Date/Time: Mon, 29 Apr 2024 10:08:48 +0000
Denali Data Feed
View Count: 1619
[2019-10-23 17:57:45] |
User135370 - Posts: 160 |
Why does it take sooooo long to connect to Denali Data Feed. I applied through AMP, Sierra sends me agreements to complete Hours ago which I have done then nothing, hours later still waiting. Can anyone help |
[2019-10-23 20:47:36] |
SC Support - Posts: 1795 |
I will email you to set-up a quick call.
[2019-10-23 22:00:20] |
The Denali Exchange Data Feed is active on your Sierra Chart account at this time. The problem is probably because you need to connect to a live trading account to authorize the CME data: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-23 22:01:54
[2020-01-16 22:07:54] |
JDP6 - Posts: 9 |
I am only using sierra chart for charting/data. i do want real time data. i am trading the /ES. what is the best data feed for this? is it Denali and if so which exchange should i activate? i need access to market profile.
Date Time Of Last Edit: 2020-01-16 22:08:09
[2020-01-16 23:21:08] |
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Also refer to: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-16 23:35:35] |
JDP6 - Posts: 9 |
i am using think or swim; i am seeing that wont work; i did just apply for the AMP account. that seems to be the easiest solution. if i fund the AMP account; do i need to activate the denali exchange feed ($25/month) still and then activate the full CME group service ($15.75/month) or since i have AMP i wont need to do this? im a bit confused on this. thank you |
[2020-01-17 00:01:48] |
When you set up the AMP account you do need to pay for the Denali exchange data feed and the exchange fee still, but you can choose the $20 option for the Sierra Chart order routing service.
[2020-01-28 10:16:00] |
opci - Posts: 90 |
Active Service: 3 - Standard - Active until: 2020-02-14 23:59:59 UTC i have an active denali package .. but i haven't activated it yet because i don't know how? now i have demo cqg still day 2 .. how do i start using data feed today? thank you |
[2020-01-28 18:52:08] |
Sierra_Chart Engineering - Posts: 14126 |
With Regards to Post #8: You can either get the Denali Exchange Data Feed through AMP or directly through Sierra Chart. It will be the same cost in either case. The only difference is who you pay. If you want to set it up through AMP, then let them know and have them take care of it. If you want to pay for the data feed directly to Sierra Chart, then follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* You can also use the Delayed exchange data feed: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 18:54:41
[2020-01-29 08:23:40] |
opci - Posts: 90 |
already paid you to the control panel $ 26 data feed I put you first sentence. I don't know how to use it "Active Service: 3 - Standard - Active until: 2020-02-14 23:59:59 UTC" |
[2020-01-29 13:41:43] |
Hi Wetro, can we give you a call to speak about this when you have time today?
[2020-01-30 14:02:15] |
opci - Posts: 90 |
i don't speak english unfortunately ,, i use google translator
[2020-01-30 15:10:28] |
Hi Wetro, going back to your first question about activating Denali, if we broke it down into steps the first step from here is to complete the Market Data Agreements. Be sure to use your full name, as it would appear at AMP. Next step: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements Documentation for Denali: Denali Exchange Data Feed |
[2020-02-05 09:44:03] |
opci - Posts: 90 |
i did it all. i clicked and edit --- translate symbol to curent service .. put sc data all service..i connect but the graph doesn't go live just update con-dis ... is that so normal? |
[2020-02-05 10:08:53] |
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-05 15:57:20] |
Hi Wetro, we can't accommodate you with Non-Professional access to the Denali, you insist on providing a Fake Name and likely Fake Address even though we have asked you politely many times. We find this disappointing.
[2020-02-21 03:21:51] |
opci - Posts: 90 |
i'm sorry, i tried to try sierra dll after the pause because of problems with dll custom 32 bit study, i did the same to broker like every year Non-Professional access.I thought it was solved.a data on sc board is from when i tested the sierra chart platform 1 time..so tell me what to do now because i didn't use the paid period at all ,, thanks in advance
