Date/Time: Sat, 27 Apr 2024 09:39:07 +0000
Unable to load Gold/COMEX charts, but all CME indices load.
View Count: 632
[2021-09-15 13:56:37] |
alhajj - Posts: 7 |
I am unable to pull up a chart or DOM for GC. I have the Denali Data Feed package and it says I have data for Comex also but it will not load anything when I attempt to change the chart symbol to GC.
[2021-09-15 15:19:52] |
We need to know the exact symbol of the chart or trading DOM. First open a chart for that symbol and then follow the instructions below. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-15 15:20:05
[2021-09-15 16:00:15] |
alhajj - Posts: 7 |
Software version: 2299 64-bit | 2021-09-15 15:57:46.072 Primary Thread ID: 18600 | 2021-09-15 15:57:46.072 Usage end date: 2021-10-15 | 2021-09-15 15:57:46.072 Enabled for: Sierra Chart Historical Data Service. | 2021-09-15 15:57:46.072 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-09-15 15:57:46.072 Enabled for: Delayed Denali Exchange Data Feed. | 2021-09-15 15:57:46.072 Enabled for exchange2: CME (Trading Account Required) | 2021-09-15 15:57:46.072 Enabled for exchange2: CBOT (Trading Account Required) | 2021-09-15 15:57:46.072 Enabled for exchange2: COMEX (Trading Account Required) | 2021-09-15 15:57:46.072 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-09-15 15:57:46.072 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-09-15 15:57:46.072 Current selected Data/Trading service: CQG WebAPI | 2021-09-15 15:57:46.072 Custom symbol settings values: enabled | 2021-09-15 15:57:46.072 Chart Update Interval: 500 | 2021-09-15 15:57:46.072 Intraday Data Storage Time Unit: 1 | 2021-09-15 15:57:46.072 Time Zone: +00:00:00 (UTC+00) | 2021-09-15 15:57:46.072 2021-09-15 15:57:46 Local computer time in UTC | 2021-09-15 15:57:46.072 2021-09-15 15:57:46 Local computer time in SC Time Zone | 2021-09-15 15:57:46.072 2021-09-15 12:52:00 Server time in UTC | 2021-09-15 15:57:46.072 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-09-15 15:57:46.072 Program path: C:\SierraChart\ | 2021-09-15 15:57:46.072 Data Files path: C:\SierraChart\Data\ | 2021-09-15 15:57:46.072 OS Version Number: 10.0 | 2021-09-15 15:57:46.073 Locale Setting: C | 2021-09-15 15:57:46.073 DLLs: UserContributedStudies_64.dll | 2021-09-15 15:57:46.073 Allowed protected custom studies: | 2021-09-15 15:57:46.073 |
[2021-09-15 16:02:20] |
alhajj - Posts: 7 |
https://gyazo.com/6802557e862dbf3f738961e7e8f57060 this link contains a screenshot of the window when i attempt to change the symbol from RTYZ21 to F.US.GCE
[2021-09-15 17:20:33] |
We need for you to repeat the process to get the Message Log, but this time we need you to open the chart for GC as well. Follow these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-16 13:04:37] |
alhajj - Posts: 7 |
John, I cannot open the chart. Nothing happens when I click open Intraday Chart for GC, nothing.
Date Time Of Last Edit: 2021-09-16 13:08:59
[2021-09-16 14:54:37] |
We would like to do a quick call and a remote assistance session to see what the issue is. Let us know when is a good time to call.
[2021-09-17 14:19:57] |
alhajj - Posts: 7 |
Anytime between 12pm-1pm eastern works for me
[2021-09-17 16:34:58] |
We tried calling but there was no answer.
[2021-09-21 13:36:29] |
alhajj - Posts: 7 |
Are you attempting to reach out via my listed phone number? or Zoom.
[2021-09-21 13:47:06] |
Through the telephone number on your account here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo We just tried calling again now but no answer. And the mailbox is full. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-21 13:48:15
[2021-09-21 14:53:34] |
Called user and helped with issue. Charts were opening up, in the main Sierra Chart window which was either minimized or small. Other charts which they were using were detached.
