Date/Time: Mon, 29 Apr 2024 08:50:17 +0000
Update 1880 Historical Data Download Failure
View Count: 752
[2019-03-01 18:34:18] |
User569009 - Posts: 8 |
For quite a while now, I have experienced the following Historic data limitations: 1/Partial or full failure to download historical data in all historic charts (Monthly, Weekly, Daily). Almost always, "some" data is populated, but generally only back to 2015 and not the 20Y account limitations I read in my Message Log (see below). This is experienced across all historic charts on all symbols. 2/Inability to alter the //Chart Settings/Main Settings/Date Range in File/"from date". The From Date seems to be auto-populated and I can not move any further back in time from the populated date. Im not sure this is a critical factor in populating data, but I want to point this out. A. Historical Charts Settings are populated with the following: 1/Chart Settings/Main Settings/Chart Type/Historical Chart 2/Chart Settings/Main Settings/Use Number of Days to Load/Day to Load: 7000 (less than the 20Y acc. maximum) 3/Chart Settings/Main Settings/Apply Global Symbol Settings B. Common Message Log errors are appended below with the following common error message: 1/Unable to determine transition date based on volume from files: ESH01.dly, ESM01.dly | 2019-03-01 12:49:22 2/The ESM01.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 C. Resolution Actions Already Taken (Thoroughly and Carefully) 1/ All instructions as described in the post: 6CH19 Daliy Historical not loading past historical data This includes a full reset of all my symbols in global settings as well as disconnect from data feed/reconnect and then delete and download all data. 2/ All instructions as described in SC Engineer recommendation: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data 3/Updated to pre-release 1880 D. Typical Message Log: ESH9 [CV] Monthly #8 | Limiting the number of years to load data for to 20 years for the continuous futures chart. Reason: Account limitation. | 2019-03-01 12:49:22 ESH9 [CV] Monthly #8 | Limiting the number of years to download historical data for to 20 years for the continuous futures chart. Reason: Account limitation. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ98.dly, ESH99.dly | 2019-03-01 12:49:22 The ESH99.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH99.dly, ESM99.dly | 2019-03-01 12:49:22 The ESM99.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM99.dly, ESU99.dly | 2019-03-01 12:49:22 The ESU99.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU99.dly, ESZ99.dly | 2019-03-01 12:49:22 The ESZ99.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ99.dly, ESH00.dly | 2019-03-01 12:49:22 The ESH00.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH00.dly, ESM00.dly | 2019-03-01 12:49:22 The ESM00.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM00.dly, ESU00.dly | 2019-03-01 12:49:22 The ESU00.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU00.dly, ESZ00.dly | 2019-03-01 12:49:22 The ESZ00.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ00.dly, ESH01.dly | 2019-03-01 12:49:22 The ESH01.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH01.dly, ESM01.dly | 2019-03-01 12:49:22 The ESM01.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM01.dly, ESU01.dly | 2019-03-01 12:49:22 The ESU01.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU01.dly, ESZ01.dly | 2019-03-01 12:49:22 The ESZ01.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ01.dly, ESH02.dly | 2019-03-01 12:49:22 The ESH02.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH02.dly, ESM02.dly | 2019-03-01 12:49:22 The ESM02.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM02.dly, ESU02.dly | 2019-03-01 12:49:22 The ESU02.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU02.dly, ESZ02.dly | 2019-03-01 12:49:22 The ESZ02.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ02.dly, ESH03.dly | 2019-03-01 12:49:22 The ESH03.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH03.dly, ESM03.dly | 2019-03-01 12:49:22 The ESM03.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM03.dly, ESU03.dly | 2019-03-01 12:49:22 The ESU03.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU03.dly, ESZ03.dly | 2019-03-01 12:49:22 The ESZ03.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ03.dly, ESH04.dly | 2019-03-01 12:49:22 The ESH04.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH04.dly, ESM04.dly | 2019-03-01 12:49:22 The ESM04.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM04.dly, ESU04.dly | 2019-03-01 12:49:22 The ESU04.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU04.dly, ESZ04.dly | 2019-03-01 12:49:22 The ESZ04.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ04.dly, ESH05.dly | 2019-03-01 12:49:22 The ESH05.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH05.dly, ESM05.dly | 2019-03-01 12:49:22 The ESM05.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM05.dly, ESU05.dly | 2019-03-01 12:49:22 The ESU05.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU05.dly, ESZ05.dly | 2019-03-01 12:49:22 The ESZ05.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ05.dly, ESH06.dly | 2019-03-01 12:49:22 The ESH06.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH06.dly, ESM06.dly | 2019-03-01 12:49:22 The ESM06.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM06.dly, ESU06.dly | 2019-03-01 12:49:22 The ESU06.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU06.dly, ESZ06.dly | 2019-03-01 12:49:22 The ESZ06.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ06.dly, ESH07.dly | 2019-03-01 12:49:22 The ESH07.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH07.dly, ESM07.dly | 2019-03-01 12:49:22 The ESM07.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM07.dly, ESU07.dly | 2019-03-01 12:49:22 The ESU07.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU07.dly, ESZ07.dly | 2019-03-01 12:49:22 The ESZ07.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ07.dly, ESH08.dly | 2019-03-01 12:49:22 The ESH08.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH08.dly, ESM08.dly | 2019-03-01 12:49:22 The ESM08.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM08.dly, ESU08.dly | 2019-03-01 12:49:22 The ESU08.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU08.dly, ESZ08.dly | 2019-03-01 12:49:22 The ESZ08.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ08.dly, ESH09.dly | 2019-03-01 12:49:22 The ESH09.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH09.dly, ESM09.dly | 2019-03-01 12:49:22 The ESM09.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM09.dly, ESU09.dly | 2019-03-01 12:49:22 The ESU09.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU09.dly, ESZ09.dly | 2019-03-01 12:49:22 The ESZ09.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ09.dly, ESH10.dly | 2019-03-01 12:49:22 The ESH10.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH10.dly, ESM10.dly | 2019-03-01 12:49:22 The ESM10.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM10.dly, ESU10.dly | 2019-03-01 12:49:22 The ESU10.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU10.dly, ESZ10.dly | 2019-03-01 12:49:22 The ESZ10.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ10.dly, ESH11.dly | 2019-03-01 12:49:22 The ESH11.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH11.dly, ESM11.dly | 2019-03-01 12:49:22 The ESM11.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM11.dly, ESU11.dly | 2019-03-01 12:49:22 The ESU11.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU11.dly, ESZ11.dly | 2019-03-01 12:49:22 The ESZ11.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ11.dly, ESH12.dly | 2019-03-01 12:49:22 The ESH12.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH12.dly, ESM12.dly | 2019-03-01 12:49:22 The ESM12.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM12.dly, ESU12.dly | 2019-03-01 12:49:22 The ESU12.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU12.dly, ESZ12.dly | 2019-03-01 12:49:22 The ESZ12.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ12.dly, ESH13.dly | 2019-03-01 12:49:22 The ESH13.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH13.dly, ESM13.dly | 2019-03-01 12:49:22 The ESM13.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM13.dly, ESU13.dly | 2019-03-01 12:49:22 The ESU13.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU13.dly, ESZ13.dly | 2019-03-01 12:49:22 The ESZ13.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ13.dly, ESH14.dly | 2019-03-01 12:49:22 The ESH14.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH14.dly, ESM14.dly | 2019-03-01 12:49:22 The ESM14.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM14.dly, ESU14.dly | 2019-03-01 12:49:22 The ESU14.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU14.dly, ESZ14.dly | 2019-03-01 12:49:22 The ESZ14.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESZ14.dly, ESH15.dly | 2019-03-01 12:49:22 The ESH15.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESH15.dly, ESM15.dly | 2019-03-01 12:49:22 The ESM15.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESM15.dly, ESU15.dly | 2019-03-01 12:49:22 The ESU15.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 Unable to determine transition date based on volume from files: ESU15.dly, ESZ15.dly | 2019-03-01 12:49:22 The ESZ15.dly symbol may not be the active contract month. | 2019-03-01 12:49:22 |
[2019-03-02 04:12:19] |
2/Inability to alter the //Chart Settings/Main Settings/Date Range in File/"from date". The From Date seems to be auto-populated and I can not move any further back in time from the populated date. Im not sure this is a critical factor in populating data, but I want to point this out. You cannot and this is documented. This is irrelevant.Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by following these instructions: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-02 04:12:43
[2019-03-03 21:55:43] |
I had previously completed all the advised actions in your response "prior" to posing my help request, however, as instructed I did complete the above instructions with no additional historic data resulting in my ES charts (populated data from December 2015 to present). A. Historical Charts Settings are populated with the following: 1/Chart Settings/Main Settings/Chart Type/Historical Chart 2/Chart Settings/Main Settings/Use Number of Days to Load/Day to Load: 7000 (less than the 20Y acc. maximum) 3/Chart Settings/Main Settings/Apply Global Symbol Settings B. Screenshot of chart and chart settings attached. C. The resulting Message Log is attached below. **Message Log** Software version: 1880 32-bit | 2019-03-03 16:43:47 Enabled for: Advanced Features. | 2019-03-03 16:43:47 Enabled for: Advanced Features 2. | 2019-03-03 16:43:47 Enabled for: Sierra Chart Historical Data Service. | 2019-03-03 16:43:47 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-03-03 16:43:47 Current selected Data/Trading service: TransAct Trading | 2019-03-03 16:43:47 Chart Update Interval: 500 | 2019-03-03 16:43:47 Intraday Data Storage Time Unit: 1 | 2019-03-03 16:43:47 Service username command line set: sm*** | 2019-03-03 16:43:47 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-03-03 16:43:47 2019-03-03 16:43:47 Local computer time | 2019-03-03 16:43:47 2019-03-03 21:43:47 Local computer time in UTC | 2019-03-03 16:43:47 2019-03-03 16:43:47 Local computer time in SC Time Zone | 2019-03-03 16:43:47 2019-03-03 19:24:23 Server time in UTC | 2019-03-03 16:43:47 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-03-03 16:43:47 Program path: C:\SierraChart\SierraChartTransActMA\ | 2019-03-03 16:43:47 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2019-03-03 16:43:47 OS Version Number: 10.0 | 2019-03-03 16:43:47 Locale Setting: C | 2019-03-03 16:43:47 DLLs: StrategyAlerts.dll, StrategyAlerts_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VCValueLevels.dll | 2019-03-03 16:43:47 Requested symbol settings for service code transact.trading. Request ID: 1. Overwrite = on. | 2019-03-03 16:44:16 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2019-03-03 16:44:16 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 46.4.97.203. | 2019-03-03 16:44:16 Symbol settings received. Request ID: 1. | 2019-03-03 16:44:17 Processed 808 symbol settings. | 2019-03-03 16:44:17 Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2019-03-03 16:44:17 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2019-03-03 16:44:17 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2019-03-03 16:44:17 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2019-03-03 16:44:17 ESH9 [CV] Monthly #1 | Reloading chart. | 2019-03-03 16:44:38 Unable to determine transition date based on volume from files: ESH00.dly, ESM00.dly | 2019-03-03 16:44:39 The ESM00.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM00.dly, ESU00.dly | 2019-03-03 16:44:39 The ESU00.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU00.dly, ESZ00.dly | 2019-03-03 16:44:39 The ESZ00.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ00.dly, ESH01.dly | 2019-03-03 16:44:39 The ESH01.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH01.dly, ESM01.dly | 2019-03-03 16:44:39 The ESM01.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM01.dly, ESU01.dly | 2019-03-03 16:44:39 The ESU01.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU01.dly, ESZ01.dly | 2019-03-03 16:44:39 The ESZ01.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ01.dly, ESH02.dly | 2019-03-03 16:44:39 The ESH02.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH02.dly, ESM02.dly | 2019-03-03 16:44:39 The ESM02.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM02.dly, ESU02.dly | 2019-03-03 16:44:39 The ESU02.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU02.dly, ESZ02.dly | 2019-03-03 16:44:39 The ESZ02.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ02.dly, ESH03.dly | 2019-03-03 16:44:39 The ESH03.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH03.dly, ESM03.dly | 2019-03-03 16:44:39 The ESM03.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM03.dly, ESU03.dly | 2019-03-03 16:44:39 The ESU03.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU03.dly, ESZ03.dly | 2019-03-03 16:44:39 The ESZ03.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ03.dly, ESH04.dly | 2019-03-03 16:44:39 The ESH04.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH04.dly, ESM04.dly | 2019-03-03 16:44:39 The ESM04.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM04.dly, ESU04.dly | 2019-03-03 16:44:39 The ESU04.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU04.dly, ESZ04.dly | 2019-03-03 16:44:39 The ESZ04.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ04.dly, ESH05.dly | 2019-03-03 16:44:39 The ESH05.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH05.dly, ESM05.dly | 2019-03-03 16:44:39 The ESM05.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM05.dly, ESU05.dly | 2019-03-03 16:44:39 The ESU05.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU05.dly, ESZ05.dly | 2019-03-03 16:44:39 The ESZ05.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ05.dly, ESH06.dly | 2019-03-03 16:44:39 The ESH06.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH06.dly, ESM06.dly | 2019-03-03 16:44:39 The ESM06.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM06.dly, ESU06.dly | 2019-03-03 16:44:39 The ESU06.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU06.dly, ESZ06.dly | 2019-03-03 16:44:39 The ESZ06.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ06.dly, ESH07.dly | 2019-03-03 16:44:39 The ESH07.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH07.dly, ESM07.dly | 2019-03-03 16:44:39 The ESM07.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM07.dly, ESU07.dly | 2019-03-03 16:44:39 The ESU07.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU07.dly, ESZ07.dly | 2019-03-03 16:44:39 The ESZ07.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ07.dly, ESH08.dly | 2019-03-03 16:44:39 The ESH08.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH08.dly, ESM08.dly | 2019-03-03 16:44:39 The ESM08.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM08.dly, ESU08.dly | 2019-03-03 16:44:39 The ESU08.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU08.dly, ESZ08.dly | 2019-03-03 16:44:39 The ESZ08.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ08.dly, ESH09.dly | 2019-03-03 16:44:39 The ESH09.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH09.dly, ESM09.dly | 2019-03-03 16:44:39 The ESM09.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM09.dly, ESU09.dly | 2019-03-03 16:44:39 The ESU09.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU09.dly, ESZ09.dly | 2019-03-03 16:44:39 The ESZ09.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ09.dly, ESH10.dly | 2019-03-03 16:44:39 The ESH10.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH10.dly, ESM10.dly | 2019-03-03 16:44:39 The ESM10.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM10.dly, ESU10.dly | 2019-03-03 16:44:39 The ESU10.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU10.dly, ESZ10.dly | 2019-03-03 16:44:39 The ESZ10.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ10.dly, ESH11.dly | 2019-03-03 16:44:39 The ESH11.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH11.dly, ESM11.dly | 2019-03-03 16:44:39 The ESM11.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM11.dly, ESU11.dly | 2019-03-03 16:44:39 The ESU11.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU11.dly, ESZ11.dly | 2019-03-03 16:44:39 The ESZ11.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ11.dly, ESH12.dly | 2019-03-03 16:44:39 The ESH12.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH12.dly, ESM12.dly | 2019-03-03 16:44:39 The ESM12.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM12.dly, ESU12.dly | 2019-03-03 16:44:39 The ESU12.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU12.dly, ESZ12.dly | 2019-03-03 16:44:39 The ESZ12.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ12.dly, ESH13.dly | 2019-03-03 16:44:39 The ESH13.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH13.dly, ESM13.dly | 2019-03-03 16:44:39 The ESM13.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM13.dly, ESU13.dly | 2019-03-03 16:44:39 The ESU13.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU13.dly, ESZ13.dly | 2019-03-03 16:44:39 The ESZ13.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ13.dly, ESH14.dly | 2019-03-03 16:44:39 The ESH14.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH14.dly, ESM14.dly | 2019-03-03 16:44:39 The ESM14.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM14.dly, ESU14.dly | 2019-03-03 16:44:39 The ESU14.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU14.dly, ESZ14.dly | 2019-03-03 16:44:39 The ESZ14.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESZ14.dly, ESH15.dly | 2019-03-03 16:44:39 The ESH15.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESH15.dly, ESM15.dly | 2019-03-03 16:44:39 The ESM15.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESM15.dly, ESU15.dly | 2019-03-03 16:44:39 The ESU15.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 Unable to determine transition date based on volume from files: ESU15.dly, ESZ15.dly | 2019-03-03 16:44:39 The ESZ15.dly symbol may not be the active contract month. | 2019-03-03 16:44:39 HD Request # 6 | Downloading Historical Daily chart data for ESH9. Starting date: 2017-06-01. Service: TransAct.Trading | 2019-03-03 16:45:10 HD Request # 6 | Requesting historical Daily data for ESH19 starting at 2017-05-31 | 2019-03-03 16:45:10 HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. | 2019-03-03 16:45:10 HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (2) | Connecting to IP: 88.99.0.216. | 2019-03-03 16:45:10 HD Request # 6 | Receiving historical Daily data for ESH9 starting at 2017-12-13 | 2019-03-03 16:45:11 HD Request # 6 | Writing historical Daily data to the file ESH9.dly | 2019-03-03 16:45:11 HD Request # 6 | Received 304 records from 2017-12-13 00:00:00 to 2019-03-01 00:00:00 (444.0 days) and wrote 304 records for ESH9 | 2019-03-03 16:45:11 HD Request # 6 | Completion time: 2s | 2019-03-03 16:45:11 HD Request # 6 | Daily data download complete for ESH9. Unique request ID: 5 | 2019-03-03 16:45:11 Removed historical data download ID 5 | 2019-03-03 16:45:11 HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-03-03 16:45:11 ESH9 [CV] Monthly #1 | Reloading chart. | 2019-03-03 16:45:11 HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-03-03 16:45:11 HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-03-03 16:45:11 Unable to determine transition date based on volume from files: ESH00.dly, ESM00.dly | 2019-03-03 16:45:12 The ESM00.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM00.dly, ESU00.dly | 2019-03-03 16:45:12 The ESU00.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU00.dly, ESZ00.dly | 2019-03-03 16:45:12 The ESZ00.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ00.dly, ESH01.dly | 2019-03-03 16:45:12 The ESH01.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH01.dly, ESM01.dly | 2019-03-03 16:45:12 The ESM01.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM01.dly, ESU01.dly | 2019-03-03 16:45:12 The ESU01.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU01.dly, ESZ01.dly | 2019-03-03 16:45:12 The ESZ01.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ01.dly, ESH02.dly | 2019-03-03 16:45:12 The ESH02.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH02.dly, ESM02.dly | 2019-03-03 16:45:12 The ESM02.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM02.dly, ESU02.dly | 2019-03-03 16:45:12 The ESU02.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU02.dly, ESZ02.dly | 2019-03-03 16:45:12 The ESZ02.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ02.dly, ESH03.dly | 2019-03-03 16:45:12 The ESH03.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH03.dly, ESM03.dly | 2019-03-03 16:45:12 The ESM03.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM03.dly, ESU03.dly | 2019-03-03 16:45:12 The ESU03.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU03.dly, ESZ03.dly | 2019-03-03 16:45:12 The ESZ03.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ03.dly, ESH04.dly | 2019-03-03 16:45:12 The ESH04.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH04.dly, ESM04.dly | 2019-03-03 16:45:12 The ESM04.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM04.dly, ESU04.dly | 2019-03-03 16:45:12 The ESU04.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU04.dly, ESZ04.dly | 2019-03-03 16:45:12 The ESZ04.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ04.dly, ESH05.dly | 2019-03-03 16:45:12 The ESH05.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH05.dly, ESM05.dly | 2019-03-03 16:45:12 The ESM05.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM05.dly, ESU05.dly | 2019-03-03 16:45:12 The ESU05.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU05.dly, ESZ05.dly | 2019-03-03 16:45:12 The ESZ05.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ05.dly, ESH06.dly | 2019-03-03 16:45:12 The ESH06.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH06.dly, ESM06.dly | 2019-03-03 16:45:12 The ESM06.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM06.dly, ESU06.dly | 2019-03-03 16:45:12 The ESU06.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU06.dly, ESZ06.dly | 2019-03-03 16:45:12 The ESZ06.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ06.dly, ESH07.dly | 2019-03-03 16:45:12 The ESH07.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH07.dly, ESM07.dly | 2019-03-03 16:45:12 The ESM07.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM07.dly, ESU07.dly | 2019-03-03 16:45:12 The ESU07.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU07.dly, ESZ07.dly | 2019-03-03 16:45:12 The ESZ07.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ07.dly, ESH08.dly | 2019-03-03 16:45:12 The ESH08.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH08.dly, ESM08.dly | 2019-03-03 16:45:12 The ESM08.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM08.dly, ESU08.dly | 2019-03-03 16:45:12 The ESU08.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU08.dly, ESZ08.dly | 2019-03-03 16:45:12 The ESZ08.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ08.dly, ESH09.dly | 2019-03-03 16:45:12 The ESH09.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH09.dly, ESM09.dly | 2019-03-03 16:45:12 The ESM09.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM09.dly, ESU09.dly | 2019-03-03 16:45:12 The ESU09.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU09.dly, ESZ09.dly | 2019-03-03 16:45:12 The ESZ09.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ09.dly, ESH10.dly | 2019-03-03 16:45:12 The ESH10.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH10.dly, ESM10.dly | 2019-03-03 16:45:12 The ESM10.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM10.dly, ESU10.dly | 2019-03-03 16:45:12 The ESU10.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU10.dly, ESZ10.dly | 2019-03-03 16:45:12 The ESZ10.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ10.dly, ESH11.dly | 2019-03-03 16:45:12 The ESH11.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH11.dly, ESM11.dly | 2019-03-03 16:45:12 The ESM11.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM11.dly, ESU11.dly | 2019-03-03 16:45:12 The ESU11.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU11.dly, ESZ11.dly | 2019-03-03 16:45:12 The ESZ11.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ11.dly, ESH12.dly | 2019-03-03 16:45:12 The ESH12.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH12.dly, ESM12.dly | 2019-03-03 16:45:12 The ESM12.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM12.dly, ESU12.dly | 2019-03-03 16:45:12 The ESU12.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU12.dly, ESZ12.dly | 2019-03-03 16:45:12 The ESZ12.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ12.dly, ESH13.dly | 2019-03-03 16:45:12 The ESH13.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH13.dly, ESM13.dly | 2019-03-03 16:45:12 The ESM13.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM13.dly, ESU13.dly | 2019-03-03 16:45:12 The ESU13.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU13.dly, ESZ13.dly | 2019-03-03 16:45:12 The ESZ13.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ13.dly, ESH14.dly | 2019-03-03 16:45:12 The ESH14.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH14.dly, ESM14.dly | 2019-03-03 16:45:12 The ESM14.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM14.dly, ESU14.dly | 2019-03-03 16:45:12 The ESU14.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU14.dly, ESZ14.dly | 2019-03-03 16:45:12 The ESZ14.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ14.dly, ESH15.dly | 2019-03-03 16:45:12 The ESH15.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH15.dly, ESM15.dly | 2019-03-03 16:45:12 The ESM15.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM15.dly, ESU15.dly | 2019-03-03 16:45:12 The ESU15.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU15.dly, ESZ15.dly | 2019-03-03 16:45:12 The ESZ15.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 ESH9 [CV] Weekly #2 | Reloading chart. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM12.dly, ESU12.dly | 2019-03-03 16:45:12 The ESU12.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU12.dly, ESZ12.dly | 2019-03-03 16:45:12 The ESZ12.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ12.dly, ESH13.dly | 2019-03-03 16:45:12 The ESH13.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH13.dly, ESM13.dly | 2019-03-03 16:45:12 The ESM13.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM13.dly, ESU13.dly | 2019-03-03 16:45:12 The ESU13.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU13.dly, ESZ13.dly | 2019-03-03 16:45:12 The ESZ13.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ13.dly, ESH14.dly | 2019-03-03 16:45:12 The ESH14.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH14.dly, ESM14.dly | 2019-03-03 16:45:12 The ESM14.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM14.dly, ESU14.dly | 2019-03-03 16:45:12 The ESU14.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU14.dly, ESZ14.dly | 2019-03-03 16:45:12 The ESZ14.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESZ14.dly, ESH15.dly | 2019-03-03 16:45:12 The ESH15.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESH15.dly, ESM15.dly | 2019-03-03 16:45:12 The ESM15.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESM15.dly, ESU15.dly | 2019-03-03 16:45:12 The ESU15.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 Unable to determine transition date based on volume from files: ESU15.dly, ESZ15.dly | 2019-03-03 16:45:12 The ESZ15.dly symbol may not be the active contract month. | 2019-03-03 16:45:12 ESH9 [CV] Daily #3 | Reloading chart. | 2019-03-03 16:45:12 |
ES Historical Chart_1.PNG / V - Attached On 2019-03-03 21:52:15 UTC - Size: 67.09 KB - 257 views Attachment Deleted. |
[2019-03-03 22:57:12] |
It does not look like the procedure was followed. We do not see any re-downloading of the data. This is what we see for the chart: http://www.sierrachart.com/image.php?Image=1551653803252.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-04 20:40:17] |
Lets review and reset, I am genuinly trying to resolve this probelm and seek your assistance. SC Engineer instructions and my actins are recorded below as well as is the message log. Instructions provided are as follows with actions taken in <<double brackets>>: 1/ Clear Message Log. <<Completed>> Window/Message Log/Clear Log 2/ Fully re-download the data in the chart. <<Completed>> Global Settings/Global Symbol settings/Full Reset <<Completed>> Chart/Reload and Recalculate <<Completed>> Chart/Chart Settings/Number of Days to Load/Days to Load/ 7000 <<Completed>> Edit/Delete All Data And Download Message Log Below: Software version: 1779 32-bit | 2019-03-04 15:20:33 Enabled for: Advanced Features. | 2019-03-04 15:20:33 Enabled for: Advanced Features 2. | 2019-03-04 15:20:33 Enabled for: Sierra Chart Historical Data Service. | 2019-03-04 15:20:33 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-03-04 15:20:33 Current selected Data/Trading service: TransAct Trading | 2019-03-04 15:20:33 Chart Update Interval: 500 | 2019-03-04 15:20:33 Service username command line set: sm*** | 2019-03-04 15:20:33 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-03-04 15:20:33 2019-03-04 15:20:32 Local computer time | 2019-03-04 15:20:33 2019-03-04 20:20:32 Local computer time in UTC | 2019-03-04 15:20:33 2019-03-04 15:20:32 Local computer time in SC Time Zone | 2019-03-04 15:20:33 2019-03-04 11:09:06 Server time in UTC | 2019-03-04 15:20:33 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-03-04 15:20:33 Program path: C:\SierraChart\SierraChartTransActMA\ | 2019-03-04 15:20:33 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2019-03-04 15:20:33 OS Version Number: 10.0 | 2019-03-04 15:20:33 Locale Setting: C | 2019-03-04 15:20:33 Requesting symbol settings for service code transact.trading. Overwrite = on. | 2019-03-04 15:26:46 HTTPS connection to www.sierrachart.com:443 (710) | Creating socket. Using TLS 1.2. | 2019-03-04 15:26:46 HTTPS connection to www.sierrachart.com:443 (710) | Connecting to IP: 46.4.97.203. | 2019-03-04 15:26:46 Symbol settings received. | 2019-03-04 15:26:47 Processed 808 symbol settings. | 2019-03-04 15:26:47 It is recommended to reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed' | 2019-03-04 15:26:47 HTTPS connection to www.sierrachart.com:443 (710) | Socket gracefully closed by remote side. | 2019-03-04 15:26:52 HTTPS connection to www.sierrachart.com:443 (710) | Received socket Close event. | 2019-03-04 15:26:52 HTTPS connection to www.sierrachart.com:443 (710) | Initiating close of socket by core. | 2019-03-04 15:26:52 HTTPS connection to www.sierrachart.com:443 (710) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-04 15:26:52 HTTPS connection to www.sierrachart.com:443 (710) | Closed. | 2019-03-04 15:26:52 ESH9 [CV] Monthly #1 | Reloading chart. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH00.dly, ESM00.dly | 2019-03-04 15:30:20 The ESM00.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM00.dly, ESU00.dly | 2019-03-04 15:30:20 The ESU00.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU00.dly, ESZ00.dly | 2019-03-04 15:30:20 The ESZ00.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ00.dly, ESH01.dly | 2019-03-04 15:30:20 The ESH01.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH01.dly, ESM01.dly | 2019-03-04 15:30:20 The ESM01.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM01.dly, ESU01.dly | 2019-03-04 15:30:20 The ESU01.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU01.dly, ESZ01.dly | 2019-03-04 15:30:20 The ESZ01.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ01.dly, ESH02.dly | 2019-03-04 15:30:20 The ESH02.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH02.dly, ESM02.dly | 2019-03-04 15:30:20 The ESM02.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM02.dly, ESU02.dly | 2019-03-04 15:30:20 The ESU02.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU02.dly, ESZ02.dly | 2019-03-04 15:30:20 The ESZ02.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ02.dly, ESH03.dly | 2019-03-04 15:30:20 The ESH03.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH03.dly, ESM03.dly | 2019-03-04 15:30:20 The ESM03.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM03.dly, ESU03.dly | 2019-03-04 15:30:20 The ESU03.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU03.dly, ESZ03.dly | 2019-03-04 15:30:20 The ESZ03.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ03.dly, ESH04.dly | 2019-03-04 15:30:20 The ESH04.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH04.dly, ESM04.dly | 2019-03-04 15:30:20 The ESM04.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM04.dly, ESU04.dly | 2019-03-04 15:30:20 The ESU04.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU04.dly, ESZ04.dly | 2019-03-04 15:30:20 The ESZ04.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ04.dly, ESH05.dly | 2019-03-04 15:30:20 The ESH05.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH05.dly, ESM05.dly | 2019-03-04 15:30:20 The ESM05.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM05.dly, ESU05.dly | 2019-03-04 15:30:20 The ESU05.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU05.dly, ESZ05.dly | 2019-03-04 15:30:20 The ESZ05.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ05.dly, ESH06.dly | 2019-03-04 15:30:20 The ESH06.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH06.dly, ESM06.dly | 2019-03-04 15:30:20 The ESM06.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM06.dly, ESU06.dly | 2019-03-04 15:30:20 The ESU06.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU06.dly, ESZ06.dly | 2019-03-04 15:30:20 The ESZ06.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ06.dly, ESH07.dly | 2019-03-04 15:30:20 The ESH07.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH07.dly, ESM07.dly | 2019-03-04 15:30:20 The ESM07.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM07.dly, ESU07.dly | 2019-03-04 15:30:20 The ESU07.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU07.dly, ESZ07.dly | 2019-03-04 15:30:20 The ESZ07.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ07.dly, ESH08.dly | 2019-03-04 15:30:20 The ESH08.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH08.dly, ESM08.dly | 2019-03-04 15:30:20 The ESM08.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM08.dly, ESU08.dly | 2019-03-04 15:30:20 The ESU08.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU08.dly, ESZ08.dly | 2019-03-04 15:30:20 The ESZ08.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ08.dly, ESH09.dly | 2019-03-04 15:30:20 The ESH09.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH09.dly, ESM09.dly | 2019-03-04 15:30:20 The ESM09.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM09.dly, ESU09.dly | 2019-03-04 15:30:20 The ESU09.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU09.dly, ESZ09.dly | 2019-03-04 15:30:20 The ESZ09.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ09.dly, ESH10.dly | 2019-03-04 15:30:20 The ESH10.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH10.dly, ESM10.dly | 2019-03-04 15:30:20 The ESM10.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM10.dly, ESU10.dly | 2019-03-04 15:30:20 The ESU10.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU10.dly, ESZ10.dly | 2019-03-04 15:30:20 The ESZ10.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ10.dly, ESH11.dly | 2019-03-04 15:30:20 The ESH11.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH11.dly, ESM11.dly | 2019-03-04 15:30:20 The ESM11.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM11.dly, ESU11.dly | 2019-03-04 15:30:20 The ESU11.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU11.dly, ESZ11.dly | 2019-03-04 15:30:20 The ESZ11.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ11.dly, ESH12.dly | 2019-03-04 15:30:20 The ESH12.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH12.dly, ESM12.dly | 2019-03-04 15:30:20 The ESM12.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM12.dly, ESU12.dly | 2019-03-04 15:30:20 The ESU12.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU12.dly, ESZ12.dly | 2019-03-04 15:30:20 The ESZ12.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ12.dly, ESH13.dly | 2019-03-04 15:30:20 The ESH13.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH13.dly, ESM13.dly | 2019-03-04 15:30:20 The ESM13.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM13.dly, ESU13.dly | 2019-03-04 15:30:20 The ESU13.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU13.dly, ESZ13.dly | 2019-03-04 15:30:20 The ESZ13.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ13.dly, ESH14.dly | 2019-03-04 15:30:20 The ESH14.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH14.dly, ESM14.dly | 2019-03-04 15:30:20 The ESM14.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM14.dly, ESU14.dly | 2019-03-04 15:30:20 The ESU14.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU14.dly, ESZ14.dly | 2019-03-04 15:30:20 The ESZ14.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESZ14.dly, ESH15.dly | 2019-03-04 15:30:20 The ESH15.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESH15.dly, ESM15.dly | 2019-03-04 15:30:20 The ESM15.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESM15.dly, ESU15.dly | 2019-03-04 15:30:20 The ESU15.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 Unable to determine transition date based on volume from files: ESU15.dly, ESZ15.dly | 2019-03-04 15:30:20 The ESZ15.dly symbol may not be the active contract month. | 2019-03-04 15:30:20 HD Request # 199 | Downloading Historical Daily chart data for ESH00. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 199 | Error downloading historical Daily data for ESH00. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 199 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH00 | 2019-03-04 15:35:42 HD Request # 199 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 199 | Daily data download complete for ESH00. Unique request ID: 254 | 2019-03-04 15:35:42 Removed historical data download ID 254 | 2019-03-04 15:35:42 HD Request # 200 | Downloading Historical Daily chart data for ESM00. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 200 | Error downloading historical Daily data for ESM00. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 200 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM00 | 2019-03-04 15:35:42 HD Request # 200 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 200 | Daily data download complete for ESM00. Unique request ID: 255 | 2019-03-04 15:35:42 Removed historical data download ID 255 | 2019-03-04 15:35:42 HD Request # 201 | Downloading Historical Daily chart data for ESU00. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 201 | Error downloading historical Daily data for ESU00. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 201 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU00 | 2019-03-04 15:35:42 HD Request # 201 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 201 | Daily data download complete for ESU00. Unique request ID: 256 | 2019-03-04 15:35:42 Removed historical data download ID 256 | 2019-03-04 15:35:42 HD Request # 202 | Downloading Historical Daily chart data for ESZ00. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 202 | Error downloading historical Daily data for ESZ00. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 202 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ00 | 2019-03-04 15:35:42 HD Request # 202 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 202 | Daily data download complete for ESZ00. Unique request ID: 257 | 2019-03-04 15:35:42 Removed historical data download ID 257 | 2019-03-04 15:35:42 HD Request # 203 | Downloading Historical Daily chart data for ESH01. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 203 | Error downloading historical Daily data for ESH01. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 203 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH01 | 2019-03-04 15:35:42 HD Request # 203 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 203 | Daily data download complete for ESH01. Unique request ID: 258 | 2019-03-04 15:35:42 Removed historical data download ID 258 | 2019-03-04 15:35:42 HD Request # 204 | Downloading Historical Daily chart data for ESM01. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 204 | Error downloading historical Daily data for ESM01. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 204 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM01 | 2019-03-04 15:35:42 HD Request # 204 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 204 | Daily data download complete for ESM01. Unique request ID: 259 | 2019-03-04 15:35:42 Removed historical data download ID 259 | 2019-03-04 15:35:42 HD Request # 205 | Downloading Historical Daily chart data for ESU01. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 205 | Error downloading historical Daily data for ESU01. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 205 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU01 | 2019-03-04 15:35:42 HD Request # 205 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 205 | Daily data download complete for ESU01. Unique request ID: 260 | 2019-03-04 15:35:42 Removed historical data download ID 260 | 2019-03-04 15:35:42 HD Request # 206 | Downloading Historical Daily chart data for ESZ01. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 206 | Error downloading historical Daily data for ESZ01. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 206 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ01 | 2019-03-04 15:35:42 HD Request # 206 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 206 | Daily data download complete for ESZ01. Unique request ID: 261 | 2019-03-04 15:35:42 Removed historical data download ID 261 | 2019-03-04 15:35:42 HD Request # 207 | Downloading Historical Daily chart data for ESH02. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 207 | Error downloading historical Daily data for ESH02. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 207 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH02 | 2019-03-04 15:35:42 HD Request # 207 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 207 | Daily data download complete for ESH02. Unique request ID: 262 | 2019-03-04 15:35:42 Removed historical data download ID 262 | 2019-03-04 15:35:42 HD Request # 208 | Downloading Historical Daily chart data for ESM02. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 208 | Error downloading historical Daily data for ESM02. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 208 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM02 | 2019-03-04 15:35:42 HD Request # 208 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 208 | Daily data download complete for ESM02. Unique request ID: 263 | 2019-03-04 15:35:42 Removed historical data download ID 263 | 2019-03-04 15:35:42 HD Request # 209 | Downloading Historical Daily chart data for ESU02. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 209 | Error downloading historical Daily data for ESU02. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 209 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU02 | 2019-03-04 15:35:42 HD Request # 209 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 209 | Daily data download complete for ESU02. Unique request ID: 264 | 2019-03-04 15:35:42 Removed historical data download ID 264 | 2019-03-04 15:35:42 HD Request # 210 | Downloading Historical Daily chart data for ESZ02. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 210 | Error downloading historical Daily data for ESZ02. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 210 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ02 | 2019-03-04 15:35:42 HD Request # 210 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 210 | Daily data download complete for ESZ02. Unique request ID: 265 | 2019-03-04 15:35:42 Removed historical data download ID 265 | 2019-03-04 15:35:42 HD Request # 211 | Downloading Historical Daily chart data for ESH03. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 211 | Error downloading historical Daily data for ESH03. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 211 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH03 | 2019-03-04 15:35:42 HD Request # 211 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 211 | Daily data download complete for ESH03. Unique request ID: 266 | 2019-03-04 15:35:42 Removed historical data download ID 266 | 2019-03-04 15:35:42 HD Request # 212 | Downloading Historical Daily chart data for ESM03. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 212 | Error downloading historical Daily data for ESM03. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 212 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM03 | 2019-03-04 15:35:42 HD Request # 212 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 212 | Daily data download complete for ESM03. Unique request ID: 267 | 2019-03-04 15:35:42 Removed historical data download ID 267 | 2019-03-04 15:35:42 HD Request # 213 | Downloading Historical Daily chart data for ESU03. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 213 | Error downloading historical Daily data for ESU03. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 213 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU03 | 2019-03-04 15:35:42 HD Request # 213 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 213 | Daily data download complete for ESU03. Unique request ID: 268 | 2019-03-04 15:35:42 Removed historical data download ID 268 | 2019-03-04 15:35:42 HD Request # 214 | Downloading Historical Daily chart data for ESZ03. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 214 | Error downloading historical Daily data for ESZ03. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 214 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ03 | 2019-03-04 15:35:42 HD Request # 214 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 214 | Daily data download complete for ESZ03. Unique request ID: 269 | 2019-03-04 15:35:42 Removed historical data download ID 269 | 2019-03-04 15:35:42 HD Request # 215 | Downloading Historical Daily chart data for ESH04. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 215 | Error downloading historical Daily data for ESH04. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 215 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH04 | 2019-03-04 15:35:42 HD Request # 215 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 215 | Daily data download complete for ESH04. Unique request ID: 270 | 2019-03-04 15:35:42 Removed historical data download ID 270 | 2019-03-04 15:35:42 HD Request # 216 | Downloading Historical Daily chart data for ESM04. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 216 | Error downloading historical Daily data for ESM04. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 216 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM04 | 2019-03-04 15:35:42 HD Request # 216 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 216 | Daily data download complete for ESM04. Unique request ID: 271 | 2019-03-04 15:35:42 Removed historical data download ID 271 | 2019-03-04 15:35:42 HD Request # 217 | Downloading Historical Daily chart data for ESU04. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 217 | Error downloading historical Daily data for ESU04. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 217 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU04 | 2019-03-04 15:35:42 HD Request # 217 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 217 | Daily data download complete for ESU04. Unique request ID: 272 | 2019-03-04 15:35:42 Removed historical data download ID 272 | 2019-03-04 15:35:42 HD Request # 218 | Downloading Historical Daily chart data for ESZ04. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 218 | Error downloading historical Daily data for ESZ04. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 218 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ04 | 2019-03-04 15:35:42 HD Request # 218 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 218 | Daily data download complete for ESZ04. Unique request ID: 273 | 2019-03-04 15:35:42 Removed historical data download ID 273 | 2019-03-04 15:35:42 HD Request # 219 | Downloading Historical Daily chart data for ESH05. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 219 | Error downloading historical Daily data for ESH05. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 219 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH05 | 2019-03-04 15:35:42 HD Request # 219 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 219 | Daily data download complete for ESH05. Unique request ID: 274 | 2019-03-04 15:35:42 Removed historical data download ID 274 | 2019-03-04 15:35:42 HD Request # 220 | Downloading Historical Daily chart data for ESM05. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 220 | Error downloading historical Daily data for ESM05. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 220 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM05 | 2019-03-04 15:35:42 HD Request # 220 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 220 | Daily data download complete for ESM05. Unique request ID: 275 | 2019-03-04 15:35:42 Removed historical data download ID 275 | 2019-03-04 15:35:42 HD Request # 221 | Downloading Historical Daily chart data for ESU05. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 221 | Error downloading historical Daily data for ESU05. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 221 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU05 | 2019-03-04 15:35:42 HD Request # 221 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 221 | Daily data download complete for ESU05. Unique request ID: 276 | 2019-03-04 15:35:42 Removed historical data download ID 276 | 2019-03-04 15:35:42 HD Request # 222 | Downloading Historical Daily chart data for ESZ05. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 222 | Error downloading historical Daily data for ESZ05. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 222 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ05 | 2019-03-04 15:35:42 HD Request # 222 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 222 | Daily data download complete for ESZ05. Unique request ID: 277 | 2019-03-04 15:35:42 Removed historical data download ID 277 | 2019-03-04 15:35:42 HD Request # 223 | Downloading Historical Daily chart data for ESH06. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 223 | Error downloading historical Daily data for ESH06. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 223 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH06 | 2019-03-04 15:35:42 HD Request # 223 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 223 | Daily data download complete for ESH06. Unique request ID: 278 | 2019-03-04 15:35:42 Removed historical data download ID 278 | 2019-03-04 15:35:42 HD Request # 224 | Downloading Historical Daily chart data for ESM06. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 224 | Error downloading historical Daily data for ESM06. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 224 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM06 | 2019-03-04 15:35:42 HD Request # 224 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 224 | Daily data download complete for ESM06. Unique request ID: 279 | 2019-03-04 15:35:42 Removed historical data download ID 279 | 2019-03-04 15:35:42 HD Request # 225 | Downloading Historical Daily chart data for ESU06. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 225 | Error downloading historical Daily data for ESU06. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 225 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU06 | 2019-03-04 15:35:42 HD Request # 225 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 225 | Daily data download complete for ESU06. Unique request ID: 280 | 2019-03-04 15:35:42 Removed historical data download ID 280 | 2019-03-04 15:35:42 HD Request # 226 | Downloading Historical Daily chart data for ESZ06. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 226 | Error downloading historical Daily data for ESZ06. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 226 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ06 | 2019-03-04 15:35:42 HD Request # 226 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 226 | Daily data download complete for ESZ06. Unique request ID: 281 | 2019-03-04 15:35:42 Removed historical data download ID 281 | 2019-03-04 15:35:42 HD Request # 227 | Downloading Historical Daily chart data for ESH07. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 227 | Error downloading historical Daily data for ESH07. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 227 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH07 | 2019-03-04 15:35:42 HD Request # 227 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 227 | Daily data download complete for ESH07. Unique request ID: 282 | 2019-03-04 15:35:42 Removed historical data download ID 282 | 2019-03-04 15:35:42 HD Request # 228 | Downloading Historical Daily chart data for ESM07. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 228 | Error downloading historical Daily data for ESM07. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 228 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM07 | 2019-03-04 15:35:42 HD Request # 228 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 228 | Daily data download complete for ESM07. Unique request ID: 283 | 2019-03-04 15:35:42 Removed historical data download ID 283 | 2019-03-04 15:35:42 HD Request # 229 | Downloading Historical Daily chart data for ESU07. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 229 | Error downloading historical Daily data for ESU07. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 229 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU07 | 2019-03-04 15:35:42 HD Request # 229 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 229 | Daily data download complete for ESU07. Unique request ID: 284 | 2019-03-04 15:35:42 Removed historical data download ID 284 | 2019-03-04 15:35:42 HD Request # 230 | Downloading Historical Daily chart data for ESZ07. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 230 | Error downloading historical Daily data for ESZ07. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 230 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ07 | 2019-03-04 15:35:42 HD Request # 230 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 230 | Daily data download complete for ESZ07. Unique request ID: 285 | 2019-03-04 15:35:42 Removed historical data download ID 285 | 2019-03-04 15:35:42 HD Request # 231 | Downloading Historical Daily chart data for ESH08. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 231 | Error downloading historical Daily data for ESH08. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 231 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH08 | 2019-03-04 15:35:42 HD Request # 231 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 231 | Daily data download complete for ESH08. Unique request ID: 286 | 2019-03-04 15:35:42 Removed historical data download ID 286 | 2019-03-04 15:35:42 HD Request # 232 | Downloading Historical Daily chart data for ESM08. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 232 | Error downloading historical Daily data for ESM08. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 232 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM08 | 2019-03-04 15:35:42 HD Request # 232 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 232 | Daily data download complete for ESM08. Unique request ID: 287 | 2019-03-04 15:35:42 Removed historical data download ID 287 | 2019-03-04 15:35:42 HD Request # 233 | Downloading Historical Daily chart data for ESU08. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 233 | Error downloading historical Daily data for ESU08. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 233 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU08 | 2019-03-04 15:35:42 HD Request # 233 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 233 | Daily data download complete for ESU08. Unique request ID: 288 | 2019-03-04 15:35:42 Removed historical data download ID 288 | 2019-03-04 15:35:42 HD Request # 234 | Downloading Historical Daily chart data for ESZ08. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 234 | Error downloading historical Daily data for ESZ08. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 234 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ08 | 2019-03-04 15:35:42 HD Request # 234 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 234 | Daily data download complete for ESZ08. Unique request ID: 289 | 2019-03-04 15:35:42 Removed historical data download ID 289 | 2019-03-04 15:35:42 HD Request # 235 | Downloading Historical Daily chart data for ESH09. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 235 | Error downloading historical Daily data for ESH09. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 235 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH09 | 2019-03-04 15:35:42 HD Request # 235 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 235 | Daily data download complete for ESH09. Unique request ID: 290 | 2019-03-04 15:35:42 Removed historical data download ID 290 | 2019-03-04 15:35:42 HD Request # 236 | Downloading Historical Daily chart data for ESM09. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 236 | Error downloading historical Daily data for ESM09. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 236 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM09 | 2019-03-04 15:35:42 HD Request # 236 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 236 | Daily data download complete for ESM09. Unique request ID: 291 | 2019-03-04 15:35:42 Removed historical data download ID 291 | 2019-03-04 15:35:42 HD Request # 237 | Downloading Historical Daily chart data for ESU09. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 237 | Error downloading historical Daily data for ESU09. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 237 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU09 | 2019-03-04 15:35:42 HD Request # 237 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 237 | Daily data download complete for ESU09. Unique request ID: 292 | 2019-03-04 15:35:42 Removed historical data download ID 292 | 2019-03-04 15:35:42 HD Request # 238 | Downloading Historical Daily chart data for ESZ09. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 238 | Error downloading historical Daily data for ESZ09. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 238 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ09 | 2019-03-04 15:35:42 HD Request # 238 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 238 | Daily data download complete for ESZ09. Unique request ID: 293 | 2019-03-04 15:35:42 Removed historical data download ID 293 | 2019-03-04 15:35:42 HD Request # 239 | Downloading Historical Daily chart data for ESH10. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 239 | Error downloading historical Daily data for ESH10. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 239 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH10 | 2019-03-04 15:35:42 HD Request # 239 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 239 | Daily data download complete for ESH10. Unique request ID: 294 | 2019-03-04 15:35:42 Removed historical data download ID 294 | 2019-03-04 15:35:42 HD Request # 240 | Downloading Historical Daily chart data for ESM10. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 240 | Error downloading historical Daily data for ESM10. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 240 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM10 | 2019-03-04 15:35:42 HD Request # 240 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 240 | Daily data download complete for ESM10. Unique request ID: 295 | 2019-03-04 15:35:42 Removed historical data download ID 295 | 2019-03-04 15:35:42 HD Request # 241 | Downloading Historical Daily chart data for ESU10. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 241 | Error downloading historical Daily data for ESU10. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 241 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU10 | 2019-03-04 15:35:42 HD Request # 241 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 241 | Daily data download complete for ESU10. Unique request ID: 296 | 2019-03-04 15:35:42 Removed historical data download ID 296 | 2019-03-04 15:35:42 HD Request # 242 | Downloading Historical Daily chart data for ESZ10. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 242 | Error downloading historical Daily data for ESZ10. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 242 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ10 | 2019-03-04 15:35:42 HD Request # 242 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 242 | Daily data download complete for ESZ10. Unique request ID: 297 | 2019-03-04 15:35:42 Removed historical data download ID 297 | 2019-03-04 15:35:42 HD Request # 243 | Downloading Historical Daily chart data for ESH11. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 243 | Error downloading historical Daily data for ESH11. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 243 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH11 | 2019-03-04 15:35:42 HD Request # 243 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 243 | Daily data download complete for ESH11. Unique request ID: 298 | 2019-03-04 15:35:42 Removed historical data download ID 298 | 2019-03-04 15:35:42 HD Request # 244 | Downloading Historical Daily chart data for ESM11. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 244 | Error downloading historical Daily data for ESM11. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 244 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM11 | 2019-03-04 15:35:42 HD Request # 244 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 244 | Daily data download complete for ESM11. Unique request ID: 299 | 2019-03-04 15:35:42 Removed historical data download ID 299 | 2019-03-04 15:35:42 HD Request # 245 | Downloading Historical Daily chart data for ESU11. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 245 | Error downloading historical Daily data for ESU11. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 245 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU11 | 2019-03-04 15:35:42 HD Request # 245 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 245 | Daily data download complete for ESU11. Unique request ID: 300 | 2019-03-04 15:35:42 Removed historical data download ID 300 | 2019-03-04 15:35:42 HD Request # 246 | Downloading Historical Daily chart data for ESZ11. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 246 | Error downloading historical Daily data for ESZ11. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 246 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ11 | 2019-03-04 15:35:42 HD Request # 246 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 246 | Daily data download complete for ESZ11. Unique request ID: 301 | 2019-03-04 15:35:42 Removed historical data download ID 301 | 2019-03-04 15:35:42 HD Request # 247 | Downloading Historical Daily chart data for ESH12. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 247 | Error downloading historical Daily data for ESH12. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 247 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH12 | 2019-03-04 15:35:42 HD Request # 247 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 247 | Daily data download complete for ESH12. Unique request ID: 302 | 2019-03-04 15:35:42 Removed historical data download ID 302 | 2019-03-04 15:35:42 HD Request # 248 | Downloading Historical Daily chart data for ESM12. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 248 | Error downloading historical Daily data for ESM12. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 248 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM12 | 2019-03-04 15:35:42 HD Request # 248 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 248 | Daily data download complete for ESM12. Unique request ID: 303 | 2019-03-04 15:35:42 Removed historical data download ID 303 | 2019-03-04 15:35:42 HD Request # 249 | Downloading Historical Daily chart data for ESU12. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 249 | Error downloading historical Daily data for ESU12. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 249 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU12 | 2019-03-04 15:35:42 HD Request # 249 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 249 | Daily data download complete for ESU12. Unique request ID: 304 | 2019-03-04 15:35:42 Removed historical data download ID 304 | 2019-03-04 15:35:42 HD Request # 250 | Downloading Historical Daily chart data for ESZ12. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 250 | Error downloading historical Daily data for ESZ12. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 250 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ12 | 2019-03-04 15:35:42 HD Request # 250 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 250 | Daily data download complete for ESZ12. Unique request ID: 305 | 2019-03-04 15:35:42 Removed historical data download ID 305 | 2019-03-04 15:35:42 HD Request # 251 | Downloading Historical Daily chart data for ESH13. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 251 | Error downloading historical Daily data for ESH13. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 251 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH13 | 2019-03-04 15:35:42 HD Request # 251 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 251 | Daily data download complete for ESH13. Unique request ID: 306 | 2019-03-04 15:35:42 Removed historical data download ID 306 | 2019-03-04 15:35:42 HD Request # 252 | Downloading Historical Daily chart data for ESM13. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 252 | Error downloading historical Daily data for ESM13. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 252 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM13 | 2019-03-04 15:35:42 HD Request # 252 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 252 | Daily data download complete for ESM13. Unique request ID: 307 | 2019-03-04 15:35:42 Removed historical data download ID 307 | 2019-03-04 15:35:42 HD Request # 253 | Downloading Historical Daily chart data for ESU13. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 253 | Error downloading historical Daily data for ESU13. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 253 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU13 | 2019-03-04 15:35:42 HD Request # 253 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 253 | Daily data download complete for ESU13. Unique request ID: 308 | 2019-03-04 15:35:42 Removed historical data download ID 308 | 2019-03-04 15:35:42 HD Request # 254 | Downloading Historical Daily chart data for ESZ13. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 254 | Error downloading historical Daily data for ESZ13. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 254 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ13 | 2019-03-04 15:35:42 HD Request # 254 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 254 | Daily data download complete for ESZ13. Unique request ID: 309 | 2019-03-04 15:35:42 Removed historical data download ID 309 | 2019-03-04 15:35:42 HD Request # 255 | Downloading Historical Daily chart data for ESH14. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 255 | Error downloading historical Daily data for ESH14. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 255 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH14 | 2019-03-04 15:35:42 HD Request # 255 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 255 | Daily data download complete for ESH14. Unique request ID: 310 | 2019-03-04 15:35:42 Removed historical data download ID 310 | 2019-03-04 15:35:42 HD Request # 256 | Downloading Historical Daily chart data for ESM14. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 256 | Error downloading historical Daily data for ESM14. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 256 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM14 | 2019-03-04 15:35:42 HD Request # 256 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 256 | Daily data download complete for ESM14. Unique request ID: 311 | 2019-03-04 15:35:42 Removed historical data download ID 311 | 2019-03-04 15:35:42 HD Request # 257 | Downloading Historical Daily chart data for ESU14. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 257 | Error downloading historical Daily data for ESU14. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 257 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU14 | 2019-03-04 15:35:42 HD Request # 257 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 257 | Daily data download complete for ESU14. Unique request ID: 312 | 2019-03-04 15:35:42 Removed historical data download ID 312 | 2019-03-04 15:35:42 HD Request # 258 | Downloading Historical Daily chart data for ESZ14. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 258 | Error downloading historical Daily data for ESZ14. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 258 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ14 | 2019-03-04 15:35:42 HD Request # 258 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 258 | Daily data download complete for ESZ14. Unique request ID: 313 | 2019-03-04 15:35:42 Removed historical data download ID 313 | 2019-03-04 15:35:42 HD Request # 259 | Downloading Historical Daily chart data for ESH15. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 259 | Error downloading historical Daily data for ESH15. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 259 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH15 | 2019-03-04 15:35:42 HD Request # 259 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 259 | Daily data download complete for ESH15. Unique request ID: 314 | 2019-03-04 15:35:42 Removed historical data download ID 314 | 2019-03-04 15:35:42 HD Request # 260 | Downloading Historical Daily chart data for ESM15. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 260 | Error downloading historical Daily data for ESM15. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 260 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM15 | 2019-03-04 15:35:42 HD Request # 260 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 260 | Daily data download complete for ESM15. Unique request ID: 315 | 2019-03-04 15:35:42 Removed historical data download ID 315 | 2019-03-04 15:35:42 HD Request # 261 | Downloading Historical Daily chart data for ESU15. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 261 | Error downloading historical Daily data for ESU15. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 261 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU15 | 2019-03-04 15:35:42 HD Request # 261 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 261 | Daily data download complete for ESU15. Unique request ID: 316 | 2019-03-04 15:35:42 Removed historical data download ID 316 | 2019-03-04 15:35:42 HD Request # 262 | Downloading Historical Daily chart data for ESZ15. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 262 | Error downloading historical Daily data for ESZ15. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 262 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ15 | 2019-03-04 15:35:42 HD Request # 262 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 262 | Daily data download complete for ESZ15. Unique request ID: 317 | 2019-03-04 15:35:42 Removed historical data download ID 317 | 2019-03-04 15:35:42 HD Request # 263 | Downloading Historical Daily chart data for ESH16. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 263 | Error downloading historical Daily data for ESH16. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 263 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH16 | 2019-03-04 15:35:42 HD Request # 263 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 263 | Daily data download complete for ESH16. Unique request ID: 318 | 2019-03-04 15:35:42 Removed historical data download ID 318 | 2019-03-04 15:35:42 HD Request # 264 | Downloading Historical Daily chart data for ESM16. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 264 | Error downloading historical Daily data for ESM16. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 264 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM16 | 2019-03-04 15:35:42 HD Request # 264 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 264 | Daily data download complete for ESM16. Unique request ID: 319 | 2019-03-04 15:35:42 Removed historical data download ID 319 | 2019-03-04 15:35:42 HD Request # 265 | Downloading Historical Daily chart data for ESU16. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 265 | Error downloading historical Daily data for ESU16. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 265 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU16 | 2019-03-04 15:35:42 HD Request # 265 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 265 | Daily data download complete for ESU16. Unique request ID: 320 | 2019-03-04 15:35:42 Removed historical data download ID 320 | 2019-03-04 15:35:42 HD Request # 266 | Downloading Historical Daily chart data for ESZ16. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 266 | Error downloading historical Daily data for ESZ16. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 266 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ16 | 2019-03-04 15:35:42 HD Request # 266 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 266 | Daily data download complete for ESZ16. Unique request ID: 321 | 2019-03-04 15:35:42 Removed historical data download ID 321 | 2019-03-04 15:35:42 HD Request # 267 | Downloading Historical Daily chart data for ESH17. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 267 | Error downloading historical Daily data for ESH17. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 267 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH17 | 2019-03-04 15:35:42 HD Request # 267 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 267 | Daily data download complete for ESH17. Unique request ID: 322 | 2019-03-04 15:35:42 Removed historical data download ID 322 | 2019-03-04 15:35:42 HD Request # 268 | Downloading Historical Daily chart data for ESM17. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 268 | Error downloading historical Daily data for ESM17. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 268 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM17 | 2019-03-04 15:35:42 HD Request # 268 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 268 | Daily data download complete for ESM17. Unique request ID: 323 | 2019-03-04 15:35:42 Removed historical data download ID 323 | 2019-03-04 15:35:42 HD Request # 269 | Downloading Historical Daily chart data for ESU17. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 269 | Error downloading historical Daily data for ESU17. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 269 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU17 | 2019-03-04 15:35:42 HD Request # 269 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 269 | Daily data download complete for ESU17. Unique request ID: 324 | 2019-03-04 15:35:42 Removed historical data download ID 324 | 2019-03-04 15:35:42 HD Request # 270 | Downloading Historical Daily chart data for ESZ17. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 270 | Error downloading historical Daily data for ESZ17. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 270 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ17 | 2019-03-04 15:35:42 HD Request # 270 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 270 | Daily data download complete for ESZ17. Unique request ID: 325 | 2019-03-04 15:35:42 Removed historical data download ID 325 | 2019-03-04 15:35:42 HD Request # 271 | Downloading Historical Daily chart data for ESH18. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 271 | Error downloading historical Daily data for ESH18. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 271 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH18 | 2019-03-04 15:35:42 HD Request # 271 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 271 | Daily data download complete for ESH18. Unique request ID: 326 | 2019-03-04 15:35:42 Removed historical data download ID 326 | 2019-03-04 15:35:42 HD Request # 272 | Downloading Historical Daily chart data for ESM18. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 272 | Error downloading historical Daily data for ESM18. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 272 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM18 | 2019-03-04 15:35:42 HD Request # 272 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 272 | Daily data download complete for ESM18. Unique request ID: 327 | 2019-03-04 15:35:42 Removed historical data download ID 327 | 2019-03-04 15:35:42 HD Request # 273 | Downloading Historical Daily chart data for ESU18. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 273 | Error downloading historical Daily data for ESU18. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 273 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU18 | 2019-03-04 15:35:42 HD Request # 273 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 273 | Daily data download complete for ESU18. Unique request ID: 328 | 2019-03-04 15:35:42 Removed historical data download ID 328 | 2019-03-04 15:35:42 HD Request # 274 | Downloading Historical Daily chart data for ESZ18. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 274 | Error downloading historical Daily data for ESZ18. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 274 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ18 | 2019-03-04 15:35:42 HD Request # 274 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 274 | Daily data download complete for ESZ18. Unique request ID: 329 | 2019-03-04 15:35:42 Removed historical data download ID 329 | 2019-03-04 15:35:42 HD Request # 275 | Downloading Historical Daily chart data for ESH9. Starting date: 1969-03-04. Service: TransAct.Trading | 2019-03-04 15:35:42 HD Request # 275 | Error downloading historical Daily data for ESH9. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42 HD Request # 275 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH9 | 2019-03-04 15:35:42 HD Request # 275 | Completion time: 0s | 2019-03-04 15:35:42 HD Request # 275 | Daily data download complete for ESH9. Unique request ID: 330 | 2019-03-04 15:35:42 Removed historical data download ID 330 | 2019-03-04 15:35:42 ESH9 [CV] Daily #3 | Reloading chart. | 2019-03-04 15:35:42 ESH9 [CV] Weekly #2 | Reloading chart. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM12.dly, ESU12.dly | 2019-03-04 15:35:42 The ESU12.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU12.dly, ESZ12.dly | 2019-03-04 15:35:42 The ESZ12.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ12.dly, ESH13.dly | 2019-03-04 15:35:42 The ESH13.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH13.dly, ESM13.dly | 2019-03-04 15:35:42 The ESM13.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM13.dly, ESU13.dly | 2019-03-04 15:35:42 The ESU13.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU13.dly, ESZ13.dly | 2019-03-04 15:35:42 The ESZ13.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ13.dly, ESH14.dly | 2019-03-04 15:35:42 The ESH14.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH14.dly, ESM14.dly | 2019-03-04 15:35:42 The ESM14.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM14.dly, ESU14.dly | 2019-03-04 15:35:42 The ESU14.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU14.dly, ESZ14.dly | 2019-03-04 15:35:42 The ESZ14.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ14.dly, ESH15.dly | 2019-03-04 15:35:42 The ESH15.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH15.dly, ESM15.dly | 2019-03-04 15:35:42 The ESM15.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM15.dly, ESU15.dly | 2019-03-04 15:35:42 The ESU15.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU15.dly, ESZ15.dly | 2019-03-04 15:35:42 The ESZ15.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 ESH9 [CV] Monthly #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2019-03-04 15:35:42 ESH9 [CV] Monthly #1 | Reloading chart. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH00.dly, ESM00.dly | 2019-03-04 15:35:42 The ESM00.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM00.dly, ESU00.dly | 2019-03-04 15:35:42 The ESU00.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU00.dly, ESZ00.dly | 2019-03-04 15:35:42 The ESZ00.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ00.dly, ESH01.dly | 2019-03-04 15:35:42 The ESH01.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH01.dly, ESM01.dly | 2019-03-04 15:35:42 The ESM01.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM01.dly, ESU01.dly | 2019-03-04 15:35:42 The ESU01.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU01.dly, ESZ01.dly | 2019-03-04 15:35:42 The ESZ01.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ01.dly, ESH02.dly | 2019-03-04 15:35:42 The ESH02.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH02.dly, ESM02.dly | 2019-03-04 15:35:42 The ESM02.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM02.dly, ESU02.dly | 2019-03-04 15:35:42 The ESU02.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU02.dly, ESZ02.dly | 2019-03-04 15:35:42 The ESZ02.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ02.dly, ESH03.dly | 2019-03-04 15:35:42 The ESH03.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH03.dly, ESM03.dly | 2019-03-04 15:35:42 The ESM03.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM03.dly, ESU03.dly | 2019-03-04 15:35:42 The ESU03.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU03.dly, ESZ03.dly | 2019-03-04 15:35:42 The ESZ03.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ03.dly, ESH04.dly | 2019-03-04 15:35:42 The ESH04.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH04.dly, ESM04.dly | 2019-03-04 15:35:42 The ESM04.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM04.dly, ESU04.dly | 2019-03-04 15:35:42 The ESU04.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU04.dly, ESZ04.dly | 2019-03-04 15:35:42 The ESZ04.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ04.dly, ESH05.dly | 2019-03-04 15:35:42 The ESH05.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH05.dly, ESM05.dly | 2019-03-04 15:35:42 The ESM05.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM05.dly, ESU05.dly | 2019-03-04 15:35:42 The ESU05.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU05.dly, ESZ05.dly | 2019-03-04 15:35:42 The ESZ05.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ05.dly, ESH06.dly | 2019-03-04 15:35:42 The ESH06.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH06.dly, ESM06.dly | 2019-03-04 15:35:42 The ESM06.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM06.dly, ESU06.dly | 2019-03-04 15:35:42 The ESU06.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU06.dly, ESZ06.dly | 2019-03-04 15:35:42 The ESZ06.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ06.dly, ESH07.dly | 2019-03-04 15:35:42 The ESH07.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH07.dly, ESM07.dly | 2019-03-04 15:35:42 The ESM07.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM07.dly, ESU07.dly | 2019-03-04 15:35:42 The ESU07.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU07.dly, ESZ07.dly | 2019-03-04 15:35:42 The ESZ07.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ07.dly, ESH08.dly | 2019-03-04 15:35:42 The ESH08.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH08.dly, ESM08.dly | 2019-03-04 15:35:42 The ESM08.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM08.dly, ESU08.dly | 2019-03-04 15:35:42 The ESU08.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU08.dly, ESZ08.dly | 2019-03-04 15:35:42 The ESZ08.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ08.dly, ESH09.dly | 2019-03-04 15:35:42 The ESH09.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH09.dly, ESM09.dly | 2019-03-04 15:35:42 The ESM09.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM09.dly, ESU09.dly | 2019-03-04 15:35:42 The ESU09.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU09.dly, ESZ09.dly | 2019-03-04 15:35:42 The ESZ09.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ09.dly, ESH10.dly | 2019-03-04 15:35:42 The ESH10.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH10.dly, ESM10.dly | 2019-03-04 15:35:42 The ESM10.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESM10.dly, ESU10.dly | 2019-03-04 15:35:42 The ESU10.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESU10.dly, ESZ10.dly | 2019-03-04 15:35:42 The ESZ10.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESZ10.dly, ESH11.dly | 2019-03-04 15:35:42 The ESH11.dly symbol may not be the active contract month. | 2019-03-04 15:35:42 Unable to determine transition date based on volume from files: ESH11.dly, ESM11.dly | 2019-03-04 15:35:43 The ESM11.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM11.dly, ESU11.dly | 2019-03-04 15:35:43 The ESU11.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU11.dly, ESZ11.dly | 2019-03-04 15:35:43 The ESZ11.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ11.dly, ESH12.dly | 2019-03-04 15:35:43 The ESH12.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH12.dly, ESM12.dly | 2019-03-04 15:35:43 The ESM12.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM12.dly, ESU12.dly | 2019-03-04 15:35:43 The ESU12.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU12.dly, ESZ12.dly | 2019-03-04 15:35:43 The ESZ12.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ12.dly, ESH13.dly | 2019-03-04 15:35:43 The ESH13.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH13.dly, ESM13.dly | 2019-03-04 15:35:43 The ESM13.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM13.dly, ESU13.dly | 2019-03-04 15:35:43 The ESU13.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU13.dly, ESZ13.dly | 2019-03-04 15:35:43 The ESZ13.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ13.dly, ESH14.dly | 2019-03-04 15:35:43 The ESH14.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH14.dly, ESM14.dly | 2019-03-04 15:35:43 The ESM14.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM14.dly, ESU14.dly | 2019-03-04 15:35:43 The ESU14.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU14.dly, ESZ14.dly | 2019-03-04 15:35:43 The ESZ14.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ14.dly, ESH15.dly | 2019-03-04 15:35:43 The ESH15.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH15.dly, ESM15.dly | 2019-03-04 15:35:43 The ESM15.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM15.dly, ESU15.dly | 2019-03-04 15:35:43 The ESU15.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU15.dly, ESZ15.dly | 2019-03-04 15:35:43 The ESZ15.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 ESH9 [CV] Monthly #1 | Reloading chart. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH00.dly, ESM00.dly | 2019-03-04 15:35:43 The ESM00.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM00.dly, ESU00.dly | 2019-03-04 15:35:43 The ESU00.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU00.dly, ESZ00.dly | 2019-03-04 15:35:43 The ESZ00.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ00.dly, ESH01.dly | 2019-03-04 15:35:43 The ESH01.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH01.dly, ESM01.dly | 2019-03-04 15:35:43 The ESM01.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM01.dly, ESU01.dly | 2019-03-04 15:35:43 The ESU01.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU01.dly, ESZ01.dly | 2019-03-04 15:35:43 The ESZ01.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ01.dly, ESH02.dly | 2019-03-04 15:35:43 The ESH02.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH02.dly, ESM02.dly | 2019-03-04 15:35:43 The ESM02.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM02.dly, ESU02.dly | 2019-03-04 15:35:43 The ESU02.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU02.dly, ESZ02.dly | 2019-03-04 15:35:43 The ESZ02.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ02.dly, ESH03.dly | 2019-03-04 15:35:43 The ESH03.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH03.dly, ESM03.dly | 2019-03-04 15:35:43 The ESM03.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM03.dly, ESU03.dly | 2019-03-04 15:35:43 The ESU03.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU03.dly, ESZ03.dly | 2019-03-04 15:35:43 The ESZ03.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ03.dly, ESH04.dly | 2019-03-04 15:35:43 The ESH04.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH04.dly, ESM04.dly | 2019-03-04 15:35:43 The ESM04.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM04.dly, ESU04.dly | 2019-03-04 15:35:43 The ESU04.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU04.dly, ESZ04.dly | 2019-03-04 15:35:43 The ESZ04.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ04.dly, ESH05.dly | 2019-03-04 15:35:43 The ESH05.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH05.dly, ESM05.dly | 2019-03-04 15:35:43 The ESM05.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM05.dly, ESU05.dly | 2019-03-04 15:35:43 The ESU05.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU05.dly, ESZ05.dly | 2019-03-04 15:35:43 The ESZ05.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ05.dly, ESH06.dly | 2019-03-04 15:35:43 The ESH06.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH06.dly, ESM06.dly | 2019-03-04 15:35:43 The ESM06.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM06.dly, ESU06.dly | 2019-03-04 15:35:43 The ESU06.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU06.dly, ESZ06.dly | 2019-03-04 15:35:43 The ESZ06.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ06.dly, ESH07.dly | 2019-03-04 15:35:43 The ESH07.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH07.dly, ESM07.dly | 2019-03-04 15:35:43 The ESM07.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM07.dly, ESU07.dly | 2019-03-04 15:35:43 The ESU07.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU07.dly, ESZ07.dly | 2019-03-04 15:35:43 The ESZ07.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ07.dly, ESH08.dly | 2019-03-04 15:35:43 The ESH08.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH08.dly, ESM08.dly | 2019-03-04 15:35:43 The ESM08.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM08.dly, ESU08.dly | 2019-03-04 15:35:43 The ESU08.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU08.dly, ESZ08.dly | 2019-03-04 15:35:43 The ESZ08.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ08.dly, ESH09.dly | 2019-03-04 15:35:43 The ESH09.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH09.dly, ESM09.dly | 2019-03-04 15:35:43 The ESM09.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM09.dly, ESU09.dly | 2019-03-04 15:35:43 The ESU09.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU09.dly, ESZ09.dly | 2019-03-04 15:35:43 The ESZ09.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ09.dly, ESH10.dly | 2019-03-04 15:35:43 The ESH10.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH10.dly, ESM10.dly | 2019-03-04 15:35:43 The ESM10.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM10.dly, ESU10.dly | 2019-03-04 15:35:43 The ESU10.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU10.dly, ESZ10.dly | 2019-03-04 15:35:43 The ESZ10.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ10.dly, ESH11.dly | 2019-03-04 15:35:43 The ESH11.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH11.dly, ESM11.dly | 2019-03-04 15:35:43 The ESM11.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM11.dly, ESU11.dly | 2019-03-04 15:35:43 The ESU11.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU11.dly, ESZ11.dly | 2019-03-04 15:35:43 The ESZ11.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ11.dly, ESH12.dly | 2019-03-04 15:35:43 The ESH12.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH12.dly, ESM12.dly | 2019-03-04 15:35:43 The ESM12.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM12.dly, ESU12.dly | 2019-03-04 15:35:43 The ESU12.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU12.dly, ESZ12.dly | 2019-03-04 15:35:43 The ESZ12.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ12.dly, ESH13.dly | 2019-03-04 15:35:43 The ESH13.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH13.dly, ESM13.dly | 2019-03-04 15:35:43 The ESM13.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM13.dly, ESU13.dly | 2019-03-04 15:35:43 The ESU13.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU13.dly, ESZ13.dly | 2019-03-04 15:35:43 The ESZ13.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ13.dly, ESH14.dly | 2019-03-04 15:35:43 The ESH14.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH14.dly, ESM14.dly | 2019-03-04 15:35:43 The ESM14.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM14.dly, ESU14.dly | 2019-03-04 15:35:43 The ESU14.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU14.dly, ESZ14.dly | 2019-03-04 15:35:43 The ESZ14.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESZ14.dly, ESH15.dly | 2019-03-04 15:35:43 The ESH15.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESH15.dly, ESM15.dly | 2019-03-04 15:35:43 The ESM15.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESM15.dly, ESU15.dly | 2019-03-04 15:35:43 The ESU15.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 Unable to determine transition date based on volume from files: ESU15.dly, ESZ15.dly | 2019-03-04 15:35:43 The ESZ15.dly symbol may not be the active contract month. | 2019-03-04 15:35:43 After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog |
[2019-03-05 02:42:15] |
This is the problem: HD Request # 249 | Error downloading historical Daily data for ESU12. Not downloading any data. Maximum downloads exceeded for the day. Limit: 200 | 2019-03-04 15:35:42
You will need a direct account to have a higher limit: Direct Sierra Chart Account Later on we will give users a new option to pay for more historical daily data queries per day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-11 14:52:56] |
User569009 - Posts: 8 |
TS Support: I understand my SC account through my broker is a "trial account" and that I am limited to historical data of 200 downloads/day. You have clarified this in your links above as the primary reason why I can not achieve historic chart data pre-2015. Having followed your instructions above my initial challenge remains, I can not achieve historic data up to 7000 days. I currently now am limited to approx 12/27/15 for my monthly historic charts. My most recent message log is attached and indicates 2 primary repeating outcomes for historic charts (example symbol SI): 1/ Unable to determine transition date based on volume from files: SIN15.dly, SIU15.dly | 2019-03-11 10:04:05, 2/The SIU15.dly symbol may not be the active contract month. | 2019-03-11 10:04:05 Kindly advise. |
Private File |
[2019-03-12 22:44:42] |
You need to re-download the data as explained here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data And if you are continuing to get a daily download limit, then we do plan an option to purchase additional queries to overcome that. Or just have a direct account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-12 22:45:04
