Date/Time: Thu, 02 May 2024 11:19:32 +0000
CQG Symbols problem
View Count: 1704
[2021-03-01 17:48:07] |
User565325 - Posts: 11 |
Hi, It seems i have 6 days to renew my services. I'm on AMP broker. Last week, i needed to switch to CQG because TT problems on CME. Today i can't trade because CGQ doesn't recognized the symbols even after translation. I could see an important message on sierra that the packages and prices are changing also Ok. I'm little lost about all those changing. I just want to trade CME and pay sierra sevices. What is the best stable solution to set my trading? Best/ Patrice Cartier it says: symbol error F.US.MESH21 is unknown, unvailable or improperly formatted. also, CQG WebAPI Market data subscription for F.US.MESH21 was unsuccesful thx Patrice/ 136109 AMP account |
[2021-03-01 20:20:17] |
John - SC Support - Posts: 31293 |
With regards to your account, you are fine, as you are paying for your Sierra Chart directly to us. The main upcoming change is that we will be changing how accounts that are setup through a broker are handled, but this does not apply to you. With regards to your error, you should not be getting that message given the symbol that you have listed, as it is correct for CQG. We would need to see the Message Log following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog ----------------------------- On a separate note, your Denali Exchange Data Feed did not renew on March 1, 2021 (today) since you did not have enough funds in your account. If you want to continue to get your data from us, then you will want to add funds to your account and reactivate the Denali Exchange Data Feed. Refer to the Setup Instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-01 22:01:41] |
Hi, thank for your answer. Yes, i will renew the Sierra services on wednesday before the 2021-03-06 expiration. I'm trading on MES. the log: Software version: 2219 64-bit | 2021-03-01 15:55:48.276 Primary Thread ID: 4728 | 2021-03-01 15:55:48.276 Usage end date: 2021-03-06 | 2021-03-01 15:55:48.276 Enabled for: Advanced Features 2. | 2021-03-01 15:55:48.276 Enabled for: Sierra Chart Historical Data Service. | 2021-03-01 15:55:48.276 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-03-01 15:55:48.276 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-03-01 15:55:48.276 Current selected Data/Trading service: CQG WebAPI | 2021-03-01 15:55:48.276 Custom symbol settings values: enabled | 2021-03-01 15:55:48.276 Chart Update Interval: 10 | 2021-03-01 15:55:48.276 Intraday Data Storage Time Unit: 0 | 2021-03-01 15:55:48.276 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-03-01 15:55:48.276 2021-03-01 21:55:48 Local computer time in UTC | 2021-03-01 15:55:48.276 2021-03-01 15:55:48 Local computer time in SC Time Zone | 2021-03-01 15:55:48.276 2021-03-01 21:53:02 Server time in UTC | 2021-03-01 15:55:48.276 Local computer UTC time and Server UTC time difference: 2 seconds. | 2021-03-01 15:55:48.276 Program path: C:\SierraChart\ | 2021-03-01 15:55:48.276 Data Files path: C:\SierraChart\Data\ | 2021-03-01 15:55:48.276 OS Version Number: 10.0 | 2021-03-01 15:55:48.277 Locale Setting: C | 2021-03-01 15:55:48.277 DLLs: UserContributedStudies_64.dll | 2021-03-01 15:55:48.277 Allowed protected custom studies: | 2021-03-01 15:55:48.277 File >> Disconnect selected. | 2021-03-01 15:55:54.763 CQG WebAPI | Sending Web API Logoff message. | 2021-03-01 15:55:54.766 CQG WebSocket socket (1) | CloseSocket call. | 2021-03-01 15:55:54.766 CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-03-01 15:55:54.766 CQG WebSocket | WebSocket closed. | 2021-03-01 15:55:54.766 CQG WebAPI | WebSocket closed. | 2021-03-01 15:55:54.766 CQG WebAPI | Disconnected. | 2021-03-01 15:55:54.766 CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-03-01 15:55:54.766 CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2021-03-01 15:55:54.793 CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-03-01 15:55:54.794 CQG WebAPI | Connecting to server api.cqg.com | 2021-03-01 15:55:58.251 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-03-01 15:55:58.251 CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2021-03-01 15:55:58.251 CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2021-03-01 15:55:58.251 CQG WebSocket socket (2) | Connecting to IP: 195.166.124.165. | 2021-03-01 15:55:58.251 CQG WebSocket | Opening WebSocket. | 2021-03-01 15:55:58.280 CQG WebSocket | Sending WebSocket handshake. | 2021-03-01 15:55:58.280 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-03-01 15:55:58.379 CQG WebSocket | Server header | Connection: upgrade | 2021-03-01 15:55:58.379 CQG WebSocket | Server header | Sec-WebSocket-Accept: wBkN1CKukyulDpH+FrW7wkP2glM= | 2021-03-01 15:55:58.379 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-03-01 15:55:58.379 CQG WebSocket | Server header | Upgrade: websocket | 2021-03-01 15:55:58.379 CQG WebSocket | Server header | | 2021-03-01 15:55:58.379 CQG WebSocket | Web socket state is now open. | 2021-03-01 15:55:58.379 CQG WebAPI | WebSocket connected. | 2021-03-01 15:55:58.379 CQG WebAPI | Sending market data logon message. | 2021-03-01 15:55:58.379 CQG WebAPI | Base Time: 2021-02-28T20:29:00. 2021-02-28 20:29:00 | 2021-03-01 15:55:59.173 CQG WebAPI | Logon successful. Session Token = m8/Y6S3KyhRjTEUDYHTnStXXI9gbdLOU66xIN6IKtGYeZEPGI+lSrI1RLXQPxv25lp/lA3+WtNi | 2021-03-01 15:55:59.173 CQG WebAPI | Connected to server complete. | 2021-03-01 15:55:59.173 Triggering next historical data download in queue. | 2021-03-01 15:55:59.173 Triggering next historical data download in queue. | 2021-03-01 15:55:59.173 Triggering next historical data download in queue. | 2021-03-01 15:55:59.174 Triggering next historical data download in queue. | 2021-03-01 15:55:59.174 Updated verified funded futures trading account ending date to: 2021-03-31 21:55:59 | 2021-03-01 15:55:59.174 CQG WebAPI | Sending Trade Accounts request message. | 2021-03-01 15:55:59.177 No download requests in the queue to start downloads for. | 2021-03-01 15:55:59.177 No download requests in the queue to start downloads for. | 2021-03-01 15:55:59.177 No download requests in the queue to start downloads for. | 2021-03-01 15:55:59.177 No download requests in the queue to start downloads for. | 2021-03-01 15:55:59.177 CQG WebAPI | Starting real-time market data updates for: F.US.MESH21. ID: 1 Service code: cqg | 2021-03-01 15:55:59.178 CQG WebAPI | Sending symbol resolution request for F.US.MESH21. ID: 483800 | 2021-03-01 15:55:59.178 CQG WebAPI | Requesting security definition data for: F.US.MESH21. ID: 1 | 2021-03-01 15:55:59.178 CQG WebAPI | Using primary service for historical data for F.US.MESH21 | 2021-03-01 15:55:59.178 Added historical Intraday data request for F.US.MESH21 to the queue. | 2021-03-01 15:55:59.178 Intraday data recording state for symbol F.US.MESH21 is set to download 'Pending'. | 2021-03-01 15:55:59.178 Triggering next historical data download in queue. | 2021-03-01 15:55:59.178 Delaying start of download for F.US.MESH21 | 2021-03-01 15:55:59.200 CQG WebAPI | Brokerage name: AMP. Account Name: 136109 | 2021-03-01 15:55:59.262 CQG WebAPI | Sending collateral subscribe request. | 2021-03-01 15:55:59.262 CQG WebAPI | Received symbol resolution report for symbol F.US.MESH21. Search Symbol: F.US.MESH21. Request ID: 483800. Contract ID: 1. | 2021-03-01 15:55:59.275 CQG WebAPI | Requesting market data for F.US.MESH21 | 2021-03-01 15:55:59.275 CQG WebAPI | Market data subscription for F.US.MESH21 was unsuccessful. Text: Real-time data for instrument F.US.MES (corresponding to ID = 1) are not allowed. | 2021-03-01 15:55:59.353 Symbol Error - F.US.MESH21 is unknown, unavailable, or improperly formatted. Real-time data for instrument F.US.MES (corresponding to ID = 1) are not allowed. | 2021-03-01 15:55:59.353 HD Request # 2 | Downloading Intraday chart data for F.US.MESH21 to the file F.US.MESH21.scid. Service: cqg | 2021-03-01 15:55:59.460 HD Request # 2 | Download start date-time: 2021-02-26 15:59:59.000000. File last date-time: 2021-02-26 15:59:59.573000 | 2021-03-01 15:55:59.461 HD Request # 2 | Requesting historical Tick data. | 2021-03-01 15:55:59.461 HD Request # 2 | Error downloading historical Intraday data for F.US.MESH21. End Of Day data is not allowed for given data type. Result=103. Num Quotes=0 | 2021-03-01 15:55:59.538 HD Request # 2 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.MESH21 | 2021-03-01 15:55:59.538 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2021-02-26 21:59:59.573000 | 2021-03-01 15:55:59.539 HD Request # 2 | Completion time: 0s | 2021-03-01 15:55:59.539 HD Request # 2 | Intraday data download complete for F.US.MESH21. Unique request ID: 2 | 2021-03-01 15:55:59.539 Removing historical data download ID 2. | 2021-03-01 15:55:59.539 Real-time Intraday chart data file updates started for F.US.MESH21 | 2021-03-01 15:55:59.539 Intraday chart data file opened for F.US.MESH21 | 2021-03-01 15:55:59.539 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-03-01 15:55:59.539 Triggering next historical data download in queue. | 2021-03-01 15:55:59.539 No download requests in the queue to start downloads for. | 2021-03-01 15:55:59.539 CQG WebAPI | Sending positions subscribe request. RequestID: 483803 | 2021-03-01 15:56:04.172 CQG WebAPI | Sending orders subscribe request. RequestID=483804 | 2021-03-01 15:56:04.172 Requesting market depth updates for: F.US.MESH21 if supported. | 2021-03-01 15:56:04.173 CQG WebAPI | Requesting market data including full depth for F.US.MESH21 | 2021-03-01 15:56:04.173 CQG WebAPI | Market data subscription for F.US.MESH21 was unsuccessful. Text: Real-time data for instrument F.US.MES (corresponding to ID = 1) are not allowed. | 2021-03-01 15:56:04.253 Symbol Error - F.US.MESH21 is unknown, unavailable, or improperly formatted. Real-time data for instrument F.US.MES (corresponding to ID = 1) are not allowed. | 2021-03-01 15:56:04.253 CQG WebSocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-03-01 15:57:58.227 CQG WebSocket socket (1) | Closed. | 2021-03-01 15:57:58.227 CQG WebSocket socket (1) | Deleting network socket now after delay. | 2021-03-01 15:58:28.240 Best |
[2021-03-01 22:23:51] |
Refer to the information at the following link: CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-01 22:40:22] |
Yes, i did it earlier. But i don’t understand what is Wrong. It worked last week when i switched to CQG because of TT CME Order problems. It was working perfectly before this change Also. Today it doesn’t work and i didn’t touch anything... I asked to AMP, They told me to see the issue with sierra C. It worked fine, and now not. What’s wrong? Please. Best regards |
[2021-03-02 00:19:02] |
The problem here is that you have been using the Denali Exchange Data Feed but it did not renew due to an insufficient balance. We have changed your package to 11 which now includes that data feed and you need to add credit here to cover the cost of exchange fees: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit And then you need to activate the exchange you want here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Once that is done you will be all set. Disregard any other information in this thread related to CQG market data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-02 00:19:17
[2021-03-02 10:45:27] |
Ok, many thanks. I will make the necessary today. Best P. |
