Date/Time: Wed, 01 May 2024 23:14:22 +0000
AMP account change
View Count: 511
[2021-01-05 17:14:32] |
User313147 - Posts: 42 |
I want to use delayed data feed in the package 5 that I have to trade. I was using CQG for order routing service but the data wasn't showing good enough. Is it possible to use my delayed data feed via package 5 with sierra and trade through that service? if so do I use TT for order routing? If that's the case how do I then set it up in sierra? |
[2021-01-05 17:59:40] |
John - SC Support - Posts: 31283 |
Theoretically what you are asking for is possible, but do you really want to place a trade based on data that is 10 minutes and 10 seconds old? Additionally, it will be hard to do anything but place Market Orders as you will not know the current price and therefore will not know where to place a Limit Order (for example). We really recommend activating the Denali Exchange Data Feed and the appropriate exchange(s) in order to get Real-Time data. Refer to the information on this page: Denali Exchange Data Feed It is really up to you as to whether you continue to use CQG or change to the Sierra Chart Order Routing Service for your trades. In either case, the Delayed Exchange Data Feed is available. Refer to the information here: Delayed Exchange Data Feed If you want to use the Sierra Chart Order Routing Service, then refer to the following page, which also has Setup Instructions on it: Sierra Chart / Trading Technologies Futures Order Routing Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-05 18:11:58] |
Yes for now I would like to be able to use my AMP account with delayed feed. How do I set this up please? |
[2021-01-05 18:27:43] |
Are you going to be using CQG or the Sierra Chart Order Routing Service with AMP?
[2021-01-05 18:29:58] |
sierra chart please
[2021-01-05 18:34:29] |
Then let AMP know that you will be getting this setup. After that, then follow the Setup Instructions on this page: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions You will just ignore the sections related to setting up the Denali Exchange Data Feed. Instead, you will just be using the Delayed Data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-05 19:34:54] |
Using delayed data with the Sierra Chart Order Routing Service is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#UsingDelayedMarketData And you will want to complete this form to use the Sierra Chart Order Routing Service: https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
