Date/Time: Fri, 06 Nov 2026 09:06:13 +0000
Denali feed Delayed
View Count: 1464
[2021-10-27 11:51:12]
User849476 - Posts: 17
Hi Team,
Could you please help me out ?
My feed is delayed by 10 minutes, i did turned off the "trade simulation mode on" but this is not resolving my issue.
Could you please tell me what i'm doing wrong ?
Thanks team.
Regards,
[2021-10-27 14:12:06]
You did not follow all the instructions to get the Denali Exchange Data Feed setup. Please follow through all of the instructions at the following link for the CME Group data (you do not need to repeat anything that you have already done):
If you are wanting data for the EUREX or CFE exchanges, then the instructions for those are on the same page as above, just scroll to the top and select the appropriate link at the top of the page.
[2021-11-17 10:09:23]
Hi Team,
I have followed the process and activated the CME non-professional top-of-book.
But still my feed is delayed... what did i miss ??
Thank you,
[2021-11-17 12:04:14]
You have signed up for the Non-Professional CME exchanges, which means that you need to connect to your live, funded futures trading account at the beginning of each month to qualify for the lower-priced exchange fees. You have not connected to your trading account yet this month. Refer to the following:
[2021-11-17 13:45:48]
Hi thanks for taking a look at my case.
I did connect several time this month.
I did it once again and attached the screenshot as a proof.
You can check the clock and the account.
There must be something else i guess
imageScreen Shot 17-11-2021 at 14.42.png / V - Attached On 2021-11-17 13:45:02 UTC - Size: 212.8 KB - 223 views
[2021-11-17 14:07:42]
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges)
Also update Sierra Chart to the current version. Instructions:
Date Time Of Last Edit: 2021-11-17 14:08:18
[2021-11-17 14:23:10]
I've just update my plateform with current version of sierra but still have the same issue
My broker is stage 5
[2021-11-17 16:49:42]
What order routing service are you setup to use with Stage 5 (what service are you connecting to in order to validate your non-professional status)?
If you are connecting to your live trading account, then for some reason that is not updating your verification date. You can view the date for which you are verified until at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
So we want to make sure that this connection is occurring properly so we can understand what is not working.
[2021-11-17 19:51:16]
Set Sierra Chart to connect to your trading account. Global Settings >> Data/Trade Service Settings >> Current Selected Service.
Reconnect to the data feed:
[2021-11-18 14:49:46]
Hi Team,
Thanks for your feedbacks.
So i took contact with stage 5 and they told me that my order rootings goes through CQG.
Attached the log.
Also i see that i was verified until May 12 of this year...
attachmentLog.txt - Attached On 2021-11-18 14:48:48 UTC - Size: 9.28 KB - 373 views
[2021-11-18 15:01:34]
You should be getting the real-time CME data based upon what we see right now on your account.
[2021-11-18 15:17:32]
Yes looks OK now, thanks team !
