Date/Time: Wed, 29 Jun 2022 15:44:53 +0000
Move TP to break even
View Count: 177
[2022-05-11 16:13:22] |
User308424 - Posts: 42 |
Hi there, I know there is a possibility to make a shortcut button to move SL to break even. What about moving take profit to break even? If I have volatile market which goes slightly against me and if I press move SL to break even then it will move the SL to the breakeven but I will no longer have a SL order securing me from further movement against me. Lest say I place a trade and market goes 5 ticks against me. I have SL at 10 ticks and TP at 20 ticks. When I press button to move SL to break even then my trade will be closed only when price reaches my break even price lvl. If price will continue to go against me I have no further stop loss order to close the trade. If I would be able to move take profit to break even, and price is again 5 ticks against me then I am secured with my SL at 10 ticks and I can hope for price to return to my break even lvl and close the trade at that lvl. Dear Sierra Chart Support, will be able to assist here? Thanks |
[2022-05-11 17:46:00] |
John - SC Support - Posts: 17020 |
There is not a shortcut to do what you want directly. But, you can use the Trade Management by Study to do what you want, but it will take a few extra steps. In particular, you would have to use another study to define the level at which you want the Target to move to (such as a Spreadsheet Formula, or the Horizontal Lines studies) and then reference that line in the Trade Management by Study. Then you could setup a Control Bar button for the Trade Management by Study to Enable it when you want to move the Target. Refer to the information at the following link for how to use the Trade Management by Study study: Attached Orders: Study Controlled Targets and Stops For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-12 08:56:29] |
Hello John, thank you for explanation. Would you tell me what I do wrong as this seems does not work for me. I used study Trading: Avarage price study as a basis. It draws a line at average price following the new orders that I place. It seems to be aligned with break/even line that I see when I place a trades. Then I add Trade Management by Study and set it to enabled. And make a reference to my study Avarage price. I add then the trade management study to my control bar. I expected that once I have some orders placed with bracket order for SL and TP and I enable the study then my Take profit lvl will be immediately adjusted to the value from the avarage price study. But it does not work... I add screenshot from Trade Management Study. Will you be so kind and check what do I do wrong? Thank you |
Attachment Deleted. ![]() |
[2022-05-12 14:54:10] |
Everything looks good. The only item of note is that you do not want to "Enable" the study until you are ready to move the Targets to the line. That is what the Control Bar button will do, it will Enable the study and then the targets will move. From what you are showing, your Targets should be moving immediately when you add the study, or vice versa, depending on which one is entered first. Make sure the study is working without the Control Bar Button first. Then add the control bar button functionality - that way you can determine where the issue lies. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-14 13:03:24] |
Hey John, unfortunately I cannot achieve what we are talking about. I tried to change all parameters in Trade Management Study but it does not move my TP according to the lvl from Trading: position average price study. I tried to add study before an order execution and vice versa. I tried to execute it on the bar close or after N seconds. I allowed negative values. I also tried to change attached order group from nearest to OCO 1 (my TP and SL are saved in OCO group 1). None of that worked :/ I was thinking that maybe baseline study is wrong (but I think Trading: Average price study should be absolutely fine for that). I am not that much into formulas so I did not try spreadsheet formula. Any hints that might help to make it work? Thanks in advance |
[2022-05-16 16:04:00] |
The Trading: Position Average Price study can work as the reference for the Trade Management by Study study. Just make sure you are referencing that particular study in the Controlling Subgraph Reference Input on the Trade Management by Study. You may also want to set the Trailing Offset to 0, which will move the Target to the exact value of the Position Average Price. The steps you would want to follow would be to setup the studies but keep the Trade Management by Study Input for Enabled set to No. Then when you have a position open and you want to move the target, then set the Enabled to Yes and after the set number of seconds (assuming you are using seconds to define the time for the update) the target should move to the Position Average Price. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-16 17:44:32] |
Hey John, this is exactly what I do... and it does not work... Controling Subgraph reference in Trade Management by study is Trading: Position Avarage price. Order Type to manage: targets I am set to adjust order in seconds, adjustment frequency is set to 1. Trailing offset is 0. Allowed zero and negative values is set to no (buy it did not work with yes too) Is there any other setting which may overcontrol/prevent this? The instruction you gave me is very simple to implement. I just cant get it working... for some reason. Would you agree that setting of a trade management by study is correct?? (see attached picture please). Thanks |
Attachment Deleted. |
[2022-05-16 21:16:09] |
Everything looks good in terms of the setup. This leads us to have to ask how you are adding the target Limit order? The Trade Management by Study only works with Attached Orders. If you are setting that target separate from the main order, then that would be why it is not adjusting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-17 05:53:57] |
Hey again John, I use basic bracket orders in OCO Group 1. I have them set up like this (see attachment). I do not add them after I place an order. They are added simultaneously with the order I place. I do however change them after they are added to the trade (I move SL and TP up and down depending on volatility and other factors) In Trade Management by Study I also tried to select parameter 'Attached orders to manage' from nearest to OCO Group 1. This did not help unfortunately. Any idea where to look further? Thanks in advance for your time and effort on helping me with this topic. Kind Regards. |
[2022-05-17 14:22:25] |
One more item to try. On the Trade Management by Study there is an Input for Detailed Logging. Please set this to Yes, then go through the process to put on a trade and enable the Trade Management by Study and wait a minute to ensure that enough time has passed. Then copy and paste your Message Log to this thread by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-17 15:11:27] |
Hey John, please see the log. At the moment of log generation Trade Management by Study is set to adjust orders 'Every N seconds' and value is set to 1. Log also says I have disabled auto trading. I enabled auto trading global and auto trading for chart and only then it worked. Unfortunately, Trade MAnagement by Study remains enabled after my bracket orders are closed and when I place new order it immediatly moves the TP bracket order to break even. Is there an option to disable the study automatically after the execution? Reading Internal Order ID file. | 2022-05-15 14:42:26.622 Reading Trade Orders file. | 2022-05-15 14:42:26.724 Reading Trade Positions file. | 2022-05-15 14:42:26.725 Reading Trade Account Data files. | 2022-05-15 14:42:26.725 UDPListener (2024). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2022-05-15 14:42:26.742 Software version: 2383 64-bit | 2022-05-15 14:42:26.743 OpenGL enabled (NVIDIA Corporation/NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2) | 2022-05-15 14:42:26.743 Primary Thread ID: 17904 | 2022-05-15 14:42:26.743 Usage end date: 2022-06-15 | 2022-05-15 14:42:26.743 Enabled for: Advanced Features 2. | 2022-05-15 14:42:26.743 Enabled for: Sierra Chart Historical Data Service. | 2022-05-15 14:42:26.743 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-05-15 14:42:26.743 Enabled for: Delayed Denali Exchange Data Feed. | 2022-05-15 14:42:26.743 Enabled for exchange2: fairx_exchange.data | 2022-05-15 14:42:26.743 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-05-15 14:42:26.743 Current selected Data/Trading service: DTC - Sub Instance | 2022-05-15 14:42:26.743 Custom symbol settings values: enabled | 2022-05-15 14:42:26.743 Chart Update Interval: 300 | 2022-05-15 14:42:26.743 Intraday Data Storage Time Unit: 0 | 2022-05-15 14:42:26.743 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-05-15 14:42:26.743 2022-05-15 19:42:26 Local computer time in UTC | 2022-05-15 14:42:26.743 2022-05-15 14:42:26 Local computer time in SC Time Zone | 2022-05-15 14:42:26.743 2022-05-15 19:42:26 Server time in UTC | 2022-05-15 14:42:26.743 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-05-15 14:42:26.743 Program path: D:\SierraChart\SierraChart2\ | 2022-05-15 14:42:26.743 Data Files path: D:\SierraChart\SierraChart2\Data\ | 2022-05-15 14:42:26.743 OS Version Number: 10.0 | 2022-05-15 14:42:26.744 Locale Setting: C | 2022-05-15 14:42:26.744 DLLs: horizontal_64.dll, sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2022-05-15 14:42:26.744 Allowed protected custom studies: SST_FreeBundle, zyp_download_free | 2022-05-15 14:42:26.744 Crash reporter started: true | 2022-05-15 14:42:26.744 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-05-15 14:42:26.772 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-05-15 14:42:26.876 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-05-15 14:42:26.876 Received 5 login tokens. | 2022-05-15 14:42:27.501 Files to Open on Startup | Opening file: SC2-10s.Cht | 2022-05-15 14:42:32.356 sst_FreeBundle.dll is not 64-bit | 2022-05-15 14:42:32.363 VersionNumber is 0 for sst_FreeBundle.dll | 2022-05-15 14:42:32.363 sst_FreeBundle_2151.dll is not 64-bit | 2022-05-15 14:42:32.363 VersionNumber is 0 for sst_FreeBundle_2151.dll | 2022-05-15 14:42:32.363 Loading DLL: D:\SierraChart\SierraChart2\Data\sst_FreeBundle.dll (sst_FreeBundle_64.dll). Handle: 66000000 | 2022-05-15 14:42:32.368 ESM22 10 Sec #1 | Reloading chart. | 2022-05-15 14:42:32.415 ESM22 500 Trades #2 | Reloading chart. | 2022-05-15 14:42:32.474 ESM22 2 Min #3 | Reloading chart. | 2022-05-15 14:42:32.508 Using symbol data fast lookup vector | 2022-05-15 14:42:32.730 Starting DelayedDownloadMonitoringTimer | 2022-05-15 14:42:32.730 Starting HDTimeoutTimer | 2022-05-15 14:42:32.730 Added historical Intraday data request for ESM22 to the queue. | 2022-05-15 14:42:32.730 Intraday data recording state for symbol ESM22 is set to download 'Pending'. | 2022-05-15 14:42:32.730 Triggering next historical data download in queue. | 2022-05-15 14:42:32.730 HD Request # 1 | Downloading Intraday chart data for ESM22 to the file ESM22.scid. Service: DTCSubInstance | 2022-05-15 14:42:32.730 HD Request # 1 | Download start date-time: 2022-05-13 15:59:59.000000. File last date-time: 2022-05-13 15:59:59.621008 | 2022-05-15 14:42:32.730 HD Request # 1 | Using server: 127.0.0.1 port 11098 | 2022-05-15 14:42:32.730 Socket (1) | Creating socket. | 2022-05-15 14:42:32.730 Socket (1) | New receive buffer size: 5242880 | 2022-05-15 14:42:32.730 Socket (1) | Connecting to IP: 127.0.0.1. | 2022-05-15 14:42:32.730 HD Request # 1 | Setting DTC encoding to Binary VLS | 2022-05-15 14:42:32.739 HD Request # 1 | Sending historical data logon request message. | 2022-05-15 14:42:32.739 HD Request # 1 | Requesting Intraday data. Start date-time: 2022-05-13 15:59:59. Record interval: 0. Symbol: ESM22 | 2022-05-15 14:42:32.739 HD Request # 1 | Data is being downloaded from a remote source. Download will start when this is done. | 2022-05-15 14:42:32.749 Loading market depth data. | 2022-05-15 14:42:34.327 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2022-05-15 14:42:34.510 DTC Client socket (2) | Creating socket. | 2022-05-15 14:42:34.510 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-05-15 14:42:34.510 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2022-05-15 14:42:34.510 DTC - Sub Instance | Network connection to server complete. | 2022-05-15 14:42:34.511 DTC - Sub Instance | Starting socket receive thread. | 2022-05-15 14:42:34.511 DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none | 2022-05-15 14:42:34.512 DTC - Sub Instance | Setting DTC encoding to Binary VLS | 2022-05-15 14:42:34.514 DTC - Sub Instance | Sending logon request message. | 2022-05-15 14:42:34.514 DTC - Sub Instance | Received logon response. | 2022-05-15 14:42:34.515 DTC - Sub Instance | Server Name: SC DTC Server. Build=41758. | 2022-05-15 14:42:34.515 DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 | 2022-05-15 14:42:34.515 DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=tradingevaluator_delayed.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2022-05-15 14:42:34.515 DTC - Sub Instance | Trading is supported. | 2022-05-15 14:42:34.515 DTC - Sub Instance | Order cancel and replace is supported. | 2022-05-15 14:42:34.515 DTC - Sub Instance | OCO Orders supported. | 2022-05-15 14:42:34.515 DTC - Sub Instance | Bracket Orders supported. | 2022-05-15 14:42:34.515 DTC - Sub Instance | Connected to server complete. | 2022-05-15 14:42:34.515 Real-time market depth file updates started for ESM22 | 2022-05-15 14:42:34.516 Opened cached Depth file: D:\SierraChart\SierraChart2\Data\MarketDepthData\ESM22.2022-05-15.depth | 2022-05-15 14:42:34.518 Triggering next historical data download in queue. | 2022-05-15 14:42:34.518 Triggering next historical data download in queue. | 2022-05-15 14:42:34.518 Triggering next historical data download in queue. | 2022-05-15 14:42:34.518 Triggering next historical data download in queue. | 2022-05-15 14:42:34.518 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2022-05-15 14:42:34.522 Checking for new symbol settings. Requested symbol settings MD5 for service code tradesimulation.dtctrading. Request ID: 1. | 2022-05-15 14:42:34.522 No download requests in the queue to start downloads for. | 2022-05-15 14:42:34.522 No download requests in the queue to start downloads for. | 2022-05-15 14:42:34.522 No download requests in the queue to start downloads for. | 2022-05-15 14:42:34.522 Using symbol data fast lookup vector | 2022-05-15 14:42:34.602 Trading Evaluator - Delayed | Starting real-time market data updates for: ESM22. ID: 1 | 2022-05-15 14:42:34.602 Trading Evaluator - Delayed | Requesting security definition data for: ESM22. ID: 1 | 2022-05-15 14:42:34.602 Requesting market depth updates for: ESM22 if supported. | 2022-05-15 14:42:34.602 Trading Evaluator - Delayed | Clearing market depth for ESM22 | 2022-05-15 14:42:34.604 Starting DelayedDownloadMonitoringTimer | 2022-05-15 14:42:34.607 Starting HDTimeoutTimer | 2022-05-15 14:42:34.607 Added historical Market depth data request for ESM22 to the queue. | 2022-05-15 14:42:34.607 Market depth data recording state for symbol ESM22 is set to download 'Pending'. | 2022-05-15 14:42:34.607 Triggering next historical data download in queue. | 2022-05-15 14:42:34.607 Trading Evaluator - Delayed | Clearing market depth for ESM22 | 2022-05-15 14:42:34.607 Trading Evaluator - Delayed | Received security definition for symbol ESM22 | 2022-05-15 14:42:34.607 HD Request # 2 | Downloading Market depth data for ESM22. Service: cme.marketdepth | 2022-05-15 14:42:34.607 HD Request # 2 | Download start date-time: 2022-05-15 14:42:34.516503. | 2022-05-15 14:42:34.610 HD Request # 2 | Using server: ds21.sierracharts.com port 10150 | 2022-05-15 14:42:34.610 Socket (4) | Creating socket. | 2022-05-15 14:42:34.611 Socket (4) | New receive buffer size: 5242880 | 2022-05-15 14:42:34.611 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-05-15 14:42:34.611 Loading market depth data. | 2022-05-15 14:42:34.651 HD Request # 2 | Setting DTC encoding to Binary VLS | 2022-05-15 14:42:35.367 HD Request # 2 | Sending historical data logon request message. | 2022-05-15 14:42:35.367 HD Request # 2 | Requesting market depth data. Start date-time: 2022-05-15 14:42:34. Symbol: ESM22 | 2022-05-15 14:42:36.546 Socket (4) | CloseSocket call. | 2022-05-15 14:42:36.716 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-05-15 14:42:36.716 HD Request # 2 | Error downloading historical Market Depth data for ESM22. No market depth data files found. Path: I:\CME_Data\MarketDepthData/ | 2022-05-15 14:42:36.716 Historical data download thread signaled to stop. | 2022-05-15 14:42:36.716 HD Request # 2 | Received 0 Market depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESM22 | 2022-05-15 14:42:36.716 HD Request # 2 | Completion time: 2s | 2022-05-15 14:42:36.716 HD Request # 2 | Market depth data download complete for ESM22. Unique request ID: 2 | 2022-05-15 14:42:36.716 Removing historical data download ID 2. | 2022-05-15 14:42:36.716 Real-time market depth file updates started for ESM22 | 2022-05-15 14:42:36.716 Opened cached Depth file: D:\SierraChart\SierraChart2\Data\MarketDepthData\ESM22.2022-05-13.depth | 2022-05-15 14:42:36.717 Triggering next historical data download in queue. | 2022-05-15 14:42:36.717 No download requests in the queue to start downloads for. | 2022-05-15 14:42:36.717 Symbol settings MD5 received. Request ID: 1. | 2022-05-15 14:42:36.826 Symbol settings are up-to-date for tradesimulation.dtctrading. | 2022-05-15 14:42:36.826 Socket (4) | Socket gracefully closed by remote side. | 2022-05-15 14:42:36.878 Socket (4) | Closed. | 2022-05-15 14:42:36.878 Loading market depth data. | 2022-05-15 14:42:37.214 Loaded depth data records for ESM22 2022-05-03 from 2022-05-03 16:59:59.697000 to 2022-05-03 19:59:59.621000. | 2022-05-15 14:42:37.296 Loaded depth data records for ESM22 2022-05-10 from 2022-05-10 10:30:00.001000 to 2022-05-10 19:59:59.061000. | 2022-05-15 14:42:37.644 Loaded depth data records for ESM22 2022-05-09 from 2022-05-09 09:30:00.000000 to 2022-05-09 19:59:59.986000. | 2022-05-15 14:42:38.073 Loaded depth data records for ESM22 2022-05-04 from 2022-05-03 20:00:00.003000 to 2022-05-04 19:59:54.927000. | 2022-05-15 14:42:40.185 HD Request # 1 | Decompressing data. | 2022-05-15 14:42:41.747 HD Request # 1 | Receiving Intraday data for ESM22 starting at 2022-05-13 15:59:59.177000 | 2022-05-15 14:42:41.748 Socket (1) | CloseSocket call. | 2022-05-15 14:42:41.748 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-05-15 14:42:41.748 Historical data download thread signaled to stop. | 2022-05-15 14:42:41.748 HD Request # 1 | Received 15 Intraday data records from 2022-05-13 15:59:59.177000 to 2022-05-13 15:59:59.621008 (0.4 seconds) and wrote 0 records for ESM22 | 2022-05-15 14:42:41.748 HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2022-05-13 20:59:59.621008 | 2022-05-15 14:42:41.748 Socket (1) | Socket gracefully closed by remote side. | 2022-05-15 14:42:41.748 Socket (1) | Closed. | 2022-05-15 14:42:41.748 HD Request # 1 | Completion time: 9s | 2022-05-15 14:42:41.748 HD Request # 1 | Intraday data download complete for ESM22. Unique request ID: 1 | 2022-05-15 14:42:41.748 Removing historical data download ID 1. | 2022-05-15 14:42:41.748 Real-time Intraday chart data file updates started for ESM22 | 2022-05-15 14:42:41.748 Intraday chart data file opened for ESM22 | 2022-05-15 14:42:41.748 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2022-05-15 14:42:41.748 Triggering next historical data download in queue. | 2022-05-15 14:42:41.748 Initiating new historical data download for ESM22 to get the latest data since the download was started while not connected to primary service. | 2022-05-15 14:42:41.748 Added historical Intraday data request for ESM22 to the queue. | 2022-05-15 14:42:41.748 Intraday data recording state for symbol ESM22 is set to download 'Pending'. | 2022-05-15 14:42:41.748 HD Request # 3 | Downloading Intraday chart data for ESM22 to the file ESM22.scid. Service: cme | 2022-05-15 14:42:41.749 HD Request # 3 | Download start date-time: 2022-05-13 15:59:59.000000. File last date-time: 2022-05-13 15:59:59.621008 | 2022-05-15 14:42:41.749 HD Request # 3 | Using server: ds21.sierracharts.com port 10149 | 2022-05-15 14:42:41.749 Socket (1) | Creating socket. | 2022-05-15 14:42:41.749 Socket (1) | New receive buffer size: 5242880 | 2022-05-15 14:42:41.749 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-05-15 14:42:41.749 Loaded depth data records for ESM22 2022-05-11 from 2022-05-10 20:00:00.003000 to 2022-05-11 19:59:59.967000. | 2022-05-15 14:42:41.968 HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-05-15 14:42:42.162 HD Request # 3 | Sending historical data logon request message. | 2022-05-15 14:42:42.162 HD Request # 3 | Requesting Intraday data. Start date-time: 2022-05-13 15:59:59. Record interval: 0. Symbol: ESM22 | 2022-05-15 14:42:42.771 HD Request # 3 | Decompressing data. | 2022-05-15 14:42:42.936 HD Request # 3 | Receiving Intraday data for ESM22 starting at 2022-05-13 15:59:59.177000 | 2022-05-15 14:42:42.937 Socket (1) | CloseSocket call. | 2022-05-15 14:42:42.937 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-05-15 14:42:42.937 Historical data download thread signaled to stop. | 2022-05-15 14:42:42.937 HD Request # 3 | Received 15 Intraday data records from 2022-05-13 15:59:59.177000 to 2022-05-13 15:59:59.621008 (0.4 seconds) and wrote 0 records for ESM22 | 2022-05-15 14:42:42.937 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2022-05-13 20:59:59.621008 | 2022-05-15 14:42:42.938 HD Request # 3 | Completion time: 1s | 2022-05-15 14:42:42.938 HD Request # 3 | Intraday data download complete for ESM22. Unique request ID: 3 | 2022-05-15 14:42:42.938 Removing historical data download ID 3. | 2022-05-15 14:42:42.938 Real-time Intraday chart data file updates started for ESM22 | 2022-05-15 14:42:42.938 Intraday chart data file opened for ESM22 | 2022-05-15 14:42:42.938 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-05-15 14:42:42.938 Triggering next historical data download in queue. | 2022-05-15 14:42:42.938 No download requests in the queue to start downloads for. | 2022-05-15 14:42:42.938 Loaded depth data records for ESM22 2022-05-10 from 2022-05-09 20:00:00.002000 to 2022-05-10 19:59:59.061000. | 2022-05-15 14:42:43.039 Socket (1) | Socket gracefully closed by remote side. | 2022-05-15 14:42:43.104 Socket (1) | Closed. | 2022-05-15 14:42:43.104 Loaded depth data records for ESM22 2022-05-05 from 2022-05-04 20:00:00.000000 to 2022-05-05 19:59:59.988000. | 2022-05-15 14:42:44.139 Loaded depth data records for ESM22 2022-05-12 from 2022-05-11 20:00:00.003000 to 2022-05-12 19:59:59.990000. | 2022-05-15 14:42:47.062 Loaded depth data records for ESM22 2022-05-11 from 2022-05-10 20:00:00.003000 to 2022-05-11 19:59:59.967000. | 2022-05-15 14:42:47.627 Loaded depth data records for ESM22 2022-05-06 from 2022-05-05 20:00:00.003000 to 2022-05-06 17:00:00.064000. | 2022-05-15 14:42:48.822 Loaded depth data records for ESM22 2022-05-08 from 2022-05-08 17:00:00.181000 to 2022-05-08 19:59:59.973000. | 2022-05-15 14:42:48.895 Loaded depth data records for ESM22 2022-05-13 from 2022-05-12 20:00:00.002000 to 2022-05-13 16:03:05.613038. | 2022-05-15 14:42:49.975 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-15 14:42:49.977 ESM22 500 Trades #2 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-15 14:42:49.995 Chart: ESM22 500 Trades #2 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-15 14:42:49.995 Loaded depth data records for ESM22 2022-05-09 from 2022-05-08 20:00:00.006000 to 2022-05-09 19:59:59.986000. | 2022-05-15 14:42:52.364 Loaded depth data records for ESM22 2022-05-12 from 2022-05-11 20:00:00.003000 to 2022-05-12 19:59:59.990000. | 2022-05-15 14:42:52.797 Loaded depth data records for ESM22 2022-05-13 from 2022-05-12 20:00:00.002000 to 2022-05-13 16:03:05.613038. | 2022-05-15 14:42:55.624 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-15 14:42:55.625 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-15 14:42:55.661 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-15 14:42:55.661 Loaded depth data records for ESM22 2022-05-10 from 2022-05-09 20:00:00.002000 to 2022-05-10 19:59:59.061000. | 2022-05-15 14:42:56.269 Loaded depth data records for ESM22 2022-05-11 from 2022-05-10 20:00:00.003000 to 2022-05-11 19:59:59.967000. | 2022-05-15 14:42:59.608 Loaded depth data records for ESM22 2022-05-12 from 2022-05-11 20:00:00.003000 to 2022-05-12 19:59:59.990000. | 2022-05-15 14:43:03.539 Loaded depth data records for ESM22 2022-05-13 from 2022-05-12 20:00:00.002000 to 2022-05-13 16:03:05.613038. | 2022-05-15 14:43:05.713 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-15 14:43:05.714 ESM22 2 Min #3 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-15 14:43:05.734 Chart: ESM22 2 Min #3 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-15 14:43:05.734 Notice: Detected that the system has resumed from a low-power state. | 2022-05-16 01:12:08.759 Re-connecting to the Data/Trading service. | 2022-05-16 01:12:08.759 Trading Evaluator - Delayed | Waiting for socket receive thread to end | 2022-05-16 01:12:08.771 DTC Client socket (2) | CloseSocket call. | 2022-05-16 01:12:08.772 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-05-16 01:12:08.772 Trading Evaluator - Delayed | Disconnected. | 2022-05-16 01:12:08.773 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-05-16 01:12:08.774 Trading Evaluator - Delayed | Connecting to the server 127.0.0.1. Port 11099 | 2022-05-16 01:12:10.773 DTC Client socket (1) | Creating socket. | 2022-05-16 01:12:10.773 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-05-16 01:12:10.774 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2022-05-16 01:12:10.774 Trading Evaluator - Delayed | Network connection to server complete. | 2022-05-16 01:12:10.775 Trading Evaluator - Delayed | Starting socket receive thread. | 2022-05-16 01:12:10.775 Trading Evaluator - Delayed | Sending encoding request to server: Binary VLS. Compression: none | 2022-05-16 01:12:10.776 Trading Evaluator - Delayed | Setting DTC encoding to Binary VLS | 2022-05-16 01:12:10.778 Trading Evaluator - Delayed | Sending logon request message. | 2022-05-16 01:12:10.778 Trading Evaluator - Delayed | Received logon response. | 2022-05-16 01:12:10.779 Trading Evaluator - Delayed | Server Name: SC DTC Server. Build=41758. | 2022-05-16 01:12:10.779 Trading Evaluator - Delayed | Server protocol version: 8. Client protocol version: 8 | 2022-05-16 01:12:10.779 Trading Evaluator - Delayed | Successfully connected. Connected to SC DTC Protocol server. Service=tradingevaluator_delayed.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2022-05-16 01:12:10.779 Trading Evaluator - Delayed | Trading is supported. | 2022-05-16 01:12:10.779 Trading Evaluator - Delayed | Order cancel and replace is supported. | 2022-05-16 01:12:10.779 Trading Evaluator - Delayed | OCO Orders supported. | 2022-05-16 01:12:10.779 Trading Evaluator - Delayed | Bracket Orders supported. | 2022-05-16 01:12:10.779 Trading Evaluator - Delayed | Connected to server complete. | 2022-05-16 01:12:10.779 Triggering next historical data download in queue. | 2022-05-16 01:12:10.779 Triggering next historical data download in queue. | 2022-05-16 01:12:10.779 Triggering next historical data download in queue. | 2022-05-16 01:12:10.779 Triggering next historical data download in queue. | 2022-05-16 01:12:10.779 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2022-05-16 01:12:10.780 Checking for new symbol settings. Requested symbol settings MD5 for service code tradesimulation.dtctrading. Request ID: 2. | 2022-05-16 01:12:10.786 No download requests in the queue to start downloads for. | 2022-05-16 01:12:10.786 No download requests in the queue to start downloads for. | 2022-05-16 01:12:10.786 No download requests in the queue to start downloads for. | 2022-05-16 01:12:10.786 No download requests in the queue to start downloads for. | 2022-05-16 01:12:10.786 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Using previously cached IP address because unable to resolve domain name | 2022-05-16 01:12:10.786 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Connect event error. Windows error code 10065: A socket operation was attempted to an unreachable host. | 2022-05-16 01:12:10.787 Request for symbol settings MD5 finished unsuccessfully. Request ID: 2. Socket connection closed during the connection attempt. | 2022-05-16 01:12:10.787 Using symbol data fast lookup vector | 2022-05-16 01:12:10.946 Trading Evaluator - Delayed | Starting real-time market data updates for: ESM22. ID: 1 | 2022-05-16 01:12:10.946 Trading Evaluator - Delayed | Requesting security definition data for: ESM22. ID: 1 | 2022-05-16 01:12:10.946 Requesting market depth updates for: ESM22 if supported. | 2022-05-16 01:12:10.946 Added historical Intraday data request for ESM22 to the queue. | 2022-05-16 01:12:10.946 Intraday data recording state for symbol ESM22 is set to download 'Pending'. | 2022-05-16 01:12:10.946 Triggering next historical data download in queue. | 2022-05-16 01:12:10.946 Delaying start of download for ESM22 | 2022-05-16 01:12:10.948 Trading Evaluator - Delayed | Market data feed reported to be restored. | 2022-05-16 01:12:18.136 Trading Evaluator - Delayed | Real-time data for symbol ESM22 has been restored. | 2022-05-16 01:12:18.386 Trading Evaluator - Delayed | Clearing market depth for ESM22 | 2022-05-16 01:12:18.386 Added historical Market depth data request for ESM22 to the queue. | 2022-05-16 01:12:18.386 Market depth data recording state for symbol ESM22 is set to download 'Pending'. | 2022-05-16 01:12:18.386 Triggering next historical data download in queue. | 2022-05-16 01:12:18.386 HD Request # 4 | Downloading Market depth data for ESM22. Service: cme.marketdepth | 2022-05-16 01:12:18.386 HD Request # 4 | Download start date-time: 2022-05-15 14:42:34.516503. | 2022-05-16 01:12:18.387 HD Request # 4 | Using server: ds23.sierracharts.com port 10149 | 2022-05-16 01:12:18.387 Trading Evaluator - Delayed | Received security definition for symbol ESM22 | 2022-05-16 01:12:18.387 Socket (3) | Creating socket. | 2022-05-16 01:12:18.426 Socket (3) | New receive buffer size: 5242880 | 2022-05-16 01:12:18.426 Socket (3) | Connecting to IP: 216.1.90.130. | 2022-05-16 01:12:18.426 HD Request # 4 | Setting DTC encoding to Binary VLS | 2022-05-16 01:12:18.738 HD Request # 4 | Sending historical data logon request message. | 2022-05-16 01:12:18.738 HD Request # 4 | Requesting market depth data. Start date-time: 2022-05-15 14:42:34. Symbol: ESM22 | 2022-05-16 01:12:19.352 HD Request # 4 | Decompressing data. | 2022-05-16 01:12:19.506 HD Request # 4 | Receiving market depth data for ESM22 starting at 2022-05-15 16:00:00.179000 | 2022-05-16 01:12:19.847 HD Request # 4 | Timestamp of first market depth data file record written: 2022-05-15 16:00:00.179000 | 2022-05-16 01:12:20.503 Trading Evaluator - Delayed | Real-time data for symbol ESM22 has been restored. | 2022-05-16 01:12:21.328 Trading Evaluator - Delayed | Clearing market depth for ESM22 | 2022-05-16 01:12:21.329 Trading Evaluator - Delayed | Received security definition for symbol ESM22 | 2022-05-16 01:12:21.902 HD Request # 5 | Downloading Intraday chart data for ESM22 to the file ESM22.scid. Service: cme | 2022-05-16 01:12:23.445 HD Request # 5 | Download start date-time: 2022-05-13 15:59:59.000000. File last date-time: 2022-05-13 15:59:59.621008 | 2022-05-16 01:12:23.445 HD Request # 5 | Using server: ds23.sierracharts.com port 10150 | 2022-05-16 01:12:23.446 Socket (4) | Creating socket. | 2022-05-16 01:12:23.446 Socket (4) | New receive buffer size: 5242880 | 2022-05-16 01:12:23.446 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-05-16 01:12:23.446 HD Request # 5 | Setting DTC encoding to Binary VLS | 2022-05-16 01:12:23.779 HD Request # 5 | Sending historical data logon request message. | 2022-05-16 01:12:23.779 HD Request # 5 | Requesting Intraday data. Start date-time: 2022-05-13 15:59:59. Record interval: 0. Symbol: ESM22 | 2022-05-16 01:12:24.400 Socket (3) | CloseSocket call. | 2022-05-16 01:12:24.512 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-05-16 01:12:24.512 Historical data download thread signaled to stop. | 2022-05-16 01:12:24.512 HD Request # 4 | Received 1277330 Market depth data records from 2022-05-15 16:00:00.179000 to 2022-05-16 01:02:23.233000 (9.0 hours) and wrote 1277330 records for ESM22 | 2022-05-16 01:12:24.513 HD Request # 4 | Completion time: 6s | 2022-05-16 01:12:24.513 HD Request # 4 | Market depth data download complete for ESM22. Unique request ID: 5 | 2022-05-16 01:12:24.513 Removing historical data download ID 5. | 2022-05-16 01:12:24.513 Real-time market depth file updates started for ESM22 | 2022-05-16 01:12:24.513 Enabling compression for file: D:\SierraChart\SierraChart2\Data\MarketDepthData\ESM22.2022-05-16.depth. This may take a while. | 2022-05-16 01:12:24.513 File compression enabled. D:\SierraChart\SierraChart2\Data\MarketDepthData\ESM22.2022-05-16.depth. CompressionState=0 | 2022-05-16 01:12:24.513 Opened cached Depth file: D:\SierraChart\SierraChart2\Data\MarketDepthData\ESM22.2022-05-16.depth | 2022-05-16 01:12:24.535 HD Request # 5 | Decompressing data. | 2022-05-16 01:12:24.537 Triggering next historical data download in queue. | 2022-05-16 01:12:24.546 No download requests in the queue to start downloads for. | 2022-05-16 01:12:24.546 Socket (3) | Socket gracefully closed by remote side. | 2022-05-16 01:12:24.663 Socket (3) | Closed. | 2022-05-16 01:12:24.663 Opened cached Depth file: D:\SierraChart\SierraChart2\Data\MarketDepthData\ESM22.2022-05-16.depth | 2022-05-16 01:12:24.728 HD Request # 5 | Receiving Intraday data for ESM22 starting at 2022-05-13 15:59:59.177000 | 2022-05-16 01:12:24.847 HD Request # 5 | Timestamp of first Intraday data file record written: 2022-05-15 17:00:00.000000 | 2022-05-16 01:12:25.482 Socket (4) | CloseSocket call. | 2022-05-16 01:12:25.505 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-05-16 01:12:25.505 Historical data download thread signaled to stop. | 2022-05-16 01:12:25.505 HD Request # 5 | Received 103353 Intraday data records from 2022-05-13 15:59:59.177000 to 2022-05-16 01:02:23.233001 (2.4 days) and wrote 103338 records for ESM22 | 2022-05-16 01:12:25.505 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2022-05-16 06:02:23.233001 | 2022-05-16 01:12:25.506 HD Request # 5 | Completion time: 2s | 2022-05-16 01:12:25.506 HD Request # 5 | Intraday data download complete for ESM22. Unique request ID: 4 | 2022-05-16 01:12:25.506 Removing historical data download ID 4. | 2022-05-16 01:12:25.506 Real-time Intraday chart data file updates started for ESM22 | 2022-05-16 01:12:25.506 Intraday chart data file opened for ESM22 | 2022-05-16 01:12:25.506 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2022-05-16 01:12:25.506 Triggering next historical data download in queue. | 2022-05-16 01:12:25.506 No download requests in the queue to start downloads for. | 2022-05-16 01:12:25.506 Socket (4) | Socket gracefully closed by remote side. | 2022-05-16 01:12:25.673 Socket (4) | Closed. | 2022-05-16 01:12:25.673 Opened cached Intraday file: D:\SierraChart\SierraChart2\Data\ESM22.scid. Thread ID: 18924 | 2022-05-16 01:12:26.303 Sierra Chart account data changed. Requesting updated account information. | 2022-05-16 01:13:08.755 Successfully processed Sierra Chart account data. | 2022-05-16 01:13:09.428 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-05-16 01:14:12.703 DTC Client socket (2) | Closed. | 2022-05-16 01:14:12.703 DTC Client socket (2) | Deleting network socket now after delay. | 2022-05-16 01:14:42.717 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:47:44.176 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:47:44.176 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:47:44.220 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:47:44.220 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:47:48.169 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:47:48.169 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:47:48.210 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:47:48.210 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:47:51.575 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:47:51.575 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:47:54.139 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:47:54.139 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:47:54.180 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:47:54.180 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:48:14.104 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:48:14.104 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:48:20.342 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:48:20.342 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:48:20.383 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:48:20.383 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:49:25.305 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:49:25.305 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:50:12.837 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:50:12.837 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 01:50:15.448 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 01:50:15.448 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 02:22:09.726 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 02:22:09.826 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 02:22:09.884 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:07:51.289 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:07:51.293 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:07:51.331 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:10:28.477 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:10:28.480 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:10:28.519 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:11:56.755 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:11:56.963 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:11:56.966 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:29:14.840 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:29:14.843 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:29:15.037 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:32:20.663 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:32:20.772 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:32:21.548 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:37:06.287 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:37:06.326 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:37:06.381 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:38:09.161 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:38:09.255 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:38:09.412 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:43:57.227 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:43:57.231 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 03:43:57.269 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 04:15:21.073 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 04:15:21.287 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 04:15:21.383 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 04:17:43.164 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 04:17:43.167 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 04:17:43.206 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 04:26:42.162 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 04:26:42.225 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 04:26:42.229 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:01:08.519 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:01:08.788 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:01:08.791 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:35:17.100 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:35:17.103 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:35:17.142 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:36:21.787 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:36:21.884 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:36:21.887 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:42:59.914 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:42:59.958 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:42:59.961 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:58:44.914 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:58:44.958 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 05:58:44.961 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 06:45:39.289 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 06:45:39.293 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 06:45:39.752 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 06:58:39.747 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 06:58:39.748 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:01:37.176 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:01:37.179 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:01:37.218 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:05:23.039 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:05:23.042 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:05:23.081 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:11:38.039 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:11:38.083 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:11:38.086 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:38:53.976 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:38:53.982 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:38:54.020 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:41:32.837 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:41:33.040 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:41:33.046 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:44:04.599 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:44:04.645 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:44:04.650 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:50:58.086 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:50:58.351 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 07:50:58.412 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 08:16:39.601 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 08:16:39.607 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 08:16:39.645 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 08:41:46.052 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 08:41:46.052 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 08:52:47.725 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 08:52:47.788 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 08:52:48.231 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 08:53:32.923 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 08:53:33.038 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 08:53:33.133 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 09:02:48.099 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 09:02:48.099 ESM22 500 Trades #2 | Enable trading keyboard shortcuts with 'Trade >> Trading Keyboard Shortcuts Enabled'. | 2022-05-16 09:02:59.886 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:05:33.666 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:05:33.728 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:05:33.823 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:07:21.474 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:07:21.612 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:07:21.617 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:10:53.662 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:10:53.723 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:10:53.820 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:15:07.509 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:15:07.612 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:15:07.727 ESM22 500 Trades #2 | Enable trading keyboard shortcuts with 'Trade >> Trading Keyboard Shortcuts Enabled'. | 2022-05-16 09:31:00.773 ESM22 500 Trades #2 | Enable trading keyboard shortcuts with 'Trade >> Trading Keyboard Shortcuts Enabled'. | 2022-05-16 09:31:01.573 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:48:15.701 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:48:15.852 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:48:15.913 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:49:01.787 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:49:01.794 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:49:01.838 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:49:58.005 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:49:58.145 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:49:58.292 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:50:47.862 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:50:48.005 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:50:48.038 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:53:48.350 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:53:48.448 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:53:48.584 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:55:50.647 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:55:50.706 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:55:50.850 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:58:29.287 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:58:29.391 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 09:58:29.451 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:00:14.623 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:00:14.686 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:00:14.785 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:07:32.412 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:07:32.509 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:07:32.609 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:08:34.287 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:08:34.349 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:08:34.449 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:13:14.958 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:13:14.964 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:13:15.226 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:13:52.828 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:13:52.889 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:13:53.039 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:16:24.353 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:16:24.491 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:16:24.590 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:19:16.675 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:19:16.813 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:19:16.819 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:21:26.161 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:21:26.223 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:21:26.323 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:24:28.041 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:24:28.141 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:24:28.243 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:26:19.291 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:26:19.297 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 10:26:19.342 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 11:54:19.834 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 11:54:19.840 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 11:54:19.890 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 11:58:15.150 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 11:58:15.195 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 11:58:15.202 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 11:59:36.397 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 11:59:36.443 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 11:59:36.450 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:03:27.338 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:03:27.345 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:03:27.396 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:04:25.565 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:04:25.667 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:04:25.772 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:05:38.688 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:05:38.750 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:05:38.900 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:05:46.709 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:05:46.759 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:05:46.804 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:13:07.961 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:13:08.024 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:13:08.129 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:15:10.462 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:15:10.567 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:15:10.674 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:16:17.334 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:16:17.396 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:16:17.876 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:20:50.563 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:20:50.571 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:20:50.772 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:22:49.796 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:22:49.796 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:22:55.356 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:22:55.356 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:22:59.575 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:22:59.678 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:22:59.837 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:27:05.127 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:27:05.127 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:27:30.129 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:27:30.129 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:27:38.584 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:27:38.646 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:27:38.754 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:28:28.354 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:28:28.354 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:28:36.370 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:28:36.370 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:28:38.904 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:28:38.904 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:28:40.627 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:28:40.627 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:29:28.273 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:29:28.280 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:29:28.331 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:32:23.587 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:32:24.744 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:32:25.138 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:37:16.232 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:37:16.232 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:37:19.407 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:37:19.407 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:42:20.398 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:42:21.661 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:42:21.908 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:42:24.608 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:42:24.608 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-16 12:42:28.186 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-16 12:42:28.186 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:45:22.129 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:45:22.334 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-16 12:45:23.970 Opened cached Depth file: D:\SierraChart\SierraChart2\Data\MarketDepthData\ESM22.2022-05-17.depth | 2022-05-16 19:10:10.172 Enabling compression for file: D:\SierraChart\SierraChart2\Data\MarketDepthData\ESM22.2022-05-17.depth. This may take a while. | 2022-05-16 19:10:10.522 File compression enabled. D:\SierraChart\SierraChart2\Data\MarketDepthData\ESM22.2022-05-17.depth. CompressionState=0 | 2022-05-16 19:10:10.522 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 00:54:15.460 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 00:54:15.464 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 00:54:15.497 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-17 03:46:15.309 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-17 03:46:15.309 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 03:48:02.651 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 03:48:02.696 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 03:48:02.700 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 06:28:41.100 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 06:28:41.103 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 06:28:41.132 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 07:55:18.382 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 07:55:18.385 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 07:55:18.413 ESM22 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 08:05:35.569 ESM22 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 08:05:35.615 ESM22 2 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-05-17 08:05:35.618 ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Making HTTP request. | 2022-05-17 09:53:30.018 Chart: ESM22 10 Sec #1 | Study: Display Forex factory calendar news items - V2 (With Alerts) | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2022-05-17 09:53:30.018 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Study not enabled. | 2022-05-17 09:54:04.328 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Study not enabled. | 2022-05-17 09:54:08.253 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Study not enabled. | 2022-05-17 09:54:09.070 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Study not enabled. | 2022-05-17 09:54:10.424 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | There was an error modifying the Stop/Target order. Internal Order ID: 75414. New Price: 4035.750000. Error Code -8998. | 2022-05-17 09:54:59.587 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:00.290 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:00.600 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:01.227 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:01.538 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:02.478 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:02.789 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:03.413 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:03.702 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:04.830 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:05.626 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:06.106 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:07.189 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | There was an error modifying the Stop/Target order. Internal Order ID: 75414. New Price: 4035.750000. Error Code -8994. | 2022-05-17 09:55:09.085 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:09.351 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:10.244 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:11.145 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:11.519 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:11.650 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:12.580 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:12.820 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:13.863 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:14.140 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:15.186 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:15.328 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:16.267 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:16.683 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:17.625 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:17.819 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:18.561 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:18.873 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:19.809 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:20.007 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:20.742 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:21.057 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:21.941 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:22.307 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:23.839 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:24.085 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:24.884 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:25.125 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:25.944 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:26.369 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:26.995 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:27.305 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:28.244 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:28.445 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:29.384 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:29.805 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:30.744 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:31.053 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:31.991 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:32.305 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:32.890 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:33.188 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:34.181 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:34.382 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:35.635 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:35.945 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:36.995 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:37.194 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:38.134 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:38.554 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:39.694 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:40.010 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:41.053 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:41.256 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:41.885 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:42.193 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:43.244 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:43.444 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:44.069 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:44.385 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:45.317 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:45.932 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:46.749 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:47.577 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:47.790 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:48.342 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:49.150 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:49.979 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:50.291 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:50.604 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:51.538 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:51.851 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:52.790 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:53.101 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:54.041 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:55.005 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:55.625 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:55.913 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:56.539 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:57.107 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:57.822 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:58.318 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:55:58.757 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:55:59.180 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:00.117 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:00.319 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:01.370 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:01.570 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:02.619 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:02.822 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:03.552 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:03.867 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:04.805 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:05.009 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:05.720 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:06.056 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:06.990 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:07.196 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:08.134 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:08.554 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:09.491 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:09.807 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:10.742 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:10.944 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:11.882 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:12.377 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:13.445 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:13.758 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:14.696 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:15.116 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:16.260 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:16.680 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:17.510 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:17.823 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:18.500 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:18.866 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:19.807 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:20.113 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:20.946 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:21.259 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:22.194 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:22.619 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:23.239 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:23.557 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:24.386 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:24.807 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:25.688 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:26.053 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:26.886 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:27.197 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:28.133 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:28.607 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:29.441 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:29.805 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:30.636 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:31.061 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:31.992 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:32.491 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:33.416 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:33.726 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:34.667 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:34.977 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:35.914 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:36.242 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:37.163 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:37.671 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:38.417 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:38.728 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:39.665 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:39.975 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:40.915 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:41.227 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:42.167 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:42.477 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:43.101 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:43.415 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:44.384 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:44.664 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:45.288 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:45.601 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:46.853 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:47.164 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:48.101 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:48.416 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:49.351 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:49.663 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:50.288 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:50.600 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:51.540 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:51.852 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:52.475 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:52.790 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:53.725 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:54.041 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:54.976 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:55.289 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:56.230 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:56.539 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:57.165 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:57.478 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:58.414 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:58.725 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:56:59.350 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:56:59.666 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:00.617 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:00.914 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:02.164 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:02.475 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:03.414 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:03.726 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:04.747 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:05.056 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:05.684 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:05.942 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:06.877 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:07.246 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:08.128 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:08.497 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:09.489 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:09.863 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:10.744 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:10.970 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:11.884 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:12.305 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:13.230 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:13.495 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:14.122 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:14.637 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:15.320 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:15.741 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:16.255 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:16.570 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:17.615 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:17.929 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:18.869 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:19.179 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:20.010 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:20.429 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:21.368 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:21.682 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:22.251 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:22.506 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:23.448 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:23.760 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:24.805 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:25.005 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:26.258 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:26.574 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:27.305 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:27.615 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:28.242 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:28.447 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:30.007 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:30.430 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:31.647 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:31.991 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:32.821 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:33.134 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:34.383 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:34.696 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:35.320 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:35.630 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled. | 2022-05-17 09:57:36.573 Chart: ESM22 10 Sec #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2022-05-17 09:57:36.994 |
[2022-05-17 16:16:44] |
John - SC Support - Posts: 17020 |
Very good you figured out what the issue was. Unfortunately, Trade MAnagement by Study remains enabled after my bracket orders are closed and when I place new order it immediatly moves the TP bracket order to break even.
Is there an option to disable the study automatically after the execution? No, there is not an automatic way to disable the study, but that is what the Control Bar Button option is for. You can add a Control Bar Button to Enable and Disable the study. Refer to the information here: Attached Orders: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-17 16:38:42] |
User308424 - Posts: 42 |
Thank you John, appreciate your assistance with the topic. Have a great day.
