Date/Time: Thu, 16 May 2024 16:17:57 +0000
data not udating
View Count: 1298
[2020-03-02 17:46:49] |
arruga - Posts: 249 |
I'm subscribed to SC data. Lately, few of my open charts just stop updating.. data is not pulsing on those... got few chartbooks open, each with few charts...some are fine, but in some I gotta do 'delete and download' for the chart to bring the latest data... Any reason why this might have started happening, or any advice to chase this out? I'm copying the recent log lines when coming back to my screen and few chart are indeed 'frozen' Message from IB: Sec-def data farm connection is OK:secdefhk. IB Error Code: 2158. Request ID: -1. | 2020-03-03 01:31:36.700 Message from IB: Sec-def data farm connection is broken:secdefhk. IB Error Code: 2157. Request ID: -1. | 2020-03-03 01:46:04.530 Message from IB: Sec-def data farm connection is OK:secdefhk. IB Error Code: 2158. Request ID: -1. | 2020-03-03 01:46:05.842 |
[2020-03-02 19:44:30] |
I just did a SC version fast update. Data still not pulsing here: http://www.sierrachart.com/image.php?Image=1583178029180.png only when I do 'delete and download gets corrected, here:http://www.sierrachart.com/image.php?Image=1583178256554.png Please advise thanks |
[2020-03-02 20:07:40] |
The reason you are not getting real-time data from the CME group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-02 20:08:02
[2020-03-02 21:02:16] |
That can't be the reason. I connect every day to my funded account and trade live from within SC. |
[2020-03-02 21:51:24] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-03 08:15:45] |
Software version: 2057 64-bit | 2020-03-03 18:13:00.586 Usage end date: 2020-03-16 | 2020-03-03 18:13:00.586 Enabled for: Advanced Features 2. | 2020-03-03 18:13:00.586 Enabled for: Sierra Chart Historical Data Service. | 2020-03-03 18:13:00.586 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2020-03-03 18:13:00.586 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-03-03 18:13:00.586 Enabled for exchange: INDEXES_DATA_BARCHART | 2020-03-03 18:13:00.586 Enabled for exchange: CME (Trading Account Required) | 2020-03-03 18:13:00.586 Enabled for exchange: CBOT (Trading Account Required) | 2020-03-03 18:13:00.586 Enabled for exchange: COMEX (Trading Account Required) | 2020-03-03 18:13:00.587 Enabled for exchange: NYMEX (Trading Account Required) | 2020-03-03 18:13:00.587 Enabled for exchange: Eurex with Market Depth | 2020-03-03 18:13:00.587 Received 1 data feed usernames. | 2020-03-03 18:13:00.587 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-03-03 18:13:00.587 Current selected Data/Trading service: Interactive Brokers | 2020-03-03 18:13:00.587 Custom symbol settings values: enabled | 2020-03-03 18:13:00.587 Chart Update Interval: 500 | 2020-03-03 18:13:00.587 Intraday Data Storage Time Unit: 0 | 2020-03-03 18:13:00.587 Time Zone: +10:00:00 (AEST+10) | 2020-03-03 18:13:00.587 2020-03-03 18:13:00 Local computer time | 2020-03-03 18:13:00.587 2020-03-03 08:13:00 Local computer time in UTC | 2020-03-03 18:13:00.587 2020-03-03 18:13:00 Local computer time in SC Time Zone | 2020-03-03 18:13:00.587 2020-03-02 19:28:29 Server time in UTC | 2020-03-03 18:13:00.587 Local computer UTC time and Server UTC time difference: 13 seconds. | 2020-03-03 18:13:00.587 Program path: C:\SierraChart\ | 2020-03-03 18:13:00.587 Data Files path: C:\SierraChart\Data\ | 2020-03-03 18:13:00.587 OS Version Number: 10.0 | 2020-03-03 18:13:00.588 Locale Setting: C | 2020-03-03 18:13:00.588 DLLs: MarketCharts_RealTimeBot_Rev7_64 (1).dll, MarketCharts_RealTimeBot_Testing_Rev1_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-03-03 18:13:00.597 File >> Disconnect selected. | 2020-03-03 18:13:18.193 IB TWS socket (1) | CloseSocket call. | 2020-03-03 18:13:18.376 IB TWS socket (1) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:18.377 IB TWS socket (1) | Socket gracefully closed by remote side. | 2020-03-03 18:13:18.384 IB TWS socket (1) | Closed. | 2020-03-03 18:13:18.384 DTC Client socket (2) | CloseSocket call. | 2020-03-03 18:13:18.391 DTC Client socket (2) | 504 bytes remaining in receive buffer when socket closed. | 2020-03-03 18:13:18.391 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:18.391 SC Data - All Services | Disconnected from the server. | 2020-03-03 18:13:18.392 DTC Client socket (3) | CloseSocket call. | 2020-03-03 18:13:18.395 DTC Client socket (3) | 112 bytes remaining in receive buffer when socket closed. | 2020-03-03 18:13:18.395 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:18.395 SC DTC Data with Market Depth | Disconnected from the server. | 2020-03-03 18:13:18.395 Interactive Brokers | Disconnected. | 2020-03-03 18:13:18.395 DTC Client socket (3) | Socket gracefully closed by remote side. | 2020-03-03 18:13:18.717 DTC Client socket (3) | Closed. | 2020-03-03 18:13:18.717 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-03 18:13:18.869 DTC Client socket (2) | Closed. | 2020-03-03 18:13:18.869 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2020-03-03 18:13:21.798 IB TWS socket (1) | Creating socket. | 2020-03-03 18:13:21.798 IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2020-03-03 18:13:21.798 Interactive Brokers | Sending API sign: API | 2020-03-03 18:13:22.305 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2020-03-03 18:13:22.305 Interactive Brokers | TWS server version: 136 | 2020-03-03 18:13:22.340 Interactive Brokers | TWS time: 20200303 18:13:34 AEST | 2020-03-03 18:13:22.340 Interactive Brokers | Connected. Sending Start API command. | 2020-03-03 18:13:22.592 Interactive Brokers | Waiting for account information. | 2020-03-03 18:13:22.592 Interactive Brokers | Sending request for contract details for contract ID 174319984 | 2020-03-03 18:13:22.599 Interactive Brokers | Sending request for contract details for contract ID 383308385 | 2020-03-03 18:13:22.599 Interactive Brokers | Sending request for contract details for contract ID 362698381 | 2020-03-03 18:13:22.599 Interactive Brokers | Sending request for contract details for contract ID 319684386 | 2020-03-03 18:13:22.654 Interactive Brokers | Sending request for contract details for contract ID 383860620 | 2020-03-03 18:13:22.654 Interactive Brokers | Sending request for contract details for contract ID 173982048 | 2020-03-03 18:13:22.654 IB Account information received. | 2020-03-03 18:13:22.660 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2020-03-03 18:13:22.660 Interactive Brokers | Connected to Live account. | 2020-03-03 18:13:22.660 Interactive Brokers | Year-Month last connected to Live account: 2020-03 | 2020-03-03 18:13:22.660 Interactive Brokers | Connected to data and trading server. | 2020-03-03 18:13:22.660 Triggering next historical data download in queue. | 2020-03-03 18:13:22.671 Triggering next historical data download in queue. | 2020-03-03 18:13:22.671 Triggering next historical data download in queue. | 2020-03-03 18:13:22.671 Triggering next historical data download in queue. | 2020-03-03 18:13:22.671 Subscribing to symbol for symbol alert. DAX-201906-DTB-EUR-5 | 2020-03-03 18:13:22.671 Mapping DAX-201906-DTB-EUR-5 to TMM19. Service code: eurex | 2020-03-03 18:13:22.671 SC Data - All Services | Starting real-time market data updates for: DAX-201906-DTB-EUR-5 (TMM19). ID: 1 Service code: eurex | 2020-03-03 18:13:22.671 SC Data - All Services | Using username 0 | 2020-03-03 18:13:22.671 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2020-03-03 18:13:22.671 SC Data - All Services | Requesting security definition data for: DAX-201906-DTB-EUR-5 (TMM19). ID: 1 | 2020-03-03 18:13:22.671 Subscribing to symbol for symbol alert. DAX-201906-DTB-EUR-5 | 2020-03-03 18:13:22.671 Subscribing to symbol for symbol alert. M6E-201909-GLOBEX | 2020-03-03 18:13:22.671 Mapping M6E-201909-GLOBEX to M6EU19. Service code: cme | 2020-03-03 18:13:22.672 SC Data - All Services | Starting real-time market data updates for: M6E-201909-GLOBEX (M6EU19). ID: 2 Service code: cme | 2020-03-03 18:13:22.672 SC Data - All Services | Requesting security definition data for: M6E-201909-GLOBEX (M6EU19). ID: 2 | 2020-03-03 18:13:22.672 Subscribing to symbol for symbol alert. GBPUSD | 2020-03-03 18:13:22.672 Using Bid/Ask average for last trade price for GBPUSD | 2020-03-03 18:13:22.672 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 3 Service code: fxcm | 2020-03-03 18:13:22.672 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2020-03-03 18:13:22.672 DTC Client socket (2) | Creating socket. | 2020-03-03 18:13:22.672 SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 3 | 2020-03-03 18:13:22.672 Subscribing to symbol for symbol alert. M6B-201909-GLOBEX-USD | 2020-03-03 18:13:22.672 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2020-03-03 18:13:22.672 Mapping M6B-201909-GLOBEX-USD to M6BU19. Service code: cme | 2020-03-03 18:13:22.672 SC Data - All Services | Starting real-time market data updates for: M6B-201909-GLOBEX-USD (M6BU19). ID: 4 Service code: cme | 2020-03-03 18:13:22.672 SC Data - All Services | Requesting security definition data for: M6B-201909-GLOBEX-USD (M6BU19). ID: 4 | 2020-03-03 18:13:22.673 Subscribing to symbol for symbol alert. EURUSD | 2020-03-03 18:13:22.673 Using Bid/Ask average for last trade price for EURUSD | 2020-03-03 18:13:22.673 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 5 Service code: fxcm | 2020-03-03 18:13:22.673 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 5 | 2020-03-03 18:13:22.673 Subscribing to symbol for symbol alert. ZN-201909-ECBOT | 2020-03-03 18:13:22.673 Mapping ZN-201909-ECBOT to ZNU19. Service code: cbot | 2020-03-03 18:13:22.673 DTC Client socket (3) | Creating socket. | 2020-03-03 18:13:22.673 DTC Client socket (3) | Connecting to IP: 192.81.56.146. | 2020-03-03 18:13:22.673 SC Data - All Services | Starting real-time market data updates for: ZN-201909-ECBOT (ZNU19). ID: 6 Service code: cbot | 2020-03-03 18:13:22.673 SC Data - All Services | Requesting security definition data for: ZN-201909-ECBOT (ZNU19). ID: 6 | 2020-03-03 18:13:22.673 Subscribing to symbol for symbol alert. MGC-201912-NYMEX-USD-10 | 2020-03-03 18:13:22.673 Mapping MGC-201912-NYMEX-USD-10 to MGCZ19. Service code: comex | 2020-03-03 18:13:22.673 SC Data - All Services | Starting real-time market data updates for: MGC-201912-NYMEX-USD-10 (MGCZ19). ID: 7 Service code: comex | 2020-03-03 18:13:22.673 SC Data - All Services | Requesting security definition data for: MGC-201912-NYMEX-USD-10 (MGCZ19). ID: 7 | 2020-03-03 18:13:22.673 Subscribing to symbol for symbol alert. QM-201910-NYMEX | 2020-03-03 18:13:22.673 Mapping QM-201910-NYMEX to QMV19. Service code: nymex | 2020-03-03 18:13:22.673 SC Data - All Services | Starting real-time market data updates for: QM-201910-NYMEX (QMV19). ID: 8 Service code: nymex | 2020-03-03 18:13:22.673 SC Data - All Services | Requesting security definition data for: QM-201910-NYMEX (QMV19). ID: 8 | 2020-03-03 18:13:22.673 Subscribing to symbol for symbol alert. ES-201909-GLOBEX | 2020-03-03 18:13:22.673 Mapping ES-201909-GLOBEX to ESU19. Service code: cme | 2020-03-03 18:13:22.673 SC Data - All Services | Starting real-time market data updates for: ES-201909-GLOBEX (ESU19). ID: 9 Service code: cme | 2020-03-03 18:13:22.674 SC Data - All Services | Requesting security definition data for: ES-201909-GLOBEX (ESU19). ID: 9 | 2020-03-03 18:13:22.674 Subscribing to symbol for symbol alert. ES-201909-GLOBEX | 2020-03-03 18:13:22.674 Subscribing to symbol for symbol alert. ZN-201909-ECBOT | 2020-03-03 18:13:22.674 Subscribing to symbol for symbol alert. ZN-201909-ECBOT | 2020-03-03 18:13:22.674 Subscribing to symbol for symbol alert. GBL-201909-DTB | 2020-03-03 18:13:22.674 Mapping GBL-201909-DTB to GGU19. Service code: eurex | 2020-03-03 18:13:22.674 SC Data - All Services | Starting real-time market data updates for: GBL-201909-DTB (GGU19). ID: 10 Service code: eurex | 2020-03-03 18:13:22.676 SC Data - All Services | Requesting security definition data for: GBL-201909-DTB (GGU19). ID: 10 | 2020-03-03 18:13:22.676 Subscribing to symbol for symbol alert. GBL-201909-DTB | 2020-03-03 18:13:22.676 Subscribing to symbol for symbol alert. MGC-201912-NYMEX-USD-10 | 2020-03-03 18:13:22.676 Subscribing to symbol for symbol alert. SI-201912-NYMEX-USD-1000 | 2020-03-03 18:13:22.676 Mapping SI-201912-NYMEX-USD-1000 to SILZ19. Service code: comex | 2020-03-03 18:13:22.676 SC Data - All Services | Starting real-time market data updates for: SI-201912-NYMEX-USD-1000 (SILZ19). ID: 11 Service code: comex | 2020-03-03 18:13:22.676 SC Data - All Services | Requesting security definition data for: SI-201912-NYMEX-USD-1000 (SILZ19). ID: 11 | 2020-03-03 18:13:22.676 Subscribing to symbol for symbol alert. MGC-201912-NYMEX-USD-10 | 2020-03-03 18:13:22.676 Subscribing to symbol for symbol alert. ZN-201912-ECBOT | 2020-03-03 18:13:22.676 Mapping ZN-201912-ECBOT to ZNZ19. Service code: cbot | 2020-03-03 18:13:22.676 SC Data - All Services | Starting real-time market data updates for: ZN-201912-ECBOT (ZNZ19). ID: 12 Service code: cbot | 2020-03-03 18:13:22.678 SC Data - All Services | Requesting security definition data for: ZN-201912-ECBOT (ZNZ19). ID: 12 | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. ZN-201912-ECBOT | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. ES-201909-GLOBEX | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. ES-201909-GLOBEX | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. EURUSD | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. EURUSD | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. EURUSD | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. USDJPY | 2020-03-03 18:13:22.678 Using Bid/Ask average for last trade price for USDJPY | 2020-03-03 18:13:22.678 SC DTC Data with Market Depth | Starting real-time market data updates for: USDJPY. ID: 13 Service code: fxcm | 2020-03-03 18:13:22.678 SC DTC Data with Market Depth | Requesting security definition data for: USDJPY. ID: 13 | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. USDJPY | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. ZN-201912-ECBOT | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. QM-201910-NYMEX | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. QM-201910-NYMEX | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. GBL-201909-DTB | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. SI-201912-NYMEX-USD-1000 | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. AUDUSD | 2020-03-03 18:13:22.678 Using Bid/Ask average for last trade price for AUDUSD | 2020-03-03 18:13:22.678 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDUSD. ID: 14 Service code: fxcm | 2020-03-03 18:13:22.678 SC DTC Data with Market Depth | Requesting security definition data for: AUDUSD. ID: 14 | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. AUDUSD | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. AUDUSD | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. AUDUSD | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. EURUSD | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. EURUSD | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. ES-201909-GLOBEX | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. QM-201910-NYMEX | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. GBL-201909-DTB | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. MGC-201912-NYMEX-USD-10 | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. USDJPY | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. ES-201909-GLOBEX | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. QM-201910-NYMEX | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. QM-201910-NYMEX | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. DAX-201909-DTB-EUR-5 | 2020-03-03 18:13:22.678 Mapping DAX-201909-DTB-EUR-5 to TMU19. Service code: eurex | 2020-03-03 18:13:22.678 SC Data - All Services | Starting real-time market data updates for: DAX-201909-DTB-EUR-5 (TMU19). ID: 15 Service code: eurex | 2020-03-03 18:13:22.678 SC Data - All Services | Requesting security definition data for: DAX-201909-DTB-EUR-5 (TMU19). ID: 15 | 2020-03-03 18:13:22.678 Subscribing to symbol for symbol alert. MGC-201912-NYMEX-USD-10 | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. DAX-201909-DTB-EUR-5 | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. USDJPY | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. USDCAD | 2020-03-03 18:13:22.679 Using Bid/Ask average for last trade price for USDCAD | 2020-03-03 18:13:22.679 SC DTC Data with Market Depth | Starting real-time market data updates for: USDCAD. ID: 16 Service code: fxcm | 2020-03-03 18:13:22.679 SC DTC Data with Market Depth | Requesting security definition data for: USDCAD. ID: 16 | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. EURUSD | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. MGC-201912-NYMEX-USD-10 | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. QM-201910-NYMEX | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. QM-201910-NYMEX | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. ZN-201912-ECBOT | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. ES-201909-GLOBEX | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. AUDUSD | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. EURUSD | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. MES-201909-GLOBEX | 2020-03-03 18:13:22.679 Interactive Brokers | Starting real-time market data updates for: MES-201909-GLOBEX. ID: 17 | 2020-03-03 18:13:22.679 Interactive Brokers | Subscribing to Symbol: MES, SecurityType: FUT, Expiration: 201909, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:22.679 Interactive Brokers | Requesting security definition data for: MES-201909-GLOBEX. ID: 17 | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. ZN-201912-ECBOT | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. MGC-201912-NYMEX-USD-10 | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. USDCAD | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. SI-201912-NYMEX-USD-1000 | 2020-03-03 18:13:22.679 Subscribing to symbol for symbol alert. EURUSD | 2020-03-03 18:13:22.679 Next valid order ID: 3988 | 2020-03-03 18:13:22.718 Message from IB: Market data farm connection is OK:usfuture.nj. IB Error Code: 2104. Request ID: -1. | 2020-03-03 18:13:22.718 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2020-03-03 18:13:22.718 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2020-03-03 18:13:22.718 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2020-03-03 18:13:22.718 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2020-03-03 18:13:22.718 Message from IB: HMDS data farm connection is OK:hkhmds. IB Error Code: 2106. Request ID: -1. | 2020-03-03 18:13:22.718 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2020-03-03 18:13:22.718 Message from IB: Sec-def data farm connection is OK:secdefhk. IB Error Code: 2158. Request ID: -1. | 2020-03-03 18:13:22.718 Interactive Brokers | Received contract details for symbol QG-202004-NYMEX | 2020-03-03 18:13:22.719 Interactive Brokers | Received contract details for symbol M6A-202003-GLOBEX-USD | 2020-03-03 18:13:22.719 Interactive Brokers | Received contract details for symbol MES-202003-GLOBEX-USD | 2020-03-03 18:13:22.719 Interactive Brokers | Received contract details for symbol MGC-202004-NYMEX-USD-10 | 2020-03-03 18:13:22.719 Next valid order ID: 3988 | 2020-03-03 18:13:22.719 Interactive Brokers | Received contract details for symbol ZN-202006-ECBOT | 2020-03-03 18:13:22.719 Interactive Brokers | Received contract details for symbol QM-202004-NYMEX | 2020-03-03 18:13:22.719 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2020-03-03 18:13:22.719 Added historical Intraday data request for GBPUSD to the queue. | 2020-03-03 18:13:22.722 Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2020-03-03 18:13:22.722 Triggering next historical data download in queue. | 2020-03-03 18:13:22.722 Delaying start of download for GBPUSD | 2020-03-03 18:13:22.722 Added historical Intraday data request for USDJPY to the queue. | 2020-03-03 18:13:22.723 Intraday data recording state for symbol USDJPY is set to download 'Pending'. | 2020-03-03 18:13:22.723 Triggering next historical data download in queue. | 2020-03-03 18:13:22.723 Added historical Intraday data request for USDCAD to the queue. | 2020-03-03 18:13:22.724 Intraday data recording state for symbol USDCAD is set to download 'Pending'. | 2020-03-03 18:13:22.724 Triggering next historical data download in queue. | 2020-03-03 18:13:22.724 Next valid order ID: 3988 | 2020-03-03 18:13:22.729 Mapping GBL-202003-DTB to GGH20. Service code: eurex | 2020-03-03 18:13:22.752 Mapping GBL-202006-DTB to GGM20. Service code: eurex | 2020-03-03 18:13:22.752 SC Data - All Services | Starting real-time market data updates for: GBL-202006-DTB (GGM20). ID: 19 Service code: eurex | 2020-03-03 18:13:22.752 SC Data - All Services | Requesting security definition data for: GBL-202006-DTB (GGM20). ID: 19 | 2020-03-03 18:13:22.752 SC Data - All Services | Starting real-time market data updates for: GBL-202003-DTB (GGH20). ID: 18 Service code: eurex | 2020-03-03 18:13:22.752 SC Data - All Services | Requesting security definition data for: GBL-202003-DTB (GGH20). ID: 18 | 2020-03-03 18:13:22.752 Added historical Intraday data request for GBL-202003-DTB to the queue. | 2020-03-03 18:13:22.752 Intraday data recording state for symbol GBL-202003-DTB is set to download 'Pending'. | 2020-03-03 18:13:22.752 Triggering next historical data download in queue. | 2020-03-03 18:13:22.752 Mapping MES-202003-GLOBEX-USD to MESH20. Service code: cme | 2020-03-03 18:13:22.754 SC Data - All Services | Starting real-time market data updates for: MES-202003-GLOBEX-USD (MESH20). ID: 20 Service code: cme | 2020-03-03 18:13:22.754 SC Data - All Services | Requesting security definition data for: MES-202003-GLOBEX-USD (MESH20). ID: 20 | 2020-03-03 18:13:22.755 Added historical Intraday data request for MES-202003-GLOBEX-USD to the queue. | 2020-03-03 18:13:22.755 Intraday data recording state for symbol MES-202003-GLOBEX-USD is set to download 'Pending'. | 2020-03-03 18:13:22.755 Triggering next historical data download in queue. | 2020-03-03 18:13:22.755 Mapping MGC-202004-NYMEX-USD-10 to MGCJ20. Service code: comex | 2020-03-03 18:13:22.767 SC Data - All Services | Starting real-time market data updates for: MGC-202004-NYMEX-USD-10 (MGCJ20). ID: 21 Service code: comex | 2020-03-03 18:13:22.767 SC Data - All Services | Requesting security definition data for: MGC-202004-NYMEX-USD-10 (MGCJ20). ID: 21 | 2020-03-03 18:13:22.767 Added historical Intraday data request for MGC-202004-NYMEX-USD-10 to the queue. | 2020-03-03 18:13:22.769 Intraday data recording state for symbol MGC-202004-NYMEX-USD-10 is set to download 'Pending'. | 2020-03-03 18:13:22.769 Triggering next historical data download in queue. | 2020-03-03 18:13:22.769 Mapping SI-202005-NYMEX-USD-1000 to SILK20. Service code: comex | 2020-03-03 18:13:22.772 SC Data - All Services | Starting real-time market data updates for: SI-202005-NYMEX-USD-1000 (SILK20). ID: 22 Service code: comex | 2020-03-03 18:13:22.772 SC Data - All Services | Requesting security definition data for: SI-202005-NYMEX-USD-1000 (SILK20). ID: 22 | 2020-03-03 18:13:22.772 Added historical Intraday data request for SI-202005-NYMEX-USD-1000 to the queue. | 2020-03-03 18:13:22.772 Intraday data recording state for symbol SI-202005-NYMEX-USD-1000 is set to download 'Pending'. | 2020-03-03 18:13:22.772 Triggering next historical data download in queue. | 2020-03-03 18:13:22.772 Mapping ZN-202006-ECBOT to ZNM20. Service code: cbot | 2020-03-03 18:13:22.824 SC Data - All Services | Starting real-time market data updates for: ZN-202006-ECBOT (ZNM20). ID: 23 Service code: cbot | 2020-03-03 18:13:22.824 SC Data - All Services | Requesting security definition data for: ZN-202006-ECBOT (ZNM20). ID: 23 | 2020-03-03 18:13:22.824 Added historical Intraday data request for ZN-202006-ECBOT to the queue. | 2020-03-03 18:13:22.828 Intraday data recording state for symbol ZN-202006-ECBOT is set to download 'Pending'. | 2020-03-03 18:13:22.828 Triggering next historical data download in queue. | 2020-03-03 18:13:22.828 SC Data - All Services | Connected to server. | 2020-03-03 18:13:22.904 SC Data - All Services | Starting socket receive thread. | 2020-03-03 18:13:22.904 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-03 18:13:22.904 SC DTC Data with Market Depth | Connected to server. | 2020-03-03 18:13:22.922 SC DTC Data with Market Depth | Starting socket receive thread. | 2020-03-03 18:13:22.922 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2020-03-03 18:13:22.922 Mapping MJY-202003-GLOBEX-USD-1250000 to MJYH20. Service code: cme | 2020-03-03 18:13:22.949 SC Data - All Services | Starting real-time market data updates for: MJY-202003-GLOBEX-USD-1250000 (MJYH20). ID: 24 Service code: cme | 2020-03-03 18:13:22.951 SC Data - All Services | Requesting security definition data for: MJY-202003-GLOBEX-USD-1250000 (MJYH20). ID: 24 | 2020-03-03 18:13:22.951 Added historical Intraday data request for MJY-202003-GLOBEX-USD-1250000 to the queue. | 2020-03-03 18:13:22.951 Intraday data recording state for symbol MJY-202003-GLOBEX-USD-1250000 is set to download 'Pending'. | 2020-03-03 18:13:22.951 Triggering next historical data download in queue. | 2020-03-03 18:13:22.951 Symbol Error - MES-201909-GLOBEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2020-03-03 18:13:23.021 Mapping ZC-202007-ECBOT to ZCN20. Service code: cbot | 2020-03-03 18:13:23.084 SC Data - All Services | Starting real-time market data updates for: ZC-202007-ECBOT (ZCN20). ID: 25 Service code: cbot | 2020-03-03 18:13:23.085 SC Data - All Services | Requesting security definition data for: ZC-202007-ECBOT (ZCN20). ID: 25 | 2020-03-03 18:13:23.085 Mapping QG-202004-NYMEX to QGJ20. Service code: nymex | 2020-03-03 18:13:23.085 SC Data - All Services | Starting real-time market data updates for: QG-202004-NYMEX (QGJ20). ID: 26 Service code: nymex | 2020-03-03 18:13:23.085 SC Data - All Services | Requesting security definition data for: QG-202004-NYMEX (QGJ20). ID: 26 | 2020-03-03 18:13:23.085 Mapping LE-202010-GLOBEX to LEV20. Service code: cme | 2020-03-03 18:13:23.085 SC Data - All Services | Starting real-time market data updates for: LE-202010-GLOBEX (LEV20). ID: 27 Service code: cme | 2020-03-03 18:13:23.085 SC Data - All Services | Requesting security definition data for: LE-202010-GLOBEX (LEV20). ID: 27 | 2020-03-03 18:13:23.085 Mapping HEM20-HEQ20.FUT_SPREAD.CME to HEM20-HEQ20.FUT_SPREAD.CME. Service code: cme | 2020-03-03 18:13:23.086 SC Data - All Services | Starting real-time market data updates for: HEM20-HEQ20.FUT_SPREAD.CME (HEM20-HEQ20.FUT_SPREAD.CME). ID: 28 Service code: cme | 2020-03-03 18:13:23.086 SC Data - All Services | Requesting security definition data for: HEM20-HEQ20.FUT_SPREAD.CME (HEM20-HEQ20.FUT_SPREAD.CME). ID: 28 | 2020-03-03 18:13:23.086 Mapping NGM20-NGN20.FUT_SPREAD.NYMEX to NGM20-NGN20.FUT_SPREAD.NYMEX. Service code: nymex | 2020-03-03 18:13:23.087 SC Data - All Services | Starting real-time market data updates for: NGM20-NGN20.FUT_SPREAD.NYMEX (NGM20-NGN20.FUT_SPREAD.NYMEX). ID: 29 Service code: nymex | 2020-03-03 18:13:23.088 SC Data - All Services | Requesting security definition data for: NGM20-NGN20.FUT_SPREAD.NYMEX (NGM20-NGN20.FUT_SPREAD.NYMEX). ID: 29 | 2020-03-03 18:13:23.089 Mapping HGK20-HGN20.FUT_SPREAD.COMEX to HGK20-HGN20.FUT_SPREAD.COMEX. Service code: comex | 2020-03-03 18:13:23.090 SC Data - All Services | Starting real-time market data updates for: HGK20-HGN20.FUT_SPREAD.COMEX (HGK20-HGN20.FUT_SPREAD.COMEX). ID: 30 Service code: comex | 2020-03-03 18:13:23.090 SC Data - All Services | Requesting security definition data for: HGK20-HGN20.FUT_SPREAD.COMEX (HGK20-HGN20.FUT_SPREAD.COMEX). ID: 30 | 2020-03-03 18:13:23.091 Mapping SIK20-SIZ20.FUT_SPREAD.COMEX to SIK20-SIZ20.FUT_SPREAD.COMEX. Service code: comex | 2020-03-03 18:13:23.091 SC Data - All Services | Starting real-time market data updates for: SIK20-SIZ20.FUT_SPREAD.COMEX (SIK20-SIZ20.FUT_SPREAD.COMEX). ID: 31 Service code: comex | 2020-03-03 18:13:23.091 SC Data - All Services | Requesting security definition data for: SIK20-SIZ20.FUT_SPREAD.COMEX (SIK20-SIZ20.FUT_SPREAD.COMEX). ID: 31 | 2020-03-03 18:13:23.091 Mapping ZLQ20-ZLF21.FUT_SPREAD.CBOT to ZLQ20-ZLF21.FUT_SPREAD.CBOT. Service code: cbot | 2020-03-03 18:13:23.091 SC Data - All Services | Starting real-time market data updates for: ZLQ20-ZLF21.FUT_SPREAD.CBOT (ZLQ20-ZLF21.FUT_SPREAD.CBOT). ID: 32 Service code: cbot | 2020-03-03 18:13:23.091 SC Data - All Services | Requesting security definition data for: ZLQ20-ZLF21.FUT_SPREAD.CBOT (ZLQ20-ZLF21.FUT_SPREAD.CBOT). ID: 32 | 2020-03-03 18:13:23.091 Interactive Brokers | Starting real-time market data updates for: _S_SP_SBK20_SBV20.FUT_SPREAD.IFUS. ID: 33 Service code: ice.us | 2020-03-03 18:13:23.091 Interactive Brokers | Subscribing to Symbol: _S_SP_SBK20_SBV20.FUT_SPREAD.IFUS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.091 Interactive Brokers | Requesting security definition data for: _S_SP_SBK20_SBV20.FUT_SPREAD.IFUS. ID: 33 | 2020-03-03 18:13:23.091 Mapping ZWN20-ZWZ20.FUT_SPREAD.CBOT to ZWN20-ZWZ20.FUT_SPREAD.CBOT. Service code: cbot | 2020-03-03 18:13:23.092 SC Data - All Services | Starting real-time market data updates for: ZWN20-ZWZ20.FUT_SPREAD.CBOT (ZWN20-ZWZ20.FUT_SPREAD.CBOT). ID: 34 Service code: cbot | 2020-03-03 18:13:23.094 SC Data - All Services | Requesting security definition data for: ZWN20-ZWZ20.FUT_SPREAD.CBOT (ZWN20-ZWZ20.FUT_SPREAD.CBOT). ID: 34 | 2020-03-03 18:13:23.094 Mapping HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX to HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX. Service code: nymex | 2020-03-03 18:13:23.096 SC Data - All Services | Starting real-time market data updates for: HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX (HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX). ID: 35 Service code: nymex | 2020-03-03 18:13:23.096 SC Data - All Services | Requesting security definition data for: HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX (HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX). ID: 35 | 2020-03-03 18:13:23.096 Mapping ZSK20-ZSQ20.FUT_SPREAD.CBOT to ZSK20-ZSQ20.FUT_SPREAD.CBOT. Service code: cbot | 2020-03-03 18:13:23.096 SC Data - All Services | Starting real-time market data updates for: ZSK20-ZSQ20.FUT_SPREAD.CBOT (ZSK20-ZSQ20.FUT_SPREAD.CBOT). ID: 36 Service code: cbot | 2020-03-03 18:13:23.096 SC Data - All Services | Requesting security definition data for: ZSK20-ZSQ20.FUT_SPREAD.CBOT (ZSK20-ZSQ20.FUT_SPREAD.CBOT). ID: 36 | 2020-03-03 18:13:23.096 Mapping ZCN20-ZCU20.FUT_SPREAD.CBOT to ZCN20-ZCU20.FUT_SPREAD.CBOT. Service code: cbot | 2020-03-03 18:13:23.097 SC Data - All Services | Starting real-time market data updates for: ZCN20-ZCU20.FUT_SPREAD.CBOT (ZCN20-ZCU20.FUT_SPREAD.CBOT). ID: 37 Service code: cbot | 2020-03-03 18:13:23.097 SC Data - All Services | Requesting security definition data for: ZCN20-ZCU20.FUT_SPREAD.CBOT (ZCN20-ZCU20.FUT_SPREAD.CBOT). ID: 37 | 2020-03-03 18:13:23.097 Mapping LEV20-LEG21.FUT_SPREAD.CME to LEV20-LEG21.FUT_SPREAD.CME. Service code: cme | 2020-03-03 18:13:23.097 SC Data - All Services | Starting real-time market data updates for: LEV20-LEG21.FUT_SPREAD.CME (LEV20-LEG21.FUT_SPREAD.CME). ID: 38 Service code: cme | 2020-03-03 18:13:23.097 SC Data - All Services | Requesting security definition data for: LEV20-LEG21.FUT_SPREAD.CME (LEV20-LEG21.FUT_SPREAD.CME). ID: 38 | 2020-03-03 18:13:23.097 Interactive Brokers | Starting real-time market data updates for: _S_SP_KCN20_KCZ20.FUT_SPREAD.IFUS. ID: 39 Service code: ice.us | 2020-03-03 18:13:23.098 Interactive Brokers | Subscribing to Symbol: _S_SP_KCN20_KCZ20.FUT_SPREAD.IFUS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.098 Interactive Brokers | Requesting security definition data for: _S_SP_KCN20_KCZ20.FUT_SPREAD.IFUS. ID: 39 | 2020-03-03 18:13:23.098 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 28. Symbol: HEM20-HEQ20.FUT_SPREAD.CME. | 2020-03-03 18:13:23.098 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 29. Symbol: NGM20-NGN20.FUT_SPREAD.NYMEX. | 2020-03-03 18:13:23.098 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 30. Symbol: HGK20-HGN20.FUT_SPREAD.COMEX. | 2020-03-03 18:13:23.098 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 31. Symbol: SIK20-SIZ20.FUT_SPREAD.COMEX. | 2020-03-03 18:13:23.098 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 32. Symbol: ZLQ20-ZLF21.FUT_SPREAD.CBOT. | 2020-03-03 18:13:23.098 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 34. Symbol: ZWN20-ZWZ20.FUT_SPREAD.CBOT. | 2020-03-03 18:13:23.098 Mapping M6A-202003-GLOBEX-USD to M6AH20. Service code: cme | 2020-03-03 18:13:23.099 SC Data - All Services | Starting real-time market data updates for: M6A-202003-GLOBEX-USD (M6AH20). ID: 40 Service code: cme | 2020-03-03 18:13:23.099 SC Data - All Services | Requesting security definition data for: M6A-202003-GLOBEX-USD (M6AH20). ID: 40 | 2020-03-03 18:13:23.099 Mapping M6E-202003-GLOBEX to M6EH20. Service code: cme | 2020-03-03 18:13:23.099 SC Data - All Services | Starting real-time market data updates for: M6E-202003-GLOBEX (M6EH20). ID: 41 Service code: cme | 2020-03-03 18:13:23.099 SC Data - All Services | Requesting security definition data for: M6E-202003-GLOBEX (M6EH20). ID: 41 | 2020-03-03 18:13:23.099 Mapping M6B-202003-GLOBEX-USD to M6BH20. Service code: cme | 2020-03-03 18:13:23.099 SC Data - All Services | Starting real-time market data updates for: M6B-202003-GLOBEX-USD (M6BH20). ID: 42 Service code: cme | 2020-03-03 18:13:23.099 SC Data - All Services | Requesting security definition data for: M6B-202003-GLOBEX-USD (M6BH20). ID: 42 | 2020-03-03 18:13:23.099 Mapping MCD-202003-GLOBEX-USD to MCDH20. Service code: cme | 2020-03-03 18:13:23.099 SC Data - All Services | Starting real-time market data updates for: MCD-202003-GLOBEX-USD (MCDH20). ID: 43 Service code: cme | 2020-03-03 18:13:23.099 SC Data - All Services | Requesting security definition data for: MCD-202003-GLOBEX-USD (MCDH20). ID: 43 | 2020-03-03 18:13:23.099 Interactive Brokers | Starting real-time market data updates for: TLT. ID: 44 | 2020-03-03 18:13:23.100 Interactive Brokers | Subscribing to Symbol: TLT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.100 Interactive Brokers | Requesting security definition data for: TLT. ID: 44 | 2020-03-03 18:13:23.100 Interactive Brokers | Starting real-time market data updates for: GLD. ID: 45 | 2020-03-03 18:13:23.101 Interactive Brokers | Subscribing to Symbol: GLD, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: ARCA, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.101 Interactive Brokers | Requesting security definition data for: GLD. ID: 45 | 2020-03-03 18:13:23.101 Interactive Brokers | Starting real-time market data updates for: SLV. ID: 46 | 2020-03-03 18:13:23.101 Interactive Brokers | Subscribing to Symbol: SLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.101 Interactive Brokers | Requesting security definition data for: SLV. ID: 46 | 2020-03-03 18:13:23.101 Interactive Brokers | Starting real-time market data updates for: GDX. ID: 47 | 2020-03-03 18:13:23.101 Interactive Brokers | Subscribing to Symbol: GDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: ARCA, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.101 Interactive Brokers | Requesting security definition data for: GDX. ID: 47 | 2020-03-03 18:13:23.101 Interactive Brokers | Starting real-time market data updates for: SPY. ID: 48 | 2020-03-03 18:13:23.101 Interactive Brokers | Subscribing to Symbol: SPY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.101 Interactive Brokers | Requesting security definition data for: SPY. ID: 48 | 2020-03-03 18:13:23.101 Interactive Brokers | Starting real-time market data updates for: UNG. ID: 49 | 2020-03-03 18:13:23.102 Interactive Brokers | Subscribing to Symbol: UNG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.102 Interactive Brokers | Requesting security definition data for: UNG. ID: 49 | 2020-03-03 18:13:23.102 Interactive Brokers | Starting real-time market data updates for: USO. ID: 50 | 2020-03-03 18:13:23.104 Interactive Brokers | Subscribing to Symbol: USO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.104 Interactive Brokers | Requesting security definition data for: USO. ID: 50 | 2020-03-03 18:13:23.104 Mapping ZC-202005-ECBOT to ZCK20. Service code: cbot | 2020-03-03 18:13:23.106 SC Data - All Services | Starting real-time market data updates for: ZC-202005-ECBOT (ZCK20). ID: 51 Service code: cbot | 2020-03-03 18:13:23.106 SC Data - All Services | Requesting security definition data for: ZC-202005-ECBOT (ZCK20). ID: 51 | 2020-03-03 18:13:23.107 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 35. Symbol: HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX. | 2020-03-03 18:13:23.107 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 36. Symbol: ZSK20-ZSQ20.FUT_SPREAD.CBOT. | 2020-03-03 18:13:23.107 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 37. Symbol: ZCN20-ZCU20.FUT_SPREAD.CBOT. | 2020-03-03 18:13:23.107 Message from IB: Error validating request:-'bQ' : cause - The symbol or the local-symbol or the security id must be entered. IB Error Code: 321. Request ID: 38. Symbol: LEV20-LEG21.FUT_SPREAD.CME. | 2020-03-03 18:13:23.107 Interactive Brokers | Starting real-time market data updates for: SPY-CFD-SMART-USD. ID: 52 | 2020-03-03 18:13:23.109 Interactive Brokers | Subscribing to Symbol: SPY, SecurityType: CFD, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2020-03-03 18:13:23.109 Interactive Brokers | Requesting security definition data for: SPY-CFD-SMART-USD. ID: 52 | 2020-03-03 18:13:23.109 Added historical Intraday data request for LEV20-LEG21.FUT_SPREAD.CME to the queue. | 2020-03-03 18:13:23.117 Intraday data recording state for symbol LEV20-LEG21.FUT_SPREAD.CME is set to download 'Pending'. | 2020-03-03 18:13:23.117 Triggering next historical data download in queue. | 2020-03-03 18:13:23.117 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:23.142 SC Data - All Services | Sending logon request message. | 2020-03-03 18:13:23.142 Added historical Intraday data request for QG-202004-NYMEX to the queue. | 2020-03-03 18:13:23.185 Intraday data recording state for symbol QG-202004-NYMEX is set to download 'Pending'. | 2020-03-03 18:13:23.185 Triggering next historical data download in queue. | 2020-03-03 18:13:23.185 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:23.196 SC DTC Data with Market Depth | Sending logon request message. | 2020-03-03 18:13:23.196 Symbol Error - _S_SP_SBK20_SBV20.FUT_SPREAD.IFUS is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2020-03-03 18:13:23.268 Symbol Error - _S_SP_KCN20_KCZ20.FUT_SPREAD.IFUS is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2020-03-03 18:13:23.268 Symbol Error - _S_SP_SBK20_SBV20.FUT_SPREAD.IFUS is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2020-03-03 18:13:23.292 Symbol Error - _S_SP_KCN20_KCZ20.FUT_SPREAD.IFUS is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2020-03-03 18:13:23.298 Added historical Intraday data request for EURUSD to the queue. | 2020-03-03 18:13:23.354 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2020-03-03 18:13:23.354 Triggering next historical data download in queue. | 2020-03-03 18:13:23.355 SC Data - All Services | Received logon response. | 2020-03-03 18:13:23.384 SC Data - All Services | Server Name: SC Realtime Server. | 2020-03-03 18:13:23.384 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-03 18:13:23.384 SC Data - All Services | Successfully connected. | 2020-03-03 18:13:23.384 SC Data - All Services | Trading is not supported. | 2020-03-03 18:13:23.384 SC Data - All Services | Restarting real-time data updates for symbol: DAX-201906-DTB-EUR-5 -> TMM19 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: DAX-201909-DTB-EUR-5 -> TMU19 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: ES-201909-GLOBEX -> ESU19 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: GBL-201909-DTB -> GGU19 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: GBL-202003-DTB -> GGH20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: GBL-202006-DTB -> GGM20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: HEM20-HEQ20.FUT_SPREAD.CME -> HEM20-HEQ20.FUT_SPREAD.CME | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: HGK20-HGN20.FUT_SPREAD.COMEX -> HGK20-HGN20.FUT_SPREAD.COMEX | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX -> HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: LE-202010-GLOBEX -> LEV20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: LEV20-LEG21.FUT_SPREAD.CME -> LEV20-LEG21.FUT_SPREAD.CME | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: M6A-202003-GLOBEX-USD -> M6AH20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: M6B-201909-GLOBEX-USD -> M6BU19 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: M6B-202003-GLOBEX-USD -> M6BH20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: M6E-201909-GLOBEX -> M6EU19 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: M6E-202003-GLOBEX -> M6EH20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: MCD-202003-GLOBEX-USD -> MCDH20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: MES-202003-GLOBEX-USD -> MESH20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: MGC-201912-NYMEX-USD-10 -> MGCZ19 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: MGC-202004-NYMEX-USD-10 -> MGCJ20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: MJY-202003-GLOBEX-USD-1250000 -> MJYH20 | 2020-03-03 18:13:23.385 SC Data - All Services | Restarting real-time data updates for symbol: NGM20-NGN20.FUT_SPREAD.NYMEX -> NGM20-NGN20.FUT_SPREAD.NYMEX | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: QG-202004-NYMEX -> QGJ20 | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: QM-201910-NYMEX -> QMV19 | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: SI-201912-NYMEX-USD-1000 -> SILZ19 | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: SI-202005-NYMEX-USD-1000 -> SILK20 | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: SIK20-SIZ20.FUT_SPREAD.COMEX -> SIK20-SIZ20.FUT_SPREAD.COMEX | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: ZC-202005-ECBOT -> ZCK20 | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: ZC-202007-ECBOT -> ZCN20 | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: ZCN20-ZCU20.FUT_SPREAD.CBOT -> ZCN20-ZCU20.FUT_SPREAD.CBOT | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: ZLQ20-ZLF21.FUT_SPREAD.CBOT -> ZLQ20-ZLF21.FUT_SPREAD.CBOT | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: ZN-201909-ECBOT -> ZNU19 | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: ZN-201912-ECBOT -> ZNZ19 | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: ZN-202006-ECBOT -> ZNM20 | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: ZSK20-ZSQ20.FUT_SPREAD.CBOT -> ZSK20-ZSQ20.FUT_SPREAD.CBOT | 2020-03-03 18:13:23.386 SC Data - All Services | Restarting real-time data updates for symbol: ZWN20-ZWZ20.FUT_SPREAD.CBOT -> ZWN20-ZWZ20.FUT_SPREAD.CBOT | 2020-03-03 18:13:23.386 Interactive Brokers | Market data type is Delayed for GLD | 2020-03-03 18:13:23.432 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 45. Symbol: GLD. | 2020-03-03 18:13:23.439 Interactive Brokers | Market data type is Delayed for GDX | 2020-03-03 18:13:23.439 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 47. Symbol: GDX. | 2020-03-03 18:13:23.439 Mapping ES-202003-GLOBEX to ESH20. Service code: cme | 2020-03-03 18:13:23.446 SC Data - All Services | Starting real-time market data updates for: ES-202003-GLOBEX (ESH20). ID: 53 Service code: cme | 2020-03-03 18:13:23.446 SC Data - All Services | Requesting security definition data for: ES-202003-GLOBEX (ESH20). ID: 53 | 2020-03-03 18:13:23.447 Added historical Intraday data request for ES-202003-GLOBEX to the queue. | 2020-03-03 18:13:23.447 Intraday data recording state for symbol ES-202003-GLOBEX is set to download 'Pending'. | 2020-03-03 18:13:23.447 Triggering next historical data download in queue. | 2020-03-03 18:13:23.447 Mapping QM-202004-NYMEX to QMJ20. Service code: nymex | 2020-03-03 18:13:23.458 SC Data - All Services | Starting real-time market data updates for: QM-202004-NYMEX (QMJ20). ID: 54 Service code: nymex | 2020-03-03 18:13:23.458 SC Data - All Services | Requesting security definition data for: QM-202004-NYMEX (QMJ20). ID: 54 | 2020-03-03 18:13:23.458 Added historical Intraday data request for QM-202004-NYMEX to the queue. | 2020-03-03 18:13:23.458 Intraday data recording state for symbol QM-202004-NYMEX is set to download 'Pending'. | 2020-03-03 18:13:23.458 Triggering next historical data download in queue. | 2020-03-03 18:13:23.458 SC Data - All Services | Real-time data for symbol DAX-201906-DTB-EUR-5 is currently unavailable. | 2020-03-03 18:13:23.641 SC Data - All Services | Received security definition for symbol DAX-201906-DTB-EUR-5 | 2020-03-03 18:13:23.641 SC Data - All Services | Real-time data for symbol DAX-201909-DTB-EUR-5 is currently unavailable. | 2020-03-03 18:13:23.641 SC Data - All Services | Received security definition for symbol DAX-201909-DTB-EUR-5 | 2020-03-03 18:13:23.641 Added historical Intraday data request for AUDUSD to the queue. | 2020-03-03 18:13:23.647 Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2020-03-03 18:13:23.647 Triggering next historical data download in queue. | 2020-03-03 18:13:23.648 SC Data - All Services | Real-time data for symbol ES-201909-GLOBEX is currently unavailable. | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol ES-201909-GLOBEX | 2020-03-03 18:13:23.910 SC Data - All Services | Real-time data for symbol GBL-201909-DTB is currently unavailable. | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol GBL-201909-DTB | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol GBL-202003-DTB | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol GBL-202006-DTB | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol HEM20-HEQ20.FUT_SPREAD.CME | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol HGK20-HGN20.FUT_SPREAD.COMEX | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol HO:BF M20-N20-Q20.FUT_SPREAD.NYMEX | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol LE-202010-GLOBEX | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol LEV20-LEG21.FUT_SPREAD.CME | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol M6A-202003-GLOBEX-USD | 2020-03-03 18:13:23.910 SC Data - All Services | Real-time data for symbol M6B-201909-GLOBEX-USD is currently unavailable. | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol M6B-201909-GLOBEX-USD | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol M6B-202003-GLOBEX-USD | 2020-03-03 18:13:23.910 SC Data - All Services | Real-time data for symbol M6E-201909-GLOBEX is currently unavailable. | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol M6E-201909-GLOBEX | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol M6E-202003-GLOBEX | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol MCD-202003-GLOBEX-USD | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol MES-202003-GLOBEX-USD | 2020-03-03 18:13:23.910 SC Data - All Services | Real-time data for symbol MGC-201912-NYMEX-USD-10 is currently unavailable. | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol MGC-201912-NYMEX-USD-10 | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol MGC-202004-NYMEX-USD-10 | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol MJY-202003-GLOBEX-USD-1250000 | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol NGM20-NGN20.FUT_SPREAD.NYMEX | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol QG-202004-NYMEX | 2020-03-03 18:13:23.910 SC Data - All Services | Real-time data for symbol QM-201910-NYMEX is currently unavailable. | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol QM-201910-NYMEX | 2020-03-03 18:13:23.910 SC Data - All Services | Real-time data for symbol SI-201912-NYMEX-USD-1000 is currently unavailable. | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol SI-201912-NYMEX-USD-1000 | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol SI-202005-NYMEX-USD-1000 | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol SIK20-SIZ20.FUT_SPREAD.COMEX | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol ZC-202005-ECBOT | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol ZC-202007-ECBOT | 2020-03-03 18:13:23.910 Symbol Error - ZCN20-ZCU20.FUT_SPREAD.CBOT is unknown, unavailable, or improperly formatted. Over symbol limit. Limit is 20 symbols. | 2020-03-03 18:13:23.910 SC Data - All Services | Received security definition for symbol ZCN20-ZCU20.FUT_SPREAD.CBOT | 2020-03-03 18:13:23.910 Symbol Error - ZLQ20-ZLF21.FUT_SPREAD.CBOT is unknown, unavailable, or improperly formatted. Over symbol limit. Limit is 20 symbols. | 2020-03-03 18:13:23.911 SC Data - All Services | Received security definition for symbol ZLQ20-ZLF21.FUT_SPREAD.CBOT | 2020-03-03 18:13:23.911 SC Data - All Services | Real-time data for symbol ZN-201909-ECBOT is currently unavailable. | 2020-03-03 18:13:23.911 SC Data - All Services | Received security definition for symbol ZN-201909-ECBOT | 2020-03-03 18:13:23.911 SC Data - All Services | Real-time data for symbol ZN-201912-ECBOT is currently unavailable. | 2020-03-03 18:13:23.911 SC Data - All Services | Received security definition for symbol ZN-201912-ECBOT | 2020-03-03 18:13:23.911 Symbol Error - ZN-202006-ECBOT is unknown, unavailable, or improperly formatted. Over symbol limit. Limit is 20 symbols. | 2020-03-03 18:13:23.911 SC Data - All Services | Received security definition for symbol ZN-202006-ECBOT | 2020-03-03 18:13:23.911 Symbol Error - ZSK20-ZSQ20.FUT_SPREAD.CBOT is unknown, unavailable, or improperly formatted. Over symbol limit. Limit is 20 symbols. | 2020-03-03 18:13:23.911 SC Data - All Services | Received security definition for symbol ZSK20-ZSQ20.FUT_SPREAD.CBOT | 2020-03-03 18:13:23.911 Symbol Error - ZWN20-ZWZ20.FUT_SPREAD.CBOT is unknown, unavailable, or improperly formatted. Over symbol limit. Limit is 20 symbols. | 2020-03-03 18:13:23.911 SC Data - All Services | Received security definition for symbol ZWN20-ZWZ20.FUT_SPREAD.CBOT | 2020-03-03 18:13:23.911 Symbol Error - ES-202003-GLOBEX is unknown, unavailable, or improperly formatted. Over symbol limit. Limit is 20 symbols. | 2020-03-03 18:13:23.911 SC Data - All Services | Received security definition for symbol ES-202003-GLOBEX | 2020-03-03 18:13:23.911 Symbol Error - QM-202004-NYMEX is unknown, unavailable, or improperly formatted. Over symbol limit. Limit is 20 symbols. | 2020-03-03 18:13:23.911 SC Data - All Services | Received security definition for symbol QM-202004-NYMEX | 2020-03-03 18:13:23.911 SC DTC Data with Market Depth | Received logon response. | 2020-03-03 18:13:23.973 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2020-03-03 18:13:23.973 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2020-03-03 18:13:23.973 SC DTC Data with Market Depth | Successfully connected. | 2020-03-03 18:13:23.973 SC DTC Data with Market Depth | Trading is not supported. | 2020-03-03 18:13:23.973 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2020-03-03 18:13:23.973 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2020-03-03 18:13:23.973 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2020-03-03 18:13:23.973 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCAD | 2020-03-03 18:13:23.973 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDJPY | 2020-03-03 18:13:23.973 Interactive Brokers | Market data type is Delayed for SLV | 2020-03-03 18:13:24.255 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 46. Symbol: SLV. | 2020-03-03 18:13:24.255 Interactive Brokers | Market data type is Delayed for TLT | 2020-03-03 18:13:24.255 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 44. Symbol: TLT. | 2020-03-03 18:13:24.255 Interactive Brokers | Market data type is Delayed for SPY | 2020-03-03 18:13:24.255 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 48. Symbol: SPY. | 2020-03-03 18:13:24.255 Interactive Brokers | Market data type is Delayed for UNG | 2020-03-03 18:13:24.255 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 49. Symbol: UNG. | 2020-03-03 18:13:24.256 Interactive Brokers | Market data type is Delayed for USO | 2020-03-03 18:13:24.256 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 50. Symbol: USO. | 2020-03-03 18:13:24.256 SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2020-03-03 18:13:24.289 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2020-03-03 18:13:24.289 SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2020-03-03 18:13:24.289 SC DTC Data with Market Depth | Received security definition for symbol USDCAD | 2020-03-03 18:13:24.289 SC DTC Data with Market Depth | Received security definition for symbol USDJPY | 2020-03-03 18:13:24.289 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates (6)) for account: U744* | 2020-03-03 18:13:28.084 Requesting market depth updates for: LEV20-LEG21.FUT_SPREAD.CME if supported. | 2020-03-03 18:13:28.089 Interactive Brokers | Begin Trade Positions processing. | 2020-03-03 18:13:28.094 Interactive Brokers | Sending request for contract details for contract ID 97589608 | 2020-03-03 18:13:28.095 Interactive Brokers | Sending request for contract details for contract ID 174230636 | 2020-03-03 18:13:28.095 Interactive Brokers | Sending request for contract details for contract ID 174230633 | 2020-03-03 18:13:28.095 Interactive Brokers | Sending request for contract details for contract ID 391530668 | 2020-03-03 18:13:28.095 Interactive Brokers | Sending request for contract details for contract ID 76602051 | 2020-03-03 18:13:28.095 Interactive Brokers | Sending request for contract details for contract ID 345852461 | 2020-03-03 18:13:28.095 Interactive Brokers | Sending request for contract details for contract ID 360760454 | 2020-03-03 18:13:28.095 Interactive Brokers | Sending request for contract details for contract ID 195730913 | 2020-03-03 18:13:28.095 Interactive Brokers | Sending request for contract details for contract ID 201720953 | 2020-03-03 18:13:28.095 Interactive Brokers | Sending request for contract details for contract ID 257430140 | 2020-03-03 18:13:28.096 Interactive Brokers | Sending request for contract details for contract ID 257430150 | 2020-03-03 18:13:28.100 Interactive Brokers | Sending request for contract details for contract ID 257430153 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 284612980 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 301449965 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 282503602 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 98307991 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 98307992 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 277954796 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 294670379 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 324078717 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 217648764 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 299451305 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 385575820 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 299451213 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 345852193 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 296077541 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 296077553 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 282503457 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 282503460 | 2020-03-03 18:13:28.102 Interactive Brokers | Sending request for contract details for contract ID 325818447 | 2020-03-03 18:13:28.102 Interactive Brokers | Received Trade Positions download end message for account U744* | 2020-03-03 18:13:28.102 Interactive Brokers | Received Trade Positions for all accounts. Performing final processing. | 2020-03-03 18:13:28.102 Interactive Brokers | Received contract details for symbol CL-202006-NYMEX | 2020-03-03 18:13:28.132 Interactive Brokers | Received contract details for symbol CL-202007-NYMEX | 2020-03-03 18:13:28.132 Interactive Brokers | Received contract details for symbol CL-202008-NYMEX | 2020-03-03 18:13:28.132 Interactive Brokers | Received contract details for symbol GE-202005-GLOBEX | 2020-03-03 18:13:28.132 Interactive Brokers | Received contract details for symbol GE-202006-GLOBEX | 2020-03-03 18:13:28.132 Interactive Brokers | Received contract details for symbol HE-202006-GLOBEX | 2020-03-03 18:13:28.161 Interactive Brokers | Received contract details for symbol HE-202008-GLOBEX | 2020-03-03 18:13:28.161 Interactive Brokers | Received contract details for symbol HG-202005-NYMEX | 2020-03-03 18:13:28.161 Interactive Brokers | Received contract details for symbol HG-202007-NYMEX | 2020-03-03 18:13:28.161 Interactive Brokers | Received contract details for symbol HO-202006-NYMEX | 2020-03-03 18:13:28.161 Interactive Brokers | Received contract details for symbol HO-202007-NYMEX | 2020-03-03 18:13:28.161 Interactive Brokers | Received contract details for symbol HO-202008-NYMEX | 2020-03-03 18:13:28.161 Interactive Brokers | Received contract details for symbol KC-202007-NYBOT | 2020-03-03 18:13:28.161 Interactive Brokers | Received contract details for symbol KC-202012-NYBOT | 2020-03-03 18:13:28.161 Interactive Brokers | Received contract details for symbol KE-202007-ECBOT-USD-5000 | 2020-03-03 18:13:28.179 Interactive Brokers | Received contract details for symbol NG-202006-NYMEX | 2020-03-03 18:13:28.179 Interactive Brokers | Received contract details for symbol NG-202007-NYMEX | 2020-03-03 18:13:28.179 RemoveDuplicateFills | TradeAccount: . DatesOfRecordsToInsert: 2020-03-02, 2020-03-03, . MostRecentFileNameSearched: TradeActivityLog_2020-03-03_UTC.U7448814.data. RecordsRemovedCount: 20. OriginalRecordsToInsertCount: 20. RecordsToInsertCount: 0 | 2020-03-03 18:13:28.195 Interactive Brokers | Received contract details for symbol SB-202005-NYBOT | 2020-03-03 18:13:28.211 Interactive Brokers | Received contract details for symbol SB-202010-NYBOT | 2020-03-03 18:13:28.211 Interactive Brokers | Received contract details for symbol SI-202005-NYMEX-USD-5000 | 2020-03-03 18:13:28.223 Interactive Brokers | Received contract details for symbol SI-202012-NYMEX-USD-5000 | 2020-03-03 18:13:28.223 Interactive Brokers | Received contract details for symbol ZC-202009-ECBOT | 2020-03-03 18:13:28.263 Interactive Brokers | Received contract details for symbol ZF-202006-ECBOT | 2020-03-03 18:13:28.263 Interactive Brokers | Received contract details for symbol ZL-202008-ECBOT | 2020-03-03 18:13:28.313 Interactive Brokers | Received contract details for symbol ZL-202101-ECBOT | 2020-03-03 18:13:28.313 Interactive Brokers | Received contract details for symbol ZS-202005-ECBOT | 2020-03-03 18:13:28.324 Interactive Brokers | Received contract details for symbol ZS-202008-ECBOT | 2020-03-03 18:13:28.324 Interactive Brokers | Received contract details for symbol ZW-202005-ECBOT | 2020-03-03 18:13:28.329 Interactive Brokers | Received contract details for symbol ZW-202007-ECBOT | 2020-03-03 18:13:28.346 Interactive Brokers | Received contract details for symbol ZW-202012-ECBOT | 2020-03-03 18:13:28.346 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2020-03-03 18:13:28.346 SC Data - All Services | Market Depth data has been rejected for symbol: LEV20-LEG21.FUT_SPREAD.CME. Not authorized for market depth. | 2020-03-03 18:13:28.349 HD Request # 126 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2020-03-03 18:13:29.778 HD Request # 126 | Download start date-time: 2020-03-03 18:13:30.000 | 2020-03-03 18:13:29.778 HD Request # 126 | Using server: ds3.sierracharts.com port 10150 | 2020-03-03 18:13:29.780 Socket (4) | Creating socket. | 2020-03-03 18:13:29.783 Socket (4) | Connecting to IP: 65.182.172.42. | 2020-03-03 18:13:29.784 HD Request # 126 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:30.261 HD Request # 126 | Sending historical data logon request message. | 2020-03-03 18:13:30.261 HD Request # 126 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:30. Record interval: 0. Symbol: GBPUSD | 2020-03-03 18:13:30.490 HD Request # 126 | Decompressing data. | 2020-03-03 18:13:30.720 HD Request # 126 | Receiving Intraday data for GBPUSD starting at 2020-03-03 18:13:30 | 2020-03-03 18:13:30.720 Socket (4) | CloseSocket call. | 2020-03-03 18:13:30.721 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:30.721 Historical data download thread signaled to stop. | 2020-03-03 18:13:30.724 HD Request # 126 | Timestamp of first Intraday data file record written: 2020-03-03 18:13:31 | 2020-03-03 18:13:30.724 HD Request # 126 | Received 105 records from 2020-03-03 18:13:30.000 to 2020-03-03 18:13:43.002 (13.0 seconds) and wrote 94 records for GBPUSD | 2020-03-03 18:13:30.724 HD Request # 126 | Completion time: 0s | 2020-03-03 18:13:30.726 HD Request # 126 | Intraday data download complete for GBPUSD. Unique request ID: 127 | 2020-03-03 18:13:30.726 Removing historical data download ID 127. | 2020-03-03 18:13:30.726 Real-time Intraday chart data file updates started for GBPUSD | 2020-03-03 18:13:30.726 Intraday chart data file opened for GBPUSD | 2020-03-03 18:13:30.726 HD Request # 126 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:30.726 Triggering next historical data download in queue. | 2020-03-03 18:13:30.727 HD Request # 127 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2020-03-03 18:13:30.728 HD Request # 127 | Download start date-time: 2020-03-03 18:13:30.000 | 2020-03-03 18:13:30.729 HD Request # 127 | Using server: ds4.sierracharts.com port 10149 | 2020-03-03 18:13:30.731 Socket (5) | Creating socket. | 2020-03-03 18:13:30.731 Socket (5) | Connecting to IP: 192.81.56.146. | 2020-03-03 18:13:30.732 Socket (4) | Socket gracefully closed by remote side. | 2020-03-03 18:13:30.953 Socket (4) | Closed. | 2020-03-03 18:13:30.953 HD Request # 127 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:31.433 HD Request # 127 | Sending historical data logon request message. | 2020-03-03 18:13:31.433 Chart #4 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.Cht | 2020-03-03 18:13:31.479 GBPUSD [CBV-D][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: GBPUSD.Cht | 2020-03-03 18:13:31.524 HD Request # 127 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:30. Record interval: 0. Symbol: USDJPY | 2020-03-03 18:13:32.273 Opened cached Intraday file: C:\SierraChart\Data\GBPUSD.scid | 2020-03-03 18:13:32.560 HD Request # 127 | Decompressing data. | 2020-03-03 18:13:32.604 HD Request # 127 | Receiving Intraday data for USDJPY starting at 2020-03-03 18:13:30 | 2020-03-03 18:13:32.604 Socket (5) | CloseSocket call. | 2020-03-03 18:13:32.606 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:32.606 Historical data download thread signaled to stop. | 2020-03-03 18:13:32.611 HD Request # 127 | Timestamp of first Intraday data file record written: 2020-03-03 18:13:31 | 2020-03-03 18:13:32.611 HD Request # 127 | Received 119 records from 2020-03-03 18:13:30.000 to 2020-03-03 18:13:44.005 (14.0 seconds) and wrote 106 records for USDJPY | 2020-03-03 18:13:32.611 HD Request # 127 | Completion time: 2s | 2020-03-03 18:13:32.611 HD Request # 127 | Intraday data download complete for USDJPY. Unique request ID: 128 | 2020-03-03 18:13:32.611 Removing historical data download ID 128. | 2020-03-03 18:13:32.611 Real-time Intraday chart data file updates started for USDJPY | 2020-03-03 18:13:32.611 Intraday chart data file opened for USDJPY | 2020-03-03 18:13:32.611 HD Request # 127 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:32.611 Triggering next historical data download in queue. | 2020-03-03 18:13:32.611 HD Request # 128 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2020-03-03 18:13:32.613 HD Request # 128 | Download start date-time: 2020-03-03 18:13:30.000 | 2020-03-03 18:13:32.614 HD Request # 128 | Using server: ds3.sierracharts.com port 10150 | 2020-03-03 18:13:32.618 Socket (4) | Creating socket. | 2020-03-03 18:13:32.618 Socket (4) | Connecting to IP: 65.182.172.42. | 2020-03-03 18:13:32.618 Socket (5) | Socket gracefully closed by remote side. | 2020-03-03 18:13:32.942 Socket (5) | Closed. | 2020-03-03 18:13:32.943 Chart #4 has tagged chart #2 for full recalculation. Chartbook: USDJPY.Cht | 2020-03-03 18:13:32.976 HD Request # 128 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:33.087 HD Request # 128 | Sending historical data logon request message. | 2020-03-03 18:13:33.087 HD Request # 128 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:30. Record interval: 0. Symbol: USDCAD | 2020-03-03 18:13:33.320 HD Request # 128 | Decompressing data. | 2020-03-03 18:13:33.554 HD Request # 128 | Receiving Intraday data for USDCAD starting at 2020-03-03 18:13:30 | 2020-03-03 18:13:33.554 Socket (4) | CloseSocket call. | 2020-03-03 18:13:33.555 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:33.555 Historical data download thread signaled to stop. | 2020-03-03 18:13:33.558 HD Request # 128 | Timestamp of first Intraday data file record written: 2020-03-03 18:13:31 | 2020-03-03 18:13:33.558 HD Request # 128 | Received 80 records from 2020-03-03 18:13:30.000 to 2020-03-03 18:13:45.001 (15.0 seconds) and wrote 75 records for USDCAD | 2020-03-03 18:13:33.558 HD Request # 128 | Completion time: 0s | 2020-03-03 18:13:33.559 HD Request # 128 | Intraday data download complete for USDCAD. Unique request ID: 129 | 2020-03-03 18:13:33.559 Removing historical data download ID 129. | 2020-03-03 18:13:33.559 Real-time Intraday chart data file updates started for USDCAD | 2020-03-03 18:13:33.559 Intraday chart data file opened for USDCAD | 2020-03-03 18:13:33.559 HD Request # 128 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:33.559 Triggering next historical data download in queue. | 2020-03-03 18:13:33.559 HD Request # 129 | Downloading Intraday chart data for GBL-202003-DTB to the file GBL-202003-DTB.scid. Service: eurex | 2020-03-03 18:13:33.561 HD Request # 129 | Download start date-time: 2020-03-03 18:13:30.000 | 2020-03-03 18:13:33.562 HD Request # 129 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2020-03-03 18:13:33.562 Socket (5) | Creating socket. | 2020-03-03 18:13:33.563 Socket (5) | Connecting to IP: 8.18.161.133. | 2020-03-03 18:13:33.563 USDJPY [CBV-D][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: USDJPY.Cht | 2020-03-03 18:13:33.595 Chart #4 has tagged chart #2 for full recalculation. Chartbook: USDCAD.Cht | 2020-03-03 18:13:33.673 Socket (4) | Socket gracefully closed by remote side. | 2020-03-03 18:13:33.782 Socket (4) | Closed. | 2020-03-03 18:13:33.782 USDCAD [CBV-D][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: USDCAD.Cht | 2020-03-03 18:13:33.826 HD Request # 129 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:34.039 HD Request # 129 | Sending historical data logon request message. | 2020-03-03 18:13:34.039 HD Request # 129 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:30. Record interval: 0. Symbol: GGH20 | 2020-03-03 18:13:34.268 HD Request # 129 | Decompressing data. | 2020-03-03 18:13:34.498 HD Request # 129 | Receiving Intraday data for GBL-202003-DTB starting at 2020-03-03 18:13:30 | 2020-03-03 18:13:34.498 Socket (5) | CloseSocket call. | 2020-03-03 18:13:34.501 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:34.501 Historical data download thread signaled to stop. | 2020-03-03 18:13:34.503 HD Request # 129 | Timestamp of first Intraday data file record written: 2020-03-03 18:13:31 | 2020-03-03 18:13:34.503 HD Request # 129 | Received 54 records from 2020-03-03 18:13:30.000 to 2020-03-03 18:13:42.005 (12.0 seconds) and wrote 50 records for GBL-202003-DTB | 2020-03-03 18:13:34.503 HD Request # 129 | Completion time: 1s | 2020-03-03 18:13:34.503 HD Request # 129 | Intraday data download complete for GBL-202003-DTB. Unique request ID: 130 | 2020-03-03 18:13:34.503 Removing historical data download ID 130. | 2020-03-03 18:13:34.503 Real-time Intraday chart data file updates started for GBL-202003-DTB | 2020-03-03 18:13:34.503 Intraday chart data file opened for GBL-202003-DTB | 2020-03-03 18:13:34.503 HD Request # 129 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:34.503 Triggering next historical data download in queue. | 2020-03-03 18:13:34.504 HD Request # 130 | Downloading Intraday chart data for MES-202003-GLOBEX-USD to the file MES-202003-GLOBEX-USD.scid. Service: cme | 2020-03-03 18:13:34.505 HD Request # 130 | Download start date-time: 2020-03-03 18:13:31.000 | 2020-03-03 18:13:34.506 HD Request # 130 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2020-03-03 18:13:34.508 Socket (4) | Creating socket. | 2020-03-03 18:13:34.508 Socket (4) | Connecting to IP: 8.18.161.135. | 2020-03-03 18:13:34.508 Socket (5) | Socket gracefully closed by remote side. | 2020-03-03 18:13:34.729 Socket (5) | Closed. | 2020-03-03 18:13:34.729 HD Request # 130 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:34.969 HD Request # 130 | Sending historical data logon request message. | 2020-03-03 18:13:34.969 HD Request # 130 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:31. Record interval: 0. Symbol: MESH20 | 2020-03-03 18:13:35.200 Chart #4 has tagged chart #2 for full recalculation. Chartbook: BUND.Cht | 2020-03-03 18:13:35.327 Chart #4 has tagged chart #5 for full recalculation. Chartbook: BUND.Cht | 2020-03-03 18:13:35.327 Chart #4 has tagged chart #6 for full recalculation. Chartbook: BUND.Cht | 2020-03-03 18:13:35.327 GBL-202003-DTB [CBV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: BUND.Cht | 2020-03-03 18:13:35.424 HD Request # 130 | Decompressing data. | 2020-03-03 18:13:35.427 HD Request # 130 | Receiving Intraday data for MES-202003-GLOBEX-USD starting at 2020-03-03 18:13:31 | 2020-03-03 18:13:35.427 Socket (4) | CloseSocket call. | 2020-03-03 18:13:35.430 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:35.430 Historical data download thread signaled to stop. | 2020-03-03 18:13:35.457 HD Request # 130 | Timestamp of first Intraday data file record written: 2020-03-03 18:13:31 | 2020-03-03 18:13:35.457 HD Request # 130 | Received 54 records from 2020-03-03 18:13:31.000 to 2020-03-03 18:13:44.006 (13.0 seconds) and wrote 53 records for MES-202003-GLOBEX-USD | 2020-03-03 18:13:35.457 HD Request # 130 | Completion time: 0s | 2020-03-03 18:13:35.458 HD Request # 130 | Intraday data download complete for MES-202003-GLOBEX-USD. Unique request ID: 131 | 2020-03-03 18:13:35.458 Removing historical data download ID 131. | 2020-03-03 18:13:35.458 Real-time Intraday chart data file updates started for MES-202003-GLOBEX-USD | 2020-03-03 18:13:35.458 Intraday chart data file opened for MES-202003-GLOBEX-USD | 2020-03-03 18:13:35.458 HD Request # 130 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:35.458 Triggering next historical data download in queue. | 2020-03-03 18:13:35.459 HD Request # 131 | Downloading Intraday chart data for MGC-202004-NYMEX-USD-10 to the file MGC-202004-NYMEX-USD-10.scid. Service: comex | 2020-03-03 18:13:35.460 HD Request # 131 | Download start date-time: 2020-03-03 18:13:30.000 | 2020-03-03 18:13:35.460 HD Request # 131 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2020-03-03 18:13:35.462 Socket (5) | Creating socket. | 2020-03-03 18:13:35.462 Socket (5) | Connecting to IP: 8.18.161.133. | 2020-03-03 18:13:35.462 Chart #4 has tagged chart #2 for full recalculation. Chartbook: MES.Cht | 2020-03-03 18:13:35.573 Chart #4 has tagged chart #5 for full recalculation. Chartbook: MES.Cht | 2020-03-03 18:13:35.573 Chart #4 has tagged chart #6 for full recalculation. Chartbook: MES.Cht | 2020-03-03 18:13:35.573 Socket (4) | Socket gracefully closed by remote side. | 2020-03-03 18:13:35.655 Socket (4) | Closed. | 2020-03-03 18:13:35.655 MES-202003-GLOBEX-USD [CBV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: MES.Cht | 2020-03-03 18:13:35.808 GBL-202003-DTB [CBV][M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BUND.Cht | 2020-03-03 18:13:35.827 GBL-202003-DTB [CBV][M] 15 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: BUND.Cht | 2020-03-03 18:13:35.855 HD Request # 131 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:35.911 HD Request # 131 | Sending historical data logon request message. | 2020-03-03 18:13:35.911 MES-202003-GLOBEX-USD [CBV][M] 15 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MES.Cht | 2020-03-03 18:13:35.976 MES-202003-GLOBEX-USD [CBV][M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: MES.Cht | 2020-03-03 18:13:36.013 HD Request # 131 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:30. Record interval: 0. Symbol: MGCJ20 | 2020-03-03 18:13:36.131 HD Request # 131 | Decompressing data. | 2020-03-03 18:13:36.357 HD Request # 131 | Receiving Intraday data for MGC-202004-NYMEX-USD-10 starting at 2020-03-03 18:13:30 | 2020-03-03 18:13:36.357 Socket (5) | CloseSocket call. | 2020-03-03 18:13:36.357 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:36.357 Historical data download thread signaled to stop. | 2020-03-03 18:13:36.360 HD Request # 131 | Received 1 record from 2020-03-03 18:13:30.000 to 2020-03-03 18:13:30.000 (0.0 seconds) and wrote 0 records for MGC-202004-NYMEX-USD-10 | 2020-03-03 18:13:36.360 HD Request # 131 | Completion time: 0s | 2020-03-03 18:13:36.360 HD Request # 131 | Intraday data download complete for MGC-202004-NYMEX-USD-10. Unique request ID: 132 | 2020-03-03 18:13:36.360 Removing historical data download ID 132. | 2020-03-03 18:13:36.360 Real-time Intraday chart data file updates started for MGC-202004-NYMEX-USD-10 | 2020-03-03 18:13:36.360 Intraday chart data file opened for MGC-202004-NYMEX-USD-10 | 2020-03-03 18:13:36.360 HD Request # 131 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:36.360 Triggering next historical data download in queue. | 2020-03-03 18:13:36.360 HD Request # 132 | Downloading Intraday chart data for SI-202005-NYMEX-USD-1000 to the file SI-202005-NYMEX-USD-1000.scid. Service: comex | 2020-03-03 18:13:36.360 HD Request # 132 | Download start date-time: 2020-03-03 18:11:27.000 | 2020-03-03 18:13:36.360 HD Request # 132 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2020-03-03 18:13:36.362 Socket (4) | Creating socket. | 2020-03-03 18:13:36.362 Socket (4) | Connecting to IP: 8.18.161.135. | 2020-03-03 18:13:36.362 Chart #4 has tagged chart #2 for full recalculation. Chartbook: GC.Cht | 2020-03-03 18:13:36.476 Chart #4 has tagged chart #5 for full recalculation. Chartbook: GC.Cht | 2020-03-03 18:13:36.476 Chart #4 has tagged chart #6 for full recalculation. Chartbook: GC.Cht | 2020-03-03 18:13:36.476 MGC-202004-NYMEX-USD-10 [CBV][M] 15 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: GC.Cht | 2020-03-03 18:13:36.483 MGC-202004-NYMEX-USD-10 [CBV][M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: GC.Cht | 2020-03-03 18:13:36.504 MGC-202004-NYMEX-USD-10 [CBV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: GC.Cht | 2020-03-03 18:13:36.526 Socket (5) | Socket gracefully closed by remote side. | 2020-03-03 18:13:36.579 Socket (5) | Closed. | 2020-03-03 18:13:36.580 HD Request # 132 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:36.823 HD Request # 132 | Sending historical data logon request message. | 2020-03-03 18:13:36.823 HD Request # 132 | Requesting Intraday data. Start date-time: 2020-03-03 18:11:27. Record interval: 0. Symbol: SILK20 | 2020-03-03 18:13:37.049 HD Request # 132 | Decompressing data. | 2020-03-03 18:13:37.272 HD Request # 132 | Receiving Intraday data for SI-202005-NYMEX-USD-1000 starting at 2020-03-03 18:11:27 | 2020-03-03 18:13:37.272 Socket (4) | CloseSocket call. | 2020-03-03 18:13:37.272 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:37.272 Historical data download thread signaled to stop. | 2020-03-03 18:13:37.282 HD Request # 132 | Received 2 records from 2020-03-03 18:11:27.000 to 2020-03-03 18:11:27.001 (0.0 seconds) and wrote 0 records for SI-202005-NYMEX-USD-1000 | 2020-03-03 18:13:37.284 HD Request # 132 | Completion time: 1s | 2020-03-03 18:13:37.284 HD Request # 132 | Intraday data download complete for SI-202005-NYMEX-USD-1000. Unique request ID: 133 | 2020-03-03 18:13:37.284 Removing historical data download ID 133. | 2020-03-03 18:13:37.284 Real-time Intraday chart data file updates started for SI-202005-NYMEX-USD-1000 | 2020-03-03 18:13:37.284 Intraday chart data file opened for SI-202005-NYMEX-USD-1000 | 2020-03-03 18:13:37.284 HD Request # 132 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:37.284 Triggering next historical data download in queue. | 2020-03-03 18:13:37.287 HD Request # 133 | Downloading Intraday chart data for ZN-202006-ECBOT to the file ZN-202006-ECBOT.scid. Service: cbot | 2020-03-03 18:13:37.289 HD Request # 133 | Download start date-time: 2020-03-03 18:00:57.000 | 2020-03-03 18:13:37.290 HD Request # 133 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2020-03-03 18:13:37.290 Socket (5) | Creating socket. | 2020-03-03 18:13:37.290 Socket (5) | Connecting to IP: 8.18.161.133. | 2020-03-03 18:13:37.290 Socket (4) | Socket gracefully closed by remote side. | 2020-03-03 18:13:37.501 Socket (4) | Closed. | 2020-03-03 18:13:37.501 Opened cached Intraday file: C:\SierraChart\Data\USDJPY.scid | 2020-03-03 18:13:37.579 Opened cached Intraday file: C:\SierraChart\Data\USDCAD.scid | 2020-03-03 18:13:37.610 Opened cached Intraday file: C:\SierraChart\Data\GBL-202003-DTB.scid | 2020-03-03 18:13:37.610 Opened cached Intraday file: C:\SierraChart\Data\MES-202003-GLOBEX-USD.scid | 2020-03-03 18:13:37.611 Opened cached Intraday file: C:\SierraChart\Data\MGC-202004-NYMEX-USD-10.scid | 2020-03-03 18:13:37.611 Chart #4 has tagged chart #2 for full recalculation. Chartbook: SI.Cht | 2020-03-03 18:13:37.657 Chart #4 has tagged chart #5 for full recalculation. Chartbook: SI.Cht | 2020-03-03 18:13:37.657 Chart #4 has tagged chart #6 for full recalculation. Chartbook: SI.Cht | 2020-03-03 18:13:37.657 SI-202005-NYMEX-USD-1000 [CBV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: SI.Cht | 2020-03-03 18:13:37.669 HD Request # 133 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:37.750 HD Request # 133 | Sending historical data logon request message. | 2020-03-03 18:13:37.750 SI-202005-NYMEX-USD-1000 [CBV][M] 15 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: SI.Cht | 2020-03-03 18:13:37.758 SI-202005-NYMEX-USD-1000 [CBV][M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SI.Cht | 2020-03-03 18:13:37.921 HD Request # 133 | Requesting Intraday data. Start date-time: 2020-03-03 18:00:57. Record interval: 0. Symbol: ZNM20 | 2020-03-03 18:13:37.975 HD Request # 133 | Decompressing data. | 2020-03-03 18:13:38.210 HD Request # 133 | Receiving Intraday data for ZN-202006-ECBOT starting at 2020-03-03 18:00:57 | 2020-03-03 18:13:38.445 Socket (5) | CloseSocket call. | 2020-03-03 18:13:38.449 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:38.449 Historical data download thread signaled to stop. | 2020-03-03 18:13:38.454 HD Request # 133 | Timestamp of first Intraday data file record written: 2020-03-03 18:00:59 | 2020-03-03 18:13:38.455 HD Request # 133 | Received 5610 records from 2020-03-03 18:00:57.000 to 2020-03-03 18:13:47.001 (12.8 minutes) and wrote 5585 records for ZN-202006-ECBOT | 2020-03-03 18:13:38.455 HD Request # 133 | Completion time: 0s | 2020-03-03 18:13:38.459 HD Request # 133 | Intraday data download complete for ZN-202006-ECBOT. Unique request ID: 134 | 2020-03-03 18:13:38.459 Removing historical data download ID 134. | 2020-03-03 18:13:38.459 Real-time Intraday chart data file updates started for ZN-202006-ECBOT | 2020-03-03 18:13:38.459 Intraday chart data file opened for ZN-202006-ECBOT | 2020-03-03 18:13:38.459 HD Request # 133 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:38.459 Triggering next historical data download in queue. | 2020-03-03 18:13:38.459 HD Request # 134 | Downloading Intraday chart data for MJY-202003-GLOBEX-USD-1250000 to the file MJY-202003-GLOBEX-USD-1250000.scid. Service: cme | 2020-03-03 18:13:38.459 HD Request # 134 | Download start date-time: 2020-03-03 18:10:04.000 | 2020-03-03 18:13:38.460 HD Request # 134 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2020-03-03 18:13:38.463 Socket (4) | Creating socket. | 2020-03-03 18:13:38.463 Socket (4) | Connecting to IP: 8.18.161.135. | 2020-03-03 18:13:38.463 Socket (5) | Socket gracefully closed by remote side. | 2020-03-03 18:13:38.675 Socket (5) | Closed. | 2020-03-03 18:13:38.675 Interactive Brokers | All contract details received for symbols used for trading. Re-requesting trading data. | 2020-03-03 18:13:38.700 Interactive Brokers | Stopping automatic Trade Position updates for account: U744* | 2020-03-03 18:13:38.700 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates (6)) for account: U744* | 2020-03-03 18:13:38.700 Message from IB: API client has been unsubscribed from account data. IB Error Code: 2100. Request ID: -1. | 2020-03-03 18:13:38.705 Interactive Brokers | Begin Trade Positions processing. | 2020-03-03 18:13:38.714 Interactive Brokers | Received Trade Positions download end message for account U744* | 2020-03-03 18:13:38.715 Interactive Brokers | Received Trade Positions for all accounts. Performing final processing. | 2020-03-03 18:13:38.715 HD Request # 134 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:38.922 HD Request # 134 | Sending historical data logon request message. | 2020-03-03 18:13:38.922 HD Request # 134 | Requesting Intraday data. Start date-time: 2020-03-03 18:10:04. Record interval: 0. Symbol: MJYH20 | 2020-03-03 18:13:39.153 Chart #4 has tagged chart #2 for full recalculation. Chartbook: ZN.Cht | 2020-03-03 18:13:39.300 Chart #4 has tagged chart #5 for full recalculation. Chartbook: ZN.Cht | 2020-03-03 18:13:39.300 Chart #4 has tagged chart #6 for full recalculation. Chartbook: ZN.Cht | 2020-03-03 18:13:39.300 ZN-202006-ECBOT [CBV][M] 15 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: ZN.Cht | 2020-03-03 18:13:39.371 HD Request # 134 | Decompressing data. | 2020-03-03 18:13:39.382 HD Request # 134 | Receiving Intraday data for MJY-202003-GLOBEX-USD-1250000 starting at 2020-03-03 18:10:04 | 2020-03-03 18:13:39.382 Socket (4) | CloseSocket call. | 2020-03-03 18:13:39.382 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:39.382 Historical data download thread signaled to stop. | 2020-03-03 18:13:39.404 HD Request # 134 | Received 1 record from 2020-03-03 18:10:04.000 to 2020-03-03 18:10:04.000 (0.0 seconds) and wrote 0 records for MJY-202003-GLOBEX-USD-1250000 | 2020-03-03 18:13:39.404 HD Request # 134 | Completion time: 0s | 2020-03-03 18:13:39.405 HD Request # 134 | Intraday data download complete for MJY-202003-GLOBEX-USD-1250000. Unique request ID: 135 | 2020-03-03 18:13:39.405 Removing historical data download ID 135. | 2020-03-03 18:13:39.405 Real-time Intraday chart data file updates started for MJY-202003-GLOBEX-USD-1250000 | 2020-03-03 18:13:39.405 Intraday chart data file opened for MJY-202003-GLOBEX-USD-1250000 | 2020-03-03 18:13:39.405 HD Request # 134 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:39.405 Triggering next historical data download in queue. | 2020-03-03 18:13:39.406 HD Request # 135 | Downloading Intraday chart data for LEV20-LEG21.FUT_SPREAD.CME to the file LEV20-LEG21.FUT_SPREAD.CME.scid. Service: cme | 2020-03-03 18:13:39.407 HD Request # 135 | Download start date-time: 2020-03-03 05:02:50.000 | 2020-03-03 18:13:39.411 HD Request # 135 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2020-03-03 18:13:39.411 Socket (5) | Creating socket. | 2020-03-03 18:13:39.411 Socket (5) | Connecting to IP: 8.18.161.133. | 2020-03-03 18:13:39.411 Socket (4) | Socket gracefully closed by remote side. | 2020-03-03 18:13:39.609 Socket (4) | Closed. | 2020-03-03 18:13:39.610 Chart #4 has tagged chart #2 for full recalculation. Chartbook: Quoteboard.Cht | 2020-03-03 18:13:39.809 Chart #4 has tagged chart #5 for full recalculation. Chartbook: Quoteboard.Cht | 2020-03-03 18:13:39.809 Chart #4 has tagged chart #6 for full recalculation. Chartbook: Quoteboard.Cht | 2020-03-03 18:13:39.809 MJY-202003-GLOBEX-USD-1250000/SPY-CFD-SMART-USD [CBV][M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: Quoteboard.Cht | 2020-03-03 18:13:39.826 MJY-202003-GLOBEX-USD-1250000[M]/SPY-CFD-SMART-USD [CBV] 15 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: Quoteboard.Cht | 2020-03-03 18:13:39.881 HD Request # 135 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:39.885 HD Request # 135 | Sending historical data logon request message. | 2020-03-03 18:13:39.885 HD Request # 135 | Requesting Intraday data. Start date-time: 2020-03-03 05:02:50. Record interval: 0. Symbol: LEV20-LEG21.FUT_SPREAD.CME | 2020-03-03 18:13:40.118 MJY-202003-GLOBEX-USD-1250000 [CBV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Quoteboard.Cht | 2020-03-03 18:13:40.133 ZN-202006-ECBOT [CBV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ZN.Cht | 2020-03-03 18:13:40.179 HD Request # 135 | Decompressing data. | 2020-03-03 18:13:40.350 HD Request # 135 | Receiving Intraday data for LEV20-LEG21.FUT_SPREAD.CME starting at 2020-03-03 05:02:50 | 2020-03-03 18:13:40.350 Socket (5) | CloseSocket call. | 2020-03-03 18:13:40.350 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:40.350 ZN-202006-ECBOT [CBV][M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: ZN.Cht | 2020-03-03 18:13:40.351 Historical data download thread signaled to stop. | 2020-03-03 18:13:40.384 HD Request # 135 | Received 3 records from 2020-03-03 05:02:50.000 to 2020-03-03 05:02:50.002 (0.0 seconds) and wrote 0 records for LEV20-LEG21.FUT_SPREAD.CME | 2020-03-03 18:13:40.384 HD Request # 135 | Completion time: 1s | 2020-03-03 18:13:40.384 HD Request # 135 | Intraday data download complete for LEV20-LEG21.FUT_SPREAD.CME. Unique request ID: 136 | 2020-03-03 18:13:40.384 Removing historical data download ID 136. | 2020-03-03 18:13:40.384 Real-time Intraday chart data file updates started for LEV20-LEG21.FUT_SPREAD.CME | 2020-03-03 18:13:40.384 Intraday chart data file opened for LEV20-LEG21.FUT_SPREAD.CME | 2020-03-03 18:13:40.384 HD Request # 135 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:40.384 Triggering next historical data download in queue. | 2020-03-03 18:13:40.384 HD Request # 136 | Downloading Intraday chart data for QG-202004-NYMEX to the file QG-202004-NYMEX.scid. Service: nymex | 2020-03-03 18:13:40.385 HD Request # 136 | Download start date-time: 2020-03-03 18:10:54.000 | 2020-03-03 18:13:40.385 HD Request # 136 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2020-03-03 18:13:40.387 Socket (4) | Creating socket. | 2020-03-03 18:13:40.387 Socket (4) | Connecting to IP: 8.18.161.135. | 2020-03-03 18:13:40.387 Socket (5) | Socket gracefully closed by remote side. | 2020-03-03 18:13:40.583 Socket (5) | Closed. | 2020-03-03 18:13:40.583 HD Request # 136 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:40.857 HD Request # 136 | Sending historical data logon request message. | 2020-03-03 18:13:40.857 HD Request # 136 | Requesting Intraday data. Start date-time: 2020-03-03 18:10:54. Record interval: 0. Symbol: QGJ20 | 2020-03-03 18:13:41.085 HD Request # 136 | Decompressing data. | 2020-03-03 18:13:41.315 HD Request # 136 | Receiving Intraday data for QG-202004-NYMEX starting at 2020-03-03 18:10:54 | 2020-03-03 18:13:41.315 Socket (4) | CloseSocket call. | 2020-03-03 18:13:41.315 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:41.316 Historical data download thread signaled to stop. | 2020-03-03 18:13:41.322 HD Request # 136 | Received 1 record from 2020-03-03 18:10:54.000 to 2020-03-03 18:10:54.000 (0.0 seconds) and wrote 0 records for QG-202004-NYMEX | 2020-03-03 18:13:41.322 HD Request # 136 | Completion time: 1s | 2020-03-03 18:13:41.322 HD Request # 136 | Intraday data download complete for QG-202004-NYMEX. Unique request ID: 137 | 2020-03-03 18:13:41.322 Removing historical data download ID 137. | 2020-03-03 18:13:41.322 Real-time Intraday chart data file updates started for QG-202004-NYMEX | 2020-03-03 18:13:41.322 Intraday chart data file opened for QG-202004-NYMEX | 2020-03-03 18:13:41.322 HD Request # 136 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:41.322 Triggering next historical data download in queue. | 2020-03-03 18:13:41.322 HD Request # 137 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2020-03-03 18:13:41.325 HD Request # 137 | Download start date-time: 2020-03-03 18:13:30.000 | 2020-03-03 18:13:41.326 HD Request # 137 | Using server: ds4.sierracharts.com port 10149 | 2020-03-03 18:13:41.326 Socket (5) | Creating socket. | 2020-03-03 18:13:41.326 Socket (5) | Connecting to IP: 192.81.56.146. | 2020-03-03 18:13:41.326 Chart #8 has tagged chart #7 for full recalculation. Chartbook: Spreads.Cht | 2020-03-03 18:13:41.376 QG-202004-NYMEX[M] 1 Day #7 | Performing a full recalculation because it has been tagged. Chartbook: Spreads.Cht | 2020-03-03 18:13:41.401 Socket (4) | Socket gracefully closed by remote side. | 2020-03-03 18:13:41.543 Socket (4) | Closed. | 2020-03-03 18:13:41.543 HD Request # 137 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:41.826 HD Request # 137 | Sending historical data logon request message. | 2020-03-03 18:13:41.826 Chart #4 has tagged chart #2 for full recalculation. Chartbook: QG.Cht | 2020-03-03 18:13:42.038 Chart #4 has tagged chart #5 for full recalculation. Chartbook: QG.Cht | 2020-03-03 18:13:42.038 Chart #4 has tagged chart #6 for full recalculation. Chartbook: QG.Cht | 2020-03-03 18:13:42.038 HD Request # 137 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:30. Record interval: 0. Symbol: EURUSD | 2020-03-03 18:13:42.077 QG-202004-NYMEX [CBV][M] 15 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: QG.Cht | 2020-03-03 18:13:42.095 QG-202004-NYMEX [CBV][M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: QG.Cht | 2020-03-03 18:13:42.111 QG-202004-NYMEX[M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: QG.Cht | 2020-03-03 18:13:42.193 HD Request # 137 | Decompressing data. | 2020-03-03 18:13:42.324 HD Request # 137 | Receiving Intraday data for EURUSD starting at 2020-03-03 18:13:30 | 2020-03-03 18:13:42.324 Socket (5) | CloseSocket call. | 2020-03-03 18:13:42.326 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:42.326 Historical data download thread signaled to stop. | 2020-03-03 18:13:42.336 HD Request # 137 | Timestamp of first Intraday data file record written: 2020-03-03 18:13:31 | 2020-03-03 18:13:42.336 HD Request # 137 | Received 157 records from 2020-03-03 18:13:30.000 to 2020-03-03 18:13:54.002 (24.0 seconds) and wrote 147 records for EURUSD | 2020-03-03 18:13:42.336 HD Request # 137 | Completion time: 1s | 2020-03-03 18:13:42.336 HD Request # 137 | Intraday data download complete for EURUSD. Unique request ID: 138 | 2020-03-03 18:13:42.336 Removing historical data download ID 138. | 2020-03-03 18:13:42.336 Real-time Intraday chart data file updates started for EURUSD | 2020-03-03 18:13:42.336 Intraday chart data file opened for EURUSD | 2020-03-03 18:13:42.336 HD Request # 137 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:42.336 Triggering next historical data download in queue. | 2020-03-03 18:13:42.336 HD Request # 138 | Downloading Intraday chart data for ES-202003-GLOBEX to the file ES-202003-GLOBEX.scid. Service: cme | 2020-03-03 18:13:42.339 HD Request # 138 | Download start date-time: 2020-03-03 18:13:31.000 | 2020-03-03 18:13:42.340 HD Request # 138 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2020-03-03 18:13:42.340 Socket (4) | Creating socket. | 2020-03-03 18:13:42.340 Socket (4) | Connecting to IP: 8.18.161.133. | 2020-03-03 18:13:42.340 Socket (5) | Socket gracefully closed by remote side. | 2020-03-03 18:13:42.575 Socket (5) | Closed. | 2020-03-03 18:13:42.575 Chart #4 has tagged chart #2 for full recalculation. Chartbook: EURUSD.Cht | 2020-03-03 18:13:42.608 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid | 2020-03-03 18:13:42.621 Opened cached Intraday file: C:\SierraChart\Data\MJY-202003-GLOBEX-USD-1250000.scid | 2020-03-03 18:13:42.622 HD Request # 138 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:42.794 HD Request # 138 | Sending historical data logon request message. | 2020-03-03 18:13:42.794 HD Request # 138 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:31. Record interval: 0. Symbol: ESH20 | 2020-03-03 18:13:43.020 HD Request # 138 | Decompressing data. | 2020-03-03 18:13:43.248 HD Request # 138 | Receiving Intraday data for ES-202003-GLOBEX starting at 2020-03-03 18:13:31 | 2020-03-03 18:13:43.248 Socket (4) | CloseSocket call. | 2020-03-03 18:13:43.249 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:43.249 Historical data download thread signaled to stop. | 2020-03-03 18:13:43.277 HD Request # 138 | Timestamp of first Intraday data file record written: 2020-03-03 18:13:31 | 2020-03-03 18:13:43.277 HD Request # 138 | Received 308 records from 2020-03-03 18:13:31.000 to 2020-03-03 18:13:53.000 (22.0 seconds) and wrote 306 records for ES-202003-GLOBEX | 2020-03-03 18:13:43.278 HD Request # 138 | Completion time: 0s | 2020-03-03 18:13:43.278 HD Request # 138 | Intraday data download complete for ES-202003-GLOBEX. Unique request ID: 139 | 2020-03-03 18:13:43.278 Removing historical data download ID 139. | 2020-03-03 18:13:43.278 Real-time Intraday chart data file updates started for ES-202003-GLOBEX | 2020-03-03 18:13:43.278 Intraday chart data file opened for ES-202003-GLOBEX | 2020-03-03 18:13:43.278 HD Request # 138 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:43.278 Triggering next historical data download in queue. | 2020-03-03 18:13:43.278 HD Request # 139 | Downloading Intraday chart data for QM-202004-NYMEX to the file QM-202004-NYMEX.scid. Service: nymex | 2020-03-03 18:13:43.296 HD Request # 139 | Download start date-time: 2020-03-03 18:13:30.000 | 2020-03-03 18:13:43.297 HD Request # 139 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2020-03-03 18:13:43.300 Socket (5) | Creating socket. | 2020-03-03 18:13:43.300 Socket (5) | Connecting to IP: 8.18.161.135. | 2020-03-03 18:13:43.300 Socket (4) | Socket gracefully closed by remote side. | 2020-03-03 18:13:43.472 Socket (4) | Closed. | 2020-03-03 18:13:43.472 EURUSD [CBV-D][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: EURUSD.Cht | 2020-03-03 18:13:43.605 HD Request # 139 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:43.761 HD Request # 139 | Sending historical data logon request message. | 2020-03-03 18:13:43.761 HD Request # 139 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:30. Record interval: 0. Symbol: QMJ20 | 2020-03-03 18:13:43.990 HD Request # 139 | Decompressing data. | 2020-03-03 18:13:44.219 HD Request # 139 | Receiving Intraday data for QM-202004-NYMEX starting at 2020-03-03 18:13:30 | 2020-03-03 18:13:44.219 Socket (5) | CloseSocket call. | 2020-03-03 18:13:44.220 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:44.220 Historical data download thread signaled to stop. | 2020-03-03 18:13:44.250 HD Request # 139 | Timestamp of first Intraday data file record written: 2020-03-03 18:13:35 | 2020-03-03 18:13:44.252 HD Request # 139 | Received 10 records from 2020-03-03 18:13:30.000 to 2020-03-03 18:13:48.000 (18.0 seconds) and wrote 8 records for QM-202004-NYMEX | 2020-03-03 18:13:44.252 HD Request # 139 | Completion time: 1s | 2020-03-03 18:13:44.252 HD Request # 139 | Intraday data download complete for QM-202004-NYMEX. Unique request ID: 140 | 2020-03-03 18:13:44.252 Removing historical data download ID 140. | 2020-03-03 18:13:44.252 Real-time Intraday chart data file updates started for QM-202004-NYMEX | 2020-03-03 18:13:44.252 Intraday chart data file opened for QM-202004-NYMEX | 2020-03-03 18:13:44.252 HD Request # 139 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:44.252 Triggering next historical data download in queue. | 2020-03-03 18:13:44.253 HD Request # 140 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2020-03-03 18:13:44.253 HD Request # 140 | Download start date-time: 2020-03-03 18:13:30.000 | 2020-03-03 18:13:44.254 HD Request # 140 | Using server: ds3.sierracharts.com port 10150 | 2020-03-03 18:13:44.258 Socket (4) | Creating socket. | 2020-03-03 18:13:44.258 Socket (4) | Connecting to IP: 65.182.172.42. | 2020-03-03 18:13:44.258 Socket (5) | Socket gracefully closed by remote side. | 2020-03-03 18:13:44.451 Socket (5) | Closed. | 2020-03-03 18:13:44.451 Chart #4 has tagged chart #2 for full recalculation. Chartbook: ES.Cht | 2020-03-03 18:13:44.478 Chart #4 has tagged chart #5 for full recalculation. Chartbook: ES.Cht | 2020-03-03 18:13:44.478 Chart #4 has tagged chart #6 for full recalculation. Chartbook: ES.Cht | 2020-03-03 18:13:44.478 Chart #4 has tagged chart #2 for full recalculation. Chartbook: QM.Cht | 2020-03-03 18:13:44.493 Chart #4 has tagged chart #5 for full recalculation. Chartbook: QM.Cht | 2020-03-03 18:13:44.493 Chart #4 has tagged chart #6 for full recalculation. Chartbook: QM.Cht | 2020-03-03 18:13:44.493 HD Request # 140 | Setting DTC encoding to Binary VLS | 2020-03-03 18:13:44.738 HD Request # 140 | Sending historical data logon request message. | 2020-03-03 18:13:44.738 HD Request # 140 | Requesting Intraday data. Start date-time: 2020-03-03 18:13:30. Record interval: 0. Symbol: AUDUSD | 2020-03-03 18:13:44.979 QM-202004-NYMEX [CBV][M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: QM.Cht | 2020-03-03 18:13:45.180 ES-202003-GLOBEX [CBV][M] 15 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2020-03-03 18:13:45.211 HD Request # 140 | Decompressing data. | 2020-03-03 18:13:45.215 HD Request # 140 | Receiving Intraday data for AUDUSD starting at 2020-03-03 18:13:30 | 2020-03-03 18:13:45.215 Socket (4) | CloseSocket call. | 2020-03-03 18:13:45.217 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-03-03 18:13:45.217 Historical data download thread signaled to stop. | 2020-03-03 18:13:45.238 HD Request # 140 | Timestamp of first Intraday data file record written: 2020-03-03 18:13:34 | 2020-03-03 18:13:45.238 HD Request # 140 | Received 136 records from 2020-03-03 18:13:30.000 to 2020-03-03 18:13:56.001 (26.0 seconds) and wrote 134 records for AUDUSD | 2020-03-03 18:13:45.239 HD Request # 140 | Completion time: 0s | 2020-03-03 18:13:45.239 HD Request # 140 | Intraday data download complete for AUDUSD. Unique request ID: 141 | 2020-03-03 18:13:45.239 Removing historical data download ID 141. | 2020-03-03 18:13:45.239 Real-time Intraday chart data file updates started for AUDUSD | 2020-03-03 18:13:45.239 Intraday chart data file opened for AUDUSD | 2020-03-03 18:13:45.239 HD Request # 140 | Enabling Intraday chart updating for symbol. | 2020-03-03 18:13:45.239 Triggering next historical data download in queue. | 2020-03-03 18:13:45.240 QM-202004-NYMEX [CBV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: QM.Cht | 2020-03-03 18:13:45.243 ES-202003-GLOBEX [CBV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2020-03-03 18:13:45.284 ES-202003-GLOBEX [CBV][M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2020-03-03 18:13:45.323 QM-202004-NYMEX [CBV][M] 15 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: QM.Cht | 2020-03-03 18:13:45.345 Chart #4 has tagged chart #2 for full recalculation. Chartbook: AUDUSD.Cht | 2020-03-03 18:13:45.360 AUDUSD [CBV-D][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: AUDUSD.Cht | 2020-03-03 18:13:45.372 Socket (4) | Socket gracefully closed by remote side. | 2020-03-03 18:13:45.455 Socket (4) | Closed. | 2020-03-03 18:13:45.455 Opened cached Intraday file: C:\SierraChart\Data\AUDUSD.scid | 2020-03-03 18:13:47.625 |
[2020-03-03 10:29:39] |
This is the problem: Symbol Error - ZCN20-ZCU20.FUT_SPREAD.CBOT is unknown, unavailable, or improperly formatted. Over symbol limit. Limit is 20 symbols. | 2020-03-03 18:13:23.910 You have gone over the 20 symbol limit you have on the real-time connection . You need to change to 100 symbols. Refer to: Sierra Chart Exchange Data Feed: Symbol Limits Also be aware the new Denali Exchange Data Feed has no symbol limits. You can use the Denali exchange data feed for all of the CME group data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-03 10:29:58
