Date/Time: Fri, 26 Apr 2024 06:36:16 +0000
Chart not loading
View Count: 366
[2022-05-09 17:43:41] |
User293980 - Posts: 4 |
I choose a package, but maybe forget something. still not working. I would like to use ES 500 Cart, so data for it. So what should i do? Which steps should i take? Dont have any login data for Data service Settings. Maybe just dont know which to use.
Screenshot_3.png / V - Attached On 2022-05-09 17:42:05 UTC - Size: 79.47 KB - 84 views Screenshot_4.png / V - Attached On 2022-05-09 17:42:14 UTC - Size: 130.9 KB - 96 views |
[2022-05-09 17:51:57] |
John - SC Support - Posts: 31131 |
Do you have a live trading account? If so, what order routing service are you setup to use? Sierra Chart has support for CQG, Rithmic, Interactive Brokers, and the Teton Order Routing Service. Let us know if you are using one of these and then we can help you get connected. If you do not have a live trading account, then be aware of the requirement from the CME Group that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have a live trading account, then we recommend you use our Delayed Streaming Data while you are learning how to use Sierra Chart. Refer to the information here: Delayed Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-15 05:22:12] |
Is it possible to get money back for the Packege. Cause i will not use Sierra next timeand have 64 USD on the Service Surplus? Or is it possible to freesethe Surplus? Thank you
Screenshot_1.png / V - Attached On 2022-05-15 05:21:56 UTC - Size: 120.36 KB - 87 views Attachment Deleted. |
[2022-05-15 05:59:56] |
Yes we can do the refund but we think there was a misinterpretation about what you were asking about in post #1. We apologize for that. If you have a problem with the chart not loading at all we can help with that. Our response at post #2 was about obtaining real-time data. If you do not get any chart, then open a chart for this symbol: ESM22-CME Instructions: Getting Started, Opening Charts and Basic Trading: Open Chart Let us know that you are getting a chart for this symbol. You will be using the Delayed Exchange Data Feed: Delayed Exchange Data Feed: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-17 14:43:58] |
is it possible to freeze the the Payment for the later use of the Packege? If not can we do the refund?
[2022-05-17 15:46:02] |
We can not "freeze" the current monthly service. But we have set your account to not renew when this term is completed on June 4, 2022. The funds you have in your account will stay there as well. So when you are ready to come back, you just need to select your Service Package to get going again. When that occurs, refer to the following instructions: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
