Date/Time: Thu, 02 May 2024 19:36:47 +0000
OPTIONS not working
View Count: 611
[2020-06-24 17:17:30] |
taipeicity - Posts: 52 |
hi, my options chart stopped working since tuesday E4CM20 C3070.FUT_OPT.CME did u change the format? |
[2020-06-24 18:01:01] |
That symbol is expired. It is a June 20 symbol. There are no format changes.
[2020-06-25 04:08:15] |
EW4M20 C3080.FUT_OPT.CME the above symbol is found from your symbol list, not expired it is expired on June 26, they just do not work please you need to listen to customer's problem, it is NOT expired i can not wait for support borad to reply, it is urgent it just happened since tuesday |
[2020-06-25 05:11:18] |
Sierra_Chart Engineering - Posts: 14183 |
We did check this symbol and we do see there is trading still occurring for it: EW4M20 C3080.FUT_OPT.CME We did say it was expired because it is a June 2020 contract and we are near the end of June so we just made a reasonable conclusion that trading had ended in it already. This may not be relevant but you are running an older version of Sierra Chart. We want you to update to the current version following these instructions: Software Download: Fast Update After that we want you to follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-25 05:11:33
[2020-06-25 09:06:11] |
i have been trading options for many years and everyday IT IS NOT EXPIRED, AND IT happened first time on SC charts; it never happened before !!!! ALL OPTIONS CHARTS ARE NOT LOADING, NOT ONLY JUNE CONTRACTS YOU UNDERSTAND NOW ?????? PLEASE FIXED IT |
[2020-06-25 09:28:12] |
How can we help you if you are not providing us the information that we need? Did you see our prior post? There is no point in asking us for further help if our instructions are not followed. We have verified that we are receiving data for that option symbol from all three Sierra Chart servers for the Denali data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-25 09:37:57
[2020-06-25 17:30:54] |
OPTIONS JUST NOT WORKING SINCE TUESDAY
sc-option2.png / V - Attached On 2020-06-25 17:28:21 UTC - Size: 130.55 KB - 205 views sc-options.png / V - Attached On 2020-06-25 17:28:27 UTC - Size: 115.14 KB - 191 views Attachment Deleted. |
[2020-06-25 18:49:43] |
This is not the information we need. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-23 07:17:14] |
same problem again ....ES options charts do not load .... error message "SYMBOL NOT FOUND ON THIS SYSTEM" is it a routine problem ?????? HAPPENED ON JUne 24, August 22, now october 22 PLEASE FIX IT ASAP, really driving me nuts every 2 months, what did i do wrong, please tell me |
[2020-10-23 09:07:03] |
First we want you to update the Symbol Settings. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Denali data feed futures options are only now provided with the SC Data-All Services service and the SC Order Routing service. And not with Interactive Brokers. Instructions to access them are here: Real-Time Exchange Data Feeds Available From Sierra Chart: Futures Options So you need to install another copy of Sierra Chart if necessary to access the options data: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-23 09:07:26
