Date/Time: Sat, 18 May 2024 10:42:31 +0000
Multiple connections in SC
View Count: 1109
[2020-05-15 16:56:08] |
Antonino De Rosa - Posts: 47 |
Dear SC Team, as i understand in your post below, i can have three connections with my three screens on the same system isn´t it ?Could you explain or discribe how I can open three connections to SC with the same system on three screens ? Or on two different computers ? Actually I use Denali fort the CBOT and SC Datafeed for Eurex DATAS Furthermore I would like to use also the delayed CME data. How can manage this in combination with more connections ? To take advantage of 3 connections per system requires that you are running the current version of Sierra Chart which is now 2074: Software Download: Fast Update Make sure you update if you need to be able to connect to the Denali Data Feed more than once from the same system. The connection management changes described in the first post, will go into effect after the close today (2020-04-02). If you previously have been accessing the Denali feed on two different systems, then the solution is to use a single system and run all of the installations that you need of Sierra Chart on that one system. You can receive 3 direct connections to the Denali Data Feed on that system and you can share the data to as many installations of Sierra Chart as you need. Install the number of monitors you need to that system. ( How can i do this )??? And if you need to access it remotely just simply use Windows Remote Desktop Connection or Team Viewer. Many thanks in advance and kind regards. Antonino |
[2020-05-15 20:02:03] |
Are these "three screens" different computers?
[2020-05-15 20:05:01] |
No only one computer
[2020-05-15 20:14:48] |
Run Sierra Chart on a single computer and use the File >> New Instance to create multiple instances of Sierra Chart that you can move to the other monitors. Refer to the information here: Using DTC Server for Data and Trading in Another Sierra Chart Instance All of these instances will then have access to the data feeds that you have enabled. You should already be receiving the Delayed Streaming data for the CME Group of exchanges that you do not have activated. Refer to the information here on this data: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-15 21:23:11
[2020-05-15 20:20:54] |
Many thanks. I‘ll try it.
[2020-05-15 21:39:36] |
Just tested, but in the DATA TRADE SERVICE SETTINGS I can`t Change the Service in SC Futures / Orders Routing Data. There appears DTC- Sub Instance ( trading ) And don´t open any Symbol. |
[2020-05-17 02:32:12] |
No you definitely do not have to change the Global Settings >> Data/Trade Service Settings >> Service setting. In regards to post #6, what do you want to do specifically? Just tell us one of those things. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-17 08:38:58] |
I want to open three instances on three screens with one computer. I did ir. But in two of three screens i don’t receive data when i open a chartbook. How should i set up the other two screens / instances ? Can i receive also the delayed CME data with this settings. Thank you |
[2020-05-17 10:01:32] |
It looks as though that you did start those instances with File >> New Instance. So there should not be any problem. Tell us the symbol of one of the charts that is not updating in the sub instance, and provide the Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog ---- However, please wait until Sunday evening when the markets open. For any CME Group symbol you are not paying for real-time data for, you will automatically receive delayed data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-18 08:22:03
[2020-05-18 08:21:36] |
If you are still not receiving the delayed data automatically update to the very latest prerelease which is now 2106: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-18 08:21:43
[2020-05-18 08:28:50] |
Dear SC Team, many thanks for your support. Everything is working fine now. I receive the delayed data for the ES. The three instances now are also working already fine with the realtime datas. Many thanks again for your support!! Best regards Antonino |
