Date/Time: Fri, 06 Nov 2026 09:06:10 +0000
NinjaTrader CQG Connection
View Count: 1357
| [2021-11-17 10:49:15] |
| User934000 - Posts: 10 |
I am logging in "Data/Trade Service Settings" with my NinjaTrader CQG WebAPI [Trading] Login. The login works, and I was using it to trade until I had also the Denali data, now I am not having the Denali data, I pay a fee with NinjaTrader to use my Data with Sierra, but since the Denali stopped I can't see any data! the login seem to work, but no price is entering into the platform. When I enter in the chart that was previously working I get "Symbol Unknown, Click for symbol information. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBZ21. ID:1". But that's the only symbol I am finding for BUND FGBL. I also get the message "Download Failed Historical data only supported with Sierra Chart data feed" does it mean that unless I have Denali I can't have historical data?? I don't know what to do, can you help? I am using an advanced package (5)... can I use CQG data from NinjaTrader account with that? I asked NinjaTrader support and they replied with this: Hello Sergio,
Thank you for the inquiry. I can confirm your account connection is enabled for FGBL data and the account is authorized to trade it. I would recommend following up with Sierra Charts support regarding their software. Please let us know if we may be of further assistance. Date Time Of Last Edit: 2021-11-17 15:59:54
| [2021-11-17 16:32:00] |
| John - SC Support - Posts: 48449 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-17 17:37:04] |
Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. F.US.DBZ21 Disconnect from the data feed with "File >> Disconnect".
Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log Software version: 2320 64-bit | 2021-11-17 17:29:31.108 Primary Thread ID: 15720 | 2021-11-17 17:29:31.108 Usage end date: 2021-12-18 | 2021-11-17 17:29:31.108 Enabled for: Advanced Features 2. | 2021-11-17 17:29:31.108 Enabled for: Sierra Chart Historical Data Service. | 2021-11-17 17:29:31.108 Enabled for: Delayed Denali Exchange Data Feed. | 2021-11-17 17:29:31.108 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-11-17 17:29:31.108 Current selected Data/Trading service: CQG WebAPI | 2021-11-17 17:29:31.108 Custom symbol settings values: enabled | 2021-11-17 17:29:31.108 Chart Update Interval: 500 | 2021-11-17 17:29:31.108 Intraday Data Storage Time Unit: 0 | 2021-11-17 17:29:31.108 Time Zone: +00:00:00 (UTC+00) | 2021-11-17 17:29:31.108 2021-11-17 17:29:31 Local computer time in UTC | 2021-11-17 17:29:31.108 2021-11-17 17:29:31 Local computer time in SC Time Zone | 2021-11-17 17:29:31.108 2021-11-17 12:13:20 Server time in UTC | 2021-11-17 17:29:31.108 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-11-17 17:29:31.108 Program path: C:\SierraChart\ | 2021-11-17 17:29:31.108 Data Files path: C:\SierraChart\Data\ | 2021-11-17 17:29:31.108 OS Version Number: 10.0 | 2021-11-17 17:29:31.108 Locale Setting: C | 2021-11-17 17:29:31.108 DLLs: UserContributedStudies_64.dll | 2021-11-17 17:29:31.108 Allowed protected custom studies: | 2021-11-17 17:29:31.108 F.US.DBZ21 1 Min #1 | Reloading chart. | 2021-11-17 17:31:37.942 CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBZ21. ID: 2 | 2021-11-17 17:31:38.438 Symbol Error - F.US.DBZ21 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBZ21. ID: 2 | 2021-11-17 17:31:38.438 CQG WebAPI | Using primary service for historical data for F.US.DBZ21 | 2021-11-17 17:31:38.438 No historical data client is currently set to download historical Intraday data for F.US.DBZ21. | 2021-11-17 17:31:38.438 Real-time Intraday chart data file updates started for F.US.DBZ21 | 2021-11-17 17:31:38.438 Intraday chart data file opened for F.US.DBZ21 | 2021-11-17 17:31:38.438 F.US.DBZ21 60 Min #1 | Reloading chart. | 2021-11-17 17:32:28.507 File >> Disconnect selected. | 2021-11-17 17:34:34.715 CQG WebAPI | Sending Web API Logoff message. | 2021-11-17 17:34:34.715 CQG WebSocket socket (1) | CloseSocket call. | 2021-11-17 17:34:34.715 CQG WebSocket | WebSocket closed. | 2021-11-17 17:34:34.715 CQG WebAPI | WebSocket closed. | 2021-11-17 17:34:34.715 CQG WebAPI | Disconnected. | 2021-11-17 17:34:34.715 CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-11-17 17:34:34.715 CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2021-11-17 17:34:34.722 CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-11-17 17:34:34.722 CQG WebAPI | Connecting to server api.cqg.com | 2021-11-17 17:34:43.196 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-11-17 17:34:43.196 CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2021-11-17 17:34:43.299 CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2021-11-17 17:34:43.299 CQG WebSocket socket (2) | Connecting to IP: 195.166.124.165. | 2021-11-17 17:34:43.299 CQG WebSocket | Opening WebSocket. | 2021-11-17 17:34:43.307 CQG WebSocket | Sending WebSocket handshake. | 2021-11-17 17:34:43.307 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-11-17 17:34:43.337 CQG WebSocket | Server header | Connection: upgrade | 2021-11-17 17:34:43.337 CQG WebSocket | Server header | Sec-WebSocket-Accept: 9CVskmOA8m3QHKIgaBovBjFaDfo= | 2021-11-17 17:34:43.337 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-11-17 17:34:43.337 CQG WebSocket | Server header | Upgrade: websocket | 2021-11-17 17:34:43.337 CQG WebSocket | Server header | | 2021-11-17 17:34:43.337 CQG WebSocket | Web socket state is now open. | 2021-11-17 17:34:43.337 CQG WebAPI | WebSocket connected. | 2021-11-17 17:34:43.337 CQG WebAPI | Sending market data logon message. | 2021-11-17 17:34:43.337 CQG WebAPI | Base Time: 2021-10-31T06:38:50. 2021-10-31 06:38:50 | 2021-11-17 17:34:43.904 CQG WebAPI | Logon successful. Session Token = rq5nNTxjj66hOkkgYvEYetREi4omOo5rN9eCiMcbhMgB13+OoGICBA+2E7c8eaO0rGwpA1TlxEv | 2021-11-17 17:34:43.904 CQG WebAPI | Connected to server complete. | 2021-11-17 17:34:43.904 Triggering next historical data download in queue. | 2021-11-17 17:34:43.905 Triggering next historical data download in queue. | 2021-11-17 17:34:43.905 Triggering next historical data download in queue. | 2021-11-17 17:34:43.905 Triggering next historical data download in queue. | 2021-11-17 17:34:43.905 Subscribing to symbol for symbol alert. FGBLZ21 | 2021-11-17 17:34:43.905 CQG WebAPI | Starting real-time market data updates for: FGBLZ21. ID: 1 | 2021-11-17 17:34:43.905 CQG WebAPI | Sending symbol resolution request for FGBLZ21. ID: 334899 | 2021-11-17 17:34:43.905 CQG WebAPI | Requesting security definition data for: FGBLZ21. ID: 1 | 2021-11-17 17:34:43.905 Updated verified funded futures trading account ending date to: 2021-12-17 17:34:43 | 2021-11-17 17:34:43.905 CQG WebAPI | Sending Trade Accounts request message. | 2021-11-17 17:34:43.905 No download requests in the queue to start downloads for. | 2021-11-17 17:34:43.905 No download requests in the queue to start downloads for. | 2021-11-17 17:34:43.905 No download requests in the queue to start downloads for. | 2021-11-17 17:34:43.905 No download requests in the queue to start downloads for. | 2021-11-17 17:34:43.905 CQG WebAPI | Brokerage name: Mirus. Account Name: Sergio Marelli Limited | 2021-11-17 17:34:43.963 Updated verified funded futures trading account ending date to: 2021-12-17 17:34:43 | 2021-11-17 17:34:43.963 CQG WebAPI | Sending collateral subscribe request. | 2021-11-17 17:34:43.963 CQG WebAPI | Received message: Requested symbol was not found. | 2021-11-17 17:34:43.987 Symbol Error - FGBLZ21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-11-17 17:34:43.987 CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBZ21. ID: 2 | 2021-11-17 17:34:44.001 Symbol Error - F.US.DBZ21 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBZ21. ID: 2 | 2021-11-17 17:34:44.001 CQG WebAPI | Using primary service for historical data for F.US.DBZ21 | 2021-11-17 17:34:44.001 No historical data client is currently set to download historical Intraday data for F.US.DBZ21. | 2021-11-17 17:34:44.001 Real-time Intraday chart data file updates started for F.US.DBZ21 | 2021-11-17 17:34:44.001 Intraday chart data file opened for F.US.DBZ21 | 2021-11-17 17:34:44.001 CQG WebAPI | Sending positions subscribe request. RequestID: 334902 | 2021-11-17 17:34:46.892 CQG WebAPI | Sending orders subscribe request. RequestID: 334903 | 2021-11-17 17:34:46.892 CQG WebSocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-11-17 17:36:46.780 CQG WebSocket socket (1) | Closed. | 2021-11-17 17:36:46.780 |
| [2021-11-17 18:18:19] |
You are trying to get data for the EUREX. In order to get the EUREX data from a source other than Sierra Chart, you need to be on Package 10, 11, or 12. We have set your account to evaluate Package 12 for the next 30 days. Therefore, you will have access to the EUREX data from CQG for these 30 days. But before the 30 days ends, you will need to either change your package to Package 11 (equivalent to Package 5, with the EUREX capability) or setup the Denali Exchange Data Feed to get the EUREX data from us. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-17 20:12:38] |
brilliant! thank you so much, much appreciated. Any brokerage service to suggest to be using directly SierraChart without passing through NinjaTrader data? |
| [2021-11-17 22:00:50] |
You can use any broker and still get the data from us. Sierra Chart is specifically setup to allow this. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services But, if you are interested in our Teton Direct Order Routing service, which has trading for the CME Group (we are working on EUREX trading next) then you would want to use Stage 5 for your broker with Advantage as the FCM. Refer to the information at the following link: Sierra Chart Teton Futures Order Routing Note that when using the Teton Direct Order Routing, you have to use the Denali Exchange Data Feed, as you are not connected to any other service that supplies data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
