Date/Time: Sun, 05 May 2024 23:49:33 +0000
question on sierra real time data feed...
View Count: 1979
[2014-03-26 04:52:13] |
User53765 - Posts: 66 |
Hi Support, A general question please. With the Sierra real time data im assuming the charting is separate from that of the fcm trading account charting. If so if we are using CTS for example, if we receive the Sierra real time data with a CTS account how far back of the ES contract for example can one look at based on Sierra real time data. I see expired contracts are currently a problem for CTS users to look at, is it the same problem if one is using Sierra real time data instead? Thanks in advance. |
[2014-03-26 05:04:24] |
If you use the Sierra Chart Real-time and Historical Exchange Data Feed with CTS T4, you will be able to get data for expired futures contracts. There will be no problem with this. You can get five years of historical data. Both daily and Intraday. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-26 06:37:31] |
It would be a good idea to use the Sierra Chart data feed for the time being until expired futures contracts can again be used with CTS T4. We would expect they can be used probably in about 2 to 3 weeks. It depends upon what we find with more testing and how fast CTS can resolve the issue.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-26 06:37:44
[2014-03-26 13:31:16] |
User83762 - Posts: 61 |
How far back does the SC data feed provide 1-tick data for the ES? Using the SC historical 1-tick data with CTS real time data, I assume there will be no exchange fees required? Thanks. Date Time Of Last Edit: 2014-03-26 14:10:41
[2014-03-26 18:25:01] |
There is at least 3 years of tick by tick data for the ES futures. There is an exchange fee of 4USD per month for the CME. Your account also has to be set to a standard Sierra Chart account that you pay for. Otherwise, you cannot subscribe to the Sierra Chart data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-26 18:25:20
[2014-03-27 00:00:34] |
I am a TopStepTrader client. I am currently using CTS T4 for real-time data. From what I read on your site, the SC historical data feed is included in the trial. Should I be able to display intraday and historical charts going back a few years, fully back adjusted, that contain tick volume data, by combining these two feeds? If so, we cannot get this to work, no matter what settings we change. Do I need the SC historical and real-time feed combined with CTS to make this work? If so, why - how does this combination differ from CTS plus SC Historical only? Version 1112 contains only one symbol for the ES; yet it displays a black, empty chart. It is only when I use a symbol format from an earlier version that anything displays, yet it contains incomplete, gappy data, and the price axis does not include the decimal point. At this stage, I need you to provide remote assistance to fix these problems. Please tell me how we can set this up as soon as possible. Thanks. |
[2014-03-27 23:05:02] |
We have looked into this and the Sierra Chart Historical Data Service was supposed to have been provided with some limitations to Top Step Trader users, but apparently it was not. It should now be working.This service can be used on its own, but not combined with CTS T4 data because the pricing format is totally different and we do not offer support for that. Your other questions have been answered in the same posting you made in another thread. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-27 23:06:41
[2014-03-28 00:14:49] |
Here's a screenshot of a daily RTH chart, with 'bad' data; note the bars on the left portion of the chart, and the missing parts of the volume profile on the right margin. The real time data feed is Rithmic, and I have added the second symbol of ESM14 (not sure if this is correct or necessary for the SC Historical Data Service). The rollover choice on the first Advanced Settings tab is set to 'Continuous Futures contract - Date Rule rollover, Back Adjusted'. What am I missing. Thanks. |
Attachment Deleted. SNAG-0003.png / V - Attached On 2014-03-28 00:13:29 UTC - Size: 104.39 KB - 395 views Attachment Deleted. |
[2014-03-28 00:32:52] |
With Rithmic, we need to make it very clear. There is no reliable support for Continuous Futures Contracts. Unless you use the Sierra Chart Real-time and Historical Exchange Data Feed: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php This is the solution. It is an inexpensive feed. Please subscribe to it and you will solve the problems. We also need to convert your account to a normal account. Just let us know if you would like us to do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-28 00:56:42] |
If the only fee is for the SC data feed for 2 months, then yes, please convert my account; I need the TPO and volume profile features in package 5, the same ones that are included in the trial. Thanks.
[2014-03-28 16:26:05] |
I don't see any change to my account; it still says "Trial Package". Thanks.
[2014-03-28 17:34:06] |
We apologize for the delay with this. We needed to review this because when we convert your account to a normal account you then have to pay for Sierra Chart which would be 40 USD per month for package 5. The trial time would be set to 1 week. And that is probably what you do not want. We will leave the one month of usage time on your account but there will need to be a payment after the usage time expires. Your account has been converted to a standard account. Restart Sierra Chart. You need to follow the instructions here to use the Sierra Chart Exchange Data Feed: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-28 17:35:00
[2014-03-28 19:05:25] |
What are these two exchange fees; do I need to pay for this also for full DOM market depth, even though I have Rithmic and another futures brokerage account elsewhere???
[2014-03-28 19:28:16] |
If you do want market depth data, then you do have to pay the 15.75 CME exchange fee. It does not matter what other accounts that you have. This is the fee that is collected and paid to the CME for this data feed. We had thought you would be fine just with the 4USD fee for the level 1 data. Keep in mind this data feed only has to be used temporarily. At the latest by the end of next month because we expect CTS to resolve the issue which is causing expired futures contract data to not be accessible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-28 19:29:05
[2014-03-28 19:59:50] |
Can I activate the $4 fee now for just the remainder of this month, and then switch to the full depth $15.75 fee on the first of next month?
[2014-03-28 20:03:01] |
Yes, you can do that. Just Activate it, after the charge of 4 USD is deducted and you confirm the exchange is activated, then deactivate it so it does not automatically renew. It will remain active until the end of the month. Deactivating it just means you are disabling automatic renewal. When April 1 comes, then go ahead and activate the CME 15.75 exchange fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-28 20:03:29
[2014-03-28 20:22:11] |
Ok, I have activated the exchange fee, paid for the historical data feed, allowed support for Sierra chart Data Feeds, completed all account information and agreement, updated symbol settings from server, disconnected and reconnected, and still no historical data or 'M' symbol.
[2014-03-28 20:39:27] |
Restart Sierra Chart. Open a chart and connect to the data feed and then provide a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-28 20:55:23] |
While disconnecting and reconnecting had no affect, exiting and restarting did bring up the symbol with the 'M' at the end. However data still is only going back to December2013, while 360 days are requested. After my charts loaded, I opened a new chart, changed it to Intraday Chart Only, 1-0-0 for the day session, ESM4-CME; it only goes back to Novermber 2013. Intraday charts have gappy bars. Log: Software version: 1112 | 2014-03-28 16:47:31 Usage end date: 2014-04-28 | 2014-03-28 16:47:31 Enabled for: Sierra Chart Historical Data Service. | 2014-03-28 16:47:31 Enabled for: Sierra Chart Real-Time Market Data Feed. | 2014-03-28 16:47:31 Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-03-28 16:47:31 Received 1 data feed usernames. | 2014-03-28 16:47:31 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-03-28 16:47:31 Active service: Rithmic Trading | 2014-03-28 16:47:31 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-03-28 16:47:31 2014-03-28 16:47:31 Local computer clock time | 2014-03-28 16:47:31 2014-03-28 20:47:31 GMT time | 2014-03-28 16:47:31 2014-03-28 16:47:31 Time zone adjusted time | 2014-03-28 16:47:31 Time difference to server time: 5 seconds. | 2014-03-28 16:47:31 Program path: C:\SierraChart\ | 2014-03-28 16:47:31 Data Files path: C:\SierraChart\Data\ | 2014-03-28 16:47:31 OS Version Number: 6.1 | 2014-03-28 16:47:31 Checking for new symbol settings for rim | 2014-03-28 16:47:31 Symbol settings are up-to-date for rim | 2014-03-28 16:47:32 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13 | 2014-03-28 16:47:34 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12 | 2014-03-28 16:47:34 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12 | 2014-03-28 16:47:34 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13 | 2014-03-28 16:47:34 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12 | 2014-03-28 16:47:34 Intraday data file for ESM3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:47:34 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-03-28 16:47:34 Intraday data file for ESU3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:47:34 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-03-28 16:47:34 Intraday data file for ESZ3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:47:34 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-03-28 16:47:34 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13 | 2014-03-28 16:47:34 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-03-28 16:47:34 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 0 | 2014-03-28 16:47:34 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-03-28 16:47:34 Symbols used for ESM4-CME continuous contract chart: | 2014-03-28 16:47:34 ESM3-CME | 2014-03-28 16:47:34 ESU3-CME | 2014-03-28 16:47:34 ESZ3-CME | 2014-03-28 16:47:34 ESH4-CME | 2014-03-28 16:47:34 ESM4-CME | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: Performing continuous futures contract back adjustment calculations. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESU3-CME Open price on 2013-06-13 is 1605. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESM3-CME price difference to ESU3-CME is -5.75. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESU3-CME price difference to ESZ3-CME is -6.5. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESZ3-CME price difference to ESH4-CME is -6.5. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: ESH4-CME price difference to ESM4-CME is -7.25. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: Back adjust amount for symbol ESM3-CME is -26. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: Back adjust amount for symbol ESU3-CME is -20.25. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: Back adjust amount for symbol ESZ3-CME is -13.75. | 2014-03-28 16:47:34 ESM4-CME [CB] 1 Day #2: Back adjust amount for symbol ESH4-CME is -7.25. | 2014-03-28 16:47:34 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13 | 2014-03-28 16:47:35 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12 | 2014-03-28 16:47:35 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12 | 2014-03-28 16:47:35 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13 | 2014-03-28 16:47:35 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12 | 2014-03-28 16:47:35 Intraday data file for ESM3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:47:35 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-03-28 16:47:35 Intraday data file for ESU3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:47:35 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-03-28 16:47:35 Intraday data file for ESZ3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:47:35 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-03-28 16:47:35 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13 | 2014-03-28 16:47:35 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-03-28 16:47:35 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 0 | 2014-03-28 16:47:35 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-03-28 16:47:35 Symbols used for ESM4-CME continuous contract chart: | 2014-03-28 16:47:35 ESM3-CME | 2014-03-28 16:47:35 ESU3-CME | 2014-03-28 16:47:35 ESZ3-CME | 2014-03-28 16:47:35 ESH4-CME | 2014-03-28 16:47:35 ESM4-CME | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: Performing continuous futures contract back adjustment calculations. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESU3-CME Open price on 2013-06-13 is 1605. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESM3-CME price difference to ESU3-CME is -5.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESU3-CME price difference to ESZ3-CME is -6.5. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESZ3-CME price difference to ESH4-CME is -6.5. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: ESH4-CME price difference to ESM4-CME is -7.25. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: Back adjust amount for symbol ESM3-CME is -26. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: Back adjust amount for symbol ESU3-CME is -20.25. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: Back adjust amount for symbol ESZ3-CME is -13.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 1 Day #1: Back adjust amount for symbol ESH4-CME is -7.25. | 2014-03-28 16:47:35 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13 | 2014-03-28 16:47:35 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12 | 2014-03-28 16:47:35 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13 | 2014-03-28 16:47:35 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-03-28 16:47:35 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 0 | 2014-03-28 16:47:35 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-03-28 16:47:35 Symbols used for ESM4-CME continuous contract chart: | 2014-03-28 16:47:35 ESH4-CME | 2014-03-28 16:47:35 ESM4-CME | 2014-03-28 16:47:35 ESM4-CME [CB] Rev. 5t #7: Performing continuous futures contract back adjustment calculations. | 2014-03-28 16:47:35 ESM4-CME [CB] Rev. 5t #7: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2014-03-28 16:47:35 ESM4-CME [CB] Rev. 5t #7: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2014-03-28 16:47:35 ESM4-CME [CB] Rev. 5t #7: ESH4-CME price difference to ESM4-CME is -7.25. | 2014-03-28 16:47:35 ESM4-CME [CB] Rev. 5t #7: Back adjust amount for symbol ESH4-CME is -7.25. | 2014-03-28 16:47:35 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13 | 2014-03-28 16:47:35 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12 | 2014-03-28 16:47:35 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12 | 2014-03-28 16:47:35 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13 | 2014-03-28 16:47:35 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12 | 2014-03-28 16:47:35 Intraday data file for ESM3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:47:35 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-03-28 16:47:35 Intraday data file for ESU3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:47:35 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-03-28 16:47:35 Intraday data file for ESZ3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:47:35 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-03-28 16:47:35 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13 | 2014-03-28 16:47:35 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-03-28 16:47:35 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 0 | 2014-03-28 16:47:35 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-03-28 16:47:35 Symbols used for ESM4-CME continuous contract chart: | 2014-03-28 16:47:35 ESM3-CME | 2014-03-28 16:47:35 ESU3-CME | 2014-03-28 16:47:35 ESZ3-CME | 2014-03-28 16:47:35 ESH4-CME | 2014-03-28 16:47:35 ESM4-CME | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESU3-CME Open price on 2013-06-13 is 1605. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESM3-CME price difference to ESU3-CME is -5.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESU3-CME price difference to ESZ3-CME is -6.5. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESZ3-CME price difference to ESH4-CME is -6.5. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: ESH4-CME price difference to ESM4-CME is -7.25. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: Back adjust amount for symbol ESM3-CME is -26. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: Back adjust amount for symbol ESU3-CME is -20.25. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: Back adjust amount for symbol ESZ3-CME is -13.75. | 2014-03-28 16:47:35 ESM4-CME [CB] 30 Min #4: Back adjust amount for symbol ESH4-CME is -7.25. | 2014-03-28 16:47:35 Mapping ESM4-CME to ESM4. Service code: cme | 2014-03-28 16:47:35 HD Request # 2 - Downloading Intraday chart data for ESM4-CME to the file ESM4-CME.scid. Service: cme | 2014-03-28 16:47:35 HD Request # 2 - Download start Date-Time: 2014-03-28 16:46:52.0 | 2014-03-28 16:47:35 HD Request # 2 - Using server: scdf2.sierracharts.com port 10149 | 2014-03-28 16:47:35 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-03-28 16:47:35 The network socket is connected. | 2014-03-28 16:47:35 HD Request # 2 - Sending historical data logon request message. | 2014-03-28 16:47:35 HD Request # 2 - Requesting Intraday data. Max. days to return: 360. Start Date-Time: 2014-03-28 20:46:52. Record interval: 0 | 2014-03-28 16:47:35 HD Request # 2 - Decompressing data. | 2014-03-28 16:47:35 HD Request # 2 - Historical data for ESM4-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-03-28 16:47:35 Socket has been shutdown and closed. | 2014-03-28 16:47:35 The network socket for historical data has been closed. | 2014-03-28 16:47:35 HD Request # 2 - Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM4-CME | 2014-03-28 16:47:35 HD Request # 2 - Intraday download COMPLETE for ESM4-CME | 2014-03-28 16:47:35 Rithmic Trading - Port for executable: 22047 | 2014-03-28 16:47:37 Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-28 16:47:37 Rithmic Trading: Connecting to the server 127.0.0.1. Port 22047 | 2014-03-28 16:47:39 The network socket is connected. | 2014-03-28 16:47:39 Rithmic Trading: Connected to server. | 2014-03-28 16:47:39 Rithmic Trading: Sending logon request message. | 2014-03-28 16:47:39 Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-28 16:47:39 Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-28 16:47:39 Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-28 16:47:39 Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-28 16:47:46 Rithmic Trading - Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2014-03-28 16:47:46 Rithmic Trading - Server Alert: Trading System Connection Opened | 2014-03-28 16:47:46 Rithmic Trading - Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2014-03-28 16:47:46 Rithmic Trading - Server Alert: PnL Connection Opened | 2014-03-28 16:47:46 Rithmic Trading - Server Alert: PnL Connection Login Complete. Result text: "ok" | 2014-03-28 16:47:46 Rithmic Trading - Server Alert: Intraday History Connection Opened | 2014-03-28 16:47:46 Rithmic Trading - Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2014-03-28 16:47:46 Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-28 16:47:46 Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-28 16:47:46 Rithmic DTC - Successfully connected. | 2014-03-28 16:47:46 Rithmic DTC: Requesting trade accounts from server. | 2014-03-28 16:47:46 Mapping ESM4-CME to ESM4. Service code: cme | 2014-03-28 16:47:46 SC Exchange Data - Starting real-time market data updates for: ESM4 | 2014-03-28 16:47:46 Using username 0 | 2014-03-28 16:47:46 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-03-28 16:47:46 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-03-28 16:47:46 HD Request # 3 - Downloading Intraday chart data for ESM4-CME to the file ESM4-CME.scid. Service: cme | 2014-03-28 16:47:46 HD Request # 3 - Download start Date-Time: 2014-03-28 16:46:52.0 | 2014-03-28 16:47:46 HD Request # 3 - Using server: scdf1.sierracharts.com port 10149 | 2014-03-28 16:47:46 The network socket is connected. | 2014-03-28 16:47:46 SC Exchange Data: Connected to server. | 2014-03-28 16:47:46 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-03-28 16:47:46 SC Exchange Data: Sending logon request message. | 2014-03-28 16:47:46 The network socket is connected. | 2014-03-28 16:47:46 HD Request # 3 - Sending historical data logon request message. | 2014-03-28 16:47:46 SC Exchange Data Server Info - Server Name: . Server Version: . Provider Name: . | 2014-03-28 16:47:47 SC Exchange Data - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-28 16:47:47 SC Exchange Data - Successfully connected. | 2014-03-28 16:47:47 SC Exchange Data - Restarting real-time data updates for symbol: ESM4-CME -> ESM4 | 2014-03-28 16:47:47 HD Request # 3 - Requesting Intraday data. Max. days to return: 360. Start Date-Time: 2014-03-28 20:46:52. Record interval: 0 | 2014-03-28 16:47:47 HD Request # 3 - Decompressing data. | 2014-03-28 16:47:47 HD Request # 3 - Receiving Intraday data for ESM4-CME starting at 2014-03-28 16:46:52 | 2014-03-28 16:47:47 HD Request # 3 - Timestamp of first Intraday data file record written: 2014-03-28 16:47:19 | 2014-03-28 16:47:47 Socket has been shutdown and closed. | 2014-03-28 16:47:47 The network socket for historical data has been closed. | 2014-03-28 16:47:47 HD Request # 3 - Received 5 records from 2014-03-28 16:46:52 to 2014-03-28 16:47:36 (44.0 seconds) and wrote 4 records for ESM4-CME | 2014-03-28 16:47:47 HD Request # 3 - Intraday download COMPLETE for ESM4-CME | 2014-03-28 16:47:47 Real-time Intraday chart data file updates started for ESM4-CME | 2014-03-28 16:47:47 Rithmic DTC: Requesting Trade Positions data. | 2014-03-28 16:47:51 Requesting market depth updates for: ESM4-CME if supported. | 2014-03-28 16:47:51 Market Depth data has been rejected for symbol: ESM4-CME. Not authorized for market depth. | 2014-03-28 16:47:51 HD Request # 4 - Downloading Intraday chart data for ESM4-CME to the file ESM4-CME.scid. Service: cme | 2014-03-28 16:50:10 HD Request # 4 - Truncating file to starting Date-Time of 2013-04-01 20:00:00 | 2014-03-28 16:50:10 HD Request # 4 - Download start Date-Time: 2013-04-01 19:59:59.0 | 2014-03-28 16:50:10 HD Request # 4 - Using server: scdf2.sierracharts.com port 10149 | 2014-03-28 16:50:10 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-03-28 16:50:10 The network socket is connected. | 2014-03-28 16:50:10 HD Request # 4 - Sending historical data logon request message. | 2014-03-28 16:50:10 HD Request # 4 - Requesting Intraday data. Start Date-Time: 2013-04-01 23:59:59. Record interval: 0 | 2014-03-28 16:50:10 HD Request # 4 - Decompressing data. | 2014-03-28 16:50:10 HD Request # 4 - Receiving Intraday data for ESM4-CME starting at 2013-11-04 04:46:14 | 2014-03-28 16:50:10 HD Request # 4 - Timestamp of first Intraday data file record written: 2013-11-04 04:46:14 | 2014-03-28 16:50:10 Socket has been shutdown and closed. | 2014-03-28 16:50:18 The network socket for historical data has been closed. | 2014-03-28 16:50:18 HD Request # 4 - Received 5346265 records from 2013-11-04 04:46:14 to 2014-03-28 16:50:05 (144.5 days) and wrote 5346265 records for ESM4-CME | 2014-03-28 16:50:18 HD Request # 4 - Intraday download COMPLETE for ESM4-CME | 2014-03-28 16:50:18 Real-time Intraday chart data file updates started for ESM4-CME | 2014-03-28 16:50:18 HD Request # 4 - Reloading Intraday charts for symbol. | 2014-03-28 16:50:18 Reloading all charts with filename: ESM4-CME.scid | 2014-03-28 16:50:18 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13 | 2014-03-28 16:50:18 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12 | 2014-03-28 16:50:18 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12 | 2014-03-28 16:50:18 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13 | 2014-03-28 16:50:18 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12 | 2014-03-28 16:50:18 Intraday data file for ESM3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:50:18 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-03-28 16:50:18 Intraday data file for ESU3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:50:18 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-03-28 16:50:18 Intraday data file for ESZ3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:50:18 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-03-28 16:50:18 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13 | 2014-03-28 16:50:18 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-03-28 16:50:18 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 0 | 2014-03-28 16:50:18 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-03-28 16:50:18 Symbols used for ESM4-CME continuous contract chart: | 2014-03-28 16:50:18 ESM3-CME | 2014-03-28 16:50:18 ESU3-CME | 2014-03-28 16:50:18 ESZ3-CME | 2014-03-28 16:50:18 ESH4-CME | 2014-03-28 16:50:18 ESM4-CME | 2014-03-28 16:50:18 ESM4-CME [CB] [M] 1 Day #2: Performing continuous futures contract back adjustment calculations. | 2014-03-28 16:50:18 ESM4-CME [CB] [M] 1 Day #2: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2014-03-28 16:50:18 ESM4-CME [CB] [M] 1 Day #2: ESU3-CME Open price on 2013-06-13 is 1605. | 2014-03-28 16:50:18 ESM4-CME [CB] [M] 1 Day #2: ESM3-CME price difference to ESU3-CME is -5.75. | 2014-03-28 16:50:18 ESM4-CME [CB] [M] 1 Day #2: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2014-03-28 16:50:18 ESM4-CME [CB] [M] 1 Day #2: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2014-03-28 16:50:18 ESM4-CME [CB] [M] 1 Day #2: ESU3-CME price difference to ESZ3-CME is -6.5. | 2014-03-28 16:50:18 ESM4-CME [CB] [M] 1 Day #2: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #2: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #2: ESZ3-CME price difference to ESH4-CME is -6.5. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #2: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #2: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #2: ESH4-CME price difference to ESM4-CME is -7.25. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #2: Back adjust amount for symbol ESM3-CME is -26. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #2: Back adjust amount for symbol ESU3-CME is -20.25. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #2: Back adjust amount for symbol ESZ3-CME is -13.75. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #2: Back adjust amount for symbol ESH4-CME is -7.25. | 2014-03-28 16:50:19 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13 | 2014-03-28 16:50:19 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12 | 2014-03-28 16:50:19 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12 | 2014-03-28 16:50:19 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13 | 2014-03-28 16:50:19 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12 | 2014-03-28 16:50:19 Intraday data file for ESM3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:50:19 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-03-28 16:50:19 Intraday data file for ESU3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:50:19 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-03-28 16:50:19 Intraday data file for ESZ3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:50:19 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-03-28 16:50:19 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13 | 2014-03-28 16:50:19 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-03-28 16:50:19 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 0 | 2014-03-28 16:50:19 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-03-28 16:50:19 Symbols used for ESM4-CME continuous contract chart: | 2014-03-28 16:50:19 ESM3-CME | 2014-03-28 16:50:19 ESU3-CME | 2014-03-28 16:50:19 ESZ3-CME | 2014-03-28 16:50:19 ESH4-CME | 2014-03-28 16:50:19 ESM4-CME | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: Performing continuous futures contract back adjustment calculations. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESU3-CME Open price on 2013-06-13 is 1605. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESM3-CME price difference to ESU3-CME is -5.75. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESU3-CME price difference to ESZ3-CME is -6.5. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESZ3-CME price difference to ESH4-CME is -6.5. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: ESH4-CME price difference to ESM4-CME is -7.25. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: Back adjust amount for symbol ESM3-CME is -26. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: Back adjust amount for symbol ESU3-CME is -20.25. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: Back adjust amount for symbol ESZ3-CME is -13.75. | 2014-03-28 16:50:19 ESM4-CME [CB] [M] 1 Day #1: Back adjust amount for symbol ESH4-CME is -7.25. | 2014-03-28 16:50:19 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13 | 2014-03-28 16:50:20 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12 | 2014-03-28 16:50:20 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13 | 2014-03-28 16:50:20 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-03-28 16:50:20 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 0 | 2014-03-28 16:50:20 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-03-28 16:50:20 Symbols used for ESM4-CME continuous contract chart: | 2014-03-28 16:50:20 ESH4-CME | 2014-03-28 16:50:20 ESM4-CME | 2014-03-28 16:50:20 ESM4-CME [CB] [M] Rev. 5t #7: Performing continuous futures contract back adjustment calculations. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] Rev. 5t #7: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] Rev. 5t #7: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] Rev. 5t #7: ESH4-CME price difference to ESM4-CME is -7.25. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] Rev. 5t #7: Back adjust amount for symbol ESH4-CME is -7.25. | 2014-03-28 16:50:20 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13 | 2014-03-28 16:50:20 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12 | 2014-03-28 16:50:20 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12 | 2014-03-28 16:50:20 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13 | 2014-03-28 16:50:20 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12 | 2014-03-28 16:50:20 Intraday data file for ESM3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:50:20 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-03-28 16:50:20 Intraday data file for ESU3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:50:20 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-03-28 16:50:20 Intraday data file for ESZ3-CME exists and is empty. Skipping Intraday data download. | 2014-03-28 16:50:20 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-03-28 16:50:20 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13 | 2014-03-28 16:50:20 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-08 | 2014-03-28 16:50:20 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 0 | 2014-03-28 16:50:20 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 0 | 2014-03-28 16:50:20 Symbols used for ESM4-CME continuous contract chart: | 2014-03-28 16:50:20 ESM3-CME | 2014-03-28 16:50:20 ESU3-CME | 2014-03-28 16:50:20 ESZ3-CME | 2014-03-28 16:50:20 ESH4-CME | 2014-03-28 16:50:20 ESM4-CME | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESU3-CME Open price on 2013-06-13 is 1605. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESM3-CME price difference to ESU3-CME is -5.75. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESU3-CME price difference to ESZ3-CME is -6.5. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESZ3-CME price difference to ESH4-CME is -6.5. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: ESH4-CME price difference to ESM4-CME is -7.25. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: Back adjust amount for symbol ESM3-CME is -26. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: Back adjust amount for symbol ESU3-CME is -20.25. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: Back adjust amount for symbol ESZ3-CME is -13.75. | 2014-03-28 16:50:20 ESM4-CME [CB] [M] 30 Min #4: Back adjust amount for symbol ESH4-CME is -7.25. | 2014-03-28 16:50:20 |
[2014-03-28 21:14:57] |
Follow through the procedure here to do a full re-download of the data: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Be sure to re-download the data for each contract. This may be necessary to clear out the older data from the previous Rithmic connection and get the fresh data from the Sierra Chart server. If you still have a problem we could call in about 20 minutes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-28 21:35:57] |
I tried that previously for each chart, it had no affect. This time it worked for all but one intraday chart. Please call.
