AMP. They told me I was good on their end. Reading Internal Order ID file. | 2021-02-05 22:21:49.737 Reading Trade Orders file. | 2021-02-05 22:21:49.783 Reading Trade Positions file. | 2021-02-05 22:21:49.783 Reading Trade Account Data files. | 2021-02-05 22:21:49.783 UDPListener (1464). Port 22904 | Listening on UDP port 22904. | 2021-02-05 22:21:49.799 Software version: 2226 64-bit | 2021-02-05 22:21:49.799 Primary Thread ID: 14032 | 2021-02-05 22:21:49.799 Usage end date: 2021-03-05 | 2021-02-05 22:21:49.799 Enabled for: Sierra Chart Historical Data Service. | 2021-02-05 22:21:49.799 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-02-05 22:21:49.799 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-05 22:21:49.799 Enabled for exchange2: CME (Trading Account Required) | 2021-02-05 22:21:49.799 Enabled for exchange2: CBOT (Trading Account Required) | 2021-02-05 22:21:49.799 Enabled for exchange2: COMEX (Trading Account Required) | 2021-02-05 22:21:49.799 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-02-05 22:21:49.799 Allow Support for Sierra Chart Data Feeds is disabled. | 2021-02-05 22:21:49.799 Current selected Data/Trading service: SC Data - All Services | 2021-02-05 22:21:49.799 Custom symbol settings values: enabled | 2021-02-05 22:21:49.799 Chart Update Interval: 500 | 2021-02-05 22:21:49.799 Intraday Data Storage Time Unit: 1 | 2021-02-05 22:21:49.799 Time Zone: +00:00:00 (UTC+00) | 2021-02-05 22:21:49.799 2021-02-05 22:21:49 Local computer time in UTC | 2021-02-05 22:21:49.799 2021-02-05 22:21:49 Local computer time in SC Time Zone | 2021-02-05 22:21:49.799 2021-02-05 22:21:49 Server time in UTC | 2021-02-05 22:21:49.799 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-02-05 22:21:49.799 Program path: C:\SierraChart\ | 2021-02-05 22:21:49.799 Data Files path: C:\SierraChart\Data\ | 2021-02-05 22:21:49.799 OS Version Number: 10.0 | 2021-02-05 22:21:49.799 Locale Setting: C | 2021-02-05 22:21:49.799 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-02-05 22:21:49.799 Allowed protected custom studies: | 2021-02-05 22:21:49.799 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2021-02-05 22:21:49.807 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-02-05 22:21:49.833 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-02-05 22:21:49.976 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-02-05 22:21:49.976 Received 5 login tokens. | 2021-02-05 22:21:50.342 Symbol settings MD5 received. Request ID: 1. | 2021-02-05 22:21:50.916 Symbol settings are up-to-date for scdataallservices. | 2021-02-05 22:21:50.916 Files to Open on Startup | Opening file: Chartbook6.Cht | 2021-02-05 22:21:54.442 MESH21-CME 5 Min #1 | Reloading chart. | 2021-02-05 22:21:54.462 MESH21-CME 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-02-05 22:21:54.640 Mapping MESH21-CME to MESH21. Service code: cme | 2021-02-05 22:21:54.958 Starting DelayedDownloadMonitoringTimer | 2021-02-05 22:21:54.958 Starting HDTimeoutTimer | 2021-02-05 22:21:54.958 Added historical Intraday data request for MESH21-CME to the queue. | 2021-02-05 22:21:54.959 Intraday data recording state for symbol MESH21-CME is set to download 'Pending'. | 2021-02-05 22:21:54.959 Triggering next historical data download in queue. | 2021-02-05 22:21:54.959 HD Request # 1 | Downloading Intraday chart data for MESH21-CME to the file MESH21-CME.scid. Service: cme | 2021-02-05 22:21:54.969 HD Request # 1 | Download start date-time: 2021-02-05 21:07:34.000000. File last date-time: 2021-02-05 21:07:34.088000 | 2021-02-05 22:21:54.969 HD Request # 1 | Using server: ds21.sierracharts.com port 10150 | 2021-02-05 22:21:54.969 Socket (1) | Creating socket. | 2021-02-05 22:21:54.970 Socket (1) | New receive buffer size: 5242880 | 2021-02-05 22:21:54.970 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-02-05 22:21:54.970 HD Request # 1 | Setting DTC encoding to Binary VLS | 2021-02-05 22:21:55.047 HD Request # 1 | Sending historical data logon request message. | 2021-02-05 22:21:55.047 HD Request # 1 | Requesting Intraday data. Start date-time: 2021-02-05 21:07:34. Record interval: 1. Symbol: MESH21 | 2021-02-05 22:21:55.536 HD Request # 1 | Decompressing data. | 2021-02-05 22:21:55.572 HD Request # 1 | Receiving Intraday data for MESH21-CME starting at 2021-02-05 21:07:34.088000 | 2021-02-05 22:21:55.608 Socket (1) | CloseSocket call. | 2021-02-05 22:21:55.609 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-05 22:21:55.609 HD Request # 1 | Historical data for MESH21-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-02-05 22:21:55.609 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-05 22:21:55.609 Historical data download thread signaled to stop. | 2021-02-05 22:21:55.609 HD Request # 1 | Timestamp of first Intraday data file record written: 2021-02-05 21:07:34.088000 | 2021-02-05 22:21:55.609 HD Request # 1 | Received 773 records from 2021-02-05 21:07:34.088000 to 2021-02-05 21:59:59.344000 (52.4 minutes) and wrote 773 records for MESH21-CME | 2021-02-05 22:21:55.609 HD Request # 1 | Completion time: 1s | 2021-02-05 22:21:55.609 HD Request # 1 | Intraday data download complete for MESH21-CME. Unique request ID: 1 | 2021-02-05 22:21:55.609 Removing historical data download ID 1. | 2021-02-05 22:21:55.609 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2021-02-05 22:21:55.609 Triggering next historical data download in queue. | 2021-02-05 22:21:55.609 No download requests in the queue to start downloads for. | 2021-02-05 22:21:55.609 Socket (1) | Socket gracefully closed by remote side. | 2021-02-05 22:21:55.647 Socket (1) | Closed. | 2021-02-05 22:21:55.648 SC Data - All Services | Connected to server complete. | 2021-02-05 22:21:56.458 Triggering next historical data download in queue. | 2021-02-05 22:21:56.458 Triggering next historical data download in queue. | 2021-02-05 22:21:56.458 Triggering next historical data download in queue. | 2021-02-05 22:21:56.458 Triggering next historical data download in queue. | 2021-02-05 22:21:56.458 No download requests in the queue to start downloads for. | 2021-02-05 22:21:56.468 No download requests in the queue to start downloads for. | 2021-02-05 22:21:56.468 No download requests in the queue to start downloads for. | 2021-02-05 22:21:56.468 No download requests in the queue to start downloads for. | 2021-02-05 22:21:56.468 Mapping MESH21-CME to MESH21. Service code: cme | 2021-02-05 22:21:56.468 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESH21-CME (MESH21). ID: 1 Service code: cme | 2021-02-05 22:21:56.468 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10044 | 2021-02-05 22:21:56.468 SC DTC Delayed Exchange Data | Requesting security definition data for: MESH21-CME (MESH21). ID: 1 | 2021-02-05 22:21:56.468 Added historical Intraday data request for MESH21-CME to the queue. | 2021-02-05 22:21:56.468 Intraday data recording state for symbol MESH21-CME is set to download 'Pending'. | 2021-02-05 22:21:56.468 Triggering next historical data download in queue. | 2021-02-05 22:21:56.468 DTC Client socket (1) | Creating socket. | 2021-02-05 22:21:56.468 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-05 22:21:56.468 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-02-05 22:21:56.469 Delaying start of download for MESH21-CME | 2021-02-05 22:21:56.473 SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-02-05 22:21:56.507 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-02-05 22:21:56.507 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-02-05 22:21:56.507 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-02-05 22:21:56.554 SC DTC Delayed Exchange Data | Sending logon request message. | 2021-02-05 22:21:56.554 SC DTC Delayed Exchange Data | Received logon response. | 2021-02-05 22:21:57.117 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-02-05 22:21:57.117 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-02-05 22:21:57.117 SC DTC Delayed Exchange Data | Successfully connected. | 2021-02-05 22:21:57.117 SC DTC Delayed Exchange Data | Trading is not supported. | 2021-02-05 22:21:57.117 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MESH21-CME -> MESH21 | 2021-02-05 22:21:57.117 SC DTC Delayed Exchange Data | Received security definition for symbol MESH21-CME | 2021-02-05 22:21:57.242 HD Request # 2 | Downloading Intraday chart data for MESH21-CME to the file MESH21-CME.scid. Service: cme | 2021-02-05 22:22:02.967 HD Request # 2 | Download start date-time: 2021-02-05 21:59:59.000000. File last date-time: 2021-02-05 21:59:59.344000 | 2021-02-05 22:22:02.968 HD Request # 2 | Using server: ds23.sierracharts.com port 10149 | 2021-02-05 22:22:02.968 Socket (2) | Creating socket. | 2021-02-05 22:22:02.968 Socket (2) | New receive buffer size: 5242880 | 2021-02-05 22:22:02.968 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-02-05 22:22:02.969 HD Request # 2 | Setting DTC encoding to Binary VLS | 2021-02-05 22:22:03.056 HD Request # 2 | Sending historical data logon request message. | 2021-02-05 22:22:03.056 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-02-05 21:59:59. Record interval: 1. Symbol: MESH21 | 2021-02-05 22:22:03.546 HD Request # 2 | Decompressing data. | 2021-02-05 22:22:03.583 HD Request # 2 | Receiving Intraday data for MESH21-CME starting at 2021-02-05 21:59:59.344000 | 2021-02-05 22:22:03.584 Socket (2) | CloseSocket call. | 2021-02-05 22:22:03.584 Socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-05 22:22:03.584 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-02-05 22:22:03.585 Historical data download thread signaled to stop. | 2021-02-05 22:22:03.585 HD Request # 2 | Timestamp of first Intraday data file record written: 2021-02-05 21:59:59.344000 | 2021-02-05 22:22:03.585 HD Request # 2 | Received 1 record from 2021-02-05 21:59:59.344000 to 2021-02-05 21:59:59.344000 (0.0 seconds) and wrote 1 record for MESH21-CME | 2021-02-05 22:22:03.585 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2021-02-05 21:59:59.344000 | 2021-02-05 22:22:03.585 HD Request # 2 | Completion time: 1s | 2021-02-05 22:22:03.585 HD Request # 2 | Intraday data download complete for MESH21-CME. Unique request ID: 2 | 2021-02-05 22:22:03.585 Removing historical data download ID 2. | 2021-02-05 22:22:03.586 Real-time Intraday chart data file updates started for MESH21-CME | 2021-02-05 22:22:03.586 Opened cached Intraday file: C:\SierraChart\Data\MESH21-CME.scid. Thread ID: 14032 | 2021-02-05 22:22:03.586 Intraday chart data file opened for MESH21-CME | 2021-02-05 22:22:03.586 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-02-05 22:22:03.586 Triggering next historical data download in queue. | 2021-02-05 22:22:03.586 No download requests in the queue to start downloads for. | 2021-02-05 22:22:03.586 Socket (2) | Socket gracefully closed by remote side. | 2021-02-05 22:22:03.624 Socket (2) | Closed. | 2021-02-05 22:22:03.624 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-06 10:29:13.713 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-02-06 10:29:13.713 DTC Client socket (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-06 10:29:13.915 DTC Client socket (1) | CloseSocket call. | 2021-02-06 10:29:14.154 DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-06 10:29:14.154 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-06 10:29:14.154 DTC Client socket (1) | Closed. | 2021-02-06 10:29:14.154 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2021-02-06 10:29:14.155 DTC Client socket (0) | CloseSocket call. | 2021-02-06 10:29:14.156 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-02-06 10:29:14.156 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-02-06 10:29:14.156 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2021-02-06 10:29:16.138 Error getting address info for ds12-2.sierracharts.com. Windows error code 11001: No such host is known. | 2021-02-06 10:29:16.138 * DTC Client socket (1) | CloseSocket call. | 2021-02-06 10:29:16.138 DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-06 10:29:16.138 DTC Client socket (0) | CloseSocket call. | 2021-02-06 10:29:16.138 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-02-06 10:29:16.138 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-02-06 10:29:16.138 SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10044 | 2021-02-06 10:29:18.137 Error getting address info for ds13.sierracharts.com. Windows error code 11001: No such host is known. | 2021-02-06 10:29:18.138 * DTC Client socket (1) | CloseSocket call. | 2021-02-06 10:29:18.138 DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-06 10:29:18.138 DTC Client socket (0) | CloseSocket call. | 2021-02-06 10:29:18.138 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-02-06 10:29:18.138 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-02-06 10:29:18.138 Notice: Detected that the system has resumed from a low-power state. | 2021-02-07 05:30:44.098 Re-connecting to the Data/Trading service. | 2021-02-07 05:30:44.098 DTC Client socket (0) | CloseSocket call. | 2021-02-07 05:30:44.103 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-02-07 05:30:44.103 SC Data - All Services | Disconnected. | 2021-02-07 05:30:44.103 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-07 05:30:44.103 SC Data - All Services | Connected to server complete. | 2021-02-07 05:30:47.451 Triggering next historical data download in queue. | 2021-02-07 05:30:47.451 Triggering next historical data download in queue. | 2021-02-07 05:30:47.451 Triggering next historical data download in queue. | 2021-02-07 05:30:47.451 Triggering next historical data download in queue. | 2021-02-07 05:30:47.451 No download requests in the queue to start downloads for. | 2021-02-07 05:30:47.456 No download requests in the queue to start downloads for. | 2021-02-07 05:30:47.456 No download requests in the queue to start downloads for. | 2021-02-07 05:30:47.456 No download requests in the queue to start downloads for. | 2021-02-07 05:30:47.456 Mapping MESH21-CME to MESH21. Service code: cme | 2021-02-07 05:30:47.457 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESH21-CME (MESH21). ID: 1 Service code: cme | 2021-02-07 05:30:47.457 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2021-02-07 05:30:47.457 SC DTC Delayed Exchange Data | Requesting security definition data for: MESH21-CME (MESH21). ID: 1 | 2021-02-07 05:30:47.457 Added historical Intraday data request for MESH21-CME to the queue. | 2021-02-07 05:30:47.457 Intraday data recording state for symbol MESH21-CME is set to download 'Pending'. | 2021-02-07 05:30:47.457 Triggering next historical data download in queue. | 2021-02-07 05:30:47.457 DTC Client socket (1) | Using previously cached IP address because unable to resolve domain name | 2021-02-07 05:30:47.457 DTC Client socket (1) | Creating socket. | 2021-02-07 05:30:47.457 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-07 05:30:47.457 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-02-07 05:30:47.457 DTC Client socket (1) | Connect event error. Windows error code 10065: A socket operation was attempted to an unreachable host. | 2021-02-07 05:30:47.458 * Delaying start of download for MESH21-CME | 2021-02-07 05:30:47.469 DTC Client socket (1) | CloseSocket call. | 2021-02-07 05:30:47.469 DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-07 05:30:47.469 DTC Client socket (0) | CloseSocket call. | 2021-02-07 05:30:47.469 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-02-07 05:30:47.469 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-02-07 05:30:47.469 DTC Client socket (1) | Closed. | 2021-02-07 05:30:47.469 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10044 | 2021-02-07 05:30:49.465 DTC Client socket (1) | Creating socket. | 2021-02-07 05:30:49.542 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-07 05:30:49.542 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-02-07 05:30:49.542 SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-02-07 05:30:49.581 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-02-07 05:30:49.581 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-02-07 05:30:49.581 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-02-07 05:30:49.622 SC DTC Delayed Exchange Data | Sending logon request message. | 2021-02-07 05:30:49.622 SC DTC Delayed Exchange Data | Received logon response. | 2021-02-07 05:30:50.187 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-02-07 05:30:50.187 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-02-07 05:30:50.187 SC DTC Delayed Exchange Data | Successfully connected. | 2021-02-07 05:30:50.187 SC DTC Delayed Exchange Data | Trading is not supported. | 2021-02-07 05:30:50.187 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MESH21-CME -> MESH21 | 2021-02-07 05:30:50.187 SC DTC Delayed Exchange Data | Received security definition for symbol MESH21-CME | 2021-02-07 05:30:50.309 HD Request # 3 | Downloading Intraday chart data for MESH21-CME to the file MESH21-CME.scid. Service: cme | 2021-02-07 05:30:55.918 HD Request # 3 | Download start date-time: 2021-02-05 21:59:59.000000. File last date-time: 2021-02-05 21:59:59.344000 | 2021-02-07 05:30:55.918 HD Request # 3 | Using server: ds21.sierracharts.com port 10150 | 2021-02-07 05:30:55.918 Socket (2) | Creating socket. | 2021-02-07 05:30:55.919 Socket (2) | New receive buffer size: 5242880 | 2021-02-07 05:30:55.919 Socket (2) | Connecting to IP: 216.1.90.129. | 2021-02-07 05:30:55.919 HD Request # 3 | Setting DTC encoding to Binary VLS | 2021-02-07 05:30:55.994 HD Request # 3 | Sending historical data logon request message. | 2021-02-07 05:30:55.994 HD Request # 3 | Requesting Intraday data. Start date-time: 2021-02-05 21:59:59. Record interval: 1. Symbol: MESH21 | 2021-02-07 05:30:56.480 HD Request # 3 | Decompressing data. | 2021-02-07 05:30:56.516 HD Request # 3 | Receiving Intraday data for MESH21-CME starting at 2021-02-05 21:59:59.344000 | 2021-02-07 05:30:56.516 Socket (2) | CloseSocket call. | 2021-02-07 05:30:56.516 Socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-07 05:30:56.516 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-02-07 05:30:56.517 Historical data download thread signaled to stop. | 2021-02-07 05:30:56.517 HD Request # 3 | Timestamp of first Intraday data file record written: 2021-02-05 21:59:59.344000 | 2021-02-07 05:30:56.517 HD Request # 3 | Received 1 record from 2021-02-05 21:59:59.344000 to 2021-02-05 21:59:59.344000 (0.0 seconds) and wrote 1 record for MESH21-CME | 2021-02-07 05:30:56.517 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2021-02-05 21:59:59.344000 | 2021-02-07 05:30:56.517 HD Request # 3 | Completion time: 1s | 2021-02-07 05:30:56.517 HD Request # 3 | Intraday data download complete for MESH21-CME. Unique request ID: 3 | 2021-02-07 05:30:56.517 Removing historical data download ID 3. | 2021-02-07 05:30:56.517 Real-time Intraday chart data file updates started for MESH21-CME | 2021-02-07 05:30:56.517 Opened cached Intraday file: C:\SierraChart\Data\MESH21-CME.scid. Thread ID: 14032 | 2021-02-07 05:30:56.518 Intraday chart data file opened for MESH21-CME | 2021-02-07 05:30:56.518 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2021-02-07 05:30:56.518 Triggering next historical data download in queue. | 2021-02-07 05:30:56.518 No download requests in the queue to start downloads for. | 2021-02-07 05:30:56.518 Socket (2) | Socket gracefully closed by remote side. | 2021-02-07 05:30:56.555 Socket (2) | Closed. | 2021-02-07 05:30:56.555 Notice: Detected that the system has resumed from a low-power state. | 2021-02-07 06:44:59.477 Re-connecting to the Data/Trading service. | 2021-02-07 06:44:59.477 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2021-02-07 06:44:59.492 DTC Client socket (1) | CloseSocket call. | 2021-02-07 06:44:59.494 DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-07 06:44:59.494 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-02-07 06:44:59.494 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-02-07 06:44:59.494 SC Data - All Services | Disconnected. | 2021-02-07 06:44:59.494 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-07 06:44:59.494 SC Data - All Services | Connected to server complete. | 2021-02-07 06:45:02.500 Triggering next historical data download in queue. | 2021-02-07 06:45:02.501 Triggering next historical data download in queue. | 2021-02-07 06:45:02.501 Triggering next historical data download in queue. | 2021-02-07 06:45:02.501 Triggering next historical data download in queue. | 2021-02-07 06:45:02.501 No download requests in the queue to start downloads for. | 2021-02-07 06:45:02.505 No download requests in the queue to start downloads for. | 2021-02-07 06:45:02.505 No download requests in the queue to start downloads for. | 2021-02-07 06:45:02.505 No download requests in the queue to start downloads for. | 2021-02-07 06:45:02.505 Mapping MESH21-CME to MESH21. Service code: cme | 2021-02-07 06:45:02.507 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESH21-CME (MESH21). ID: 1 Service code: cme | 2021-02-07 06:45:02.507 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2021-02-07 06:45:02.507 SC DTC Delayed Exchange Data | Requesting security definition data for: MESH21-CME (MESH21). ID: 1 | 2021-02-07 06:45:02.507 Added historical Intraday data request for MESH21-CME to the queue. | 2021-02-07 06:45:02.507 Intraday data recording state for symbol MESH21-CME is set to download 'Pending'. | 2021-02-07 06:45:02.507 Triggering next historical data download in queue. | 2021-02-07 06:45:02.507 Delaying start of download for MESH21-CME | 2021-02-07 06:45:02.517 DTC Client socket (2) | Creating socket. | 2021-02-07 06:45:02.568 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-02-07 06:45:02.568 DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2021-02-07 06:45:02.568 SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-02-07 06:45:02.624 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-02-07 06:45:02.624 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-02-07 06:45:02.624 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-02-07 06:45:02.720 SC DTC Delayed Exchange Data | Sending logon request message. | 2021-02-07 06:45:02.720 SC DTC Delayed Exchange Data | Received logon response. | 2021-02-07 06:45:03.347 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-02-07 06:45:03.347 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-02-07 06:45:03.347 SC DTC Delayed Exchange Data | Successfully connected. | 2021-02-07 06:45:03.347 SC DTC Delayed Exchange Data | Trading is not supported. | 2021-02-07 06:45:03.347 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MESH21-CME -> MESH21 | 2021-02-07 06:45:03.347 SC DTC Delayed Exchange Data | Received security definition for symbol MESH21-CME | 2021-02-07 06:45:03.502 HD Request # 4 | Downloading Intraday chart data for MESH21-CME to the file MESH21-CME.scid. Service: cme | 2021-02-07 06:45:08.509 HD Request # 4 | Download start date-time: 2021-02-05 21:59:59.000000. File last date-time: 2021-02-05 21:59:59.344000 | 2021-02-07 06:45:08.509 HD Request # 4 | Using server: ds23.sierracharts.com port 10149 | 2021-02-07 06:45:08.509 Socket (3) | Creating socket. | 2021-02-07 06:45:08.572 Socket (3) | New receive buffer size: 5242880 | 2021-02-07 06:45:08.572 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-02-07 06:45:08.572 HD Request # 4 | Setting DTC encoding to Binary VLS | 2021-02-07 06:45:08.669 HD Request # 4 | Sending historical data logon request message. | 2021-02-07 06:45:08.669 HD Request # 4 | Requesting Intraday data. Start date-time: 2021-02-05 21:59:59. Record interval: 1. Symbol: MESH21 | 2021-02-07 06:45:09.177 HD Request # 4 | Decompressing data. | 2021-02-07 06:45:09.215 HD Request # 4 | Receiving Intraday data for MESH21-CME starting at 2021-02-05 21:59:59.344000 | 2021-02-07 06:45:09.216 Socket (3) | CloseSocket call. | 2021-02-07 06:45:09.216 Socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-07 06:45:09.216 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-02-07 06:45:09.216 Historical data download thread signaled to stop. | 2021-02-07 06:45:09.216 HD Request # 4 | Timestamp of first Intraday data file record written: 2021-02-05 21:59:59.344000 | 2021-02-07 06:45:09.217 HD Request # 4 | Received 1 record from 2021-02-05 21:59:59.344000 to 2021-02-05 21:59:59.344000 (0.0 seconds) and wrote 1 record for MESH21-CME | 2021-02-07 06:45:09.217 HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2021-02-05 21:59:59.344000 | 2021-02-07 06:45:09.217 HD Request # 4 | Completion time: 1s | 2021-02-07 06:45:09.217 HD Request # 4 | Intraday data download complete for MESH21-CME. Unique request ID: 4 | 2021-02-07 06:45:09.217 Removing historical data download ID 4. | 2021-02-07 06:45:09.217 Real-time Intraday chart data file updates started for MESH21-CME | 2021-02-07 06:45:09.217 Opened cached Intraday file: C:\SierraChart\Data\MESH21-CME.scid. Thread ID: 14032 | 2021-02-07 06:45:09.217 Intraday chart data file opened for MESH21-CME | 2021-02-07 06:45:09.217 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2021-02-07 06:45:09.217 Triggering next historical data download in queue. | 2021-02-07 06:45:09.217 No download requests in the queue to start downloads for. | 2021-02-07 06:45:09.217 Socket (3) | Socket gracefully closed by remote side. | 2021-02-07 06:45:09.254 Socket (3) | Closed. | 2021-02-07 06:45:09.254 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-02-07 06:45:20.551 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-07 06:45:20.551 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-07 06:45:20.551 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-02-07 06:45:20.551 DTC Client socket (1) | Closed. | 2021-02-07 06:45:20.551 Notice: Detected that the system has resumed from a low-power state. | 2021-02-07 15:03:04.573 Re-connecting to the Data/Trading service. | 2021-02-07 15:03:04.573 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2021-02-07 15:03:04.599 DTC Client socket (2) | CloseSocket call. | 2021-02-07 15:03:04.607 DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-07 15:03:04.607 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-02-07 15:03:04.608 SC Data - All Services | Disconnected. | 2021-02-07 15:03:04.608 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-07 15:03:04.608 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-02-07 15:03:04.610 SC Data - All Services | Connected to server complete. | 2021-02-07 15:03:07.591 Triggering next historical data download in queue. | 2021-02-07 15:03:07.591 Triggering next historical data download in queue. | 2021-02-07 15:03:07.591 Triggering next historical data download in queue. | 2021-02-07 15:03:07.591 Triggering next historical data download in queue. | 2021-02-07 15:03:07.591 No download requests in the queue to start downloads for. | 2021-02-07 15:03:07.595 No download requests in the queue to start downloads for. | 2021-02-07 15:03:07.595 No download requests in the queue to start downloads for. | 2021-02-07 15:03:07.595 No download requests in the queue to start downloads for. | 2021-02-07 15:03:07.595 Mapping MESH21-CME to MESH21. Service code: cme | 2021-02-07 15:03:07.998 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESH21-CME (MESH21). ID: 1 Service code: cme | 2021-02-07 15:03:07.998 SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10044 | 2021-02-07 15:03:07.998 SC DTC Delayed Exchange Data | Requesting security definition data for: MESH21-CME (MESH21). ID: 1 | 2021-02-07 15:03:07.998 Added historical Intraday data request for MESH21-CME to the queue. | 2021-02-07 15:03:07.998 Intraday data recording state for symbol MESH21-CME is set to download 'Pending'. | 2021-02-07 15:03:07.998 Triggering next historical data download in queue. | 2021-02-07 15:03:07.998 Delaying start of download for MESH21-CME | 2021-02-07 15:03:08.006 DTC Client socket (3) | Creating socket. | 2021-02-07 15:03:08.048 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-02-07 15:03:08.049 DTC Client socket (3) | Connecting to IP: 64.38.174.178. | 2021-02-07 15:03:08.049 SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-02-07 15:03:08.112 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-02-07 15:03:08.112 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-02-07 15:03:08.112 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-02-07 15:03:08.194 SC DTC Delayed Exchange Data | Sending logon request message. | 2021-02-07 15:03:08.194 SC DTC Delayed Exchange Data | Received logon response. | 2021-02-07 15:03:08.977 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-02-07 15:03:08.977 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-02-07 15:03:08.977 SC DTC Delayed Exchange Data | Successfully connected. | 2021-02-07 15:03:08.977 SC DTC Delayed Exchange Data | Trading is not supported. | 2021-02-07 15:03:08.977 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MESH21-CME -> MESH21 | 2021-02-07 15:03:08.977 SC DTC Delayed Exchange Data | Received security definition for symbol MESH21-CME | 2021-02-07 15:03:09.132 HD Request # 5 | Downloading Intraday chart data for MESH21-CME to the file MESH21-CME.scid. Service: cme | 2021-02-07 15:03:14.507 HD Request # 5 | Download start date-time: 2021-02-05 21:59:59.000000. File last date-time: 2021-02-05 21:59:59.344000 | 2021-02-07 15:03:14.507 HD Request # 5 | Using server: ds21.sierracharts.com port 10150 | 2021-02-07 15:03:14.507 Socket (4) | Creating socket. | 2021-02-07 15:03:14.507 Socket (4) | New receive buffer size: 5242880 | 2021-02-07 15:03:14.507 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-02-07 15:03:14.507 HD Request # 5 | Setting DTC encoding to Binary VLS | 2021-02-07 15:03:14.584 HD Request # 5 | Sending historical data logon request message. | 2021-02-07 15:03:14.584 HD Request # 5 | Requesting Intraday data. Start date-time: 2021-02-05 21:59:59. Record interval: 1. Symbol: MESH21 | 2021-02-07 15:03:15.073 HD Request # 5 | Decompressing data. | 2021-02-07 15:03:15.108 HD Request # 5 | Receiving Intraday data for MESH21-CME starting at 2021-02-05 21:59:59.344000 | 2021-02-07 15:03:15.109 Socket (4) | CloseSocket call. | 2021-02-07 15:03:15.109 Socket (4) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-07 15:03:15.109 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-02-07 15:03:15.109 Historical data download thread signaled to stop. | 2021-02-07 15:03:15.109 HD Request # 5 | Timestamp of first Intraday data file record written: 2021-02-05 21:59:59.344000 | 2021-02-07 15:03:15.109 HD Request # 5 | Received 1 record from 2021-02-05 21:59:59.344000 to 2021-02-05 21:59:59.344000 (0.0 seconds) and wrote 1 record for MESH21-CME | 2021-02-07 15:03:15.109 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2021-02-05 21:59:59.344000 | 2021-02-07 15:03:15.110 HD Request # 5 | Completion time: 1s | 2021-02-07 15:03:15.110 HD Request # 5 | Intraday data download complete for MESH21-CME. Unique request ID: 5 | 2021-02-07 15:03:15.110 Removing historical data download ID 5. | 2021-02-07 15:03:15.110 Real-time Intraday chart data file updates started for MESH21-CME | 2021-02-07 15:03:15.110 Opened cached Intraday file: C:\SierraChart\Data\MESH21-CME.scid. Thread ID: 14032 | 2021-02-07 15:03:15.110 Intraday chart data file opened for MESH21-CME | 2021-02-07 15:03:15.110 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2021-02-07 15:03:15.110 Triggering next historical data download in queue. | 2021-02-07 15:03:15.110 No download requests in the queue to start downloads for. | 2021-02-07 15:03:15.110 Socket (4) | Socket gracefully closed by remote side. | 2021-02-07 15:03:15.149 Socket (4) | Closed. | 2021-02-07 15:03:15.149 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2021-02-07 15:03:25.268 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-02-07 15:03:25.268 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-07 15:03:25.269 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-02-07 15:03:25.269 DTC Client socket (2) | Closed. | 2021-02-07 15:03:25.269 |
[2021-02-07 23:17:04] |
i have 10 min delayed quotes today. started 10 minutes after the market opened
[2021-02-08 01:05:21] |
Regarding the Message Log at post #5 we need you to open a FGBLH21 chart and then provide the Message Log again. Regarding the Message Log at post # 7: Allow Support for Sierra Chart Data Feeds is disabled. | 2021-02-05 22:21:49.799 You need to enable this setting: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) But in order to trade live, you need to follow the instructions starting at step number 9 here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions and be sure to follow step 19. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-08 01:11:03
[2021-02-08 01:53:41] |
I enabled Allow Support for Sierra Chart Data Feeds Made $10 payment... i expected this to be completed by AMP Still no [M] and still delayed quotes |
[2021-02-08 02:29:47] |
Regarding post #10, reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers If you are still receiving delayed data, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-08 02:30:15
[2021-02-08 02:52:19] |
im not receiving anything now. when it loads, its done
[2021-02-08 04:41:32] |
copied this from my account info Sierra Chart version 1944 or higher required to use this data feed. Before you can activate the Service, make sure that you have Completed the required agreements. CME / CBOT / NYMEX / COMEX Exchange Agreements (required) Your account is not authorized for updating the data feed service. <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Active Service: Denali Exchange Data Feed for All Services - Active until: 2021-02-28 23:59:59 UTC Activate / Deactivate Denali Exchange Data Feed Exchanges [CME / CBOT / NYMEX / COMEX] (required) |
[2021-02-08 05:46:42] |
You now need to translate the symbols. You need to translate the symbols by selecting Edit >> Translate Symbols to Current Service. We did specifically to indicate that needs to be done by referring to the particular step . Do that and let us know if you still are not receiving the real-time data. If not provide the Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-08 07:57:19] |
Hi, here's my log after opening FGBLH21. I have live data working perfectly. Thank you very much for the quick support you provided to both of us ! Software version: 2226 64-bit | 2021-02-08 08:51:01.644 Primary Thread ID: 12928 | 2021-02-08 08:51:01.644 Usage end date: 2021-03-05 | 2021-02-08 08:51:01.644 Enabled for: Advanced Features 2. | 2021-02-08 08:51:01.644 Enabled for: Sierra Chart Historical Data Service. | 2021-02-08 08:51:01.644 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-02-08 08:51:01.644 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-08 08:51:01.644 Enabled for exchange: Eurex with Market Depth | 2021-02-08 08:51:01.644 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-08 08:51:01.644 Current selected Data/Trading service: Trading Evaluator | 2021-02-08 08:51:01.644 Custom symbol settings values: enabled | 2021-02-08 08:51:01.644 Chart Update Interval: 500 | 2021-02-08 08:51:01.644 Intraday Data Storage Time Unit: 1 | 2021-02-08 08:51:01.644 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2021-02-08 08:51:01.644 2021-02-08 07:51:01 Local computer time in UTC | 2021-02-08 08:51:01.644 2021-02-08 08:51:01 Local computer time in SC Time Zone | 2021-02-08 08:51:01.644 2021-02-08 07:49:45 Server time in UTC | 2021-02-08 08:51:01.644 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-02-08 08:51:01.644 Program path: C:\SierraChart\ | 2021-02-08 08:51:01.644 Data Files path: C:\SierraChart\Data\ | 2021-02-08 08:51:01.644 OS Version Number: 10.0 | 2021-02-08 08:51:01.644 Locale Setting: C | 2021-02-08 08:51:01.644 DLLs: UserContributedStudies_64.dll | 2021-02-08 08:51:01.644 Allowed protected custom studies: | 2021-02-08 08:51:01.644 Trading Evaluator | Connecting to the server evaluator.sierracharts.com. Port 11250 | 2021-02-08 08:51:05.127 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-02-08 08:51:05.128 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-08 08:51:05.128 DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2021-02-08 08:51:05.128 Trading Evaluator | Network connection to server complete. | 2021-02-08 08:51:05.233 Trading Evaluator | Starting socket receive thread. | 2021-02-08 08:51:05.233 Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2021-02-08 08:51:05.233 Trading Evaluator | Setting DTC encoding to Binary VLS | 2021-02-08 08:51:05.551 Trading Evaluator | Sending logon request message. | 2021-02-08 08:51:05.551 Trading Evaluator | Received logon response. | 2021-02-08 08:51:05.663 Trading Evaluator | Server Name: SC DTC Server. | 2021-02-08 08:51:05.663 Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2021-02-08 08:51:05.663 Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2021-02-08 08:51:05.663 Trading Evaluator | Trading is supported. | 2021-02-08 08:51:05.663 Trading Evaluator | Order cancel and replace is supported. | 2021-02-08 08:51:05.663 Trading Evaluator | OCO Orders supported. | 2021-02-08 08:51:05.663 Trading Evaluator | Bracket Orders supported. | 2021-02-08 08:51:05.663 Trading Evaluator | Connected to server complete. | 2021-02-08 08:51:05.663 Triggering next historical data download in queue. | 2021-02-08 08:51:05.663 Triggering next historical data download in queue. | 2021-02-08 08:51:05.663 Triggering next historical data download in queue. | 2021-02-08 08:51:05.663 Triggering next historical data download in queue. | 2021-02-08 08:51:05.663 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-02-08 08:51:05.663 No download requests in the queue to start downloads for. | 2021-02-08 08:51:05.663 No download requests in the queue to start downloads for. | 2021-02-08 08:51:05.663 No download requests in the queue to start downloads for. | 2021-02-08 08:51:05.663 No download requests in the queue to start downloads for. | 2021-02-08 08:51:05.663 FGBLH21 1 Min #1 | Reloading chart. | 2021-02-08 08:51:10.110 FGBLH21 1 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2021-02-06 20:51:00. Next Bar Date Time: 2021-02-05 20:51:00. Filename: FGBLH21.scid | 2021-02-08 08:51:10.187 Mapping FGBLH21 to GGH21. Service code: eurex | 2021-02-08 08:51:10.609 SC Data - All Services | Starting real-time market data updates for: FGBLH21 (GGH21). ID: 1 Service code: eurex | 2021-02-08 08:51:10.610 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2021-02-08 08:51:10.610 SC Data - All Services | Requesting security definition data for: FGBLH21 (GGH21). ID: 1 | 2021-02-08 08:51:10.610 Starting DelayedDownloadMonitoringTimer | 2021-02-08 08:51:10.610 Starting HDTimeoutTimer | 2021-02-08 08:51:10.610 Added historical Intraday data request for FGBLH21 to the queue. | 2021-02-08 08:51:10.610 Intraday data recording state for symbol FGBLH21 is set to download 'Pending'. | 2021-02-08 08:51:10.610 Triggering next historical data download in queue. | 2021-02-08 08:51:10.610 DTC Client socket (2) | Creating socket. | 2021-02-08 08:51:10.613 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-02-08 08:51:10.613 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2021-02-08 08:51:10.613 Delaying start of download for FGBLH21 | 2021-02-08 08:51:10.614 Trading Evaluator | Received security definition for symbol FGBLH21 | 2021-02-08 08:51:10.714 SC Data - All Services | Network connection to server complete. | 2021-02-08 08:51:10.722 SC Data - All Services | Starting socket receive thread. | 2021-02-08 08:51:10.722 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-02-08 08:51:10.722 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-02-08 08:51:10.840 SC Data - All Services | Sending logon request message. | 2021-02-08 08:51:10.840 SC Data - All Services | Received logon response. | 2021-02-08 08:51:11.577 SC Data - All Services | Server Name: SC Realtime Server. | 2021-02-08 08:51:11.577 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-02-08 08:51:11.577 SC Data - All Services | Successfully connected. | 2021-02-08 08:51:11.577 SC Data - All Services | Trading is not supported. | 2021-02-08 08:51:11.577 SC Data - All Services | Restarting real-time data updates for symbol: FGBLH21 -> GGH21 | 2021-02-08 08:51:11.577 SC Data - All Services | Received security definition for symbol FGBLH21 | 2021-02-08 08:51:11.765 HD Request # 1 | Downloading Intraday chart data for FGBLH21 to the file FGBLH21.scid. Service: eurex | 2021-02-08 08:51:16.621 HD Request # 1 | Download start date-time: 2021-02-05 22:03:27.000000. File last date-time: 2021-02-05 22:03:27.170000 | 2021-02-08 08:51:16.621 HD Request # 1 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2021-02-08 08:51:16.621 Socket (3) | Creating socket. | 2021-02-08 08:51:16.625 Socket (3) | New receive buffer size: 5242880 | 2021-02-08 08:51:16.625 Socket (3) | Connecting to IP: 8.18.161.133. | 2021-02-08 08:51:16.625 HD Request # 1 | Setting DTC encoding to Binary VLS | 2021-02-08 08:51:16.852 HD Request # 1 | Sending historical data logon request message. | 2021-02-08 08:51:16.852 HD Request # 1 | Requesting Intraday data. Start date-time: 2021-02-05 22:03:27. Record interval: 1. Symbol: GGH21 | 2021-02-08 08:51:17.419 HD Request # 1 | Decompressing data. | 2021-02-08 08:51:17.527 HD Request # 1 | Receiving Intraday data for FGBLH21 starting at 2021-02-05 22:03:27.170000 | 2021-02-08 08:51:17.641 Socket (3) | CloseSocket call. | 2021-02-08 08:51:17.641 Socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-08 08:51:17.641 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-02-08 08:51:17.641 Historical data download thread signaled to stop. | 2021-02-08 08:51:17.641 HD Request # 1 | Timestamp of first Intraday data file record written: 2021-02-05 22:03:27.170000 | 2021-02-08 08:51:17.641 HD Request # 1 | Received 1285 records from 2021-02-05 22:03:27.170000 to 2021-02-08 08:51:14.248000 (2.4 days) and wrote 1285 records for FGBLH21 | 2021-02-08 08:51:17.642 HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2021-02-08 07:51:14.248000 | 2021-02-08 08:51:17.642 Added 1 Time and Sales records to Intraday data file for FGBLH21 after download. | 2021-02-08 08:51:17.642 HD Request # 1 | Completion time: 1s | 2021-02-08 08:51:17.642 HD Request # 1 | Intraday data download complete for FGBLH21. Unique request ID: 1 | 2021-02-08 08:51:17.642 Removing historical data download ID 1. | 2021-02-08 08:51:17.642 Real-time Intraday chart data file updates started for FGBLH21 | 2021-02-08 08:51:17.642 Opened cached Intraday file: C:\SierraChart\Data\FGBLH21.scid. Thread ID: 12928 | 2021-02-08 08:51:17.642 Intraday chart data file opened for FGBLH21 | 2021-02-08 08:51:17.642 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2021-02-08 08:51:17.642 Triggering next historical data download in queue. | 2021-02-08 08:51:17.642 No download requests in the queue to start downloads for. | 2021-02-08 08:51:17.642 Socket (3) | Socket gracefully closed by remote side. | 2021-02-08 08:51:17.748 Socket (3) | Closed. | 2021-02-08 08:51:17.748 |
[2021-02-08 08:21:16] |
Regarding post #15 we understand everything is now fine.
[2021-02-08 14:12:10] |
If i set 'Current Selected Service' to 'SC Data - All Services{data]' my data works If i set 'Current Selected Service' to 'Set the Service to SC Futures Order Routing/Data' my data locks up |
[2021-02-08 14:37:16] |
John - SC Support - Posts: 31283 |
With Regards to Post #17: Are you changing the symbols when you switch between the services? They each use a slightly different symbol format, and when you change the Service and select OK on that window, you should get a prompt that asks if you want to update the symbols to the current service, in general, you should say Yes to this. If, for any reason, the symbols are not updated, then use the option "Edit >> Translate Symbols to Current Service". Refer to the information here: Edit Menu: Edit >> Translate Symbols To Current Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-08 14:56:34] |
yes i did. but my question is... in step #9 above... But in order to trade live, you need to follow the instructions starting at step number 9 here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions 9. Select Global Settings >> Data/Trade Service Settings. 10. Set the Service to SC Futures Order Routing/Data when i set mine to Service to SC Futures Order Routing/Data, my data locks up. i have to set it to 'SC Data - All Services{data]' to get my data to work. is there still something wrong? |
[2021-02-08 16:18:46] |
Please switch your service to the SC Futures Order Routing/Data and then follow these instructions to get us your Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-09 05:28:43] |
Software version: 2226 64-bit | 2021-02-08 23:16:56.452 Primary Thread ID: 22180 | 2021-02-08 23:16:56.452 Usage end date: 2021-03-05 | 2021-02-08 23:16:56.452 Enabled for: Sierra Chart Historical Data Service. | 2021-02-08 23:16:56.452 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-02-08 23:16:56.452 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-08 23:16:56.452 Enabled for exchange2: CME (Trading Account Required) | 2021-02-08 23:16:56.452 Enabled for exchange2: CBOT (Trading Account Required) | 2021-02-08 23:16:56.452 Enabled for exchange2: COMEX (Trading Account Required) | 2021-02-08 23:16:56.452 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-02-08 23:16:56.452 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-08 23:16:56.452 Current selected Data/Trading service: SC Futures Order Routing/Data | 2021-02-08 23:16:56.452 Custom symbol settings values: enabled | 2021-02-08 23:16:56.452 Chart Update Interval: 500 | 2021-02-08 23:16:56.452 Intraday Data Storage Time Unit: 1 | 2021-02-08 23:16:56.452 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-02-08 23:16:56.452 2021-02-09 05:16:56 Local computer time in UTC | 2021-02-08 23:16:56.452 2021-02-08 23:16:56 Local computer time in SC Time Zone | 2021-02-08 23:16:56.452 2021-02-09 05:13:59 Server time in UTC | 2021-02-08 23:16:56.452 Local computer UTC time and Server UTC time difference: 2 seconds. | 2021-02-08 23:16:56.452 Program path: C:\SierraChart\ | 2021-02-08 23:16:56.452 Data Files path: C:\SierraChart\Data\ | 2021-02-08 23:16:56.452 OS Version Number: 10.0 | 2021-02-08 23:16:56.453 Locale Setting: C | 2021-02-08 23:16:56.453 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-02-08 23:16:56.453 Allowed protected custom studies: | 2021-02-08 23:16:56.453 FGBLH21_FUT_Eurex This is the symbol SC requested I try after the history loads, the chart is frozen... no new candles... no delayed data... frozen also tried MESH21_FUT_CME[M] it appears to be working now. this is the one I trade so if it works I'm good. I only have DENALI CME data though AMP |
[2021-02-09 10:15:01] |
For the EUREX, you are not subscribed to EUREX data so that chart will not update in real time. Next week we expect to offer delayed streaming EUREX data if you do not pay the exchange fee.
