Date/Time: Mon, 14 Jul 2025 21:08:22 +0000
Help!! activating Denali feed ..
View Count: 2837
[2022-03-19 16:23:54] |
User630795 - Posts: 93 |
Hi. I am currently trading Nasdaq Futures (NQ) with AMP account using CQG data feed. Today, I changed my SC package to use Denali data feed. I followed the instruction but I don't think my charts are using Denali data feed. I don't know what I need to do. Do I need to make any changes to "Dat/Trade Service Setting"? I did not make any change there. Yes, "Allow Support for Sierra Chart Data Feeds" was/is still set to "YES." I followed the instruction about downloading "Symbol Setting" download and "Delete All Data and Download." I'd appreciate your prompt help. I want this data feed to work properly before the market open. FYI, this is my first experience of changing data feed. Thank you. |
[2022-03-19 17:20:28] |
I just changed "Current Selected Service" in "Data/Trade Service Settings" to "SC Data - All Services [data]" and this seem to have fixed my problem. it is connecting to Denali data feed now. I have not notified AMP (broker) about this data feed switch yet. What do I need to tell AMP? At this point, would I be still using CQG order routing? FYI, I am in a process of setting up accounts with Edge Clear for eventual migration from AMP to them so I can ultimate use Teton order routing. Thank you. |
[2022-03-19 18:27:53] |
You did do everything correctly in post #1. For now you do have to have Sierra Chart set to connect to CQG. If there still is a problem: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. ---- What do I need to tell AMP? Tell them to cancel market data exchange fees for your account. At this point, would I be still using CQG order routing? Yes until you begin to use Teton through Edge Clear.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-19 18:29:23
[2022-03-19 20:50:12] |
after i switched to Denali data feed, looks like only 7 days worth of data are downloaded. all my (intraday) charts only load 7 days worth of data. what setting do i need to change to download more data? (I trade NQ)
[2022-03-19 20:59:54] |
never mind. i did "Edit => Delete All Data and Download" and it seems to have fixed it.
[2022-03-19 21:38:51] |
Ok very good. This is the relevant documentation: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-20 22:07:52] |
the market just opened but my charts are not moving. is something wrong with Denali data feed? fyi, i trad NQ.
[2022-03-20 22:12:05] |
You should be getting delayed data so you should at this moment start to see updating. For real-time data, complete the agreements here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements And activate the exchanges you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-20 22:14:45] |
You are getting delayed data. Not real time. Refer to our post #8 above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-20 22:37:18] |
never mind. just activated.... "The 'Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts' exchange has been internally activated, and will be renewed." but the dom is not showing full bid and ask quantities. only showing top 10 of each side even though i activated for the full deck. |
[2022-03-20 23:08:55] |
hello. can someone fix this? DOM is not showing full bid/ask quanitites |
[2022-03-20 23:41:04] |
You should only be seeing one level of depth on each side since you activated the top of book exchange fee. For the full market depth data, you need to activate the exchange fees that support Market Depth. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Adding Support for CME Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-20 23:41:28
[2022-03-20 23:43:31] |
that is what i activated. where do i go to fix this? |
[2022-03-20 23:46:00] |
You activated: Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts Instead you would want something like: CME with Market Depth for nonprofessional Trading accounts It depends upon what symbols you need Market Depth data for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-20 23:49:49] |
so, again, how do i correct this? i only trade NQ. |
[2022-03-21 00:11:08] |
i don't understand how this is better than CQG that I was using?
[2022-03-21 00:20:20] |
with CQG, i was getting 10 levels for $3.50/month for the same price you provide 1 level for full level CME data, you charge $11/month. ?? |
[2022-03-21 02:15:07] |
i love Sierra Chart. however, i don't like that you made changes to your program to make it difficult to use CQG data feed so you can have recurring revenue stream by directing your customers to use your data feed. I don't mind supporting SC by using your products (data feed and order routing) so I can continue to use your amazing platform. However, you should at least match CQG's prices. For $3.50/month, I was getting 10 levels but I only get 1 level with your data feed. I have to pay three times more to get more market depth. it is not a lot of money but i don't like the notion that you force customers to pay more for the product (data feed) after making it difficult to use CQG. well.... |
[2022-03-21 08:42:11] |
with CQG, i was getting 10 levels for $3.50/month This is absolutely false! You cannot get 10 levels of market depth data for this price. These are exchange fees billed by the CME. That price, is for the entire CME Group, type of book/Level 1 data.for the same price you provide 1 level This is absolutely false: For $3.50/month, I was getting 10 levels but I only get 1 level with your data feed. I have to pay three times more to get more market depth. it is not a lot of money but i don't like the notion that you force customers to pay more for the product (data feed) after making it difficult to use CQG. well.... If this is true, we are going to report CQG to the CME for violating CME rules but we know they are not doing that. It makes no sense. They would not do that.The exchange fees that you see here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Are from the CME with a small markup of about 3% typically. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-21 08:44:14
[2022-03-21 08:46:28] |
We have activated this exchange for you: CME with Market Depth for nonprofessional Trading accounts This will provide you real-time data for NQ with market depth data. There is no cost for the month of March and there will be a cost of 11 USD, effective in April 2022 and going forward until you cancel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-21 08:56:14] |
Being that Sierra Chart provides CME Group data directly from the exchange and delivers this data reliably, and comprehensively, it only makes sense that we do not support CME market data from any other source and only our own. This will provide our users the most reliable data, the most complete data (historical, Real-time, market depth, and market by order data), and consistent data. Our data feeds provide all of the data that Sierra Chart users require. Sierra Chart has extensive market data needs which cannot be met by CQG . Users will have less or no issues, and all users receive the same data. This is on a highly reliable and redundant network with multiple ISPs. It reduces our support load, gives users the best impression of Sierra Chart. It is foolish for us to be supporting CQG CME and EUREX data at all. And we will not do that and our position on this is very clear and firm. So we cannot accept the claims that you are making and if CQG is actually providing you market depth data with the fee that you are paying of about 3.50 USD per month, we are going to report them to the CME because they are violating their market data policies. Although we really do not think they are doing that and there is some other explanation here. And be sure to refer to our two posts above so they are not overlooked. Thank you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-21 09:02:37
