Date/Time: Wed, 01 May 2024 04:59:50 +0000
Adding bars high and low
View Count: 6092
[2021-04-09 16:58:57] |
User237543 - Posts: 71 |
Hi I want to plot lines showing the 10, 20, 50 bars’ High and Low, Pls advise how Like to use them as support and resistance levels on my main chart Thanks Amy |
[2021-04-09 18:26:09] |
John - SC Support - Posts: 31240 |
Refer to the following study: Highest High/Lowest Low Over N Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-10 11:26:44] |
Thanks so much! I managed to plot these lines, wonderful! however is there a way to cut the lines short just to show at around the last few bars. Now they go all the way back to the left of the chart and makes my chart very crowded with too manliness across it. thanks! |
[2021-04-10 14:50:55] |
Ackin - Posts: 1865 |
Hi, It's possible download it for free from our CZ/SK forum. Study: High/Low levels Contact: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free https://twitter.com/Zyp_sierra |
High Low levels.png / V - Attached On 2021-04-10 14:49:33 UTC - Size: 23.01 KB - 325 views |
[2021-04-16 17:38:24] |
I like to set up an Alert (a sound alert)when price moves near the threshold area of that ATR line, say within threshold of 4, then the sound alert will be trigged, like to show these threshold area in shaded colour too above and below the ATR line too. Pls advise how can I do that? Thanks so much |
[2021-04-16 19:36:40] |
Also be aware of the following draw style that is similar to what you ask:Chart Studies: Line Extend To Edge (ACSIL: DRAWSTYLE_LINE_EXTEND_TO_EDGE) I like to set up an Alert (a sound alert)when price moves near the threshold area of that ATR line
Refer to the following for Alerts:Study/Chart Alerts And Scanning like to show these threshold area in shaded colour too above and below the ATR line too.
We are not sure if you are asking to color this when the alert happens, or at all times.If you want to color based on the alert, then you would want to use the Color Bar Based on Alert Condition study. Refer to the following: Color Bar Based on Alert Condition If you are wanting to create a filled area between two lines, then refer to the following and the section after it: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-18 13:36:20] |
http://www.sierrachart.com/image.php?Image=1618752260748.png see attached screenshot can explain better what I like to do I like to create zones (shaded area in the chart pointed by green arrows) above and below the ATR lines, then set sound alerts, so that once prices reach these zones (eg at the red circles), a sound alert will be triggered, so that I will be alerted to look at price action pls advise how I can achieve this? thanks so much |
[2021-04-19 03:34:52] |
Sawtooth - Posts: 3987 |
Use the Bands/Envelope study: - Set the Based On to the study for the ATR lines. - Set the Input Value to its subgraph - Set the Draw Styles to the Transparent Top/Transparent Bottom pair. For alerts, use a formula like this on the Alerts tab of any study: =OR(AND(H[-1]<ID5.SG2[-1],H>ID5.SG2),AND(L[-1]>ID5.SG1[-1],L<ID5.SG2)) where the Bands/Envelope study is ID5. If you want to also color the bars at the alerts, put the formula on the Alerts tab of an instance of the Color Bar Based On Alert Condition study. |
[2021-04-20 11:30:29] |
Thanks for all the help. I have been setting alert for Moving averages, and want to be alerted when the eg 13 ema is above 34 ema , so I input alert condition as IDx.SG1>IDx.SG2, ID being the moving average study , SG1 being 13, and SG2 being 34 However the alert sound trigger keeps repeating , while the condition remains true... so quite noisy all the time. I like to set the alert to sound only once the condition set is true the first instance , and only for that once, and not repeating while the condition remains true. Where can I set this criteria ? Thanks! |
[2021-04-20 16:46:20] |
In general, an alert only goes off when it goes from False to True. If it remains true, it does not continue to go off. Make sure you have the following option not enabled: Study/Chart Alerts And Scanning: Reset Alert Condition On New Bar And also look at the other Alert Options in that section to make sure they are set how you want them to be. And then check your Alert Number to make sure you have not set it to repeat: General Settings Window: Playing Alert Sound Multiple Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-21 12:11:13] |
http://www.sierrachart.com/image.php?Image=1619006487995.png I like to set the line of RSI-TS study to be red once below the 50 line. See chart example. I tried the auto colour (subgraphs) however it is based on +/- of a zero line. Whereas I like to set it based on the 50 line. Pls advise me how can set this auto colour based on the 50 line instead? Thanks so much for your help. |
[2021-04-21 14:21:39] |
You would need to use the Color Bar Based on Alert Condition study. Refer to the following: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-23 09:43:33] |
Thanks for the help. I Like to set an sound alert at certain time of the day eg lunch hour, where should I set the alert condition? Should I add a time line study then type in the alert under that time line study s alert condition box?or is that an simpler way Thanks! |
[2021-04-23 14:56:56] |
You can add the alert to the Chart under Chart >> Chart Settings >> Alerts.
[2021-04-23 17:14:38] |
Thanks so much for your help. Is there a way to create a Dashboard which can scan and show the alerts conditions I have set under different symbols so I can see them all at a glance
[2021-04-23 19:52:36] |
There is not. It has been requested previously, but it is not something we have gotten to. You can always see the results of alerts that have gone "off" by looking at the Alerts Log. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-02 13:51:07] |
Hi ! I like to set colour background switch for MACD crossing the zero line , however I only want the colour to flip when the next bar after the MACD crosses the zero line, for eg if it is a 5 min chart,and MACD line crosses pass the zero line, I want the colour background to flip only if the second 5 min bar close following the crossing and the MACD line is still above the zero line I know the condition to set for the normal MACD cross colour background switch, What do I need to modify to be able to set for the next bar close to be the trigger for the colour switch? Thanks |
[2021-05-02 20:50:05] |
Refer to this section on referencing bars other than the current bar: Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart So you would need to use the AND function to check both bars status. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-19 09:39:53] |
Hi there Like to overlay the previous RTH day session high low to my 60 mins chart and also the weekly high low onto my 60 mins chart, pls advise how Thanks ! |
[2021-05-19 14:22:16] |
You would use the Period OHLC - Variable Period study to get the data you want. This study allows you to reference one period back, so you can see the previous period on the current bars. Refer to the information here: Previous/Period OHLC-Variable Period If you need to use a different chart to get the Period OHLC - Variable Period information, then you would use the Study/Price Overlay to then overlay that information into the chart you want. Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-31 20:16:23] |
Hi I would like to have the chart values/pointer (tools) to appear at the same time in all charts under the same symbols, eg ES 7000 ticks and my ES one hour chart, pls advise how can I link these together? At the moment I can have the chart value/pointer appearing one one chart only. They are not linked. Thanks. |
[2021-08-01 04:09:56] |
Refer to: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) (Global Cursor) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-01 04:10:08
[2021-08-09 16:49:03] |
Hi there, is there a tool where I can count the no of bars of e.g a Swing High to Swing Low , and can I use the Chart calculator to measure the time of certain periods on the charts? the numbers seem funny. Is there another tool specially for measuring time and time projection? Thanks so much |
[2021-08-09 17:34:36] |
Take a look at the Time Projection and Time Expansion Drawing Tools and see if they have what you are looking for: Chart Drawing Tools: Time Expansion Chart Drawing Tools: Time Projection For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-15 15:53:06] |
Hi there I would like to backtest last year s futures indexes price data, eg RTY Russell 2000 from August 2020, however the choices shown only goes back to June 2021 contract. Pls advise how I can retrieve the historical data for last year, so I can set the replay mode to play from there. Also how far back I can go to for these historical data. Thanks! |
