Date/Time: Tue, 14 May 2024 18:39:25 +0000
[Locked] - EUREX Data feed setup
View Count: 2063
[2021-02-09 15:35:11] |
User98716 - Posts: 10 |
Hello, I'm a bit confused as to which method I need to follow to setup the Eurex Datafeed. From what I can tell there are two methods below: 1 - Sierra Chart Exchange Data Feed, including Setup Instructions refer to the Sierra Chart Exchange Data Feed page. 2 - Denali Exchange Data Feed, including Setup Instructions, refer to the Denali Exchange Data Feed page. I'm currently classed as a non-professional trader as I trade privately at home. I see you have just about got everything set up in EUREX data centre with the feed starting to come through. So I'm looking to get things set up on my end as well. As I would like to start receiving the EUREX DAX market depth data feed from you. I would also like to see how this compares against the IQ feed I'm currently subscribed to. I noticed from the current posts (New Upcoming EUREX Full Order Book Data Feed (Now Available!)) its mentioned it's free this month while you double check everything. If you are able to set up the subscription for me or tell me which route to take (Sierra Chart Exchange Data Feed or Danali Exchange Data Feed) I would appreciate it. Regards, Richard |
[2021-02-09 17:40:12] |
John - SC Support - Posts: 31608 |
If you can wait another day or two, then the new implementation should be ready to be used. When available, it will be part of the Denali Exchange Data Feed, but there is no requirement for a funded trading account (that is a CME Group requirement). Just watch that thread that you reference for when this is available. If you cannot wait, then you would need to setup the Sierra Chart Exchange Data Feed and enable the EUREX exchange. You will be eventually moved to the new implementation. Refer to the information here: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-09 20:55:35] |
We should have this released late this evening through the Denali data feed.
[2021-02-10 12:00:47] |
I've enabled the Denali data feed and followed the instructions to set up real time data feed for the EUREX Dax futures market. However I'm not getting any real time data coming through. It appears to only be historic data. There is no [M] next to the symbol as well. I was previously using IQFeed before switching over to SC Data - All Services. The symbol when using IQFeed for the Dax market is XG# whereas when using SC Data - All Services feed the symbol is FDAXH21-EUREX. Unfortunately when selecting translate symbol to current service it doesn't work. I have to manually change the symbol. In any case even once manually changed it still doesn't work. I've tried following the Sierra Chart Software Instructions section but it still doesn't work - Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Attached is a screenshot. Date Time Of Last Edit: 2021-02-10 12:06:31
Screenshot 2021-02-10 114116.png / V - Attached On 2021-02-10 11:59:53 UTC - Size: 175.61 KB - 233 views Attachment Deleted. Screenshot 2021-02-10 120602.png / V - Attached On 2021-02-10 12:06:25 UTC - Size: 29.81 KB - 233 views |
[2021-02-10 12:44:16] |
We had to delay the release of this new EUREX data feed. We should be ready to release it this evening. More information is here: IMPORTANT NOTICE : Regarding EUREX Data Interruption for Users (SC Exchange Data Feed) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-11 07:55:00] |
I see the EUREX data feed is released again on the Denali Exchange data feed as indicated on the thread New Upcoming EUREX Full Order Book Data Feed (Now Available!) I've got the pre-release version 2227, Denali Exchange data feed active and SC Data - All Services selected. I'm not receiving any real time data, it's stuck on historical data. I don't have the [M] next to the symbol to indicate real time data. Screenshot attached. |
Screenshot 2021-02-11 075051.png / V - Attached On 2021-02-11 07:54:50 UTC - Size: 12.12 KB - 233 views |
[2021-02-11 10:01:03] |
User120666 - Posts: 46 |
I have the same issue - I have got everything setup but it's not moving in real time. If I run a delete and download data it refreshes the data, but it doesn't move again from that point onwards. How do I get the real-time data please? |
[2021-02-11 10:19:15] |
Regarding post #6 and #7, we need you to do the following so we can determine what the problem is: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-11 10:35:52] |
Software version: 2227 64-bit | 2021-02-11 10:34:48.323 Primary Thread ID: 10028 | 2021-02-11 10:34:48.323 Usage end date: 2021-04-16 | 2021-02-11 10:34:48.323 Enabled for: Advanced Features 2. | 2021-02-11 10:34:48.323 Enabled for: Sierra Chart Historical Data Service. | 2021-02-11 10:34:48.323 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-11 10:34:48.323 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-11 10:34:48.323 Current selected Data/Trading service: SC Data - All Services | 2021-02-11 10:34:48.323 Custom symbol settings values: disabled | 2021-02-11 10:34:48.323 Chart Update Interval: 500 | 2021-02-11 10:34:48.323 Intraday Data Storage Time Unit: 0 | 2021-02-11 10:34:48.323 Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2021-02-11 10:34:48.323 2021-02-11 10:34:48 Local computer time in UTC | 2021-02-11 10:34:48.323 2021-02-11 10:34:48 Local computer time in SC Time Zone | 2021-02-11 10:34:48.323 2021-02-11 10:30:10 Server time in UTC | 2021-02-11 10:34:48.323 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-02-11 10:34:48.323 Program path: C:\SierraChart\ | 2021-02-11 10:34:48.323 Data Files path: C:\SierraChart\Data\ | 2021-02-11 10:34:48.323 OS Version Number: 10.0 | 2021-02-11 10:34:48.324 Locale Setting: C | 2021-02-11 10:34:48.324 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-02-11 10:34:48.324 Allowed protected custom studies: | 2021-02-11 10:34:48.324 File >> Disconnect selected. | 2021-02-11 10:34:51.452 SC Data - All Services | Disconnected. | 2021-02-11 10:34:51.453 SC Data - All Services | Connected to server complete. | 2021-02-11 10:34:54.034 Triggering next historical data download in queue. | 2021-02-11 10:34:54.035 Triggering next historical data download in queue. | 2021-02-11 10:34:54.035 Triggering next historical data download in queue. | 2021-02-11 10:34:54.035 Triggering next historical data download in queue. | 2021-02-11 10:34:54.035 No download requests in the queue to start downloads for. | 2021-02-11 10:34:54.035 No download requests in the queue to start downloads for. | 2021-02-11 10:34:54.035 No download requests in the queue to start downloads for. | 2021-02-11 10:34:54.035 No download requests in the queue to start downloads for. | 2021-02-11 10:34:54.035 SC Data - All Services | Starting real-time market data updates for: FDAXH21-EUREX. ID: 1 Service code: eurex | 2021-02-11 10:34:54.280 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: FDAXH21-EUREX | 2021-02-11 10:34:54.280 SC Data - All Services | Requesting security definition data for: FDAXH21-EUREX. ID: 1 | 2021-02-11 10:34:54.280 Added historical Intraday data request for FDAXH21-EUREX to the queue. | 2021-02-11 10:34:54.280 Intraday data recording state for symbol FDAXH21-EUREX is set to download 'Pending'. | 2021-02-11 10:34:54.280 Triggering next historical data download in queue. | 2021-02-11 10:34:54.281 Delaying start of download for FDAXH21-EUREX | 2021-02-11 10:34:54.295 HD Request # 14 | Downloading Intraday chart data for FDAXH21-EUREX to the file FDAXH21-EUREX.scid. Service: eurex | 2021-02-11 10:34:59.459 HD Request # 14 | Download start date-time: 2021-02-11 10:21:39.000000. File last date-time: 2021-02-11 10:21:39.395000 | 2021-02-11 10:34:59.460 HD Request # 14 | Using server: ds14.sierracharts.com port 10149 | 2021-02-11 10:34:59.460 Socket (1) | Creating socket. | 2021-02-11 10:34:59.460 Socket (1) | New receive buffer size: 5242880 | 2021-02-11 10:34:59.460 Socket (1) | Connecting to IP: 157.90.1.40. | 2021-02-11 10:34:59.460 HD Request # 14 | Setting DTC encoding to Binary VLS | 2021-02-11 10:34:59.530 HD Request # 14 | Sending historical data logon request message. | 2021-02-11 10:34:59.530 HD Request # 14 | Requesting Intraday data. Start date-time: 2021-02-11 10:21:39. Record interval: 0. Symbol: FDAX202103_FUT_EUREX | 2021-02-11 10:34:59.579 HD Request # 14 | Decompressing data. | 2021-02-11 10:34:59.617 HD Request # 14 | Receiving Intraday data for FDAXH21-EUREX starting at 2021-02-11 10:21:39.395000 | 2021-02-11 10:34:59.618 Socket (1) | CloseSocket call. | 2021-02-11 10:34:59.619 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 10:34:59.619 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-11 10:34:59.619 Historical data download thread signaled to stop. | 2021-02-11 10:34:59.619 HD Request # 14 | Timestamp of first Intraday data file record written: 2021-02-11 10:21:47.958000 | 2021-02-11 10:34:59.619 HD Request # 14 | Received 185 records from 2021-02-11 10:21:39.395000 to 2021-02-11 10:24:52.000000 (3.2 minutes) and wrote 184 records for FDAXH21-EUREX | 2021-02-11 10:34:59.619 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2021-02-11 10:24:52.000000 | 2021-02-11 10:34:59.633 HD Request # 14 | Completion time: 0s | 2021-02-11 10:34:59.633 HD Request # 14 | Intraday data download complete for FDAXH21-EUREX. Unique request ID: 15 | 2021-02-11 10:34:59.633 Removing historical data download ID 15. | 2021-02-11 10:34:59.633 Real-time Intraday chart data file updates started for FDAXH21-EUREX | 2021-02-11 10:34:59.633 Intraday chart data file opened for FDAXH21-EUREX | 2021-02-11 10:34:59.633 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2021-02-11 10:34:59.633 Triggering next historical data download in queue. | 2021-02-11 10:34:59.633 No download requests in the queue to start downloads for. | 2021-02-11 10:34:59.633 Socket (1) | Socket gracefully closed by remote side. | 2021-02-11 10:34:59.652 Socket (1) | Closed. | 2021-02-11 10:34:59.652 |
[2021-02-11 10:37:28] |
There's the message log - current time is 10.36 am and last bar is 10.20am ish (5 min bars)... no fresh data after the re-connect
[2021-02-11 10:44:54] |
There is the requirement to activate the Denali Exchange Data Feed here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed But you do not have to activate any exchange Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-11 10:53:14] |
I have now activated denali as instructed, but still no live data. It comes on, refreshes to current bar, then just stops...
[2021-02-11 10:55:13] |
Software version: 2227 64-bit | 2021-02-11 10:54:08.460 Primary Thread ID: 5908 | 2021-02-11 10:54:08.460 Usage end date: 2021-04-16 | 2021-02-11 10:54:08.460 Enabled for: Advanced Features 2. | 2021-02-11 10:54:08.460 Enabled for: Sierra Chart Historical Data Service. | 2021-02-11 10:54:08.460 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-02-11 10:54:08.460 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-11 10:54:08.460 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-11 10:54:08.460 Current selected Data/Trading service: SC Data - All Services | 2021-02-11 10:54:08.460 Custom symbol settings values: disabled | 2021-02-11 10:54:08.460 Chart Update Interval: 500 | 2021-02-11 10:54:08.460 Intraday Data Storage Time Unit: 0 | 2021-02-11 10:54:08.460 Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2021-02-11 10:54:08.460 2021-02-11 10:54:08 Local computer time in UTC | 2021-02-11 10:54:08.460 2021-02-11 10:54:08 Local computer time in SC Time Zone | 2021-02-11 10:54:08.460 2021-02-11 10:53:15 Server time in UTC | 2021-02-11 10:54:08.460 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-02-11 10:54:08.460 Program path: C:\SierraChart\ | 2021-02-11 10:54:08.460 Data Files path: C:\SierraChart\Data\ | 2021-02-11 10:54:08.460 OS Version Number: 10.0 | 2021-02-11 10:54:08.461 Locale Setting: C | 2021-02-11 10:54:08.461 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-02-11 10:54:08.461 Allowed protected custom studies: | 2021-02-11 10:54:08.461 File >> Disconnect selected. | 2021-02-11 10:54:13.763 SC Data - All Services | Disconnected. | 2021-02-11 10:54:13.764 SC Data - All Services | Connected to server complete. | 2021-02-11 10:54:16.594 Triggering next historical data download in queue. | 2021-02-11 10:54:16.594 Triggering next historical data download in queue. | 2021-02-11 10:54:16.594 Triggering next historical data download in queue. | 2021-02-11 10:54:16.594 Triggering next historical data download in queue. | 2021-02-11 10:54:16.594 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-02-11 10:54:16.594 No download requests in the queue to start downloads for. | 2021-02-11 10:54:16.594 No download requests in the queue to start downloads for. | 2021-02-11 10:54:16.594 No download requests in the queue to start downloads for. | 2021-02-11 10:54:16.594 No download requests in the queue to start downloads for. | 2021-02-11 10:54:16.594 SC Data - All Services | Starting real-time market data updates for: FDAXH21-EUREX. ID: 1 Service code: eurex | 2021-02-11 10:54:16.748 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: FDAXH21-EUREX | 2021-02-11 10:54:16.748 SC Data - All Services | Requesting security definition data for: FDAXH21-EUREX. ID: 1 | 2021-02-11 10:54:16.748 Added historical Intraday data request for FDAXH21-EUREX to the queue. | 2021-02-11 10:54:16.748 Intraday data recording state for symbol FDAXH21-EUREX is set to download 'Pending'. | 2021-02-11 10:54:16.748 Triggering next historical data download in queue. | 2021-02-11 10:54:16.748 Delaying start of download for FDAXH21-EUREX | 2021-02-11 10:54:16.765 HD Request # 2 | Downloading Intraday chart data for FDAXH21-EUREX to the file FDAXH21-EUREX.scid. Service: eurex | 2021-02-11 10:54:21.597 HD Request # 2 | Download start date-time: 2021-02-11 10:53:38.000000. File last date-time: 2021-02-11 10:53:38.462000 | 2021-02-11 10:54:21.598 HD Request # 2 | Using server: ds14.sierracharts.com port 10150 | 2021-02-11 10:54:21.598 Socket (1) | Creating socket. | 2021-02-11 10:54:21.598 Socket (1) | New receive buffer size: 5242880 | 2021-02-11 10:54:21.598 Socket (1) | Connecting to IP: 157.90.1.40. | 2021-02-11 10:54:21.598 HD Request # 2 | Setting DTC encoding to Binary VLS | 2021-02-11 10:54:21.667 HD Request # 2 | Sending historical data logon request message. | 2021-02-11 10:54:21.667 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-02-11 10:53:38. Record interval: 0. Symbol: FDAX202103_FUT_EUREX | 2021-02-11 10:54:21.753 HD Request # 2 | Decompressing data. | 2021-02-11 10:54:21.791 HD Request # 2 | Receiving Intraday data for FDAXH21-EUREX starting at 2021-02-11 10:53:38.456000 | 2021-02-11 10:54:21.792 Socket (1) | CloseSocket call. | 2021-02-11 10:54:21.792 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 10:54:21.792 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-11 10:54:21.793 Historical data download thread signaled to stop. | 2021-02-11 10:54:21.796 HD Request # 2 | Timestamp of first Intraday data file record written: 2021-02-11 10:53:45.522000 | 2021-02-11 10:54:21.796 HD Request # 2 | Received 9 records from 2021-02-11 10:53:38.456000 to 2021-02-11 10:54:08.666000 (30.2 seconds) and wrote 6 records for FDAXH21-EUREX | 2021-02-11 10:54:21.796 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2021-02-11 10:54:08.666000 | 2021-02-11 10:54:21.807 HD Request # 2 | Completion time: 0s | 2021-02-11 10:54:21.807 HD Request # 2 | Intraday data download complete for FDAXH21-EUREX. Unique request ID: 2 | 2021-02-11 10:54:21.807 Removing historical data download ID 2. | 2021-02-11 10:54:21.807 Real-time Intraday chart data file updates started for FDAXH21-EUREX | 2021-02-11 10:54:21.807 Intraday chart data file opened for FDAXH21-EUREX | 2021-02-11 10:54:21.807 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-02-11 10:54:21.807 Triggering next historical data download in queue. | 2021-02-11 10:54:21.807 No download requests in the queue to start downloads for. | 2021-02-11 10:54:21.807 Socket (1) | Socket gracefully closed by remote side. | 2021-02-11 10:54:21.826 Socket (1) | Closed. | 2021-02-11 10:54:21.826 |
[2021-02-11 10:56:57] |
Currant time is 10.57am, last 1 minute bar is 10.54am...
[2021-02-11 11:16:03] |
Follow the instructions here to perform a Forced Login: Sierra Chart - Software Login Instructions: Forced Login Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-11 11:22:11] |
OK done... same issue, no live data...
[2021-02-11 11:23:11] |
Software version: 2227 64-bit | 2021-02-11 11:22:24.732 Primary Thread ID: 10732 | 2021-02-11 11:22:24.732 Usage end date: 2021-04-16 | 2021-02-11 11:22:24.732 Enabled for: Advanced Features 2. | 2021-02-11 11:22:24.732 Enabled for: Sierra Chart Historical Data Service. | 2021-02-11 11:22:24.732 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-02-11 11:22:24.732 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-11 11:22:24.732 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-11 11:22:24.732 Current selected Data/Trading service: SC Data - All Services | 2021-02-11 11:22:24.732 Custom symbol settings values: disabled | 2021-02-11 11:22:24.732 Chart Update Interval: 500 | 2021-02-11 11:22:24.732 Intraday Data Storage Time Unit: 0 | 2021-02-11 11:22:24.732 Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2021-02-11 11:22:24.732 2021-02-11 11:22:24 Local computer time in UTC | 2021-02-11 11:22:24.732 2021-02-11 11:22:24 Local computer time in SC Time Zone | 2021-02-11 11:22:24.732 2021-02-11 11:21:22 Server time in UTC | 2021-02-11 11:22:24.732 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-02-11 11:22:24.732 Program path: C:\SierraChart\ | 2021-02-11 11:22:24.732 Data Files path: C:\SierraChart\Data\ | 2021-02-11 11:22:24.732 OS Version Number: 10.0 | 2021-02-11 11:22:24.732 Locale Setting: C | 2021-02-11 11:22:24.732 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-02-11 11:22:24.732 Allowed protected custom studies: | 2021-02-11 11:22:24.732 File >> Disconnect selected. | 2021-02-11 11:22:38.515 SC Data - All Services | Disconnected. | 2021-02-11 11:22:38.515 SC Data - All Services | Connected to server complete. | 2021-02-11 11:22:41.372 Triggering next historical data download in queue. | 2021-02-11 11:22:41.372 Triggering next historical data download in queue. | 2021-02-11 11:22:41.372 Triggering next historical data download in queue. | 2021-02-11 11:22:41.372 Triggering next historical data download in queue. | 2021-02-11 11:22:41.372 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-02-11 11:22:41.372 No download requests in the queue to start downloads for. | 2021-02-11 11:22:41.373 No download requests in the queue to start downloads for. | 2021-02-11 11:22:41.373 No download requests in the queue to start downloads for. | 2021-02-11 11:22:41.373 No download requests in the queue to start downloads for. | 2021-02-11 11:22:41.373 SC Data - All Services | Starting real-time market data updates for: FDAXH21-EUREX. ID: 1 Service code: eurex | 2021-02-11 11:22:41.487 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: FDAXH21-EUREX | 2021-02-11 11:22:41.487 SC Data - All Services | Requesting security definition data for: FDAXH21-EUREX. ID: 1 | 2021-02-11 11:22:41.487 Added historical Intraday data request for FDAXH21-EUREX to the queue. | 2021-02-11 11:22:41.487 Intraday data recording state for symbol FDAXH21-EUREX is set to download 'Pending'. | 2021-02-11 11:22:41.487 Triggering next historical data download in queue. | 2021-02-11 11:22:41.487 Delaying start of download for FDAXH21-EUREX | 2021-02-11 11:22:41.509 HD Request # 2 | Downloading Intraday chart data for FDAXH21-EUREX to the file FDAXH21-EUREX.scid. Service: eurex | 2021-02-11 11:22:46.534 HD Request # 2 | Download start date-time: 2021-02-11 11:21:30.000000. File last date-time: 2021-02-11 11:21:30.464000 | 2021-02-11 11:22:46.535 HD Request # 2 | Using server: ds14.sierracharts.com port 10149 | 2021-02-11 11:22:46.535 Socket (1) | Creating socket. | 2021-02-11 11:22:46.535 Socket (1) | New receive buffer size: 5242880 | 2021-02-11 11:22:46.536 Socket (1) | Connecting to IP: 157.90.1.40. | 2021-02-11 11:22:46.536 HD Request # 2 | Setting DTC encoding to Binary VLS | 2021-02-11 11:22:46.614 HD Request # 2 | Sending historical data logon request message. | 2021-02-11 11:22:46.614 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-02-11 11:21:30. Record interval: 0. Symbol: FDAX202103_FUT_EUREX | 2021-02-11 11:22:46.665 HD Request # 2 | Decompressing data. | 2021-02-11 11:22:46.703 HD Request # 2 | Receiving Intraday data for FDAXH21-EUREX starting at 2021-02-11 11:21:30.464000 | 2021-02-11 11:22:46.704 Socket (1) | CloseSocket call. | 2021-02-11 11:22:46.704 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 11:22:46.704 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-11 11:22:46.704 Historical data download thread signaled to stop. | 2021-02-11 11:22:46.704 HD Request # 2 | Timestamp of first Intraday data file record written: 2021-02-11 11:21:40.980000 | 2021-02-11 11:22:46.705 HD Request # 2 | Received 19 records from 2021-02-11 11:21:30.464000 to 2021-02-11 11:22:40.317000 (69.9 seconds) and wrote 18 records for FDAXH21-EUREX | 2021-02-11 11:22:46.705 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2021-02-11 11:22:40.317000 | 2021-02-11 11:22:46.716 HD Request # 2 | Completion time: 0s | 2021-02-11 11:22:46.716 HD Request # 2 | Intraday data download complete for FDAXH21-EUREX. Unique request ID: 2 | 2021-02-11 11:22:46.716 Removing historical data download ID 2. | 2021-02-11 11:22:46.716 Real-time Intraday chart data file updates started for FDAXH21-EUREX | 2021-02-11 11:22:46.716 Intraday chart data file opened for FDAXH21-EUREX | 2021-02-11 11:22:46.716 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-02-11 11:22:46.716 Triggering next historical data download in queue. | 2021-02-11 11:22:46.716 No download requests in the queue to start downloads for. | 2021-02-11 11:22:46.716 Socket (1) | Socket gracefully closed by remote side. | 2021-02-11 11:22:46.743 Socket (1) | Closed. | 2021-02-11 11:22:46.743 |
[2021-02-11 11:24:04] |
That's the message log after the forced login. I opened Sierra, clicked cancel, ticked the force login box, then clicked login. Then cleared message log and that's what I've sent above. |
[2021-02-11 12:51:11] |
We apologize for the delay and the issue. We will do our best to get this resolved today but it may not be until tomorrow. As an alternative, we will release the EUREX exchange option with a cost of 0 USD so it can be activated. So we do not have to use these methods of providing access which obviously are having a problem in some cases. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-11 12:51:26
[2021-02-11 12:57:48] |
ok thanks - is that ready now? Where do I need to go to activate that please?
[2021-02-11 13:47:47] |
Software version: 2227 64-bit | 2021-02-11 13:43:15.031 Primary Thread ID: 9696 | 2021-02-11 13:43:15.031 Usage end date: 2021-02-26 | 2021-02-11 13:43:15.031 Enabled for: Advanced Features 2. | 2021-02-11 13:43:15.031 Enabled for: Sierra Chart Historical Data Service. | 2021-02-11 13:43:15.031 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-02-11 13:43:15.031 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-11 13:43:15.031 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-11 13:43:15.031 Current selected Data/Trading service: SC Data - All Services | 2021-02-11 13:43:15.031 Custom symbol settings values: enabled | 2021-02-11 13:43:15.031 Chart Update Interval: 500 | 2021-02-11 13:43:15.031 Intraday Data Storage Time Unit: 0 | 2021-02-11 13:43:15.031 Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2021-02-11 13:43:15.031 2021-02-11 13:43:15 Local computer time in UTC | 2021-02-11 13:43:15.031 2021-02-11 13:43:15 Local computer time in SC Time Zone | 2021-02-11 13:43:15.031 2021-02-11 13:40:10 Server time in UTC | 2021-02-11 13:43:15.031 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-02-11 13:43:15.031 Program path: C:\SierraChart\ | 2021-02-11 13:43:15.031 Data Files path: C:\SierraChart\Data\ | 2021-02-11 13:43:15.031 OS Version Number: 10.0 | 2021-02-11 13:43:15.031 Locale Setting: C | 2021-02-11 13:43:15.031 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-02-11 13:43:15.031 Allowed protected custom studies: | 2021-02-11 13:43:15.031 File >> Disconnect selected. | 2021-02-11 13:44:43.229 SC Data - All Services | Disconnected. | 2021-02-11 13:44:43.233 SC Data - All Services | Connected to server complete. | 2021-02-11 13:44:49.873 Triggering next historical data download in queue. | 2021-02-11 13:44:49.873 Triggering next historical data download in queue. | 2021-02-11 13:44:49.873 Triggering next historical data download in queue. | 2021-02-11 13:44:49.873 Triggering next historical data download in queue. | 2021-02-11 13:44:49.873 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-02-11 13:44:49.873 No download requests in the queue to start downloads for. | 2021-02-11 13:44:49.877 No download requests in the queue to start downloads for. | 2021-02-11 13:44:49.877 No download requests in the queue to start downloads for. | 2021-02-11 13:44:49.877 No download requests in the queue to start downloads for. | 2021-02-11 13:44:49.877 SC Data - All Services | Starting real-time market data updates for: FDAXH21-EUREX. ID: 1 Service code: eurex | 2021-02-11 13:44:49.951 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: FDAXH21-EUREX | 2021-02-11 13:44:49.951 SC Data - All Services | Requesting security definition data for: FDAXH21-EUREX. ID: 1 | 2021-02-11 13:44:49.951 Added historical Intraday data request for FDAXH21-EUREX to the queue. | 2021-02-11 13:44:49.952 Intraday data recording state for symbol FDAXH21-EUREX is set to download 'Pending'. | 2021-02-11 13:44:49.952 Triggering next historical data download in queue. | 2021-02-11 13:44:49.952 Delaying start of download for FDAXH21-EUREX | 2021-02-11 13:44:50.246 HD Request # 3 | Downloading Intraday chart data for FDAXH21-EUREX to the file FDAXH21-EUREX.scid. Service: eurex | 2021-02-11 13:44:54.869 HD Request # 3 | Download start date-time: 2021-02-11 13:41:40.000000. File last date-time: 2021-02-11 13:41:40.871000 | 2021-02-11 13:44:54.871 HD Request # 3 | Using server: ds14.sierracharts.com port 10150 | 2021-02-11 13:44:54.871 Socket (1) | Creating socket. | 2021-02-11 13:44:54.871 Socket (1) | New receive buffer size: 5242880 | 2021-02-11 13:44:54.871 Socket (1) | Connecting to IP: 157.90.1.40. | 2021-02-11 13:44:54.871 HD Request # 3 | Setting DTC encoding to Binary VLS | 2021-02-11 13:44:54.946 HD Request # 3 | Sending historical data logon request message. | 2021-02-11 13:44:54.946 HD Request # 3 | Requesting Intraday data. Start date-time: 2021-02-11 13:41:40. Record interval: 0. Symbol: FDAX202103_FUT_EUREX | 2021-02-11 13:44:55.003 HD Request # 3 | Decompressing data. | 2021-02-11 13:44:55.040 HD Request # 3 | Receiving Intraday data for FDAXH21-EUREX starting at 2021-02-11 13:41:40.871000 | 2021-02-11 13:44:55.040 Socket (1) | CloseSocket call. | 2021-02-11 13:44:55.041 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-11 13:44:55.041 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-11 13:44:55.042 Socket (1) | Socket gracefully closed by remote side. | 2021-02-11 13:44:55.075 Socket (1) | Closed. | 2021-02-11 13:44:55.076 Historical data download thread signaled to stop. | 2021-02-11 13:44:55.389 HD Request # 3 | Timestamp of first Intraday data file record written: 2021-02-11 13:41:46.623000 | 2021-02-11 13:44:55.389 HD Request # 3 | Received 98 records from 2021-02-11 13:41:40.871000 to 2021-02-11 13:44:52.193000 (3.2 minutes) and wrote 97 records for FDAXH21-EUREX | 2021-02-11 13:44:55.390 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2021-02-11 13:44:52.193000 | 2021-02-11 13:44:55.392 HD Request # 3 | Completion time: 1s | 2021-02-11 13:44:55.392 HD Request # 3 | Intraday data download complete for FDAXH21-EUREX. Unique request ID: 3 | 2021-02-11 13:44:55.392 Removing historical data download ID 3. | 2021-02-11 13:44:55.392 Real-time Intraday chart data file updates started for FDAXH21-EUREX | 2021-02-11 13:44:55.392 Intraday chart data file opened for FDAXH21-EUREX | 2021-02-11 13:44:55.392 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2021-02-11 13:44:55.392 Triggering next historical data download in queue. | 2021-02-11 13:44:55.392 No download requests in the queue to start downloads for. | 2021-02-11 13:44:55.392 |
[2021-02-11 13:49:10] |
Above is my message log for the issues I'm having. I've been subscribed to the Denali Exchange Data Feed since yesterday and signed the correct documents to receive realtime data.
[2021-02-11 23:06:01] |
We are still working on this, but you can activate the EUREX exchange here at no cost: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliEUREX That will ensure you get access. You do need to complete the related documents first though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-12 09:00:42] |
Is this something I'll need to do once you have everything fixed properly, or do you just mean in the meantime while you fix it?
[2021-02-12 09:04:03] |
By the end of next week you will need to enable the EUREX exchange. So yes you will eventually have to do that anyway.
