Date/Time: Wed, 04 Nov 2026 09:29:27 +0000
TICK/TRIN is on time. Denali real time is delayed
View Count: 1008
[2021-03-05 17:28:37]
User439924 - Posts: 4
Hello:
The TICK and TRIN charts are running in real time. The Denali real time is delayed. Any thoughts on how to fix this?
Thanks,
Bob
[2021-03-05 17:55:34]
Make sure the option for File >> Data/Trade Service Settings >> Common Settings >> Allow Support For Sierra Chart Data Feeds is set to Yes. If not, then set to Yes and then select File >> Disconnect, then File >> Connect to Data Feed. Refer to the following:
Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings)
Otherwise, we need to see your Message Log following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2021-03-06 00:48:44]
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
We recommend using the above solution in any case to avoid this problem in the future.
