Date/Time: Mon, 06 Feb 2023 07:08:27 +0000
Teton Real Time Data
View Count: 119
[2022-09-26 09:46:58] |
User122704 - Posts: 12 |
Team SC I am logged into SC, have updated to most current version, have Teton, but I am not recieving any realtime data on my charts and can not figure out what is wrong. Have not had this issue before. Please advise if you are able. Thank you for your time. |
[2022-09-26 10:22:56] |
Sierra_Chart Engineering - Posts: 6483 |
Make sure this option is set to Yes: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) And translate the symbols if necessary: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-26 10:53:12] |
Thank you for the quick reply. The option was already selected "Yes" and I went ahead and translated symbols just to be safe. Still not working. Charts and real-time data were working Friday. I made no changes other than to reboot the computer and SC. When data didn't work tonight I updated to the current version and that didn't help either. any other ideas?
[2022-09-26 11:03:14] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-26 11:15:14] |
YM, MYM, NQ, MNQ Log: Software version: 2442 64-bit | 2022-09-26 07:08:01.887 Primary Thread ID: 9084 | 2022-09-26 07:08:01.887 Usage end date: 2022-10-11 | 2022-09-26 07:08:01.887 Enabled for: Advanced Features 2. | 2022-09-26 07:08:01.887 Enabled for: Sierra Chart Historical Data Service. | 2022-09-26 07:08:01.887 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-09-26 07:08:01.887 Enabled for: Delayed Denali Exchange Data Feed. | 2022-09-26 07:08:01.887 Enabled for exchange2: CME (Trading Account Required) | 2022-09-26 07:08:01.887 Enabled for exchange2: CBOT (Trading Account Required) | 2022-09-26 07:08:01.887 Enabled for exchange2: COMEX (Trading Account Required) | 2022-09-26 07:08:01.887 Enabled for exchange2: NYMEX (Trading Account Required) | 2022-09-26 07:08:01.887 Enabled for exchange2: fairx_exchange.data | 2022-09-26 07:08:01.887 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-09-26 07:08:01.887 Current selected Data/Trading service: Teton CME Order Routing | 2022-09-26 07:08:01.887 Custom symbol settings values: enabled | 2022-09-26 07:08:01.887 Chart Update Interval: 500 | 2022-09-26 07:08:01.887 Intraday Data Storage Time Unit: 0 | 2022-09-26 07:08:01.887 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-09-26 07:08:01.887 2022-09-26 11:08:01 Local computer time in UTC | 2022-09-26 07:08:01.887 2022-09-26 07:08:01 Local computer time in SC Time Zone | 2022-09-26 07:08:01.887 2022-09-26 09:20:40 Server time in UTC | 2022-09-26 07:08:01.887 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-09-26 07:08:01.887 Program path: C:\SierraChart\ | 2022-09-26 07:08:01.887 Data Files path: C:\SierraChart\Data\ | 2022-09-26 07:08:01.887 OS Version Number: 10.0 | 2022-09-26 07:08:01.887 Locale Setting: C | 2022-09-26 07:08:01.887 DLLs: ATR_Color_Bars_64.dll, PolarisTradingGroup_2151_64.dll, PolarisTradingGroup_DV_Strategy_64.dll, TTTLines.dll, TTTLines_64.dll, TTTRange.dll, TTTRange_64.dll, TTTStdDev.dll, TTTStdDev_64.dll, UserContributedStudies_64.dll, Zyp Free by Zyp_64.dll, Zyp OrderFlow by Zdislav_64.dll, Zyp Trade_Your_Plan_64.dll | 2022-09-26 07:08:01.888 Allowed protected custom studies: Polaris Trading Group, Polaris Trading Group DV Strategy, zyp_app | 2022-09-26 07:08:01.888 Crash reporter started: true | 2022-09-26 07:08:01.888 SC Data - All Services | Connecting to the server ds27.sierracharts.com. Port 10048 | 2022-09-26 07:08:21.433 DTC Client socket (3) | Creating socket. | 2022-09-26 07:08:21.433 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-09-26 07:08:21.433 DTC Client socket (3) | Connecting to IP: 208.185.224.128. | 2022-09-26 07:08:21.433 SC Data - All Services | Network connection to server complete. | 2022-09-26 07:08:21.494 SC Data - All Services | Starting socket receive thread. | 2022-09-26 07:08:21.494 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:08:21.495 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-26 07:08:21.570 SC Data - All Services | Sending logon request message. | 2022-09-26 07:08:21.570 SC Data - All Services | Received logon response. | 2022-09-26 07:08:22.257 SC Data - All Services | Server Name: RealTime Server. | 2022-09-26 07:08:22.257 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:08:22.257 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:08:22.257 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-26 07:08:22.257 DTC Client socket (3) | CloseSocket call. | 2022-09-26 07:08:22.257 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:08:22.257 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:08:22.257 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-09-26 07:08:22.257 DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-09-26 07:08:22.315 DTC Client socket (3) | Closed. | 2022-09-26 07:08:22.315 File >> Disconnect selected. | 2022-09-26 07:08:40.156 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-09-26 07:08:40.238 DTC Client socket (2) | CloseSocket call. | 2022-09-26 07:08:40.239 DTC Client socket (2) | Max send buffers used during socket life: 4 | 2022-09-26 07:08:40.239 DTC Client socket (2) | Max send buffer size during socket life: 253 | 2022-09-26 07:08:40.239 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:08:40.239 DTC Client socket (0) | CloseSocket call. | 2022-09-26 07:08:40.239 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:08:40.239 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-09-26 07:08:40.239 DTC Client socket (4) | CloseSocket call. | 2022-09-26 07:08:40.240 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:08:40.240 SC DTC Data with Market Depth | Disconnected from the server. | 2022-09-26 07:08:40.240 Teton CME Order Routing | Disconnected. | 2022-09-26 07:08:40.240 DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-09-26 07:08:40.299 DTC Client socket (2) | Closed. | 2022-09-26 07:08:40.300 Teton CME Order Routing | Firm: Dorman | 2022-09-26 07:08:48.417 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-09-26 07:08:48.417 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-09-26 07:08:48.446 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-09-26 07:08:48.446 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-09-26 07:08:48.446 Teton CME Order Routing | Network connection to server complete. | 2022-09-26 07:08:48.507 Teton CME Order Routing | Starting socket receive thread. | 2022-09-26 07:08:48.507 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-09-26 07:08:48.507 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-09-26 07:08:48.696 Teton CME Order Routing | Sending logon request message. | 2022-09-26 07:08:48.696 Teton CME Order Routing | Received logon response. | 2022-09-26 07:08:49.220 Teton CME Order Routing | Server Name: SC DTC Server. Build=43649. | 2022-09-26 07:08:49.220 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:08:49.220 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-09-26 07:08:49.220 Teton CME Order Routing | Trading is supported. | 2022-09-26 07:08:49.220 Teton CME Order Routing | Order cancel and replace is supported. | 2022-09-26 07:08:49.220 Teton CME Order Routing | OCO Orders supported. | 2022-09-26 07:08:49.220 Teton CME Order Routing | Bracket Orders supported. | 2022-09-26 07:08:49.220 Teton CME Order Routing | Connected to server complete. | 2022-09-26 07:08:49.220 Triggering next historical data download in queue. | 2022-09-26 07:08:49.221 Triggering next historical data download in queue. | 2022-09-26 07:08:49.221 Triggering next historical data download in queue. | 2022-09-26 07:08:49.221 Triggering next historical data download in queue. | 2022-09-26 07:08:49.221 Updated verified funded futures trading account ending date to: 2022-10-26 11:08:49 | 2022-09-26 07:08:49.221 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-09-26 07:08:49.299 No download requests in the queue to start downloads for. | 2022-09-26 07:08:49.299 No download requests in the queue to start downloads for. | 2022-09-26 07:08:49.299 No download requests in the queue to start downloads for. | 2022-09-26 07:08:49.299 No download requests in the queue to start downloads for. | 2022-09-26 07:08:49.300 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-09-26 09:28:54.239625 | 2022-09-26 07:08:49.302 Mapping MYMZ22_FUT_CME to MYMZ22. Service code: cbot | 2022-09-26 07:08:49.302 Using symbol data fast lookup vector | 2022-09-26 07:08:49.302 SC Data - All Services | Starting real-time market data updates for: MYMZ22_FUT_CME (MYMZ22). ID: 1 Service code: cbot | 2022-09-26 07:08:49.303 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-09-26 07:08:49.303 SC Data - All Services | Requesting security definition data for: MYMZ22_FUT_CME (MYMZ22). ID: 1 | 2022-09-26 07:08:49.303 DTC Client socket (3) | Creating socket. | 2022-09-26 07:08:49.303 Added historical Intraday data request for MYMZ22_FUT_CME to the queue. | 2022-09-26 07:08:49.303 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-09-26 07:08:49.303 Intraday data recording state for symbol MYMZ22_FUT_CME is set to download 'Pending'. | 2022-09-26 07:08:49.303 DTC Client socket (3) | Connecting to IP: 216.1.90.130. | 2022-09-26 07:08:49.303 Triggering next historical data download in queue. | 2022-09-26 07:08:49.303 Delaying start of download for MYMZ22_FUT_CME. | 2022-09-26 07:08:49.305 Updated verified funded futures trading account ending date to: 2022-10-26 11:08:49 | 2022-09-26 07:08:49.372 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMZ22_FUT_CME | 2022-09-26 07:08:49.372 Teton CME Order Routing | Received security definition for symbol MYMZ22_FUT_CME | 2022-09-26 07:08:49.372 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=C1963 | 2022-09-26 07:08:49.372 SC Data - All Services | Network connection to server complete. | 2022-09-26 07:08:49.407 SC Data - All Services | Starting socket receive thread. | 2022-09-26 07:08:49.407 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:08:49.408 Mapping NQZ22_FUT_CME to NQZ22. Service code: cme | 2022-09-26 07:08:49.441 SC Data - All Services | Starting real-time market data updates for: NQZ22_FUT_CME (NQZ22). ID: 2 Service code: cme | 2022-09-26 07:08:49.441 SC Data - All Services | Requesting security definition data for: NQZ22_FUT_CME (NQZ22). ID: 2 | 2022-09-26 07:08:49.441 Added historical Intraday data request for NQZ22_FUT_CME to the queue. | 2022-09-26 07:08:49.442 Intraday data recording state for symbol NQZ22_FUT_CME is set to download 'Pending'. | 2022-09-26 07:08:49.442 Triggering next historical data download in queue. | 2022-09-26 07:08:49.442 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-26 07:08:49.471 SC Data - All Services | Sending logon request message. | 2022-09-26 07:08:49.471 Requesting market depth updates for: NQZ22_FUT_CME if supported. | 2022-09-26 07:08:49.471 Separate subscription for market depth updates not supported. NQZ22_FUT_CME | 2022-09-26 07:08:49.471 Mapping YMZ22_FUT_CME to YMZ22. Service code: cbot | 2022-09-26 07:08:49.472 SC Data - All Services | Starting real-time market data updates for: YMZ22_FUT_CME (YMZ22). ID: 3 Service code: cbot | 2022-09-26 07:08:49.472 SC Data - All Services | Requesting security definition data for: YMZ22_FUT_CME (YMZ22). ID: 3 | 2022-09-26 07:08:49.472 Added historical Intraday data request for YMZ22_FUT_CME to the queue. | 2022-09-26 07:08:49.472 Intraday data recording state for symbol YMZ22_FUT_CME is set to download 'Pending'. | 2022-09-26 07:08:49.472 Triggering next historical data download in queue. | 2022-09-26 07:08:49.472 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQZ22_FUT_CME | 2022-09-26 07:08:49.507 Teton CME Order Routing | Received security definition for symbol NQZ22_FUT_CME | 2022-09-26 07:08:49.507 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMZ22_FUT_CME | 2022-09-26 07:08:49.559 Teton CME Order Routing | Received security definition for symbol YMZ22_FUT_CME | 2022-09-26 07:08:49.559 Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-09-26 07:08:49.743 SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 4 Service code: cme | 2022-09-26 07:08:49.743 SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 4 | 2022-09-26 07:08:49.743 Requesting market depth updates for: ESZ22_FUT_CME if supported. | 2022-09-26 07:08:49.743 Separate subscription for market depth updates not supported. ESZ22_FUT_CME | 2022-09-26 07:08:49.743 Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-09-26 07:08:49.743 Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-09-26 07:08:49.743 Triggering next historical data download in queue. | 2022-09-26 07:08:49.743 Mapping MNQZ22_FUT_CME to MNQZ22. Service code: cme | 2022-09-26 07:08:49.748 SC Data - All Services | Starting real-time market data updates for: MNQZ22_FUT_CME (MNQZ22). ID: 5 Service code: cme | 2022-09-26 07:08:49.748 SC Data - All Services | Requesting security definition data for: MNQZ22_FUT_CME (MNQZ22). ID: 5 | 2022-09-26 07:08:49.748 Requesting market depth updates for: MNQZ22_FUT_CME if supported. | 2022-09-26 07:08:49.748 Separate subscription for market depth updates not supported. MNQZ22_FUT_CME | 2022-09-26 07:08:49.748 Added historical Intraday data request for MNQZ22_FUT_CME to the queue. | 2022-09-26 07:08:49.748 Intraday data recording state for symbol MNQZ22_FUT_CME is set to download 'Pending'. | 2022-09-26 07:08:49.748 Triggering next historical data download in queue. | 2022-09-26 07:08:49.748 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ22_FUT_CME | 2022-09-26 07:08:49.811 Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-09-26 07:08:49.811 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQZ22_FUT_CME | 2022-09-26 07:08:49.844 Teton CME Order Routing | Received security definition for symbol MNQZ22_FUT_CME | 2022-09-26 07:08:49.844 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 6 Service code: statscalc | 2022-09-26 07:08:49.844 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 10048 | 2022-09-26 07:08:49.844 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 6 | 2022-09-26 07:08:49.844 Added historical Intraday data request for TICK-NYSE to the queue. | 2022-09-26 07:08:49.844 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2022-09-26 07:08:49.844 Triggering next historical data download in queue. | 2022-09-26 07:08:49.844 DTC Client socket (5) | Creating socket. | 2022-09-26 07:08:49.845 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-09-26 07:08:49.845 DTC Client socket (5) | Connecting to IP: 162.251.232.235. | 2022-09-26 07:08:49.845 SC DTC Data with Market Depth | Network connection to server complete. | 2022-09-26 07:08:49.917 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-09-26 07:08:49.917 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:08:49.917 Requesting market depth updates for: YMZ22_FUT_CME if supported. | 2022-09-26 07:08:49.961 Separate subscription for market depth updates not supported. YMZ22_FUT_CME | 2022-09-26 07:08:49.961 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-09-26 07:08:50.056 SC DTC Data with Market Depth | Sending logon request message. | 2022-09-26 07:08:50.056 SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NYSE. ID: 7 Service code: statscalc | 2022-09-26 07:08:50.057 SC DTC Data with Market Depth | Requesting security definition data for: ADR-NYSE. ID: 7 | 2022-09-26 07:08:50.057 Added historical Intraday data request for ADR-NYSE to the queue. | 2022-09-26 07:08:50.057 Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2022-09-26 07:08:50.057 Triggering next historical data download in queue. | 2022-09-26 07:08:50.058 SC Data - All Services | Received logon response. | 2022-09-26 07:08:50.118 SC Data - All Services | Server Name: RealTime Server. | 2022-09-26 07:08:50.118 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:08:50.118 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:08:50.118 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-26 07:08:50.118 DTC Client socket (3) | CloseSocket call. | 2022-09-26 07:08:50.119 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:08:50.119 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:08:50.119 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-09-26 07:08:50.119 Requesting market depth updates for: MYMZ22_FUT_CME if supported. | 2022-09-26 07:08:50.162 Separate subscription for market depth updates not supported. MYMZ22_FUT_CME | 2022-09-26 07:08:50.162 DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-09-26 07:08:50.183 DTC Client socket (3) | Closed. | 2022-09-26 07:08:50.183 Mapping MESZ22_FUT_CME to MESZ22. Service code: cme | 2022-09-26 07:08:50.258 SC Data - All Services | Starting real-time market data updates for: MESZ22_FUT_CME (MESZ22). ID: 8 Service code: cme | 2022-09-26 07:08:50.258 SC Data - All Services | Requesting security definition data for: MESZ22_FUT_CME (MESZ22). ID: 8 | 2022-09-26 07:08:50.258 Mapping GCZ22_FUT_CME to GCZ22. Service code: comex | 2022-09-26 07:08:50.258 SC Data - All Services | Starting real-time market data updates for: GCZ22_FUT_CME (GCZ22). ID: 9 Service code: comex | 2022-09-26 07:08:50.258 SC Data - All Services | Requesting security definition data for: GCZ22_FUT_CME (GCZ22). ID: 9 | 2022-09-26 07:08:50.258 Mapping SIZ22_FUT_CME to SIZ22. Service code: comex | 2022-09-26 07:08:50.258 SC Data - All Services | Starting real-time market data updates for: SIZ22_FUT_CME (SIZ22). ID: 10 Service code: comex | 2022-09-26 07:08:50.258 SC Data - All Services | Requesting security definition data for: SIZ22_FUT_CME (SIZ22). ID: 10 | 2022-09-26 07:08:50.258 Mapping CLX22_FUT_CME to CLX22. Service code: nymex | 2022-09-26 07:08:50.258 SC Data - All Services | Starting real-time market data updates for: CLX22_FUT_CME (CLX22). ID: 11 Service code: nymex | 2022-09-26 07:08:50.258 SC Data - All Services | Requesting security definition data for: CLX22_FUT_CME (CLX22). ID: 11 | 2022-09-26 07:08:50.258 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ22_FUT_CME | 2022-09-26 07:08:50.313 Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-09-26 07:08:50.313 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCZ22_FUT_CME | 2022-09-26 07:08:50.314 Teton CME Order Routing | Received security definition for symbol GCZ22_FUT_CME | 2022-09-26 07:08:50.314 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: SIZ22_FUT_CME | 2022-09-26 07:08:50.314 Teton CME Order Routing | Received security definition for symbol SIZ22_FUT_CME | 2022-09-26 07:08:50.314 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLX22_FUT_CME | 2022-09-26 07:08:50.401 Teton CME Order Routing | Received security definition for symbol CLX22_FUT_CME | 2022-09-26 07:08:50.401 SC DTC Data with Market Depth | Received logon response. | 2022-09-26 07:08:50.858 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-09-26 07:08:50.858 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:08:50.858 SC DTC Data with Market Depth | Successfully connected. | 2022-09-26 07:08:50.858 SC DTC Data with Market Depth | Trading is not supported. | 2022-09-26 07:08:50.858 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NYSE | 2022-09-26 07:08:50.858 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2022-09-26 07:08:50.858 SC DTC Data with Market Depth | Received security definition for symbol ADR-NYSE | 2022-09-26 07:08:51.016 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2022-09-26 07:08:51.016 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-09-26 07:09:20.115 DTC Client socket (3) | Creating socket. | 2022-09-26 07:09:20.116 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-09-26 07:09:20.116 DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-09-26 07:09:20.116 SC Data - All Services | Network connection to server complete. | 2022-09-26 07:09:20.175 SC Data - All Services | Starting socket receive thread. | 2022-09-26 07:09:20.175 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:09:20.175 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-26 07:09:20.248 SC Data - All Services | Sending logon request message. | 2022-09-26 07:09:20.248 HD Request # 29 | Downloading Intraday chart data for MYMZ22_FUT_CME to the file MYMZ22_FUT_CME.scid. Service: cbot | 2022-09-26 07:09:20.893 HD Request # 29 | Download start date-time: 2022-09-26 07:04:33.000000. File last date-time: 2022-09-26 07:04:33.880000 | 2022-09-26 07:09:20.894 HD Request # 29 | Using server: ds21.sierracharts.com port 10150 | 2022-09-26 07:09:20.894 Socket (6) | Creating socket. | 2022-09-26 07:09:20.894 Socket (6) | New receive buffer size: 5242880 | 2022-09-26 07:09:20.894 Socket (6) | Connecting to IP: 216.1.90.129. | 2022-09-26 07:09:20.894 SC Data - All Services | Received logon response. | 2022-09-26 07:09:20.962 SC Data - All Services | Server Name: RealTime Server. | 2022-09-26 07:09:20.962 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:09:20.962 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:09:20.962 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-26 07:09:20.962 DTC Client socket (3) | CloseSocket call. | 2022-09-26 07:09:20.962 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:09:20.962 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:09:20.962 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-09-26 07:09:20.962 DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-09-26 07:09:21.010 DTC Client socket (3) | Closed. | 2022-09-26 07:09:21.010 HD Request # 29 | Setting DTC encoding to Binary VLS | 2022-09-26 07:09:21.024 HD Request # 29 | Sending historical data logon request message. | 2022-09-26 07:09:21.024 HD Request # 29 | Requesting Intraday data. Start date-time: 2022-09-26 07:04:33. Record interval: 0. Symbol: MYMZ22 | 2022-09-26 07:09:21.545 HD Request # 29 | Decompressing data. | 2022-09-26 07:09:21.612 HD Request # 29 | Receiving Intraday data for MYMZ22_FUT_CME starting at 2022-09-26 07:04:33.880000 | 2022-09-26 07:09:21.613 Socket (6) | CloseSocket call. | 2022-09-26 07:09:21.614 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:09:21.614 Historical data download thread signaled to stop. | 2022-09-26 07:09:21.616 HD Request # 29 | Timestamp of first Intraday data file record written: 2022-09-26 07:04:36.477000. | 2022-09-26 07:09:21.616 HD Request # 29 | Received 286 Intraday data records from 2022-09-26 07:04:33.880000 to 2022-09-26 07:09:22.159001 (4.8 minutes) and wrote 285 records for MYMZ22_FUT_CME | 2022-09-26 07:09:21.616 HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2022-09-26 11:09:22.159001 | 2022-09-26 07:09:21.616 HD Request # 29 | Completion time: 1s. | 2022-09-26 07:09:21.617 HD Request # 29 | Intraday data download complete for MYMZ22_FUT_CME. Unique request ID: 29 | 2022-09-26 07:09:21.617 Removing historical data download ID 29. | 2022-09-26 07:09:21.617 Real-time Intraday chart data file updates started for MYMZ22_FUT_CME | 2022-09-26 07:09:21.617 Intraday chart data file opened for MYMZ22_FUT_CME | 2022-09-26 07:09:21.617 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2022-09-26 07:09:21.617 Triggering next historical data download in queue. | 2022-09-26 07:09:21.617 HD Request # 30 | Downloading Intraday chart data for NQZ22_FUT_CME to the file NQZ22_FUT_CME.scid. Service: cme | 2022-09-26 07:09:21.618 HD Request # 30 | Download start date-time: 2022-09-26 07:04:16.000000. File last date-time: 2022-09-26 07:04:16.692000 | 2022-09-26 07:09:21.619 HD Request # 30 | Using server: ds23.sierracharts.com port 10149 | 2022-09-26 07:09:21.619 Socket (3) | Creating socket. | 2022-09-26 07:09:21.619 Socket (3) | New receive buffer size: 5242880 | 2022-09-26 07:09:21.619 Socket (3) | Connecting to IP: 216.1.90.130. | 2022-09-26 07:09:21.619 Socket (6) | Socket gracefully closed by remote side. | 2022-09-26 07:09:21.685 Socket (6) | Closed. | 2022-09-26 07:09:21.685 Chart #14 has tagged chart #6 for full recalculation. Chartbook: LTC YM.Cht | 2022-09-26 07:09:21.765 HD Request # 30 | Setting DTC encoding to Binary VLS | 2022-09-26 07:09:21.775 HD Request # 30 | Sending historical data logon request message. | 2022-09-26 07:09:21.775 Chart #15 has tagged chart #7 for full recalculation. Chartbook: LTC YM.Cht | 2022-09-26 07:09:21.870 YMZ22_FUT_CME[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: LTC YM.Cht | 2022-09-26 07:09:21.948 Chart: YMZ22_FUT_CME[M] 5 Min #6 | Study: TTT StdDev | You need a license to use this study | 2022-09-26 07:09:21.948 * Chart: YMZ22_FUT_CME[M] 5 Min #6 | Study: TTT Lines | You need a license to use this study | 2022-09-26 07:09:21.948 * Chart: YMZ22_FUT_CME[M] 5 Min #6 | Study: TTT Range | You need a license to use this study | 2022-09-26 07:09:21.948 * YMZ22_FUT_CME[M] 60 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: LTC YM.Cht | 2022-09-26 07:09:21.987 Chart: YMZ22_FUT_CME[M] 60 Min #7 | Study: TTT StdDev | You need a license to use this study | 2022-09-26 07:09:21.988 * Chart: YMZ22_FUT_CME[M] 60 Min #7 | Study: TTT Range | You need a license to use this study | 2022-09-26 07:09:21.988 * Chart: YMZ22_FUT_CME[M] 60 Min #7 | Study: TTT Lines | You need a license to use this study | 2022-09-26 07:09:21.988 * HD Request # 30 | Requesting Intraday data. Start date-time: 2022-09-26 07:04:16. Record interval: 0. Symbol: NQZ22 | 2022-09-26 07:09:22.336 HD Request # 30 | Decompressing data. | 2022-09-26 07:09:22.398 HD Request # 30 | Receiving Intraday data for NQZ22_FUT_CME starting at 2022-09-26 07:04:16.692000 | 2022-09-26 07:09:22.462 Socket (3) | CloseSocket call. | 2022-09-26 07:09:22.462 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:09:22.462 Historical data download thread signaled to stop. | 2022-09-26 07:09:22.462 HD Request # 30 | Timestamp of first Intraday data file record written: 2022-09-26 07:04:17.866000. | 2022-09-26 07:09:22.463 HD Request # 30 | Received 1077 Intraday data records from 2022-09-26 07:04:16.692000 to 2022-09-26 07:09:20.956001 (5.1 minutes) and wrote 1076 records for NQZ22_FUT_CME | 2022-09-26 07:09:22.463 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2022-09-26 11:09:20.956001 | 2022-09-26 07:09:22.463 HD Request # 30 | Completion time: 1s. | 2022-09-26 07:09:22.463 HD Request # 30 | Intraday data download complete for NQZ22_FUT_CME. Unique request ID: 30 | 2022-09-26 07:09:22.463 Removing historical data download ID 30. | 2022-09-26 07:09:22.463 Real-time Intraday chart data file updates started for NQZ22_FUT_CME | 2022-09-26 07:09:22.463 Intraday chart data file opened for NQZ22_FUT_CME | 2022-09-26 07:09:22.463 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2022-09-26 07:09:22.463 Triggering next historical data download in queue. | 2022-09-26 07:09:22.463 HD Request # 31 | Downloading Intraday chart data for YMZ22_FUT_CME to the file YMZ22_FUT_CME.scid. Service: cbot | 2022-09-26 07:09:22.463 HD Request # 31 | Download start date-time: 2022-09-26 07:04:12.000000. File last date-time: 2022-09-26 07:04:12.734000 | 2022-09-26 07:09:22.464 HD Request # 31 | Using server: ds21.sierracharts.com port 10150 | 2022-09-26 07:09:22.464 Socket (6) | Creating socket. | 2022-09-26 07:09:22.464 Socket (6) | New receive buffer size: 5242880 | 2022-09-26 07:09:22.464 Socket (6) | Connecting to IP: 216.1.90.129. | 2022-09-26 07:09:22.464 Socket (3) | Socket gracefully closed by remote side. | 2022-09-26 07:09:22.526 Socket (3) | Closed. | 2022-09-26 07:09:22.527 HD Request # 31 | Setting DTC encoding to Binary VLS | 2022-09-26 07:09:22.592 HD Request # 31 | Sending historical data logon request message. | 2022-09-26 07:09:22.592 HD Request # 31 | Requesting Intraday data. Start date-time: 2022-09-26 07:04:12. Record interval: 0. Symbol: YMZ22 | 2022-09-26 07:09:22.656 HD Request # 31 | Decompressing data. | 2022-09-26 07:09:22.716 HD Request # 31 | Receiving Intraday data for YMZ22_FUT_CME starting at 2022-09-26 07:04:12.734000 | 2022-09-26 07:09:22.718 Socket (6) | CloseSocket call. | 2022-09-26 07:09:22.718 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:09:22.718 Historical data download thread signaled to stop. | 2022-09-26 07:09:22.737 HD Request # 31 | Timestamp of first Intraday data file record written: 2022-09-26 07:04:18.509000. | 2022-09-26 07:09:22.737 HD Request # 31 | Received 438 Intraday data records from 2022-09-26 07:04:12.734000 to 2022-09-26 07:09:22.163000 (5.2 minutes) and wrote 437 records for YMZ22_FUT_CME | 2022-09-26 07:09:22.737 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2022-09-26 11:09:22.163000 | 2022-09-26 07:09:22.738 HD Request # 31 | Completion time: 0s. | 2022-09-26 07:09:22.738 HD Request # 31 | Intraday data download complete for YMZ22_FUT_CME. Unique request ID: 31 | 2022-09-26 07:09:22.738 Removing historical data download ID 31. | 2022-09-26 07:09:22.738 Real-time Intraday chart data file updates started for YMZ22_FUT_CME | 2022-09-26 07:09:22.738 Intraday chart data file opened for YMZ22_FUT_CME | 2022-09-26 07:09:22.738 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2022-09-26 07:09:22.738 Triggering next historical data download in queue. | 2022-09-26 07:09:22.738 HD Request # 32 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-09-26 07:09:22.738 HD Request # 32 | Download start date-time: 2022-09-26 07:04:33.000000. File last date-time: 2022-09-26 07:04:33.881001 | 2022-09-26 07:09:22.738 HD Request # 32 | Using server: ds23.sierracharts.com port 10149 | 2022-09-26 07:09:22.738 Socket (3) | Creating socket. | 2022-09-26 07:09:22.738 Socket (3) | New receive buffer size: 5242880 | 2022-09-26 07:09:22.738 Socket (3) | Connecting to IP: 216.1.90.130. | 2022-09-26 07:09:22.738 Socket (6) | Socket gracefully closed by remote side. | 2022-09-26 07:09:22.783 Socket (6) | Closed. | 2022-09-26 07:09:22.783 HD Request # 32 | Setting DTC encoding to Binary VLS | 2022-09-26 07:09:22.886 HD Request # 32 | Sending historical data logon request message. | 2022-09-26 07:09:22.886 HD Request # 32 | Requesting Intraday data. Start date-time: 2022-09-26 07:04:33. Record interval: 0. Symbol: ESZ22 | 2022-09-26 07:09:22.948 HD Request # 32 | Decompressing data. | 2022-09-26 07:09:23.015 Chart #15 has tagged chart #37 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:23.086 NQZ22_FUT_CME[M] 60 Min #37 | Performing a full recalculation because it has been tagged. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:23.087 HD Request # 32 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-09-26 07:04:33.140000 | 2022-09-26 07:09:23.089 Chart: NQZ22_FUT_CME[M] 60 Min #37 | Study: TTT StdDev | You need a license to use this study | 2022-09-26 07:09:23.089 * Chart: NQZ22_FUT_CME[M] 60 Min #37 | Study: TTT Range | You need a license to use this study | 2022-09-26 07:09:23.089 * Chart: NQZ22_FUT_CME[M] 60 Min #37 | Study: TTT Lines | You need a license to use this study | 2022-09-26 07:09:23.089 * Socket (3) | CloseSocket call. | 2022-09-26 07:09:23.090 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:09:23.090 Historical data download thread signaled to stop. | 2022-09-26 07:09:23.095 HD Request # 32 | Timestamp of first Intraday data file record written: 2022-09-26 07:04:36.477000. | 2022-09-26 07:09:23.095 HD Request # 32 | Received 1897 Intraday data records from 2022-09-26 07:04:33.140000 to 2022-09-26 07:09:20.956003 (4.8 minutes) and wrote 1894 records for ESZ22_FUT_CME | 2022-09-26 07:09:23.096 HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2022-09-26 11:09:20.956003 | 2022-09-26 07:09:23.096 HD Request # 32 | Completion time: 1s. | 2022-09-26 07:09:23.096 HD Request # 32 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 32 | 2022-09-26 07:09:23.096 Removing historical data download ID 32. | 2022-09-26 07:09:23.096 Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-09-26 07:09:23.096 Intraday chart data file opened for ESZ22_FUT_CME | 2022-09-26 07:09:23.096 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2022-09-26 07:09:23.096 Triggering next historical data download in queue. | 2022-09-26 07:09:23.096 HD Request # 33 | Downloading Intraday chart data for MNQZ22_FUT_CME to the file MNQZ22_FUT_CME.scid. Service: cme | 2022-09-26 07:09:23.096 HD Request # 33 | Download start date-time: 2022-09-26 07:04:33.000000. File last date-time: 2022-09-26 07:04:33.882000 | 2022-09-26 07:09:23.096 HD Request # 33 | Using server: ds21.sierracharts.com port 10150 | 2022-09-26 07:09:23.096 Socket (6) | Creating socket. | 2022-09-26 07:09:23.096 Socket (6) | New receive buffer size: 5242880 | 2022-09-26 07:09:23.097 Socket (6) | Connecting to IP: 216.1.90.129. | 2022-09-26 07:09:23.097 Chart #16 has tagged chart #2 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:23.102 Chart #16 has tagged chart #3 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:23.102 Chart #11 has tagged chart #3 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:23.113 Chart #39 has tagged chart #37 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:23.115 Socket (3) | Socket gracefully closed by remote side. | 2022-09-26 07:09:23.156 Socket (3) | Closed. | 2022-09-26 07:09:23.156 Chart #16 has tagged chart #4 for full recalculation. Chartbook: LTC YM.Cht | 2022-09-26 07:09:23.177 Chart #16 has tagged chart #5 for full recalculation. Chartbook: LTC YM.Cht | 2022-09-26 07:09:23.177 YMZ22_FUT_CME[M] Rev. 8t #5 | Performing a full recalculation because it has been tagged. Chartbook: LTC YM.Cht | 2022-09-26 07:09:23.205 YMZ22_FUT_CME [CBV][M] 15 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: LTC YM.Cht | 2022-09-26 07:09:23.217 HD Request # 33 | Setting DTC encoding to Binary VLS | 2022-09-26 07:09:23.226 HD Request # 33 | Sending historical data logon request message. | 2022-09-26 07:09:23.226 HD Request # 33 | Requesting Intraday data. Start date-time: 2022-09-26 07:04:33. Record interval: 0. Symbol: MNQZ22 | 2022-09-26 07:09:23.290 HD Request # 33 | Decompressing data. | 2022-09-26 07:09:23.351 HD Request # 33 | Receiving Intraday data for MNQZ22_FUT_CME starting at 2022-09-26 07:04:33.658000 | 2022-09-26 07:09:23.515 Socket (6) | CloseSocket call. | 2022-09-26 07:09:23.516 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:09:23.516 Socket (6) | Socket gracefully closed by remote side. | 2022-09-26 07:09:23.576 Socket (6) | Closed. | 2022-09-26 07:09:23.576 Historical data download thread signaled to stop. | 2022-09-26 07:09:38.457 HD Request # 33 | Timestamp of first Intraday data file record written: 2022-09-26 07:04:33.968000. | 2022-09-26 07:09:38.457 HD Request # 33 | Received 2551 Intraday data records from 2022-09-26 07:04:33.658000 to 2022-09-26 07:09:23.361001 (4.8 minutes) and wrote 2546 records for MNQZ22_FUT_CME | 2022-09-26 07:09:38.457 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2022-09-26 11:09:23.361001 | 2022-09-26 07:09:38.458 HD Request # 33 | Completion time: 15s. | 2022-09-26 07:09:38.458 HD Request # 33 | Intraday data download complete for MNQZ22_FUT_CME. Unique request ID: 33 | 2022-09-26 07:09:38.458 Removing historical data download ID 33. | 2022-09-26 07:09:38.458 Real-time Intraday chart data file updates started for MNQZ22_FUT_CME | 2022-09-26 07:09:38.458 Intraday chart data file opened for MNQZ22_FUT_CME | 2022-09-26 07:09:38.458 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2022-09-26 07:09:38.458 Triggering next historical data download in queue. | 2022-09-26 07:09:38.458 HD Request # 34 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2022-09-26 07:09:38.462 HD Request # 34 | Download start date-time: 2022-09-26 07:08:40.000000. File last date-time: 2022-09-26 07:08:40.960000 | 2022-09-26 07:09:38.462 HD Request # 34 | Using server: ds4.sierracharts.com port 10149 | 2022-09-26 07:09:38.462 Socket (3) | Creating socket. | 2022-09-26 07:09:38.462 Socket (3) | New receive buffer size: 5242880 | 2022-09-26 07:09:38.462 Socket (3) | Connecting to IP: 162.251.232.235. | 2022-09-26 07:09:38.462 HD Request # 34 | Setting DTC encoding to Binary VLS | 2022-09-26 07:09:38.570 HD Request # 34 | Sending historical data logon request message. | 2022-09-26 07:09:38.570 Chart #11 has tagged chart #5 for full recalculation. Chartbook: LTC YM.Cht | 2022-09-26 07:09:39.196 Chart #17 has tagged chart #3 for full recalculation. Chartbook: LTC YM.Cht | 2022-09-26 07:09:39.201 HD Request # 34 | Requesting Intraday data. Start date-time: 2022-09-26 07:08:40. Record interval: 0. Symbol: TICK-NYSE | 2022-09-26 07:09:39.300 NQZ22_FUT_CME[M] 60 Min #37 | Performing a full recalculation because it has been tagged. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:39.314 Chart: NQZ22_FUT_CME[M] 60 Min #37 | Study: TTT StdDev | You need a license to use this study | 2022-09-26 07:09:39.316 * Chart: NQZ22_FUT_CME[M] 60 Min #37 | Study: TTT Range | You need a license to use this study | 2022-09-26 07:09:39.316 * Chart: NQZ22_FUT_CME[M] 60 Min #37 | Study: TTT Lines | You need a license to use this study | 2022-09-26 07:09:39.316 * HD Request # 34 | Decompressing data. | 2022-09-26 07:09:39.351 HD Request # 34 | Receiving Intraday data for TICK-NYSE starting at 2022-09-26 07:08:40.000000 | 2022-09-26 07:09:39.352 Socket (3) | CloseSocket call. | 2022-09-26 07:09:39.352 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:09:39.353 Historical data download thread signaled to stop. | 2022-09-26 07:09:39.387 HD Request # 34 | Timestamp of first Intraday data file record written: 2022-09-26 07:08:41.000000. | 2022-09-26 07:09:39.387 HD Request # 34 | Received 59 Intraday data records from 2022-09-26 07:08:40.000000 to 2022-09-26 07:09:38.000000 (58.0 seconds) and wrote 58 records for TICK-NYSE | 2022-09-26 07:09:39.387 HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2022-09-26 11:09:38.000000 | 2022-09-26 07:09:39.387 Added 8 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2022-09-26 07:09:39.387 HD Request # 34 | Completion time: 1s. | 2022-09-26 07:09:39.387 HD Request # 34 | Intraday data download complete for TICK-NYSE. Unique request ID: 34 | 2022-09-26 07:09:39.387 Removing historical data download ID 34. | 2022-09-26 07:09:39.387 Real-time Intraday chart data file updates started for TICK-NYSE | 2022-09-26 07:09:39.387 Intraday chart data file opened for TICK-NYSE | 2022-09-26 07:09:39.387 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2022-09-26 07:09:39.387 Triggering next historical data download in queue. | 2022-09-26 07:09:39.387 HD Request # 35 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2022-09-26 07:09:39.387 HD Request # 35 | Download start date-time: 2022-09-26 07:08:40.000000. File last date-time: 2022-09-26 07:08:40.960000 | 2022-09-26 07:09:39.388 HD Request # 35 | Using server: ds13-3.sierracharts.com port 10150 | 2022-09-26 07:09:39.388 Socket (6) | Creating socket. | 2022-09-26 07:09:39.388 Socket (6) | New receive buffer size: 5242880 | 2022-09-26 07:09:39.388 Socket (6) | Connecting to IP: 162.251.232.235. | 2022-09-26 07:09:39.388 Socket (3) | Socket gracefully closed by remote side. | 2022-09-26 07:09:39.411 Socket (3) | Closed. | 2022-09-26 07:09:39.411 HD Request # 35 | Setting DTC encoding to Binary VLS | 2022-09-26 07:09:39.498 HD Request # 35 | Sending historical data logon request message. | 2022-09-26 07:09:39.498 YMZ22_FUT_CME[M] #3 | Performing a full recalculation because it has been tagged. Chartbook: LTC YM.Cht | 2022-09-26 07:09:39.746 Chart: YMZ22_FUT_CME[M] #3 - Period: 1 Days, TPOs: 3 x 30 min | Study: TTT Lines | You need a license to use this study | 2022-09-26 07:09:39.761 * Chart #22 has tagged chart #4 for full recalculation. Chartbook: LTC YM.Cht | 2022-09-26 07:09:39.813 Chart #22 has tagged chart #5 for full recalculation. Chartbook: LTC YM.Cht | 2022-09-26 07:09:39.813 Chart #22 has tagged chart #9 for full recalculation. Chartbook: LTC YM.Cht | 2022-09-26 07:09:39.813 YMZ22_FUT_CME[M] Rev. 8t #5 | Performing a full recalculation because it has been tagged. Chartbook: LTC YM.Cht | 2022-09-26 07:09:39.816 YMZ22_FUT_CME [CBV][M] 15 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: LTC YM.Cht | 2022-09-26 07:09:39.827 HD Request # 35 | Requesting Intraday data. Start date-time: 2022-09-26 07:08:40. Record interval: 0. Symbol: ADR-NYSE | 2022-09-26 07:09:40.221 HD Request # 35 | Decompressing data. | 2022-09-26 07:09:40.272 HD Request # 35 | Receiving Intraday data for ADR-NYSE starting at 2022-09-26 07:08:40.000000 | 2022-09-26 07:09:40.273 Socket (6) | CloseSocket call. | 2022-09-26 07:09:40.273 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:09:40.273 Socket (6) | Socket gracefully closed by remote side. | 2022-09-26 07:09:40.326 Socket (6) | Closed. | 2022-09-26 07:09:40.326 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 10508 | 2022-09-26 07:09:43.256 Historical data download thread signaled to stop. | 2022-09-26 07:09:54.874 HD Request # 35 | Timestamp of first Intraday data file record written: 2022-09-26 07:08:41.000000. | 2022-09-26 07:09:54.874 HD Request # 35 | Received 61 Intraday data records from 2022-09-26 07:08:40.000000 to 2022-09-26 07:09:40.000000 (60.0 seconds) and wrote 60 records for ADR-NYSE | 2022-09-26 07:09:54.874 HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2022-09-26 11:09:40.000000 | 2022-09-26 07:09:54.875 Added 57 Time and Sales records to Intraday data file for ADR-NYSE after download. | 2022-09-26 07:09:54.875 HD Request # 35 | Completion time: 15s. | 2022-09-26 07:09:54.875 HD Request # 35 | Intraday data download complete for ADR-NYSE. Unique request ID: 35 | 2022-09-26 07:09:54.875 Removing historical data download ID 35. | 2022-09-26 07:09:54.875 Real-time Intraday chart data file updates started for ADR-NYSE | 2022-09-26 07:09:54.875 Intraday chart data file opened for ADR-NYSE | 2022-09-26 07:09:54.875 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2022-09-26 07:09:54.875 Triggering next historical data download in queue. | 2022-09-26 07:09:54.875 No download requests in the queue to start downloads for. | 2022-09-26 07:09:54.884 Chart #22 has tagged chart #2 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:55.526 Chart #22 has tagged chart #3 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:55.526 Chart #22 has tagged chart #48 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:55.526 Chart #28 has tagged chart #2 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:55.526 Chart #28 has tagged chart #3 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:55.526 NQZ22_FUT_CME [CBV][M] 15 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: PTG-NQ.Cht | 2022-09-26 07:09:55.536 Opened cached Intraday file: C:\SierraChart\Data\ADR-NYSE.scid. Thread ID: 10508 | 2022-09-26 07:09:58.371 DTC client #9. 127.0.0.1 (1) | Socket gracefully closed by remote side. | 2022-09-26 07:10:10.663 DTC client #9. 127.0.0.1 (1) | CloseSocket call. | 2022-09-26 07:10:38.355 DTC client #9. 127.0.0.1 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-09-26 07:10:38.355 DTC client #9. 127.0.0.1 (1) | Closed. | 2022-09-26 07:10:38.355 DTC Protocol server | Incoming connection from 127.0.0.1. | 2022-09-26 07:10:38.355 DTC client #10. 127.0.0.1 (1) | Creating socket. | 2022-09-26 07:10:38.364 DTC client #10. 127.0.0.1 (1) | New receive buffer size: 262144 | 2022-09-26 07:10:38.364 DTC client #10. 127.0.0.1 (1) | Allocated send buffers: 32 of 131072 bytes. | 2022-09-26 07:10:38.365 DTC Protocol server | Incoming connection from 127.0.0.1. | 2022-09-26 07:10:38.366 DTC client #11. 127.0.0.1 (3) | Creating socket. | 2022-09-26 07:10:38.376 DTC client #11. 127.0.0.1 (3) | New receive buffer size: 262144 | 2022-09-26 07:10:38.377 DTC client #11. 127.0.0.1 (3) | Allocated send buffers: 32 of 131072 bytes. | 2022-09-26 07:10:38.378 DTC client #10. 127.0.0.1 | Set DTC encoding to Binary VLS | 2022-09-26 07:10:38.378 DTC client #10. 127.0.0.1 (1) | Socket gracefully closed by remote side. | 2022-09-26 07:10:38.378 DTC client #11. 127.0.0.1 | Set DTC encoding to Binary VLS | 2022-09-26 07:10:38.378 DTC client #10. 127.0.0.1 (1) | CloseSocket call. | 2022-09-26 07:10:38.379 DTC client #10. 127.0.0.1 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-09-26 07:10:38.379 DTC client #10. 127.0.0.1 (1) | Closed. | 2022-09-26 07:10:38.379 DTC client #11. 127.0.0.1 | Requested heartbeat interval: 20 | 2022-09-26 07:10:38.391 DTC client #11. Sierra Chart. 127.0.0.1 | Received logon request. | 2022-09-26 07:10:38.391 DTC client #11. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Kelly Alton. Result text: Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading | 2022-09-26 07:10:38.391 MNQZ22_FUT_CME[M] Rev. 8t #3 | Performing a full recalculation because it has been tagged. Chartbook: PTG-NQ.Cht | 2022-09-26 07:10:39.075 Chart #17 has tagged chart #4 for full recalculation. Chartbook: PTG-NQ.Cht | 2022-09-26 07:10:39.094 ADR-NYSE[M] 3 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: LTC YM.Cht | 2022-09-26 07:10:39.145 ADR-NYSE[M] 3 Min #48 | Performing a full recalculation because it has been tagged. Chartbook: PTG-NQ.Cht | 2022-09-26 07:10:39.206 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-09-26 07:10:39.219 DTC Client socket (6) | Creating socket. | 2022-09-26 07:10:39.219 DTC Client socket (6) | New receive buffer size: 5242880 | 2022-09-26 07:10:39.219 DTC Client socket (6) | Connecting to IP: 216.1.90.129. | 2022-09-26 07:10:39.219 NQZ22_FUT_CME[M] #4 | Performing a full recalculation because it has been tagged. Chartbook: PTG-NQ.Cht | 2022-09-26 07:10:39.221 Chart: NQZ22_FUT_CME[M] #4 - Period: 1 Days, TPOs: 0.75 x 30 min | Study: TTT Lines | You need a license to use this study | 2022-09-26 07:10:39.250 * SC Data - All Services | Network connection to server complete. | 2022-09-26 07:10:39.280 SC Data - All Services | Starting socket receive thread. | 2022-09-26 07:10:39.280 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:10:39.280 Deleting individual DTC server: DTC client #9. Sierra Chart. 127.0.0.1 | 2022-09-26 07:10:39.351 DTC server: DTC client #9. Sierra Chart. 127.0.0.1 successfully deleted. | 2022-09-26 07:10:39.355 Deleting individual DTC server: DTC client #10. 127.0.0.1 | 2022-09-26 07:10:39.355 DTC server: DTC client #10. 127.0.0.1 successfully deleted. | 2022-09-26 07:10:39.355 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-26 07:10:39.392 SC Data - All Services | Sending logon request message. | 2022-09-26 07:10:39.392 SC Data - All Services | Received logon response. | 2022-09-26 07:10:40.020 SC Data - All Services | Server Name: RealTime Server. | 2022-09-26 07:10:40.020 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:10:40.020 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:10:40.020 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-26 07:10:40.020 DTC Client socket (6) | CloseSocket call. | 2022-09-26 07:10:40.020 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:10:40.021 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:10:40.021 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-09-26 07:10:40.021 DTC Client socket (6) | Socket gracefully closed by remote side. | 2022-09-26 07:10:40.081 DTC Client socket (6) | Closed. | 2022-09-26 07:10:40.081 DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-09-26 07:11:05.963 DTC Client socket (4) | Closed. | 2022-09-26 07:11:05.963 SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 443 | 2022-09-26 07:11:10.938 DTC Client socket (1) | Creating socket. | 2022-09-26 07:11:10.938 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-09-26 07:11:10.938 DTC Client socket (1) | Connecting to IP: 142.215.18.107. | 2022-09-26 07:11:10.938 SC Data - All Services | Network connection to server complete. | 2022-09-26 07:11:11.010 SC Data - All Services | Starting socket receive thread. | 2022-09-26 07:11:11.010 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:11:11.010 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-26 07:11:11.103 SC Data - All Services | Sending logon request message. | 2022-09-26 07:11:11.103 SC Data - All Services | Received logon response. | 2022-09-26 07:11:11.822 SC Data - All Services | Server Name: RealTime Server. | 2022-09-26 07:11:11.822 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:11:11.822 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:11:11.822 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-26 07:11:11.822 DTC Client socket (1) | CloseSocket call. | 2022-09-26 07:11:11.823 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:11:11.823 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:11:11.823 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-09-26 07:11:11.823 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-09-26 07:11:11.885 DTC Client socket (1) | Closed. | 2022-09-26 07:11:11.885 DTC Client socket (4) | Deleting network socket now after delay. | 2022-09-26 07:11:35.973 SC Data - All Services | Connecting to the server ds27.sierracharts.com. Port 10048 | 2022-09-26 07:11:41.817 DTC Client socket (1) | Creating socket. | 2022-09-26 07:11:41.818 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-09-26 07:11:41.818 DTC Client socket (1) | Connecting to IP: 208.185.224.128. | 2022-09-26 07:11:41.818 SC Data - All Services | Network connection to server complete. | 2022-09-26 07:11:41.889 SC Data - All Services | Starting socket receive thread. | 2022-09-26 07:11:41.889 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:11:41.889 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-26 07:11:41.976 SC Data - All Services | Sending logon request message. | 2022-09-26 07:11:41.976 SC Data - All Services | Received logon response. | 2022-09-26 07:11:42.648 SC Data - All Services | Server Name: RealTime Server. | 2022-09-26 07:11:42.648 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:11:42.648 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:11:42.648 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-26 07:11:42.648 DTC Client socket (1) | CloseSocket call. | 2022-09-26 07:11:42.648 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:11:42.649 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:11:42.649 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-09-26 07:11:42.649 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-09-26 07:11:42.708 DTC Client socket (1) | Closed. | 2022-09-26 07:11:42.708 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-09-26 07:12:12.645 DTC Client socket (1) | Creating socket. | 2022-09-26 07:12:12.645 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-09-26 07:12:12.646 DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2022-09-26 07:12:12.646 SC Data - All Services | Network connection to server complete. | 2022-09-26 07:12:12.708 SC Data - All Services | Starting socket receive thread. | 2022-09-26 07:12:12.708 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:12:12.708 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-26 07:12:12.809 SC Data - All Services | Sending logon request message. | 2022-09-26 07:12:12.809 SC Data - All Services | Received logon response. | 2022-09-26 07:12:13.469 SC Data - All Services | Server Name: RealTime Server. | 2022-09-26 07:12:13.469 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:12:13.469 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:12:13.469 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-26 07:12:13.469 DTC Client socket (1) | CloseSocket call. | 2022-09-26 07:12:13.469 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:12:13.469 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:12:13.469 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-09-26 07:12:13.470 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-09-26 07:12:13.532 DTC Client socket (1) | Closed. | 2022-09-26 07:12:13.532 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-09-26 07:12:43.457 DTC Client socket (1) | Creating socket. | 2022-09-26 07:12:43.458 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-09-26 07:12:43.458 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-09-26 07:12:43.458 SC Data - All Services | Network connection to server complete. | 2022-09-26 07:12:43.515 SC Data - All Services | Starting socket receive thread. | 2022-09-26 07:12:43.515 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:12:43.515 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-26 07:12:43.582 SC Data - All Services | Sending logon request message. | 2022-09-26 07:12:43.582 SC Data - All Services | Received logon response. | 2022-09-26 07:12:44.224 SC Data - All Services | Server Name: RealTime Server. | 2022-09-26 07:12:44.224 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:12:44.224 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:12:44.224 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-26 07:12:44.224 DTC Client socket (1) | CloseSocket call. | 2022-09-26 07:12:44.225 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:12:44.225 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:12:44.225 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-09-26 07:12:44.225 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-09-26 07:12:44.288 DTC Client socket (1) | Closed. | 2022-09-26 07:12:44.288 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-09-26 07:13:14.225 DTC Client socket (1) | Creating socket. | 2022-09-26 07:13:14.225 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-09-26 07:13:14.225 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-09-26 07:13:14.225 SC Data - All Services | Network connection to server complete. | 2022-09-26 07:13:14.288 SC Data - All Services | Starting socket receive thread. | 2022-09-26 07:13:14.288 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-09-26 07:13:14.288 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-09-26 07:13:14.388 SC Data - All Services | Sending logon request message. | 2022-09-26 07:13:14.388 SC Data - All Services | Received logon response. | 2022-09-26 07:13:15.016 SC Data - All Services | Server Name: RealTime Server. | 2022-09-26 07:13:15.016 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-09-26 07:13:15.016 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:13:15.016 SC Data - All Services | Waiting for socket receive thread to end | 2022-09-26 07:13:15.016 DTC Client socket (1) | CloseSocket call. | 2022-09-26 07:13:15.016 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-09-26 07:13:15.016 SC Data - All Services | Disconnected from the server. | 2022-09-26 07:13:15.017 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-09-26 07:13:15.017 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-09-26 07:13:15.076 DTC Client socket (1) | Closed. | 2022-09-26 07:13:15.077 |
[2022-09-26 11:45:42] |
Sierra_Chart Engineering - Posts: 6483 |
You have Sierra Chart running on another computer in your network: SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-09-26 07:08:50.118
This is the problem. Refer to: Denali Exchange Data Feed: Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
