Date/Time: Sat, 12 Sep 2026 08:27:40 +0000
Won't connect to Data Feed
View Count: 1126
| [2022-07-13 02:15:52] |
| ambtn723 - Posts: 14 |
Just updated the package, account management shows that the package is update for 90 days, but am getting the service package does not support this function or account is expired error.
| [2022-07-13 04:35:07] |
We see that you changed your Service Package from 5 to 11. We put your service package back to 5 and we gave you a free evaluation of service package 12 for 60 days. You will now be able to connect to external trading services. After that you need to change to Service Package 10 or 11 depending upon whether you were using Service package 3 or 5. Package 10 is equivalent to package 3 and package 11 is equivalent to package 5. Service Package 10 and 11 support connections to external services. For complete details, refer to: Service Package Changes | Discontinued External Services | Reducing Overall Costs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-07-18 14:51:16] |
I have no clue what's happening now. I can't get a live data feed nor my amp account connected. I had CQG web data activated and it was working fine until Friday. Now I switch on to SC Data all Services and am getting a delayed data set even though I am supposedly paying for real data. This is a mess. What do I need to do to continue using your product with amp futures? For that matter, why in the world am I paying what I'm paying for delayed data??? |
| [2022-07-18 14:53:40] |
Set Sierra Chart to use CQG: CQG Trading Platform Service: Setup Instructions Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-07-18 15:35:20] |
I verified that CQG order routing only is enabled. I am getting no data from Sierra/Teton however. Created the DTC Protocol server. | 2022-07-12 23:36:48.990 DTC Protocol Server listening on port 11099. | 2022-07-12 23:36:48.991 Reading Internal Order ID file. | 2022-07-12 23:36:48.992 Reading Trade Orders file. | 2022-07-12 23:36:49.076 Reading Trade Positions file. | 2022-07-12 23:36:49.077 Reading Trade Account Data files. | 2022-07-12 23:36:49.077 UDPListener (1536). Port 22904 | Listening on UDP port 22904. | 2022-07-12 23:36:49.105 Software version: 2348 64-bit | 2022-07-12 23:36:49.106 Primary Thread ID: 17860 | 2022-07-12 23:36:49.106 Usage end date: 2022-10-13 | 2022-07-12 23:36:49.106 Enabled for: Advanced Features 2. | 2022-07-12 23:36:49.106 Enabled for: Sierra Chart Historical Data Service. | 2022-07-12 23:36:49.106 Enabled for: Delayed Denali Exchange Data Feed. | 2022-07-12 23:36:49.106 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-07-12 23:36:49.106 Current selected Data/Trading service: CQG WebAPI | 2022-07-12 23:36:49.106 Custom symbol settings values: enabled | 2022-07-12 23:36:49.106 Chart Update Interval: 500 | 2022-07-12 23:36:49.106 Intraday Data Storage Time Unit: 0 | 2022-07-12 23:36:49.106 Time Zone: +00:00:00 (UTC+00) | 2022-07-12 23:36:49.106 2022-07-12 23:36:49 Local computer time in UTC | 2022-07-12 23:36:49.106 2022-07-12 23:36:49 Local computer time in SC Time Zone | 2022-07-12 23:36:49.106 2022-07-12 23:36:45 Server time in UTC | 2022-07-12 23:36:49.106 Local computer UTC time and Server UTC time difference: 3 seconds. | 2022-07-12 23:36:49.106 Program path: C:\SierraChart\ | 2022-07-12 23:36:49.106 Data Files path: C:\SierraChart\Data\ | 2022-07-12 23:36:49.106 OS Version Number: 10.0 | 2022-07-12 23:36:49.106 Locale Setting: C | 2022-07-12 23:36:49.106 DLLs: OrderFlowLabs.com.beta_64.dll, OrderFlowLabs.com_64.dll, UserContributedStudies_64.dll | 2022-07-12 23:36:49.107 Allowed protected custom studies: OrderFlowLabs.com, OrderFlowLabs.com Beta | 2022-07-12 23:36:49.107 Created the DTC Protocol historical data server. | 2022-07-12 23:36:49.142 HD Server Manager | Listening on port 11098. | 2022-07-12 23:36:49.147 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2022-07-12 23:36:49.147 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-07-12 23:36:49.189 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-07-12 23:36:49.463 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-07-12 23:36:49.463 Received 5 login tokens. | 2022-07-12 23:36:49.737 Symbol settings MD5 received. Request ID: 1. | 2022-07-12 23:36:51.312 Requested symbol settings for service code cqg. Request ID: 2. | 2022-07-12 23:36:51.312 Symbol settings received. Request ID: 2. | 2022-07-12 23:36:53.946 Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2022-07-12 23:36:56.055 * Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2022-07-12 23:37:06.805 * Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2022-07-12 23:38:02.022 * CQG WebSocket socket (0) | CloseSocket call. | 2022-07-12 23:44:17.810 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-12 23:44:17.810 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-12 23:44:17.810 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 3. | 2022-07-12 23:44:17.814 Current selected Data/Trading service: SC Data - All Services | 2022-07-12 23:44:17.814 Symbol settings MD5 received. Request ID: 3. | 2022-07-12 23:44:20.202 Requested symbol settings for service code scdataallservices. Request ID: 4. | 2022-07-12 23:44:20.202 SC Data - All Services | Connected to server complete. | 2022-07-12 23:44:20.898 Triggering next historical data download in queue. | 2022-07-12 23:44:20.898 Triggering next historical data download in queue. | 2022-07-12 23:44:20.898 Triggering next historical data download in queue. | 2022-07-12 23:44:20.898 Triggering next historical data download in queue. | 2022-07-12 23:44:20.898 Subscribing to symbol for symbol alert. F.US.MNQM22 | 2022-07-12 23:44:20.898 Using symbol data fast lookup vector | 2022-07-12 23:44:20.898 SC Data - All Services | Starting real-time market data updates for: F.US.MNQM22. ID: 1 | 2022-07-12 23:44:20.898 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.MNQM22 | 2022-07-12 23:44:20.898 SC Data - All Services | Requesting security definition data for: F.US.MNQM22. ID: 1 | 2022-07-12 23:44:20.898 No download requests in the queue to start downloads for. | 2022-07-12 23:44:20.899 No download requests in the queue to start downloads for. | 2022-07-12 23:44:20.899 No download requests in the queue to start downloads for. | 2022-07-12 23:44:20.899 No download requests in the queue to start downloads for. | 2022-07-12 23:44:20.899 Symbol settings received. Request ID: 4. | 2022-07-12 23:44:23.204 Loading DLL: C:\SierraChart\Data\OrderFlowLabs.com.dll (OrderFlowLabs.com_64.dll). Handle: 7ffa196a0000 | 2022-07-12 23:44:30.956 F.US.ENQU22 [CBV] 750 Volume #1 | Reloading chart. | 2022-07-12 23:44:30.965 F.US.ENQU22 [CBV] 750 Volume #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:30.965 F.US.ENQU22 [CBV] 750 Volume #1 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:30.965 Loading DLL: C:\SierraChart\Data\OrderFlowLabs.com.beta.dll (OrderFlowLabs.com.beta_64.dll). Handle: 7ffa080e0000 | 2022-07-12 23:44:30.972 F.US.ENQU22 [CBV] 750 Volume #26 | Reloading chart. | 2022-07-12 23:44:30.980 F.US.ENQU22 [CBV] 750 Volume #26 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:30.980 F.US.ENQU22 [CBV] 750 Volume #26 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:30.980 F.US.ENQU22 [CBV] 5 Min #6 | Reloading chart. | 2022-07-12 23:44:30.994 F.US.ENQU22 [CBV] 5 Min #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:30.994 F.US.ENQU22 [CBV] 5 Min #6 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:30.994 F.US.ENQU22 [CBV] 1 Min #27 | Reloading chart. | 2022-07-12 23:44:31.007 F.US.ENQU22 [CBV] 1 Min #27 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.007 F.US.ENQU22 [CBV] 1 Min #27 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.007 F.US.ENQU22 [CBV] 1 Day #3 | Reloading chart. | 2022-07-12 23:44:31.027 F.US.ENQU22 [CBV] 1 Day #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.027 F.US.ENQU22 [CBV] 1 Day #3 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.027 F.US.ENQU22 30 Sec #13 | Reloading chart. | 2022-07-12 23:44:31.046 F.US.ENQU22 [CBV] 500 Volume #28 | Reloading chart. | 2022-07-12 23:44:31.062 F.US.ENQU22 [CBV] 500 Volume #28 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.062 F.US.ENQU22 [CBV] 500 Volume #28 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.062 F.US.ENQU22 [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-12 23:44:31.077 F.US.ENQU22 [CBV] 3072 Trades #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.077 F.US.ENQU22 [CBV] 3072 Trades #4 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.077 F.US.ENQU22 [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-12 23:44:31.092 F.US.ENQU22 [CBV] 3072 Trades #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.092 F.US.ENQU22 [CBV] 3072 Trades #11 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.092 F.US.ENQU22 [CBV] 512 Trades #5 | Reloading chart. | 2022-07-12 23:44:31.101 F.US.ENQU22 [CBV] 512 Trades #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.101 F.US.ENQU22 [CBV] 512 Trades #5 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.101 F.US.ENQU22 [CBV] 512 Trades #17 | Reloading chart. | 2022-07-12 23:44:31.116 F.US.ENQU22 [CBV] 512 Trades #17 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.116 F.US.ENQU22 [CBV] 512 Trades #17 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.116 F.US.ENQU22 [CBV] 375 Volume #19 | Reloading chart. | 2022-07-12 23:44:31.127 F.US.ENQU22 [CBV] 375 Volume #19 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.127 F.US.ENQU22 [CBV] 375 Volume #19 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.127 F.US.ENQU22 [CBV] 825 Trades #23 | Reloading chart. | 2022-07-12 23:44:31.144 F.US.ENQU22 [CBV] 825 Trades #23 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.144 F.US.ENQU22 [CBV] 825 Trades #23 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.144 F.US.ENQU22 [CBV] 5 Min #25 | Reloading chart. | 2022-07-12 23:44:31.158 F.US.ENQU22 [CBV] 5 Min #25 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.158 F.US.ENQU22 [CBV] 5 Min #25 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.158 F.US.ENQU22 [CBV] 60 Min #22 | Reloading chart. | 2022-07-12 23:44:31.172 F.US.ENQU22 [CBV] 60 Min #22 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.172 F.US.ENQU22 [CBV] 60 Min #22 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.172 F.US.ENQU22 [CBV] 60 Min #15 | Reloading chart. | 2022-07-12 23:44:31.186 F.US.ENQU22 [CBV] 60 Min #15 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.186 F.US.ENQU22 [CBV] 60 Min #15 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.186 F.US.ENQU22 [CBV] 5 Min #12 | Reloading chart. | 2022-07-12 23:44:31.207 F.US.ENQU22 [CBV] 5 Min #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.207 F.US.ENQU22 [CBV] 5 Min #12 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.207 F.US.ENQU22 [CBV] 15 Min #10 | Reloading chart. | 2022-07-12 23:44:31.232 F.US.ENQU22 [CBV] 15 Min #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.232 F.US.ENQU22 [CBV] 15 Min #10 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.232 F.US.ENQU22 [CBV] 30 Min #2 | Reloading chart. | 2022-07-12 23:44:31.249 F.US.ENQU22 [CBV] 30 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.249 F.US.ENQU22 [CBV] 30 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.249 F.US.ENQU22 [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-12 23:44:31.268 F.US.ENQU22 [CBV] 7500 Volume #20 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.268 F.US.ENQU22 [CBV] 7500 Volume #20 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.268 F.US.ENQU22 [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-12 23:44:31.286 F.US.ENQU22 [CBV] 7500 Volume #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.286 F.US.ENQU22 [CBV] 7500 Volume #7 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.286 F.US.ENQU22 1 Min #18 | Reloading chart. | 2022-07-12 23:44:31.383 F.US.ENQU22 1250 Volume #24 | Reloading chart. | 2022-07-12 23:44:31.398 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-12 23:44:31.438 F.US.ENQU22 [CBV] #16 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.438 F.US.ENQU22 [CBV] #16 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.438 F.US.ENQU22 [CBV] 60 Min #8 | Reloading chart. | 2022-07-12 23:44:31.494 F.US.ENQU22 [CBV] 60 Min #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:31.494 F.US.ENQU22 [CBV] 60 Min #8 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:31.494 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Reloading chart. | 2022-07-12 23:44:35.915 F.US.ENQU22 1 Trades #21 | Reloading chart. | 2022-07-12 23:44:36.330 F.US.ENQU22 [CBV] 240 Min #9 | Reloading chart. | 2022-07-12 23:44:36.350 F.US.ENQU22 [CBV] 240 Min #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:36.350 F.US.ENQU22 [CBV] 240 Min #9 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:36.350 F.US.ENQU22 [CBV] 60 Min #29 | Reloading chart. | 2022-07-12 23:44:36.368 F.US.ENQU22 [CBV] 60 Min #29 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:36.368 F.US.ENQU22 [CBV] 60 Min #29 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:36.368 F.US.ENQU22 [CBV] 15 Min #30 | Reloading chart. | 2022-07-12 23:44:36.393 F.US.ENQU22 [CBV] 15 Min #30 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-07-12 23:44:36.393 F.US.ENQU22 [CBV] 15 Min #30 | There are no continuous futures contract symbols. Loading data normally. | 2022-07-12 23:44:36.393 F.US.ENQU22 1 Trades #21 | StartDateTimeForLoadingOrderFills: 2022-06-28 18:26:55 | 2022-07-12 23:44:37.930 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:44:39.992 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:44:39.992 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:44:39.992 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-28 18:26:55 | 2022-07-12 23:44:40.091 F.US.ENQU22 [CBV-D] 15 Min #30 | StartDateTimeForLoadingOrderFills: 2022-05-24 19:00:00 | 2022-07-12 23:44:41.330 SC Data - All Services | Starting real-time market data updates for: F.US.ENQU22. ID: 2 | 2022-07-12 23:44:41.802 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.ENQU22 | 2022-07-12 23:44:41.802 SC Data - All Services | Requesting security definition data for: F.US.ENQU22. ID: 2 | 2022-07-12 23:44:41.802 No historical data client is currently set to download historical Intraday data for F.US.ENQU22. | 2022-07-12 23:44:41.802 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-12 23:44:41.802 Intraday chart data file opened for F.US.ENQU22 | 2022-07-12 23:44:41.802 F.US.ENQU22 [CBV-D] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:44:41.989 F.US.ENQU22 [CBV-D] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:44:41.996 F.US.ENQU22 [CBV-D] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:44:42.437 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:44:42.441 SC Data - All Services | Starting real-time market data updates for: F.US.MNQU22. ID: 3 | 2022-07-12 23:44:42.459 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.MNQU22 | 2022-07-12 23:44:42.459 SC Data - All Services | Requesting security definition data for: F.US.MNQU22. ID: 3 | 2022-07-12 23:44:42.459 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:44:42.459 Enabling compression for file: C:\SierraChart\Data\NQU22-CME.scid. This may take a while. | 2022-07-12 23:46:49.819 File compression enabled. C:\SierraChart\Data\NQU22-CME.scid. CompressionState=0 | 2022-07-12 23:46:49.819 NQU22-CME [CBV-D] 500 Volume #28 | Reloading chart. | 2022-07-12 23:46:49.820 Starting DelayedDownloadMonitoringTimer | 2022-07-12 23:46:49.821 Starting HDTimeoutTimer | 2022-07-12 23:46:49.821 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-12 23:46:49.821 Triggering next historical data download in queue. | 2022-07-12 23:46:49.821 NQU22-CME [CBV-D] 500 Volume #28 | Performing continuous chart historical Daily data download for symbol NQU22-CME starting at last date in file. | 2022-07-12 23:46:49.825 Starting DelayedDownloadMonitoringTimer | 2022-07-12 23:46:49.825 Starting HDTimeoutTimer | 2022-07-12 23:46:49.825 Added historical Daily data request for NQU22-CME to the queue. | 2022-07-12 23:46:49.825 Triggering next historical data download in queue. | 2022-07-12 23:46:49.825 NQU22-CME [CBV-D] 500 Volume #28 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:49.826 Mapping NQU22-CME to NQU22. Service code: cme | 2022-07-12 23:46:49.859 HD Request # 1 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-12 23:46:49.859 HD Request # 1 | Download start date-time: 2022-06-01 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-12 23:46:49.860 HD Request # 1 | Using server: ds21.sierracharts.com port 10149 | 2022-07-12 23:46:49.860 HD Request # 2 | Downloading Historical Daily chart data for NQU22-CME. Starting date: 1972-07-12. Service: scdataallservices | 2022-07-12 23:46:49.860 Socket (1) | Creating socket. | 2022-07-12 23:46:49.914 Socket (1) | New receive buffer size: 5242880 | 2022-07-12 23:46:49.914 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-07-12 23:46:49.914 HD Request # 1 | Setting DTC encoding to Binary VLS | 2022-07-12 23:46:50.083 HD Request # 1 | Sending historical data logon request message. | 2022-07-12 23:46:50.083 NQU22-CME [CBV-D] 60 Min #22 | Reloading chart. | 2022-07-12 23:46:50.115 Added historical Intraday data request for NQH22-CME to the queue. | 2022-07-12 23:46:50.115 Triggering next historical data download in queue. | 2022-07-12 23:46:50.115 NQU22-CME [CBV-D] 60 Min #22 | Performing continuous chart historical Daily data download for symbol NQH22-CME starting at last date in file. | 2022-07-12 23:46:50.117 Added historical Daily data request for NQH22-CME to the queue. | 2022-07-12 23:46:50.117 Triggering next historical data download in queue. | 2022-07-12 23:46:50.117 Added historical Intraday data request for NQM22-CME to the queue. | 2022-07-12 23:46:50.117 NQU22-CME [CBV-D] 60 Min #22 | Performing continuous chart historical Daily data download for symbol NQM22-CME starting at last date in file. | 2022-07-12 23:46:50.118 Added historical Daily data request for NQM22-CME to the queue. | 2022-07-12 23:46:50.118 NQU22-CME [CBV-D] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, | 2022-07-12 23:46:50.119 NQU22-CME [CBV-D] 60 Min #15 | Reloading chart. | 2022-07-12 23:46:50.122 Added historical Intraday data request for NQU21-CME to the queue. | 2022-07-12 23:46:50.122 Triggering next historical data download in queue. | 2022-07-12 23:46:50.122 NQU22-CME [CBV-D] 60 Min #15 | Performing continuous chart historical Daily data download for symbol NQU21-CME starting at last date in file. | 2022-07-12 23:46:50.123 Added historical Daily data request for NQU21-CME to the queue. | 2022-07-12 23:46:50.123 Triggering next historical data download in queue. | 2022-07-12 23:46:50.123 Added historical Intraday data request for NQZ21-CME to the queue. | 2022-07-12 23:46:50.124 NQU22-CME [CBV-D] 60 Min #15 | Performing continuous chart historical Daily data download for symbol NQZ21-CME starting at last date in file. | 2022-07-12 23:46:50.125 Added historical Daily data request for NQZ21-CME to the queue. | 2022-07-12 23:46:50.125 Enabling compression for file: C:\SierraChart\Data\NQH22-CME.scid. This may take a while. | 2022-07-12 23:46:50.125 File compression enabled. C:\SierraChart\Data\NQH22-CME.scid. CompressionState=0 | 2022-07-12 23:46:50.125 Enabling compression for file: C:\SierraChart\Data\NQM22-CME.scid. This may take a while. | 2022-07-12 23:46:50.126 File compression enabled. C:\SierraChart\Data\NQM22-CME.scid. CompressionState=0 | 2022-07-12 23:46:50.126 NQU22-CME [CBV-D] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, | 2022-07-12 23:46:50.129 NQU22-CME [CBV-D] 5 Min #12 | Reloading chart. | 2022-07-12 23:46:50.130 NQU22-CME [CBV-D] 5 Min #12 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.132 NQU22-CME [CBV-D] 15 Min #10 | Reloading chart. | 2022-07-12 23:46:50.134 NQU22-CME [CBV-D] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.136 NQU22-CME [CBV-D] 30 Min #2 | Reloading chart. | 2022-07-12 23:46:50.138 NQU22-CME [CBV-D] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.139 NQU22-CME/F.US.MNQU22 512 Trades #14 | Reloading chart. | 2022-07-12 23:46:50.143 NQU22-CME/F.US.MNQU22 512 Trades #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22-CME.scid | 2022-07-12 23:46:50.149 NQU22-CME [CBV-D] 7500 Volume #20 | Reloading chart. | 2022-07-12 23:46:50.156 NQU22-CME [CBV-D] 7500 Volume #20 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.157 NQU22-CME [CBV-D] 7500 Volume #7 | Reloading chart. | 2022-07-12 23:46:50.158 NQU22-CME [CBV-D] 7500 Volume #7 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.159 NQU22-CME [CBV-D] 240 Min #9 | Reloading chart. | 2022-07-12 23:46:50.160 NQU22-CME [CBV-D] 240 Min #9 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.161 NQU22-CME [CBV-D] 60 Min #29 | Reloading chart. | 2022-07-12 23:46:50.165 NQU22-CME [CBV-D] 60 Min #29 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.166 NQU22-CME 1 Min #18 | Reloading chart. | 2022-07-12 23:46:50.169 NQU22-CME 1 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22-CME.scid | 2022-07-12 23:46:50.175 NQU22-CME 1 Trades #21 | Reloading chart. | 2022-07-12 23:46:50.199 NQU22-CME 1 Trades #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22-CME.scid | 2022-07-12 23:46:50.205 NQU22-CME 1250 Volume #24 | Reloading chart. | 2022-07-12 23:46:50.206 NQU22-CME 1250 Volume #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22-CME.scid | 2022-07-12 23:46:50.210 NQU22-CME [CBV-D] #16 | Reloading chart. | 2022-07-12 23:46:50.211 NQU22-CME [CBV-D] #16 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.212 NQU22-CME [CBV-D] 750 Volume #1 | Reloading chart. | 2022-07-12 23:46:50.215 NQU22-CME [CBV-D] 750 Volume #1 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.217 NQU22-CME [CBV-D] 750 Volume #26 | Reloading chart. | 2022-07-12 23:46:50.219 NQU22-CME [CBV-D] 750 Volume #26 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.221 NQU22-CME [CBV-D] 5 Min #6 | Reloading chart. | 2022-07-12 23:46:50.223 NQU22-CME [CBV-D] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.223 NQU22-CME [CBV-D] 60 Min #8 | Reloading chart. | 2022-07-12 23:46:50.225 NQU22-CME [CBV-D] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.226 NQU22-CME [CBV-D] 1 Min #27 | Reloading chart. | 2022-07-12 23:46:50.227 NQU22-CME [CBV-D] 1 Min #27 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.227 SC DTC Delayed Exchange Data | Starting real-time market data updates for: NQU22-CME (NQU22). ID: 4 Service code: cme | 2022-07-12 23:46:50.228 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-07-12 23:46:50.228 SC DTC Delayed Exchange Data | Requesting security definition data for: NQU22-CME (NQU22). ID: 4 | 2022-07-12 23:46:50.229 DTC Client socket (3) | Creating socket. | 2022-07-12 23:46:50.229 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-07-12 23:46:50.229 DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2022-07-12 23:46:50.229 NQU22-CME [CBV-D] 1 Day #3 | Reloading chart. | 2022-07-12 23:46:50.232 Enabling compression for file: C:\SierraChart\Data\NQU21-CME.scid. This may take a while. | 2022-07-12 23:46:50.232 File compression enabled. C:\SierraChart\Data\NQU21-CME.scid. CompressionState=0 | 2022-07-12 23:46:50.232 Enabling compression for file: C:\SierraChart\Data\NQZ21-CME.scid. This may take a while. | 2022-07-12 23:46:50.233 File compression enabled. C:\SierraChart\Data\NQZ21-CME.scid. CompressionState=0 | 2022-07-12 23:46:50.233 NQU22-CME [CBV-D] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, | 2022-07-12 23:46:50.236 NQU22-CME 30 Sec #13 | Reloading chart. | 2022-07-12 23:46:50.238 NQU22-CME 30 Sec #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22-CME.scid | 2022-07-12 23:46:50.242 NQU22-CME [CBV-D] 3072 Trades #4 | Reloading chart. | 2022-07-12 23:46:50.243 NQU22-CME [CBV-D] 3072 Trades #4 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.244 NQU22-CME [CBV-D] 3072 Trades #11 | Reloading chart. | 2022-07-12 23:46:50.246 NQU22-CME [CBV-D] 3072 Trades #11 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.247 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-12 23:46:50.252 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-12 23:46:50.252 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-12 23:46:50.252 NQU22-CME [CBV-D] 512 Trades #17 | Reloading chart. | 2022-07-12 23:46:50.253 NQU22-CME [CBV-D] 512 Trades #17 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.254 NQU22-CME [CBV-D] 512 Trades #5 | Reloading chart. | 2022-07-12 23:46:50.255 NQU22-CME [CBV-D] 512 Trades #5 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.256 NQU22-CME [CBV-D] 375 Volume #19 | Reloading chart. | 2022-07-12 23:46:50.257 NQU22-CME [CBV-D] 375 Volume #19 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.258 NQU22-CME [CBV-D] 825 Trades #23 | Reloading chart. | 2022-07-12 23:46:50.261 NQU22-CME [CBV-D] 825 Trades #23 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2022-07-12 23:46:50.262 NQU22-CME [CBV-D] 5 Min #25 | Reloading chart. | 2022-07-12 23:46:50.267 NQU22-CME [CBV-D] 5 Min #25 | Waiting for historical downloads to complete with the IDs: 1, 2, 5, 6, | 2022-07-12 23:46:50.269 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-12 23:46:50.411 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-12 23:46:50.411 HD Request # 1 | Requesting Intraday data. Start date-time: 2022-06-01 00:00:00. Record interval: 0. Symbol: NQU22 | 2022-07-12 23:46:50.617 HD Request # 2 | Requesting historical Daily data for NQU22 starting at 1972-07-11. SC External HD service. | 2022-07-12 23:46:50.635 HD Request # 1 | Decompressing data. | 2022-07-12 23:46:50.640 HD Request # 1 | Receiving Intraday data for NQU22-CME starting at 2022-06-01 00:12:40.124000 | 2022-07-12 23:46:50.871 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-12 23:46:51.023 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-12 23:46:51.023 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-12 23:46:51.023 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-12 23:46:51.023 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-12 23:46:51.023 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-12 23:46:51.023 HD Request # 2 | Receiving historical Daily data for NQU22-CME starting at 2021-06-17 | 2022-07-12 23:46:51.189 HD Request # 2 | Writing historical Daily data to the file NQU22-CME.dly | 2022-07-12 23:46:51.189 HD Request # 2 | Bytes received: 16813 | 2022-07-12 23:46:51.202 HD Request # 2 | Received 269 Daily data records from 2021-06-17 00:00:00 to 2022-07-12 00:00:00 (391.0 days) and wrote 269 records for NQU22-CME | 2022-07-12 23:46:51.202 HD Request # 2 | Completion time: 2s | 2022-07-12 23:46:51.202 HD Request # 2 | Daily data download complete for NQU22-CME. Unique request ID: 2 | 2022-07-12 23:46:51.202 Removing historical data download ID 2. | 2022-07-12 23:46:51.202 Triggering next historical data download in queue. | 2022-07-12 23:46:51.202 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-12 23:46:51.202 Mapping NQH22-CME to NQH22. Service code: cme | 2022-07-12 23:46:51.202 HD Request # 3 | Downloading Historical Daily chart data for NQH22-CME. Starting date: 1972-07-12. Service: scdataallservices | 2022-07-12 23:46:51.203 HD Request # 1 | Timestamp of first Intraday data file record written: 2022-06-01 00:12:40.124000 | 2022-07-12 23:46:51.269 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-05-27 03:26:41 | 2022-07-12 23:46:51.303 NQU22-CME[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 2022-05-27 08:34:37 | 2022-07-12 23:46:51.968 HD Request # 3 | Requesting historical Daily data for NQH22 starting at 1972-07-11. SC External HD service. | 2022-07-12 23:46:53.203 HD Request # 3 | Receiving historical Daily data for NQH22-CME starting at 2020-12-17 | 2022-07-12 23:46:53.465 HD Request # 3 | Writing historical Daily data to the file NQH22-CME.dly | 2022-07-12 23:46:53.465 HD Request # 3 | Bytes received: 19556 | 2022-07-12 23:46:53.478 HD Request # 3 | Received 315 Daily data records from 2020-12-17 00:00:00 to 2022-03-18 00:00:00 (457.0 days) and wrote 315 records for NQH22-CME | 2022-07-12 23:46:53.478 HD Request # 3 | Completion time: 2s | 2022-07-12 23:46:53.478 HD Request # 3 | Daily data download complete for NQH22-CME. Unique request ID: 4 | 2022-07-12 23:46:53.478 Removing historical data download ID 4. | 2022-07-12 23:46:53.478 Triggering next historical data download in queue. | 2022-07-12 23:46:53.478 Mapping NQM22-CME to NQM22. Service code: cme | 2022-07-12 23:46:53.478 HD Request # 4 | Downloading Historical Daily chart data for NQM22-CME. Starting date: 1972-07-12. Service: scdataallservices | 2022-07-12 23:46:53.478 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:46:53.742 Socket (1) | New receive buffer size: 10485760 | 2022-07-12 23:46:55.640 HD Request # 4 | Requesting historical Daily data for NQM22 starting at 1972-07-11. SC External HD service. | 2022-07-12 23:47:00.921 HD Request # 4 | Receiving historical Daily data for NQM22-CME starting at 2021-03-18 | 2022-07-12 23:47:01.221 HD Request # 4 | Writing historical Daily data to the file NQM22-CME.dly | 2022-07-12 23:47:01.221 HD Request # 4 | Bytes received: 19684 | 2022-07-12 23:47:01.233 HD Request # 4 | Received 317 Daily data records from 2021-03-18 00:00:00 to 2022-06-17 00:00:00 (457.0 days) and wrote 317 records for NQM22-CME | 2022-07-12 23:47:01.233 HD Request # 4 | Completion time: 8s | 2022-07-12 23:47:01.233 HD Request # 4 | Daily data download complete for NQM22-CME. Unique request ID: 6 | 2022-07-12 23:47:01.233 Removing historical data download ID 6. | 2022-07-12 23:47:01.233 Triggering next historical data download in queue. | 2022-07-12 23:47:01.233 Mapping NQU21-CME to NQU21. Service code: cme | 2022-07-12 23:47:01.234 HD Request # 5 | Downloading Historical Daily chart data for NQU21-CME. Starting date: 1972-07-12. Service: scdataallservices | 2022-07-12 23:47:01.234 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:47:02.031 HD Request # 5 | Requesting historical Daily data for NQU21 starting at 1972-07-11. SC External HD service. | 2022-07-12 23:47:02.971 Socket (1) | New receive buffer size: 16777216 | 2022-07-12 23:47:04.773 HD Request # 5 | Receiving historical Daily data for NQU21-CME starting at 2020-06-18 | 2022-07-12 23:47:04.841 HD Request # 5 | Writing historical Daily data to the file NQU21-CME.dly | 2022-07-12 23:47:04.841 HD Request # 5 | Bytes received: 19717 | 2022-07-12 23:47:04.853 HD Request # 5 | Received 316 Daily data records from 2020-06-18 00:00:00 to 2021-09-17 00:00:00 (457.0 days) and wrote 316 records for NQU21-CME | 2022-07-12 23:47:04.853 HD Request # 5 | Completion time: 3s | 2022-07-12 23:47:04.854 HD Request # 5 | Daily data download complete for NQU21-CME. Unique request ID: 8 | 2022-07-12 23:47:04.854 Removing historical data download ID 8. | 2022-07-12 23:47:04.854 Triggering next historical data download in queue. | 2022-07-12 23:47:04.854 Mapping NQZ21-CME to NQZ21. Service code: cme | 2022-07-12 23:47:04.854 HD Request # 6 | Downloading Historical Daily chart data for NQZ21-CME. Starting date: 1972-07-12. Service: scdataallservices | 2022-07-12 23:47:04.855 Socket (1) | CloseSocket call. | 2022-07-12 23:47:13.871 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-12 23:47:13.871 Socket (1) | Socket gracefully closed by remote side. | 2022-07-12 23:47:13.890 Socket (1) | Closed. | 2022-07-12 23:47:13.890 Historical data download thread signaled to stop. | 2022-07-12 23:47:27.228 HD Request # 1 | Received 11948730 Intraday data records from 2022-06-01 00:12:40.124000 to 2022-07-12 23:37:11.690000 (42.0 days) and wrote 11948730 records for NQU22-CME | 2022-07-12 23:47:27.229 HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2022-07-12 23:37:11.690000 | 2022-07-12 23:47:27.243 Added 9 Time and Sales records to Intraday data file for NQU22-CME after download. | 2022-07-12 23:47:27.243 HD Request # 1 | Completion time: 38s | 2022-07-12 23:47:27.243 HD Request # 1 | Intraday data download complete for NQU22-CME. Unique request ID: 1 | 2022-07-12 23:47:27.243 Removing historical data download ID 1. | 2022-07-12 23:47:27.243 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-12 23:47:27.243 Intraday chart data file opened for NQU22-CME | 2022-07-12 23:47:27.243 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2022-07-12 23:47:27.243 Triggering next historical data download in queue. | 2022-07-12 23:47:27.243 HD Request # 7 | Downloading Intraday chart data for NQH22-CME to the file NQH22-CME.scid. Service: cme | 2022-07-12 23:47:27.243 HD Request # 7 | Download start date-time: 2021-12-01 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-12 23:47:27.244 HD Request # 7 | Using server: ds23.sierracharts.com port 10150 | 2022-07-12 23:47:27.244 Socket (1) | Creating socket. | 2022-07-12 23:47:27.291 Socket (1) | New receive buffer size: 5242880 | 2022-07-12 23:47:27.291 Socket (1) | Connecting to IP: 216.1.90.130. | 2022-07-12 23:47:27.291 HD Request # 7 | Setting DTC encoding to Binary VLS | 2022-07-12 23:47:27.391 HD Request # 7 | Sending historical data logon request message. | 2022-07-12 23:47:27.391 HD Request # 7 | Requesting Intraday data. Start date-time: 2021-12-01 00:00:00. Record interval: 0. Symbol: NQH22 | 2022-07-12 23:47:27.969 HD Request # 7 | Decompressing data. | 2022-07-12 23:47:27.998 HD Request # 7 | Receiving Intraday data for NQH22-CME starting at 2021-12-01 00:00:22.800000 | 2022-07-12 23:47:28.835 HD Request # 6 | Requesting historical Daily data for NQZ21 starting at 1972-07-11. SC External HD service. | 2022-07-12 23:47:28.880 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 20880 | 2022-07-12 23:47:30.240 HD Request # 7 | Timestamp of first Intraday data file record written: 2021-12-01 00:00:22.800000 | 2022-07-12 23:47:30.256 Socket (1) | New receive buffer size: 10485760 | 2022-07-12 23:47:30.294 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:47:30.349 NQU22-CME [CBV-D] 7500 Volume #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:30.363 NQU22-CME [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-12 23:47:30.368 HD Request # 6 | Receiving historical Daily data for NQZ21-CME starting at 2020-09-17 | 2022-07-12 23:47:31.842 HD Request # 6 | Writing historical Daily data to the file NQZ21-CME.dly | 2022-07-12 23:47:31.842 HD Request # 6 | Bytes received: 19643 | 2022-07-12 23:47:31.854 HD Request # 6 | Received 317 Daily data records from 2020-09-17 00:00:00 to 2021-12-17 00:00:00 (457.0 days) and wrote 317 records for NQZ21-CME | 2022-07-12 23:47:31.854 HD Request # 6 | Completion time: 27s | 2022-07-12 23:47:31.854 HD Request # 6 | Daily data download complete for NQZ21-CME. Unique request ID: 10 | 2022-07-12 23:47:31.854 Removing historical data download ID 10. | 2022-07-12 23:47:31.854 Triggering next historical data download in queue. | 2022-07-12 23:47:31.854 No download requests in the queue to start downloads for. | 2022-07-12 23:47:31.854 NQU22-CME [CBV-D] 825 Trades #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:31.864 NQU22-CME [CBV] 825 Trades #23 | Reloading chart. | 2022-07-12 23:47:31.865 NQU22-CME [CBV-D] 375 Volume #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:31.869 NQU22-CME [CBV] 375 Volume #19 | Reloading chart. | 2022-07-12 23:47:31.869 NQU22-CME [CBV-D] 500 Volume #28 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:31.873 NQU22-CME [CBV] 500 Volume #28 | Reloading chart. | 2022-07-12 23:47:31.877 Socket (1) | New receive buffer size: 16777216 | 2022-07-12 23:47:33.325 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:47:57.281 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:47:57.296 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:47:57.329 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:47:57.348 NQU22-CME [CBV-D] 1 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:57.580 NQU22-CME [CBV] 1 Min #27 | Reloading chart. | 2022-07-12 23:47:57.581 NQU22-CME [CBV-D] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:57.585 NQU22-CME [CBV] 60 Min #8 | Reloading chart. | 2022-07-12 23:47:57.586 NQU22-CME [CBV-D] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:57.591 NQU22-CME [CBV] 5 Min #6 | Reloading chart. | 2022-07-12 23:47:57.593 NQU22-CME [CBV-D] 512 Trades #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:57.603 NQU22-CME [CBV] 512 Trades #5 | Reloading chart. | 2022-07-12 23:47:57.603 NQU22-CME [CBV-D] 512 Trades #17 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:57.610 NQU22-CME [CBV] 512 Trades #17 | Reloading chart. | 2022-07-12 23:47:57.612 NQU22-CME [CBV-D] 3072 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:57.621 NQU22-CME [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-12 23:47:57.622 NQU22-CME [CBV-D] 3072 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:47:57.628 NQU22-CME [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-12 23:47:57.630 NQU22-CME [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-12 23:47:57.754 Enabling compression for file: C:\SierraChart\Data\NQU22-CME.dly. This may take a while. | 2022-07-12 23:47:57.756 File compression enabled. C:\SierraChart\Data\NQU22-CME.dly. CompressionState=0 | 2022-07-12 23:47:57.756 NQU22-CME [CBV] 825 Trades #23 | Reloading chart. | 2022-07-12 23:47:57.994 NQU22-CME [CBV] 500 Volume #28 | Reloading chart. | 2022-07-12 23:47:58.009 NQU22-CME [CBV] 375 Volume #19 | Reloading chart. | 2022-07-12 23:47:58.025 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:27.526 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:27.526 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:27.536 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:27.561 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:27.580 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:27.595 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:27.707 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:27.752 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:27.986 NQU22-CME [CBV] 1 Min #27 | Reloading chart. | 2022-07-12 23:48:28.404 NQU22-CME [CBV] 5 Min #6 | Reloading chart. | 2022-07-12 23:48:28.420 NQU22-CME [CBV] 60 Min #8 | Reloading chart. | 2022-07-12 23:48:28.439 NQU22-CME [CBV] 512 Trades #17 | Reloading chart. | 2022-07-12 23:48:28.455 NQU22-CME [CBV] 512 Trades #5 | Reloading chart. | 2022-07-12 23:48:28.471 NQU22-CME [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-12 23:48:28.490 NQU22-CME [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-12 23:48:28.513 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.085 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.085 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.102 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.110 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.122 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.134 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.165 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.176 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.406 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.409 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:48:48.437 Socket (1) | CloseSocket call. | 2022-07-12 23:48:59.104 Historical data download thread signaled to stop. | 2022-07-12 23:48:59.104 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-12 23:48:59.104 HD Request # 7 | Received 39927099 Intraday data records from 2021-12-01 00:00:22.800000 to 2022-03-18 13:29:57.710000 (107.6 days) and wrote 39927099 records for NQH22-CME | 2022-07-12 23:48:59.104 HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2022-03-18 13:29:57.710000 | 2022-07-12 23:48:59.121 HD Request # 7 | Completion time: 1m 32s | 2022-07-12 23:48:59.121 HD Request # 7 | Intraday data download complete for NQH22-CME. Unique request ID: 3 | 2022-07-12 23:48:59.121 Removing historical data download ID 3. | 2022-07-12 23:48:59.121 Real-time Intraday chart data file updates started for NQH22-CME | 2022-07-12 23:48:59.121 Intraday chart data file opened for NQH22-CME | 2022-07-12 23:48:59.121 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2022-07-12 23:48:59.121 Triggering next historical data download in queue. | 2022-07-12 23:48:59.121 HD Request # 8 | Downloading Intraday chart data for NQM22-CME to the file NQM22-CME.scid. Service: cme | 2022-07-12 23:48:59.121 HD Request # 8 | Download start date-time: 2022-03-02 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-12 23:48:59.122 HD Request # 8 | Using server: ds21.sierracharts.com port 10149 | 2022-07-12 23:48:59.122 Socket (2) | Creating socket. | 2022-07-12 23:48:59.123 Socket (2) | New receive buffer size: 5242880 | 2022-07-12 23:48:59.123 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-07-12 23:48:59.123 Socket (1) | Socket gracefully closed by remote side. | 2022-07-12 23:48:59.248 Socket (1) | Closed. | 2022-07-12 23:48:59.248 HD Request # 8 | Setting DTC encoding to Binary VLS | 2022-07-12 23:48:59.253 HD Request # 8 | Sending historical data logon request message. | 2022-07-12 23:48:59.253 HD Request # 8 | Requesting Intraday data. Start date-time: 2022-03-02 00:00:00. Record interval: 0. Symbol: NQM22 | 2022-07-12 23:48:59.734 HD Request # 8 | Decompressing data. | 2022-07-12 23:48:59.869 HD Request # 8 | Receiving Intraday data for NQM22-CME starting at 2022-03-02 00:05:33.211000 | 2022-07-12 23:48:59.870 HD Request # 8 | Timestamp of first Intraday data file record written: 2022-03-02 00:05:33.211000 | 2022-07-12 23:49:00.344 NQU22-CME/MNQU22-CME [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-12 23:49:01.097 Mapping MNQU22-CME to MNQU22. Service code: cme | 2022-07-12 23:49:01.607 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MNQU22-CME (MNQU22). ID: 9 Service code: cme | 2022-07-12 23:49:01.607 SC DTC Delayed Exchange Data | Requesting security definition data for: MNQU22-CME (MNQU22). ID: 9 | 2022-07-12 23:49:01.607 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-12 23:49:01.924 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:49:01.952 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:49:01.963 Socket (2) | CloseSocket call. | 2022-07-12 23:50:22.170 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-12 23:50:22.170 Historical data download thread signaled to stop. | 2022-07-12 23:50:22.171 HD Request # 8 | Received 38098066 Intraday data records from 2022-03-02 00:05:33.211000 to 2022-06-17 13:29:57.034000 (107.6 days) and wrote 38098066 records for NQM22-CME | 2022-07-12 23:50:22.172 HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2022-06-17 13:29:57.034000 | 2022-07-12 23:50:22.176 HD Request # 8 | Completion time: 1m 23s | 2022-07-12 23:50:22.176 HD Request # 8 | Intraday data download complete for NQM22-CME. Unique request ID: 5 | 2022-07-12 23:50:22.176 Removing historical data download ID 5. | 2022-07-12 23:50:22.176 Real-time Intraday chart data file updates started for NQM22-CME | 2022-07-12 23:50:22.176 Intraday chart data file opened for NQM22-CME | 2022-07-12 23:50:22.176 HD Request # 8 | Enabling Intraday chart updating for symbol. | 2022-07-12 23:50:22.176 Triggering next historical data download in queue. | 2022-07-12 23:50:22.176 HD Request # 9 | Downloading Intraday chart data for NQU21-CME to the file NQU21-CME.scid. Service: cme | 2022-07-12 23:50:22.176 HD Request # 9 | Download start date-time: 2021-06-02 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-12 23:50:22.176 HD Request # 9 | Using server: ds23.sierracharts.com port 10150 | 2022-07-12 23:50:22.176 Socket (1) | Creating socket. | 2022-07-12 23:50:22.176 Socket (1) | New receive buffer size: 5242880 | 2022-07-12 23:50:22.176 Socket (1) | Connecting to IP: 216.1.90.130. | 2022-07-12 23:50:22.176 Socket (2) | Socket gracefully closed by remote side. | 2022-07-12 23:50:22.192 Socket (2) | Closed. | 2022-07-12 23:50:22.192 HD Request # 9 | Setting DTC encoding to Binary VLS | 2022-07-12 23:50:22.241 HD Request # 9 | Sending historical data logon request message. | 2022-07-12 23:50:22.241 NQU22-CME [CBV-D] 60 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.245 NQU22-CME [CBV] 60 Min #22 | Reloading chart. | 2022-07-12 23:50:22.245 Enabling compression for file: C:\SierraChart\Data\NQH22-CME.dly. This may take a while. | 2022-07-12 23:50:22.264 File compression enabled. C:\SierraChart\Data\NQH22-CME.dly. CompressionState=0 | 2022-07-12 23:50:22.264 Enabling compression for file: C:\SierraChart\Data\NQM22-CME.dly. This may take a while. | 2022-07-12 23:50:22.269 File compression enabled. C:\SierraChart\Data\NQM22-CME.dly. CompressionState=0 | 2022-07-12 23:50:22.269 NQU22-CME [CBV-D] 5 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.282 NQU22-CME [CBV] 5 Min #12 | Reloading chart. | 2022-07-12 23:50:22.286 NQU22-CME [CBV-D] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.344 NQU22-CME [CBV] 30 Min #2 | Reloading chart. | 2022-07-12 23:50:22.344 NQU22-CME [CBV-D] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.360 NQU22-CME [CBV] 15 Min #10 | Reloading chart. | 2022-07-12 23:50:22.365 NQU22-CME [CBV-D] 240 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.380 NQU22-CME [CBV] 240 Min #9 | Reloading chart. | 2022-07-12 23:50:22.384 NQU22-CME [CBV-D] 7500 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.410 NQU22-CME [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-12 23:50:22.417 NQU22-CME [CBV-D] 60 Min #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.448 NQU22-CME [CBV] 60 Min #29 | Reloading chart. | 2022-07-12 23:50:22.449 NQU22-CME [CBV-D] 750 Volume #26 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.513 NQU22-CME [CBV] 750 Volume #26 | Reloading chart. | 2022-07-12 23:50:22.516 NQU22-CME [CBV-D] 750 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.542 NQU22-CME [CBV] 750 Volume #1 | Reloading chart. | 2022-07-12 23:50:22.559 NQU22-CME [CBV-D] #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:22.583 NQU22-CME [CBV] #16 | Reloading chart. | 2022-07-12 23:50:22.585 HD Request # 9 | Requesting Intraday data. Start date-time: 2021-06-02 00:00:00. Record interval: 0. Symbol: NQU21 | 2022-07-12 23:50:22.787 HD Request # 9 | Decompressing data. | 2022-07-12 23:50:22.818 HD Request # 9 | Receiving Intraday data for NQU21-CME starting at 2021-06-02 00:06:01.937000 | 2022-07-12 23:50:23.059 NQU22-CME [CBV-D] 5 Min #25 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:50:23.202 NQU22-CME [CBV] 5 Min #25 | Reloading chart. | 2022-07-12 23:50:23.203 HD Request # 9 | Timestamp of first Intraday data file record written: 2021-06-02 00:06:01.937000 | 2022-07-12 23:50:23.224 NQU22-CME [CBV] 60 Min #22 | Reloading chart. | 2022-07-12 23:50:23.783 NQU22-CME [CBV] 5 Min #12 | Reloading chart. | 2022-07-12 23:50:24.114 NQU22-CME [CBV] 30 Min #2 | Reloading chart. | 2022-07-12 23:50:24.335 NQU22-CME [CBV] 15 Min #10 | Reloading chart. | 2022-07-12 23:50:24.424 NQU22-CME [CBV] 240 Min #9 | Reloading chart. | 2022-07-12 23:50:24.474 NQU22-CME [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-12 23:50:24.868 NQU22-CME [CBV] 60 Min #29 | Reloading chart. | 2022-07-12 23:50:24.916 NQU22-CME [CBV] 750 Volume #26 | Reloading chart. | 2022-07-12 23:50:24.971 NQU22-CME [CBV] 750 Volume #1 | Reloading chart. | 2022-07-12 23:50:25.137 NQU22-CME [CBV] #16 | Reloading chart. | 2022-07-12 23:50:25.185 NQU22-CME [CBV] 5 Min #25 | Reloading chart. | 2022-07-12 23:50:26.909 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:27.503 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:42.745 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:42.745 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:42.745 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:42.745 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:47.200 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:47.792 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:48.440 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:48.443 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:50:48.535 Socket (1) | CloseSocket call. | 2022-07-12 23:51:17.712 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-12 23:51:17.712 Historical data download thread signaled to stop. | 2022-07-12 23:51:17.724 HD Request # 9 | Received 26847635 Intraday data records from 2021-06-02 00:06:01.937000 to 2021-09-17 13:29:59.967000 (107.6 days) and wrote 26847635 records for NQU21-CME | 2022-07-12 23:51:17.725 HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2021-09-17 13:29:59.967000 | 2022-07-12 23:51:17.730 HD Request # 9 | Completion time: 55s | 2022-07-12 23:51:17.730 HD Request # 9 | Intraday data download complete for NQU21-CME. Unique request ID: 7 | 2022-07-12 23:51:17.730 Removing historical data download ID 7. | 2022-07-12 23:51:17.730 Real-time Intraday chart data file updates started for NQU21-CME | 2022-07-12 23:51:17.730 Intraday chart data file opened for NQU21-CME | 2022-07-12 23:51:17.730 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2022-07-12 23:51:17.730 Triggering next historical data download in queue. | 2022-07-12 23:51:17.730 HD Request # 10 | Downloading Intraday chart data for NQZ21-CME to the file NQZ21-CME.scid. Service: cme | 2022-07-12 23:51:17.730 HD Request # 10 | Download start date-time: 2021-09-01 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-12 23:51:17.730 HD Request # 10 | Using server: ds21.sierracharts.com port 10149 | 2022-07-12 23:51:17.730 Socket (2) | Creating socket. | 2022-07-12 23:51:17.731 Socket (2) | New receive buffer size: 5242880 | 2022-07-12 23:51:17.731 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-07-12 23:51:17.731 Socket (1) | Socket gracefully closed by remote side. | 2022-07-12 23:51:17.747 Socket (1) | Closed. | 2022-07-12 23:51:17.747 HD Request # 10 | Setting DTC encoding to Binary VLS | 2022-07-12 23:51:17.783 HD Request # 10 | Sending historical data logon request message. | 2022-07-12 23:51:17.783 HD Request # 10 | Requesting Intraday data. Start date-time: 2021-09-01 00:00:00. Record interval: 0. Symbol: NQZ21 | 2022-07-12 23:51:18.289 HD Request # 10 | Decompressing data. | 2022-07-12 23:51:18.310 HD Request # 10 | Receiving Intraday data for NQZ21-CME starting at 2021-09-01 00:12:56.887000 | 2022-07-12 23:51:18.427 HD Request # 10 | Timestamp of first Intraday data file record written: 2021-09-01 00:12:56.887000 | 2022-07-12 23:51:18.606 Socket (2) | CloseSocket call. | 2022-07-12 23:52:24.316 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-12 23:52:24.316 Socket (2) | Socket gracefully closed by remote side. | 2022-07-12 23:52:24.339 Socket (2) | Closed. | 2022-07-12 23:52:24.339 Historical data download thread signaled to stop. | 2022-07-12 23:52:24.360 HD Request # 10 | Received 33740009 Intraday data records from 2021-09-01 00:12:56.887000 to 2021-12-17 14:29:56.869000 (107.6 days) and wrote 33740009 records for NQZ21-CME | 2022-07-12 23:52:24.360 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2021-12-17 14:29:56.869000 | 2022-07-12 23:52:24.364 HD Request # 10 | Completion time: 1m 7s | 2022-07-12 23:52:24.364 HD Request # 10 | Intraday data download complete for NQZ21-CME. Unique request ID: 9 | 2022-07-12 23:52:24.364 Removing historical data download ID 9. | 2022-07-12 23:52:24.364 Real-time Intraday chart data file updates started for NQZ21-CME | 2022-07-12 23:52:24.364 Intraday chart data file opened for NQZ21-CME | 2022-07-12 23:52:24.364 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2022-07-12 23:52:24.364 Triggering next historical data download in queue. | 2022-07-12 23:52:24.364 No download requests in the queue to start downloads for. | 2022-07-12 23:52:24.364 NQU22-CME [CBV-D] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:52:24.399 NQU22-CME [CBV] 60 Min #15 | Reloading chart. | 2022-07-12 23:52:24.400 Enabling compression for file: C:\SierraChart\Data\NQU21-CME.dly. This may take a while. | 2022-07-12 23:52:24.426 File compression enabled. C:\SierraChart\Data\NQU21-CME.dly. CompressionState=0 | 2022-07-12 23:52:24.426 Enabling compression for file: C:\SierraChart\Data\NQZ21-CME.dly. This may take a while. | 2022-07-12 23:52:24.431 File compression enabled. C:\SierraChart\Data\NQZ21-CME.dly. CompressionState=0 | 2022-07-12 23:52:24.431 NQU22-CME [CBV-D] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-12 23:52:24.512 NQU22-CME [CBV] 1 Day #3 | Reloading chart. | 2022-07-12 23:52:24.513 NQU22-CME [CBV] 60 Min #15 | Reloading chart. | 2022-07-12 23:52:24.924 NQU22-CME [CBV] 1 Day #3 | Reloading chart. | 2022-07-12 23:52:25.148 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:52:42.987 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-12 23:52:46.086 NQU22-CME [CBV][M] #16 | Reloading chart. | 2022-07-13 00:00:18.731 NQU22-CME [CBV][M] #16 | Reloading chart. | 2022-07-13 00:01:06.999 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-05-31 19:12:40 | 2022-07-13 00:02:55.024 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-05-31 19:12:40 | 2022-07-13 00:02:55.797 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-05-31 19:12:40 | 2022-07-13 00:44:38.097 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-05-31 19:12:40 | 2022-07-13 00:44:40.166 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-13 00:45:14.046 NQU22-CME[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-13 00:45:14.559 F.US.ENQU22 [CBV-D] 15 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-13 00:46:31.231 Sierra Chart account data changed. Requesting updated account information. | 2022-07-13 01:06:49.132 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-13 01:06:52.057 DTC Client socket (3) | CloseSocket call. | 2022-07-13 01:06:52.057 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-13 01:06:52.057 SC Data - All Services | Disconnected. | 2022-07-13 01:06:52.057 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-13 01:06:52.057 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-13 01:06:52.057 SC Data - All Services | Disconnected. | 2022-07-13 01:06:52.057 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-13 01:06:52.057 Successfully processed Sierra Chart account data. | 2022-07-13 01:06:52.057 SC Data - All Services | Connected to server complete. | 2022-07-13 01:06:54.069 Triggering next historical data download in queue. | 2022-07-13 01:06:54.070 Triggering next historical data download in queue. | 2022-07-13 01:06:54.070 Triggering next historical data download in queue. | 2022-07-13 01:06:54.070 Triggering next historical data download in queue. | 2022-07-13 01:06:54.070 Subscribing to symbol for symbol alert. F.US.MNQM22 | 2022-07-13 01:06:54.070 Using symbol data fast lookup vector | 2022-07-13 01:06:54.070 SC Data - All Services | Starting real-time market data updates for: F.US.MNQM22. ID: 1 | 2022-07-13 01:06:54.070 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.MNQM22 | 2022-07-13 01:06:54.070 SC Data - All Services | Requesting security definition data for: F.US.MNQM22. ID: 1 | 2022-07-13 01:06:54.070 No download requests in the queue to start downloads for. | 2022-07-13 01:06:54.074 No download requests in the queue to start downloads for. | 2022-07-13 01:06:54.074 No download requests in the queue to start downloads for. | 2022-07-13 01:06:54.074 No download requests in the queue to start downloads for. | 2022-07-13 01:06:54.074 Mapping NQU22-CME to NQU22. Service code: cme | 2022-07-13 01:06:54.099 SC DTC Delayed Exchange Data | Starting real-time market data updates for: NQU22-CME (NQU22). ID: 2 Service code: cme | 2022-07-13 01:06:54.099 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-07-13 01:06:54.099 SC DTC Delayed Exchange Data | Requesting security definition data for: NQU22-CME (NQU22). ID: 2 | 2022-07-13 01:06:54.099 SC Data - All Services | Starting real-time market data updates for: F.US.MNQU22. ID: 3 | 2022-07-13 01:06:54.099 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.MNQU22 | 2022-07-13 01:06:54.099 SC Data - All Services | Requesting security definition data for: F.US.MNQU22. ID: 3 | 2022-07-13 01:06:54.099 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-13 01:06:54.099 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-13 01:06:54.099 Triggering next historical data download in queue. | 2022-07-13 01:06:54.099 Delaying start of download for NQU22-CME | 2022-07-13 01:06:54.100 DTC Client socket (1) | Creating socket. | 2022-07-13 01:06:54.168 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-13 01:06:54.168 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2022-07-13 01:06:54.168 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-13 01:06:54.201 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-13 01:06:54.201 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-13 01:06:54.201 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-13 01:06:54.264 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-13 01:06:54.264 Mapping MNQU22-CME to MNQU22. Service code: cme | 2022-07-13 01:06:54.472 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MNQU22-CME (MNQU22). ID: 4 Service code: cme | 2022-07-13 01:06:54.472 SC DTC Delayed Exchange Data | Requesting security definition data for: MNQU22-CME (MNQU22). ID: 4 | 2022-07-13 01:06:54.472 SC Data - All Services | Starting real-time market data updates for: F.US.ENQU22. ID: 5 | 2022-07-13 01:06:54.475 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.ENQU22 | 2022-07-13 01:06:54.475 SC Data - All Services | Requesting security definition data for: F.US.ENQU22. ID: 5 | 2022-07-13 01:06:54.475 No historical data client is currently set to download historical Intraday data for F.US.ENQU22. | 2022-07-13 01:06:54.475 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-13 01:06:54.475 Intraday chart data file opened for F.US.ENQU22 | 2022-07-13 01:06:54.475 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-13 01:06:54.924 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-13 01:06:54.924 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-13 01:06:54.924 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-13 01:06:54.924 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-13 01:06:54.924 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-13 01:06:54.924 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-13 01:06:54.924 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-13 01:06:55.050 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-13 01:06:55.050 HD Request # 11 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-13 01:07:00.793 HD Request # 11 | Download start date-time: 2022-07-13 00:56:37.000000. File last date-time: 2022-07-13 00:56:37.429002 | 2022-07-13 01:07:00.794 HD Request # 11 | Using server: ds23.sierracharts.com port 10150 | 2022-07-13 01:07:00.794 Socket (2) | Creating socket. | 2022-07-13 01:07:00.795 Socket (2) | New receive buffer size: 5242880 | 2022-07-13 01:07:00.795 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-07-13 01:07:00.795 HD Request # 11 | Setting DTC encoding to Binary VLS | 2022-07-13 01:07:00.863 HD Request # 11 | Sending historical data logon request message. | 2022-07-13 01:07:00.863 HD Request # 11 | Requesting Intraday data. Start date-time: 2022-07-13 00:56:37. Record interval: 0. Symbol: NQU22 | 2022-07-13 01:07:01.446 HD Request # 11 | Decompressing data. | 2022-07-13 01:07:01.485 HD Request # 11 | Receiving Intraday data for NQU22-CME starting at 2022-07-13 00:56:37.429000 | 2022-07-13 01:07:01.486 Socket (2) | CloseSocket call. | 2022-07-13 01:07:01.486 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-13 01:07:01.487 Historical data download thread signaled to stop. | 2022-07-13 01:07:01.491 HD Request # 11 | Timestamp of first Intraday data file record written: 2022-07-13 00:56:43.740000 | 2022-07-13 01:07:01.491 HD Request # 11 | Received 17 Intraday data records from 2022-07-13 00:56:37.429000 to 2022-07-13 00:56:56.885000 (19.5 seconds) and wrote 14 records for NQU22-CME | 2022-07-13 01:07:01.491 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2022-07-13 00:56:56.885000 | 2022-07-13 01:07:01.496 HD Request # 11 | Completion time: 1s | 2022-07-13 01:07:01.496 HD Request # 11 | Intraday data download complete for NQU22-CME. Unique request ID: 11 | 2022-07-13 01:07:01.496 Removing historical data download ID 11. | 2022-07-13 01:07:01.496 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-13 01:07:01.496 Intraday chart data file opened for NQU22-CME | 2022-07-13 01:07:01.496 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2022-07-13 01:07:01.496 Triggering next historical data download in queue. | 2022-07-13 01:07:01.496 No download requests in the queue to start downloads for. | 2022-07-13 01:07:01.496 Socket (2) | Socket gracefully closed by remote side. | 2022-07-13 01:07:01.514 Socket (2) | Closed. | 2022-07-13 01:07:01.514 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:01.786 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:01.795 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.151 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.151 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.151 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.151 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.159 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.166 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.193 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.210 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.226 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.226 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.231 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.237 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.240 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.252 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.380 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.386 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.389 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.393 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.395 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.398 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.967 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.967 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:02.984 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:03.314 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:03.513 NQU22-CME/F.US.MNQU22[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:03.588 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 23556 | 2022-07-13 01:07:04.099 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-13 01:07:13.520 DTC Client socket (1) | CloseSocket call. | 2022-07-13 01:07:13.520 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-13 01:07:13.520 SC Data - All Services | Disconnected. | 2022-07-13 01:07:13.520 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-13 01:07:13.521 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-13 01:07:13.564 DTC Client socket (1) | Closed. | 2022-07-13 01:07:13.564 SC Data - All Services | Disconnected. | 2022-07-13 01:07:13.586 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 5. | 2022-07-13 01:07:13.590 Current selected Data/Trading service: CQG WebAPI | 2022-07-13 01:07:13.590 Symbol settings MD5 received. Request ID: 5. | 2022-07-13 01:07:15.674 Requested symbol settings for service code cqg. Request ID: 6. | 2022-07-13 01:07:15.675 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-13 01:07:17.208 F.US.ENQU22/F.US.MNQU22[M] 512 Trades #14 | Reloading chart. | 2022-07-13 01:07:17.268 F.US.ENQU22 [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-13 01:07:17.501 F.US.ENQU22 [CBV][M] 60 Min #29 | Performing continuous chart historical Daily data download for symbol F.US.ENQU22 starting at last date in file. | 2022-07-13 01:07:17.505 Added historical Daily data request for F.US.ENQU22 to the queue. | 2022-07-13 01:07:17.506 Triggering next historical data download in queue. | 2022-07-13 01:07:17.506 F.US.ENQU22 [CBV][M] 60 Min #29 | Waiting for historical downloads to complete with the IDs: 12, | 2022-07-13 01:07:17.532 HD Request # 12 | Downloading Historical Daily chart data for F.US.ENQU22. Starting date: 2022-07-06. Service: cqg | 2022-07-13 01:07:17.534 F.US.ENQU22 [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-13 01:07:17.537 CQG WebAPI | Using primary service for historical data for F.US.ENQH22 | 2022-07-13 01:07:17.538 Starting DelayedDownloadMonitoringTimer | 2022-07-13 01:07:17.539 Starting HDTimeoutTimer | 2022-07-13 01:07:17.539 Added historical Intraday data request for F.US.ENQH22 to the queue. | 2022-07-13 01:07:17.539 Triggering next historical data download in queue. | 2022-07-13 01:07:17.539 F.US.ENQU22 [CBV][M] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 12, 13, | 2022-07-13 01:07:17.579 F.US.ENQU22 [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-13 01:07:17.592 CQG WebAPI | Using primary service for historical data for F.US.ENQZ21 | 2022-07-13 01:07:17.594 Added historical Intraday data request for F.US.ENQZ21 to the queue. | 2022-07-13 01:07:17.594 Triggering next historical data download in queue. | 2022-07-13 01:07:17.594 F.US.ENQU22 [CBV][M] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 12, 13, 14, | 2022-07-13 01:07:17.647 F.US.ENQU22 [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-13 01:07:17.661 F.US.ENQU22 [CBV][M] 1 Min #27 | Waiting for historical downloads to complete with the IDs: 12, | 2022-07-13 01:07:17.665 F.US.ENQU22 [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-13 01:07:17.726 F.US.ENQU22 [CBV][M] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 12, | 2022-07-13 01:07:17.731 F.US.ENQU22 [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-13 01:07:17.744 F.US.ENQU22 [CBV][M] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 12, | 2022-07-13 01:07:17.747 F.US.ENQU22 [CBV][M] 512 Trades #17 | Reloading chart. | 2022-07-13 01:07:17.754 F.US.ENQU22 [CBV][M] 512 Trades #17 | Waiting for historical downloads to complete with the IDs: 12, | 2022-07-13 01:07:17.772 F.US.ENQU22 [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-13 01:07:17.773 F.US.ENQU22 [CBV][M] 240 Min #9 | Waiting for historical downloads to complete with the IDs: 12, | 2022-07-13 01:07:17.789 F.US.ENQU22 [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-13 01:07:17.800 F.US.ENQU22 [CBV][M] 750 Volume #26 | Waiting for historical downloads to complete with the IDs: 12, | 2022-07-13 01:07:17.831 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-13 01:07:17.842 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Waiting for historical downloads to complete with the IDs: 12, | 2022-07-13 01:07:17.858 F.US.ENQU22[M] 1250 Volume #24 | Reloading chart. | 2022-07-13 01:07:17.867 F.US.ENQU22[M] 1 Trades #21 | Reloading chart. | 2022-07-13 01:07:18.941 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-13 01:07:18.949 HD Request # 12 | Requesting historical Daily data for NQU22 starting at 2022-07-05. SC External HD service. | 2022-07-13 01:07:18.980 Symbol settings received. Request ID: 6. | 2022-07-13 01:07:19.061 F.US.ENQU22[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-13 01:07:19.191 HD Request # 12 | Receiving historical Daily data for F.US.ENQU22 starting at 2022-07-06 | 2022-07-13 01:07:20.818 HD Request # 12 | Writing historical Daily data to the file F.US.ENQU22.dly | 2022-07-13 01:07:20.818 HD Request # 12 | Bytes received: 374 | 2022-07-13 01:07:20.819 HD Request # 12 | Received 6 Daily data records from 2022-07-06 00:00:00 to 2022-07-12 00:00:00 (7.0 days) and wrote 5 records for F.US.ENQU22 | 2022-07-13 01:07:20.819 HD Request # 12 | Completion time: 3s | 2022-07-13 01:07:20.819 HD Request # 12 | Daily data download complete for F.US.ENQU22. Unique request ID: 12 | 2022-07-13 01:07:20.819 Removing historical data download ID 12. | 2022-07-13 01:07:20.819 Triggering next historical data download in queue. | 2022-07-13 01:07:20.819 No download requests in the queue to start downloads for. | 2022-07-13 01:07:20.820 F.US.ENQU22 [CBV][M] #16 | Reloading chart. | 2022-07-13 01:07:20.823 F.US.ENQU22 [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-13 01:07:20.882 F.US.ENQU22 [CBV][M] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 13, 14, | 2022-07-13 01:07:20.936 F.US.ENQU22 [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-13 01:07:20.937 F.US.ENQU22 [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-13 01:07:20.948 F.US.ENQU22 [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-13 01:07:20.959 F.US.ENQU22 [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-13 01:07:20.975 F.US.ENQU22[M] 1 Min #18 | Reloading chart. | 2022-07-13 01:07:21.188 F.US.ENQU22 [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-13 01:07:21.261 F.US.ENQU22[M] 30 Sec #13 | Reloading chart. | 2022-07-13 01:07:21.470 F.US.ENQU22 [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-13 01:07:21.502 F.US.ENQU22 [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-13 01:07:21.534 F.US.ENQU22 [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-13 01:07:21.667 F.US.ENQU22 [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-13 01:07:21.797 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:21.982 F.US.ENQU22 [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-13 01:07:21.988 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:22.062 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:22.132 F.US.ENQU22 [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-13 01:07:22.223 F.US.ENQU22[M]/F.US.MNQU22 [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-13 01:07:22.278 F.US.ENQU22 [CBV][M] 60 Min #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:22.410 F.US.ENQU22 [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-13 01:07:22.444 F.US.ENQU22 [CBV][M] 1 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:22.473 F.US.ENQU22 [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-13 01:07:22.475 F.US.ENQU22 [CBV][M] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:22.483 F.US.ENQU22 [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-13 01:07:22.485 F.US.ENQU22 [CBV][M] 512 Trades #17 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:22.496 F.US.ENQU22 [CBV][M] 512 Trades #17 | Reloading chart. | 2022-07-13 01:07:22.592 F.US.ENQU22 [CBV][M] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:22.599 F.US.ENQU22 [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-13 01:07:22.599 F.US.ENQU22 [CBV][M] 240 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:22.626 F.US.ENQU22 [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-13 01:07:22.663 F.US.ENQU22 [CBV][M] 750 Volume #26 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:22.694 F.US.ENQU22 [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-13 01:07:22.694 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:22.738 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-13 01:07:22.738 CQG WebAPI | Connecting to server api.cqg.com | 2022-07-13 01:07:22.852 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-07-13 01:07:22.852 CQG WebSocket socket (5) | Creating socket. Using TLS 1.2. | 2022-07-13 01:07:22.999 CQG WebSocket socket (5) | New receive buffer size: 5242880 | 2022-07-13 01:07:22.999 CQG WebSocket socket (5) | Connecting to IP: 208.48.16.35. | 2022-07-13 01:07:22.999 CQG WebSocket | Opening WebSocket. | 2022-07-13 01:07:23.031 CQG WebSocket | Sending WebSocket handshake. | 2022-07-13 01:07:23.031 F.US.ENQU22 [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-13 01:07:23.048 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-07-13 01:07:23.353 CQG WebSocket | Server header | Connection: upgrade | 2022-07-13 01:07:23.353 CQG WebSocket | Server header | Sec-WebSocket-Accept: kOpx/H2ScDKyFuvH0kP/noNHOdc= | 2022-07-13 01:07:23.353 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-07-13 01:07:23.353 CQG WebSocket | Server header | Upgrade: websocket | 2022-07-13 01:07:23.353 CQG WebSocket | Server header | | 2022-07-13 01:07:23.353 CQG WebSocket | Web socket state is now open. | 2022-07-13 01:07:23.353 CQG WebAPI | WebSocket connected. | 2022-07-13 01:07:23.354 CQG WebAPI | Sending market data logon message. | 2022-07-13 01:07:23.354 CQG WebAPI | Base Time: 2022-06-18T07:21:14. 2022-06-18 07:21:14 | 2022-07-13 01:07:23.537 CQG WebAPI | Logon successful. Session Token = e6wKZiLMIVC0suuwlum7bWYQb9I5VXGok25E3CUQKCISkBm7DuS2tUpvOXmDP37LDgHDlAg0zbp | 2022-07-13 01:07:23.537 CQG WebAPI | Connected to server complete. | 2022-07-13 01:07:23.537 Triggering next historical data download in queue. | 2022-07-13 01:07:23.617 Triggering next historical data download in queue. | 2022-07-13 01:07:23.617 Triggering next historical data download in queue. | 2022-07-13 01:07:23.617 Triggering next historical data download in queue. | 2022-07-13 01:07:23.617 Subscribing to symbol for symbol alert. F.US.MNQM22 | 2022-07-13 01:07:23.617 Using symbol data fast lookup vector | 2022-07-13 01:07:23.617 CQG WebAPI | Starting real-time market data updates for: F.US.MNQM22. ID: 1 Service code: cqg | 2022-07-13 01:07:23.617 CQG WebAPI | Sending symbol resolution request for F.US.MNQM22. ID: 764517 | 2022-07-13 01:07:23.620 CQG WebAPI | Requesting security definition data for: F.US.MNQM22. ID: 1 | 2022-07-13 01:07:23.648 Updated verified funded futures trading account ending date to: 2022-08-12 01:07:23 | 2022-07-13 01:07:23.648 CQG WebAPI | Sending Trade Accounts request message. | 2022-07-13 01:07:23.649 HD Request # 13 | Downloading Intraday chart data for F.US.ENQH22 to the file F.US.ENQH22.scid. Service: cqg | 2022-07-13 01:07:23.652 HD Request # 13 | Performing multistage download. Downloading Minute data first. | 2022-07-13 01:07:23.653 HD Request # 13 | Download start date-time: 2022-03-14 06:00:39.000000. File last date-time: 2022-03-14 06:00:39.748001 | 2022-07-13 01:07:23.653 HD Request # 13 | Disabling Intraday chart updating for symbol. | 2022-07-13 01:07:23.653 CQG WebAPI | Sending symbol resolution request for F.US.ENQH22. ID: 764519 | 2022-07-13 01:07:23.653 No download requests in the queue to start downloads for. | 2022-07-13 01:07:23.653 No download requests in the queue to start downloads for. | 2022-07-13 01:07:23.653 No download requests in the queue to start downloads for. | 2022-07-13 01:07:23.653 F.US.ENQU22 [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-13 01:07:23.654 CQG WebAPI | Starting real-time market data updates for: F.US.ENQU22. ID: 3 Service code: cqg | 2022-07-13 01:07:23.669 CQG WebAPI | Sending symbol resolution request for F.US.ENQU22. ID: 764520 | 2022-07-13 01:07:23.669 CQG WebAPI | Requesting security definition data for: F.US.ENQU22. ID: 3 | 2022-07-13 01:07:23.669 CQG WebAPI | Using primary service for historical data for F.US.ENQU22 | 2022-07-13 01:07:23.669 Added historical Intraday data request for F.US.ENQU22 to the queue. | 2022-07-13 01:07:23.669 Intraday data recording state for symbol F.US.ENQU22 is set to download 'Pending'. | 2022-07-13 01:07:23.669 Triggering next historical data download in queue. | 2022-07-13 01:07:23.669 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQM22. Search Symbol: F.US.MNQM22. Request ID: 764517. Contract ID: 1. | 2022-07-13 01:07:23.692 CQG WebAPI | Requesting market data for F.US.MNQM22 | 2022-07-13 01:07:23.692 CQG WebAPI | Received message: Requested symbol was not found. | 2022-07-13 01:07:23.693 HD Request # 13 | Error downloading historical Intraday data for F.US.ENQH22. Requested symbol was not found. | 2022-07-13 01:07:23.693 HD Request # 13 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQH22 | 2022-07-13 01:07:23.693 HD Request # 13 | Completion time: 0s | 2022-07-13 01:07:23.701 HD Request # 13 | Intraday data download complete for F.US.ENQH22. Unique request ID: 13 | 2022-07-13 01:07:23.701 Added historical Intraday data request for F.US.ENQH22 to the queue. | 2022-07-13 01:07:23.701 Triggering next historical data download in queue. | 2022-07-13 01:07:23.701 Symbol Error - F.US.ENQH22 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2022-07-13 01:07:23.703 CQG WebAPI | Brokerage name: AMP3. Account Name: 131836 | 2022-07-13 01:07:23.703 Updated verified funded futures trading account ending date to: 2022-08-12 01:07:23 | 2022-07-13 01:07:23.703 CQG WebAPI | Sending collateral subscribe request. | 2022-07-13 01:07:23.703 HD Request # 14 | Downloading Intraday chart data for F.US.ENQH22 to the file F.US.ENQH22.scid. Service: cqg | 2022-07-13 01:07:23.705 HD Request # 14 | Rounding start date-time down to the minute: 2022-03-14 06:00:00.000 | 2022-07-13 01:07:23.705 HD Request # 14 | Download start date-time: 2022-03-14 06:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-13 01:07:23.705 HD Request # 14 | Error downloading historical Intraday data for F.US.ENQH22. The symbol is unknown to the server. | 2022-07-13 01:07:23.705 HD Request # 14 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQH22 | 2022-07-13 01:07:23.705 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-07-13 01:07:23.705 HD Request # 14 | Completion time: 0s | 2022-07-13 01:07:23.705 HD Request # 14 | Intraday data download complete for F.US.ENQH22. Unique request ID: 13 | 2022-07-13 01:07:23.706 Removing historical data download ID 13. | 2022-07-13 01:07:23.706 Real-time Intraday chart data file updates started for F.US.ENQH22 | 2022-07-13 01:07:23.706 Intraday chart data file opened for F.US.ENQH22 | 2022-07-13 01:07:23.706 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2022-07-13 01:07:23.706 Triggering next historical data download in queue. | 2022-07-13 01:07:23.706 HD Request # 15 | Downloading Intraday chart data for F.US.ENQZ21 to the file F.US.ENQZ21.scid. Service: cqg | 2022-07-13 01:07:23.706 HD Request # 15 | Performing multistage download. Downloading Minute data first. | 2022-07-13 01:07:23.706 HD Request # 15 | Download start date-time: 2021-10-12 14:18:48.000000. File last date-time: 2021-10-12 14:18:48.000000 | 2022-07-13 01:07:23.706 HD Request # 15 | Disabling Intraday chart updating for symbol. | 2022-07-13 01:07:23.706 CQG WebAPI | Sending symbol resolution request for F.US.ENQZ21. ID: 764522 | 2022-07-13 01:07:23.706 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:23.718 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU22. Search Symbol: F.US.ENQU22. Request ID: 764520. Contract ID: 2. | 2022-07-13 01:07:23.730 CQG WebAPI | Requesting market data for F.US.ENQU22 | 2022-07-13 01:07:23.730 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQZ21. Search Symbol: F.US.ENQZ21. Request ID: 764522. Contract ID: 3. | 2022-07-13 01:07:23.751 HD Request # 15 | Requesting historical Minute data. | 2022-07-13 01:07:23.751 HD Request # 15 | Error downloading historical Intraday data for F.US.ENQZ21. Historical data unavailable for this instrument. | 2022-07-13 01:07:23.846 HD Request # 15 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQZ21 | 2022-07-13 01:07:23.846 HD Request # 15 | Completion time: 0s | 2022-07-13 01:07:23.935 HD Request # 15 | Intraday data download complete for F.US.ENQZ21. Unique request ID: 14 | 2022-07-13 01:07:23.935 Added historical Intraday data request for F.US.ENQZ21 to the queue. | 2022-07-13 01:07:23.935 Triggering next historical data download in queue. | 2022-07-13 01:07:23.935 HD Request # 16 | Downloading Intraday chart data for F.US.ENQZ21 to the file F.US.ENQZ21.scid. Service: cqg | 2022-07-13 01:07:23.969 HD Request # 16 | Rounding start date-time down to the minute: 2021-10-12 14:18:00.000 | 2022-07-13 01:07:23.969 HD Request # 16 | Download start date-time: 2021-10-12 14:18:00.000000. File last date-time: 00:00:00.000000 | 2022-07-13 01:07:23.969 HD Request # 16 | Requesting historical Tick data. | 2022-07-13 01:07:23.969 HD Request # 16 | Error downloading historical Intraday data for F.US.ENQZ21. Historical data unavailable for this instrument. Result=104. Num Quotes=0 | 2022-07-13 01:07:24.049 HD Request # 16 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQZ21 | 2022-07-13 01:07:24.049 HD Request # 16 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-07-13 01:07:24.050 HD Request # 16 | Completion time: 1s | 2022-07-13 01:07:24.050 HD Request # 16 | Intraday data download complete for F.US.ENQZ21. Unique request ID: 14 | 2022-07-13 01:07:24.050 Removing historical data download ID 14. | 2022-07-13 01:07:24.050 Real-time Intraday chart data file updates started for F.US.ENQZ21 | 2022-07-13 01:07:24.050 Intraday chart data file opened for F.US.ENQZ21 | 2022-07-13 01:07:24.050 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2022-07-13 01:07:24.050 Triggering next historical data download in queue. | 2022-07-13 01:07:24.050 Delaying start of download for F.US.ENQU22 | 2022-07-13 01:07:24.050 F.US.ENQU22 [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-13 01:07:24.050 CQG WebAPI | Starting real-time market data updates for: F.US.MNQU22. ID: 5 Service code: cqg | 2022-07-13 01:07:24.067 CQG WebAPI | Sending symbol resolution request for F.US.MNQU22. ID: 764525 | 2022-07-13 01:07:24.067 CQG WebAPI | Requesting security definition data for: F.US.MNQU22. ID: 5 | 2022-07-13 01:07:24.067 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:24.419 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU22. Search Symbol: F.US.MNQU22. Request ID: 764525. Contract ID: 4. | 2022-07-13 01:07:24.425 CQG WebAPI | Requesting market data for F.US.MNQU22 | 2022-07-13 01:07:24.425 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:24.434 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:24.520 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:24.520 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:24.711 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:24.750 F.US.ENQU22 [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-13 01:07:25.144 F.US.ENQU22 [CBV][M] 512 Trades #17 | Reloading chart. | 2022-07-13 01:07:25.193 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:25.240 F.US.ENQU22 [CBV][M] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:25.348 F.US.ENQU22 [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-13 01:07:25.349 F.US.ENQU22 [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-13 01:07:25.530 F.US.ENQU22 [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-13 01:07:25.725 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:26.015 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-13 01:07:26.027 F.US.ENQU22 [CBV][M] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:26.177 F.US.ENQU22 [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-13 01:07:26.177 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:26.295 F.US.ENQU22 [CBV][M] 60 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 01:07:26.713 F.US.ENQU22 [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-13 01:07:26.714 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:28.050 F.US.ENQU22 [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-13 01:07:28.344 CQG WebAPI | Sending positions subscribe request. RequestID: 764526 | 2022-07-13 01:07:29.301 CQG WebAPI | Sending orders subscribe request. RequestID: 764527 | 2022-07-13 01:07:29.301 F.US.ENQU22 [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-13 01:07:29.308 F.US.ENQU22 [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-13 01:07:31.041 HD Request # 17 | Downloading Intraday chart data for F.US.ENQU22 to the file F.US.ENQU22.scid. Service: cqg | 2022-07-13 01:07:31.184 HD Request # 17 | Download start date-time: 2022-07-12 23:26:55.000000. File last date-time: 2022-07-12 23:26:55.172001 | 2022-07-13 01:07:31.184 HD Request # 17 | Requesting historical Tick data. | 2022-07-13 01:07:31.185 HD Request # 17 | Receiving Intraday data for F.US.ENQU22 starting at 2022-07-12 23:26:55.172000 | 2022-07-13 01:07:31.497 HD Request # 17 | Timestamp of first Intraday data file record written: 2022-07-12 23:26:59.860000 | 2022-07-13 01:07:31.499 HD Request # 17 | Received 9094 Intraday data records from 2022-07-12 23:26:55.172000 to 2022-07-13 01:07:29.728001 (100.6 minutes) and wrote 9092 records for F.US.ENQU22 | 2022-07-13 01:07:31.499 HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2022-07-13 01:07:29.728001 | 2022-07-13 01:07:31.506 HD Request # 17 | Completion time: 0s | 2022-07-13 01:07:31.511 HD Request # 17 | Intraday data download complete for F.US.ENQU22. Unique request ID: 15 | 2022-07-13 01:07:31.511 Removing historical data download ID 15. | 2022-07-13 01:07:31.511 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-13 01:07:31.511 Intraday chart data file opened for F.US.ENQU22 | 2022-07-13 01:07:31.511 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2022-07-13 01:07:31.511 Triggering next historical data download in queue. | 2022-07-13 01:07:31.514 No download requests in the queue to start downloads for. | 2022-07-13 01:07:31.514 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:32.877 Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQU22.scid. Thread ID: 11824 | 2022-07-13 01:07:35.135 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:41.392 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:43.369 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:43.369 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:43.369 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:43.369 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:48.591 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:48.701 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:48.704 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:48.718 F.US.ENQU22 [CBV] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:48.916 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:49.023 F.US.ENQU22 [CBV] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:49.643 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:49.645 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 01:07:49.781 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-13 01:07:54.976 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-28 20:07:56 | 2022-07-13 01:07:59.291 F.US.ENQU22 1 Trades #21 | StartDateTimeForLoadingOrderFills: 2022-06-28 20:07:56 | 2022-07-13 01:07:59.608 F.US.ENQU22 [CBV-D] 15 Min #30 | StartDateTimeForLoadingOrderFills: 2022-05-24 19:00:00 | 2022-07-13 01:08:00.479 DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-13 01:09:12.371 DTC Client socket (3) | Closed. | 2022-07-13 01:09:12.371 DTC Client socket (3) | Deleting network socket now after delay. | 2022-07-13 01:09:42.375 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-28 20:18:47 | 2022-07-13 01:18:50.867 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-28 20:18:50 | 2022-07-13 01:18:51.935 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 01:25:20.498 F.US.ENQU22/F.US.MNQU22 256 Trades #14 | Reloading chart. | 2022-07-13 01:33:27.572 F.US.ENQU22/F.US.MNQU22 256 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-28 20:33:26 | 2022-07-13 01:33:28.231 F.US.ENQU22/F.US.MNQU22 256 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-28 20:33:26 | 2022-07-13 01:33:29.510 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Reloading chart. | 2022-07-13 01:34:02.547 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-28 20:34:02 | 2022-07-13 01:34:03.161 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-28 20:34:02 | 2022-07-13 01:34:03.380 F.US.ENQU22 [CBV] 240 Min #9 | Reloading chart. | 2022-07-13 02:00:10.744 F.US.ENQU22 [CBV] 240 Min #9 | Reloading chart. | 2022-07-13 02:00:35.146 Sierra Chart account data changed. Requesting updated account information. | 2022-07-13 04:27:49.363 Successfully processed Sierra Chart account data. | 2022-07-13 04:27:53.646 Sierra Chart account data changed. Requesting updated account information. | 2022-07-13 04:34:49.454 Successfully processed Sierra Chart account data. | 2022-07-13 04:34:53.507 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-29 07:35:28 | 2022-07-13 12:35:30.815 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-29 07:35:29 | 2022-07-13 12:35:31.647 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.933 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.933 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.933 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.933 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.938 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.938 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.938 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.938 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.947 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.947 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.947 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.947 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.972 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.972 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.972 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.972 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.985 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.985 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.985 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:17.985 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:18.020 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:18.020 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:18.020 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:18.020 Chart #16 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 305 | 2022-07-13 20:14:18.022 Array message repeat count limit reached. | 2022-07-13 20:14:18.022 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 20:15:10.666 F.US.ENQU22 [CBV] #16 | Performing continuous chart historical Daily data download for symbol F.US.ENQU22 starting at last date in file. | 2022-07-13 20:15:10.685 Added historical Daily data request for F.US.ENQU22 to the queue. | 2022-07-13 20:15:10.686 Triggering next historical data download in queue. | 2022-07-13 20:15:10.686 F.US.ENQU22 [CBV] #16 | Waiting for historical downloads to complete with the IDs: 16, | 2022-07-13 20:15:10.698 HD Request # 18 | Downloading Historical Daily chart data for F.US.ENQU22. Starting date: 2022-07-08. Service: cqg | 2022-07-13 20:15:10.703 HD Request # 18 | Requesting historical Daily data for NQU22 starting at 2022-07-07. SC External HD service. | 2022-07-13 20:15:11.410 HD Request # 18 | Receiving historical Daily data for F.US.ENQU22 starting at 2022-07-08 | 2022-07-13 20:15:11.699 HD Request # 18 | Writing historical Daily data to the file F.US.ENQU22.dly | 2022-07-13 20:15:11.700 HD Request # 18 | Bytes received: 244 | 2022-07-13 20:15:11.703 HD Request # 18 | Received 4 Daily data records from 2022-07-08 00:00:00 to 2022-07-12 00:00:00 (5.0 days) and wrote 3 records for F.US.ENQU22 | 2022-07-13 20:15:11.703 HD Request # 18 | Completion time: 1s | 2022-07-13 20:15:11.703 HD Request # 18 | Daily data download complete for F.US.ENQU22. Unique request ID: 16 | 2022-07-13 20:15:11.703 Removing historical data download ID 16. | 2022-07-13 20:15:11.703 Triggering next historical data download in queue. | 2022-07-13 20:15:11.703 No download requests in the queue to start downloads for. | 2022-07-13 20:15:11.703 F.US.ENQU22 [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 20:15:12.170 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 20:15:12.171 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 20:15:12.679 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 20:15:14.684 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 23:30:02.572 F.US.ENQU22 [CBV] #16 | Performing continuous chart historical Daily data download for symbol F.US.ENQU22 starting at last date in file. | 2022-07-13 23:30:02.576 Added historical Daily data request for F.US.ENQU22 to the queue. | 2022-07-13 23:30:02.576 Triggering next historical data download in queue. | 2022-07-13 23:30:02.576 F.US.ENQU22 [CBV] #16 | Waiting for historical downloads to complete with the IDs: 17, | 2022-07-13 23:30:02.587 HD Request # 19 | Downloading Historical Daily chart data for F.US.ENQU22. Starting date: 2022-07-08. Service: cqg | 2022-07-13 23:30:02.591 HD Request # 19 | Requesting historical Daily data for NQU22 starting at 2022-07-07. SC External HD service. | 2022-07-13 23:30:03.360 HD Request # 19 | Receiving historical Daily data for F.US.ENQU22 starting at 2022-07-08 | 2022-07-13 23:30:03.724 HD Request # 19 | Writing historical Daily data to the file F.US.ENQU22.dly | 2022-07-13 23:30:03.725 HD Request # 19 | Bytes received: 305 | 2022-07-13 23:30:03.726 HD Request # 19 | Received 5 Daily data records from 2022-07-08 00:00:00 to 2022-07-13 00:00:00 (6.0 days) and wrote 4 records for F.US.ENQU22 | 2022-07-13 23:30:03.726 HD Request # 19 | Completion time: 1s | 2022-07-13 23:30:03.726 HD Request # 19 | Daily data download complete for F.US.ENQU22. Unique request ID: 17 | 2022-07-13 23:30:03.726 Removing historical data download ID 17. | 2022-07-13 23:30:03.726 Triggering next historical data download in queue. | 2022-07-13 23:30:03.726 No download requests in the queue to start downloads for. | 2022-07-13 23:30:03.726 F.US.ENQU22 [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-13 23:30:03.832 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 23:30:03.832 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 23:30:04.333 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 23:30:05.875 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 23:30:12.910 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 23:30:14.905 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 23:30:21.639 F.US.ENQU22 [CBV] #16 | Reloading chart. | 2022-07-13 23:30:23.894 F.US.ENQU22 [CBV] 512 Trades #17 | Chart Settings have been synchronized between Destination chart number #14 and Source data chart number #17. Performing a chart reload of Source data chart. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 23:44:48.936 F.US.ENQU22 512 Trades #17 | Reloading chart. | 2022-07-13 23:44:48.937 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 23:44:49.261 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-13 23:44:49.482 F.US.ENQU22/F.US.MNQU22 5 Min #14 | Reloading chart. | 2022-07-14 14:20:16.352 F.US.ENQU22/F.US.MNQU22 5 Min #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 09:20:12 | 2022-07-14 14:20:16.892 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Reloading chart. | 2022-07-14 14:20:28.553 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 09:20:24 | 2022-07-14 14:20:29.130 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 09:20:24 | 2022-07-14 14:20:29.453 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 09:20:56 | 2022-07-14 14:21:01.304 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 09:20:57 | 2022-07-14 14:21:02.425 F.US.ENQU22 [CBV-D] 15 Min #30 | StartDateTimeForLoadingOrderFills: 2022-05-24 19:00:00 | 2022-07-14 15:08:05.869 F.US.ENQU22 [CBV-D] 15 Min #30 | StartDateTimeForLoadingOrderFills: 2022-05-24 19:00:00 | 2022-07-14 15:08:07.762 F.US.ENQU22 [CBV-D] 15 Min #30 | StartDateTimeForLoadingOrderFills: 2022-05-24 19:00:00 | 2022-07-14 15:08:15.361 F.US.ENQU22 [CBV-D] 15 Min #30 | StartDateTimeForLoadingOrderFills: 2022-05-24 19:00:00 | 2022-07-14 15:08:16.391 F.US.ENQU22 [CBV-D] 15 Min #30 | StartDateTimeForLoadingOrderFills: 2022-05-24 19:00:00 | 2022-07-14 15:08:17.515 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 10:08:21 | 2022-07-14 15:08:26.302 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 10:08:26 | 2022-07-14 15:08:30.757 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 10:08:28 | 2022-07-14 15:08:32.870 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 10:16:24 | 2022-07-14 15:16:28.995 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-30 10:16:25 | 2022-07-14 15:16:30.324 F.US.ENQU22 [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-14 15:25:19.530 F.US.ENQU22 [CBV] 7500 Volume #7 | Performing continuous chart historical Daily data download for symbol F.US.ENQU22 starting at last date in file. | 2022-07-14 15:25:19.549 Added historical Daily data request for F.US.ENQU22 to the queue. | 2022-07-14 15:25:19.549 Triggering next historical data download in queue. | 2022-07-14 15:25:19.549 F.US.ENQU22 [CBV] 7500 Volume #7 | Waiting for historical downloads to complete with the IDs: 18, | 2022-07-14 15:25:19.561 HD Request # 20 | Downloading Historical Daily chart data for F.US.ENQU22. Starting date: 2022-07-11. Service: cqg | 2022-07-14 15:25:19.594 HD Request # 20 | Requesting historical Daily data for NQU22 starting at 2022-07-10. SC External HD service. | 2022-07-14 15:25:20.393 HD Request # 20 | Receiving historical Daily data for F.US.ENQU22 starting at 2022-07-11 | 2022-07-14 15:25:20.903 HD Request # 20 | Writing historical Daily data to the file F.US.ENQU22.dly | 2022-07-14 15:25:20.903 HD Request # 20 | Bytes received: 184 | 2022-07-14 15:25:20.907 HD Request # 20 | Received 3 Daily data records from 2022-07-11 00:00:00 to 2022-07-13 00:00:00 (3.0 days) and wrote 3 records for F.US.ENQU22 | 2022-07-14 15:25:20.907 HD Request # 20 | Completion time: 1s | 2022-07-14 15:25:20.907 HD Request # 20 | Daily data download complete for F.US.ENQU22. Unique request ID: 18 | 2022-07-14 15:25:20.907 Removing historical data download ID 18. | 2022-07-14 15:25:20.907 Triggering next historical data download in queue. | 2022-07-14 15:25:20.907 No download requests in the queue to start downloads for. | 2022-07-14 15:25:20.907 F.US.ENQU22 [CBV] 7500 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-14 15:25:21.302 F.US.ENQU22 [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-14 15:25:21.303 F.US.ENQU22 [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-14 15:25:21.832 F.US.ENQU22 [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-14 15:25:29.275 F.US.ENQU22 [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-14 15:25:34.262 F.US.ENQU22 [CBV] Daily #9 | Reloading chart. | 2022-07-14 16:00:53.348 Added historical Daily data request for F.US.ENQU22 to the queue. | 2022-07-14 16:00:55.189 Triggering next historical data download in queue. | 2022-07-14 16:00:55.189 HD Request # 21 | Downloading Historical Daily chart data for F.US.ENQU22. Starting date: 2022-07-11. Service: cqg | 2022-07-14 16:00:55.193 HD Request # 21 | Requesting historical Daily data for NQU22 starting at 2022-07-10. SC External HD service. | 2022-07-14 16:00:55.919 HD Request # 21 | Receiving historical Daily data for F.US.ENQU22 starting at 2022-07-11 | 2022-07-14 16:00:56.136 HD Request # 21 | Writing historical Daily data to the file F.US.ENQU22.dly | 2022-07-14 16:00:56.136 HD Request # 21 | Bytes received: 184 | 2022-07-14 16:00:56.138 HD Request # 21 | Received 3 Daily data records from 2022-07-11 00:00:00 to 2022-07-13 00:00:00 (3.0 days) and wrote 3 records for F.US.ENQU22 | 2022-07-14 16:00:56.138 HD Request # 21 | Completion time: 1s | 2022-07-14 16:00:56.138 HD Request # 21 | Daily data download complete for F.US.ENQU22. Unique request ID: 19 | 2022-07-14 16:00:56.138 Removing historical data download ID 19. | 2022-07-14 16:00:56.138 Triggering next historical data download in queue. | 2022-07-14 16:00:56.138 No download requests in the queue to start downloads for. | 2022-07-14 16:00:56.138 F.US.ENQU22 [CBV] Daily #9 | Reloading chart. | 2022-07-14 16:00:56.269 F.US.ENQU22 [CBV] Daily #9 | Reloading chart. | 2022-07-14 16:02:20.954 F.US.ENQU22 [CBV] Weekly #9 | Reloading chart. | 2022-07-14 16:02:21.812 Restarting the loading process. | 2022-07-14 16:02:22.711 F.US.ENQU22 [CBV] 240 Min #9 | Reloading chart. | 2022-07-14 16:03:56.227 F.US.ENQU22 [CBV] 60 Min #22 | Reloading chart. | 2022-07-14 16:50:51.277 F.US.ENQU22 [CBV] 60 Min #22 | Reloading chart. | 2022-07-14 16:51:05.283 F.US.ENQU22 [CBV] 60 Min #22 | Reloading chart. | 2022-07-14 16:51:13.073 F.US.ENQU22 [CBV] 60 Min #22 | Reloading chart. | 2022-07-14 16:51:50.615 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:48.807 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:48.807 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:48.807 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:48.807 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:48.844 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:48.986 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:49.594 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:49.600 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:49.807 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:49.871 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:54.869 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:54.869 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:54.869 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:54.869 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:54.939 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:55.179 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:55.793 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:55.797 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:55.984 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:54:55.992 F.US.ENQU22 [CBV] 60 Min #22 | Reloading chart. | 2022-07-14 16:55:08.188 F.US.ENQU22 [CBV] 750 Volume #1 | Reloading chart. | 2022-07-14 16:55:17.439 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:18.518 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:18.518 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:18.518 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:18.518 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:18.655 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:18.736 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:19.086 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:19.091 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:19.107 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:20.217 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:20.217 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:20.217 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:20.217 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:20.368 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:20.554 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:20.689 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:21.048 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:21.052 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:21.305 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:58.491 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:58.492 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:58.492 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:58.492 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:58.625 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:58.709 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:59.066 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:59.070 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:55:59.176 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:01.294 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:01.294 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:01.294 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:01.294 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:01.302 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:01.315 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:01.597 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:01.953 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:01.958 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:02.237 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:02.237 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:02.237 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:02.237 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:02.272 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:02.306 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:02.573 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:02.992 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:02.996 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:03.334 F.US.ENQU22 [CBV] 750 Volume #1 | Reloading chart. | 2022-07-14 16:56:34.451 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:35.228 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:35.228 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:35.228 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:35.228 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:35.236 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:35.560 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:35.564 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:35.645 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:35.895 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:39.087 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:39.087 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:39.087 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:39.087 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:39.410 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:39.503 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:39.663 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:39.965 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:39.969 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:56:40.194 F.US.ENQU22 [CBV] 750 Volume #1 | Reloading chart. | 2022-07-14 16:56:57.136 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:03.844 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:03.844 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:03.844 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:03.844 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:03.913 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:04.058 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:04.136 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:04.742 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:04.746 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:04.859 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:06.943 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:06.943 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:06.943 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:06.943 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:07.069 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:07.221 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:07.317 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:07.937 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:07.943 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:08.142 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:14.338 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:14.338 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:14.338 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:14.338 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:14.345 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:14.601 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:14.677 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:15.273 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:15.276 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:15.336 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:18.561 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:18.561 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:18.561 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:18.561 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:18.678 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:18.749 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:19.355 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:19.358 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:19.453 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:21.674 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:21.674 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:21.674 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:21.674 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:21.682 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:21.759 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:22.357 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:22.361 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:22.441 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:25.838 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:25.838 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:25.838 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:25.838 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:25.851 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:25.855 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:25.949 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:26.189 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:26.263 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:31.730 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:31.730 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:31.730 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:31.730 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:31.871 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:31.933 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:32.096 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:32.720 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:32.724 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:32.787 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:36.650 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:36.650 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:36.650 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:36.650 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:37.478 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:38.096 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:38.100 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:38.332 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:57:38.340 F.US.ENQU22 [CBV] 60 Min #22 | Reloading chart. | 2022-07-14 16:58:02.683 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:52.359 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:52.359 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:52.359 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:52.359 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:52.496 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:52.698 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:52.781 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:53.409 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:53.414 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:58:53.536 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:59:05.303 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:59:05.303 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:59:05.303 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:59:05.303 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:59:05.354 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:59:06.002 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:59:06.006 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:59:06.215 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 16:59:06.417 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 17:01:08.940 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 17:01:08.940 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 17:01:08.940 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 17:01:08.940 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 17:01:08.979 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 17:01:09.241 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 17:01:09.874 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 17:01:09.879 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-14 17:01:09.945 F.US.ENQU22 [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-14 17:57:32.466 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-07-01 09:35:42 | 2022-07-15 14:35:48.668 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-07-01 09:35:42 | 2022-07-15 14:35:49.510 CQG WebSocket socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-15 17:11:28.577 * CQG WebSocket socket (5) | Socket gracefully closed by remote side. | 2022-07-15 17:11:28.577 CQG WebSocket socket (5) | CloseSocket call. | 2022-07-15 17:11:28.577 CQG WebSocket socket (5) | Max send buffers used during socket life: 3 | 2022-07-15 17:11:28.577 CQG WebSocket socket (5) | Max send buffer size during socket life: 488 | 2022-07-15 17:11:28.577 CQG WebSocket | Network socket for WebSocket has been closed by remote side or error. | 2022-07-15 17:11:28.577 CQG WebAPI | WebSocket closed. | 2022-07-15 17:11:28.577 CQG WebSocket socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-15 17:11:28.577 Connection to the external service has been lost. | 2022-07-15 17:11:28.577 CQG WebSocket socket (5) | Closed. | 2022-07-15 17:11:28.577 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-15 17:11:28.619 CQG WebAPI | Disconnected. | 2022-07-15 17:11:28.619 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-15 17:11:28.619 CQG WebAPI | Connecting to server api.cqg.com | 2022-07-15 17:11:30.620 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-07-15 17:11:30.620 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2022-07-15 17:11:30.680 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2022-07-15 17:11:30.680 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2022-07-15 17:11:30.680 CQG WebSocket | Opening WebSocket. | 2022-07-15 17:11:30.716 CQG WebSocket | Sending WebSocket handshake. | 2022-07-15 17:11:30.716 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-07-15 17:11:30.919 CQG WebSocket | Server header | Connection: upgrade | 2022-07-15 17:11:30.919 CQG WebSocket | Server header | Sec-WebSocket-Accept: OFfMuqascKkiGk0fbWUUNzKnWBs= | 2022-07-15 17:11:30.919 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-07-15 17:11:30.919 CQG WebSocket | Server header | Upgrade: websocket | 2022-07-15 17:11:30.919 CQG WebSocket | Server header | | 2022-07-15 17:11:30.919 CQG WebSocket | Web socket state is now open. | 2022-07-15 17:11:30.919 CQG WebAPI | WebSocket connected. | 2022-07-15 17:11:30.919 CQG WebAPI | Sending market data logon message. | 2022-07-15 17:11:30.919 CQG WebAPI | Base Time: 2022-06-18T07:21:13. 2022-06-18 07:21:13 | 2022-07-15 17:11:31.078 CQG WebAPI | Logon successful. Session Token = acmf7dBVKGRYvrharfCUqUE9kxRBsFv/t6moUIjEu1scc4dU+8szM1qBr/TdOrcm7o4jIwh3FHC | 2022-07-15 17:11:31.078 CQG WebAPI | Connected to server complete. | 2022-07-15 17:11:31.078 Triggering next historical data download in queue. | 2022-07-15 17:11:31.079 Triggering next historical data download in queue. | 2022-07-15 17:11:31.079 Triggering next historical data download in queue. | 2022-07-15 17:11:31.079 Triggering next historical data download in queue. | 2022-07-15 17:11:31.079 Subscribing to symbol for symbol alert. F.US.MNQM22 | 2022-07-15 17:11:31.079 Using symbol data fast lookup vector | 2022-07-15 17:11:31.079 CQG WebAPI | Starting real-time market data updates for: F.US.MNQM22. ID: 1 Service code: cqg | 2022-07-15 17:11:31.080 CQG WebAPI | Sending symbol resolution request for F.US.MNQM22. ID: 764882 | 2022-07-15 17:11:31.080 CQG WebAPI | Requesting security definition data for: F.US.MNQM22. ID: 1 | 2022-07-15 17:11:31.080 Updated verified funded futures trading account ending date to: 2022-08-14 17:11:31 | 2022-07-15 17:11:31.080 CQG WebAPI | Sending Trade Accounts request message. | 2022-07-15 17:11:31.118 No download requests in the queue to start downloads for. | 2022-07-15 17:11:31.119 No download requests in the queue to start downloads for. | 2022-07-15 17:11:31.119 No download requests in the queue to start downloads for. | 2022-07-15 17:11:31.119 No download requests in the queue to start downloads for. | 2022-07-15 17:11:31.119 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQM22. Search Symbol: F.US.MNQM22. Request ID: 764882. Contract ID: 1. | 2022-07-15 17:11:31.119 CQG WebAPI | Requesting market data for F.US.MNQM22 | 2022-07-15 17:11:31.119 CQG WebAPI | Starting real-time market data updates for: F.US.ENQU22. ID: 2 Service code: cqg | 2022-07-15 17:11:31.132 CQG WebAPI | Sending symbol resolution request for F.US.ENQU22. ID: 764884 | 2022-07-15 17:11:31.132 CQG WebAPI | Requesting security definition data for: F.US.ENQU22. ID: 2 | 2022-07-15 17:11:31.132 CQG WebAPI | Starting real-time market data updates for: F.US.MNQU22. ID: 3 Service code: cqg | 2022-07-15 17:11:31.132 CQG WebAPI | Sending symbol resolution request for F.US.MNQU22. ID: 764885 | 2022-07-15 17:11:31.132 CQG WebAPI | Requesting security definition data for: F.US.MNQU22. ID: 3 | 2022-07-15 17:11:31.132 CQG WebAPI | Using primary service for historical data for F.US.ENQU22 | 2022-07-15 17:11:31.132 Added historical Intraday data request for F.US.ENQU22 to the queue. | 2022-07-15 17:11:31.133 Intraday data recording state for symbol F.US.ENQU22 is set to download 'Pending'. | 2022-07-15 17:11:31.133 Triggering next historical data download in queue. | 2022-07-15 17:11:31.133 Delaying start of download for F.US.ENQU22 | 2022-07-15 17:11:31.167 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU22. Search Symbol: F.US.ENQU22. Request ID: 764884. Contract ID: 2. | 2022-07-15 17:11:31.167 CQG WebAPI | Requesting market data for F.US.ENQU22 | 2022-07-15 17:11:31.167 CQG WebAPI | Brokerage name: AMP3. Account Name: 131836 | 2022-07-15 17:11:31.167 Updated verified funded futures trading account ending date to: 2022-08-14 17:11:31 | 2022-07-15 17:11:31.167 CQG WebAPI | Sending collateral subscribe request. | 2022-07-15 17:11:31.167 CQG WebAPI | Market data subscription for F.US.MNQM22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 1) is not enabled. | 2022-07-15 17:11:31.167 Symbol Error - F.US.MNQM22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 1) is not enabled. | 2022-07-15 17:11:31.167 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU22. Search Symbol: F.US.MNQU22. Request ID: 764885. Contract ID: 3. | 2022-07-15 17:11:31.191 CQG WebAPI | Requesting market data for F.US.MNQU22 | 2022-07-15 17:11:31.191 CQG WebAPI | Market data subscription for F.US.ENQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 2) is not enabled. | 2022-07-15 17:11:31.195 Symbol Error - F.US.ENQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 2) is not enabled. | 2022-07-15 17:11:31.195 CQG WebAPI | Market data subscription for F.US.MNQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 3) is not enabled. | 2022-07-15 17:11:31.265 Symbol Error - F.US.MNQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 3) is not enabled. | 2022-07-15 17:11:31.265 HD Request # 22 | Downloading Intraday chart data for F.US.ENQU22 to the file F.US.ENQU22.scid. Service: cqg | 2022-07-15 17:11:31.902 HD Request # 22 | Download start date-time: 2022-07-15 17:10:58.000000. File last date-time: 2022-07-15 17:10:58.276000 | 2022-07-15 17:11:31.902 HD Request # 22 | Requesting historical Tick data. | 2022-07-15 17:11:31.902 HD Request # 22 | Error downloading historical Intraday data for F.US.ENQU22. Instrument F.US.ENQ (corresponding to ID 2) is not allowed. Result=103. Num Quotes=0 | 2022-07-15 17:11:31.973 HD Request # 22 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQU22 | 2022-07-15 17:11:31.973 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2022-07-15 17:10:58.276000 | 2022-07-15 17:11:31.973 HD Request # 22 | Completion time: 0s | 2022-07-15 17:11:31.973 HD Request # 22 | Intraday data download complete for F.US.ENQU22. Unique request ID: 20 | 2022-07-15 17:11:31.973 Removing historical data download ID 20. | 2022-07-15 17:11:31.973 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-15 17:11:31.973 Intraday chart data file opened for F.US.ENQU22 | 2022-07-15 17:11:31.973 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2022-07-15 17:11:31.973 Triggering next historical data download in queue. | 2022-07-15 17:11:31.973 No download requests in the queue to start downloads for. | 2022-07-15 17:11:31.973 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.205 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.206 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.206 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.206 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.206 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.207 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.207 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.207 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.207 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.208 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.208 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.208 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.208 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.209 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.235 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.235 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.236 F.US.ENQU22 [CBV] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.236 F.US.ENQU22 [CBV] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.262 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.264 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:32.265 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:33.589 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:33.589 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:33.589 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:33.618 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:33.620 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:33.620 F.US.ENQU22 [CBV] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:33.842 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:33.864 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:11:33.867 CQG WebAPI | Sending positions subscribe request. RequestID: 764888 | 2022-07-15 17:11:34.075 CQG WebAPI | Sending orders subscribe request. RequestID: 764889 | 2022-07-15 17:11:34.076 File >> Disconnect selected. | 2022-07-15 17:37:03.233 CQG WebAPI | Sending Web API Logoff message. | 2022-07-15 17:37:03.257 CQG WebSocket socket (1) | CloseSocket call. | 2022-07-15 17:37:03.257 CQG WebSocket socket (1) | Max send buffers used during socket life: 3 | 2022-07-15 17:37:03.257 CQG WebSocket socket (1) | Max send buffer size during socket life: 309 | 2022-07-15 17:37:03.257 CQG WebSocket | WebSocket closed. | 2022-07-15 17:37:03.257 CQG WebAPI | WebSocket closed. | 2022-07-15 17:37:03.257 CQG WebAPI | Disconnected. | 2022-07-15 17:37:03.257 CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-15 17:37:03.257 CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2022-07-15 17:37:03.272 CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-15 17:37:03.272 CQG WebAPI | Connecting to server api.cqg.com | 2022-07-15 17:37:07.183 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-07-15 17:37:07.183 CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2022-07-15 17:37:07.247 CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2022-07-15 17:37:07.247 CQG WebSocket socket (2) | Connecting to IP: 208.48.16.35. | 2022-07-15 17:37:07.247 CQG WebSocket | Opening WebSocket. | 2022-07-15 17:37:07.272 CQG WebSocket | Sending WebSocket handshake. | 2022-07-15 17:37:07.272 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-07-15 17:37:07.481 CQG WebSocket | Server header | Connection: upgrade | 2022-07-15 17:37:07.481 CQG WebSocket | Server header | Sec-WebSocket-Accept: cnH1lx8pmdKeVSKHOHe0V9k6E88= | 2022-07-15 17:37:07.481 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-07-15 17:37:07.481 CQG WebSocket | Server header | Upgrade: websocket | 2022-07-15 17:37:07.481 CQG WebSocket | Server header | | 2022-07-15 17:37:07.481 CQG WebSocket | Web socket state is now open. | 2022-07-15 17:37:07.481 CQG WebAPI | WebSocket connected. | 2022-07-15 17:37:07.481 CQG WebAPI | Sending market data logon message. | 2022-07-15 17:37:07.481 CQG WebAPI | Base Time: 2022-06-18T07:21:13. 2022-06-18 07:21:13 | 2022-07-15 17:37:07.635 CQG WebAPI | Logon successful. Session Token = ++tUTDBHRPJ90GyzFR0jPO8bt7edJzz+sxoVxxuWkEQjHlB8UBviiud3j/ZYCDcEpn5aOKz4jr3 | 2022-07-15 17:37:07.635 CQG WebAPI | Connected to server complete. | 2022-07-15 17:37:07.635 Triggering next historical data download in queue. | 2022-07-15 17:37:07.635 Triggering next historical data download in queue. | 2022-07-15 17:37:07.635 Triggering next historical data download in queue. | 2022-07-15 17:37:07.635 Triggering next historical data download in queue. | 2022-07-15 17:37:07.635 Subscribing to symbol for symbol alert. F.US.MNQM22 | 2022-07-15 17:37:07.635 Using symbol data fast lookup vector | 2022-07-15 17:37:07.635 CQG WebAPI | Starting real-time market data updates for: F.US.MNQM22. ID: 1 Service code: cqg | 2022-07-15 17:37:07.636 CQG WebAPI | Sending symbol resolution request for F.US.MNQM22. ID: 764890 | 2022-07-15 17:37:07.636 CQG WebAPI | Requesting security definition data for: F.US.MNQM22. ID: 1 | 2022-07-15 17:37:07.636 Updated verified funded futures trading account ending date to: 2022-08-14 17:37:07 | 2022-07-15 17:37:07.636 CQG WebAPI | Sending Trade Accounts request message. | 2022-07-15 17:37:07.656 No download requests in the queue to start downloads for. | 2022-07-15 17:37:07.656 No download requests in the queue to start downloads for. | 2022-07-15 17:37:07.656 No download requests in the queue to start downloads for. | 2022-07-15 17:37:07.656 No download requests in the queue to start downloads for. | 2022-07-15 17:37:07.656 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQM22. Search Symbol: F.US.MNQM22. Request ID: 764890. Contract ID: 1. | 2022-07-15 17:37:07.659 CQG WebAPI | Requesting market data for F.US.MNQM22 | 2022-07-15 17:37:07.659 CQG WebAPI | Starting real-time market data updates for: F.US.ENQU22. ID: 2 Service code: cqg | 2022-07-15 17:37:07.708 CQG WebAPI | Sending symbol resolution request for F.US.ENQU22. ID: 764892 | 2022-07-15 17:37:07.708 CQG WebAPI | Requesting security definition data for: F.US.ENQU22. ID: 2 | 2022-07-15 17:37:07.708 CQG WebAPI | Starting real-time market data updates for: F.US.MNQU22. ID: 3 Service code: cqg | 2022-07-15 17:37:07.708 CQG WebAPI | Sending symbol resolution request for F.US.MNQU22. ID: 764893 | 2022-07-15 17:37:07.708 CQG WebAPI | Requesting security definition data for: F.US.MNQU22. ID: 3 | 2022-07-15 17:37:07.708 CQG WebAPI | Using primary service for historical data for F.US.ENQU22 | 2022-07-15 17:37:07.708 Added historical Intraday data request for F.US.ENQU22 to the queue. | 2022-07-15 17:37:07.709 Intraday data recording state for symbol F.US.ENQU22 is set to download 'Pending'. | 2022-07-15 17:37:07.709 Triggering next historical data download in queue. | 2022-07-15 17:37:07.709 Delaying start of download for F.US.ENQU22 | 2022-07-15 17:37:07.753 CQG WebAPI | Brokerage name: AMP3. Account Name: 131836 | 2022-07-15 17:37:07.848 Updated verified funded futures trading account ending date to: 2022-08-14 17:37:07 | 2022-07-15 17:37:07.848 CQG WebAPI | Sending collateral subscribe request. | 2022-07-15 17:37:07.848 CQG WebAPI | Market data subscription for F.US.MNQM22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 1) is not enabled. | 2022-07-15 17:37:07.849 Symbol Error - F.US.MNQM22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 1) is not enabled. | 2022-07-15 17:37:07.849 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU22. Search Symbol: F.US.ENQU22. Request ID: 764892. Contract ID: 2. | 2022-07-15 17:37:07.849 CQG WebAPI | Requesting market data for F.US.ENQU22 | 2022-07-15 17:37:07.849 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU22. Search Symbol: F.US.MNQU22. Request ID: 764893. Contract ID: 3. | 2022-07-15 17:37:07.849 CQG WebAPI | Requesting market data for F.US.MNQU22 | 2022-07-15 17:37:07.849 CQG WebAPI | Market data subscription for F.US.ENQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 2) is not enabled. | 2022-07-15 17:37:07.930 Symbol Error - F.US.ENQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 2) is not enabled. | 2022-07-15 17:37:07.930 CQG WebAPI | Market data subscription for F.US.MNQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 3) is not enabled. | 2022-07-15 17:37:07.930 Symbol Error - F.US.MNQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 3) is not enabled. | 2022-07-15 17:37:07.930 HD Request # 23 | Downloading Intraday chart data for F.US.ENQU22 to the file F.US.ENQU22.scid. Service: cqg | 2022-07-15 17:37:08.764 HD Request # 23 | Download start date-time: 2022-07-15 17:10:58.000000. File last date-time: 2022-07-15 17:10:58.276000 | 2022-07-15 17:37:08.765 HD Request # 23 | Requesting historical Tick data. | 2022-07-15 17:37:08.765 HD Request # 23 | Error downloading historical Intraday data for F.US.ENQU22. Instrument F.US.ENQ (corresponding to ID 2) is not allowed. Result=103. Num Quotes=0 | 2022-07-15 17:37:08.858 HD Request # 23 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQU22 | 2022-07-15 17:37:08.858 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2022-07-15 17:10:58.276000 | 2022-07-15 17:37:08.858 HD Request # 23 | Completion time: 0s | 2022-07-15 17:37:08.858 HD Request # 23 | Intraday data download complete for F.US.ENQU22. Unique request ID: 21 | 2022-07-15 17:37:08.858 Removing historical data download ID 21. | 2022-07-15 17:37:08.858 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-15 17:37:08.858 Intraday chart data file opened for F.US.ENQU22 | 2022-07-15 17:37:08.858 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2022-07-15 17:37:08.858 Triggering next historical data download in queue. | 2022-07-15 17:37:08.858 No download requests in the queue to start downloads for. | 2022-07-15 17:37:08.858 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.344 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.358 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.361 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.372 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.372 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.397 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.397 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.400 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.409 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.448 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.448 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.448 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.448 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.544 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.596 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.610 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.617 F.US.ENQU22 [CBV] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.626 F.US.ENQU22 [CBV] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.672 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.682 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:09.693 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:10.401 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:10.401 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:10.406 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:10.410 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:10.471 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:10.492 F.US.ENQU22 [CBV] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:10.606 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:10.610 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:10.616 CQG WebAPI | Sending positions subscribe request. RequestID: 764896 | 2022-07-15 17:37:10.741 CQG WebAPI | Sending orders subscribe request. RequestID: 764897 | 2022-07-15 17:37:10.741 CQG WebAPI | Sending Web API Logoff message. | 2022-07-15 17:37:53.352 CQG WebSocket socket (2) | CloseSocket call. | 2022-07-15 17:37:53.352 CQG WebSocket | WebSocket closed. | 2022-07-15 17:37:53.352 CQG WebAPI | WebSocket closed. | 2022-07-15 17:37:53.352 CQG WebAPI | Disconnected. | 2022-07-15 17:37:53.352 CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-15 17:37:53.352 CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2022-07-15 17:37:53.372 CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-15 17:37:53.372 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-15 17:37:53.526 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-15 17:37:53.526 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-15 17:37:53.532 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 7. | 2022-07-15 17:37:53.536 Current selected Data/Trading service: SC Data - All Services | 2022-07-15 17:37:53.536 Symbol settings MD5 received. Request ID: 7. | 2022-07-15 17:37:55.749 Requested symbol settings for service code scdataallservices. Request ID: 8. | 2022-07-15 17:37:55.749 SC Data - All Services | Disconnected. | 2022-07-15 17:37:56.354 SC Data - All Services | Disconnected. | 2022-07-15 17:37:56.358 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-15 17:37:56.358 NQU22-CME/MNQU22-CME 512 Trades #14 | Reloading chart. | 2022-07-15 17:37:56.560 NQU22-CME 512 Trades #17 | Reloading chart. | 2022-07-15 17:37:56.599 NQU22-CME [CBV] 825 Trades #23 | Reloading chart. | 2022-07-15 17:37:56.620 NQU22-CME [CBV] 825 Trades #23 | Performing continuous chart historical Daily data download for symbol NQU22-CME starting at last date in file. | 2022-07-15 17:37:56.631 Added historical Daily data request for NQU22-CME to the queue. | 2022-07-15 17:37:56.631 Triggering next historical data download in queue. | 2022-07-15 17:37:56.631 NQU22-CME [CBV] 825 Trades #23 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:56.646 Mapping NQU22-CME to NQU22. Service code: cme | 2022-07-15 17:37:56.647 HD Request # 24 | Downloading Historical Daily chart data for NQU22-CME. Starting date: 2022-07-08. Service: scdataallservices | 2022-07-15 17:37:56.648 NQU22-CME [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-15 17:37:56.650 NQU22-CME [CBV] 3072 Trades #4 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:56.656 NQU22-CME 30 Sec #13 | Reloading chart. | 2022-07-15 17:37:56.676 NQU22-CME [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-15 17:37:56.760 NQU22-CME [CBV] 7500 Volume #20 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:56.777 NQU22-CME [CBV] 5 Min #25 | Reloading chart. | 2022-07-15 17:37:56.789 NQU22-CME [CBV] 5 Min #25 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:56.848 NQU22-CME [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-15 17:37:56.862 NQU22-CME [CBV] 3072 Trades #11 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:56.868 NQU22-CME [CBV] 60 Min #22 | Reloading chart. | 2022-07-15 17:37:56.912 NQU22-CME [CBV] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:56.934 NQU22-CME [CBV] 750 Volume #1 | Reloading chart. | 2022-07-15 17:37:56.959 NQU22-CME [CBV] 750 Volume #1 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:56.993 NQU22-CME [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-15 17:37:56.998 NQU22-CME [CBV] 7500 Volume #7 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.034 NQU22-CME [CBV-D] 15 Min #30 | Reloading chart. | 2022-07-15 17:37:57.050 NQU22-CME [CBV-D] 15 Min #30 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.115 NQU22-CME [CBV] 60 Min #15 | Reloading chart. | 2022-07-15 17:37:57.124 NQU22-CME [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.215 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:37:57.218 NQU22-CME 1250 Volume #24 | Reloading chart. | 2022-07-15 17:37:57.232 NQU22-CME [CBV] 30 Min #2 | Reloading chart. | 2022-07-15 17:37:57.251 NQU22-CME [CBV] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.272 NQU22-CME 1 Trades #21 | Reloading chart. | 2022-07-15 17:37:57.339 NQU22-CME [CBV] 512 Trades #5 | Reloading chart. | 2022-07-15 17:37:57.358 NQU22-CME [CBV] 512 Trades #5 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.365 NQU22-CME [CBV] 1 Day #3 | Reloading chart. | 2022-07-15 17:37:57.368 NQU22-CME [CBV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.438 HD Request # 24 | Requesting historical Daily data for NQU22 starting at 2022-07-07. SC External HD service. | 2022-07-15 17:37:57.440 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Reloading chart. | 2022-07-15 17:37:57.444 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.451 NQU22-CME [CBV] #16 | Reloading chart. | 2022-07-15 17:37:57.454 NQU22-CME [CBV] #16 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.472 NQU22-CME [CBV] 240 Min #9 | Reloading chart. | 2022-07-15 17:37:57.476 NQU22-CME [CBV] 240 Min #9 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.499 NQU22-CME [CBV] 60 Min #29 | Reloading chart. | 2022-07-15 17:37:57.501 NQU22-CME [CBV] 60 Min #29 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.531 NQU22-CME [CBV] 5 Min #6 | Reloading chart. | 2022-07-15 17:37:57.548 NQU22-CME [CBV] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.553 NQU22-CME [CBV] 5 Min #12 | Reloading chart. | 2022-07-15 17:37:57.555 NQU22-CME [CBV] 5 Min #12 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.573 NQU22-CME [CBV] 1 Min #27 | Reloading chart. | 2022-07-15 17:37:57.579 NQU22-CME [CBV] 1 Min #27 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.584 NQU22-CME [CBV] 60 Min #8 | Reloading chart. | 2022-07-15 17:37:57.587 NQU22-CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.591 NQU22-CME [CBV] 15 Min #10 | Reloading chart. | 2022-07-15 17:37:57.593 NQU22-CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.617 NQU22-CME 1 Min #18 | Reloading chart. | 2022-07-15 17:37:57.622 NQU22-CME [CBV] 750 Volume #26 | Reloading chart. | 2022-07-15 17:37:57.657 NQU22-CME [CBV] 750 Volume #26 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.676 NQU22-CME/MNQU22-CME 512 Trades #14 | StartDateTimeForLoadingOrderFills: 2022-06-28 19:56:56 | 2022-07-15 17:37:57.678 NQU22-CME [CBV] 375 Volume #19 | Reloading chart. | 2022-07-15 17:37:57.712 NQU22-CME [CBV] 375 Volume #19 | Waiting for historical downloads to complete with the IDs: 22, | 2022-07-15 17:37:57.718 Mapping MNQU22-CME to MNQU22. Service code: cme | 2022-07-15 17:37:57.720 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-15 17:37:57.721 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-15 17:37:57.721 Triggering next historical data download in queue. | 2022-07-15 17:37:57.721 HD Request # 25 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-15 17:37:57.730 HD Request # 25 | Download start date-time: 2022-07-13 00:56:56.000000. File last date-time: 2022-07-13 00:56:56.885000 | 2022-07-15 17:37:57.731 HD Request # 25 | Using server: ds21.sierracharts.com port 10149 | 2022-07-15 17:37:57.731 NQU22-CME 1 Trades #21 | StartDateTimeForLoadingOrderFills: 2022-06-28 19:56:56 | 2022-07-15 17:37:57.796 Socket (6) | Creating socket. | 2022-07-15 17:37:57.818 Socket (6) | New receive buffer size: 5242880 | 2022-07-15 17:37:57.818 Socket (6) | Connecting to IP: 216.1.90.129. | 2022-07-15 17:37:57.818 HD Request # 25 | Setting DTC encoding to Binary VLS | 2022-07-15 17:37:57.863 HD Request # 25 | Sending historical data logon request message. | 2022-07-15 17:37:57.863 HD Request # 25 | Requesting Intraday data. Start date-time: 2022-07-13 00:56:56. Record interval: 0. Symbol: NQU22 | 2022-07-15 17:37:58.374 HD Request # 25 | Decompressing data. | 2022-07-15 17:37:58.398 HD Request # 25 | Receiving Intraday data for NQU22-CME starting at 2022-07-13 00:56:56.032000 | 2022-07-15 17:37:58.508 HD Request # 25 | Timestamp of first Intraday data file record written: 2022-07-13 00:57:02.728000 | 2022-07-15 17:37:58.663 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:00.140 HD Request # 24 | Receiving historical Daily data for NQU22-CME starting at 2022-07-08 | 2022-07-15 17:38:00.155 HD Request # 24 | Writing historical Daily data to the file NQU22-CME.dly | 2022-07-15 17:38:00.155 HD Request # 24 | Bytes received: 367 | 2022-07-15 17:38:00.156 HD Request # 24 | Received 6 Daily data records from 2022-07-08 00:00:00 to 2022-07-14 00:00:00 (7.0 days) and wrote 5 records for NQU22-CME | 2022-07-15 17:38:00.156 HD Request # 24 | Completion time: 4s | 2022-07-15 17:38:00.156 HD Request # 24 | Daily data download complete for NQU22-CME. Unique request ID: 22 | 2022-07-15 17:38:00.156 Removing historical data download ID 22. | 2022-07-15 17:38:00.156 Triggering next historical data download in queue. | 2022-07-15 17:38:00.156 No download requests in the queue to start downloads for. | 2022-07-15 17:38:00.740 NQU22-CME [CBV] 825 Trades #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:00.932 NQU22-CME [CBV] 825 Trades #23 | Reloading chart. | 2022-07-15 17:38:00.937 NQU22-CME [CBV] 3072 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:00.944 NQU22-CME [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-15 17:38:00.963 Symbol settings received. Request ID: 8. | 2022-07-15 17:38:01.184 Socket (6) | CloseSocket call. | 2022-07-15 17:38:01.238 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-07-15 17:38:01.238 Socket (6) | Socket gracefully closed by remote side. | 2022-07-15 17:38:01.261 Socket (6) | Closed. | 2022-07-15 17:38:01.261 Historical data download thread signaled to stop. | 2022-07-15 17:38:01.341 HD Request # 25 | Received 1630506 Intraday data records from 2022-07-13 00:56:56.032000 to 2022-07-15 17:27:53.686001 (2.7 days) and wrote 1630504 records for NQU22-CME | 2022-07-15 17:38:01.341 HD Request # 25 | Completion time: 4s | 2022-07-15 17:38:01.341 HD Request # 25 | Intraday data download complete for NQU22-CME. Unique request ID: 23 | 2022-07-15 17:38:01.341 Removing historical data download ID 23. | 2022-07-15 17:38:01.341 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2022-07-15 17:38:01.341 Triggering next historical data download in queue. | 2022-07-15 17:38:01.341 Historical data for NQU22-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-07-15 17:38:01.341 No download requests in the queue to start downloads for. | 2022-07-15 17:38:01.341 NQU22-CME [CBV] 7500 Volume #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:01.443 NQU22-CME [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-15 17:38:01.443 NQU22-CME [CBV] 5 Min #25 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:01.448 NQU22-CME [CBV] 5 Min #25 | Reloading chart. | 2022-07-15 17:38:01.471 NQU22-CME [CBV] 3072 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:01.488 NQU22-CME [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-15 17:38:01.512 NQU22-CME [CBV] 60 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:01.520 NQU22-CME [CBV] 60 Min #22 | Reloading chart. | 2022-07-15 17:38:01.552 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:01.730 NQU22-CME [CBV] 750 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:01.739 NQU22-CME [CBV] 750 Volume #1 | Reloading chart. | 2022-07-15 17:38:01.753 NQU22-CME [CBV] 7500 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:01.796 NQU22-CME [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-15 17:38:01.805 NQU22-CME [CBV-D] 15 Min #30 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:01.854 NQU22-CME [CBV] 15 Min #30 | Reloading chart. | 2022-07-15 17:38:01.890 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:01.967 NQU22-CME [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:01.977 NQU22-CME [CBV] 60 Min #15 | Reloading chart. | 2022-07-15 17:38:02.018 NQU22-CME [CBV] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:02.399 NQU22-CME [CBV] 30 Min #2 | Reloading chart. | 2022-07-15 17:38:02.523 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:35.196 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:35.224 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:35.224 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:35.236 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:36.874 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:36.874 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:36.874 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:36.874 NQU22-CME [CBV] 512 Trades #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.229 NQU22-CME [CBV] 512 Trades #5 | Reloading chart. | 2022-07-15 17:38:37.230 NQU22-CME [CBV] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.239 NQU22-CME [CBV] 1 Day #3 | Reloading chart. | 2022-07-15 17:38:37.256 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.364 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Reloading chart. | 2022-07-15 17:38:37.400 NQU22-CME [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.411 NQU22-CME [CBV] #16 | Reloading chart. | 2022-07-15 17:38:37.446 NQU22-CME [CBV] 240 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.653 NQU22-CME [CBV] 240 Min #9 | Reloading chart. | 2022-07-15 17:38:37.654 NQU22-CME [CBV] 60 Min #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.727 NQU22-CME [CBV] 60 Min #29 | Reloading chart. | 2022-07-15 17:38:37.729 NQU22-CME [CBV] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.849 NQU22-CME [CBV] 5 Min #6 | Reloading chart. | 2022-07-15 17:38:37.880 NQU22-CME [CBV] 5 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.909 NQU22-CME [CBV] 5 Min #12 | Reloading chart. | 2022-07-15 17:38:37.927 NQU22-CME [CBV] 1 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.963 NQU22-CME [CBV] 1 Min #27 | Reloading chart. | 2022-07-15 17:38:37.963 NQU22-CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:37.972 NQU22-CME [CBV] 15 Min #10 | Reloading chart. | 2022-07-15 17:38:37.972 NQU22-CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:38.361 NQU22-CME [CBV] 60 Min #8 | Reloading chart. | 2022-07-15 17:38:38.427 NQU22-CME [CBV] 750 Volume #26 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:38.732 NQU22-CME [CBV] 750 Volume #26 | Reloading chart. | 2022-07-15 17:38:38.759 NQU22-CME [CBV] 375 Volume #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-15 17:38:39.067 NQU22-CME [CBV] 375 Volume #19 | Reloading chart. | 2022-07-15 17:38:39.067 SC Data - All Services | Connected to server complete. | 2022-07-15 17:38:39.081 Triggering next historical data download in queue. | 2022-07-15 17:38:39.085 Triggering next historical data download in queue. | 2022-07-15 17:38:39.085 Triggering next historical data download in queue. | 2022-07-15 17:38:39.085 Triggering next historical data download in queue. | 2022-07-15 17:38:39.085 Subscribing to symbol for symbol alert. MNQM22-CME | 2022-07-15 17:38:39.085 Mapping MNQM22-CME to MNQM22. Service code: cme | 2022-07-15 17:38:39.085 Using symbol data fast lookup vector | 2022-07-15 17:38:39.085 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MNQM22-CME (MNQM22). ID: 1 Service code: cme | 2022-07-15 17:38:39.085 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-07-15 17:38:39.085 SC DTC Delayed Exchange Data | Requesting security definition data for: MNQM22-CME (MNQM22). ID: 1 | 2022-07-15 17:38:39.086 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:39.087 No download requests in the queue to start downloads for. | 2022-07-15 17:38:39.098 No download requests in the queue to start downloads for. | 2022-07-15 17:38:39.098 No download requests in the queue to start downloads for. | 2022-07-15 17:38:39.099 No download requests in the queue to start downloads for. | 2022-07-15 17:38:39.099 DTC Client socket (3) | Creating socket. | 2022-07-15 17:38:39.242 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-07-15 17:38:39.242 DTC Client socket (3) | Connecting to IP: 216.1.90.130. | 2022-07-15 17:38:39.242 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-15 17:38:39.310 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-15 17:38:39.310 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-15 17:38:39.310 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-15 17:38:39.615 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-15 17:38:39.615 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:40.059 Mapping NQU22-CME to NQU22. Service code: cme | 2022-07-15 17:38:40.097 SC DTC Delayed Exchange Data | Starting real-time market data updates for: NQU22-CME (NQU22). ID: 2 Service code: cme | 2022-07-15 17:38:40.097 SC DTC Delayed Exchange Data | Requesting security definition data for: NQU22-CME (NQU22). ID: 2 | 2022-07-15 17:38:40.097 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-15 17:38:40.097 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-15 17:38:40.097 Triggering next historical data download in queue. | 2022-07-15 17:38:40.097 Delaying start of download for NQU22-CME | 2022-07-15 17:38:40.266 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-15 17:38:40.309 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-15 17:38:40.309 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-15 17:38:40.309 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-15 17:38:40.309 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-15 17:38:40.309 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-15 17:38:40.309 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-15 17:38:40.309 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:40.491 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:40.491 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-15 17:38:40.507 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-15 17:38:40.507 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-15 17:38:40.507 NQU22-CME [CBV] 825 Trades #23 | Reloading chart. | 2022-07-15 17:38:41.291 NQU22-CME [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-15 17:38:41.378 NQU22-CME [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-15 17:38:41.408 NQU22-CME [CBV] 5 Min #25 | Reloading chart. | 2022-07-15 17:38:41.448 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:41.822 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:42.459 NQU22-CME [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-15 17:38:42.523 NQU22-CME [CBV] 60 Min #22 | Reloading chart. | 2022-07-15 17:38:42.559 NQU22-CME [CBV] 750 Volume #1 | Reloading chart. | 2022-07-15 17:38:42.747 NQU22-CME [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-15 17:38:42.959 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:43.271 NQU22-CME [CBV] 15 Min #30 | StartDateTimeForLoadingOrderFills: 2022-03-17 15:00:00 | 2022-07-15 17:38:43.444 NQU22-CME [CBV] 15 Min #30 | Reloading chart. | 2022-07-15 17:38:44.357 NQU22-CME [CBV] 60 Min #15 | Reloading chart. | 2022-07-15 17:38:44.650 Mapping MNQU22-CME to MNQU22. Service code: cme | 2022-07-15 17:38:45.013 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MNQU22-CME (MNQU22). ID: 3 Service code: cme | 2022-07-15 17:38:45.013 SC DTC Delayed Exchange Data | Requesting security definition data for: MNQU22-CME (MNQU22). ID: 3 | 2022-07-15 17:38:45.013 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:48.856 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-15 17:38:48.892 NQU22-CME [CBV] 30 Min #2 | Reloading chart. | 2022-07-15 17:38:48.897 NQU22-CME [CBV] 512 Trades #5 | Reloading chart. | 2022-07-15 17:38:50.613 NQU22-CME [CBV] 1 Day #3 | Reloading chart. | 2022-07-15 17:38:50.672 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Reloading chart. | 2022-07-15 17:38:51.242 NQU22-CME [CBV] #16 | Reloading chart. | 2022-07-15 17:38:51.258 NQU22-CME [CBV] 240 Min #9 | Reloading chart. | 2022-07-15 17:38:51.426 NQU22-CME [CBV] 60 Min #29 | Reloading chart. | 2022-07-15 17:38:51.638 NQU22-CME [CBV] 5 Min #6 | Reloading chart. | 2022-07-15 17:38:51.949 NQU22-CME [CBV] 5 Min #12 | Reloading chart. | 2022-07-15 17:38:54.858 NQU22-CME [CBV] 15 Min #10 | Reloading chart. | 2022-07-15 17:38:55.093 NQU22-CME [CBV] 1 Min #27 | Reloading chart. | 2022-07-15 17:38:55.151 NQU22-CME [CBV] 60 Min #8 | Reloading chart. | 2022-07-15 17:38:55.324 NQU22-CME [CBV] 750 Volume #26 | Reloading chart. | 2022-07-15 17:38:55.343 NQU22-CME [CBV] 375 Volume #19 | Reloading chart. | 2022-07-15 17:38:55.564 HD Request # 26 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-15 17:38:55.674 HD Request # 26 | Download start date-time: 2022-07-15 17:27:53.000000. File last date-time: 2022-07-15 17:27:53.686001 | 2022-07-15 17:38:55.675 HD Request # 26 | Using server: ds23.sierracharts.com port 10150 | 2022-07-15 17:38:55.675 Socket (4) | Creating socket. | 2022-07-15 17:38:55.675 Socket (4) | New receive buffer size: 5242880 | 2022-07-15 17:38:55.675 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-07-15 17:38:55.675 HD Request # 26 | Setting DTC encoding to Binary VLS | 2022-07-15 17:38:55.752 HD Request # 26 | Sending historical data logon request message. | 2022-07-15 17:38:55.752 HD Request # 26 | Requesting Intraday data. Start date-time: 2022-07-15 17:27:53. Record interval: 0. Symbol: NQU22 | 2022-07-15 17:38:56.329 HD Request # 26 | Decompressing data. | 2022-07-15 17:38:56.360 HD Request # 26 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 17:27:53.253000 | 2022-07-15 17:38:56.360 Socket (4) | CloseSocket call. | 2022-07-15 17:38:56.361 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-07-15 17:38:56.361 Socket (4) | Socket gracefully closed by remote side. | 2022-07-15 17:38:56.390 Socket (4) | Closed. | 2022-07-15 17:38:56.390 Historical data download thread signaled to stop. | 2022-07-15 17:38:57.268 HD Request # 26 | Timestamp of first Intraday data file record written: 2022-07-15 17:27:54.171000 | 2022-07-15 17:38:57.268 HD Request # 26 | Received 598 Intraday data records from 2022-07-15 17:27:53.253000 to 2022-07-15 17:28:48.923000 (55.7 seconds) and wrote 591 records for NQU22-CME | 2022-07-15 17:38:57.268 HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2022-07-15 17:28:48.923000 | 2022-07-15 17:38:57.276 HD Request # 26 | Completion time: 2s | 2022-07-15 17:38:57.358 HD Request # 26 | Intraday data download complete for NQU22-CME. Unique request ID: 24 | 2022-07-15 17:38:57.358 Removing historical data download ID 24. | 2022-07-15 17:38:57.358 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-15 17:38:57.358 Intraday chart data file opened for NQU22-CME | 2022-07-15 17:38:57.358 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2022-07-15 17:38:57.358 Triggering next historical data download in queue. | 2022-07-15 17:38:57.370 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:57.579 No download requests in the queue to start downloads for. | 2022-07-15 17:38:57.589 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 11812 | 2022-07-15 17:38:57.630 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:38:58.622 CQG WebSocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-15 17:39:12.939 CQG WebSocket socket (1) | Closed. | 2022-07-15 17:39:12.940 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:17.489 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:17.489 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:17.489 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:21.552 NQU22-CME [CBV][M] 15 Min #30 | StartDateTimeForLoadingOrderFills: 2022-03-17 15:00:00 | 2022-07-15 17:39:23.005 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:23.289 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:23.375 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:24.051 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:24.098 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:24.347 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:24.418 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:24.421 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 17:39:24.618 CQG WebSocket socket (1) | Deleting network socket now after delay. | 2022-07-15 17:39:42.951 CQG WebSocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-15 17:40:12.952 CQG WebSocket socket (2) | Closed. | 2022-07-15 17:40:12.952 CQG WebSocket socket (2) | Deleting network socket now after delay. | 2022-07-15 17:40:42.965 DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-15 20:43:22.525 * DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-07-15 20:43:22.525 DTC Client socket (3) | CloseSocket call. | 2022-07-15 20:43:22.526 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-15 20:43:22.526 DTC Client socket (3) | Closed. | 2022-07-15 20:43:22.526 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-15 20:43:22.527 DTC Client socket (0) | CloseSocket call. | 2022-07-15 20:43:22.528 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-15 20:43:22.528 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-15 20:43:22.528 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-07-15 20:43:24.533 DTC Client socket (1) | Creating socket. | 2022-07-15 20:43:24.534 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-15 20:43:24.534 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-07-15 20:43:24.534 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-15 20:43:24.558 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-15 20:43:24.558 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-15 20:43:24.558 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-15 20:43:24.607 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-15 20:43:24.607 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-15 20:43:25.236 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-15 20:43:25.236 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-15 20:43:25.236 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-15 20:43:25.236 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-15 20:43:25.236 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-15 20:43:25.236 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-15 20:43:25.236 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-15 20:43:25.237 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-15 20:43:25.237 Triggering next historical data download in queue. | 2022-07-15 20:43:25.237 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-15 20:43:25.237 HD Request # 27 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-15 20:43:25.237 HD Request # 27 | Download start date-time: 2022-07-15 20:32:40.000000. File last date-time: 2022-07-15 20:32:40.600001 | 2022-07-15 20:43:25.237 HD Request # 27 | Using server: ds21.sierracharts.com port 10149 | 2022-07-15 20:43:25.237 Socket (2) | Creating socket. | 2022-07-15 20:43:25.238 Socket (2) | New receive buffer size: 5242880 | 2022-07-15 20:43:25.238 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-07-15 20:43:25.238 HD Request # 27 | Setting DTC encoding to Binary VLS | 2022-07-15 20:43:25.289 HD Request # 27 | Sending historical data logon request message. | 2022-07-15 20:43:25.289 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-15 20:43:25.474 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-15 20:43:25.474 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-15 20:43:25.474 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-15 20:43:25.474 HD Request # 27 | Requesting Intraday data. Start date-time: 2022-07-15 20:32:40. Record interval: 0. Symbol: NQU22 | 2022-07-15 20:43:25.763 HD Request # 27 | Decompressing data. | 2022-07-15 20:43:25.783 HD Request # 27 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:32:40.600000 | 2022-07-15 20:43:25.784 Socket (2) | CloseSocket call. | 2022-07-15 20:43:25.784 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-15 20:43:25.784 Socket (2) | Socket gracefully closed by remote side. | 2022-07-15 20:43:25.808 Socket (2) | Closed. | 2022-07-15 20:43:25.808 Historical data download thread signaled to stop. | 2022-07-15 20:43:25.814 HD Request # 27 | Timestamp of first Intraday data file record written: 2022-07-15 20:32:42.519000 | 2022-07-15 20:43:25.814 HD Request # 27 | Received 39 Intraday data records from 2022-07-15 20:32:40.600000 to 2022-07-15 20:33:15.506001 (34.9 seconds) and wrote 37 records for NQU22-CME | 2022-07-15 20:43:25.814 HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:33:15.506001 | 2022-07-15 20:43:25.823 HD Request # 27 | Completion time: 0s | 2022-07-15 20:43:25.823 HD Request # 27 | Intraday data download complete for NQU22-CME. Unique request ID: 25 | 2022-07-15 20:43:25.823 Removing historical data download ID 25. | 2022-07-15 20:43:25.823 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-15 20:43:25.823 Intraday chart data file opened for NQU22-CME | 2022-07-15 20:43:25.823 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2022-07-15 20:43:25.823 Triggering next historical data download in queue. | 2022-07-15 20:43:25.823 No download requests in the queue to start downloads for. | 2022-07-15 20:43:25.823 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.836 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.860 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.921 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.930 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.930 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.937 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.941 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.941 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.955 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.958 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.961 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.961 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.964 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.970 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:26.985 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.012 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.019 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.019 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.019 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.019 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.034 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.043 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.067 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.300 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.347 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 20496 | 2022-07-15 20:43:27.761 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:27.768 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:28.656 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 20:43:28.790 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-15 21:08:35.735 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-15 21:08:35.735 DTC Client socket (1) | CloseSocket call. | 2022-07-15 21:08:35.736 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-15 21:08:35.736 DTC Client socket (1) | Closed. | 2022-07-15 21:08:35.736 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-15 21:08:35.736 DTC Client socket (0) | CloseSocket call. | 2022-07-15 21:08:35.737 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-15 21:08:35.737 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-15 21:08:35.737 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-07-15 21:08:37.736 DTC Client socket (1) | Creating socket. | 2022-07-15 21:08:37.869 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-15 21:08:37.869 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2022-07-15 21:08:37.869 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-15 21:08:37.994 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-15 21:08:37.994 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-15 21:08:37.995 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-15 21:08:38.068 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-15 21:08:38.068 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-15 21:08:38.723 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-15 21:08:38.723 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-15 21:08:38.723 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-15 21:08:38.723 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-15 21:08:38.723 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-15 21:08:38.724 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-15 21:08:38.724 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-15 21:08:38.724 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-15 21:08:38.724 Triggering next historical data download in queue. | 2022-07-15 21:08:38.724 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-15 21:08:38.724 HD Request # 28 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-15 21:08:38.724 HD Request # 28 | Download start date-time: 2022-07-15 20:57:46.000000. File last date-time: 2022-07-15 20:57:46.856000 | 2022-07-15 21:08:38.725 HD Request # 28 | Using server: ds23.sierracharts.com port 10150 | 2022-07-15 21:08:38.725 Socket (2) | Creating socket. | 2022-07-15 21:08:38.726 Socket (2) | New receive buffer size: 5242880 | 2022-07-15 21:08:38.726 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-07-15 21:08:38.726 HD Request # 28 | Setting DTC encoding to Binary VLS | 2022-07-15 21:08:38.773 HD Request # 28 | Sending historical data logon request message. | 2022-07-15 21:08:38.773 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-15 21:08:38.906 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-15 21:08:38.906 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-15 21:08:38.906 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-15 21:08:38.906 HD Request # 28 | Requesting Intraday data. Start date-time: 2022-07-15 20:57:46. Record interval: 0. Symbol: NQU22 | 2022-07-15 21:08:39.256 HD Request # 28 | Decompressing data. | 2022-07-15 21:08:39.281 HD Request # 28 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:57:46.753000 | 2022-07-15 21:08:39.282 Socket (2) | CloseSocket call. | 2022-07-15 21:08:39.282 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-15 21:08:39.282 Historical data download thread signaled to stop. | 2022-07-15 21:08:39.284 HD Request # 28 | Timestamp of first Intraday data file record written: 2022-07-15 20:57:47.763000 | 2022-07-15 21:08:39.284 HD Request # 28 | Received 63 Intraday data records from 2022-07-15 20:57:46.753000 to 2022-07-15 20:58:31.025000 (44.3 seconds) and wrote 54 records for NQU22-CME | 2022-07-15 21:08:39.284 HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:58:31.025000 | 2022-07-15 21:08:39.289 HD Request # 28 | Completion time: 1s | 2022-07-15 21:08:39.289 HD Request # 28 | Intraday data download complete for NQU22-CME. Unique request ID: 26 | 2022-07-15 21:08:39.289 Removing historical data download ID 26. | 2022-07-15 21:08:39.289 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-15 21:08:39.289 Intraday chart data file opened for NQU22-CME | 2022-07-15 21:08:39.289 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2022-07-15 21:08:39.289 Triggering next historical data download in queue. | 2022-07-15 21:08:39.289 No download requests in the queue to start downloads for. | 2022-07-15 21:08:39.289 Socket (2) | Socket gracefully closed by remote side. | 2022-07-15 21:08:39.307 Socket (2) | Closed. | 2022-07-15 21:08:39.307 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.863 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.873 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.873 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.877 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.881 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.881 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.902 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.905 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.909 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.909 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.911 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.915 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.932 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.954 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.962 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.962 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.962 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.962 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.969 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.972 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:39.989 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:40.107 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:40.147 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 17732 | 2022-07-15 21:08:40.860 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:40.942 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:41.036 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:41.234 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:41.256 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:41.258 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 21:08:41.606 SC DTC Delayed Exchange Data | There has been no activity on the network socket for 1m. Will reconnect. | 2022-07-15 22:46:37.752 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-15 22:46:37.752 DTC Client socket (1) | CloseSocket call. | 2022-07-15 22:46:37.754 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-15 22:46:37.754 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-15 22:46:37.754 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-15 22:46:37.754 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-07-15 22:46:39.747 DTC Client socket (2) | Creating socket. | 2022-07-15 22:46:39.748 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-07-15 22:46:39.748 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-07-15 22:46:39.748 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-15 22:46:39.774 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-15 22:46:39.774 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-15 22:46:39.775 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-15 22:46:39.823 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-15 22:46:39.823 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-15 22:46:40.447 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-15 22:46:40.447 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-15 22:46:40.447 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-15 22:46:40.447 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-15 22:46:40.448 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-15 22:46:40.448 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-15 22:46:40.448 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-15 22:46:40.448 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-15 22:46:40.448 Triggering next historical data download in queue. | 2022-07-15 22:46:40.448 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-15 22:46:40.448 HD Request # 29 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-15 22:46:40.448 HD Request # 29 | Download start date-time: 2022-07-15 20:59:59.000000. File last date-time: 2022-07-15 20:59:59.827000 | 2022-07-15 22:46:40.449 HD Request # 29 | Using server: ds21.sierracharts.com port 10149 | 2022-07-15 22:46:40.449 Socket (3) | Creating socket. | 2022-07-15 22:46:40.451 Socket (3) | New receive buffer size: 5242880 | 2022-07-15 22:46:40.451 Socket (3) | Connecting to IP: 216.1.90.129. | 2022-07-15 22:46:40.451 HD Request # 29 | Setting DTC encoding to Binary VLS | 2022-07-15 22:46:40.500 HD Request # 29 | Sending historical data logon request message. | 2022-07-15 22:46:40.501 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-15 22:46:40.632 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-15 22:46:40.632 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-15 22:46:40.632 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-15 22:46:40.632 HD Request # 29 | Requesting Intraday data. Start date-time: 2022-07-15 20:59:59. Record interval: 0. Symbol: NQU22 | 2022-07-15 22:46:41.045 HD Request # 29 | Decompressing data. | 2022-07-15 22:46:41.081 HD Request # 29 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:59:59.100000 | 2022-07-15 22:46:41.094 Socket (3) | CloseSocket call. | 2022-07-15 22:46:41.094 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-15 22:46:41.094 Historical data download thread signaled to stop. | 2022-07-15 22:46:41.094 HD Request # 29 | Received 6 Intraday data records from 2022-07-15 20:59:59.100000 to 2022-07-15 20:59:59.827000 (0.7 seconds) and wrote 0 records for NQU22-CME | 2022-07-15 22:46:41.094 HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:59:59.827000 | 2022-07-15 22:46:41.095 HD Request # 29 | Completion time: 1s | 2022-07-15 22:46:41.095 HD Request # 29 | Intraday data download complete for NQU22-CME. Unique request ID: 27 | 2022-07-15 22:46:41.095 Removing historical data download ID 27. | 2022-07-15 22:46:41.095 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-15 22:46:41.095 Intraday chart data file opened for NQU22-CME | 2022-07-15 22:46:41.095 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2022-07-15 22:46:41.095 Triggering next historical data download in queue. | 2022-07-15 22:46:41.095 No download requests in the queue to start downloads for. | 2022-07-15 22:46:41.095 Socket (3) | Socket gracefully closed by remote side. | 2022-07-15 22:46:41.126 Socket (3) | Closed. | 2022-07-15 22:46:41.126 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:41.651 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:41.651 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:41.651 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:41.651 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:41.660 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:41.666 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:41.688 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:41.843 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:41.896 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.854 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.877 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.880 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.938 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.954 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.954 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.960 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.963 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.963 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.974 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.979 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.982 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.982 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.984 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:42.989 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:43.008 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:43.031 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:43.232 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-15 22:46:43.246 DTC Client socket (1) | Timed out waiting for final send. Canceling I/O. | 2022-07-15 22:47:47.670 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2022-07-15 22:47:47.670 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-15 22:47:47.670 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-15 22:47:47.670 DTC Client socket (1) | Closed. | 2022-07-15 22:47:47.670 SC DTC Delayed Exchange Data | Real-time data for symbol MNQU22-CME is currently unavailable. | 2022-07-16 07:38:29.436 SC DTC Delayed Exchange Data | Real-time data for symbol NQU22-CME is currently unavailable. | 2022-07-16 07:38:29.436 SC DTC Delayed Exchange Data | Real-time data for symbol MNQU22-CME is currently unavailable. | 2022-07-16 07:38:29.436 SC DTC Delayed Exchange Data | Real-time data for symbol NQU22-CME is currently unavailable. | 2022-07-16 07:38:29.436 SC DTC Delayed Exchange Data | Real-time data for symbol MNQU22-CME is currently unavailable. | 2022-07-16 07:38:41.472 SC DTC Delayed Exchange Data | Real-time data for symbol NQU22-CME is currently unavailable. | 2022-07-16 07:38:41.472 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-16 07:39:40.416 SC DTC Delayed Exchange Data | Real-time data for symbol MNQU22-CME has been restored. | 2022-07-16 07:39:40.416 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-16 07:39:40.416 SC DTC Delayed Exchange Data | Real-time data for symbol NQU22-CME has been restored. | 2022-07-16 07:39:40.416 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-16 07:39:40.416 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-16 07:39:40.416 Triggering next historical data download in queue. | 2022-07-16 07:39:40.416 HD Request # 30 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-16 07:39:40.416 HD Request # 30 | Download start date-time: 2022-07-15 20:59:59.000000. File last date-time: 2022-07-15 20:59:59.827000 | 2022-07-16 07:39:40.417 HD Request # 30 | Using server: ds23.sierracharts.com port 10150 | 2022-07-16 07:39:40.417 Socket (1) | Creating socket. | 2022-07-16 07:39:40.457 Socket (1) | New receive buffer size: 5242880 | 2022-07-16 07:39:40.457 Socket (1) | Connecting to IP: 216.1.90.130. | 2022-07-16 07:39:40.457 HD Request # 30 | Setting DTC encoding to Binary VLS | 2022-07-16 07:39:40.555 HD Request # 30 | Sending historical data logon request message. | 2022-07-16 07:39:40.555 HD Request # 30 | Requesting Intraday data. Start date-time: 2022-07-15 20:59:59. Record interval: 0. Symbol: NQU22 | 2022-07-16 07:39:41.184 HD Request # 30 | Decompressing data. | 2022-07-16 07:39:41.205 HD Request # 30 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:59:59.100000 | 2022-07-16 07:39:41.206 Socket (1) | CloseSocket call. | 2022-07-16 07:39:41.206 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-16 07:39:41.206 Historical data download thread signaled to stop. | 2022-07-16 07:39:41.206 HD Request # 30 | Received 6 Intraday data records from 2022-07-15 20:59:59.100000 to 2022-07-15 20:59:59.827000 (0.7 seconds) and wrote 0 records for NQU22-CME | 2022-07-16 07:39:41.206 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:59:59.827000 | 2022-07-16 07:39:41.207 HD Request # 30 | Completion time: 1s | 2022-07-16 07:39:41.207 HD Request # 30 | Intraday data download complete for NQU22-CME. Unique request ID: 28 | 2022-07-16 07:39:41.207 Removing historical data download ID 28. | 2022-07-16 07:39:41.207 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-16 07:39:41.207 Intraday chart data file opened for NQU22-CME | 2022-07-16 07:39:41.207 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2022-07-16 07:39:41.207 Triggering next historical data download in queue. | 2022-07-16 07:39:41.207 No download requests in the queue to start downloads for. | 2022-07-16 07:39:41.207 Socket (1) | Socket gracefully closed by remote side. | 2022-07-16 07:39:41.232 Socket (1) | Closed. | 2022-07-16 07:39:41.232 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:41.710 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:41.710 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:41.710 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:41.710 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:41.718 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:41.730 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:41.751 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:41.896 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:41.936 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.836 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.855 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.857 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.897 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.905 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.905 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.915 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.923 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.923 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.934 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.939 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.942 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.942 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.948 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.952 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.967 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:42.988 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:43.187 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:39:43.200 SC DTC Delayed Exchange Data | Real-time data for symbol MNQU22-CME has been restored. | 2022-07-16 07:49:50.592 SC DTC Delayed Exchange Data | Real-time data for symbol NQU22-CME has been restored. | 2022-07-16 07:49:50.592 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-16 07:49:50.592 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-16 07:49:50.592 Triggering next historical data download in queue. | 2022-07-16 07:49:50.592 HD Request # 31 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-16 07:49:50.592 HD Request # 31 | Download start date-time: 2022-07-15 20:59:59.000000. File last date-time: 2022-07-15 20:59:59.827000 | 2022-07-16 07:49:50.593 HD Request # 31 | Using server: ds21.sierracharts.com port 10149 | 2022-07-16 07:49:50.593 Socket (1) | Creating socket. | 2022-07-16 07:49:50.642 Socket (1) | New receive buffer size: 5242880 | 2022-07-16 07:49:50.642 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-07-16 07:49:50.643 HD Request # 31 | Setting DTC encoding to Binary VLS | 2022-07-16 07:49:50.689 HD Request # 31 | Sending historical data logon request message. | 2022-07-16 07:49:50.689 HD Request # 31 | Requesting Intraday data. Start date-time: 2022-07-15 20:59:59. Record interval: 0. Symbol: NQU22 | 2022-07-16 07:49:51.778 HD Request # 31 | Decompressing data. | 2022-07-16 07:49:51.804 HD Request # 31 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:59:59.100000 | 2022-07-16 07:49:51.804 Socket (1) | CloseSocket call. | 2022-07-16 07:49:51.804 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-16 07:49:51.805 Socket (1) | Socket gracefully closed by remote side. | 2022-07-16 07:49:51.827 Socket (1) | Closed. | 2022-07-16 07:49:51.827 Historical data download thread signaled to stop. | 2022-07-16 07:49:51.845 HD Request # 31 | Received 6 Intraday data records from 2022-07-15 20:59:59.100000 to 2022-07-15 20:59:59.827000 (0.7 seconds) and wrote 0 records for NQU22-CME | 2022-07-16 07:49:51.845 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:59:59.827000 | 2022-07-16 07:49:51.845 HD Request # 31 | Completion time: 1s | 2022-07-16 07:49:51.845 HD Request # 31 | Intraday data download complete for NQU22-CME. Unique request ID: 29 | 2022-07-16 07:49:51.845 Removing historical data download ID 29. | 2022-07-16 07:49:51.845 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-16 07:49:51.845 Intraday chart data file opened for NQU22-CME | 2022-07-16 07:49:51.845 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2022-07-16 07:49:51.845 Triggering next historical data download in queue. | 2022-07-16 07:49:51.845 No download requests in the queue to start downloads for. | 2022-07-16 07:49:51.845 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.334 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.361 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.407 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.417 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.417 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.423 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.428 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.428 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.439 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.443 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.447 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.447 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.450 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.455 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.469 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.489 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.495 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.495 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.495 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.495 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.500 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.505 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.528 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.683 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.884 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:52.930 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:53.682 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:53.823 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 07:49:54.003 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-16 12:21:26.571 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-07-16 12:21:26.571 DTC Client socket (2) | CloseSocket call. | 2022-07-16 12:21:26.572 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-16 12:21:26.572 DTC Client socket (2) | Closed. | 2022-07-16 12:21:26.572 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-16 12:21:26.573 DTC Client socket (0) | CloseSocket call. | 2022-07-16 12:21:26.574 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-16 12:21:26.574 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-16 12:21:26.574 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-07-16 12:21:28.574 DTC Client socket (1) | Creating socket. | 2022-07-16 12:21:28.575 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-16 12:21:28.575 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-07-16 12:21:28.575 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-16 12:21:28.641 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-16 12:21:28.641 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-16 12:21:28.641 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-16 12:21:28.684 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-16 12:21:28.684 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-16 12:21:29.324 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-16 12:21:29.324 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-16 12:21:29.324 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-16 12:21:29.324 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-16 12:21:29.324 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-16 12:21:29.324 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-16 12:21:29.324 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-16 12:21:29.324 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-16 12:21:29.324 Triggering next historical data download in queue. | 2022-07-16 12:21:29.324 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-16 12:21:29.324 HD Request # 32 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-16 12:21:29.324 HD Request # 32 | Download start date-time: 2022-07-15 20:59:59.000000. File last date-time: 2022-07-15 20:59:59.827000 | 2022-07-16 12:21:29.325 HD Request # 32 | Using server: ds23.sierracharts.com port 10150 | 2022-07-16 12:21:29.325 Socket (2) | Creating socket. | 2022-07-16 12:21:29.326 Socket (2) | New receive buffer size: 5242880 | 2022-07-16 12:21:29.326 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-07-16 12:21:29.326 HD Request # 32 | Setting DTC encoding to Binary VLS | 2022-07-16 12:21:29.385 HD Request # 32 | Sending historical data logon request message. | 2022-07-16 12:21:29.385 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-16 12:21:29.464 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-16 12:21:29.464 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-16 12:21:29.464 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-16 12:21:29.464 HD Request # 32 | Requesting Intraday data. Start date-time: 2022-07-15 20:59:59. Record interval: 0. Symbol: NQU22 | 2022-07-16 12:21:29.975 HD Request # 32 | Decompressing data. | 2022-07-16 12:21:29.998 HD Request # 32 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:59:59.100000 | 2022-07-16 12:21:29.998 Socket (2) | CloseSocket call. | 2022-07-16 12:21:29.998 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-16 12:21:29.998 Historical data download thread signaled to stop. | 2022-07-16 12:21:29.998 HD Request # 32 | Received 6 Intraday data records from 2022-07-15 20:59:59.100000 to 2022-07-15 20:59:59.827000 (0.7 seconds) and wrote 0 records for NQU22-CME | 2022-07-16 12:21:29.998 HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:59:59.827000 | 2022-07-16 12:21:29.999 HD Request # 32 | Completion time: 0s | 2022-07-16 12:21:29.999 HD Request # 32 | Intraday data download complete for NQU22-CME. Unique request ID: 30 | 2022-07-16 12:21:29.999 Removing historical data download ID 30. | 2022-07-16 12:21:29.999 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-16 12:21:29.999 Intraday chart data file opened for NQU22-CME | 2022-07-16 12:21:29.999 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2022-07-16 12:21:29.999 Triggering next historical data download in queue. | 2022-07-16 12:21:29.999 No download requests in the queue to start downloads for. | 2022-07-16 12:21:29.999 Socket (2) | Socket gracefully closed by remote side. | 2022-07-16 12:21:30.022 Socket (2) | Closed. | 2022-07-16 12:21:30.022 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.420 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.420 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.423 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.423 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.423 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.423 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.423 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.423 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.424 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.432 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.433 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.433 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.433 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.433 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.434 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.434 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.436 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.436 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.436 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.436 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.436 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.447 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.447 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.449 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:30.450 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:31.884 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:31.908 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 12:21:32.184 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-16 16:32:12.650 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-16 16:32:12.650 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-16 16:32:12.650 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-16 16:32:12.650 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-16 16:32:12.650 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-16 16:32:12.650 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-16 16:34:16.770 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-16 16:34:16.770 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-16 16:34:16.770 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-16 16:34:16.770 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-16 16:34:16.770 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-16 16:34:16.770 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-16 20:29:59.707 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-16 20:29:59.707 DTC Client socket (1) | CloseSocket call. | 2022-07-16 20:29:59.708 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-16 20:29:59.708 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-16 20:29:59.708 DTC Client socket (1) | Closed. | 2022-07-16 20:29:59.708 DTC Client socket (0) | CloseSocket call. | 2022-07-16 20:29:59.709 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-16 20:29:59.709 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-16 20:29:59.709 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-07-16 20:30:01.708 DTC Client socket (1) | Creating socket. | 2022-07-16 20:30:01.871 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-16 20:30:01.871 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2022-07-16 20:30:01.871 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-16 20:30:01.930 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-16 20:30:01.930 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-16 20:30:01.930 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-16 20:30:02.075 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-16 20:30:02.075 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-16 20:30:02.743 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-16 20:30:02.743 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-16 20:30:02.743 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-16 20:30:02.743 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-16 20:30:02.743 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-16 20:30:02.743 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-16 20:30:02.743 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-16 20:30:02.744 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-16 20:30:02.744 Triggering next historical data download in queue. | 2022-07-16 20:30:02.744 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-16 20:30:02.744 HD Request # 33 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-16 20:30:02.744 HD Request # 33 | Download start date-time: 2022-07-15 20:59:59.000000. File last date-time: 2022-07-15 20:59:59.827000 | 2022-07-16 20:30:02.745 HD Request # 33 | Using server: ds21.sierracharts.com port 10149 | 2022-07-16 20:30:02.745 Socket (3) | Creating socket. | 2022-07-16 20:30:02.919 Socket (3) | New receive buffer size: 5242880 | 2022-07-16 20:30:02.919 Socket (3) | Connecting to IP: 216.1.90.129. | 2022-07-16 20:30:02.919 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-16 20:30:02.919 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-16 20:30:02.919 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-16 20:30:02.919 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-16 20:30:02.920 HD Request # 33 | Setting DTC encoding to Binary VLS | 2022-07-16 20:30:02.979 HD Request # 33 | Sending historical data logon request message. | 2022-07-16 20:30:02.979 HD Request # 33 | Requesting Intraday data. Start date-time: 2022-07-15 20:59:59. Record interval: 0. Symbol: NQU22 | 2022-07-16 20:30:03.519 HD Request # 33 | Decompressing data. | 2022-07-16 20:30:03.543 HD Request # 33 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:59:59.100000 | 2022-07-16 20:30:03.544 Socket (3) | CloseSocket call. | 2022-07-16 20:30:03.544 Historical data download thread signaled to stop. | 2022-07-16 20:30:03.544 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-16 20:30:03.544 HD Request # 33 | Received 6 Intraday data records from 2022-07-15 20:59:59.100000 to 2022-07-15 20:59:59.827000 (0.7 seconds) and wrote 0 records for NQU22-CME | 2022-07-16 20:30:03.544 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:59:59.827000 | 2022-07-16 20:30:03.544 HD Request # 33 | Completion time: 1s | 2022-07-16 20:30:03.544 HD Request # 33 | Intraday data download complete for NQU22-CME. Unique request ID: 31 | 2022-07-16 20:30:03.545 Removing historical data download ID 31. | 2022-07-16 20:30:03.545 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-16 20:30:03.545 Intraday chart data file opened for NQU22-CME | 2022-07-16 20:30:03.545 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2022-07-16 20:30:03.545 Triggering next historical data download in queue. | 2022-07-16 20:30:03.545 No download requests in the queue to start downloads for. | 2022-07-16 20:30:03.547 Socket (3) | Socket gracefully closed by remote side. | 2022-07-16 20:30:03.568 Socket (3) | Closed. | 2022-07-16 20:30:03.568 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.784 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.785 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.787 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.787 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.787 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.787 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.788 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.788 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.788 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.794 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.795 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.795 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.795 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.795 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.796 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.796 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.796 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.796 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.797 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.797 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.797 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.803 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.803 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.804 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:03.804 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:04.935 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:04.958 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-16 20:30:05.128 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-17 16:04:24.381 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-17 16:04:24.381 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-17 16:04:24.381 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-17 16:04:24.381 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-17 16:04:24.381 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-17 16:04:24.381 SC DTC Delayed Exchange Data | There has been no activity on the network socket for 1m 2s. Will reconnect. | 2022-07-17 19:21:21.953 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-17 19:21:21.953 DTC Client socket (1) | CloseSocket call. | 2022-07-17 19:21:21.953 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-17 19:21:21.953 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-17 19:21:21.953 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-17 19:21:21.953 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-07-17 19:21:23.948 DTC Client socket (2) | Creating socket. | 2022-07-17 19:21:24.086 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-07-17 19:21:24.086 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-07-17 19:21:24.086 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-17 19:21:24.113 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-17 19:21:24.113 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-17 19:21:24.113 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-17 19:21:24.159 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-17 19:21:24.159 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-17 19:21:24.751 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-17 19:21:24.751 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-17 19:21:24.751 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-17 19:21:24.751 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-17 19:21:24.751 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-17 19:21:24.751 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-17 19:21:24.751 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-17 19:21:24.752 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-17 19:21:24.752 Triggering next historical data download in queue. | 2022-07-17 19:21:24.752 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-17 19:21:24.752 HD Request # 34 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-17 19:21:24.752 HD Request # 34 | Download start date-time: 2022-07-15 20:59:59.000000. File last date-time: 2022-07-15 20:59:59.827000 | 2022-07-17 19:21:24.752 HD Request # 34 | Using server: ds23.sierracharts.com port 10150 | 2022-07-17 19:21:24.753 Socket (3) | Creating socket. | 2022-07-17 19:21:24.753 Socket (3) | New receive buffer size: 5242880 | 2022-07-17 19:21:24.753 Socket (3) | Connecting to IP: 216.1.90.130. | 2022-07-17 19:21:24.753 HD Request # 34 | Setting DTC encoding to Binary VLS | 2022-07-17 19:21:24.807 HD Request # 34 | Sending historical data logon request message. | 2022-07-17 19:21:24.807 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-17 19:21:24.876 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-17 19:21:24.876 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-17 19:21:24.876 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-17 19:21:24.876 HD Request # 34 | Requesting Intraday data. Start date-time: 2022-07-15 20:59:59. Record interval: 0. Symbol: NQU22 | 2022-07-17 19:21:25.319 HD Request # 34 | Decompressing data. | 2022-07-17 19:21:25.341 HD Request # 34 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:59:59.100000 | 2022-07-17 19:21:25.342 Socket (3) | CloseSocket call. | 2022-07-17 19:21:25.342 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-17 19:21:25.342 Historical data download thread signaled to stop. | 2022-07-17 19:21:25.342 HD Request # 34 | Received 6 Intraday data records from 2022-07-15 20:59:59.100000 to 2022-07-15 20:59:59.827000 (0.7 seconds) and wrote 0 records for NQU22-CME | 2022-07-17 19:21:25.342 HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:59:59.827000 | 2022-07-17 19:21:25.343 HD Request # 34 | Completion time: 1s | 2022-07-17 19:21:25.343 HD Request # 34 | Intraday data download complete for NQU22-CME. Unique request ID: 32 | 2022-07-17 19:21:25.343 Removing historical data download ID 32. | 2022-07-17 19:21:25.343 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-17 19:21:25.343 Intraday chart data file opened for NQU22-CME | 2022-07-17 19:21:25.343 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2022-07-17 19:21:25.343 Triggering next historical data download in queue. | 2022-07-17 19:21:25.343 No download requests in the queue to start downloads for. | 2022-07-17 19:21:25.343 Socket (3) | Socket gracefully closed by remote side. | 2022-07-17 19:21:25.367 Socket (3) | Closed. | 2022-07-17 19:21:25.368 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.733 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.733 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.734 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.735 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.735 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.735 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.736 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.736 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.736 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.747 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.748 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.748 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.748 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.748 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.749 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.749 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.750 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.750 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.750 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.750 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.750 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.766 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.767 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.769 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:25.770 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:27.344 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:27.619 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 19:21:27.670 DTC Client socket (1) | Timed out waiting for final send. Canceling I/O. | 2022-07-17 19:22:29.672 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2022-07-17 19:22:29.672 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-17 19:22:29.672 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-17 19:22:29.672 DTC Client socket (1) | Closed. | 2022-07-17 19:22:29.672 SC DTC Delayed Exchange Data | Real-time data for symbol MNQU22-CME is currently unavailable. | 2022-07-17 21:42:21.760 SC DTC Delayed Exchange Data | Real-time data for symbol NQU22-CME is currently unavailable. | 2022-07-17 21:42:21.760 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-17 21:43:13.772 SC DTC Delayed Exchange Data | Real-time data for symbol MNQU22-CME has been restored. | 2022-07-17 21:43:13.772 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-17 21:43:13.772 SC DTC Delayed Exchange Data | Real-time data for symbol NQU22-CME has been restored. | 2022-07-17 21:43:13.772 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-17 21:43:13.772 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-17 21:43:13.772 Triggering next historical data download in queue. | 2022-07-17 21:43:13.772 HD Request # 35 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-17 21:43:13.772 HD Request # 35 | Download start date-time: 2022-07-15 20:59:59.000000. File last date-time: 2022-07-15 20:59:59.827000 | 2022-07-17 21:43:13.773 HD Request # 35 | Using server: ds21.sierracharts.com port 10149 | 2022-07-17 21:43:13.774 Socket (1) | Creating socket. | 2022-07-17 21:43:13.806 Socket (1) | New receive buffer size: 5242880 | 2022-07-17 21:43:13.807 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-07-17 21:43:13.807 HD Request # 35 | Setting DTC encoding to Binary VLS | 2022-07-17 21:43:13.854 HD Request # 35 | Sending historical data logon request message. | 2022-07-17 21:43:13.854 HD Request # 35 | Requesting Intraday data. Start date-time: 2022-07-15 20:59:59. Record interval: 0. Symbol: NQU22 | 2022-07-17 21:43:24.149 HD Request # 35 | Decompressing data. | 2022-07-17 21:43:24.170 HD Request # 35 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:59:59.100000 | 2022-07-17 21:43:24.171 Socket (1) | CloseSocket call. | 2022-07-17 21:43:24.171 Historical data download thread signaled to stop. | 2022-07-17 21:43:24.171 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-17 21:43:24.171 HD Request # 35 | Received 6 Intraday data records from 2022-07-15 20:59:59.100000 to 2022-07-15 20:59:59.827000 (0.7 seconds) and wrote 0 records for NQU22-CME | 2022-07-17 21:43:24.171 HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:59:59.827000 | 2022-07-17 21:43:24.172 HD Request # 35 | Completion time: 11s | 2022-07-17 21:43:24.172 HD Request # 35 | Intraday data download complete for NQU22-CME. Unique request ID: 33 | 2022-07-17 21:43:24.172 Removing historical data download ID 33. | 2022-07-17 21:43:24.172 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-17 21:43:24.172 Intraday chart data file opened for NQU22-CME | 2022-07-17 21:43:24.172 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2022-07-17 21:43:24.172 Triggering next historical data download in queue. | 2022-07-17 21:43:24.172 No download requests in the queue to start downloads for. | 2022-07-17 21:43:24.172 Socket (1) | Socket gracefully closed by remote side. | 2022-07-17 21:43:24.193 Socket (1) | Closed. | 2022-07-17 21:43:24.193 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.312 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.313 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.315 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.315 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.315 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.316 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.316 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.316 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.316 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.329 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.329 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.329 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.330 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.330 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.331 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.331 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.334 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.334 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.334 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.334 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.334 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.346 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.346 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.348 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:24.349 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:25.645 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:25.905 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:43:25.933 SC DTC Delayed Exchange Data | Real-time data for symbol MNQU22-CME has been restored. | 2022-07-17 21:53:27.172 SC DTC Delayed Exchange Data | Real-time data for symbol NQU22-CME has been restored. | 2022-07-17 21:53:27.172 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-17 21:53:27.172 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-17 21:53:27.172 Triggering next historical data download in queue. | 2022-07-17 21:53:27.172 HD Request # 36 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-17 21:53:27.172 HD Request # 36 | Download start date-time: 2022-07-15 20:59:59.000000. File last date-time: 2022-07-15 20:59:59.827000 | 2022-07-17 21:53:27.173 HD Request # 36 | Using server: ds23.sierracharts.com port 10150 | 2022-07-17 21:53:27.173 Socket (1) | Creating socket. | 2022-07-17 21:53:27.174 Socket (1) | New receive buffer size: 5242880 | 2022-07-17 21:53:27.174 Socket (1) | Connecting to IP: 216.1.90.130. | 2022-07-17 21:53:27.174 HD Request # 36 | Setting DTC encoding to Binary VLS | 2022-07-17 21:53:27.234 HD Request # 36 | Sending historical data logon request message. | 2022-07-17 21:53:27.234 HD Request # 36 | Requesting Intraday data. Start date-time: 2022-07-15 20:59:59. Record interval: 0. Symbol: NQU22 | 2022-07-17 21:53:27.753 HD Request # 36 | Decompressing data. | 2022-07-17 21:53:27.778 HD Request # 36 | Receiving Intraday data for NQU22-CME starting at 2022-07-15 20:59:59.100000 | 2022-07-17 21:53:27.779 Socket (1) | CloseSocket call. | 2022-07-17 21:53:27.779 Historical data download thread signaled to stop. | 2022-07-17 21:53:27.779 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-17 21:53:27.779 HD Request # 36 | Received 6 Intraday data records from 2022-07-15 20:59:59.100000 to 2022-07-15 20:59:59.827000 (0.7 seconds) and wrote 0 records for NQU22-CME | 2022-07-17 21:53:27.779 HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2022-07-15 20:59:59.827000 | 2022-07-17 21:53:27.780 HD Request # 36 | Completion time: 0s | 2022-07-17 21:53:27.780 HD Request # 36 | Intraday data download complete for NQU22-CME. Unique request ID: 34 | 2022-07-17 21:53:27.780 Removing historical data download ID 34. | 2022-07-17 21:53:27.780 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-17 21:53:27.780 Intraday chart data file opened for NQU22-CME | 2022-07-17 21:53:27.780 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2022-07-17 21:53:27.780 Triggering next historical data download in queue. | 2022-07-17 21:53:27.780 No download requests in the queue to start downloads for. | 2022-07-17 21:53:27.780 Socket (1) | Socket gracefully closed by remote side. | 2022-07-17 21:53:27.806 Socket (1) | Closed. | 2022-07-17 21:53:27.806 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.912 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.912 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.915 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.916 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.916 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.916 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.917 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.917 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.917 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.926 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.927 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.927 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.927 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.927 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.928 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.928 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.930 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.930 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.930 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.930 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.930 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.940 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.940 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.943 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:27.943 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:29.084 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:29.367 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 21:53:29.420 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 8344 | 2022-07-17 22:10:21.581 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-17 22:19:08.075 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-07-17 22:19:08.075 DTC Client socket (2) | CloseSocket call. | 2022-07-17 22:19:08.076 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-17 22:19:08.076 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-17 22:19:08.076 DTC Client socket (2) | Closed. | 2022-07-17 22:19:08.076 DTC Client socket (0) | CloseSocket call. | 2022-07-17 22:19:08.077 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-17 22:19:08.077 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-17 22:19:08.077 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-07-17 22:19:10.073 DTC Client socket (1) | Creating socket. | 2022-07-17 22:19:10.082 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-17 22:19:10.082 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-07-17 22:19:10.082 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-17 22:19:10.196 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-17 22:19:10.196 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-17 22:19:10.197 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-17 22:19:10.233 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-17 22:19:10.233 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-17 22:19:10.863 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-17 22:19:10.863 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-17 22:19:10.863 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-17 22:19:10.863 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-17 22:19:10.863 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-17 22:19:10.863 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-17 22:19:10.863 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-17 22:19:10.864 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-17 22:19:10.864 Triggering next historical data download in queue. | 2022-07-17 22:19:10.864 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-17 22:19:10.864 HD Request # 37 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-17 22:19:10.864 HD Request # 37 | Download start date-time: 2022-07-17 22:08:23.000000. File last date-time: 2022-07-17 22:08:23.322001 | 2022-07-17 22:19:10.864 HD Request # 37 | Using server: ds21.sierracharts.com port 10149 | 2022-07-17 22:19:10.865 Socket (2) | Creating socket. | 2022-07-17 22:19:10.865 Socket (2) | New receive buffer size: 5242880 | 2022-07-17 22:19:10.865 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-07-17 22:19:10.865 HD Request # 37 | Setting DTC encoding to Binary VLS | 2022-07-17 22:19:10.915 HD Request # 37 | Sending historical data logon request message. | 2022-07-17 22:19:10.915 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-17 22:19:10.969 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-17 22:19:10.969 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-17 22:19:10.969 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-17 22:19:10.969 HD Request # 37 | Requesting Intraday data. Start date-time: 2022-07-17 22:08:23. Record interval: 0. Symbol: NQU22 | 2022-07-17 22:19:11.403 HD Request # 37 | Decompressing data. | 2022-07-17 22:19:11.430 HD Request # 37 | Receiving Intraday data for NQU22-CME starting at 2022-07-17 22:08:23.322000 | 2022-07-17 22:19:11.430 Socket (2) | CloseSocket call. | 2022-07-17 22:19:11.431 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-17 22:19:11.431 Historical data download thread signaled to stop. | 2022-07-17 22:19:11.431 HD Request # 37 | Timestamp of first Intraday data file record written: 2022-07-17 22:08:25.423000 | 2022-07-17 22:19:11.431 HD Request # 37 | Received 79 Intraday data records from 2022-07-17 22:08:23.322000 to 2022-07-17 22:08:59.953000 (36.6 seconds) and wrote 77 records for NQU22-CME | 2022-07-17 22:19:11.431 HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2022-07-17 22:08:59.953000 | 2022-07-17 22:19:11.435 HD Request # 37 | Completion time: 1s | 2022-07-17 22:19:11.436 HD Request # 37 | Intraday data download complete for NQU22-CME. Unique request ID: 35 | 2022-07-17 22:19:11.436 Removing historical data download ID 35. | 2022-07-17 22:19:11.436 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-17 22:19:11.436 Intraday chart data file opened for NQU22-CME | 2022-07-17 22:19:11.436 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2022-07-17 22:19:11.436 Triggering next historical data download in queue. | 2022-07-17 22:19:11.436 No download requests in the queue to start downloads for. | 2022-07-17 22:19:11.436 Socket (2) | Socket gracefully closed by remote side. | 2022-07-17 22:19:11.460 Socket (2) | Closed. | 2022-07-17 22:19:11.460 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.732 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.734 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.740 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.740 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.740 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.741 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.742 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.742 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.742 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.751 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.752 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.752 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.752 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.752 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.753 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.753 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.755 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.755 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.755 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.755 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.755 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.764 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.765 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.766 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:11.767 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 14536 | 2022-07-17 22:19:12.504 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:13.020 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:13.061 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 22:19:13.305 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-17 23:43:25.621 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-17 23:43:25.621 DTC Client socket (1) | CloseSocket call. | 2022-07-17 23:43:25.621 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-17 23:43:25.621 DTC Client socket (1) | Closed. | 2022-07-17 23:43:25.621 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-17 23:43:25.622 DTC Client socket (0) | CloseSocket call. | 2022-07-17 23:43:25.622 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-17 23:43:25.622 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-17 23:43:25.623 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-07-17 23:43:27.620 DTC Client socket (1) | Creating socket. | 2022-07-17 23:43:27.796 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-17 23:43:27.796 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2022-07-17 23:43:27.796 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-17 23:43:27.844 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-17 23:43:27.844 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-17 23:43:27.844 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-17 23:43:27.904 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-17 23:43:27.904 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-17 23:43:28.561 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-17 23:43:28.561 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-17 23:43:28.561 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-17 23:43:28.561 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-17 23:43:28.561 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-17 23:43:28.561 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-17 23:43:28.561 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-17 23:43:28.561 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-17 23:43:28.561 Triggering next historical data download in queue. | 2022-07-17 23:43:28.561 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-17 23:43:28.561 HD Request # 38 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-17 23:43:28.561 HD Request # 38 | Download start date-time: 2022-07-17 23:32:30.000000. File last date-time: 2022-07-17 23:32:30.642000 | 2022-07-17 23:43:28.562 HD Request # 38 | Using server: ds23.sierracharts.com port 10150 | 2022-07-17 23:43:28.562 Socket (2) | Creating socket. | 2022-07-17 23:43:28.563 Socket (2) | New receive buffer size: 5242880 | 2022-07-17 23:43:28.563 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-07-17 23:43:28.563 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-17 23:43:28.684 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-17 23:43:28.684 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-17 23:43:28.684 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-17 23:43:28.684 HD Request # 38 | Setting DTC encoding to Binary VLS | 2022-07-17 23:43:28.732 HD Request # 38 | Sending historical data logon request message. | 2022-07-17 23:43:28.732 HD Request # 38 | Requesting Intraday data. Start date-time: 2022-07-17 23:32:30. Record interval: 0. Symbol: NQU22 | 2022-07-17 23:43:29.294 HD Request # 38 | Decompressing data. | 2022-07-17 23:43:29.314 HD Request # 38 | Receiving Intraday data for NQU22-CME starting at 2022-07-17 23:32:30.640000 | 2022-07-17 23:43:29.315 Socket (2) | CloseSocket call. | 2022-07-17 23:43:29.316 Historical data download thread signaled to stop. | 2022-07-17 23:43:29.316 HD Request # 38 | Timestamp of first Intraday data file record written: 2022-07-17 23:32:33.794000 | 2022-07-17 23:43:29.316 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-17 23:43:29.316 HD Request # 38 | Received 30 Intraday data records from 2022-07-17 23:32:30.640000 to 2022-07-17 23:33:16.887000 (46.2 seconds) and wrote 25 records for NQU22-CME | 2022-07-17 23:43:29.316 HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2022-07-17 23:33:16.887000 | 2022-07-17 23:43:29.327 HD Request # 38 | Completion time: 1s | 2022-07-17 23:43:29.328 HD Request # 38 | Intraday data download complete for NQU22-CME. Unique request ID: 36 | 2022-07-17 23:43:29.328 Removing historical data download ID 36. | 2022-07-17 23:43:29.328 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-17 23:43:29.328 Intraday chart data file opened for NQU22-CME | 2022-07-17 23:43:29.328 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2022-07-17 23:43:29.328 Triggering next historical data download in queue. | 2022-07-17 23:43:29.328 No download requests in the queue to start downloads for. | 2022-07-17 23:43:29.328 Socket (2) | Socket gracefully closed by remote side. | 2022-07-17 23:43:29.352 Socket (2) | Closed. | 2022-07-17 23:43:29.352 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.435 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.435 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.438 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.439 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.439 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.439 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.440 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.440 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.440 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.448 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.449 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.449 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.449 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.449 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.450 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.451 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.452 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.452 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.452 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.452 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.452 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.462 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.463 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.464 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:29.466 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:30.673 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:30.722 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-17 23:43:30.970 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 19904 | 2022-07-17 23:43:34.412 NQU22-CME [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 00:18:53.361 NQU22-CME [CBV][M] 375 Volume #19 | Performing continuous chart historical Daily data download for symbol NQU22-CME starting at last date in file. | 2022-07-18 00:18:53.370 Added historical Daily data request for NQU22-CME to the queue. | 2022-07-18 00:18:53.370 Triggering next historical data download in queue. | 2022-07-18 00:18:53.370 NQU22-CME [CBV][M] 375 Volume #19 | Waiting for historical downloads to complete with the IDs: 37, | 2022-07-18 00:18:53.373 HD Request # 39 | Downloading Historical Daily chart data for NQU22-CME. Starting date: 2022-07-12. Service: scdataallservices | 2022-07-18 00:18:53.410 HD Request # 39 | Requesting historical Daily data for NQU22 starting at 2022-07-11. SC External HD service. | 2022-07-18 00:18:54.139 HD Request # 39 | Receiving historical Daily data for NQU22-CME starting at 2022-07-12 | 2022-07-18 00:18:54.591 HD Request # 39 | Writing historical Daily data to the file NQU22-CME.dly | 2022-07-18 00:18:54.591 HD Request # 39 | Bytes received: 310 | 2022-07-18 00:18:54.592 HD Request # 39 | Received 5 Daily data records from 2022-07-12 00:00:00 to 2022-07-15 00:00:00 (4.0 days) and wrote 4 records for NQU22-CME | 2022-07-18 00:18:54.592 HD Request # 39 | Completion time: 1s | 2022-07-18 00:18:54.592 HD Request # 39 | Daily data download complete for NQU22-CME. Unique request ID: 37 | 2022-07-18 00:18:54.592 Removing historical data download ID 37. | 2022-07-18 00:18:54.592 Triggering next historical data download in queue. | 2022-07-18 00:18:54.592 No download requests in the queue to start downloads for. | 2022-07-18 00:18:54.592 NQU22-CME [CBV][M] 375 Volume #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 00:18:54.667 NQU22-CME [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 00:18:54.667 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:18:55.069 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:18:55.124 NQU22-CME [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 00:18:55.271 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:18:55.608 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:18:55.633 NQU22-CME [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 00:19:01.059 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:01.709 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:01.721 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:01.999 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:02.041 NQU22-CME[M] 30 Sec #13 | Reloading chart. | 2022-07-18 00:19:09.824 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:10.516 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:10.516 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:10.629 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:10.832 NQU22-CME[M]/MNQU22-CME [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 00:19:17.761 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:18.418 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:18.431 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:18.597 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:18.674 NQU22-CME [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 00:19:25.376 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:25.715 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:25.728 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:25.935 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:25.978 NQU22-CME [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 00:19:32.995 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:33.444 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:33.737 NQU22-CME [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 00:19:43.941 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:44.266 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:19:44.644 NQU22-CME [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 00:20:26.348 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:26.634 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:26.634 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:26.661 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:26.973 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:26.975 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:26.978 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:27.149 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:27.149 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:27.207 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:27.901 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:27.904 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:20:27.910 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:41.663 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:41.663 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:41.663 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:41.663 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:41.705 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:42.464 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:42.702 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:42.815 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:42.822 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:43.001 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:44.418 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:44.418 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:44.418 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:44.418 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:44.674 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:45.428 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:45.450 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:45.784 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:45.787 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:22:45.988 NQU22-CME [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 00:22:59.918 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:00.303 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:00.487 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:06.858 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:07.104 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:08.696 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:08.749 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:09.279 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:09.763 NQU22-CME [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 00:23:19.667 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:20.169 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:20.169 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:20.202 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:20.537 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:20.703 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:20.703 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:20.793 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:21.250 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:57.357 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:57.357 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:57.431 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:23:57.720 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:00.357 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:00.357 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:00.603 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:00.791 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:04.694 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:04.694 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:04.759 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:04.878 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:39.944 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:39.944 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:40.001 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:40.303 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:42.068 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:42.068 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:42.125 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:42.458 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:57.166 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:57.166 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:57.173 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:57.308 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:57.616 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:57.616 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:57.687 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:24:58.000 NQU22-CME[M] 1 Min #18 | Reloading chart. | 2022-07-18 00:26:05.080 NQU22-CME[M] 1250 Volume #24 | Reloading chart. | 2022-07-18 00:26:18.209 NQU22-CME [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 00:26:26.048 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:26:26.999 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 00:26:27.137 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-18 04:09:52.848 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-18 04:09:52.848 * DTC Client socket (1) | CloseSocket call. | 2022-07-18 04:09:52.848 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-18 04:09:52.848 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-18 04:09:52.848 DTC Client socket (1) | Closed. | 2022-07-18 04:09:52.848 DTC Client socket (0) | CloseSocket call. | 2022-07-18 04:09:52.849 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-18 04:09:52.849 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-18 04:09:52.849 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-07-18 04:09:54.835 DTC Client socket (1) | Creating socket. | 2022-07-18 04:09:54.890 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-18 04:09:54.890 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2022-07-18 04:09:54.890 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-18 04:09:54.914 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-18 04:09:54.914 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-18 04:09:54.914 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-18 04:09:54.964 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-18 04:09:54.964 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-18 04:09:55.600 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-18 04:09:55.600 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-18 04:09:55.600 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-18 04:09:55.600 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-18 04:09:55.600 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-18 04:09:55.600 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-18 04:09:55.600 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-18 04:09:55.600 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-18 04:09:55.600 Triggering next historical data download in queue. | 2022-07-18 04:09:55.600 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-18 04:09:55.600 HD Request # 40 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-18 04:09:55.600 HD Request # 40 | Download start date-time: 2022-07-18 03:59:07.000000. File last date-time: 2022-07-18 03:59:07.850001 | 2022-07-18 04:09:55.601 HD Request # 40 | Using server: ds21.sierracharts.com port 10149 | 2022-07-18 04:09:55.601 Socket (2) | Creating socket. | 2022-07-18 04:09:55.690 Socket (2) | New receive buffer size: 5242880 | 2022-07-18 04:09:55.690 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-07-18 04:09:55.690 HD Request # 40 | Setting DTC encoding to Binary VLS | 2022-07-18 04:09:55.861 HD Request # 40 | Sending historical data logon request message. | 2022-07-18 04:09:55.861 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-18 04:09:55.886 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-18 04:09:55.886 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-18 04:09:55.886 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-18 04:09:55.886 HD Request # 40 | Requesting Intraday data. Start date-time: 2022-07-18 03:59:07. Record interval: 0. Symbol: NQU22 | 2022-07-18 04:09:56.416 HD Request # 40 | Decompressing data. | 2022-07-18 04:09:56.461 HD Request # 40 | Receiving Intraday data for NQU22-CME starting at 2022-07-18 03:59:07.850000 | 2022-07-18 04:09:56.462 Socket (2) | CloseSocket call. | 2022-07-18 04:09:56.462 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 04:09:56.462 Historical data download thread signaled to stop. | 2022-07-18 04:09:56.468 HD Request # 40 | Timestamp of first Intraday data file record written: 2022-07-18 03:59:09.954000 | 2022-07-18 04:09:56.468 HD Request # 40 | Received 21 Intraday data records from 2022-07-18 03:59:07.850000 to 2022-07-18 03:59:43.469000 (35.6 seconds) and wrote 19 records for NQU22-CME | 2022-07-18 04:09:56.468 HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2022-07-18 03:59:43.469000 | 2022-07-18 04:09:56.472 HD Request # 40 | Completion time: 1s | 2022-07-18 04:09:56.472 HD Request # 40 | Intraday data download complete for NQU22-CME. Unique request ID: 38 | 2022-07-18 04:09:56.472 Removing historical data download ID 38. | 2022-07-18 04:09:56.472 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-18 04:09:56.472 Intraday chart data file opened for NQU22-CME | 2022-07-18 04:09:56.472 HD Request # 40 | Enabling Intraday chart updating for symbol. | 2022-07-18 04:09:56.472 Triggering next historical data download in queue. | 2022-07-18 04:09:56.472 No download requests in the queue to start downloads for. | 2022-07-18 04:09:56.472 Socket (2) | Socket gracefully closed by remote side. | 2022-07-18 04:09:56.490 Socket (2) | Closed. | 2022-07-18 04:09:56.490 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:56.879 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:56.886 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:56.890 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:56.894 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:56.894 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:56.897 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:56.897 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:56.908 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.053 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.058 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.071 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.073 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.079 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.083 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.083 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.120 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.128 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.131 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.155 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.159 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.159 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.159 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.159 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.293 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:57.933 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:58.022 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:58.041 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:58.223 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:58.227 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:58.242 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 04:09:58.320 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 8960 | 2022-07-18 04:09:58.669 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-18 08:10:08.216 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-18 08:10:08.216 DTC Client socket (1) | CloseSocket call. | 2022-07-18 08:10:08.216 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-18 08:10:08.216 DTC Client socket (1) | Closed. | 2022-07-18 08:10:08.216 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-18 08:10:08.217 DTC Client socket (0) | CloseSocket call. | 2022-07-18 08:10:08.217 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-18 08:10:08.217 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-18 08:10:08.217 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-07-18 08:10:10.210 DTC Client socket (1) | Creating socket. | 2022-07-18 08:10:10.211 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-18 08:10:10.211 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-07-18 08:10:10.211 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-18 08:10:10.238 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-18 08:10:10.238 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-18 08:10:10.238 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-18 08:10:10.296 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-18 08:10:10.296 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-18 08:10:10.877 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-18 08:10:10.877 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-18 08:10:10.877 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-18 08:10:10.877 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-18 08:10:10.877 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-18 08:10:10.877 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-18 08:10:10.877 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-18 08:10:10.877 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-18 08:10:10.877 Triggering next historical data download in queue. | 2022-07-18 08:10:10.877 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-18 08:10:10.877 HD Request # 41 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-18 08:10:10.877 HD Request # 41 | Download start date-time: 2022-07-18 07:59:06.000000. File last date-time: 2022-07-18 07:59:06.785001 | 2022-07-18 08:10:10.878 HD Request # 41 | Using server: ds23.sierracharts.com port 10150 | 2022-07-18 08:10:10.878 Socket (2) | Creating socket. | 2022-07-18 08:10:10.879 Socket (2) | New receive buffer size: 5242880 | 2022-07-18 08:10:10.879 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-07-18 08:10:10.879 HD Request # 41 | Setting DTC encoding to Binary VLS | 2022-07-18 08:10:10.939 HD Request # 41 | Sending historical data logon request message. | 2022-07-18 08:10:10.940 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-18 08:10:11.075 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-18 08:10:11.075 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-18 08:10:11.075 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-18 08:10:11.075 HD Request # 41 | Requesting Intraday data. Start date-time: 2022-07-18 07:59:06. Record interval: 0. Symbol: NQU22 | 2022-07-18 08:10:11.458 HD Request # 41 | Decompressing data. | 2022-07-18 08:10:11.481 HD Request # 41 | Receiving Intraday data for NQU22-CME starting at 2022-07-18 07:59:06.779000 | 2022-07-18 08:10:11.481 Socket (2) | CloseSocket call. | 2022-07-18 08:10:11.481 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 08:10:11.482 Socket (2) | Socket gracefully closed by remote side. | 2022-07-18 08:10:11.508 Socket (2) | Closed. | 2022-07-18 08:10:11.508 Historical data download thread signaled to stop. | 2022-07-18 08:10:11.512 HD Request # 41 | Timestamp of first Intraday data file record written: 2022-07-18 07:59:09.021000 | 2022-07-18 08:10:11.512 HD Request # 41 | Received 111 Intraday data records from 2022-07-18 07:59:06.779000 to 2022-07-18 07:59:58.934000 (52.2 seconds) and wrote 105 records for NQU22-CME | 2022-07-18 08:10:11.512 HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2022-07-18 07:59:58.934000 | 2022-07-18 08:10:11.518 HD Request # 41 | Completion time: 1s | 2022-07-18 08:10:11.518 HD Request # 41 | Intraday data download complete for NQU22-CME. Unique request ID: 39 | 2022-07-18 08:10:11.518 Removing historical data download ID 39. | 2022-07-18 08:10:11.518 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-18 08:10:11.518 Intraday chart data file opened for NQU22-CME | 2022-07-18 08:10:11.518 HD Request # 41 | Enabling Intraday chart updating for symbol. | 2022-07-18 08:10:11.518 Triggering next historical data download in queue. | 2022-07-18 08:10:11.518 No download requests in the queue to start downloads for. | 2022-07-18 08:10:11.518 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:11.979 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.000 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.007 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.010 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.016 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.016 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.020 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.020 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.031 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.034 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.047 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.050 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.058 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.062 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.062 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.112 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.121 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.126 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.151 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.156 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.156 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.156 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.156 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.276 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 3912 | 2022-07-18 08:10:12.434 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:12.468 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:13.183 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:13.345 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:13.348 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:13.379 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 08:10:13.633 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-18 11:16:24.491 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-18 11:16:24.492 DTC Client socket (1) | CloseSocket call. | 2022-07-18 11:16:24.492 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-18 11:16:24.492 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-18 11:16:24.492 DTC Client socket (1) | Closed. | 2022-07-18 11:16:24.492 DTC Client socket (0) | CloseSocket call. | 2022-07-18 11:16:24.493 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-18 11:16:24.493 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-18 11:16:24.493 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-07-18 11:16:26.496 DTC Client socket (1) | Creating socket. | 2022-07-18 11:16:26.553 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-18 11:16:26.553 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2022-07-18 11:16:26.553 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-18 11:16:26.586 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-18 11:16:26.586 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-18 11:16:26.586 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-18 11:16:26.657 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-18 11:16:26.657 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-18 11:16:27.313 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-18 11:16:27.313 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-18 11:16:27.313 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-18 11:16:27.313 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-18 11:16:27.313 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-18 11:16:27.313 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-18 11:16:27.313 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-18 11:16:27.314 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-18 11:16:27.314 Triggering next historical data download in queue. | 2022-07-18 11:16:27.314 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-18 11:16:27.314 HD Request # 42 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-18 11:16:27.314 HD Request # 42 | Download start date-time: 2022-07-18 11:05:30.000000. File last date-time: 2022-07-18 11:05:30.952000 | 2022-07-18 11:16:27.315 HD Request # 42 | Using server: ds21.sierracharts.com port 10149 | 2022-07-18 11:16:27.315 Socket (2) | Creating socket. | 2022-07-18 11:16:27.380 Socket (2) | New receive buffer size: 5242880 | 2022-07-18 11:16:27.380 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-07-18 11:16:27.381 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-18 11:16:27.501 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-18 11:16:27.501 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-18 11:16:27.501 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-18 11:16:27.501 HD Request # 42 | Setting DTC encoding to Binary VLS | 2022-07-18 11:16:27.540 HD Request # 42 | Sending historical data logon request message. | 2022-07-18 11:16:27.540 HD Request # 42 | Requesting Intraday data. Start date-time: 2022-07-18 11:05:30. Record interval: 0. Symbol: NQU22 | 2022-07-18 11:16:28.103 HD Request # 42 | Decompressing data. | 2022-07-18 11:16:28.125 HD Request # 42 | Receiving Intraday data for NQU22-CME starting at 2022-07-18 11:05:30.952000 | 2022-07-18 11:16:28.125 Socket (2) | CloseSocket call. | 2022-07-18 11:16:28.125 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 11:16:28.126 Socket (2) | Socket gracefully closed by remote side. | 2022-07-18 11:16:28.154 Socket (2) | Closed. | 2022-07-18 11:16:28.154 Historical data download thread signaled to stop. | 2022-07-18 11:16:28.175 HD Request # 42 | Timestamp of first Intraday data file record written: 2022-07-18 11:05:41.714000 | 2022-07-18 11:16:28.175 HD Request # 42 | Received 35 Intraday data records from 2022-07-18 11:05:30.952000 to 2022-07-18 11:06:11.003000 (40.1 seconds) and wrote 34 records for NQU22-CME | 2022-07-18 11:16:28.175 HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2022-07-18 11:06:11.003000 | 2022-07-18 11:16:28.179 HD Request # 42 | Completion time: 1s | 2022-07-18 11:16:28.179 HD Request # 42 | Intraday data download complete for NQU22-CME. Unique request ID: 40 | 2022-07-18 11:16:28.179 Removing historical data download ID 40. | 2022-07-18 11:16:28.179 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-18 11:16:28.179 Intraday chart data file opened for NQU22-CME | 2022-07-18 11:16:28.179 HD Request # 42 | Enabling Intraday chart updating for symbol. | 2022-07-18 11:16:28.179 Triggering next historical data download in queue. | 2022-07-18 11:16:28.179 No download requests in the queue to start downloads for. | 2022-07-18 11:16:28.179 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 5548 | 2022-07-18 11:16:28.756 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.758 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.779 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.787 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.790 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.797 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.797 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.800 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.800 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.812 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.815 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.829 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.831 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.840 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.845 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.845 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.886 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.893 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.896 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.922 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.927 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.927 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.927 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:28.927 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:29.037 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:29.208 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:29.865 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:30.010 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:30.013 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:30.043 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:16:30.081 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-18 11:23:32.224 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-18 11:23:32.224 DTC Client socket (1) | CloseSocket call. | 2022-07-18 11:23:32.224 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-18 11:23:32.225 DTC Client socket (1) | Closed. | 2022-07-18 11:23:32.225 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-18 11:23:32.225 DTC Client socket (0) | CloseSocket call. | 2022-07-18 11:23:32.226 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-18 11:23:32.226 SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-18 11:23:32.226 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-07-18 11:23:34.238 DTC Client socket (1) | Creating socket. | 2022-07-18 11:23:34.401 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-18 11:23:34.401 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2022-07-18 11:23:34.401 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-18 11:23:34.463 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-18 11:23:34.463 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-18 11:23:34.463 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-18 11:23:34.606 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-18 11:23:34.606 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-18 11:23:35.219 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-18 11:23:35.219 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-18 11:23:35.219 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-18 11:23:35.219 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-18 11:23:35.219 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-18 11:23:35.219 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-18 11:23:35.219 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-18 11:23:35.219 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-18 11:23:35.219 Triggering next historical data download in queue. | 2022-07-18 11:23:35.219 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-18 11:23:35.219 HD Request # 43 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-18 11:23:35.219 HD Request # 43 | Download start date-time: 2022-07-18 11:12:45.000000. File last date-time: 2022-07-18 11:12:45.486000 | 2022-07-18 11:23:35.220 HD Request # 43 | Using server: ds23.sierracharts.com port 10150 | 2022-07-18 11:23:35.220 Socket (2) | Creating socket. | 2022-07-18 11:23:35.220 Socket (2) | New receive buffer size: 5242880 | 2022-07-18 11:23:35.220 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-07-18 11:23:35.220 HD Request # 43 | Setting DTC encoding to Binary VLS | 2022-07-18 11:23:35.382 HD Request # 43 | Sending historical data logon request message. | 2022-07-18 11:23:35.382 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-18 11:23:35.393 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-18 11:23:35.393 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-18 11:23:35.393 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-18 11:23:35.393 HD Request # 43 | Requesting Intraday data. Start date-time: 2022-07-18 11:12:45. Record interval: 0. Symbol: NQU22 | 2022-07-18 11:23:35.871 HD Request # 43 | Decompressing data. | 2022-07-18 11:23:35.897 HD Request # 43 | Receiving Intraday data for NQU22-CME starting at 2022-07-18 11:12:45.486000 | 2022-07-18 11:23:35.897 Socket (2) | CloseSocket call. | 2022-07-18 11:23:35.898 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 11:23:35.898 Historical data download thread signaled to stop. | 2022-07-18 11:23:35.903 HD Request # 43 | Timestamp of first Intraday data file record written: 2022-07-18 11:12:49.057000 | 2022-07-18 11:23:35.903 HD Request # 43 | Received 31 Intraday data records from 2022-07-18 11:12:45.486000 to 2022-07-18 11:13:19.279000 (33.8 seconds) and wrote 30 records for NQU22-CME | 2022-07-18 11:23:35.904 HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2022-07-18 11:13:19.279000 | 2022-07-18 11:23:35.910 HD Request # 43 | Completion time: 0s | 2022-07-18 11:23:35.910 HD Request # 43 | Intraday data download complete for NQU22-CME. Unique request ID: 41 | 2022-07-18 11:23:35.910 Removing historical data download ID 41. | 2022-07-18 11:23:35.910 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-18 11:23:35.910 Intraday chart data file opened for NQU22-CME | 2022-07-18 11:23:35.910 HD Request # 43 | Enabling Intraday chart updating for symbol. | 2022-07-18 11:23:35.910 Triggering next historical data download in queue. | 2022-07-18 11:23:35.910 No download requests in the queue to start downloads for. | 2022-07-18 11:23:35.910 Socket (2) | Socket gracefully closed by remote side. | 2022-07-18 11:23:36.039 Socket (2) | Closed. | 2022-07-18 11:23:36.039 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:36.339 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:36.345 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:36.350 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:36.373 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:36.373 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:36.373 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:36.373 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:36.507 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 14940 | 2022-07-18 11:23:36.650 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:36.654 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.364 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.384 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.390 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.393 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.398 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.398 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.401 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.401 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.410 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.412 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.415 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.428 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.430 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.438 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.443 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.443 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.451 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.521 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.641 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 11:23:37.857 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:09.994 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:09.994 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:09.994 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:09.994 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:10.047 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:10.319 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:10.322 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:10.358 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:10.589 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:11.925 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:11.925 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:11.925 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:11.925 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:12.607 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:13.012 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:13.015 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:13.071 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:13.297 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 12:44:14.060 NQU22-CME [CBV][M] 15 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:41:29.477 NQU22-CME[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:41:29.968 NQU22-CME/MNQU22-CME[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:41:48.349 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-18 13:42:15.548 DTC Client socket (1) | CloseSocket call. | 2022-07-18 13:42:15.548 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-18 13:42:15.549 SC Data - All Services | Disconnected. | 2022-07-18 13:42:15.549 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-18 13:42:15.549 SC Data - All Services | Disconnected. | 2022-07-18 13:42:15.684 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 9. | 2022-07-18 13:42:15.688 Current selected Data/Trading service: CQG WebAPI | 2022-07-18 13:42:15.688 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-18 13:42:17.127 F.US.ENQU22/F.US.MNQU22[M] 512 Trades #14 | Reloading chart. | 2022-07-18 13:42:17.283 F.US.ENQU22 [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-18 13:42:17.363 F.US.ENQU22 [CBV][M] 5 Min #25 | Performing continuous chart historical Daily data download for symbol F.US.ENQU22 starting at last date in file. | 2022-07-18 13:42:17.413 Added historical Daily data request for F.US.ENQU22 to the queue. | 2022-07-18 13:42:17.413 Triggering next historical data download in queue. | 2022-07-18 13:42:17.413 F.US.ENQU22 [CBV][M] 5 Min #25 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.429 HD Request # 44 | Downloading Historical Daily chart data for F.US.ENQU22. Starting date: 2022-07-11. Service: cqg | 2022-07-18 13:42:17.432 F.US.ENQU22 [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-18 13:42:17.434 F.US.ENQU22 [CBV][M] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.453 F.US.ENQU22 [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-18 13:42:17.459 F.US.ENQU22 [CBV][M] 60 Min #29 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.475 F.US.ENQU22 [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-18 13:42:17.491 F.US.ENQU22 [CBV][M] 750 Volume #1 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.509 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-18 13:42:17.512 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.530 F.US.ENQU22 [CBV][M] 15 Min #30 | Reloading chart. | 2022-07-18 13:42:17.537 CQG WebAPI | Using primary service for historical data for F.US.ENQH22 | 2022-07-18 13:42:17.550 Starting DelayedDownloadMonitoringTimer | 2022-07-18 13:42:17.550 Starting HDTimeoutTimer | 2022-07-18 13:42:17.550 Added historical Intraday data request for F.US.ENQH22 to the queue. | 2022-07-18 13:42:17.550 Triggering next historical data download in queue. | 2022-07-18 13:42:17.550 F.US.ENQU22 [CBV][M] 15 Min #30 | Waiting for historical downloads to complete with the IDs: 42, 43, | 2022-07-18 13:42:17.595 F.US.ENQU22 [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-18 13:42:17.603 F.US.ENQU22 [CBV][M] 750 Volume #26 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.634 F.US.ENQU22 [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-18 13:42:17.650 F.US.ENQU22 [CBV][M] 240 Min #9 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.667 F.US.ENQU22 [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-18 13:42:17.671 F.US.ENQU22 [CBV][M] 5 Min #12 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.692 F.US.ENQU22 [CBV][M] #16 | Reloading chart. | 2022-07-18 13:42:17.704 F.US.ENQU22 [CBV][M] #16 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.727 F.US.ENQU22 [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 13:42:17.733 F.US.ENQU22 [CBV][M] 375 Volume #19 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.738 F.US.ENQU22[M]/F.US.MNQU22 [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 13:42:17.741 F.US.ENQU22[M]/F.US.MNQU22 [CBV][M] 500 Volume #28 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.745 F.US.ENQU22 [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 13:42:17.760 F.US.ENQU22 [CBV][M] 3072 Trades #4 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.764 F.US.ENQU22 [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 13:42:17.766 F.US.ENQU22 [CBV][M] 3072 Trades #11 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.770 F.US.ENQU22 [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 13:42:17.786 F.US.ENQU22 [CBV][M] 1 Min #27 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.790 F.US.ENQU22[M] 30 Sec #13 | Reloading chart. | 2022-07-18 13:42:17.795 Symbol settings MD5 received. Request ID: 9. | 2022-07-18 13:42:17.808 Requested symbol settings for service code cqg. Request ID: 10. | 2022-07-18 13:42:17.808 F.US.ENQU22 [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 13:42:17.815 F.US.ENQU22 [CBV][M] 512 Trades #5 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.821 F.US.ENQU22 [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 13:42:17.832 F.US.ENQU22 [CBV][M] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.836 F.US.ENQU22 [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 13:42:17.837 F.US.ENQU22 [CBV][M] 825 Trades #23 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.843 F.US.ENQU22[M] 1 Min #18 | Reloading chart. | 2022-07-18 13:42:17.847 F.US.ENQU22 [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 13:42:17.875 F.US.ENQU22 [CBV][M] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.879 F.US.ENQU22 [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 13:42:17.881 F.US.ENQU22 [CBV][M] 7500 Volume #20 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:17.885 F.US.ENQU22[M] 1250 Volume #24 | Reloading chart. | 2022-07-18 13:42:17.887 F.US.ENQU22 [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-18 13:42:17.900 CQG WebAPI | Using primary service for historical data for F.US.ENQZ21 | 2022-07-18 13:42:17.923 Added historical Intraday data request for F.US.ENQZ21 to the queue. | 2022-07-18 13:42:17.923 Triggering next historical data download in queue. | 2022-07-18 13:42:17.923 F.US.ENQU22 [CBV][M] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 42, 43, 44, | 2022-07-18 13:42:18.015 F.US.ENQU22 [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-18 13:42:18.024 F.US.ENQU22 [CBV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:18.047 F.US.ENQU22[M] 1 Trades #21 | Reloading chart. | 2022-07-18 13:42:18.253 HD Request # 44 | Requesting historical Daily data for NQU22 starting at 2022-07-10. SC External HD service. | 2022-07-18 13:42:18.257 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:42:18.267 F.US.ENQU22[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:42:18.294 F.US.ENQU22 [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-18 13:42:18.339 F.US.ENQU22 [CBV][M] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 42, | 2022-07-18 13:42:18.364 F.US.ENQU22[M] 512 Trades #17 | Reloading chart. | 2022-07-18 13:42:18.407 F.US.ENQU22 [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-18 13:42:18.424 F.US.ENQU22 [CBV][M] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 42, 43, 44, | 2022-07-18 13:42:18.503 HD Request # 44 | Receiving historical Daily data for F.US.ENQU22 starting at 2022-07-11 | 2022-07-18 13:42:18.536 HD Request # 44 | Writing historical Daily data to the file F.US.ENQU22.dly | 2022-07-18 13:42:18.536 HD Request # 44 | Bytes received: 305 | 2022-07-18 13:42:18.538 HD Request # 44 | Received 5 Daily data records from 2022-07-11 00:00:00 to 2022-07-15 00:00:00 (5.0 days) and wrote 5 records for F.US.ENQU22 | 2022-07-18 13:42:18.538 HD Request # 44 | Completion time: 1s | 2022-07-18 13:42:18.538 HD Request # 44 | Daily data download complete for F.US.ENQU22. Unique request ID: 42 | 2022-07-18 13:42:18.538 Removing historical data download ID 42. | 2022-07-18 13:42:18.538 Triggering next historical data download in queue. | 2022-07-18 13:42:18.538 No download requests in the queue to start downloads for. | 2022-07-18 13:42:18.538 F.US.ENQU22 [CBV][M] 5 Min #25 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:18.547 F.US.ENQU22 [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-18 13:42:18.549 F.US.ENQU22 [CBV][M] 60 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:18.581 F.US.ENQU22 [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-18 13:42:18.592 F.US.ENQU22 [CBV][M] 60 Min #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:18.716 F.US.ENQU22 [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-18 13:42:18.772 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:18.903 F.US.ENQU22 [CBV][M] 750 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.034 F.US.ENQU22 [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-18 13:42:19.048 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:19.090 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.111 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-18 13:42:19.111 F.US.ENQU22 [CBV][M] 750 Volume #26 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.165 F.US.ENQU22 [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-18 13:42:19.195 F.US.ENQU22 [CBV][M] 240 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.230 F.US.ENQU22 [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-18 13:42:19.265 F.US.ENQU22 [CBV][M] 5 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.295 F.US.ENQU22 [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-18 13:42:19.312 F.US.ENQU22 [CBV][M] #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.346 F.US.ENQU22 [CBV][M] #16 | Reloading chart. | 2022-07-18 13:42:19.411 F.US.ENQU22[M]/F.US.MNQU22 [CBV][M] 500 Volume #28 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.466 F.US.ENQU22[M]/F.US.MNQU22 [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 13:42:19.479 F.US.ENQU22 [CBV][M] 375 Volume #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.487 F.US.ENQU22 [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 13:42:19.508 F.US.ENQU22 [CBV][M] 3072 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.570 F.US.ENQU22 [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 13:42:19.591 F.US.ENQU22 [CBV][M] 3072 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.619 F.US.ENQU22 [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 13:42:19.663 F.US.ENQU22 [CBV][M] 1 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.721 F.US.ENQU22 [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 13:42:19.746 F.US.ENQU22 [CBV][M] 512 Trades #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.877 F.US.ENQU22 [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 13:42:19.879 F.US.ENQU22 [CBV][M] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:19.887 F.US.ENQU22 [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 13:42:20.040 F.US.ENQU22 [CBV][M] 825 Trades #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:20.069 F.US.ENQU22 [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 13:42:20.070 F.US.ENQU22 [CBV][M] 7500 Volume #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:20.095 F.US.ENQU22 [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 13:42:20.096 F.US.ENQU22 [CBV][M] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:20.105 F.US.ENQU22 [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 13:42:20.105 F.US.ENQU22 [CBV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:20.120 F.US.ENQU22 [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-18 13:42:20.120 F.US.ENQU22 [CBV][M] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:20.495 F.US.ENQU22 [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-18 13:42:20.496 F.US.ENQU22 [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-18 13:42:20.652 F.US.ENQU22 [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-18 13:42:20.891 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:21.065 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:21.065 Symbol settings received. Request ID: 10. | 2022-07-18 13:42:21.092 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:21.497 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:21.543 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:21.559 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:21.570 CQG WebAPI | Connecting to server api.cqg.com | 2022-07-18 13:42:21.611 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-07-18 13:42:21.611 F.US.ENQU22 [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-18 13:42:21.617 CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2022-07-18 13:42:21.650 CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2022-07-18 13:42:21.650 CQG WebSocket socket (2) | Connecting to IP: 208.48.16.35. | 2022-07-18 13:42:21.650 CQG WebSocket | Opening WebSocket. | 2022-07-18 13:42:21.787 CQG WebSocket | Sending WebSocket handshake. | 2022-07-18 13:42:21.787 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:21.793 F.US.ENQU22 [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-18 13:42:21.800 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-18 13:42:21.888 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-07-18 13:42:22.023 CQG WebSocket | Server header | Connection: upgrade | 2022-07-18 13:42:22.023 CQG WebSocket | Server header | Sec-WebSocket-Accept: Fnweooj+oym2k84PoMpqhtuNYc0= | 2022-07-18 13:42:22.023 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-07-18 13:42:22.023 CQG WebSocket | Server header | Upgrade: websocket | 2022-07-18 13:42:22.023 CQG WebSocket | Server header | | 2022-07-18 13:42:22.023 CQG WebSocket | Web socket state is now open. | 2022-07-18 13:42:22.023 CQG WebAPI | WebSocket connected. | 2022-07-18 13:42:22.023 CQG WebAPI | Sending market data logon message. | 2022-07-18 13:42:22.023 F.US.ENQU22 [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-18 13:42:22.040 F.US.ENQU22 [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-18 13:42:22.162 CQG WebAPI | Base Time: 2022-07-17T17:00:53. 2022-07-17 17:00:53 | 2022-07-18 13:42:22.276 CQG WebAPI | Logon successful. Session Token = twzEpye5ZIEROGPplMfNp8NfLaGxcyHtLX07Rf/slFI6XiTfuoktV7B1Cy8ZK4QSGZwu4Qq/hsS | 2022-07-18 13:42:22.276 CQG WebAPI | Connected to server complete. | 2022-07-18 13:42:22.276 Triggering next historical data download in queue. | 2022-07-18 13:42:22.279 Triggering next historical data download in queue. | 2022-07-18 13:42:22.279 Triggering next historical data download in queue. | 2022-07-18 13:42:22.279 Triggering next historical data download in queue. | 2022-07-18 13:42:22.279 Subscribing to symbol for symbol alert. F.US.MNQM22 | 2022-07-18 13:42:22.279 Using symbol data fast lookup vector | 2022-07-18 13:42:22.279 CQG WebAPI | Starting real-time market data updates for: F.US.MNQM22. ID: 1 Service code: cqg | 2022-07-18 13:42:22.279 CQG WebAPI | Sending symbol resolution request for F.US.MNQM22. ID: 322242 | 2022-07-18 13:42:22.279 CQG WebAPI | Requesting security definition data for: F.US.MNQM22. ID: 1 | 2022-07-18 13:42:22.279 Updated verified funded futures trading account ending date to: 2022-08-17 13:42:22 | 2022-07-18 13:42:22.279 CQG WebAPI | Sending Trade Accounts request message. | 2022-07-18 13:42:23.601 HD Request # 45 | Downloading Intraday chart data for F.US.ENQH22 to the file F.US.ENQH22.scid. Service: cqg | 2022-07-18 13:42:23.601 HD Request # 45 | Performing multistage download. Downloading Minute data first. | 2022-07-18 13:42:23.602 HD Request # 45 | Download start date-time: 2022-03-14 06:00:39.000000. File last date-time: 2022-03-14 06:00:39.748001 | 2022-07-18 13:42:23.602 HD Request # 45 | Disabling Intraday chart updating for symbol. | 2022-07-18 13:42:23.602 CQG WebAPI | Sending symbol resolution request for F.US.ENQH22. ID: 322244 | 2022-07-18 13:42:23.602 No download requests in the queue to start downloads for. | 2022-07-18 13:42:23.602 No download requests in the queue to start downloads for. | 2022-07-18 13:42:23.602 No download requests in the queue to start downloads for. | 2022-07-18 13:42:23.602 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQM22. Search Symbol: F.US.MNQM22. Request ID: 322242. Contract ID: 1. | 2022-07-18 13:42:23.602 CQG WebAPI | Requesting market data for F.US.MNQM22 | 2022-07-18 13:42:23.602 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:23.605 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:23.605 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:23.707 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:23.739 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:23.788 CQG WebAPI | Received message: Requested symbol was not found. | 2022-07-18 13:42:23.795 HD Request # 45 | Error downloading historical Intraday data for F.US.ENQH22. Requested symbol was not found. | 2022-07-18 13:42:23.795 HD Request # 45 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQH22 | 2022-07-18 13:42:23.796 HD Request # 45 | Completion time: 0s | 2022-07-18 13:42:23.796 HD Request # 45 | Intraday data download complete for F.US.ENQH22. Unique request ID: 43 | 2022-07-18 13:42:23.796 Added historical Intraday data request for F.US.ENQH22 to the queue. | 2022-07-18 13:42:23.796 Triggering next historical data download in queue. | 2022-07-18 13:42:23.796 Symbol Error - F.US.ENQH22 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2022-07-18 13:42:23.796 CQG WebAPI | Brokerage name: AMP3. Account Name: 131836 | 2022-07-18 13:42:23.796 Updated verified funded futures trading account ending date to: 2022-08-17 13:42:23 | 2022-07-18 13:42:23.796 CQG WebAPI | Sending collateral subscribe request. | 2022-07-18 13:42:23.796 CQG WebAPI | Market data subscription for F.US.MNQM22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 1) is not enabled. | 2022-07-18 13:42:23.796 Symbol Error - F.US.MNQM22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 1) is not enabled. | 2022-07-18 13:42:23.796 HD Request # 46 | Downloading Intraday chart data for F.US.ENQH22 to the file F.US.ENQH22.scid. Service: cqg | 2022-07-18 13:42:23.796 HD Request # 46 | Rounding start date-time down to the minute: 2022-03-14 06:00:00.000 | 2022-07-18 13:42:23.796 HD Request # 46 | Download start date-time: 2022-03-14 06:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-18 13:42:23.796 HD Request # 46 | Error downloading historical Intraday data for F.US.ENQH22. The symbol is unknown to the server. | 2022-07-18 13:42:23.796 HD Request # 46 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQH22 | 2022-07-18 13:42:23.796 HD Request # 46 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-07-18 13:42:23.796 HD Request # 46 | Completion time: 0s | 2022-07-18 13:42:23.796 HD Request # 46 | Intraday data download complete for F.US.ENQH22. Unique request ID: 43 | 2022-07-18 13:42:23.796 Removing historical data download ID 43. | 2022-07-18 13:42:23.797 Real-time Intraday chart data file updates started for F.US.ENQH22 | 2022-07-18 13:42:23.797 Intraday chart data file opened for F.US.ENQH22 | 2022-07-18 13:42:23.797 HD Request # 46 | Enabling Intraday chart updating for symbol. | 2022-07-18 13:42:23.797 Triggering next historical data download in queue. | 2022-07-18 13:42:23.797 HD Request # 47 | Downloading Intraday chart data for F.US.ENQZ21 to the file F.US.ENQZ21.scid. Service: cqg | 2022-07-18 13:42:23.797 HD Request # 47 | Performing multistage download. Downloading Minute data first. | 2022-07-18 13:42:23.797 HD Request # 47 | Download start date-time: 2021-10-12 14:18:48.000000. File last date-time: 2021-10-12 14:18:48.000000 | 2022-07-18 13:42:23.797 HD Request # 47 | Disabling Intraday chart updating for symbol. | 2022-07-18 13:42:23.797 CQG WebAPI | Sending symbol resolution request for F.US.ENQZ21. ID: 322246 | 2022-07-18 13:42:23.797 CQG WebAPI | Starting real-time market data updates for: F.US.ENQU22. ID: 4 Service code: cqg | 2022-07-18 13:42:23.801 CQG WebAPI | Sending symbol resolution request for F.US.ENQU22. ID: 322247 | 2022-07-18 13:42:23.801 CQG WebAPI | Requesting security definition data for: F.US.ENQU22. ID: 4 | 2022-07-18 13:42:23.801 CQG WebAPI | Using primary service for historical data for F.US.ENQU22 | 2022-07-18 13:42:23.801 Added historical Intraday data request for F.US.ENQU22 to the queue. | 2022-07-18 13:42:23.801 Intraday data recording state for symbol F.US.ENQU22 is set to download 'Pending'. | 2022-07-18 13:42:23.801 Triggering next historical data download in queue. | 2022-07-18 13:42:23.801 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:23.916 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQZ21. Search Symbol: F.US.ENQZ21. Request ID: 322246. Contract ID: 2. | 2022-07-18 13:42:23.942 HD Request # 47 | Requesting historical Minute data. | 2022-07-18 13:42:23.942 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU22. Search Symbol: F.US.ENQU22. Request ID: 322247. Contract ID: 3. | 2022-07-18 13:42:23.942 CQG WebAPI | Requesting market data for F.US.ENQU22 | 2022-07-18 13:42:23.942 CQG WebAPI | Market data subscription for F.US.ENQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 3) is not enabled. | 2022-07-18 13:42:24.020 Symbol Error - F.US.ENQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 3) is not enabled. | 2022-07-18 13:42:24.020 HD Request # 47 | Error downloading historical Intraday data for F.US.ENQZ21. Instrument F.US.ENQ (corresponding to ID 2) is not allowed. | 2022-07-18 13:42:24.020 HD Request # 47 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQZ21 | 2022-07-18 13:42:24.020 HD Request # 47 | Completion time: 1s | 2022-07-18 13:42:24.020 HD Request # 47 | Intraday data download complete for F.US.ENQZ21. Unique request ID: 44 | 2022-07-18 13:42:24.020 Added historical Intraday data request for F.US.ENQZ21 to the queue. | 2022-07-18 13:42:24.020 Triggering next historical data download in queue. | 2022-07-18 13:42:24.020 HD Request # 48 | Downloading Intraday chart data for F.US.ENQZ21 to the file F.US.ENQZ21.scid. Service: cqg | 2022-07-18 13:42:24.020 HD Request # 48 | Rounding start date-time down to the minute: 2021-10-12 14:18:00.000 | 2022-07-18 13:42:24.021 HD Request # 48 | Download start date-time: 2021-10-12 14:18:00.000000. File last date-time: 00:00:00.000000 | 2022-07-18 13:42:24.021 HD Request # 48 | Requesting historical Tick data. | 2022-07-18 13:42:24.021 HD Request # 48 | Error downloading historical Intraday data for F.US.ENQZ21. Instrument F.US.ENQ (corresponding to ID 2) is not allowed. Result=103. Num Quotes=0 | 2022-07-18 13:42:24.742 HD Request # 48 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQZ21 | 2022-07-18 13:42:24.742 HD Request # 48 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-07-18 13:42:24.756 HD Request # 48 | Completion time: 0s | 2022-07-18 13:42:24.812 HD Request # 48 | Intraday data download complete for F.US.ENQZ21. Unique request ID: 44 | 2022-07-18 13:42:24.812 Removing historical data download ID 44. | 2022-07-18 13:42:24.812 Real-time Intraday chart data file updates started for F.US.ENQZ21 | 2022-07-18 13:42:24.812 Intraday chart data file opened for F.US.ENQZ21 | 2022-07-18 13:42:24.812 HD Request # 48 | Enabling Intraday chart updating for symbol. | 2022-07-18 13:42:24.812 Triggering next historical data download in queue. | 2022-07-18 13:42:24.902 HD Request # 49 | Downloading Intraday chart data for F.US.ENQU22 to the file F.US.ENQU22.scid. Service: cqg | 2022-07-18 13:42:24.902 HD Request # 49 | Download start date-time: 2022-07-15 17:10:58.000000. File last date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 13:42:24.903 HD Request # 49 | Requesting historical Tick data. | 2022-07-18 13:42:24.903 HD Request # 49 | Error downloading historical Intraday data for F.US.ENQU22. Instrument F.US.ENQ (corresponding to ID 3) is not allowed. Result=103. Num Quotes=0 | 2022-07-18 13:42:25.089 HD Request # 49 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQU22 | 2022-07-18 13:42:25.089 HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 13:42:25.090 HD Request # 49 | Completion time: 1s | 2022-07-18 13:42:25.090 HD Request # 49 | Intraday data download complete for F.US.ENQU22. Unique request ID: 45 | 2022-07-18 13:42:25.090 Removing historical data download ID 45. | 2022-07-18 13:42:25.090 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-18 13:42:25.090 Intraday chart data file opened for F.US.ENQU22 | 2022-07-18 13:42:25.090 HD Request # 49 | Enabling Intraday chart updating for symbol. | 2022-07-18 13:42:25.090 Triggering next historical data download in queue. | 2022-07-18 13:42:25.090 No download requests in the queue to start downloads for. | 2022-07-18 13:42:25.090 F.US.ENQU22 [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-18 13:42:26.137 F.US.ENQU22 [CBV][M] #16 | Reloading chart. | 2022-07-18 13:42:26.234 F.US.ENQU22[M]/F.US.MNQU22 [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 13:42:26.427 F.US.ENQU22 [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 13:42:26.444 F.US.ENQU22 [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 13:42:26.461 F.US.ENQU22 [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 13:42:26.477 F.US.ENQU22 [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 13:42:26.495 F.US.ENQU22 [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 13:42:26.642 F.US.ENQU22 [CBV][M] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:26.668 F.US.ENQU22 [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-18 13:42:26.668 CQG WebAPI | Starting real-time market data updates for: F.US.MNQU22. ID: 5 Service code: cqg | 2022-07-18 13:42:27.175 CQG WebAPI | Sending symbol resolution request for F.US.MNQU22. ID: 322251 | 2022-07-18 13:42:27.175 CQG WebAPI | Requesting security definition data for: F.US.MNQU22. ID: 5 | 2022-07-18 13:42:27.175 F.US.ENQU22 [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 13:42:27.192 F.US.ENQU22 [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 13:42:27.213 F.US.ENQU22 [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 13:42:27.231 F.US.ENQU22 [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 13:42:27.247 F.US.ENQU22 [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-18 13:42:27.263 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU22. Search Symbol: F.US.MNQU22. Request ID: 322251. Contract ID: 4. | 2022-07-18 13:42:27.552 CQG WebAPI | Requesting market data for F.US.MNQU22 | 2022-07-18 13:42:27.552 F.US.ENQU22 [CBV][M] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:27.580 F.US.ENQU22 [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-18 13:42:27.751 CQG WebAPI | Market data subscription for F.US.MNQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 4) is not enabled. | 2022-07-18 13:42:28.002 Symbol Error - F.US.MNQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 4) is not enabled. | 2022-07-18 13:42:28.002 F.US.ENQU22 [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-18 13:42:28.019 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:28.380 F.US.ENQU22 [CBV][M] 15 Min #30 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:42:28.455 F.US.ENQU22 [CBV][M] 15 Min #30 | Reloading chart. | 2022-07-18 13:42:28.455 CQG WebAPI | Sending positions subscribe request. RequestID: 322252 | 2022-07-18 13:42:28.871 CQG WebAPI | Sending orders subscribe request. RequestID: 322253 | 2022-07-18 13:42:28.871 F.US.ENQU22 [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-18 13:42:28.971 F.US.ENQU22 [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-18 13:42:32.219 F.US.ENQU22 [CBV][M] 15 Min #30 | Reloading chart. | 2022-07-18 13:42:32.681 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:44.478 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:44.478 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:44.478 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:44.478 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:45.752 F.US.ENQU22 [CBV] 15 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:42:52.488 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:52.716 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:53.211 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:54.357 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:54.361 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:42:54.391 F.US.ENQU22 512 Trades #14 | Reloading chart. | 2022-07-18 13:43:06.274 F.US.ENQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:43:06.930 F.US.ENQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:43:07.199 F.US.ENQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:43:13.723 F.US.ENQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:43:32.942 F.US.ENQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:43:33.919 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-18 13:44:17.049 DTC Client socket (1) | Closed. | 2022-07-18 13:44:17.049 DTC Client socket (1) | Deleting network socket now after delay. | 2022-07-18 13:44:47.055 CQG WebAPI | Sending Web API Logoff message. | 2022-07-18 13:46:10.636 CQG WebSocket socket (2) | CloseSocket call. | 2022-07-18 13:46:10.636 CQG WebSocket socket (2) | Max send buffers used during socket life: 3 | 2022-07-18 13:46:10.636 CQG WebSocket socket (2) | Max send buffer size during socket life: 340 | 2022-07-18 13:46:10.636 CQG WebSocket | WebSocket closed. | 2022-07-18 13:46:10.636 CQG WebAPI | WebSocket closed. | 2022-07-18 13:46:10.636 CQG WebAPI | Disconnected. | 2022-07-18 13:46:10.636 CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-18 13:46:10.637 CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2022-07-18 13:46:10.720 CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 13:46:10.720 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-18 13:46:10.800 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-18 13:46:10.800 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-18 13:46:10.800 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 11. | 2022-07-18 13:46:10.806 Current selected Data/Trading service: SC Data - All Services | 2022-07-18 13:46:10.806 SC Data - All Services | Disconnected. | 2022-07-18 13:46:11.997 SC Data - All Services | Disconnected. | 2022-07-18 13:46:12.001 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-18 13:46:12.001 NQU22-CME 512 Trades #14 | Reloading chart. | 2022-07-18 13:46:12.013 Mapping NQU22-CME to NQU22. Service code: cme | 2022-07-18 13:46:12.080 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-18 13:46:12.080 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-18 13:46:12.080 Triggering next historical data download in queue. | 2022-07-18 13:46:12.080 HD Request # 50 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-18 13:46:12.080 HD Request # 50 | Download start date-time: 2022-07-18 13:31:52.000000. File last date-time: 2022-07-18 13:31:52.578000 | 2022-07-18 13:46:12.081 HD Request # 50 | Using server: ds21.sierracharts.com port 10149 | 2022-07-18 13:46:12.081 Socket (3) | Creating socket. | 2022-07-18 13:46:12.082 Socket (3) | New receive buffer size: 5242880 | 2022-07-18 13:46:12.082 Socket (3) | Connecting to IP: 216.1.90.129. | 2022-07-18 13:46:12.082 HD Request # 50 | Setting DTC encoding to Binary VLS | 2022-07-18 13:46:12.143 HD Request # 50 | Sending historical data logon request message. | 2022-07-18 13:46:12.143 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Reloading chart. | 2022-07-18 13:46:12.532 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Performing continuous chart historical Daily data download for symbol NQU22-CME starting at last date in file. | 2022-07-18 13:46:12.549 Added historical Daily data request for NQU22-CME to the queue. | 2022-07-18 13:46:12.549 Triggering next historical data download in queue. | 2022-07-18 13:46:12.549 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.552 HD Request # 51 | Downloading Historical Daily chart data for NQU22-CME. Starting date: 2022-07-13. Service: scdataallservices | 2022-07-18 13:46:12.554 NQU22-CME [CBV] 375 Volume #19 | Reloading chart. | 2022-07-18 13:46:12.557 NQU22-CME [CBV] 375 Volume #19 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.563 NQU22-CME [CBV] 60 Min #15 | Reloading chart. | 2022-07-18 13:46:12.565 NQU22-CME [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.660 NQU22-CME[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:46:12.663 HD Request # 50 | Requesting Intraday data. Start date-time: 2022-07-18 13:31:52. Record interval: 0. Symbol: NQU22 | 2022-07-18 13:46:12.741 NQU22-CME [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-18 13:46:12.759 NQU22-CME [CBV] 3072 Trades #11 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.763 NQU22-CME [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-18 13:46:12.766 HD Request # 50 | Decompressing data. | 2022-07-18 13:46:12.769 NQU22-CME [CBV] 3072 Trades #4 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.770 NQU22-CME [CBV] 1 Min #27 | Reloading chart. | 2022-07-18 13:46:12.773 NQU22-CME [CBV] 1 Min #27 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.778 NQU22-CME [CBV] 15 Min #10 | Reloading chart. | 2022-07-18 13:46:12.783 NQU22-CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.798 NQU22-CME [CBV] 15 Min #30 | Reloading chart. | 2022-07-18 13:46:12.803 NQU22-CME [CBV] 15 Min #30 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.830 NQU22-CME [CBV] 1 Day #3 | Reloading chart. | 2022-07-18 13:46:12.833 NQU22-CME [CBV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.883 HD Request # 50 | Receiving Intraday data for NQU22-CME starting at 2022-07-18 13:31:52.068000 | 2022-07-18 13:46:12.915 NQU22-CME [CBV] 512 Trades #5 | Reloading chart. | 2022-07-18 13:46:12.932 NQU22-CME [CBV] 512 Trades #5 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.936 NQU22-CME [CBV] #16 | Reloading chart. | 2022-07-18 13:46:12.938 NQU22-CME [CBV] #16 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.953 NQU22-CME 1 Trades #21 | Reloading chart. | 2022-07-18 13:46:12.956 NQU22-CME 1 Trades #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22-CME.scid | 2022-07-18 13:46:12.962 NQU22-CME 512 Trades #17 | Reloading chart. | 2022-07-18 13:46:12.966 NQU22-CME [CBV] 60 Min #8 | Reloading chart. | 2022-07-18 13:46:12.971 NQU22-CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.975 NQU22-CME [CBV] 825 Trades #23 | Reloading chart. | 2022-07-18 13:46:12.977 NQU22-CME [CBV] 825 Trades #23 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.983 NQU22-CME [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-18 13:46:12.987 NQU22-CME [CBV] 7500 Volume #20 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.992 NQU22-CME [CBV] 5 Min #6 | Reloading chart. | 2022-07-18 13:46:12.993 NQU22-CME [CBV] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:12.998 NQU22-CME [CBV] 30 Min #2 | Reloading chart. | 2022-07-18 13:46:13.006 Socket (3) | CloseSocket call. | 2022-07-18 13:46:13.022 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-18 13:46:13.022 NQU22-CME [CBV] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:13.023 Historical data download thread signaled to stop. | 2022-07-18 13:46:13.025 HD Request # 50 | Timestamp of first Intraday data file record written: 2022-07-18 13:31:52.665000 | 2022-07-18 13:46:13.026 HD Request # 50 | Received 16276 Intraday data records from 2022-07-18 13:31:52.068000 to 2022-07-18 13:35:59.973001 (4.1 minutes) and wrote 16268 records for NQU22-CME | 2022-07-18 13:46:13.026 HD Request # 50 | Completion time: 1s | 2022-07-18 13:46:13.026 HD Request # 50 | Intraday data download complete for NQU22-CME. Unique request ID: 46 | 2022-07-18 13:46:13.026 Removing historical data download ID 46. | 2022-07-18 13:46:13.026 HD Request # 50 | Enabling Intraday chart updating for symbol. | 2022-07-18 13:46:13.026 Triggering next historical data download in queue. | 2022-07-18 13:46:13.026 Historical data for NQU22-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-07-18 13:46:13.026 No download requests in the queue to start downloads for. | 2022-07-18 13:46:13.026 Socket (3) | Socket gracefully closed by remote side. | 2022-07-18 13:46:13.099 Socket (3) | Closed. | 2022-07-18 13:46:13.099 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:13.244 Symbol settings MD5 received. Request ID: 11. | 2022-07-18 13:46:13.251 Requested symbol settings for service code scdataallservices. Request ID: 12. | 2022-07-18 13:46:13.251 NQU22-CME [CBV] 5 Min #25 | Reloading chart. | 2022-07-18 13:46:13.254 NQU22-CME [CBV] 5 Min #25 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:13.268 NQU22-CME [CBV] 60 Min #22 | Reloading chart. | 2022-07-18 13:46:13.271 NQU22-CME [CBV] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:13.286 HD Request # 51 | Requesting historical Daily data for NQU22 starting at 2022-07-12. SC External HD service. | 2022-07-18 13:46:13.287 NQU22-CME [CBV] 60 Min #29 | Reloading chart. | 2022-07-18 13:46:13.288 NQU22-CME [CBV] 60 Min #29 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:13.303 NQU22-CME [CBV] 750 Volume #1 | Reloading chart. | 2022-07-18 13:46:13.311 NQU22-CME [CBV] 750 Volume #1 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:13.325 NQU22-CME [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-18 13:46:13.327 NQU22-CME [CBV] 7500 Volume #7 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:13.340 NQU22-CME [CBV] 750 Volume #26 | Reloading chart. | 2022-07-18 13:46:13.347 NQU22-CME [CBV] 750 Volume #26 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:13.360 NQU22-CME [CBV] 240 Min #9 | Reloading chart. | 2022-07-18 13:46:13.361 NQU22-CME [CBV] 240 Min #9 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:13.374 NQU22-CME 30 Sec #13 | Reloading chart. | 2022-07-18 13:46:13.377 NQU22-CME 1 Min #18 | Reloading chart. | 2022-07-18 13:46:13.395 NQU22-CME 1250 Volume #24 | Reloading chart. | 2022-07-18 13:46:13.401 NQU22-CME [CBV] 5 Min #12 | Reloading chart. | 2022-07-18 13:46:13.406 NQU22-CME [CBV] 5 Min #12 | Waiting for historical downloads to complete with the IDs: 47, | 2022-07-18 13:46:13.422 HD Request # 51 | Receiving historical Daily data for NQU22-CME starting at 2022-07-13 | 2022-07-18 13:46:13.478 HD Request # 51 | Writing historical Daily data to the file NQU22-CME.dly | 2022-07-18 13:46:13.478 HD Request # 51 | Bytes received: 241 | 2022-07-18 13:46:13.479 HD Request # 51 | Received 4 Daily data records from 2022-07-13 00:00:00 to 2022-07-15 00:00:00 (3.0 days) and wrote 3 records for NQU22-CME | 2022-07-18 13:46:13.479 HD Request # 51 | Completion time: 1s | 2022-07-18 13:46:13.479 HD Request # 51 | Daily data download complete for NQU22-CME. Unique request ID: 47 | 2022-07-18 13:46:13.479 Removing historical data download ID 47. | 2022-07-18 13:46:13.479 Triggering next historical data download in queue. | 2022-07-18 13:46:13.479 No download requests in the queue to start downloads for. | 2022-07-18 13:46:13.479 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:13.480 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Reloading chart. | 2022-07-18 13:46:13.480 NQU22-CME [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:13.486 NQU22-CME [CBV] 60 Min #15 | Reloading chart. | 2022-07-18 13:46:13.486 NQU22-CME [CBV] 375 Volume #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:13.539 NQU22-CME [CBV] 375 Volume #19 | Reloading chart. | 2022-07-18 13:46:13.570 NQU22-CME [CBV] 3072 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:13.575 NQU22-CME [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-18 13:46:13.577 NQU22-CME [CBV] 3072 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:13.599 NQU22-CME [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-18 13:46:13.601 NQU22-CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:13.607 NQU22-CME [CBV] 15 Min #10 | Reloading chart. | 2022-07-18 13:46:13.608 NQU22-CME [CBV] 1 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:13.769 NQU22-CME [CBV] 1 Min #27 | Reloading chart. | 2022-07-18 13:46:13.908 NQU22-CME [CBV] 15 Min #30 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:13.917 NQU22-CME [CBV] 15 Min #30 | Reloading chart. | 2022-07-18 13:46:13.918 NQU22-CME [CBV] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:13.966 NQU22-CME [CBV] 1 Day #3 | Reloading chart. | 2022-07-18 13:46:13.966 NQU22-CME [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:14.302 NQU22-CME [CBV] #16 | Reloading chart. | 2022-07-18 13:46:14.328 NQU22-CME [CBV] 512 Trades #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:14.417 NQU22-CME [CBV] 512 Trades #5 | Reloading chart. | 2022-07-18 13:46:14.534 NQU22-CME[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:46:14.767 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:14.990 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:15.050 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:15.310 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:15.352 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:15.496 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:15.524 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:15.524 NQU22-CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:15.536 NQU22-CME [CBV] 60 Min #8 | Reloading chart. | 2022-07-18 13:46:15.537 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:15.548 NQU22-CME [CBV] 7500 Volume #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:15.603 NQU22-CME [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-18 13:46:15.611 NQU22-CME [CBV] 825 Trades #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:15.618 NQU22-CME [CBV] 825 Trades #23 | Reloading chart. | 2022-07-18 13:46:15.623 NQU22-CME [CBV] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:15.648 NQU22-CME [CBV] 30 Min #2 | Reloading chart. | 2022-07-18 13:46:15.648 NQU22-CME [CBV] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:15.849 NQU22-CME [CBV] 5 Min #6 | Reloading chart. | 2022-07-18 13:46:15.853 NQU22-CME [CBV] 5 Min #25 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:15.860 NQU22-CME [CBV] 5 Min #25 | Reloading chart. | 2022-07-18 13:46:15.860 NQU22-CME [CBV] 60 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:15.913 NQU22-CME [CBV] 60 Min #22 | Reloading chart. | 2022-07-18 13:46:15.913 NQU22-CME [CBV] 60 Min #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:15.996 NQU22-CME [CBV] 60 Min #29 | Reloading chart. | 2022-07-18 13:46:16.006 NQU22-CME [CBV] 750 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:16.047 NQU22-CME [CBV] 750 Volume #1 | Reloading chart. | 2022-07-18 13:46:16.048 NQU22-CME [CBV] 7500 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:16.074 NQU22-CME [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-18 13:46:16.238 NQU22-CME [CBV] 750 Volume #26 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:16.264 NQU22-CME [CBV] 750 Volume #26 | Reloading chart. | 2022-07-18 13:46:16.265 NQU22-CME [CBV] 240 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:16.381 NQU22-CME [CBV] 240 Min #9 | Reloading chart. | 2022-07-18 13:46:16.413 NQU22-CME [CBV] 5 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 13:46:16.614 NQU22-CME [CBV] 5 Min #12 | Reloading chart. | 2022-07-18 13:46:16.660 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:16.812 Symbol settings received. Request ID: 12. | 2022-07-18 13:46:17.018 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:17.400 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:17.400 NQU22-CME [CBV] 60 Min #15 | Reloading chart. | 2022-07-18 13:46:17.408 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Reloading chart. | 2022-07-18 13:46:18.241 SC Data - All Services | Connected to server complete. | 2022-07-18 13:46:18.395 Triggering next historical data download in queue. | 2022-07-18 13:46:18.395 Triggering next historical data download in queue. | 2022-07-18 13:46:18.395 Triggering next historical data download in queue. | 2022-07-18 13:46:18.395 Triggering next historical data download in queue. | 2022-07-18 13:46:18.395 Subscribing to symbol for symbol alert. MNQM22-CME | 2022-07-18 13:46:18.395 Mapping MNQM22-CME to MNQM22. Service code: cme | 2022-07-18 13:46:18.395 Using symbol data fast lookup vector | 2022-07-18 13:46:18.395 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MNQM22-CME (MNQM22). ID: 1 Service code: cme | 2022-07-18 13:46:18.395 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-07-18 13:46:18.395 SC DTC Delayed Exchange Data | Requesting security definition data for: MNQM22-CME (MNQM22). ID: 1 | 2022-07-18 13:46:18.396 DTC Client socket (1) | Creating socket. | 2022-07-18 13:46:18.396 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-18 13:46:18.396 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-07-18 13:46:18.396 No download requests in the queue to start downloads for. | 2022-07-18 13:46:19.850 No download requests in the queue to start downloads for. | 2022-07-18 13:46:19.850 No download requests in the queue to start downloads for. | 2022-07-18 13:46:19.850 No download requests in the queue to start downloads for. | 2022-07-18 13:46:19.850 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:19.911 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-18 13:46:19.920 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-18 13:46:19.920 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-18 13:46:19.920 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:20.004 NQU22-CME [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-18 13:46:20.076 NQU22-CME [CBV] 375 Volume #19 | Reloading chart. | 2022-07-18 13:46:20.098 NQU22-CME [CBV] 15 Min #10 | Reloading chart. | 2022-07-18 13:46:20.119 NQU22-CME [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-18 13:46:20.546 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-18 13:46:20.579 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-18 13:46:20.579 NQU22-CME [CBV] 1 Min #27 | Reloading chart. | 2022-07-18 13:46:20.649 NQU22-CME [CBV] 15 Min #30 | Reloading chart. | 2022-07-18 13:46:20.672 NQU22-CME [CBV] 1 Day #3 | Reloading chart. | 2022-07-18 13:46:21.052 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:22.350 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-18 13:46:22.489 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-18 13:46:22.489 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-18 13:46:22.489 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-18 13:46:22.489 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-18 13:46:22.489 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-18 13:46:22.490 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:22.532 NQU22-CME [CBV] #16 | Reloading chart. | 2022-07-18 13:46:22.608 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-18 13:46:22.673 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-18 13:46:22.673 Mapping NQU22-CME to NQU22. Service code: cme | 2022-07-18 13:46:23.059 SC DTC Delayed Exchange Data | Starting real-time market data updates for: NQU22-CME (NQU22). ID: 2 Service code: cme | 2022-07-18 13:46:23.059 SC DTC Delayed Exchange Data | Requesting security definition data for: NQU22-CME (NQU22). ID: 2 | 2022-07-18 13:46:23.059 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-18 13:46:23.060 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-18 13:46:23.060 Triggering next historical data download in queue. | 2022-07-18 13:46:23.142 Delaying start of download for NQU22-CME | 2022-07-18 13:46:23.145 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-18 13:46:23.342 NQU22-CME [CBV] 512 Trades #5 | Reloading chart. | 2022-07-18 13:46:24.235 NQU22-CME [CBV] 60 Min #8 | Reloading chart. | 2022-07-18 13:46:24.483 NQU22-CME [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-18 13:46:24.598 NQU22-CME [CBV] 825 Trades #23 | Reloading chart. | 2022-07-18 13:46:24.618 NQU22-CME [CBV] 30 Min #2 | Reloading chart. | 2022-07-18 13:46:24.644 NQU22-CME [CBV] 5 Min #25 | Reloading chart. | 2022-07-18 13:46:24.925 NQU22-CME [CBV] 5 Min #6 | Reloading chart. | 2022-07-18 13:46:24.985 NQU22-CME [CBV] 60 Min #22 | Reloading chart. | 2022-07-18 13:46:25.004 NQU22-CME [CBV] 60 Min #29 | Reloading chart. | 2022-07-18 13:46:25.214 NQU22-CME [CBV] 750 Volume #1 | Reloading chart. | 2022-07-18 13:46:25.265 NQU22-CME [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-18 13:46:25.527 NQU22-CME [CBV] 750 Volume #26 | Reloading chart. | 2022-07-18 13:46:30.135 NQU22-CME [CBV] 240 Min #9 | Reloading chart. | 2022-07-18 13:46:30.299 NQU22-CME [CBV] 5 Min #12 | Reloading chart. | 2022-07-18 13:46:30.390 Mapping MNQU22-CME to MNQU22. Service code: cme | 2022-07-18 13:46:30.466 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MNQU22-CME (MNQU22). ID: 3 Service code: cme | 2022-07-18 13:46:30.466 SC DTC Delayed Exchange Data | Requesting security definition data for: MNQU22-CME (MNQU22). ID: 3 | 2022-07-18 13:46:30.466 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-18 13:46:30.678 HD Request # 52 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-18 13:46:30.911 HD Request # 52 | Download start date-time: 2022-07-18 13:35:59.000000. File last date-time: 2022-07-18 13:35:59.973001 | 2022-07-18 13:46:30.913 HD Request # 52 | Using server: ds23.sierracharts.com port 10150 | 2022-07-18 13:46:30.913 Socket (3) | Creating socket. | 2022-07-18 13:46:30.916 Socket (3) | New receive buffer size: 5242880 | 2022-07-18 13:46:30.916 Socket (3) | Connecting to IP: 216.1.90.130. | 2022-07-18 13:46:30.916 HD Request # 52 | Setting DTC encoding to Binary VLS | 2022-07-18 13:46:31.053 HD Request # 52 | Sending historical data logon request message. | 2022-07-18 13:46:31.053 HD Request # 52 | Requesting Intraday data. Start date-time: 2022-07-18 13:35:59. Record interval: 0. Symbol: NQU22 | 2022-07-18 13:46:31.613 HD Request # 52 | Decompressing data. | 2022-07-18 13:46:31.659 HD Request # 52 | Receiving Intraday data for NQU22-CME starting at 2022-07-18 13:35:59.065000 | 2022-07-18 13:46:31.660 Socket (3) | CloseSocket call. | 2022-07-18 13:46:31.789 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-18 13:46:31.789 Socket (3) | Socket gracefully closed by remote side. | 2022-07-18 13:46:31.873 Socket (3) | Closed. | 2022-07-18 13:46:31.874 Historical data download thread signaled to stop. | 2022-07-18 13:46:32.052 HD Request # 52 | Timestamp of first Intraday data file record written: 2022-07-18 13:36:00.026000 | 2022-07-18 13:46:32.053 HD Request # 52 | Received 1476 Intraday data records from 2022-07-18 13:35:59.065000 to 2022-07-18 13:36:18.907000 (19.8 seconds) and wrote 1375 records for NQU22-CME | 2022-07-18 13:46:32.053 HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2022-07-18 13:36:18.907000 | 2022-07-18 13:46:32.061 HD Request # 52 | Completion time: 2s | 2022-07-18 13:46:32.114 HD Request # 52 | Intraday data download complete for NQU22-CME. Unique request ID: 48 | 2022-07-18 13:46:32.114 Removing historical data download ID 48. | 2022-07-18 13:46:32.114 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-18 13:46:32.114 Intraday chart data file opened for NQU22-CME | 2022-07-18 13:46:32.114 HD Request # 52 | Enabling Intraday chart updating for symbol. | 2022-07-18 13:46:32.114 Triggering next historical data download in queue. | 2022-07-18 13:46:32.114 No download requests in the queue to start downloads for. | 2022-07-18 13:46:32.114 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 16240 | 2022-07-18 13:46:32.129 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:34.598 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:34.856 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:40.859 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:40.859 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:40.859 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:40.859 NQU22-CME [CBV][M] 15 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 13:46:48.682 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:50.873 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:57.851 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:57.938 NQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:58.020 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:58.354 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:58.356 NQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 13:46:58.473 CQG WebSocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-18 13:48:17.219 CQG WebSocket socket (2) | Closed. | 2022-07-18 13:48:17.220 CQG WebSocket socket (2) | Deleting network socket now after delay. | 2022-07-18 13:48:47.229 The request for the installer program MD5 has been made. | 2022-07-18 14:10:35.781 * The request for the installer program has been made. | 2022-07-18 14:10:36.766 Request for installer program has been redirected. Request ID: 2 -> 3. New URL: https://download2.sierrachart.com/downloads/SierraChartFileDownloader.exe | 2022-07-18 14:10:37.642 File has been written to: C:\SierraChart\SierraChartFileDownloader.exe. File Size: 8671232 bytes. | 2022-07-18 14:10:56.831 Sierra Chart account data changed. Requesting updated account information. | 2022-07-18 14:12:52.389 Successfully processed Sierra Chart account data. | 2022-07-18 14:12:55.163 HTTPS connection ID:3 to download2.sierrachart.com:443 for request ID:3 (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-18 14:13:17.603 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-18 14:14:33.105 DTC Client socket (1) | CloseSocket call. | 2022-07-18 14:14:33.106 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:14:33.106 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-18 14:14:33.106 SC Data - All Services | Disconnected. | 2022-07-18 14:14:33.106 SC Data - All Services | Disconnected. | 2022-07-18 14:14:33.155 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 13. | 2022-07-18 14:14:33.159 Current selected Data/Trading service: CQG WebAPI | 2022-07-18 14:14:33.159 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-18 14:14:34.684 F.US.ENQU22[M] 512 Trades #14 | Reloading chart. | 2022-07-18 14:14:34.779 F.US.ENQU22[M] 512 Trades #17 | Reloading chart. | 2022-07-18 14:14:34.823 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-18 14:14:34.834 F.US.ENQU22[M] 30 Sec #13 | Reloading chart. | 2022-07-18 14:14:34.893 F.US.ENQU22[M] 1 Min #18 | Reloading chart. | 2022-07-18 14:14:34.903 F.US.ENQU22 [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 14:14:34.915 F.US.ENQU22 [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-18 14:14:34.936 F.US.ENQU22 [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 14:14:35.020 F.US.ENQU22[M]/F.US.MNQU22 [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 14:14:35.037 F.US.ENQU22 [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-18 14:14:35.052 F.US.ENQU22 [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-18 14:14:35.102 Symbol settings MD5 received. Request ID: 13. | 2022-07-18 14:14:35.227 Requested symbol settings for service code cqg. Request ID: 14. | 2022-07-18 14:14:35.227 F.US.ENQU22[M] 1250 Volume #24 | Reloading chart. | 2022-07-18 14:14:35.234 F.US.ENQU22 [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-18 14:14:35.256 F.US.ENQU22 [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 14:14:35.580 F.US.ENQU22 [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-18 14:14:35.609 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:36.044 F.US.ENQU22[M] 1 Trades #21 | Reloading chart. | 2022-07-18 14:14:36.073 F.US.ENQU22 [CBV][M] #16 | Reloading chart. | 2022-07-18 14:14:36.085 F.US.ENQU22[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:14:36.262 F.US.ENQU22 [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-18 14:14:36.346 F.US.ENQU22 [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-18 14:14:36.712 F.US.ENQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:14:36.896 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:37.384 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:37.418 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:37.652 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:38.317 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:38.361 Symbol settings received. Request ID: 14. | 2022-07-18 14:14:38.472 F.US.ENQU22 [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 14:14:38.812 F.US.ENQU22 [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-18 14:14:38.829 F.US.ENQU22 [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 14:14:38.906 F.US.ENQU22 [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 14:14:38.924 F.US.ENQU22 [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-18 14:14:38.957 F.US.ENQU22 [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 14:14:39.240 F.US.ENQU22 [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 14:14:39.280 F.US.ENQU22 [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-18 14:14:39.491 F.US.ENQU22 [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-18 14:14:39.592 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:39.850 F.US.ENQU22 [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 14:14:39.874 F.US.ENQU22 [CBV][M] 15 Min #30 | Reloading chart. | 2022-07-18 14:14:39.902 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:40.390 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:40.690 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:40.977 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:41.315 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:41.315 CQG WebAPI | Connecting to server api.cqg.com | 2022-07-18 14:14:41.549 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-07-18 14:14:41.549 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:41.948 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:42.638 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:42.638 CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2022-07-18 14:14:45.351 CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2022-07-18 14:14:45.351 CQG WebSocket socket (2) | Connecting to IP: 208.48.16.35. | 2022-07-18 14:14:45.351 CQG WebSocket | Opening WebSocket. | 2022-07-18 14:14:45.379 CQG WebSocket | Sending WebSocket handshake. | 2022-07-18 14:14:45.379 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-07-18 14:14:45.447 CQG WebSocket | Server header | Connection: upgrade | 2022-07-18 14:14:45.447 CQG WebSocket | Server header | Sec-WebSocket-Accept: KrROXYLwpU6PzBRg9ppgNOOYbKU= | 2022-07-18 14:14:45.447 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-07-18 14:14:45.447 CQG WebSocket | Server header | Upgrade: websocket | 2022-07-18 14:14:45.447 CQG WebSocket | Server header | | 2022-07-18 14:14:45.447 CQG WebSocket | Web socket state is now open. | 2022-07-18 14:14:45.447 CQG WebAPI | WebSocket connected. | 2022-07-18 14:14:45.447 CQG WebAPI | Sending market data logon message. | 2022-07-18 14:14:45.447 CQG WebAPI | Base Time: 2022-07-17T17:00:53. 2022-07-17 17:00:53 | 2022-07-18 14:14:45.583 CQG WebAPI | Logon successful. Session Token = 4qQQHQSJcfDgA0aQZLLimyCTd73Wl+sN7Ig9Xd3LVE0YP9WQh06P5HLclE5l/YP8/kIeZq/38ED | 2022-07-18 14:14:45.583 CQG WebAPI | Connected to server complete. | 2022-07-18 14:14:45.583 Triggering next historical data download in queue. | 2022-07-18 14:14:45.584 Triggering next historical data download in queue. | 2022-07-18 14:14:45.584 Triggering next historical data download in queue. | 2022-07-18 14:14:45.584 Triggering next historical data download in queue. | 2022-07-18 14:14:45.584 Subscribing to symbol for symbol alert. F.US.MNQM22 | 2022-07-18 14:14:45.584 Using symbol data fast lookup vector | 2022-07-18 14:14:45.584 CQG WebAPI | Starting real-time market data updates for: F.US.MNQM22. ID: 1 Service code: cqg | 2022-07-18 14:14:45.585 CQG WebAPI | Sending symbol resolution request for F.US.MNQM22. ID: 533456 | 2022-07-18 14:14:45.585 CQG WebAPI | Requesting security definition data for: F.US.MNQM22. ID: 1 | 2022-07-18 14:14:45.585 Updated verified funded futures trading account ending date to: 2022-08-17 14:14:45 | 2022-07-18 14:14:45.585 CQG WebAPI | Sending Trade Accounts request message. | 2022-07-18 14:14:45.646 No download requests in the queue to start downloads for. | 2022-07-18 14:14:45.646 No download requests in the queue to start downloads for. | 2022-07-18 14:14:45.646 No download requests in the queue to start downloads for. | 2022-07-18 14:14:45.646 No download requests in the queue to start downloads for. | 2022-07-18 14:14:45.646 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQM22. Search Symbol: F.US.MNQM22. Request ID: 533456. Contract ID: 1. | 2022-07-18 14:14:45.646 CQG WebAPI | Requesting market data for F.US.MNQM22 | 2022-07-18 14:14:45.646 CQG WebAPI | Starting real-time market data updates for: F.US.ENQU22. ID: 2 Service code: cqg | 2022-07-18 14:14:45.685 CQG WebAPI | Sending symbol resolution request for F.US.ENQU22. ID: 533458 | 2022-07-18 14:14:45.685 CQG WebAPI | Requesting security definition data for: F.US.ENQU22. ID: 2 | 2022-07-18 14:14:45.685 CQG WebAPI | Using primary service for historical data for F.US.ENQU22 | 2022-07-18 14:14:45.685 Starting DelayedDownloadMonitoringTimer | 2022-07-18 14:14:45.685 Starting HDTimeoutTimer | 2022-07-18 14:14:45.685 Added historical Intraday data request for F.US.ENQU22 to the queue. | 2022-07-18 14:14:45.685 Intraday data recording state for symbol F.US.ENQU22 is set to download 'Pending'. | 2022-07-18 14:14:45.685 Triggering next historical data download in queue. | 2022-07-18 14:14:45.717 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU22. Search Symbol: F.US.ENQU22. Request ID: 533458. Contract ID: 2. | 2022-07-18 14:14:45.717 CQG WebAPI | Requesting market data for F.US.ENQU22 | 2022-07-18 14:14:45.717 CQG WebAPI | Brokerage name: AMP3. Account Name: 131836 | 2022-07-18 14:14:45.717 Updated verified funded futures trading account ending date to: 2022-08-17 14:14:45 | 2022-07-18 14:14:45.717 CQG WebAPI | Sending collateral subscribe request. | 2022-07-18 14:14:45.717 CQG WebAPI | Market data subscription for F.US.MNQM22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 1) is not enabled. | 2022-07-18 14:14:45.717 Symbol Error - F.US.MNQM22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 1) is not enabled. | 2022-07-18 14:14:45.717 Delaying start of download for F.US.ENQU22 | 2022-07-18 14:14:45.717 CQG WebAPI | Market data subscription for F.US.ENQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 2) is not enabled. | 2022-07-18 14:14:46.237 Symbol Error - F.US.ENQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 2) is not enabled. | 2022-07-18 14:14:46.237 CQG WebAPI | Starting real-time market data updates for: F.US.MNQU22. ID: 3 Service code: cqg | 2022-07-18 14:14:48.660 CQG WebAPI | Sending symbol resolution request for F.US.MNQU22. ID: 533460 | 2022-07-18 14:14:48.660 CQG WebAPI | Requesting security definition data for: F.US.MNQU22. ID: 3 | 2022-07-18 14:14:48.660 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU22. Search Symbol: F.US.MNQU22. Request ID: 533460. Contract ID: 3. | 2022-07-18 14:14:48.811 CQG WebAPI | Requesting market data for F.US.MNQU22 | 2022-07-18 14:14:48.811 CQG WebAPI | Market data subscription for F.US.MNQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 3) is not enabled. | 2022-07-18 14:14:49.084 Symbol Error - F.US.MNQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 3) is not enabled. | 2022-07-18 14:14:49.084 HD Request # 53 | Downloading Intraday chart data for F.US.ENQU22 to the file F.US.ENQU22.scid. Service: cqg | 2022-07-18 14:14:49.203 HD Request # 53 | Download start date-time: 2022-07-15 17:10:58.000000. File last date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 14:14:49.204 HD Request # 53 | Requesting historical Tick data. | 2022-07-18 14:14:49.204 HD Request # 53 | Error downloading historical Intraday data for F.US.ENQU22. Instrument F.US.ENQ (corresponding to ID 2) is not allowed. Result=103. Num Quotes=0 | 2022-07-18 14:14:49.291 HD Request # 53 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQU22 | 2022-07-18 14:14:49.361 HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 14:14:49.362 HD Request # 53 | Completion time: 0s | 2022-07-18 14:14:49.362 HD Request # 53 | Intraday data download complete for F.US.ENQU22. Unique request ID: 49 | 2022-07-18 14:14:49.362 Removing historical data download ID 49. | 2022-07-18 14:14:49.362 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-18 14:14:49.362 Intraday chart data file opened for F.US.ENQU22 | 2022-07-18 14:14:49.362 HD Request # 53 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:14:49.362 Triggering next historical data download in queue. | 2022-07-18 14:14:49.362 No download requests in the queue to start downloads for. | 2022-07-18 14:14:49.362 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:51.167 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:51.186 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:51.186 CQG WebAPI | Sending positions subscribe request. RequestID: 533462 | 2022-07-18 14:14:51.237 CQG WebAPI | Sending orders subscribe request. RequestID: 533463 | 2022-07-18 14:14:51.237 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:51.586 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:51.625 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:14:59.451 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:05.190 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:05.190 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:05.190 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:05.190 F.US.ENQU22 [CBV] 15 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:15:11.349 F.US.ENQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:11.571 F.US.ENQU22 [CBV] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:11.688 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:11.690 F.US.ENQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:11.778 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:11.901 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:11.904 F.US.ENQU22 [CBV] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:11.919 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:12.004 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:12.659 F.US.ENQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:15:12.667 F.US.ENQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:15:22.413 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-18 14:16:47.719 DTC Client socket (1) | Closed. | 2022-07-18 14:16:47.719 DTC Client socket (1) | Deleting network socket now after delay. | 2022-07-18 14:17:17.726 CQG WebAPI | Sending Web API Logoff message. | 2022-07-18 14:17:46.002 CQG WebSocket socket (2) | CloseSocket call. | 2022-07-18 14:17:46.002 CQG WebSocket | WebSocket closed. | 2022-07-18 14:17:46.002 CQG WebAPI | WebSocket closed. | 2022-07-18 14:17:46.002 CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-18 14:17:46.002 CQG WebAPI | Disconnected. | 2022-07-18 14:17:46.003 CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2022-07-18 14:17:46.016 CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:17:46.016 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-18 14:17:46.062 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-18 14:17:46.062 CQG WebSocket socket (0) | CloseSocket call. | 2022-07-18 14:17:46.062 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 15. | 2022-07-18 14:17:46.068 Current selected Data/Trading service: SC Data - All Services | 2022-07-18 14:17:46.068 SC Data - All Services | Disconnected. | 2022-07-18 14:17:47.910 SC Data - All Services | Disconnected. | 2022-07-18 14:17:47.914 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-18 14:17:47.914 NQU22-CME [CBV] 512 Trades #5 | Reloading chart. | 2022-07-18 14:17:48.025 NQU22-CME [CBV] 60 Min #29 | Reloading chart. | 2022-07-18 14:17:48.053 NQU22-CME [CBV] 750 Volume #1 | Reloading chart. | 2022-07-18 14:17:48.128 NQU22-CME [CBV] 1 Min #27 | Reloading chart. | 2022-07-18 14:17:48.188 NQU22-CME 512 Trades #17 | Reloading chart. | 2022-07-18 14:17:48.214 NQU22-CME [CBV] 7500 Volume #7 | Reloading chart. | 2022-07-18 14:17:48.237 Symbol settings MD5 received. Request ID: 15. | 2022-07-18 14:17:48.311 Requested symbol settings for service code scdataallservices. Request ID: 16. | 2022-07-18 14:17:48.311 NQU22-CME 30 Sec #13 | Reloading chart. | 2022-07-18 14:17:48.319 NQU22-CME [CBV] 375 Volume #19 | Reloading chart. | 2022-07-18 14:17:48.342 NQU22-CME 512 Trades #14 | Reloading chart. | 2022-07-18 14:17:48.366 NQU22-CME [CBV] 7500 Volume #20 | Reloading chart. | 2022-07-18 14:17:48.420 NQU22-CME [CBV] 825 Trades #23 | Reloading chart. | 2022-07-18 14:17:48.439 NQU22-CME [CBV] 30 Min #2 | Reloading chart. | 2022-07-18 14:17:48.458 NQU22-CME [CBV] 750 Volume #26 | Reloading chart. | 2022-07-18 14:17:48.731 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:48.866 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:48.883 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:48.883 NQU22-CME [CBV] 15 Min #30 | Reloading chart. | 2022-07-18 14:17:48.895 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:49.207 NQU22-CME 1 Min #18 | Reloading chart. | 2022-07-18 14:17:49.290 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:49.326 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:49.384 NQU22-CME [CBV] 5 Min #6 | Reloading chart. | 2022-07-18 14:17:49.487 NQU22-CME [CBV] 60 Min #22 | Reloading chart. | 2022-07-18 14:17:49.543 NQU22-CME [CBV] 60 Min #8 | Reloading chart. | 2022-07-18 14:17:49.668 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:49.685 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:49.685 NQU22-CME/MNQU22-CME [CBV] 500 Volume #28 | Reloading chart. | 2022-07-18 14:17:49.691 NQU22-CME [CBV] 5 Min #25 | Reloading chart. | 2022-07-18 14:17:49.808 NQU22-CME [CBV] 3072 Trades #11 | Reloading chart. | 2022-07-18 14:17:49.905 NQU22-CME [CBV] #16 | Reloading chart. | 2022-07-18 14:17:49.920 NQU22-CME 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:17:50.155 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:50.456 NQU22-CME 1 Trades #21 | Reloading chart. | 2022-07-18 14:17:50.496 NQU22-CME [CBV] 15 Min #10 | Reloading chart. | 2022-07-18 14:17:50.504 NQU22-CME 1 Trades #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22-CME.scid | 2022-07-18 14:17:50.692 NQU22-CME [CBV] 1 Day #3 | Reloading chart. | 2022-07-18 14:17:50.695 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:51.546 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:51.686 NQU22-CME [CBV] 5 Min #12 | Reloading chart. | 2022-07-18 14:17:51.774 NQU22-CME 1250 Volume #24 | Reloading chart. | 2022-07-18 14:17:51.860 NQU22-CME [CBV] 60 Min #15 | Reloading chart. | 2022-07-18 14:17:51.867 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:52.212 NQU22-CME [CBV] 240 Min #9 | Reloading chart. | 2022-07-18 14:17:52.229 Symbol settings received. Request ID: 16. | 2022-07-18 14:17:52.520 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:52.833 NQU22-CME [CBV] 3072 Trades #4 | Reloading chart. | 2022-07-18 14:17:52.855 Mapping NQU22-CME to NQU22. Service code: cme | 2022-07-18 14:17:52.876 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-18 14:17:52.876 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-18 14:17:52.876 Triggering next historical data download in queue. | 2022-07-18 14:17:52.876 HD Request # 54 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-18 14:17:53.050 HD Request # 54 | Download start date-time: 2022-07-18 14:04:10.000000. File last date-time: 2022-07-18 14:04:10.194000 | 2022-07-18 14:17:53.063 HD Request # 54 | Using server: ds21.sierracharts.com port 10149 | 2022-07-18 14:17:53.064 Socket (4) | Creating socket. | 2022-07-18 14:17:53.076 Socket (4) | New receive buffer size: 5242880 | 2022-07-18 14:17:53.076 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-07-18 14:17:53.076 HD Request # 54 | Setting DTC encoding to Binary VLS | 2022-07-18 14:17:53.132 HD Request # 54 | Sending historical data logon request message. | 2022-07-18 14:17:53.132 SC Data - All Services | Connected to server complete. | 2022-07-18 14:17:53.685 Triggering next historical data download in queue. | 2022-07-18 14:17:53.685 Triggering next historical data download in queue. | 2022-07-18 14:17:53.685 Triggering next historical data download in queue. | 2022-07-18 14:17:53.685 Triggering next historical data download in queue. | 2022-07-18 14:17:53.685 Subscribing to symbol for symbol alert. MNQM22-CME | 2022-07-18 14:17:53.685 Mapping MNQM22-CME to MNQM22. Service code: cme | 2022-07-18 14:17:53.686 Using symbol data fast lookup vector | 2022-07-18 14:17:53.686 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MNQM22-CME (MNQM22). ID: 1 Service code: cme | 2022-07-18 14:17:53.686 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-07-18 14:17:53.686 SC DTC Delayed Exchange Data | Requesting security definition data for: MNQM22-CME (MNQM22). ID: 1 | 2022-07-18 14:17:53.686 DTC Client socket (1) | Creating socket. | 2022-07-18 14:17:53.687 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-18 14:17:53.687 DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2022-07-18 14:17:53.687 No download requests in the queue to start downloads for. | 2022-07-18 14:17:53.695 No download requests in the queue to start downloads for. | 2022-07-18 14:17:53.695 No download requests in the queue to start downloads for. | 2022-07-18 14:17:53.695 Mapping NQU22-CME to NQU22. Service code: cme | 2022-07-18 14:17:53.704 SC DTC Delayed Exchange Data | Starting real-time market data updates for: NQU22-CME (NQU22). ID: 2 Service code: cme | 2022-07-18 14:17:53.704 SC DTC Delayed Exchange Data | Requesting security definition data for: NQU22-CME (NQU22). ID: 2 | 2022-07-18 14:17:53.704 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-18 14:17:53.742 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-18 14:17:53.742 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-18 14:17:53.742 HD Request # 54 | Requesting Intraday data. Start date-time: 2022-07-18 14:04:10. Record interval: 0. Symbol: NQU22 | 2022-07-18 14:17:53.758 HD Request # 54 | Decompressing data. | 2022-07-18 14:17:53.788 HD Request # 54 | Receiving Intraday data for NQU22-CME starting at 2022-07-18 14:04:10.194000 | 2022-07-18 14:17:53.789 Mapping MNQU22-CME to MNQU22. Service code: cme | 2022-07-18 14:17:53.816 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MNQU22-CME (MNQU22). ID: 3 Service code: cme | 2022-07-18 14:17:53.816 SC DTC Delayed Exchange Data | Requesting security definition data for: MNQU22-CME (MNQU22). ID: 3 | 2022-07-18 14:17:53.816 Socket (4) | CloseSocket call. | 2022-07-18 14:17:53.908 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:17:53.908 Socket (4) | Socket gracefully closed by remote side. | 2022-07-18 14:17:53.938 Socket (4) | Closed. | 2022-07-18 14:17:53.938 Historical data download thread signaled to stop. | 2022-07-18 14:17:54.042 HD Request # 54 | Timestamp of first Intraday data file record written: 2022-07-18 14:04:10.195000 | 2022-07-18 14:17:54.042 HD Request # 54 | Received 4717 Intraday data records from 2022-07-18 14:04:10.194000 to 2022-07-18 14:07:40.968000 (3.5 minutes) and wrote 4716 records for NQU22-CME | 2022-07-18 14:17:54.043 HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2022-07-18 14:07:40.968000 | 2022-07-18 14:17:54.048 HD Request # 54 | Completion time: 1s | 2022-07-18 14:17:54.052 HD Request # 54 | Intraday data download complete for NQU22-CME. Unique request ID: 50 | 2022-07-18 14:17:54.052 Removing historical data download ID 50. | 2022-07-18 14:17:54.052 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-18 14:17:54.052 Intraday chart data file opened for NQU22-CME | 2022-07-18 14:17:54.052 HD Request # 54 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:17:54.052 Triggering next historical data download in queue. | 2022-07-18 14:17:54.052 Initiating new historical data download for NQU22-CME to get the latest data since the download was started while not connected to primary service. | 2022-07-18 14:17:54.052 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-18 14:17:54.052 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-18 14:17:54.052 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-18 14:17:54.052 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-18 14:17:54.052 Delaying start of download for NQU22-CME | 2022-07-18 14:17:54.053 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.248 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.574 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.583 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.583 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.592 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.622 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.685 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.710 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-18 14:17:54.778 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-18 14:17:54.778 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-18 14:17:54.778 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-18 14:17:54.778 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-18 14:17:54.778 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQM22-CME -> MNQM22 | 2022-07-18 14:17:54.778 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MNQU22-CME -> MNQU22 | 2022-07-18 14:17:54.778 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-18 14:17:54.778 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.800 SC DTC Delayed Exchange Data | Real-time data for symbol MNQM22-CME is currently unavailable. | 2022-07-18 14:17:54.907 SC DTC Delayed Exchange Data | Received security definition for symbol MNQM22-CME | 2022-07-18 14:17:54.907 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-18 14:17:54.907 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-18 14:17:54.907 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:17:54.912 NQU22-CME[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:17:54.951 HD Request # 55 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-18 14:17:59.852 HD Request # 55 | Download start date-time: 2022-07-18 14:07:40.000000. File last date-time: 2022-07-18 14:07:40.968000 | 2022-07-18 14:17:59.852 HD Request # 55 | Using server: ds23.sierracharts.com port 10150 | 2022-07-18 14:17:59.852 Socket (3) | Creating socket. | 2022-07-18 14:17:59.867 Socket (3) | New receive buffer size: 5242880 | 2022-07-18 14:17:59.867 Socket (3) | Connecting to IP: 216.1.90.130. | 2022-07-18 14:17:59.867 HD Request # 55 | Setting DTC encoding to Binary VLS | 2022-07-18 14:18:00.033 HD Request # 55 | Sending historical data logon request message. | 2022-07-18 14:18:00.033 HD Request # 55 | Requesting Intraday data. Start date-time: 2022-07-18 14:07:40. Record interval: 0. Symbol: NQU22 | 2022-07-18 14:18:00.612 HD Request # 55 | Decompressing data. | 2022-07-18 14:18:00.641 HD Request # 55 | Receiving Intraday data for NQU22-CME starting at 2022-07-18 14:07:40.073000 | 2022-07-18 14:18:00.641 Socket (3) | CloseSocket call. | 2022-07-18 14:18:00.642 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:18:00.642 Socket (3) | Socket gracefully closed by remote side. | 2022-07-18 14:18:00.668 Socket (3) | Closed. | 2022-07-18 14:18:00.668 Historical data download thread signaled to stop. | 2022-07-18 14:18:00.724 HD Request # 55 | Timestamp of first Intraday data file record written: 2022-07-18 14:07:41.192000 | 2022-07-18 14:18:00.724 HD Request # 55 | Received 115 Intraday data records from 2022-07-18 14:07:40.073000 to 2022-07-18 14:07:47.961000 (7.9 seconds) and wrote 86 records for NQU22-CME | 2022-07-18 14:18:00.724 HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2022-07-18 14:07:47.961000 | 2022-07-18 14:18:00.732 HD Request # 55 | Completion time: 1s | 2022-07-18 14:18:00.736 HD Request # 55 | Intraday data download complete for NQU22-CME. Unique request ID: 51 | 2022-07-18 14:18:00.736 Removing historical data download ID 51. | 2022-07-18 14:18:00.736 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-18 14:18:00.736 Intraday chart data file opened for NQU22-CME | 2022-07-18 14:18:00.736 HD Request # 55 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:18:00.736 Triggering next historical data download in queue. | 2022-07-18 14:18:00.738 No download requests in the queue to start downloads for. | 2022-07-18 14:18:00.738 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 25080 | 2022-07-18 14:18:00.841 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:01.771 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:10.915 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:10.915 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:10.915 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:10.915 NQU22-CME [CBV][M] 15 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:18:24.224 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:25.337 NQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:28.464 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:28.598 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:28.601 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:28.717 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:29.628 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:29.718 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:29.719 NQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:18:29.851 CQG WebSocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-18 14:19:47.772 CQG WebSocket socket (2) | Closed. | 2022-07-18 14:19:47.772 CQG WebSocket socket (2) | Deleting network socket now after delay. | 2022-07-18 14:20:17.782 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-18 14:26:49.841 DTC Client socket (1) | CloseSocket call. | 2022-07-18 14:26:49.842 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-18 14:26:49.842 SC Data - All Services | Disconnected. | 2022-07-18 14:26:49.842 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:26:49.842 Symbol settings could not be loaded because there are no applicable files to load. | 2022-07-18 14:26:49.842 Requested symbol settings for service code sc_futures.dtc.trading. Request ID: 17. | 2022-07-18 14:26:49.842 SC Data - All Services | Disconnected. | 2022-07-18 14:26:49.845 Current selected Data/Trading service: SC/TT Futures Order Routing | 2022-07-18 14:26:49.860 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-07-18 14:26:49.872 DTC Client socket (1) | Closed. | 2022-07-18 14:26:49.872 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-18 14:26:51.254 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:51.533 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:51.578 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:51.578 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.395 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.398 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.398 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.436 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.444 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.476 NQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.502 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.609 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.730 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.735 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.735 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.881 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:52.888 Symbol settings received. Request ID: 17. | 2022-07-18 14:26:52.982 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:53.178 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:53.763 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:53.763 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:53.763 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:53.763 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:53.775 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:53.784 SC/TT Futures Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2022-07-18 14:26:54.415 NQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:54.416 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2022-07-18 14:26:54.488 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-07-18 14:26:54.488 DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-07-18 14:26:54.488 SC/TT Futures Order Routing | Network connection to server complete. | 2022-07-18 14:26:54.520 SC/TT Futures Order Routing | Starting socket receive thread. | 2022-07-18 14:26:54.520 SC/TT Futures Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-07-18 14:26:54.520 NQU22-CME [CBV][M] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:26:54.528 SC/TT Futures Order Routing | Setting DTC encoding to Binary VLS | 2022-07-18 14:26:54.582 SC/TT Futures Order Routing | Sending logon request message. | 2022-07-18 14:26:54.582 SC/TT Futures Order Routing | Received logon response. | 2022-07-18 14:26:54.605 SC/TT Futures Order Routing | Server Name: SC DTC Server. | 2022-07-18 14:26:54.605 SC/TT Futures Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-07-18 14:26:54.605 SC/TT Futures Order Routing | Connection error: Trade account not assigned. | 2022-07-18 14:26:54.605 * SC/TT Futures Order Routing | Waiting for socket receive thread to end | 2022-07-18 14:26:54.633 DTC Client socket (3) | CloseSocket call. | 2022-07-18 14:26:54.633 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:26:54.633 SC/TT Futures Order Routing | Disconnected. | 2022-07-18 14:26:54.633 DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-07-18 14:26:54.654 DTC Client socket (3) | Closed. | 2022-07-18 14:26:54.654 WSACleanup called. | 2022-07-18 14:27:43.674 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 18. | 2022-07-18 14:27:43.679 Current selected Data/Trading service: Teton CME Order Routing | 2022-07-18 14:27:43.679 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-18 14:27:44.729 Enabling compression for file: C:\SierraChart\Data\NQU22_FUT_CME.scid. This may take a while. | 2022-07-18 14:27:44.853 File compression enabled. C:\SierraChart\Data\NQU22_FUT_CME.scid. CompressionState=0 | 2022-07-18 14:27:44.853 NQU22_FUT_CME[M]/MNQU22_FUT_CME [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 14:27:44.855 Added historical Intraday data request for NQU22_FUT_CME to the queue. | 2022-07-18 14:27:44.862 Triggering next historical data download in queue. | 2022-07-18 14:27:44.862 NQU22_FUT_CME[M]/MNQU22_FUT_CME [CBV][M] 500 Volume #28 | Performing continuous chart historical Daily data download for symbol NQU22_FUT_CME starting at last date in file. | 2022-07-18 14:27:44.872 Added historical Daily data request for NQU22_FUT_CME to the queue. | 2022-07-18 14:27:44.873 Triggering next historical data download in queue. | 2022-07-18 14:27:44.873 NQU22_FUT_CME[M]/MNQU22_FUT_CME [CBV][M] 500 Volume #28 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:44.874 Mapping NQU22_FUT_CME to NQU22. Service code: cme | 2022-07-18 14:27:44.879 HD Request # 56 | Downloading Intraday chart data for NQU22_FUT_CME to the file NQU22_FUT_CME.scid. Service: cme | 2022-07-18 14:27:44.881 HD Request # 56 | Download start date-time: 2022-05-25 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-18 14:27:44.882 HD Request # 56 | Using server: ds21.sierracharts.com port 10149 | 2022-07-18 14:27:44.883 Socket (2) | Creating socket. | 2022-07-18 14:27:44.883 Socket (2) | New receive buffer size: 5242880 | 2022-07-18 14:27:44.884 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-07-18 14:27:44.884 HD Request # 57 | Downloading Historical Daily chart data for NQU22_FUT_CME. Starting date: 1972-07-18. Service: sc_futures_direct.dtc.trading | 2022-07-18 14:27:44.885 HD Request # 56 | Setting DTC encoding to Binary VLS | 2022-07-18 14:27:44.930 HD Request # 56 | Sending historical data logon request message. | 2022-07-18 14:27:44.930 NQU22_FUT_CME [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-18 14:27:45.332 Added historical Intraday data request for NQM22_FUT_CME to the queue. | 2022-07-18 14:27:45.357 Triggering next historical data download in queue. | 2022-07-18 14:27:45.357 NQU22_FUT_CME [CBV][M] 750 Volume #1 | Performing continuous chart historical Daily data download for symbol NQM22_FUT_CME starting at last date in file. | 2022-07-18 14:27:45.363 Added historical Daily data request for NQM22_FUT_CME to the queue. | 2022-07-18 14:27:45.363 Triggering next historical data download in queue. | 2022-07-18 14:27:45.363 NQU22_FUT_CME [CBV][M] 750 Volume #1 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.370 NQU22_FUT_CME [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 14:27:45.372 NQU22_FUT_CME [CBV][M] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:45.373 NQU22_FUT_CME[M] 512 Trades #14 | Reloading chart. | 2022-07-18 14:27:45.376 NQU22_FUT_CME[M] 512 Trades #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22_FUT_CME.scid | 2022-07-18 14:27:45.383 NQU22_FUT_CME [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-18 14:27:45.389 Added historical Intraday data request for NQZ21_FUT_CME to the queue. | 2022-07-18 14:27:45.397 Triggering next historical data download in queue. | 2022-07-18 14:27:45.397 Added historical Intraday data request for NQH22_FUT_CME to the queue. | 2022-07-18 14:27:45.408 HD Request # 56 | Requesting Intraday data. Start date-time: 2022-05-25 00:00:00. Record interval: 0. Symbol: NQU22 | 2022-07-18 14:27:45.412 Enabling compression for file: C:\SierraChart\Data\NQH22_FUT_CME.dly. This may take a while. | 2022-07-18 14:27:45.423 File compression enabled. C:\SierraChart\Data\NQH22_FUT_CME.dly. CompressionState=0 | 2022-07-18 14:27:45.423 HD Request # 56 | Decompressing data. | 2022-07-18 14:27:45.430 Enabling compression for file: C:\SierraChart\Data\NQZ21_FUT_CME.dly. This may take a while. | 2022-07-18 14:27:45.434 File compression enabled. C:\SierraChart\Data\NQZ21_FUT_CME.dly. CompressionState=0 | 2022-07-18 14:27:45.434 Enabling compression for file: C:\SierraChart\Data\NQU21_FUT_CME.dly. This may take a while. | 2022-07-18 14:27:45.445 File compression enabled. C:\SierraChart\Data\NQU21_FUT_CME.dly. CompressionState=0 | 2022-07-18 14:27:45.445 NQU22_FUT_CME [CBV][M] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, 56, 57, | 2022-07-18 14:27:45.455 NQU22_FUT_CME [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 14:27:45.456 NQU22_FUT_CME [CBV][M] 1 Min #27 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:45.457 NQU22_FUT_CME [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-18 14:27:45.458 NQU22_FUT_CME [CBV][M] 240 Min #9 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.464 NQU22_FUT_CME [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-18 14:27:45.466 NQU22_FUT_CME [CBV][M] 7500 Volume #7 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.473 NQU22_FUT_CME[M] 512 Trades #17 | Reloading chart. | 2022-07-18 14:27:45.475 NQU22_FUT_CME[M] 512 Trades #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22_FUT_CME.scid | 2022-07-18 14:27:45.481 NQU22_FUT_CME [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-18 14:27:45.482 NQU22_FUT_CME [CBV][M] 5 Min #25 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.490 NQU22_FUT_CME[M] 1250 Volume #24 | Reloading chart. | 2022-07-18 14:27:45.491 NQU22_FUT_CME[M] 1250 Volume #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22_FUT_CME.scid | 2022-07-18 14:27:45.496 NQU22_FUT_CME [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 14:27:45.497 NQU22_FUT_CME [CBV][M] 375 Volume #19 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:45.498 NQU22_FUT_CME [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 14:27:45.499 NQU22_FUT_CME [CBV][M] 3072 Trades #4 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:45.500 NQU22_FUT_CME[M] 30 Sec #13 | Reloading chart. | 2022-07-18 14:27:45.505 NQU22_FUT_CME[M] 30 Sec #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22_FUT_CME.scid | 2022-07-18 14:27:45.510 NQU22_FUT_CME [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-18 14:27:45.514 NQU22_FUT_CME [CBV][M] 750 Volume #26 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.523 HD Request # 56 | Receiving Intraday data for NQU22_FUT_CME starting at 2022-05-25 00:06:58.526000 | 2022-07-18 14:27:45.523 Symbol settings MD5 received. Request ID: 18. | 2022-07-18 14:27:45.524 Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 19. | 2022-07-18 14:27:45.524 NQU22_FUT_CME[M] 1 Min #18 | Reloading chart. | 2022-07-18 14:27:45.525 NQU22_FUT_CME[M] 1 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22_FUT_CME.scid | 2022-07-18 14:27:45.530 NQU22_FUT_CME [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-18 14:27:45.532 NQU22_FUT_CME [CBV][M] 5 Min #12 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.539 NQU22_FUT_CME [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 14:27:45.543 NQU22_FUT_CME [CBV][M] 825 Trades #23 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:45.544 NQU22_FUT_CME [CBV][M] 15 Min #30 | Reloading chart. | 2022-07-18 14:27:45.555 NQU22_FUT_CME [CBV][M] 15 Min #30 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, 57, | 2022-07-18 14:27:45.576 NQU22_FUT_CME [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-18 14:27:45.578 NQU22_FUT_CME [CBV][M] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, 56, 57, | 2022-07-18 14:27:45.622 HD Request # 57 | Requesting historical Daily data for NQU22 starting at 1972-07-17. SC External HD service. | 2022-07-18 14:27:45.623 NQU22_FUT_CME [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 14:27:45.624 NQU22_FUT_CME [CBV][M] 3072 Trades #11 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:45.625 NQU22_FUT_CME [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 14:27:45.626 NQU22_FUT_CME [CBV][M] 7500 Volume #20 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:45.626 NQU22_FUT_CME [CBV][M] #16 | Reloading chart. | 2022-07-18 14:27:45.629 NQU22_FUT_CME [CBV][M] #16 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.636 NQU22_FUT_CME [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-18 14:27:45.640 NQU22_FUT_CME [CBV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.646 NQU22_FUT_CME [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 14:27:45.648 NQU22_FUT_CME [CBV][M] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:45.649 NQU22_FUT_CME [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 14:27:45.651 NQU22_FUT_CME [CBV][M] 512 Trades #5 | Waiting for historical downloads to complete with the IDs: 52, 53, | 2022-07-18 14:27:45.652 NQU22_FUT_CME[M] 1 Trades #21 | Reloading chart. | 2022-07-18 14:27:45.657 NQU22_FUT_CME[M] 1 Trades #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22_FUT_CME.scid | 2022-07-18 14:27:45.662 NQU22_FUT_CME [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-18 14:27:45.664 NQU22_FUT_CME [CBV][M] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.672 NQU22_FUT_CME [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-18 14:27:45.675 NQU22_FUT_CME [CBV][M] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.682 NQU22_FUT_CME [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-18 14:27:45.683 NQU22_FUT_CME [CBV][M] 60 Min #29 | Waiting for historical downloads to complete with the IDs: 52, 53, 54, 55, | 2022-07-18 14:27:45.690 HD Request # 56 | Timestamp of first Intraday data file record written: 2022-05-25 00:06:58.526000 | 2022-07-18 14:27:45.729 NQU22_FUT_CME[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:27:45.760 HD Request # 57 | Receiving historical Daily data for NQU22_FUT_CME starting at 2021-06-17 | 2022-07-18 14:27:45.875 HD Request # 57 | Writing historical Daily data to the file NQU22_FUT_CME.dly | 2022-07-18 14:27:45.876 HD Request # 57 | Bytes received: 16995 | 2022-07-18 14:27:45.888 HD Request # 57 | Received 272 Daily data records from 2021-06-17 00:00:00 to 2022-07-15 00:00:00 (394.0 days) and wrote 272 records for NQU22_FUT_CME | 2022-07-18 14:27:45.888 HD Request # 57 | Completion time: 1s | 2022-07-18 14:27:45.888 HD Request # 57 | Daily data download complete for NQU22_FUT_CME. Unique request ID: 53 | 2022-07-18 14:27:45.888 Removing historical data download ID 53. | 2022-07-18 14:27:45.888 Triggering next historical data download in queue. | 2022-07-18 14:27:45.888 Mapping NQM22_FUT_CME to NQM22. Service code: cme | 2022-07-18 14:27:45.888 HD Request # 58 | Downloading Historical Daily chart data for NQM22_FUT_CME. Starting date: 2022-04-27. Service: sc_futures_direct.dtc.trading | 2022-07-18 14:27:45.890 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:27:45.985 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:27:46.114 NQU22_FUT_CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:27:46.272 NQU22_FUT_CME[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:27:47.121 HD Request # 58 | Requesting historical Daily data for NQM22 starting at 2022-04-26. SC External HD service. | 2022-07-18 14:27:49.412 HD Request # 58 | Receiving historical Daily data for NQM22_FUT_CME starting at 2022-04-27 | 2022-07-18 14:27:52.174 HD Request # 58 | Writing historical Daily data to the file NQM22_FUT_CME.dly | 2022-07-18 14:27:52.175 HD Request # 58 | Bytes received: 2350 | 2022-07-18 14:27:52.176 HD Request # 58 | Received 38 Daily data records from 2022-04-27 00:00:00 to 2022-06-17 00:00:00 (52.0 days) and wrote 37 records for NQM22_FUT_CME | 2022-07-18 14:27:52.176 HD Request # 58 | Completion time: 7s | 2022-07-18 14:27:52.177 HD Request # 58 | Daily data download complete for NQM22_FUT_CME. Unique request ID: 55 | 2022-07-18 14:27:52.177 Removing historical data download ID 55. | 2022-07-18 14:27:52.177 Triggering next historical data download in queue. | 2022-07-18 14:27:52.177 No download requests in the queue to start downloads for. | 2022-07-18 14:27:52.177 Symbol settings received. Request ID: 19. | 2022-07-18 14:27:52.191 Socket (2) | New receive buffer size: 10485760 | 2022-07-18 14:27:53.425 Socket (2) | New receive buffer size: 16777216 | 2022-07-18 14:27:59.539 Socket (2) | CloseSocket call. | 2022-07-18 14:28:11.707 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:28:11.707 Socket (2) | Socket gracefully closed by remote side. | 2022-07-18 14:28:11.729 Socket (2) | Closed. | 2022-07-18 14:28:11.729 Historical data download thread signaled to stop. | 2022-07-18 14:28:14.728 HD Request # 56 | Received 13883853 Intraday data records from 2022-05-25 00:06:58.526000 to 2022-07-18 14:17:58.902000 (54.6 days) and wrote 13883853 records for NQU22_FUT_CME | 2022-07-18 14:28:14.762 HD Request # 56 | Completion time: 30s | 2022-07-18 14:28:14.856 HD Request # 56 | Intraday data download complete for NQU22_FUT_CME. Unique request ID: 52 | 2022-07-18 14:28:14.856 Removing historical data download ID 52. | 2022-07-18 14:28:14.856 HD Request # 56 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:28:14.856 Triggering next historical data download in queue. | 2022-07-18 14:28:14.856 Historical data for NQU22_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-07-18 14:28:14.856 HD Request # 59 | Downloading Intraday chart data for NQM22_FUT_CME to the file NQM22_FUT_CME.scid. Service: cme | 2022-07-18 14:28:14.856 HD Request # 59 | Download start date-time: 2022-05-02 13:36:14.000000. File last date-time: 2022-05-02 13:36:14.000000 | 2022-07-18 14:28:14.857 HD Request # 59 | Using server: ds23.sierracharts.com port 10150 | 2022-07-18 14:28:14.857 Socket (2) | Creating socket. | 2022-07-18 14:28:14.858 Socket (2) | New receive buffer size: 5242880 | 2022-07-18 14:28:14.858 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-07-18 14:28:14.858 HD Request # 59 | Setting DTC encoding to Binary VLS | 2022-07-18 14:28:14.915 HD Request # 59 | Sending historical data logon request message. | 2022-07-18 14:28:14.915 Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11093 | 2022-07-18 14:28:15.046 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2022-07-18 14:28:15.047 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-07-18 14:28:15.047 DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-07-18 14:28:15.047 HD Request # 59 | Requesting Intraday data. Start date-time: 2022-05-02 13:36:14. Record interval: 0. Symbol: NQM22 | 2022-07-18 14:28:15.462 HD Request # 59 | Decompressing data. | 2022-07-18 14:28:15.480 HD Request # 59 | Receiving Intraday data for NQM22_FUT_CME starting at 2022-05-02 13:36:14.000000 | 2022-07-18 14:28:17.328 Socket (2) | New receive buffer size: 10485760 | 2022-07-18 14:28:17.334 Teton CME Order Routing | Network connection to server complete. | 2022-07-18 14:28:17.385 Teton CME Order Routing | Starting socket receive thread. | 2022-07-18 14:28:17.385 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-07-18 14:28:17.385 NQU22_FUT_CME [CBV][M] 512 Trades #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:17.387 NQU22_FUT_CME [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 14:28:17.520 NQU22_FUT_CME [CBV][M] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:17.525 NQU22_FUT_CME [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 14:28:17.525 HD Request # 59 | Timestamp of first Intraday data file record written: 2022-05-02 13:36:14.000001 | 2022-07-18 14:28:17.527 NQU22_FUT_CME[M]/MNQU22_FUT_CME [CBV][M] 500 Volume #28 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:17.531 NQU22_FUT_CME[M]/MNQU22_FUT_CME [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 14:28:17.531 NQU22_FUT_CME [CBV][M] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:17.539 NQU22_FUT_CME [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 14:28:17.541 NQU22_FUT_CME [CBV][M] 1 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:17.546 NQU22_FUT_CME [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 14:28:17.547 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:18.758 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-07-18 14:28:18.766 Teton CME Order Routing | Sending logon request message. | 2022-07-18 14:28:18.766 DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-07-18 14:28:21.257 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:21.608 Teton CME Order Routing | Received logon response. | 2022-07-18 14:28:21.630 Teton CME Order Routing | Server Name: SC DTC Server. | 2022-07-18 14:28:21.630 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-07-18 14:28:21.630 Teton CME Order Routing | Connection error: No trade accounts assigned. | 2022-07-18 14:28:21.630 * Teton CME Order Routing | Waiting for socket receive thread to end | 2022-07-18 14:28:21.644 DTC Client socket (3) | CloseSocket call. | 2022-07-18 14:28:21.644 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-07-18 14:28:21.644 DTC Client socket (3) | Closed. | 2022-07-18 14:28:21.644 Teton CME Order Routing | Disconnected. | 2022-07-18 14:28:21.644 NQU22_FUT_CME [CBV][M] 3072 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:21.647 NQU22_FUT_CME [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 14:28:21.649 NQU22_FUT_CME [CBV][M] 375 Volume #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:21.660 NQU22_FUT_CME [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 14:28:21.661 Socket (2) | New receive buffer size: 16777216 | 2022-07-18 14:28:23.963 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:24.486 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:24.486 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:24.494 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:24.516 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:24.530 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:24.562 NQU22_FUT_CME [CBV][M] 825 Trades #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:24.569 NQU22_FUT_CME [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 14:28:24.569 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:27.111 NQU22_FUT_CME [CBV][M] 7500 Volume #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:27.135 NQU22_FUT_CME [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 14:28:27.136 NQU22_FUT_CME [CBV][M] 3072 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:28:27.150 NQU22_FUT_CME [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 14:28:27.154 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:49.148 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:49.170 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:49.193 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:49.205 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:49.205 NQU22_FUT_CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:28:49.597 NQU22_FUT_CME [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 14:28:50.127 Enabling compression for file: C:\SierraChart\Data\NQU22_FUT_CME.dly. This may take a while. | 2022-07-18 14:28:50.128 File compression enabled. C:\SierraChart\Data\NQU22_FUT_CME.dly. CompressionState=0 | 2022-07-18 14:28:50.128 NQU22_FUT_CME[M]/MNQU22_FUT_CME [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 14:28:50.137 NQU22_FUT_CME [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 14:28:50.150 NQU22_FUT_CME [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 14:28:50.224 NQU22_FUT_CME [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 14:28:50.321 NQU22_FUT_CME [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 14:28:50.363 NQU22_FUT_CME [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 14:28:50.379 NQU22_FUT_CME [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 14:28:50.395 NQU22_FUT_CME [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 14:28:50.415 NQU22_FUT_CME [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 14:28:50.441 Socket (2) | CloseSocket call. | 2022-07-18 14:28:56.011 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:28:56.011 Socket (2) | Socket gracefully closed by remote side. | 2022-07-18 14:28:56.030 Socket (2) | Closed. | 2022-07-18 14:28:56.030 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.561 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.561 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.587 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.603 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.613 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.622 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.651 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.659 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.674 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.701 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:15.711 Historical data download thread signaled to stop. | 2022-07-18 14:29:15.720 HD Request # 59 | Received 19236137 Intraday data records from 2022-05-02 13:36:14.000000 to 2022-06-17 13:29:57.034000 (46.0 days) and wrote 19236136 records for NQM22_FUT_CME | 2022-07-18 14:29:15.720 HD Request # 59 | Completion time: 1m 1s | 2022-07-18 14:29:15.720 HD Request # 59 | Intraday data download complete for NQM22_FUT_CME. Unique request ID: 54 | 2022-07-18 14:29:15.720 Removing historical data download ID 54. | 2022-07-18 14:29:15.720 HD Request # 59 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:29:15.720 Triggering next historical data download in queue. | 2022-07-18 14:29:15.720 Historical data for NQM22_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-07-18 14:29:15.720 Mapping NQZ21_FUT_CME to NQZ21. Service code: cme | 2022-07-18 14:29:15.720 HD Request # 60 | Downloading Intraday chart data for NQZ21_FUT_CME to the file NQZ21_FUT_CME.scid. Service: cme | 2022-07-18 14:29:15.721 HD Request # 60 | Download start date-time: 2021-08-25 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-18 14:29:15.721 HD Request # 60 | Using server: ds21.sierracharts.com port 10149 | 2022-07-18 14:29:15.721 Socket (1) | Creating socket. | 2022-07-18 14:29:15.723 Socket (1) | New receive buffer size: 5242880 | 2022-07-18 14:29:15.723 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-07-18 14:29:15.723 HD Request # 60 | Setting DTC encoding to Binary VLS | 2022-07-18 14:29:15.783 HD Request # 60 | Sending historical data logon request message. | 2022-07-18 14:29:15.783 NQU22_FUT_CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:29:16.023 HD Request # 60 | Requesting Intraday data. Start date-time: 2021-08-25 00:00:00. Record interval: 0. Symbol: NQZ21 | 2022-07-18 14:29:16.286 HD Request # 60 | Decompressing data. | 2022-07-18 14:29:16.312 HD Request # 60 | Receiving Intraday data for NQZ21_FUT_CME starting at 2021-08-25 00:00:38.550000 | 2022-07-18 14:29:16.408 NQU22_FUT_CME [CBV][M] 60 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.497 NQU22_FUT_CME [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-18 14:29:16.499 NQU22_FUT_CME [CBV][M] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.514 NQU22_FUT_CME [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-18 14:29:16.555 NQU22_FUT_CME [CBV][M] 60 Min #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.572 NQU22_FUT_CME [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-18 14:29:16.576 NQU22_FUT_CME [CBV][M] 750 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.611 NQU22_FUT_CME [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-18 14:29:16.617 HD Request # 60 | Timestamp of first Intraday data file record written: 2021-08-25 00:00:38.550000 | 2022-07-18 14:29:16.619 NQU22_FUT_CME [CBV][M] 240 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.638 NQU22_FUT_CME [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-18 14:29:16.658 NQU22_FUT_CME [CBV][M] 7500 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.692 NQU22_FUT_CME [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-18 14:29:16.693 NQU22_FUT_CME [CBV][M] 5 Min #25 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.755 NQU22_FUT_CME [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-18 14:29:16.818 NQU22_FUT_CME [CBV][M] 750 Volume #26 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.871 NQU22_FUT_CME [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-18 14:29:16.878 NQU22_FUT_CME [CBV][M] 5 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.912 NQU22_FUT_CME [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-18 14:29:16.914 Mapping MNQU22_FUT_CME to MNQU22. Service code: cme | 2022-07-18 14:29:16.963 NQU22_FUT_CME [CBV][M] #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:16.990 NQU22_FUT_CME [CBV][M] #16 | Reloading chart. | 2022-07-18 14:29:17.006 NQU22_FUT_CME [CBV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:29:17.067 NQU22_FUT_CME [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-18 14:29:17.076 Socket (1) | New receive buffer size: 10485760 | 2022-07-18 14:29:21.271 Socket (1) | New receive buffer size: 16777216 | 2022-07-18 14:29:21.390 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:30:11.386 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:30:12.412 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:30:12.413 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:30:12.413 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:30:12.413 NQU22_FUT_CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:30:12.887 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:30:12.907 NQU22_FUT_CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:30:13.061 NQU22_FUT_CME [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-18 14:30:13.777 NQU22_FUT_CME [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-18 14:30:13.858 NQU22_FUT_CME [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-18 14:30:14.012 NQU22_FUT_CME [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-18 14:30:14.122 NQU22_FUT_CME [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-18 14:30:14.257 Socket (1) | CloseSocket call. | 2022-07-18 14:30:23.476 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:30:23.476 Socket (1) | Socket gracefully closed by remote side. | 2022-07-18 14:30:23.498 Socket (1) | Closed. | 2022-07-18 14:30:23.498 Historical data download thread signaled to stop. | 2022-07-18 14:31:15.738 HD Request # 60 | Received 33742607 Intraday data records from 2021-08-25 00:00:38.550000 to 2021-12-17 14:29:56.869000 (114.6 days) and wrote 33742607 records for NQZ21_FUT_CME | 2022-07-18 14:31:15.745 HD Request # 60 | Completion time: 2m | 2022-07-18 14:31:15.747 HD Request # 60 | Intraday data download complete for NQZ21_FUT_CME. Unique request ID: 56 | 2022-07-18 14:31:15.747 Removing historical data download ID 56. | 2022-07-18 14:31:15.747 HD Request # 60 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:31:15.748 Triggering next historical data download in queue. | 2022-07-18 14:31:15.748 Historical data for NQZ21_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-07-18 14:31:15.748 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:31:16.533 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:31:16.533 Mapping NQH22_FUT_CME to NQH22. Service code: cme | 2022-07-18 14:31:16.697 HD Request # 61 | Downloading Intraday chart data for NQH22_FUT_CME to the file NQH22_FUT_CME.scid. Service: cme | 2022-07-18 14:31:16.701 HD Request # 61 | Download start date-time: 2021-11-24 00:00:00.000000. File last date-time: 00:00:00.000000 | 2022-07-18 14:31:16.702 HD Request # 61 | Using server: ds23.sierracharts.com port 10150 | 2022-07-18 14:31:16.703 Socket (1) | Creating socket. | 2022-07-18 14:31:16.704 Socket (1) | New receive buffer size: 5242880 | 2022-07-18 14:31:16.705 Socket (1) | Connecting to IP: 216.1.90.130. | 2022-07-18 14:31:16.705 HD Request # 61 | Setting DTC encoding to Binary VLS | 2022-07-18 14:31:16.756 HD Request # 61 | Sending historical data logon request message. | 2022-07-18 14:31:16.756 NQU22_FUT_CME [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-18 14:31:17.200 NQU22_FUT_CME [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-18 14:31:17.236 HD Request # 61 | Requesting Intraday data. Start date-time: 2021-11-24 00:00:00. Record interval: 0. Symbol: NQH22 | 2022-07-18 14:31:17.303 NQU22_FUT_CME [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-18 14:31:17.324 HD Request # 61 | Decompressing data. | 2022-07-18 14:31:17.326 NQU22_FUT_CME [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-18 14:31:17.407 HD Request # 61 | Receiving Intraday data for NQH22_FUT_CME starting at 2021-11-24 00:00:10.764000 | 2022-07-18 14:31:17.552 NQU22_FUT_CME [CBV][M] #16 | Reloading chart. | 2022-07-18 14:31:17.571 NQU22_FUT_CME [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-18 14:31:17.705 HD Request # 61 | Timestamp of first Intraday data file record written: 2021-11-24 00:00:10.764000 | 2022-07-18 14:31:17.782 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:31:26.067 NQU22_FUT_CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:31:41.008 NQU22_FUT_CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:31:41.753 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:31:41.764 NQU22_FUT_CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:31:41.779 Socket (1) | CloseSocket call. | 2022-07-18 14:32:45.849 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:32:45.849 Historical data download thread signaled to stop. | 2022-07-18 14:32:45.849 HD Request # 61 | Received 39932334 Intraday data records from 2021-11-24 00:00:10.764000 to 2022-03-18 13:29:57.710000 (114.6 days) and wrote 39932334 records for NQH22_FUT_CME | 2022-07-18 14:32:45.850 HD Request # 61 | Completion time: 1m 29s | 2022-07-18 14:32:45.850 HD Request # 61 | Intraday data download complete for NQH22_FUT_CME. Unique request ID: 57 | 2022-07-18 14:32:45.850 Removing historical data download ID 57. | 2022-07-18 14:32:45.850 HD Request # 61 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:32:45.850 Triggering next historical data download in queue. | 2022-07-18 14:32:45.850 Historical data for NQH22_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-07-18 14:32:45.850 No download requests in the queue to start downloads for. | 2022-07-18 14:32:45.850 Socket (1) | Socket gracefully closed by remote side. | 2022-07-18 14:32:45.870 Socket (1) | Closed. | 2022-07-18 14:32:45.870 NQU22_FUT_CME [CBV][M] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:32:45.935 NQU22_FUT_CME [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-18 14:32:45.939 NQU22_FUT_CME [CBV][M] 15 Min #30 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:32:46.105 NQU22_FUT_CME [CBV][M] 15 Min #30 | Reloading chart. | 2022-07-18 14:32:46.142 NQU22_FUT_CME [CBV][M] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-07-18 14:32:46.266 NQU22_FUT_CME [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-18 14:32:46.335 NQU22_FUT_CME [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-18 14:32:46.481 NQU22_FUT_CME [CBV][M] 15 Min #30 | Reloading chart. | 2022-07-18 14:32:46.676 NQU22_FUT_CME [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-18 14:32:46.861 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:33:05.052 NQU22_FUT_CME [CBV][M] 15 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:33:07.277 NQU22_FUT_CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:33:08.932 WSACleanup called. | 2022-07-18 14:35:23.301 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 20. | 2022-07-18 14:35:23.306 Current selected Data/Trading service: SC Data - All Services | 2022-07-18 14:35:23.306 SC Data - All Services | Disconnected. | 2022-07-18 14:35:24.498 SC Data - All Services | Disconnected. | 2022-07-18 14:35:24.504 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-18 14:35:24.504 NQU22-CME [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-18 14:35:24.627 NQU22-CME [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 14:35:24.710 NQU22-CME [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 14:35:24.760 NQU22-CME [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 14:35:24.812 NQU22-CME [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 14:35:24.858 NQU22-CME[M] 512 Trades #14 | Reloading chart. | 2022-07-18 14:35:24.936 NQU22-CME [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-18 14:35:24.961 NQU22-CME [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 14:35:25.235 NQU22-CME[M] 512 Trades #17 | Reloading chart. | 2022-07-18 14:35:25.358 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:25.411 Symbol settings MD5 received. Request ID: 20. | 2022-07-18 14:35:25.414 Requested symbol settings for service code scdataallservices. Request ID: 21. | 2022-07-18 14:35:25.414 NQU22-CME [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-18 14:35:25.446 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:25.528 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:25.605 NQU22-CME [CBV][M] #16 | Reloading chart. | 2022-07-18 14:35:25.672 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:25.945 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:25.945 NQU22-CME[M] 30 Sec #13 | Reloading chart. | 2022-07-18 14:35:26.002 NQU22-CME[M] 1250 Volume #24 | Reloading chart. | 2022-07-18 14:35:26.081 NQU22-CME[M] 1 Min #18 | Reloading chart. | 2022-07-18 14:35:26.122 NQU22-CME [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-18 14:35:26.169 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:26.375 NQU22-CME[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:35:26.396 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:26.697 NQU22-CME [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 14:35:26.798 NQU22-CME[M]/MNQU22-CME [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 14:35:27.107 NQU22-CME [CBV][M] 15 Min #30 | Reloading chart. | 2022-07-18 14:35:27.145 NQU22-CME [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 14:35:27.283 NQU22-CME[M] 1 Trades #21 | Reloading chart. | 2022-07-18 14:35:29.797 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:29.939 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:30.000 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:30.160 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:30.206 NQU22-CME[M] 1 Trades #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22-CME.scid | 2022-07-18 14:35:30.221 NQU22-CME [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-18 14:35:30.223 NQU22-CME [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-18 14:35:30.333 NQU22-CME [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-18 14:35:30.557 NQU22-CME [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 14:35:30.752 Symbol settings received. Request ID: 21. | 2022-07-18 14:35:31.159 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:31.633 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:31.633 NQU22-CME [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-18 14:35:31.644 NQU22-CME [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-18 14:35:31.791 NQU22-CME [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-18 14:35:31.891 NQU22-CME [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-18 14:35:31.986 NQU22-CME [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-18 14:35:32.412 NQU22-CME [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 14:35:32.545 SC Data - All Services | Connected to server complete. | 2022-07-18 14:35:33.522 Triggering next historical data download in queue. | 2022-07-18 14:35:33.526 Triggering next historical data download in queue. | 2022-07-18 14:35:33.526 Triggering next historical data download in queue. | 2022-07-18 14:35:33.526 Triggering next historical data download in queue. | 2022-07-18 14:35:33.526 No download requests in the queue to start downloads for. | 2022-07-18 14:35:33.532 No download requests in the queue to start downloads for. | 2022-07-18 14:35:33.532 No download requests in the queue to start downloads for. | 2022-07-18 14:35:33.532 No download requests in the queue to start downloads for. | 2022-07-18 14:35:33.532 Mapping NQU22-CME to NQU22. Service code: cme | 2022-07-18 14:35:33.535 Using symbol data fast lookup vector | 2022-07-18 14:35:33.535 SC DTC Delayed Exchange Data | Starting real-time market data updates for: NQU22-CME (NQU22). ID: 1 Service code: cme | 2022-07-18 14:35:33.536 SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-07-18 14:35:33.537 SC DTC Delayed Exchange Data | Requesting security definition data for: NQU22-CME (NQU22). ID: 1 | 2022-07-18 14:35:33.537 Added historical Intraday data request for NQU22-CME to the queue. | 2022-07-18 14:35:33.537 Intraday data recording state for symbol NQU22-CME is set to download 'Pending'. | 2022-07-18 14:35:33.537 Triggering next historical data download in queue. | 2022-07-18 14:35:33.540 DTC Client socket (1) | Creating socket. | 2022-07-18 14:35:33.541 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-18 14:35:33.541 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2022-07-18 14:35:33.541 Delaying start of download for NQU22-CME | 2022-07-18 14:35:33.546 SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-18 14:35:33.761 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-18 14:35:33.761 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-18 14:35:33.761 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:37.948 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-18 14:35:37.963 SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-18 14:35:37.963 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:37.969 SC DTC Delayed Exchange Data | Received logon response. | 2022-07-18 14:35:38.642 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-18 14:35:38.642 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-18 14:35:38.642 SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-18 14:35:38.642 SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-18 14:35:38.642 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: NQU22-CME -> NQU22 | 2022-07-18 14:35:38.643 Mapping MNQU22-CME to MNQU22. Service code: cme | 2022-07-18 14:35:38.816 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MNQU22-CME (MNQU22). ID: 2 Service code: cme | 2022-07-18 14:35:38.816 SC DTC Delayed Exchange Data | Requesting security definition data for: MNQU22-CME (MNQU22). ID: 2 | 2022-07-18 14:35:38.816 SC DTC Delayed Exchange Data | Received security definition for symbol NQU22-CME | 2022-07-18 14:35:38.896 SC DTC Delayed Exchange Data | Received security definition for symbol MNQU22-CME | 2022-07-18 14:35:38.980 HD Request # 62 | Downloading Intraday chart data for NQU22-CME to the file NQU22-CME.scid. Service: cme | 2022-07-18 14:35:43.113 HD Request # 62 | Download start date-time: 2022-07-18 14:16:26.000000. File last date-time: 2022-07-18 14:16:26.585000 | 2022-07-18 14:35:43.114 HD Request # 62 | Using server: ds21.sierracharts.com port 10149 | 2022-07-18 14:35:43.114 Socket (2) | Creating socket. | 2022-07-18 14:35:43.115 Socket (2) | New receive buffer size: 5242880 | 2022-07-18 14:35:43.115 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-07-18 14:35:43.115 HD Request # 62 | Setting DTC encoding to Binary VLS | 2022-07-18 14:35:43.171 HD Request # 62 | Sending historical data logon request message. | 2022-07-18 14:35:43.171 HD Request # 62 | Requesting Intraday data. Start date-time: 2022-07-18 14:16:26. Record interval: 0. Symbol: NQU22 | 2022-07-18 14:35:43.699 HD Request # 62 | Decompressing data. | 2022-07-18 14:35:43.730 HD Request # 62 | Receiving Intraday data for NQU22-CME starting at 2022-07-18 14:16:26.195000 | 2022-07-18 14:35:43.747 Socket (2) | CloseSocket call. | 2022-07-18 14:35:43.838 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:35:43.839 Socket (2) | Socket gracefully closed by remote side. | 2022-07-18 14:35:43.866 Socket (2) | Closed. | 2022-07-18 14:35:43.866 Historical data download thread signaled to stop. | 2022-07-18 14:35:43.880 HD Request # 62 | Timestamp of first Intraday data file record written: 2022-07-18 14:16:27.084000 | 2022-07-18 14:35:43.880 HD Request # 62 | Received 9626 Intraday data records from 2022-07-18 14:16:26.195000 to 2022-07-18 14:25:30.608000 (9.1 minutes) and wrote 9608 records for NQU22-CME | 2022-07-18 14:35:43.880 HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2022-07-18 14:25:30.608000 | 2022-07-18 14:35:43.888 HD Request # 62 | Completion time: 0s | 2022-07-18 14:35:43.892 HD Request # 62 | Intraday data download complete for NQU22-CME. Unique request ID: 58 | 2022-07-18 14:35:43.892 Removing historical data download ID 58. | 2022-07-18 14:35:43.892 Real-time Intraday chart data file updates started for NQU22-CME | 2022-07-18 14:35:43.892 Intraday chart data file opened for NQU22-CME | 2022-07-18 14:35:43.892 HD Request # 62 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:35:43.892 Triggering next historical data download in queue. | 2022-07-18 14:35:43.892 No download requests in the queue to start downloads for. | 2022-07-18 14:35:43.892 Opened cached Intraday file: C:\SierraChart\Data\NQU22-CME.scid. Thread ID: 26524 | 2022-07-18 14:35:44.242 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:44.670 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:44.884 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:44.913 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:45.046 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:45.055 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:45.055 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:45.064 NQU22-CME[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:35:45.139 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:45.615 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:51.830 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:51.831 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:51.831 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:35:51.831 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:36:02.020 NQU22-CME [CBV][M] 15 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:36:02.215 NQU22-CME [CBV][M] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:36:04.696 NQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:36:04.744 NQU22-CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:36:04.878 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:36:04.881 NQU22-CME [CBV][M] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:36:04.983 NQU22-CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:36:05.556 NQU22-CME [CBV][M] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:36:05.714 NQU22-CME [CBV][M] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:36:05.798 Requested new login tokens. | 2022-07-18 14:39:51.399 Received 8 login tokens. | 2022-07-18 14:39:52.043 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2022-07-18 14:40:19.986 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 32768 | 2022-07-18 14:40:19.986 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 95.216.233.104. | 2022-07-18 14:40:19.986 Trial activation response: {"ERROR":"Invalid parameters sent."} | 2022-07-18 14:40:20.916 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | CloseSocket call. | 2022-07-18 14:40:21.466 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:40:21.466 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2022-07-18 14:40:21.621 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2022-07-18 14:40:21.621 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-18 14:57:18.493 DTC Client socket (1) | CloseSocket call. | 2022-07-18 14:57:18.493 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:57:18.493 SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-18 14:57:18.493 SC Data - All Services | Disconnected. | 2022-07-18 14:57:18.493 SC Data - All Services | Disconnected. | 2022-07-18 14:57:18.546 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 22. | 2022-07-18 14:57:18.551 Current selected Data/Trading service: CQG WebAPI | 2022-07-18 14:57:18.551 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-18 14:57:19.948 F.US.ENQU22[M] 1 Min #18 | Reloading chart. | 2022-07-18 14:57:20.087 F.US.ENQU22[M]/F.US.MNQU22 [CBV][M] 500 Volume #28 | Reloading chart. | 2022-07-18 14:57:20.123 F.US.ENQU22 [CBV][M] 5 Min #25 | Reloading chart. | 2022-07-18 14:57:20.137 F.US.ENQU22 [CBV][M] 60 Min #8 | Reloading chart. | 2022-07-18 14:57:20.237 F.US.ENQU22[M] 1250 Volume #24 | Reloading chart. | 2022-07-18 14:57:20.343 F.US.ENQU22 [CBV][M] 15 Min #30 | Reloading chart. | 2022-07-18 14:57:20.395 Symbol settings MD5 received. Request ID: 22. | 2022-07-18 14:57:20.558 Requested symbol settings for service code cqg. Request ID: 23. | 2022-07-18 14:57:20.559 F.US.ENQU22 [CBV][M] 240 Min #9 | Reloading chart. | 2022-07-18 14:57:20.578 F.US.ENQU22 [CBV][M] 5 Min #12 | Reloading chart. | 2022-07-18 14:57:20.705 F.US.ENQU22[M] 512 Trades #14 | Reloading chart. | 2022-07-18 14:57:20.896 F.US.ENQU22 [CBV][M] 3072 Trades #4 | Reloading chart. | 2022-07-18 14:57:20.990 F.US.ENQU22 [CBV][M] 3072 Trades #11 | Reloading chart. | 2022-07-18 14:57:21.008 F.US.ENQU22 [CBV][M] 750 Volume #1 | Reloading chart. | 2022-07-18 14:57:21.098 F.US.ENQU22 [CBV][M] 5 Min #6 | Reloading chart. | 2022-07-18 14:57:21.441 F.US.ENQU22 [CBV][M] 7500 Volume #7 | Reloading chart. | 2022-07-18 14:57:21.610 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:21.783 F.US.ENQU22 [CBV][M] 1 Min #27 | Reloading chart. | 2022-07-18 14:57:21.816 F.US.ENQU22 [CBV][M] 375 Volume #19 | Reloading chart. | 2022-07-18 14:57:21.842 F.US.ENQU22 [CBV][M] #16 | Reloading chart. | 2022-07-18 14:57:21.862 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:22.198 F.US.ENQU22 [CBV][M] 60 Min #15 | Reloading chart. | 2022-07-18 14:57:22.267 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:23.224 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:23.247 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:23.335 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:23.335 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:23.344 F.US.ENQU22 [CBV][M] 15 Min #10 | Reloading chart. | 2022-07-18 14:57:23.403 F.US.ENQU22 [CBV][M] 825 Trades #23 | Reloading chart. | 2022-07-18 14:57:23.613 F.US.ENQU22 [CBV][M] 7500 Volume #20 | Reloading chart. | 2022-07-18 14:57:23.677 F.US.ENQU22[M] 512 Trades #17 | Reloading chart. | 2022-07-18 14:57:23.699 F.US.ENQU22 [CBV][M] 60 Min #29 | Reloading chart. | 2022-07-18 14:57:23.706 F.US.ENQU22[M] 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:57:23.869 Symbol settings received. Request ID: 23. | 2022-07-18 14:57:24.368 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:24.862 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:25.298 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:25.330 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:25.338 F.US.ENQU22 [CBV][M] 512 Trades #5 | Reloading chart. | 2022-07-18 14:57:25.359 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:25.403 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:25.403 F.US.ENQU22[M] 1 Trades #21 | Reloading chart. | 2022-07-18 14:57:25.457 F.US.ENQU22 [CBV][M] 30 Min #2 | Reloading chart. | 2022-07-18 14:57:25.544 F.US.ENQU22[M] 1 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:57:25.603 F.US.ENQU22 [CBV][M] 60 Min #22 | Reloading chart. | 2022-07-18 14:57:25.951 F.US.ENQU22 [CBV][M] 750 Volume #26 | Reloading chart. | 2022-07-18 14:57:26.129 F.US.ENQU22 [CBV][M] 1 Day #3 | Reloading chart. | 2022-07-18 14:57:26.574 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:27.457 F.US.ENQU22[M] 30 Sec #13 | Reloading chart. | 2022-07-18 14:57:27.471 CQG WebAPI | Connecting to server api.cqg.com | 2022-07-18 14:57:28.640 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-07-18 14:57:28.640 CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2022-07-18 14:57:28.759 CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2022-07-18 14:57:28.759 CQG WebSocket socket (2) | Connecting to IP: 208.48.16.35. | 2022-07-18 14:57:28.759 CQG WebSocket | Opening WebSocket. | 2022-07-18 14:57:28.861 CQG WebSocket | Sending WebSocket handshake. | 2022-07-18 14:57:28.862 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-07-18 14:57:28.958 CQG WebSocket | Server header | Connection: upgrade | 2022-07-18 14:57:28.958 CQG WebSocket | Server header | Sec-WebSocket-Accept: wMOuzs/7FU076Ceg3dhONKh7nKg= | 2022-07-18 14:57:28.958 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-07-18 14:57:28.958 CQG WebSocket | Server header | Upgrade: websocket | 2022-07-18 14:57:28.958 CQG WebSocket | Server header | | 2022-07-18 14:57:28.958 CQG WebSocket | Web socket state is now open. | 2022-07-18 14:57:28.958 CQG WebAPI | WebSocket connected. | 2022-07-18 14:57:28.958 CQG WebAPI | Sending market data logon message. | 2022-07-18 14:57:28.959 CQG WebAPI | Base Time: 2022-07-17T17:00:53. 2022-07-17 17:00:53 | 2022-07-18 14:57:29.113 CQG WebAPI | Logon successful. Session Token = S3Ipk4qoCYZqCfqOSkm8oCRQbnyFUzDCCkw20vAjqY8Aui0SMykWQFLoDdeDz6BTO54VyLSltEt | 2022-07-18 14:57:29.113 CQG WebAPI | Connected to server complete. | 2022-07-18 14:57:29.113 Triggering next historical data download in queue. | 2022-07-18 14:57:29.114 Triggering next historical data download in queue. | 2022-07-18 14:57:29.114 Triggering next historical data download in queue. | 2022-07-18 14:57:29.114 Triggering next historical data download in queue. | 2022-07-18 14:57:29.114 Updated verified funded futures trading account ending date to: 2022-08-17 14:57:29 | 2022-07-18 14:57:29.114 CQG WebAPI | Sending Trade Accounts request message. | 2022-07-18 14:57:29.282 No download requests in the queue to start downloads for. | 2022-07-18 14:57:29.282 No download requests in the queue to start downloads for. | 2022-07-18 14:57:29.282 No download requests in the queue to start downloads for. | 2022-07-18 14:57:29.282 No download requests in the queue to start downloads for. | 2022-07-18 14:57:29.282 Using symbol data fast lookup vector | 2022-07-18 14:57:29.283 CQG WebAPI | Starting real-time market data updates for: F.US.ENQU22. ID: 1 Service code: cqg | 2022-07-18 14:57:29.283 CQG WebAPI | Sending symbol resolution request for F.US.ENQU22. ID: 662051 | 2022-07-18 14:57:29.283 CQG WebAPI | Requesting security definition data for: F.US.ENQU22. ID: 1 | 2022-07-18 14:57:29.283 CQG WebAPI | Using primary service for historical data for F.US.ENQU22 | 2022-07-18 14:57:29.284 Starting DelayedDownloadMonitoringTimer | 2022-07-18 14:57:29.284 Starting HDTimeoutTimer | 2022-07-18 14:57:29.284 Added historical Intraday data request for F.US.ENQU22 to the queue. | 2022-07-18 14:57:29.284 Intraday data recording state for symbol F.US.ENQU22 is set to download 'Pending'. | 2022-07-18 14:57:29.284 Triggering next historical data download in queue. | 2022-07-18 14:57:29.284 Delaying start of download for F.US.ENQU22 | 2022-07-18 14:57:29.284 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU22. Search Symbol: F.US.ENQU22. Request ID: 662051. Contract ID: 1. | 2022-07-18 14:57:29.469 CQG WebAPI | Requesting market data for F.US.ENQU22 | 2022-07-18 14:57:29.469 CQG WebAPI | Brokerage name: AMP3. Account Name: 131836 | 2022-07-18 14:57:29.469 Updated verified funded futures trading account ending date to: 2022-08-17 14:57:29 | 2022-07-18 14:57:29.469 CQG WebAPI | Sending collateral subscribe request. | 2022-07-18 14:57:29.469 CQG WebAPI | Market data subscription for F.US.ENQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 1) is not enabled. | 2022-07-18 14:57:29.505 Symbol Error - F.US.ENQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 1) is not enabled. | 2022-07-18 14:57:29.505 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:30.849 CQG WebAPI | Starting real-time market data updates for: F.US.MNQU22. ID: 2 Service code: cqg | 2022-07-18 14:57:30.921 CQG WebAPI | Sending symbol resolution request for F.US.MNQU22. ID: 662053 | 2022-07-18 14:57:30.921 CQG WebAPI | Requesting security definition data for: F.US.MNQU22. ID: 2 | 2022-07-18 14:57:30.921 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU22. Search Symbol: F.US.MNQU22. Request ID: 662053. Contract ID: 2. | 2022-07-18 14:57:30.989 CQG WebAPI | Requesting market data for F.US.MNQU22 | 2022-07-18 14:57:30.989 CQG WebAPI | Market data subscription for F.US.MNQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 2) is not enabled. | 2022-07-18 14:57:31.081 Symbol Error - F.US.MNQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 2) is not enabled. | 2022-07-18 14:57:31.081 HD Request # 63 | Downloading Intraday chart data for F.US.ENQU22 to the file F.US.ENQU22.scid. Service: cqg | 2022-07-18 14:57:32.001 HD Request # 63 | Download start date-time: 2022-07-15 17:10:58.000000. File last date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 14:57:32.002 HD Request # 63 | Requesting historical Tick data. | 2022-07-18 14:57:32.002 HD Request # 63 | Error downloading historical Intraday data for F.US.ENQU22. Instrument F.US.ENQ (corresponding to ID 1) is not allowed. Result=103. Num Quotes=0 | 2022-07-18 14:57:32.856 HD Request # 63 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQU22 | 2022-07-18 14:57:32.856 HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 14:57:32.857 HD Request # 63 | Completion time: 1s | 2022-07-18 14:57:32.857 HD Request # 63 | Intraday data download complete for F.US.ENQU22. Unique request ID: 59 | 2022-07-18 14:57:32.857 Removing historical data download ID 59. | 2022-07-18 14:57:32.857 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-18 14:57:32.857 Intraday chart data file opened for F.US.ENQU22 | 2022-07-18 14:57:32.857 HD Request # 63 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:57:32.857 Triggering next historical data download in queue. | 2022-07-18 14:57:32.857 No download requests in the queue to start downloads for. | 2022-07-18 14:57:34.532 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:39.543 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:39.958 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:39.989 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:39.989 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:40.007 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:40.556 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:40.570 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:40.621 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:40.630 CQG WebAPI | Sending positions subscribe request. RequestID: 662055 | 2022-07-18 14:57:40.712 CQG WebAPI | Sending orders subscribe request. RequestID: 662056 | 2022-07-18 14:57:40.712 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:44.767 File >> Disconnect selected. | 2022-07-18 14:57:45.263 CQG WebAPI | Sending Web API Logoff message. | 2022-07-18 14:57:45.376 CQG WebSocket socket (2) | CloseSocket call. | 2022-07-18 14:57:45.376 CQG WebSocket | WebSocket closed. | 2022-07-18 14:57:45.376 CQG WebAPI | WebSocket closed. | 2022-07-18 14:57:45.376 CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-18 14:57:45.377 CQG WebAPI | Disconnected. | 2022-07-18 14:57:45.380 CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2022-07-18 14:57:45.403 CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-18 14:57:45.404 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:49.714 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:49.714 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:49.714 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:49.714 CQG WebAPI | Connecting to server api.cqg.com | 2022-07-18 14:57:49.747 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-07-18 14:57:49.747 CQG WebSocket socket (3) | Creating socket. Using TLS 1.2. | 2022-07-18 14:57:49.748 CQG WebSocket socket (3) | New receive buffer size: 5242880 | 2022-07-18 14:57:49.748 CQG WebSocket socket (3) | Connecting to IP: 208.48.16.35. | 2022-07-18 14:57:49.748 CQG WebSocket | Opening WebSocket. | 2022-07-18 14:57:49.910 CQG WebSocket | Sending WebSocket handshake. | 2022-07-18 14:57:49.910 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-07-18 14:57:50.167 CQG WebSocket | Server header | Connection: upgrade | 2022-07-18 14:57:50.167 CQG WebSocket | Server header | Sec-WebSocket-Accept: caLbkx/SPFsH1tcUsKZGe/3bMdE= | 2022-07-18 14:57:50.167 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-07-18 14:57:50.167 CQG WebSocket | Server header | Upgrade: websocket | 2022-07-18 14:57:50.167 CQG WebSocket | Server header | | 2022-07-18 14:57:50.167 CQG WebSocket | Web socket state is now open. | 2022-07-18 14:57:50.167 CQG WebAPI | WebSocket connected. | 2022-07-18 14:57:50.167 CQG WebAPI | Sending market data logon message. | 2022-07-18 14:57:50.167 CQG WebAPI | Base Time: 2022-07-17T17:00:53. 2022-07-17 17:00:53 | 2022-07-18 14:57:50.462 CQG WebAPI | Logon successful. Session Token = VfiME7JalG441Ceh+4Toxz5gNK9nley2PFkIqT3WeQouAWs5SwVIKG37VRx/cEzqQtw+l0eCNA3 | 2022-07-18 14:57:50.462 CQG WebAPI | Connected to server complete. | 2022-07-18 14:57:50.462 Triggering next historical data download in queue. | 2022-07-18 14:57:50.462 Triggering next historical data download in queue. | 2022-07-18 14:57:50.462 Triggering next historical data download in queue. | 2022-07-18 14:57:50.462 Triggering next historical data download in queue. | 2022-07-18 14:57:50.462 Updated verified funded futures trading account ending date to: 2022-08-17 14:57:50 | 2022-07-18 14:57:50.462 CQG WebAPI | Sending Trade Accounts request message. | 2022-07-18 14:57:50.520 No download requests in the queue to start downloads for. | 2022-07-18 14:57:50.520 No download requests in the queue to start downloads for. | 2022-07-18 14:57:50.520 No download requests in the queue to start downloads for. | 2022-07-18 14:57:50.520 No download requests in the queue to start downloads for. | 2022-07-18 14:57:50.520 Using symbol data fast lookup vector | 2022-07-18 14:57:50.526 CQG WebAPI | Starting real-time market data updates for: F.US.ENQU22. ID: 1 Service code: cqg | 2022-07-18 14:57:50.526 CQG WebAPI | Sending symbol resolution request for F.US.ENQU22. ID: 662058 | 2022-07-18 14:57:50.526 CQG WebAPI | Requesting security definition data for: F.US.ENQU22. ID: 1 | 2022-07-18 14:57:50.526 CQG WebAPI | Using primary service for historical data for F.US.ENQU22 | 2022-07-18 14:57:50.526 Added historical Intraday data request for F.US.ENQU22 to the queue. | 2022-07-18 14:57:50.527 Intraday data recording state for symbol F.US.ENQU22 is set to download 'Pending'. | 2022-07-18 14:57:50.527 Triggering next historical data download in queue. | 2022-07-18 14:57:50.527 Delaying start of download for F.US.ENQU22 | 2022-07-18 14:57:50.535 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU22. Search Symbol: F.US.ENQU22. Request ID: 662058. Contract ID: 1. | 2022-07-18 14:57:50.599 CQG WebAPI | Requesting market data for F.US.ENQU22 | 2022-07-18 14:57:50.599 CQG WebAPI | Brokerage name: AMP3. Account Name: 131836 | 2022-07-18 14:57:50.599 Updated verified funded futures trading account ending date to: 2022-08-17 14:57:50 | 2022-07-18 14:57:50.599 CQG WebAPI | Sending collateral subscribe request. | 2022-07-18 14:57:50.599 CQG WebAPI | Market data subscription for F.US.ENQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 1) is not enabled. | 2022-07-18 14:57:50.667 Symbol Error - F.US.ENQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 1) is not enabled. | 2022-07-18 14:57:50.667 HD Request # 64 | Downloading Intraday chart data for F.US.ENQU22 to the file F.US.ENQU22.scid. Service: cqg | 2022-07-18 14:57:52.095 HD Request # 64 | Download start date-time: 2022-07-15 17:10:58.000000. File last date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 14:57:52.096 HD Request # 64 | Requesting historical Tick data. | 2022-07-18 14:57:52.096 HD Request # 64 | Error downloading historical Intraday data for F.US.ENQU22. Instrument F.US.ENQ (corresponding to ID 1) is not allowed. Result=103. Num Quotes=0 | 2022-07-18 14:57:52.235 HD Request # 64 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQU22 | 2022-07-18 14:57:52.235 HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 14:57:52.235 HD Request # 64 | Completion time: 0s | 2022-07-18 14:57:52.235 HD Request # 64 | Intraday data download complete for F.US.ENQU22. Unique request ID: 60 | 2022-07-18 14:57:52.235 Removing historical data download ID 60. | 2022-07-18 14:57:52.246 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-18 14:57:52.246 Intraday chart data file opened for F.US.ENQU22 | 2022-07-18 14:57:52.246 HD Request # 64 | Enabling Intraday chart updating for symbol. | 2022-07-18 14:57:52.247 Triggering next historical data download in queue. | 2022-07-18 14:57:52.247 No download requests in the queue to start downloads for. | 2022-07-18 14:57:52.247 CQG WebAPI | Starting real-time market data updates for: F.US.MNQU22. ID: 2 Service code: cqg | 2022-07-18 14:57:52.955 CQG WebAPI | Sending symbol resolution request for F.US.MNQU22. ID: 662061 | 2022-07-18 14:57:52.955 CQG WebAPI | Requesting security definition data for: F.US.MNQU22. ID: 2 | 2022-07-18 14:57:52.955 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU22. Search Symbol: F.US.MNQU22. Request ID: 662061. Contract ID: 2. | 2022-07-18 14:57:52.995 CQG WebAPI | Requesting market data for F.US.MNQU22 | 2022-07-18 14:57:52.995 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:52.999 CQG WebAPI | Market data subscription for F.US.MNQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 2) is not enabled. | 2022-07-18 14:57:53.080 Symbol Error - F.US.MNQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 2) is not enabled. | 2022-07-18 14:57:53.080 CQG WebAPI | Sending positions subscribe request. RequestID: 662062 | 2022-07-18 14:57:53.878 CQG WebAPI | Sending orders subscribe request. RequestID: 662063 | 2022-07-18 14:57:53.878 F.US.ENQU22 [CBV] 15 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:57:53.937 F.US.ENQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:54.691 F.US.ENQU22 [CBV] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:54.930 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:54.934 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:54.992 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:54.995 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:55.023 F.US.ENQU22 [CBV] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:55.040 F.US.ENQU22 [CBV] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:55.254 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:55.266 F.US.ENQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 14:57:56.233 F.US.ENQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:58:14.897 F.US.ENQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:58:16.526 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-18 14:59:48.428 DTC Client socket (1) | Closed. | 2022-07-18 14:59:48.428 CQG WebSocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-18 14:59:48.428 CQG WebSocket socket (2) | Closed. | 2022-07-18 14:59:48.428 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Reloading chart. | 2022-07-18 14:59:54.609 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:59:55.223 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-18 14:59:56.121 DTC Client socket (1) | Deleting network socket now after delay. | 2022-07-18 15:00:18.440 CQG WebSocket socket (2) | Deleting network socket now after delay. | 2022-07-18 15:00:18.440 File >> Disconnect selected. | 2022-07-18 15:00:26.152 CQG WebAPI | Sending Web API Logoff message. | 2022-07-18 15:00:26.173 CQG WebSocket socket (3) | CloseSocket call. | 2022-07-18 15:00:26.173 CQG WebSocket | WebSocket closed. | 2022-07-18 15:00:26.173 CQG WebAPI | WebSocket closed. | 2022-07-18 15:00:26.173 CQG WebAPI | Disconnected. | 2022-07-18 15:00:26.173 CQG WebSocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-18 15:00:26.173 CQG WebSocket socket (3) | Write has completed. Shutdown being performed. | 2022-07-18 15:00:26.247 CQG WebSocket socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-18 15:00:26.247 CQG WebAPI | Connecting to server api.cqg.com | 2022-07-18 15:00:30.824 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-07-18 15:00:30.824 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2022-07-18 15:00:30.825 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2022-07-18 15:00:30.825 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2022-07-18 15:00:30.825 CQG WebSocket | Opening WebSocket. | 2022-07-18 15:00:30.857 CQG WebSocket | Sending WebSocket handshake. | 2022-07-18 15:00:30.857 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-07-18 15:00:30.936 CQG WebSocket | Server header | Connection: upgrade | 2022-07-18 15:00:30.936 CQG WebSocket | Server header | Sec-WebSocket-Accept: aq01rCgJmWfh7THT9BEOhYZZxt4= | 2022-07-18 15:00:30.936 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-07-18 15:00:30.936 CQG WebSocket | Server header | Upgrade: websocket | 2022-07-18 15:00:30.936 CQG WebSocket | Server header | | 2022-07-18 15:00:30.936 CQG WebSocket | Web socket state is now open. | 2022-07-18 15:00:30.936 CQG WebAPI | WebSocket connected. | 2022-07-18 15:00:30.936 CQG WebAPI | Sending market data logon message. | 2022-07-18 15:00:30.936 CQG WebAPI | Base Time: 2022-07-17T17:00:53. 2022-07-17 17:00:53 | 2022-07-18 15:00:31.088 CQG WebAPI | Logon successful. Session Token = wWbrR2T93ofecKEykyceBdGQxfzEoWxQg2ZAxJL/IaoIJplvQrH1FwrgBWhqz33L/dCIZK/15oL | 2022-07-18 15:00:31.088 CQG WebAPI | Connected to server complete. | 2022-07-18 15:00:31.088 Triggering next historical data download in queue. | 2022-07-18 15:00:31.089 Triggering next historical data download in queue. | 2022-07-18 15:00:31.089 Triggering next historical data download in queue. | 2022-07-18 15:00:31.089 Triggering next historical data download in queue. | 2022-07-18 15:00:31.089 Updated verified funded futures trading account ending date to: 2022-08-17 15:00:31 | 2022-07-18 15:00:31.089 CQG WebAPI | Sending Trade Accounts request message. | 2022-07-18 15:00:31.110 No download requests in the queue to start downloads for. | 2022-07-18 15:00:31.110 No download requests in the queue to start downloads for. | 2022-07-18 15:00:31.110 No download requests in the queue to start downloads for. | 2022-07-18 15:00:31.110 No download requests in the queue to start downloads for. | 2022-07-18 15:00:31.110 Using symbol data fast lookup vector | 2022-07-18 15:00:31.113 CQG WebAPI | Starting real-time market data updates for: F.US.ENQU22. ID: 1 Service code: cqg | 2022-07-18 15:00:31.113 CQG WebAPI | Sending symbol resolution request for F.US.ENQU22. ID: 662065 | 2022-07-18 15:00:31.113 CQG WebAPI | Requesting security definition data for: F.US.ENQU22. ID: 1 | 2022-07-18 15:00:31.113 CQG WebAPI | Starting real-time market data updates for: F.US.MNQU22. ID: 2 Service code: cqg | 2022-07-18 15:00:31.113 CQG WebAPI | Sending symbol resolution request for F.US.MNQU22. ID: 662066 | 2022-07-18 15:00:31.113 CQG WebAPI | Requesting security definition data for: F.US.MNQU22. ID: 2 | 2022-07-18 15:00:31.113 CQG WebAPI | Using primary service for historical data for F.US.ENQU22 | 2022-07-18 15:00:31.113 Added historical Intraday data request for F.US.ENQU22 to the queue. | 2022-07-18 15:00:31.113 Intraday data recording state for symbol F.US.ENQU22 is set to download 'Pending'. | 2022-07-18 15:00:31.113 Triggering next historical data download in queue. | 2022-07-18 15:00:31.113 Delaying start of download for F.US.ENQU22 | 2022-07-18 15:00:31.172 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU22. Search Symbol: F.US.ENQU22. Request ID: 662065. Contract ID: 1. | 2022-07-18 15:00:31.172 CQG WebAPI | Requesting market data for F.US.ENQU22 | 2022-07-18 15:00:31.172 CQG WebAPI | Brokerage name: AMP3. Account Name: 131836 | 2022-07-18 15:00:31.172 Updated verified funded futures trading account ending date to: 2022-08-17 15:00:31 | 2022-07-18 15:00:31.172 CQG WebAPI | Sending collateral subscribe request. | 2022-07-18 15:00:31.172 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU22. Search Symbol: F.US.MNQU22. Request ID: 662066. Contract ID: 2. | 2022-07-18 15:00:31.175 CQG WebAPI | Requesting market data for F.US.MNQU22 | 2022-07-18 15:00:31.175 CQG WebAPI | Market data subscription for F.US.ENQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 1) is not enabled. | 2022-07-18 15:00:31.208 Symbol Error - F.US.ENQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 1) is not enabled. | 2022-07-18 15:00:31.208 CQG WebAPI | Market data subscription for F.US.MNQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 2) is not enabled. | 2022-07-18 15:00:31.264 Symbol Error - F.US.MNQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 2) is not enabled. | 2022-07-18 15:00:31.264 HD Request # 65 | Downloading Intraday chart data for F.US.ENQU22 to the file F.US.ENQU22.scid. Service: cqg | 2022-07-18 15:00:31.642 HD Request # 65 | Download start date-time: 2022-07-15 17:10:58.000000. File last date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 15:00:31.642 HD Request # 65 | Requesting historical Tick data. | 2022-07-18 15:00:31.642 HD Request # 65 | Error downloading historical Intraday data for F.US.ENQU22. Instrument F.US.ENQ (corresponding to ID 1) is not allowed. Result=103. Num Quotes=0 | 2022-07-18 15:00:31.806 HD Request # 65 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQU22 | 2022-07-18 15:00:31.806 HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 15:00:31.806 HD Request # 65 | Completion time: 0s | 2022-07-18 15:00:31.806 HD Request # 65 | Intraday data download complete for F.US.ENQU22. Unique request ID: 61 | 2022-07-18 15:00:31.806 Removing historical data download ID 61. | 2022-07-18 15:00:31.806 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-18 15:00:31.806 Intraday chart data file opened for F.US.ENQU22 | 2022-07-18 15:00:31.806 HD Request # 65 | Enabling Intraday chart updating for symbol. | 2022-07-18 15:00:31.806 Triggering next historical data download in queue. | 2022-07-18 15:00:31.806 No download requests in the queue to start downloads for. | 2022-07-18 15:00:31.806 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.244 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.274 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.283 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.290 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.290 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.304 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.320 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.320 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.320 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.320 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.356 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.358 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.372 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.381 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.381 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.391 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.414 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.569 F.US.ENQU22 [CBV] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.592 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.599 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:32.607 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:33.227 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:33.227 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:33.251 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:33.257 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:33.264 F.US.ENQU22 [CBV] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:33.386 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:33.388 F.US.ENQU22 [CBV] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:33.392 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:00:33.481 CQG WebAPI | Sending positions subscribe request. RequestID: 662069 | 2022-07-18 15:00:34.094 CQG WebAPI | Sending orders subscribe request. RequestID: 662070 | 2022-07-18 15:00:34.094 CQG WebSocket socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-18 15:02:48.483 CQG WebSocket socket (3) | Closed. | 2022-07-18 15:02:48.483 CQG WebSocket socket (3) | Deleting network socket now after delay. | 2022-07-18 15:03:18.493 File >> Disconnect selected. | 2022-07-18 15:07:35.247 CQG WebAPI | Sending Web API Logoff message. | 2022-07-18 15:07:35.272 CQG WebSocket socket (1) | CloseSocket call. | 2022-07-18 15:07:35.272 CQG WebSocket | WebSocket closed. | 2022-07-18 15:07:35.272 CQG WebAPI | WebSocket closed. | 2022-07-18 15:07:35.272 CQG WebAPI | Disconnected. | 2022-07-18 15:07:35.272 CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-18 15:07:35.272 CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2022-07-18 15:07:35.293 CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-18 15:07:35.294 CQG WebSocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-18 15:09:48.618 CQG WebSocket socket (1) | Closed. | 2022-07-18 15:09:48.618 CQG WebSocket socket (1) | Deleting network socket now after delay. | 2022-07-18 15:10:18.625 CQG WebAPI | Connecting to server api.cqg.com | 2022-07-18 15:33:44.308 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-07-18 15:33:44.308 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2022-07-18 15:33:44.338 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2022-07-18 15:33:44.339 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2022-07-18 15:33:44.339 CQG WebSocket | Opening WebSocket. | 2022-07-18 15:33:44.362 CQG WebSocket | Sending WebSocket handshake. | 2022-07-18 15:33:44.362 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-07-18 15:33:44.439 CQG WebSocket | Server header | Connection: upgrade | 2022-07-18 15:33:44.439 CQG WebSocket | Server header | Sec-WebSocket-Accept: YTrllkL3/mgABI9F15UzQElXfAk= | 2022-07-18 15:33:44.439 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-07-18 15:33:44.439 CQG WebSocket | Server header | Upgrade: websocket | 2022-07-18 15:33:44.439 CQG WebSocket | Server header | | 2022-07-18 15:33:44.439 CQG WebSocket | Web socket state is now open. | 2022-07-18 15:33:44.439 CQG WebAPI | WebSocket connected. | 2022-07-18 15:33:44.439 CQG WebAPI | Sending market data logon message. | 2022-07-18 15:33:44.439 CQG WebAPI | Base Time: 2022-07-17T17:00:53. 2022-07-17 17:00:53 | 2022-07-18 15:33:44.628 CQG WebAPI | Logon successful. Session Token = F+uqE2ZYnne3TcqBA51lXjnuCj5u3PqeYf9b1yCz6/wRGrDo8qGf35MVoPcic2dZZONg8g3y5MX | 2022-07-18 15:33:44.628 CQG WebAPI | Connected to server complete. | 2022-07-18 15:33:44.628 Triggering next historical data download in queue. | 2022-07-18 15:33:44.628 Triggering next historical data download in queue. | 2022-07-18 15:33:44.628 Triggering next historical data download in queue. | 2022-07-18 15:33:44.628 Triggering next historical data download in queue. | 2022-07-18 15:33:44.628 Updated verified funded futures trading account ending date to: 2022-08-17 15:33:44 | 2022-07-18 15:33:44.628 CQG WebAPI | Sending Trade Accounts request message. | 2022-07-18 15:33:44.651 No download requests in the queue to start downloads for. | 2022-07-18 15:33:44.652 No download requests in the queue to start downloads for. | 2022-07-18 15:33:44.652 No download requests in the queue to start downloads for. | 2022-07-18 15:33:44.652 No download requests in the queue to start downloads for. | 2022-07-18 15:33:44.652 Using symbol data fast lookup vector | 2022-07-18 15:33:44.668 CQG WebAPI | Starting real-time market data updates for: F.US.ENQU22. ID: 1 Service code: cqg | 2022-07-18 15:33:44.668 CQG WebAPI | Sending symbol resolution request for F.US.ENQU22. ID: 662072 | 2022-07-18 15:33:44.668 CQG WebAPI | Requesting security definition data for: F.US.ENQU22. ID: 1 | 2022-07-18 15:33:44.668 CQG WebAPI | Starting real-time market data updates for: F.US.MNQU22. ID: 2 Service code: cqg | 2022-07-18 15:33:44.668 CQG WebAPI | Sending symbol resolution request for F.US.MNQU22. ID: 662073 | 2022-07-18 15:33:44.668 CQG WebAPI | Requesting security definition data for: F.US.MNQU22. ID: 2 | 2022-07-18 15:33:44.668 CQG WebAPI | Using primary service for historical data for F.US.ENQU22 | 2022-07-18 15:33:44.668 Added historical Intraday data request for F.US.ENQU22 to the queue. | 2022-07-18 15:33:44.668 Intraday data recording state for symbol F.US.ENQU22 is set to download 'Pending'. | 2022-07-18 15:33:44.668 Triggering next historical data download in queue. | 2022-07-18 15:33:44.668 Delaying start of download for F.US.ENQU22 | 2022-07-18 15:33:44.733 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU22. Search Symbol: F.US.ENQU22. Request ID: 662072. Contract ID: 1. | 2022-07-18 15:33:44.733 CQG WebAPI | Requesting market data for F.US.ENQU22 | 2022-07-18 15:33:44.733 CQG WebAPI | Brokerage name: AMP3. Account Name: 131836 | 2022-07-18 15:33:44.734 Updated verified funded futures trading account ending date to: 2022-08-17 15:33:44 | 2022-07-18 15:33:44.734 CQG WebAPI | Sending collateral subscribe request. | 2022-07-18 15:33:44.734 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU22. Search Symbol: F.US.MNQU22. Request ID: 662073. Contract ID: 2. | 2022-07-18 15:33:44.734 CQG WebAPI | Requesting market data for F.US.MNQU22 | 2022-07-18 15:33:44.734 CQG WebAPI | Market data subscription for F.US.ENQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 1) is not enabled. | 2022-07-18 15:33:44.793 Symbol Error - F.US.ENQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.ENQ (corresponding to ID = 1) is not enabled. | 2022-07-18 15:33:44.793 CQG WebAPI | Market data subscription for F.US.MNQU22 was unsuccessful. Text: Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 2) is not enabled. | 2022-07-18 15:33:44.793 Symbol Error - F.US.MNQU22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.MNQ (corresponding to ID = 2) is not enabled. | 2022-07-18 15:33:44.793 HD Request # 66 | Downloading Intraday chart data for F.US.ENQU22 to the file F.US.ENQU22.scid. Service: cqg | 2022-07-18 15:33:45.842 HD Request # 66 | Download start date-time: 2022-07-15 17:10:58.000000. File last date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 15:33:45.842 HD Request # 66 | Requesting historical Tick data. | 2022-07-18 15:33:45.842 HD Request # 66 | Error downloading historical Intraday data for F.US.ENQU22. Instrument F.US.ENQ (corresponding to ID 1) is not allowed. Result=103. Num Quotes=0 | 2022-07-18 15:33:45.942 HD Request # 66 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ENQU22 | 2022-07-18 15:33:45.942 HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2022-07-15 17:10:58.276000 | 2022-07-18 15:33:45.942 HD Request # 66 | Completion time: 0s | 2022-07-18 15:33:45.942 HD Request # 66 | Intraday data download complete for F.US.ENQU22. Unique request ID: 62 | 2022-07-18 15:33:45.942 Removing historical data download ID 62. | 2022-07-18 15:33:45.942 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-07-18 15:33:45.943 Intraday chart data file opened for F.US.ENQU22 | 2022-07-18 15:33:45.943 HD Request # 66 | Enabling Intraday chart updating for symbol. | 2022-07-18 15:33:45.943 Triggering next historical data download in queue. | 2022-07-18 15:33:45.943 No download requests in the queue to start downloads for. | 2022-07-18 15:33:45.943 Chart #5 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.533 Chart #6 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.704 Chart #17 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.730 Chart #13 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.770 Chart #13 has tagged chart #16 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.770 Chart #4 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.795 Chart #11 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.800 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.808 Chart #27 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.827 Chart #27 has tagged chart #23 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.827 Chart #19 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.835 F.US.ENQU22 [CBV] 825 Trades #23 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.859 Chart #23 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.861 Chart #28 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.889 Chart #25 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.897 Chart #20 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.906 Chart #20 has tagged chart #29 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.906 Chart #3 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.920 Chart #1 has tagged chart #12 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.938 Chart #1 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.938 Chart #1 has tagged chart #15 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.938 Chart #1 has tagged chart #8 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.938 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:46.994 F.US.ENQU22 [CBV] #16 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:47.123 F.US.ENQU22 [CBV] 60 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:47.213 F.US.ENQU22 [CBV] 5 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:47.218 F.US.ENQU22 [CBV] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:47.923 Chart #8 has tagged chart #14 for full recalculation. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:47.926 F.US.ENQU22 [CBV] 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:48.063 F.US.ENQU22/F.US.MNQU22 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: NQ_OFL_Linked.Cht | 2022-07-18 15:33:48.078 CQG WebAPI | Sending positions subscribe request. RequestID: 662076 | 2022-07-18 15:33:48.224 CQG WebAPI | Sending orders subscribe request. RequestID: 662077 | 2022-07-18 15:33:48.224 |
| [2022-07-18 18:42:51] |
| John - SC Support - Posts: 47854 |
With release 2394 we no longer allow CQG data for the CME Group and EUREX into Sierra Chart. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394 Our servers are showing that you are on version 2416, therefore you would need to use the Denali Exchange Data Feed for your data, and you also state that you are setup with AMP to have CQG for "Order Routing Only". But you do not have any exchanges activated for the Denali Exchange Data Feed. You can activate the exchange(s) you need for the CME Group at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-07-18 18:55:17] |
| ambtn723 - Posts: 14 |
I resolved the issue. Step 1: Contact amp and fill out trading request for CQG only. Step 2: download newest Sierra install Step 3: Go to your account management page, agree to the forms, and then select your Denali feed which is marked as an optional product. Step 4: Select appropriate feed Step 5: Pay the additional monthly fee This is detailed elsewhere but with the cornucopia of CQG issues got lost for me personally in the mix. |
