Date/Time: Tue, 07 May 2024 16:47:47 +0000
How do I know if I'm using the Denali feed. Display historical data very slow
View Count: 577
[2021-03-01 19:36:37] |
User715828 - Posts: 58 |
Hi I just switched to subscibing to Sierra Charts directly instead of through Amp. I am trying the Denali feed but I'm trying to pullup an intraday chart on a daily time setting (1-0-0). I'm asking to display 2 year of data for the ES. When I did this is said it was loading the continuous contract, as I thought it would, but it took a very long time and when it was done loading I could not scroll through the chart. I was so slow. I also tried this when I was just using the CQG feed with the same results. I expected the Denali feed to be much quicker. My Data/Trade Service setting show my service as CQG WebAPI and I have Allow support for Sierra Chart data feeds set to yes. Is this correct, am I using the Denali feed? If it is correct, why is that chart so slow? Thank you |
[2021-03-01 19:47:11] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Also follow through the instructions here: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-01 22:11:38] |
http://www.sierrachart.com/image.php?Image=1614636612790.png This is the chart. It is so slow, even when i click the Chart menu it takes a long time to show the sub menus. |
[2021-03-12 19:14:37] |
Hi, I still have not received an answer after posting the image. I'm testing the Denali feed I don't see any difference between Denali and when I was only using CQG through AMP so I am curious to see if I am actually getting the data from Denali. I do have the Allow support for the Sierra Chart data feeds set to yes. I would like to figure this out to see if there is an advantage to the Denali feed before my trial ends at the end of the month. Thank you, |
[2021-03-13 08:11:45] |
You definitively want to stay with the Denali Exchange Data Feed. We definitely do not recommend using CQG data. If you are having performance issues with that particular chart it is due to its complexity. We want you to close the Chartbook and start with a basic chart at first and set up the continuous futures contract settings as you require. Refer to: Continuous Futures Contract Charts so I am curious to see if I am actually getting the data from Denali. Follow the instructions below:Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-13 08:14:00
[2021-03-15 17:37:58] |
Here is the message log Software version: 2222 64-bit | 2021-03-15 10:33:36.848 Primary Thread ID: 2380 | 2021-03-15 10:33:36.848 Usage end date: 2021-03-31 | 2021-03-15 10:33:36.848 Enabled for: Advanced Features 2. | 2021-03-15 10:33:36.848 Enabled for: Sierra Chart Historical Data Service. | 2021-03-15 10:33:36.848 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-03-15 10:33:36.848 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-03-15 10:33:36.848 Enabled for exchange2: CME (Trading Account Required) | 2021-03-15 10:33:36.848 Enabled for exchange2: CBOT (Trading Account Required) | 2021-03-15 10:33:36.848 Enabled for exchange2: COMEX (Trading Account Required) | 2021-03-15 10:33:36.848 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-03-15 10:33:36.848 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-03-15 10:33:36.848 Current selected Data/Trading service: CQG WebAPI | 2021-03-15 10:33:36.848 Custom symbol settings values: enabled | 2021-03-15 10:33:36.848 Chart Update Interval: 500 | 2021-03-15 10:33:36.848 Intraday Data Storage Time Unit: 0 | 2021-03-15 10:33:36.848 Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-03-15 10:33:36.848 2021-03-15 17:33:36 Local computer time in UTC | 2021-03-15 10:33:36.848 2021-03-15 10:33:36 Local computer time in SC Time Zone | 2021-03-15 10:33:36.848 2021-03-15 13:09:40 Server time in UTC | 2021-03-15 10:33:36.848 Local computer UTC time and Server UTC time difference: 2 seconds. | 2021-03-15 10:33:36.848 Program path: D:\My Documents\Trading\Sierra Charts\ | 2021-03-15 10:33:36.848 Data Files path: D:\My Documents\Trading\Sierra Charts\Data\ | 2021-03-15 10:33:36.848 OS Version Number: 10.0 | 2021-03-15 10:33:36.848 Locale Setting: C | 2021-03-15 10:33:36.849 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-03-15 10:33:36.849 Allowed protected custom studies: zyp_download_free | 2021-03-15 10:33:36.849 File >> Disconnect selected. | 2021-03-15 10:34:19.291 CQG WebAPI | Sending Web API Logoff message. | 2021-03-15 10:34:19.308 CQG WebSocket socket (3) | CloseSocket call. | 2021-03-15 10:34:19.308 CQG WebSocket socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:19.308 CQG WebSocket socket (3) | Max send buffers used during socket life: 4 | 2021-03-15 10:34:19.308 CQG WebSocket socket (3) | Max send buffer size during socket life: 309 | 2021-03-15 10:34:19.308 CQG WebSocket | WebSocket closed. | 2021-03-15 10:34:19.308 CQG WebAPI | WebSocket closed. | 2021-03-15 10:34:19.308 CQG WebSocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-03-15 10:34:19.308 SC Data - All Services | Waiting for socket receive thread to end | 2021-03-15 10:34:19.373 DTC Client socket (2) | CloseSocket call. | 2021-03-15 10:34:19.374 DTC Client socket (2) | 100 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:19.374 SC Data - All Services | Disconnected from the server. | 2021-03-15 10:34:19.374 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:19.374 CQG WebAPI | Disconnected. | 2021-03-15 10:34:19.374 CQG WebSocket socket (3) | Write has completed. Shutdown being performed. | 2021-03-15 10:34:19.380 CQG WebSocket socket (3) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:19.380 CQG WebAPI | Connecting to server api.cqg.com | 2021-03-15 10:34:26.263 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-03-15 10:34:26.263 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-03-15 10:34:26.343 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-03-15 10:34:26.343 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2021-03-15 10:34:26.343 CQG WebSocket | Opening WebSocket. | 2021-03-15 10:34:26.421 CQG WebSocket | Sending WebSocket handshake. | 2021-03-15 10:34:26.421 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-03-15 10:34:26.675 CQG WebSocket | Server header | Connection: upgrade | 2021-03-15 10:34:26.675 CQG WebSocket | Server header | Sec-WebSocket-Accept: Gs3pyNlla5tEJoOoA0qbHgPbkFA= | 2021-03-15 10:34:26.675 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-03-15 10:34:26.675 CQG WebSocket | Server header | Upgrade: websocket | 2021-03-15 10:34:26.675 CQG WebSocket | Server header | | 2021-03-15 10:34:26.675 CQG WebSocket | Web socket state is now open. | 2021-03-15 10:34:26.675 CQG WebAPI | WebSocket connected. | 2021-03-15 10:34:26.675 CQG WebAPI | Sending market data logon message. | 2021-03-15 10:34:26.675 CQG WebAPI | Base Time: 2021-03-14T18:43:46. 2021-03-14 18:43:46 | 2021-03-15 10:34:27.105 CQG WebAPI | Logon successful. Session Token = 72bjzOAR41mtFNRnLIftiVPIAx7gT7AZqrqtLgEAuwEozu1w0rMJq0zBPwDV6YvDW7IHuW4rKHv | 2021-03-15 10:34:27.105 CQG WebAPI | Connected to server complete. | 2021-03-15 10:34:27.105 Triggering next historical data download in queue. | 2021-03-15 10:34:27.105 Triggering next historical data download in queue. | 2021-03-15 10:34:27.105 Triggering next historical data download in queue. | 2021-03-15 10:34:27.105 Triggering next historical data download in queue. | 2021-03-15 10:34:27.105 Updated verified funded futures trading account ending date to: 2021-04-14 17:34:27 | 2021-03-15 10:34:27.105 CQG WebAPI | Sending Trade Accounts request message. | 2021-03-15 10:34:27.122 No download requests in the queue to start downloads for. | 2021-03-15 10:34:27.122 No download requests in the queue to start downloads for. | 2021-03-15 10:34:27.122 No download requests in the queue to start downloads for. | 2021-03-15 10:34:27.122 No download requests in the queue to start downloads for. | 2021-03-15 10:34:27.122 Mapping F.US.EPM21 to ESM21. Service code: cme | 2021-03-15 10:34:27.126 SC Data - All Services | Starting real-time market data updates for: F.US.EPM21 (ESM21). ID: 1 Service code: cme | 2021-03-15 10:34:27.126 SC Data - All Services | Connecting to the server ds13.sierracharts.com. Port 10048 | 2021-03-15 10:34:27.126 CQG WebAPI | Sending symbol resolution request for F.US.EPM21. ID: 125963 | 2021-03-15 10:34:27.126 SC Data - All Services | Requesting security definition data for: F.US.EPM21 (ESM21). ID: 1 | 2021-03-15 10:34:27.126 Mapping F.US.MESM21 to MESM21. Service code: cme | 2021-03-15 10:34:27.126 SC Data - All Services | Starting real-time market data updates for: F.US.MESM21 (MESM21). ID: 2 Service code: cme | 2021-03-15 10:34:27.126 CQG WebAPI | Sending symbol resolution request for F.US.MESM21. ID: 125964 | 2021-03-15 10:34:27.126 SC Data - All Services | Requesting security definition data for: F.US.MESM21 (MESM21). ID: 2 | 2021-03-15 10:34:27.126 Added historical Intraday data request for F.US.EPM21 to the queue. | 2021-03-15 10:34:27.126 Intraday data recording state for symbol F.US.EPM21 is set to download 'Pending'. | 2021-03-15 10:34:27.126 Triggering next historical data download in queue. | 2021-03-15 10:34:27.126 DTC Client socket (4) | Creating socket. | 2021-03-15 10:34:27.126 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-03-15 10:34:27.126 DTC Client socket (4) | Connecting to IP: 64.38.174.178. | 2021-03-15 10:34:27.126 Delaying start of download for F.US.EPM21 | 2021-03-15 10:34:27.132 Mapping F.US.MNQM21 to MNQM21. Service code: cme | 2021-03-15 10:34:27.191 SC Data - All Services | Starting real-time market data updates for: F.US.MNQM21 (MNQM21). ID: 3 Service code: cme | 2021-03-15 10:34:27.191 CQG WebAPI | Sending symbol resolution request for F.US.MNQM21. ID: 125965 | 2021-03-15 10:34:27.191 SC Data - All Services | Requesting security definition data for: F.US.MNQM21 (MNQM21). ID: 3 | 2021-03-15 10:34:27.191 Mapping F.US.ENQM21 to NQM21. Service code: cme | 2021-03-15 10:34:27.191 SC Data - All Services | Starting real-time market data updates for: F.US.ENQM21 (NQM21). ID: 4 Service code: cme | 2021-03-15 10:34:27.191 CQG WebAPI | Sending symbol resolution request for F.US.ENQM21. ID: 125966 | 2021-03-15 10:34:27.191 SC Data - All Services | Requesting security definition data for: F.US.ENQM21 (NQM21). ID: 4 | 2021-03-15 10:34:27.191 Added historical Intraday data request for F.US.ENQM21 to the queue. | 2021-03-15 10:34:27.191 Intraday data recording state for symbol F.US.ENQM21 is set to download 'Pending'. | 2021-03-15 10:34:27.191 Triggering next historical data download in queue. | 2021-03-15 10:34:27.191 SC Data - All Services | Network connection to server complete. | 2021-03-15 10:34:27.202 SC Data - All Services | Starting socket receive thread. | 2021-03-15 10:34:27.202 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-03-15 10:34:27.202 CQG WebAPI | Received symbol resolution report for symbol F.US.EPM21. Search Symbol: F.US.EPM21. Request ID: 125963. Contract ID: 1. | 2021-03-15 10:34:27.219 CQG WebAPI | Brokerage name: AMP. Account Name: 128094 | 2021-03-15 10:34:27.219 CQG WebAPI | Sending collateral subscribe request. | 2021-03-15 10:34:27.219 CQG WebAPI | Received symbol resolution report for symbol F.US.MESM21. Search Symbol: F.US.MESM21. Request ID: 125964. Contract ID: 2. | 2021-03-15 10:34:27.219 Mapping F.US.GCEJ21 to GCJ21. Service code: comex | 2021-03-15 10:34:27.240 SC Data - All Services | Starting real-time market data updates for: F.US.GCEJ21 (GCJ21). ID: 5 Service code: comex | 2021-03-15 10:34:27.240 CQG WebAPI | Sending symbol resolution request for F.US.GCEJ21. ID: 125968 | 2021-03-15 10:34:27.240 SC Data - All Services | Requesting security definition data for: F.US.GCEJ21 (GCJ21). ID: 5 | 2021-03-15 10:34:27.240 Added historical Intraday data request for F.US.GCEJ21 to the queue. | 2021-03-15 10:34:27.240 Intraday data recording state for symbol F.US.GCEJ21 is set to download 'Pending'. | 2021-03-15 10:34:27.240 Triggering next historical data download in queue. | 2021-03-15 10:34:27.240 Mapping F.US.MESH21 to MESH21. Service code: cme | 2021-03-15 10:34:27.242 SC Data - All Services | Starting real-time market data updates for: F.US.MESH21 (MESH21). ID: 6 Service code: cme | 2021-03-15 10:34:27.242 CQG WebAPI | Sending symbol resolution request for F.US.MESH21. ID: 125969 | 2021-03-15 10:34:27.242 SC Data - All Services | Requesting security definition data for: F.US.MESH21 (MESH21). ID: 6 | 2021-03-15 10:34:27.242 Added historical Intraday data request for F.US.MESH21 to the queue. | 2021-03-15 10:34:27.242 Intraday data recording state for symbol F.US.MESH21 is set to download 'Pending'. | 2021-03-15 10:34:27.242 Triggering next historical data download in queue. | 2021-03-15 10:34:27.242 Mapping F.US.CLEG21 to CLG21. Service code: nymex | 2021-03-15 10:34:27.250 SC Data - All Services | Starting real-time market data updates for: F.US.CLEG21 (CLG21). ID: 7 Service code: nymex | 2021-03-15 10:34:27.250 CQG WebAPI | Sending symbol resolution request for F.US.CLEG21. ID: 125970 | 2021-03-15 10:34:27.250 SC Data - All Services | Requesting security definition data for: F.US.CLEG21 (CLG21). ID: 7 | 2021-03-15 10:34:27.250 Added historical Intraday data request for F.US.CLEG21 to the queue. | 2021-03-15 10:34:27.250 Intraday data recording state for symbol F.US.CLEG21 is set to download 'Pending'. | 2021-03-15 10:34:27.250 Triggering next historical data download in queue. | 2021-03-15 10:34:27.250 Requesting market depth updates for: F.US.ENQM21 if supported. | 2021-03-15 10:34:27.262 Separate subscription for market depth updates not supported. F.US.ENQM21 | 2021-03-15 10:34:27.262 Requesting market depth updates for: F.US.EPM21 if supported. | 2021-03-15 10:34:27.266 Separate subscription for market depth updates not supported. F.US.EPM21 | 2021-03-15 10:34:27.266 Mapping F.US.RTYH21 to RTYH21. Service code: cme | 2021-03-15 10:34:27.267 SC Data - All Services | Starting real-time market data updates for: F.US.RTYH21 (RTYH21). ID: 8 Service code: cme | 2021-03-15 10:34:27.267 CQG WebAPI | Sending symbol resolution request for F.US.RTYH21. ID: 125971 | 2021-03-15 10:34:27.268 SC Data - All Services | Requesting security definition data for: F.US.RTYH21 (RTYH21). ID: 8 | 2021-03-15 10:34:27.268 Added historical Intraday data request for F.US.RTYH21 to the queue. | 2021-03-15 10:34:27.268 Intraday data recording state for symbol F.US.RTYH21 is set to download 'Pending'. | 2021-03-15 10:34:27.268 Triggering next historical data download in queue. | 2021-03-15 10:34:27.268 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:27.268 SC Data - All Services | Sending logon request message. | 2021-03-15 10:34:27.268 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQM21. Search Symbol: F.US.MNQM21. Request ID: 125965. Contract ID: 3. | 2021-03-15 10:34:27.270 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQM21. Search Symbol: F.US.ENQM21. Request ID: 125966. Contract ID: 4. | 2021-03-15 10:34:27.270 Mapping F.US.MNQH21 to MNQH21. Service code: cme | 2021-03-15 10:34:27.270 SC Data - All Services | Starting real-time market data updates for: F.US.MNQH21 (MNQH21). ID: 9 Service code: cme | 2021-03-15 10:34:27.270 CQG WebAPI | Sending symbol resolution request for F.US.MNQH21. ID: 125972 | 2021-03-15 10:34:27.270 SC Data - All Services | Requesting security definition data for: F.US.MNQH21 (MNQH21). ID: 9 | 2021-03-15 10:34:27.270 Added historical Intraday data request for F.US.MNQH21 to the queue. | 2021-03-15 10:34:27.270 Intraday data recording state for symbol F.US.MNQH21 is set to download 'Pending'. | 2021-03-15 10:34:27.270 Triggering next historical data download in queue. | 2021-03-15 10:34:27.270 Mapping F.US.CLEH21 to CLH21. Service code: nymex | 2021-03-15 10:34:27.270 SC Data - All Services | Starting real-time market data updates for: F.US.CLEH21 (CLH21). ID: 10 Service code: nymex | 2021-03-15 10:34:27.271 CQG WebAPI | Sending symbol resolution request for F.US.CLEH21. ID: 125973 | 2021-03-15 10:34:27.271 SC Data - All Services | Requesting security definition data for: F.US.CLEH21 (CLH21). ID: 10 | 2021-03-15 10:34:27.271 Added historical Intraday data request for F.US.CLEH21 to the queue. | 2021-03-15 10:34:27.271 Intraday data recording state for symbol F.US.CLEH21 is set to download 'Pending'. | 2021-03-15 10:34:27.271 Triggering next historical data download in queue. | 2021-03-15 10:34:27.271 CQG WebAPI | Received symbol resolution report for symbol F.US.GCEJ21. Search Symbol: F.US.GCEJ21. Request ID: 125968. Contract ID: 5. | 2021-03-15 10:34:27.313 CQG WebAPI | Received symbol resolution report for symbol F.US.MESH21. Search Symbol: F.US.MESH21. Request ID: 125969. Contract ID: 6. | 2021-03-15 10:34:27.384 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYH21. Search Symbol: F.US.RTYH21. Request ID: 125971. Contract ID: 7. | 2021-03-15 10:34:27.384 CQG WebAPI | Received symbol resolution report for symbol F.US.MNQH21. Search Symbol: F.US.MNQH21. Request ID: 125972. Contract ID: 8. | 2021-03-15 10:34:27.384 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEH21. Search Symbol: F.US.CLEH21. Request ID: 125973. Contract ID: 9. | 2021-03-15 10:34:27.387 CQG WebAPI | Received message: Requested symbol was not found. | 2021-03-15 10:34:27.388 Symbol Error - F.US.CLEG21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-03-15 10:34:27.388 SC Data - All Services | Received logon response. | 2021-03-15 10:34:28.277 SC Data - All Services | Server Name: SC Realtime Server. | 2021-03-15 10:34:28.277 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-03-15 10:34:28.277 SC Data - All Services | Successfully connected. | 2021-03-15 10:34:28.277 SC Data - All Services | Trading is not supported. | 2021-03-15 10:34:28.277 SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEG21 -> CLG21 | 2021-03-15 10:34:28.277 SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEH21 -> CLH21 | 2021-03-15 10:34:28.277 SC Data - All Services | Restarting real-time data updates for symbol: F.US.ENQM21 -> NQM21. Market Depth data restarted. | 2021-03-15 10:34:28.277 SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPM21 -> ESM21. Market Depth data restarted. | 2021-03-15 10:34:28.278 SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEJ21 -> GCJ21 | 2021-03-15 10:34:28.278 SC Data - All Services | Restarting real-time data updates for symbol: F.US.MESH21 -> MESH21 | 2021-03-15 10:34:28.278 SC Data - All Services | Restarting real-time data updates for symbol: F.US.MESM21 -> MESM21 | 2021-03-15 10:34:28.278 SC Data - All Services | Restarting real-time data updates for symbol: F.US.MNQH21 -> MNQH21 | 2021-03-15 10:34:28.278 SC Data - All Services | Restarting real-time data updates for symbol: F.US.MNQM21 -> MNQM21 | 2021-03-15 10:34:28.278 SC Data - All Services | Restarting real-time data updates for symbol: F.US.RTYH21 -> RTYH21 | 2021-03-15 10:34:28.278 SC Data - All Services | Clearing market depth for F.US.ENQM21 | 2021-03-15 10:34:28.497 Opened cached Depth file: D:\My Documents\Trading\Sierra Charts\Data\MarketDepthData\F.US.ENQM21.2021-03-15.depth | 2021-03-15 10:34:28.498 SC Data - All Services | Real-time data for symbol F.US.CLEG21 is currently unavailable. | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.CLEG21 | 2021-03-15 10:34:28.498 SC Data - All Services | Real-time data for symbol F.US.CLEH21 is currently unavailable. | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.CLEH21 | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.ENQM21 | 2021-03-15 10:34:28.498 SC Data - All Services | Clearing market depth for F.US.EPM21 | 2021-03-15 10:34:28.498 Opened cached Depth file: D:\My Documents\Trading\Sierra Charts\Data\MarketDepthData\F.US.EPM21.2021-03-15.depth | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.EPM21 | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.GCEJ21 | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.MESH21 | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.MESM21 | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.MNQH21 | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.MNQM21 | 2021-03-15 10:34:28.498 SC Data - All Services | Received security definition for symbol F.US.RTYH21 | 2021-03-15 10:34:28.498 CQG WebAPI | Sending positions subscribe request. RequestID: 125974 | 2021-03-15 10:34:32.105 CQG WebAPI | Sending orders subscribe request. RequestID=125975 | 2021-03-15 10:34:32.105 Requesting market depth updates for: F.US.MESH21 if supported. | 2021-03-15 10:34:32.105 Requesting market depth updates for: F.US.MNQH21 if supported. | 2021-03-15 10:34:32.106 Requesting market depth updates for: F.US.MNQM21 if supported. | 2021-03-15 10:34:32.106 SC Data - All Services | Clearing market depth for F.US.MESH21 | 2021-03-15 10:34:32.253 SC Data - All Services | Clearing market depth for F.US.MNQH21 | 2021-03-15 10:34:32.253 SC Data - All Services | Clearing market depth for F.US.MNQM21 | 2021-03-15 10:34:32.253 HD Request # 18 | Downloading Intraday chart data for F.US.EPM21 to the file F.US.EPM21.scid. Service: cme | 2021-03-15 10:34:33.469 HD Request # 18 | Download start date-time: 2021-03-15 10:34:14.000000. File last date-time: 2021-03-15 10:34:14.952000 | 2021-03-15 10:34:33.469 HD Request # 18 | Using server: ds23.sierracharts.com port 10149 | 2021-03-15 10:34:33.469 Socket (6) | Creating socket. | 2021-03-15 10:34:33.470 Socket (6) | New receive buffer size: 5242880 | 2021-03-15 10:34:33.470 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-03-15 10:34:33.470 HD Request # 18 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:33.611 HD Request # 18 | Sending historical data logon request message. | 2021-03-15 10:34:33.611 HD Request # 18 | Requesting Intraday data. Start date-time: 2021-03-15 10:34:14. Record interval: 0. Symbol: ESM21 | 2021-03-15 10:34:33.671 HD Request # 18 | Decompressing data. | 2021-03-15 10:34:33.732 HD Request # 18 | Receiving Intraday data for F.US.EPM21 starting at 2021-03-15 10:34:14.521000 | 2021-03-15 10:34:33.732 Socket (6) | CloseSocket call. | 2021-03-15 10:34:33.733 Socket (6) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:33.733 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:33.733 Historical data download thread signaled to stop. | 2021-03-15 10:34:33.733 HD Request # 18 | Timestamp of first Intraday data file record written: 2021-03-15 10:34:18.423000 | 2021-03-15 10:34:33.733 HD Request # 18 | Received 70 records from 2021-03-15 10:34:14.521000 to 2021-03-15 10:34:28.582003 (14.1 seconds) and wrote 45 records for F.US.EPM21 | 2021-03-15 10:34:33.733 HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2021-03-15 17:34:28.582003 | 2021-03-15 10:34:33.736 Added 1 Time and Sales records to Intraday data file for F.US.EPM21 after download. | 2021-03-15 10:34:33.736 HD Request # 18 | Completion time: 0s | 2021-03-15 10:34:33.739 HD Request # 18 | Intraday data download complete for F.US.EPM21. Unique request ID: 15 | 2021-03-15 10:34:33.739 Removing historical data download ID 15. | 2021-03-15 10:34:33.739 Real-time Intraday chart data file updates started for F.US.EPM21 | 2021-03-15 10:34:33.739 Intraday chart data file opened for F.US.EPM21 | 2021-03-15 10:34:33.739 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2021-03-15 10:34:33.739 Triggering next historical data download in queue. | 2021-03-15 10:34:33.739 HD Request # 19 | Downloading Intraday chart data for F.US.ENQM21 to the file F.US.ENQM21.scid. Service: cme | 2021-03-15 10:34:33.739 HD Request # 19 | Download start date-time: 2021-03-15 10:34:17.000000. File last date-time: 2021-03-15 10:34:17.605000 | 2021-03-15 10:34:33.740 HD Request # 19 | Using server: ds21.sierracharts.com port 10150 | 2021-03-15 10:34:33.740 Socket (7) | Creating socket. | 2021-03-15 10:34:33.740 Socket (7) | New receive buffer size: 5242880 | 2021-03-15 10:34:33.740 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-03-15 10:34:33.740 Socket (6) | Socket gracefully closed by remote side. | 2021-03-15 10:34:33.799 Socket (6) | Closed. | 2021-03-15 10:34:33.799 Chart #2 has tagged chart #1 for full recalculation. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:33.860 Chart #2 has tagged chart #6 for full recalculation. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:33.860 F.US.ENQM21/F.US.MNQM21 [CB][M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:33.860 HD Request # 19 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:33.878 HD Request # 19 | Sending historical data logon request message. | 2021-03-15 10:34:33.878 HD Request # 19 | Requesting Intraday data. Start date-time: 2021-03-15 10:34:17. Record interval: 0. Symbol: NQM21 | 2021-03-15 10:34:33.944 Chart #3 has tagged chart #1 for full recalculation. Chartbook: Lee's template.Cht | 2021-03-15 10:34:34.000 Chart #3 has tagged chart #5 for full recalculation. Chartbook: Lee's template.Cht | 2021-03-15 10:34:34.000 Chart #3 has tagged chart #6 for full recalculation. Chartbook: Lee's template.Cht | 2021-03-15 10:34:34.000 HD Request # 19 | Decompressing data. | 2021-03-15 10:34:34.005 HD Request # 19 | Receiving Intraday data for F.US.ENQM21 starting at 2021-03-15 10:34:17.093000 | 2021-03-15 10:34:34.006 Socket (7) | CloseSocket call. | 2021-03-15 10:34:34.006 Socket (7) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:34.006 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:34.006 Historical data download thread signaled to stop. | 2021-03-15 10:34:34.007 HD Request # 19 | Timestamp of first Intraday data file record written: 2021-03-15 10:34:19.054000 | 2021-03-15 10:34:34.007 HD Request # 19 | Received 60 records from 2021-03-15 10:34:17.093000 to 2021-03-15 10:34:29.971001 (12.9 seconds) and wrote 57 records for F.US.ENQM21 | 2021-03-15 10:34:34.007 HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2021-03-15 17:34:29.971001 | 2021-03-15 10:34:34.011 Added 2 Time and Sales records to Intraday data file for F.US.ENQM21 after download. | 2021-03-15 10:34:34.011 HD Request # 19 | Completion time: 1s | 2021-03-15 10:34:34.014 HD Request # 19 | Intraday data download complete for F.US.ENQM21. Unique request ID: 16 | 2021-03-15 10:34:34.015 Removing historical data download ID 16. | 2021-03-15 10:34:34.015 Real-time Intraday chart data file updates started for F.US.ENQM21 | 2021-03-15 10:34:34.015 Intraday chart data file opened for F.US.ENQM21 | 2021-03-15 10:34:34.015 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2021-03-15 10:34:34.015 Triggering next historical data download in queue. | 2021-03-15 10:34:34.015 HD Request # 20 | Downloading Intraday chart data for F.US.GCEJ21 to the file F.US.GCEJ21.scid. Service: comex | 2021-03-15 10:34:34.015 HD Request # 20 | Download start date-time: 2021-03-15 10:34:17.000000. File last date-time: 2021-03-15 10:34:17.251000 | 2021-03-15 10:34:34.015 HD Request # 20 | Using server: ds23.sierracharts.com port 10149 | 2021-03-15 10:34:34.015 Socket (6) | Creating socket. | 2021-03-15 10:34:34.015 Socket (6) | New receive buffer size: 5242880 | 2021-03-15 10:34:34.015 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-03-15 10:34:34.015 Socket (7) | Socket gracefully closed by remote side. | 2021-03-15 10:34:34.074 Socket (7) | Closed. | 2021-03-15 10:34:34.075 F.US.EPM21 [CB][M] 1439 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.078 F.US.EPM21/F.US.MESM21[M] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: Lee's template.Cht | 2021-03-15 10:34:34.111 HD Request # 20 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:34.156 HD Request # 20 | Sending historical data logon request message. | 2021-03-15 10:34:34.156 Chart #3 has tagged chart #1 for full recalculation. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.181 Chart #3 has tagged chart #2 for full recalculation. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.181 Chart #3 has tagged chart #6 for full recalculation. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.181 Chart #5 has tagged chart #1 for full recalculation. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.217 F.US.ENQM21[M] 30 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Lee's template.Cht | 2021-03-15 10:34:34.218 HD Request # 20 | Requesting Intraday data. Start date-time: 2021-03-15 10:34:17. Record interval: 0. Symbol: GCJ21 | 2021-03-15 10:34:34.224 F.US.EPM21/F.US.MESM21 [CB][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.224 Chart #2 has tagged chart #1 for full recalculation. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.230 Chart #2 has tagged chart #6 for full recalculation. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.230 F.US.ENQM21/F.US.MNQM21 [CB][M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.230 HD Request # 20 | Decompressing data. | 2021-03-15 10:34:34.298 HD Request # 20 | Receiving Intraday data for F.US.GCEJ21 starting at 2021-03-15 10:34:17.251000 | 2021-03-15 10:34:34.299 F.US.ENQM21/F.US.MNQM21[M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: Lee's template.Cht | 2021-03-15 10:34:34.300 Socket (6) | CloseSocket call. | 2021-03-15 10:34:34.300 Socket (6) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:34.300 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:34.300 Historical data download thread signaled to stop. | 2021-03-15 10:34:34.302 HD Request # 20 | Timestamp of first Intraday data file record written: 2021-03-15 10:34:21.204000 | 2021-03-15 10:34:34.302 HD Request # 20 | Received 6 records from 2021-03-15 10:34:17.251000 to 2021-03-15 10:34:23.401000 (6.2 seconds) and wrote 5 records for F.US.GCEJ21 | 2021-03-15 10:34:34.303 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2021-03-15 17:34:23.401000 | 2021-03-15 10:34:34.306 Added 2 Time and Sales records to Intraday data file for F.US.GCEJ21 after download. | 2021-03-15 10:34:34.306 HD Request # 20 | Completion time: 0s | 2021-03-15 10:34:34.309 HD Request # 20 | Intraday data download complete for F.US.GCEJ21. Unique request ID: 17 | 2021-03-15 10:34:34.309 Removing historical data download ID 17. | 2021-03-15 10:34:34.309 Real-time Intraday chart data file updates started for F.US.GCEJ21 | 2021-03-15 10:34:34.309 Intraday chart data file opened for F.US.GCEJ21 | 2021-03-15 10:34:34.309 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2021-03-15 10:34:34.309 Triggering next historical data download in queue. | 2021-03-15 10:34:34.309 HD Request # 21 | Downloading Intraday chart data for F.US.MESH21 to the file F.US.MESH21.scid. Service: cme | 2021-03-15 10:34:34.309 HD Request # 21 | Download start date-time: 2021-03-15 10:34:16.000000. File last date-time: 2021-03-15 10:34:16.497001 | 2021-03-15 10:34:34.309 HD Request # 21 | Using server: ds21.sierracharts.com port 10150 | 2021-03-15 10:34:34.309 Socket (7) | Creating socket. | 2021-03-15 10:34:34.309 Socket (7) | New receive buffer size: 5242880 | 2021-03-15 10:34:34.309 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-03-15 10:34:34.309 Socket (6) | Socket gracefully closed by remote side. | 2021-03-15 10:34:34.362 Socket (6) | Closed. | 2021-03-15 10:34:34.362 HD Request # 21 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:34.445 HD Request # 21 | Sending historical data logon request message. | 2021-03-15 10:34:34.445 HD Request # 21 | Requesting Intraday data. Start date-time: 2021-03-15 10:34:16. Record interval: 0. Symbol: MESH21 | 2021-03-15 10:34:34.505 F.US.EPM21 [CB][M] 1439 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: TRG-Lee-FishingTrip-ES.Cht | 2021-03-15 10:34:34.518 HD Request # 21 | Decompressing data. | 2021-03-15 10:34:34.566 HD Request # 21 | Receiving Intraday data for F.US.MESH21 starting at 2021-03-15 10:34:16.497000 | 2021-03-15 10:34:34.566 Socket (7) | CloseSocket call. | 2021-03-15 10:34:34.566 Socket (7) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:34.566 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:34.567 Historical data download thread signaled to stop. | 2021-03-15 10:34:34.571 HD Request # 21 | Timestamp of first Intraday data file record written: 2021-03-15 10:34:19.504000 | 2021-03-15 10:34:34.571 HD Request # 21 | Received 4 records from 2021-03-15 10:34:16.497000 to 2021-03-15 10:34:19.504001 (3.0 seconds) and wrote 2 records for F.US.MESH21 | 2021-03-15 10:34:34.571 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2021-03-15 17:34:19.504001 | 2021-03-15 10:34:34.575 Added 4 Time and Sales records to Intraday data file for F.US.MESH21 after download. | 2021-03-15 10:34:34.575 HD Request # 21 | Completion time: 0s | 2021-03-15 10:34:34.578 HD Request # 21 | Intraday data download complete for F.US.MESH21. Unique request ID: 18 | 2021-03-15 10:34:34.578 Removing historical data download ID 18. | 2021-03-15 10:34:34.578 Real-time Intraday chart data file updates started for F.US.MESH21 | 2021-03-15 10:34:34.578 Intraday chart data file opened for F.US.MESH21 | 2021-03-15 10:34:34.578 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2021-03-15 10:34:34.578 Triggering next historical data download in queue. | 2021-03-15 10:34:34.578 HD Request # 22 | Downloading Intraday chart data for F.US.CLEG21 to the file F.US.CLEG21.scid. Service: nymex | 2021-03-15 10:34:34.578 HD Request # 22 | Performing multistage download. Downloading Minute data first. | 2021-03-15 10:34:34.578 HD Request # 22 | Download start date-time: 2021-01-20 11:29:37.000000. File last date-time: 2021-01-20 11:29:37.142000 | 2021-03-15 10:34:34.578 HD Request # 22 | Disabling Intraday chart updating for symbol. | 2021-03-15 10:34:34.578 HD Request # 22 | Using server: ds23.sierracharts.com port 10149 | 2021-03-15 10:34:34.579 Socket (6) | Creating socket. | 2021-03-15 10:34:34.579 Socket (6) | New receive buffer size: 5242880 | 2021-03-15 10:34:34.579 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-03-15 10:34:34.579 Socket (7) | Socket gracefully closed by remote side. | 2021-03-15 10:34:34.634 Socket (7) | Closed. | 2021-03-15 10:34:34.634 HD Request # 22 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:34.722 HD Request # 22 | Sending historical data logon request message. | 2021-03-15 10:34:34.722 HD Request # 22 | Requesting Intraday data. Start date-time: 2021-01-20 11:29:37. Record interval: 60. Symbol: CLG21 | 2021-03-15 10:34:34.791 HD Request # 22 | Decompressing data. | 2021-03-15 10:34:34.858 HD Request # 22 | Receiving Intraday data for F.US.CLEG21 starting at 2021-01-20 11:29:37.142000 | 2021-03-15 10:34:34.858 Socket (6) | CloseSocket call. | 2021-03-15 10:34:34.859 Socket (6) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:34.859 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:34.859 Historical data download thread signaled to stop. | 2021-03-15 10:34:34.859 HD Request # 22 | Timestamp of first Intraday data file record written: 2021-01-20 11:29:37.142000 | 2021-03-15 10:34:34.859 HD Request # 22 | Received 1 record from 2021-01-20 11:29:37.142000 to 2021-01-20 11:29:37.142000 (0.0 seconds) and wrote 1 record for F.US.CLEG21 | 2021-03-15 10:34:34.859 HD Request # 22 | Completion time: 0s | 2021-03-15 10:34:34.862 HD Request # 22 | Intraday data download complete for F.US.CLEG21. Unique request ID: 19 | 2021-03-15 10:34:34.862 Added historical Intraday data request for F.US.CLEG21 to the queue. | 2021-03-15 10:34:34.862 Triggering next historical data download in queue. | 2021-03-15 10:34:34.862 HD Request # 23 | Downloading Intraday chart data for F.US.CLEG21 to the file F.US.CLEG21.scid. Service: nymex | 2021-03-15 10:34:34.862 HD Request # 23 | Rounding start date-time down to the minute: 2021-01-20 11:29:00.000 | 2021-03-15 10:34:34.862 HD Request # 23 | Download start date-time: 2021-01-20 11:29:00.000000. File last date-time: 00:00:00.000000 | 2021-03-15 10:34:34.862 HD Request # 23 | Using server: ds21.sierracharts.com port 10150 | 2021-03-15 10:34:34.863 Socket (7) | Creating socket. | 2021-03-15 10:34:34.863 Socket (7) | New receive buffer size: 5242880 | 2021-03-15 10:34:34.863 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-03-15 10:34:34.863 Opened cached Intraday file: D:\My Documents\Trading\Sierra Charts\Data\F.US.ENQM21.scid. Thread ID: 10080 | 2021-03-15 10:34:34.881 Socket (6) | Socket gracefully closed by remote side. | 2021-03-15 10:34:34.927 Socket (6) | Closed. | 2021-03-15 10:34:34.927 HD Request # 23 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:35.005 HD Request # 23 | Sending historical data logon request message. | 2021-03-15 10:34:35.005 HD Request # 23 | Requesting Intraday data. Start date-time: 2021-01-20 11:29:00. Record interval: 0. Symbol: CLG21 | 2021-03-15 10:34:35.065 HD Request # 23 | Decompressing data. | 2021-03-15 10:34:35.125 HD Request # 23 | Receiving Intraday data for F.US.CLEG21 starting at 2021-01-20 11:29:03.481000 | 2021-03-15 10:34:35.126 HD Request # 23 | Rounded first tick record Date-time down to minute: 2021-01-20 11:29:00 | 2021-03-15 10:34:35.126 HD Request # 23 | Truncated Intraday data file at 2021-01-20 11:29:00 while receiving initial tick data during multistage download. | 2021-03-15 10:34:35.126 HD Request # 23 | Date-time after truncate 2021-01-20 11:28:55 | 2021-03-15 10:34:35.126 Socket (7) | CloseSocket call. | 2021-03-15 10:34:35.126 Socket (7) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:35.126 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:35.126 Historical data download thread signaled to stop. | 2021-03-15 10:34:35.128 HD Request # 23 | Timestamp of first Intraday data file record written: 2021-01-20 11:29:03.481000 | 2021-03-15 10:34:35.128 HD Request # 23 | Received 7 records from 2021-01-20 11:29:03.481000 to 2021-01-20 11:29:37.142000 (33.7 seconds) and wrote 7 records for F.US.CLEG21 | 2021-03-15 10:34:35.128 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2021-01-20 19:29:37.142000 | 2021-03-15 10:34:35.131 HD Request # 23 | Completion time: 1s | 2021-03-15 10:34:35.131 HD Request # 23 | Intraday data download complete for F.US.CLEG21. Unique request ID: 19 | 2021-03-15 10:34:35.131 Removing historical data download ID 19. | 2021-03-15 10:34:35.131 Real-time Intraday chart data file updates started for F.US.CLEG21 | 2021-03-15 10:34:35.132 Intraday chart data file opened for F.US.CLEG21 | 2021-03-15 10:34:35.132 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2021-03-15 10:34:35.132 F.US.CLEG21[M] 3 Min #8 | Flagging to reload Intraday data on download completion. | 2021-03-15 10:34:35.132 Triggering next historical data download in queue. | 2021-03-15 10:34:35.132 HD Request # 24 | Downloading Intraday chart data for F.US.RTYH21 to the file F.US.RTYH21.scid. Service: cme | 2021-03-15 10:34:35.133 HD Request # 24 | Download start date-time: 2021-03-15 10:34:10.000000. File last date-time: 2021-03-15 10:34:10.317000 | 2021-03-15 10:34:35.133 HD Request # 24 | Using server: ds23.sierracharts.com port 10149 | 2021-03-15 10:34:35.133 Socket (6) | Creating socket. | 2021-03-15 10:34:35.133 Socket (6) | New receive buffer size: 5242880 | 2021-03-15 10:34:35.133 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-03-15 10:34:35.133 F.US.CLEG21[M] 3 Min #8 | Reloading chart. | 2021-03-15 10:34:35.185 Socket (7) | Socket gracefully closed by remote side. | 2021-03-15 10:34:35.189 Socket (7) | Closed. | 2021-03-15 10:34:35.189 F.US.CLEG21[M] 3 Min #8 | StartDateTimeForLoadingOrderFills: 2021-01-06 11:29:37 | 2021-03-15 10:34:35.226 HD Request # 24 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:35.283 HD Request # 24 | Sending historical data logon request message. | 2021-03-15 10:34:35.283 HD Request # 24 | Requesting Intraday data. Start date-time: 2021-03-15 10:34:10. Record interval: 0. Symbol: RTYH21 | 2021-03-15 10:34:35.350 HD Request # 24 | Decompressing data. | 2021-03-15 10:34:35.411 HD Request # 24 | Receiving Intraday data for F.US.RTYH21 starting at 2021-03-15 10:34:10.317000 | 2021-03-15 10:34:35.411 Socket (6) | CloseSocket call. | 2021-03-15 10:34:35.411 Socket (6) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:35.411 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:35.411 Historical data download thread signaled to stop. | 2021-03-15 10:34:35.424 HD Request # 24 | Timestamp of first Intraday data file record written: 2021-03-15 10:34:24.200000 | 2021-03-15 10:34:35.424 HD Request # 24 | Received 11 records from 2021-03-15 10:34:10.317000 to 2021-03-15 10:34:33.435000 (23.1 seconds) and wrote 10 records for F.US.RTYH21 | 2021-03-15 10:34:35.424 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2021-03-15 17:34:33.435000 | 2021-03-15 10:34:35.427 HD Request # 24 | Completion time: 0s | 2021-03-15 10:34:35.427 HD Request # 24 | Intraday data download complete for F.US.RTYH21. Unique request ID: 20 | 2021-03-15 10:34:35.427 Removing historical data download ID 20. | 2021-03-15 10:34:35.427 Real-time Intraday chart data file updates started for F.US.RTYH21 | 2021-03-15 10:34:35.427 Intraday chart data file opened for F.US.RTYH21 | 2021-03-15 10:34:35.427 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2021-03-15 10:34:35.427 Triggering next historical data download in queue. | 2021-03-15 10:34:35.427 HD Request # 25 | Downloading Intraday chart data for F.US.MNQH21 to the file F.US.MNQH21.scid. Service: cme | 2021-03-15 10:34:35.427 HD Request # 25 | Download start date-time: 2021-03-15 10:34:16.000000. File last date-time: 2021-03-15 10:34:16.041000 | 2021-03-15 10:34:35.427 HD Request # 25 | Using server: ds21.sierracharts.com port 10150 | 2021-03-15 10:34:35.427 Socket (7) | Creating socket. | 2021-03-15 10:34:35.427 Socket (7) | New receive buffer size: 5242880 | 2021-03-15 10:34:35.427 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-03-15 10:34:35.427 Socket (6) | Socket gracefully closed by remote side. | 2021-03-15 10:34:35.476 Socket (6) | Closed. | 2021-03-15 10:34:35.477 HD Request # 25 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:35.560 HD Request # 25 | Sending historical data logon request message. | 2021-03-15 10:34:35.560 HD Request # 25 | Requesting Intraday data. Start date-time: 2021-03-15 10:34:16. Record interval: 0. Symbol: MNQH21 | 2021-03-15 10:34:35.621 HD Request # 25 | Decompressing data. | 2021-03-15 10:34:35.687 HD Request # 25 | Receiving Intraday data for F.US.MNQH21 starting at 2021-03-15 10:34:16.041000 | 2021-03-15 10:34:35.688 Socket (7) | CloseSocket call. | 2021-03-15 10:34:35.688 Socket (7) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:35.688 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:35.688 Historical data download thread signaled to stop. | 2021-03-15 10:34:35.697 HD Request # 25 | Timestamp of first Intraday data file record written: 2021-03-15 10:34:17.992000 | 2021-03-15 10:34:35.697 HD Request # 25 | Received 20 records from 2021-03-15 10:34:16.041000 to 2021-03-15 10:34:31.131000 (15.1 seconds) and wrote 19 records for F.US.MNQH21 | 2021-03-15 10:34:35.697 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2021-03-15 17:34:31.131000 | 2021-03-15 10:34:35.701 Added 12 Time and Sales records to Intraday data file for F.US.MNQH21 after download. | 2021-03-15 10:34:35.701 HD Request # 25 | Completion time: 0s | 2021-03-15 10:34:35.705 HD Request # 25 | Intraday data download complete for F.US.MNQH21. Unique request ID: 21 | 2021-03-15 10:34:35.705 Removing historical data download ID 21. | 2021-03-15 10:34:35.705 Real-time Intraday chart data file updates started for F.US.MNQH21 | 2021-03-15 10:34:35.705 Intraday chart data file opened for F.US.MNQH21 | 2021-03-15 10:34:35.705 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2021-03-15 10:34:35.705 Triggering next historical data download in queue. | 2021-03-15 10:34:35.705 HD Request # 26 | Downloading Intraday chart data for F.US.CLEH21 to the file F.US.CLEH21.scid. Service: nymex | 2021-03-15 10:34:35.705 HD Request # 26 | Performing multistage download. Downloading Minute data first. | 2021-03-15 10:34:35.705 HD Request # 26 | Download start date-time: 2021-02-22 11:29:37.000000. File last date-time: 2021-02-22 11:29:37.288000 | 2021-03-15 10:34:35.705 HD Request # 26 | Disabling Intraday chart updating for symbol. | 2021-03-15 10:34:35.705 HD Request # 26 | Using server: ds23.sierracharts.com port 10149 | 2021-03-15 10:34:35.705 Socket (6) | Creating socket. | 2021-03-15 10:34:35.705 Socket (6) | New receive buffer size: 5242880 | 2021-03-15 10:34:35.705 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-03-15 10:34:35.705 Socket (7) | Socket gracefully closed by remote side. | 2021-03-15 10:34:35.755 Socket (7) | Closed. | 2021-03-15 10:34:35.755 HD Request # 26 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:35.846 HD Request # 26 | Sending historical data logon request message. | 2021-03-15 10:34:35.846 HD Request # 26 | Requesting Intraday data. Start date-time: 2021-02-22 11:29:37. Record interval: 60. Symbol: CLH21 | 2021-03-15 10:34:35.911 HD Request # 26 | Decompressing data. | 2021-03-15 10:34:35.969 HD Request # 26 | Receiving Intraday data for F.US.CLEH21 starting at 2021-02-22 11:29:37.288000 | 2021-03-15 10:34:35.970 Socket (6) | CloseSocket call. | 2021-03-15 10:34:35.970 Socket (6) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:35.970 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:35.970 Historical data download thread signaled to stop. | 2021-03-15 10:34:35.972 HD Request # 26 | Timestamp of first Intraday data file record written: 2021-02-22 11:29:37.288000 | 2021-03-15 10:34:35.972 HD Request # 26 | Received 1 record from 2021-02-22 11:29:37.288000 to 2021-02-22 11:29:37.288000 (0.0 seconds) and wrote 1 record for F.US.CLEH21 | 2021-03-15 10:34:35.972 HD Request # 26 | Completion time: 0s | 2021-03-15 10:34:35.975 HD Request # 26 | Intraday data download complete for F.US.CLEH21. Unique request ID: 22 | 2021-03-15 10:34:35.975 Added historical Intraday data request for F.US.CLEH21 to the queue. | 2021-03-15 10:34:35.975 Triggering next historical data download in queue. | 2021-03-15 10:34:35.975 HD Request # 27 | Downloading Intraday chart data for F.US.CLEH21 to the file F.US.CLEH21.scid. Service: nymex | 2021-03-15 10:34:35.975 HD Request # 27 | Rounding start date-time down to the minute: 2021-02-22 11:29:00.000 | 2021-03-15 10:34:35.975 HD Request # 27 | Download start date-time: 2021-02-22 11:29:00.000000. File last date-time: 00:00:00.000000 | 2021-03-15 10:34:35.975 HD Request # 27 | Using server: ds21.sierracharts.com port 10150 | 2021-03-15 10:34:35.976 Socket (7) | Creating socket. | 2021-03-15 10:34:35.976 Socket (7) | New receive buffer size: 5242880 | 2021-03-15 10:34:35.976 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-03-15 10:34:35.976 Socket (6) | Socket gracefully closed by remote side. | 2021-03-15 10:34:36.036 Socket (6) | Closed. | 2021-03-15 10:34:36.036 HD Request # 27 | Setting DTC encoding to Binary VLS | 2021-03-15 10:34:36.110 HD Request # 27 | Sending historical data logon request message. | 2021-03-15 10:34:36.110 HD Request # 27 | Requesting Intraday data. Start date-time: 2021-02-22 11:29:00. Record interval: 0. Symbol: CLH21 | 2021-03-15 10:34:36.174 HD Request # 27 | Decompressing data. | 2021-03-15 10:34:36.238 HD Request # 27 | Receiving Intraday data for F.US.CLEH21 starting at 2021-02-22 11:29:00.653000 | 2021-03-15 10:34:36.239 HD Request # 27 | Rounded first tick record Date-time down to minute: 2021-02-22 11:29:00 | 2021-03-15 10:34:36.239 HD Request # 27 | Truncated Intraday data file at 2021-02-22 11:29:00 while receiving initial tick data during multistage download. | 2021-03-15 10:34:36.239 HD Request # 27 | Date-time after truncate 2021-02-22 11:28:58 | 2021-03-15 10:34:36.239 Socket (7) | CloseSocket call. | 2021-03-15 10:34:36.240 Socket (7) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-15 10:34:36.240 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-03-15 10:34:36.240 Historical data download thread signaled to stop. | 2021-03-15 10:34:36.243 HD Request # 27 | Timestamp of first Intraday data file record written: 2021-02-22 11:29:00.653000 | 2021-03-15 10:34:36.243 HD Request # 27 | Received 7 records from 2021-02-22 11:29:00.653000 to 2021-02-22 11:29:37.288000 (36.6 seconds) and wrote 7 records for F.US.CLEH21 | 2021-03-15 10:34:36.243 HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2021-02-22 19:29:37.288000 | 2021-03-15 10:34:36.247 HD Request # 27 | Completion time: 1s | 2021-03-15 10:34:36.247 HD Request # 27 | Intraday data download complete for F.US.CLEH21. Unique request ID: 22 | 2021-03-15 10:34:36.247 Removing historical data download ID 22. | 2021-03-15 10:34:36.247 Real-time Intraday chart data file updates started for F.US.CLEH21 | 2021-03-15 10:34:36.247 Intraday chart data file opened for F.US.CLEH21 | 2021-03-15 10:34:36.247 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2021-03-15 10:34:36.247 F.US.CLEH21 [CV][M] 15 Min #2 | Flagging to reload Intraday data on download completion. | 2021-03-15 10:34:36.247 F.US.CLEH21 [CV][M] 15 Min #3 | Flagging to reload Intraday data on download completion. | 2021-03-15 10:34:36.247 Triggering next historical data download in queue. | 2021-03-15 10:34:36.247 No download requests in the queue to start downloads for. | 2021-03-15 10:34:36.247 Socket (7) | Socket gracefully closed by remote side. | 2021-03-15 10:34:36.307 Socket (7) | Closed. | 2021-03-15 10:34:36.307 F.US.CLEH21 [CV][M] 15 Min #3 | Reloading chart. | 2021-03-15 10:34:36.482 F.US.CLEH21 [CV][M] 15 Min #3 | Performing historical Daily data download for symbol F.US.CLEH21 starting at last date in file. | 2021-03-15 10:34:36.520 Added historical Daily data request for F.US.CLEH21 to the queue. | 2021-03-15 10:34:36.520 Triggering next historical data download in queue. | 2021-03-15 10:34:36.520 F.US.CLEH21 [CV][M] 15 Min #3 | Waiting for historical downloads to complete with the IDs: 23, | 2021-03-15 10:34:36.537 HD Request # 28 | Downloading Historical Daily chart data for F.US.CLEH21. Starting date: 2021-02-18. Service: cqg | 2021-03-15 10:34:36.539 HD Request # 28 | Requesting historical Daily data for CLH21 starting at 2021-02-17. SC External HD service. | 2021-03-15 10:34:36.539 F.US.CLEH21 [CV][M] 15 Min #2 | Reloading chart. | 2021-03-15 10:34:36.732 F.US.CLEH21 [CV][M] 15 Min #2 | Waiting for historical downloads to complete with the IDs: 23, | 2021-03-15 10:34:36.750 HD Request # 28 | Receiving historical Daily data for F.US.CLEH21 starting at 2021-02-18 | 2021-03-15 10:34:37.840 HD Request # 28 | Writing historical Daily data to the file F.US.CLEH21.dly | 2021-03-15 10:34:37.840 HD Request # 28 | Bytes received: 214 | 2021-03-15 10:34:37.849 HD Request # 28 | Received 4 records from 2021-02-18 00:00:00 to 2021-02-22 00:00:00 (5.0 days) and wrote 3 records for F.US.CLEH21 | 2021-03-15 10:34:37.849 HD Request # 28 | Completion time: 1s | 2021-03-15 10:34:37.854 HD Request # 28 | Daily data download complete for F.US.CLEH21. Unique request ID: 23 | 2021-03-15 10:34:37.854 Removing historical data download ID 23. | 2021-03-15 10:34:37.854 Triggering next historical data download in queue. | 2021-03-15 10:34:37.854 No download requests in the queue to start downloads for. | 2021-03-15 10:34:37.854 F.US.CLEH21 [CV][M] 15 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-03-15 10:34:38.050 F.US.CLEH21 [CV][M] 15 Min #3 | Reloading chart. | 2021-03-15 10:34:38.050 F.US.CLEH21 [CV][M] 15 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-03-15 10:34:38.244 F.US.CLEH21 [CV][M] 15 Min #2 | Reloading chart. | 2021-03-15 10:34:38.245 F.US.CLEH21 [CV][M] 15 Min #3 | Reloading chart. | 2021-03-15 10:34:38.607 F.US.CLEH21 [CV][M] 15 Min #2 | Reloading chart. | 2021-03-15 10:34:38.792 Opened cached Intraday file: D:\My Documents\Trading\Sierra Charts\Data\F.US.EPM21.scid. Thread ID: 10080 | 2021-03-15 10:34:39.927 Opened cached Intraday file: D:\My Documents\Trading\Sierra Charts\Data\F.US.GCEJ21.scid. Thread ID: 10080 | 2021-03-15 10:34:39.927 Opened cached Intraday file: D:\My Documents\Trading\Sierra Charts\Data\F.US.MESH21.scid. Thread ID: 10080 | 2021-03-15 10:34:39.928 Opened cached Intraday file: D:\My Documents\Trading\Sierra Charts\Data\F.US.RTYH21.scid. Thread ID: 10080 | 2021-03-15 10:34:39.928 Opened cached Intraday file: D:\My Documents\Trading\Sierra Charts\Data\F.US.MNQH21.scid. Thread ID: 10080 | 2021-03-15 10:34:39.928 |
