Date/Time: Sat, 12 Jul 2025 00:50:33 +0000
[Locked] - Historical Data on the New Rithmic Connection
View Count: 4629
[2021-11-09 16:45:14] |
We have been consistently hearing, that historical data directly provided by Rithmic is either very slow, or not being received with the new Rithmic connection. Based upon the information we have from Rithmic, the solution is to reduce the amount of days that Sierra Chart is requesting historical data for. And also it should help if Minute data is requested instead of Tick Data. 1. Select Global Settings >> Data/Trade Service Settings >> Common Settings. 2. Set Maximum Historical Intraday Days to Download >> 1-Tick Data to 5. 3. Set Maximum Historical Intraday Days to Download >> Non-Tick Data to 5. 4. Press OK. 5. Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers 6. If that does not resolve the issue, then set the Global Settings >> Data/Trade Service Settings >> Common Settings >> Intraday Data Storage Time Unit to 1 Minute. 7. And then reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers If you want to re-download all the data in the chart, go to the chart and select "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. ---- If you have any further issues, we recommend users use the Denali Exchange Data Feed which is provided by Sierra Chart, for the best and fastest market data: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-09 20:01:08
[2021-11-09 19:19:51] |
fcpauldiaz - Posts: 18 |
is there a way to use Rithmic only for trading and use Denali as the data feed?
[2021-11-09 19:59:50] |
Yes of course. This is fully supported. It is explained in the Introduction section here: Denali Exchange Data Feed: Introduction And here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
