Date/Time: Sat, 04 May 2024 15:43:02 +0000
New and some questions
View Count: 625
[2019-10-13 12:09:50] |
User680631 - Posts: 3 |
Hi, I just downloaded Sierra as I want to change softwares. I used to use Ensign but they do not really offer what I need. My questions: -How can I overlap 2 indicators in a subwindow? -How can I show the volume profil? -How can I get a Footprint chart? -How can I change the color of the scale? -How can I change the size of the subwindow, mine are much to high? I have been looking around in the software for the last 3 hours but do not step forward. That is my first questions. Woukd be great if you help me. Thanks a million Date Time Of Last Edit: 2019-10-13 12:10:44
[2019-10-15 15:24:18] |
John - SC Support - Posts: 31362 |
Here are the answers to your questions: 1. Just place both studies in the same region. Refer to the following: Chart Studies: Settings and Inputs Tab >> Chart Region Be sure to look through all of the above, as it includes a section on using the Left-Hand Scale if the values between the studies are very different. 2. Add the Volume by Price study to the chart. Refer to the following: Volume By Price Study 3. This is called Numbers Bars in Sierra Chart. Refer to the following: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#s328 4. The colors are controlled in Global Settings >> Graphics Settings - Global. The text in the scales is controlled by the general Chart Text coloring. Refer to the following: Graphics Settings: Chart Text 5. We assume you mean the Regions. Refer to the following to change the size of the regions: Working With Charts: Chart Window and Regions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
