Date/Time: Wed, 15 May 2024 15:20:06 +0000
Sierra data not working after switch...
View Count: 742
[2019-07-01 11:40:04] |
User629089 - Posts: 93 |
Hi, I've just added the Sierra data two week trial and I'm not seeing the "[M]" following the exchange on any chart. In the instructions it says I should contact support and that symbol mapping will need to be set up by support. I don't see this on any symbol that I'm using which includes: YMU9-CBOT, ESU9-CME, NQU9-CME, RTYU9-CME, ZNU9-CBOT, ZBU9-CBOT, 6JU9-CME, GCQ9-COMEX, CLQ9-NYMEX, 6BU9-CME, 6EU9-CME. I think that's it for the futures symbols. I think I set everything up exactly as instructed. The "[M]" does appear just after you pull the software up but disappears shortly after. I also use cash mkt symbols like AD line and Net Vol. Are these part of the Sierra data service? Please help. Thanks... |
[2019-07-01 11:59:05] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog ----- I also use cash mkt symbols like AD line and Net Vol. Are these part of the Sierra data service? In regards to these, refer to:Sierra Chart Market Statistics: Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-01 12:14:13] |
Hi, Here's the Message Log after cleared and the data feed reconnected... Software version: 1941 64-bit | 2019-07-01 07:11:29.422 Usage end date: 2019-07-12 | 2019-07-01 07:11:29.423 Enabled for: Advanced Features. | 2019-07-01 07:11:29.423 Enabled for: Advanced Features 2. | 2019-07-01 07:11:29.423 Enabled for: Sierra Chart Historical Data Service. | 2019-07-01 07:11:29.423 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-07-01 07:11:29.423 Enabled for exchange: INDEXES_DATA_BARCHART | 2019-07-01 07:11:29.423 Enabled for exchange: CME (Trading Account Required) | 2019-07-01 07:11:29.423 Enabled for exchange: CBOT (Trading Account Required) | 2019-07-01 07:11:29.423 Enabled for exchange: COMEX (Trading Account Required) | 2019-07-01 07:11:29.423 Enabled for exchange: NYMEX (Trading Account Required) | 2019-07-01 07:11:29.423 Received 1 data feed usernames. | 2019-07-01 07:11:29.423 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-07-01 07:11:29.423 Current selected Data/Trading service: Rithmic Trading | 2019-07-01 07:11:29.423 Custom symbol settings values: enabled | 2019-07-01 07:11:29.423 Chart Update Interval: 500 | 2019-07-01 07:11:29.423 Intraday Data Storage Time Unit: 0 | 2019-07-01 07:11:29.423 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-07-01 07:11:29.423 2019-07-01 07:11:29 Local computer time | 2019-07-01 07:11:29.423 2019-07-01 12:11:29 Local computer time in UTC | 2019-07-01 07:11:29.423 2019-07-01 07:11:29 Local computer time in SC Time Zone | 2019-07-01 07:11:29.423 2019-07-01 12:06:42 Server time in UTC | 2019-07-01 07:11:29.423 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-07-01 07:11:29.423 Program path: E:\SierraChart\ | 2019-07-01 07:11:29.423 Data Files path: E:\SierraChart\Data\ | 2019-07-01 07:11:29.423 OS Version Number: 6.1 | 2019-07-01 07:11:29.423 Locale Setting: C | 2019-07-01 07:11:29.423 DLLs: Convergent.dll, Convergent_64.dll, Smaug_SC_Library.dll, Smaug_SC_Library_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-07-01 07:11:29.424 Rithmic Trading | Port for executable: 63528 | 2019-07-01 07:11:51.922 Listening socket (1140). Port 63528 | Closed. | 2019-07-01 07:11:51.922 Rithmic Trading | Starting server: E:\SierraChart\Rim\DTCBridge.exe | 2019-07-01 07:11:51.922 Created process E:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:63528. Current folder: E:\SierraChart\Rim | 2019-07-01 07:11:51.933 Rithmic Trading | Bridge process is running. | 2019-07-01 07:11:53.943 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63528 | 2019-07-01 07:11:53.943 DTC Client socket (1) | Creating socket. | 2019-07-01 07:11:53.943 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-07-01 07:11:53.943 Rithmic Trading | Connected to server. | 2019-07-01 07:11:53.944 Rithmic Trading | Starting socket receive thread. | 2019-07-01 07:11:53.944 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-07-01 07:11:53.945 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-07-01 07:11:53.948 Rithmic Trading | Sending logon request message. | 2019-07-01 07:11:53.948 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-07-01 07:11:53.950 Rithmic Trading | Message from server: Logging is enabled. Log file: E:\SierraChart\Rim\Rithmic.log | 2019-07-01 07:11:53.954 Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-01 07:11:53.954 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-07-01 07:11:54.821 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-07-01 07:11:54.821 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2019-07-01 07:11:54.933 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2019-07-01 07:11:54.961 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2019-07-01 07:11:55.102 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2019-07-01 07:11:55.124 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2019-07-01 07:11:55.280 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2019-07-01 07:11:55.280 Rithmic Trading | Received logon response. | 2019-07-01 07:11:55.973 Rithmic Trading | Server Name: SC DTC Bridge. | 2019-07-01 07:11:55.973 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-07-01 07:11:55.973 Rithmic Trading | Successfully connected. IB='Stage5-Paper', Firm='Dorman'. | 2019-07-01 07:11:55.973 Rithmic Trading | Trading is supported. | 2019-07-01 07:11:55.973 Rithmic Trading | Order cancel and replace is supported. | 2019-07-01 07:11:55.973 Rithmic Trading | OCO Orders supported. | 2019-07-01 07:11:55.973 Rithmic Trading | Connected to data and trading server. | 2019-07-01 07:11:55.973 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2019-07-01 07:11:55.973 Rithmic Trading | Starting real-time market data updates for: 6JU9-CME. ID: 1 Service code: rithmic.trading | 2019-07-01 07:11:55.975 Rithmic Trading | Requesting security definition data for: 6JU9-CME. ID: 1 | 2019-07-01 07:11:55.975 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6JU9-CME | 2019-07-01 07:11:55.976 Intraday data recording state for symbol 6JU9-CME is set to download 'Pending'. | 2019-07-01 07:11:55.976 ZNU9-CBOT 30 Min #42 | Started historical data download for additional symbol 6JU9-CME. Download ID: 59 | 2019-07-01 07:11:55.976 Rithmic Trading | Starting real-time market data updates for: NQU9-CME. ID: 2 Service code: rithmic.trading | 2019-07-01 07:11:55.976 Rithmic Trading | Requesting security definition data for: NQU9-CME. ID: 2 | 2019-07-01 07:11:55.976 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQU9-CME | 2019-07-01 07:11:55.976 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-07-01 07:11:55.977 ZNU9-CBOT 30 Min #42 | Started historical data download for additional symbol NQU9-CME. Download ID: 60 | 2019-07-01 07:11:55.977 Rithmic Trading | Starting real-time market data updates for: YMU9-CBOT. ID: 3 Service code: rithmic.trading | 2019-07-01 07:11:55.977 Rithmic Trading | Requesting security definition data for: YMU9-CBOT. ID: 3 | 2019-07-01 07:11:55.977 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMU9-CBOT | 2019-07-01 07:11:55.977 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-07-01 07:11:55.977 ZNU9-CBOT 30 Min #42 | Started historical data download for additional symbol YMU9-CBOT. Download ID: 61 | 2019-07-01 07:11:55.977 Rithmic Trading | Starting real-time market data updates for: RTYU9-CME. ID: 4 Service code: rithmic.trading | 2019-07-01 07:11:55.977 Rithmic Trading | Requesting security definition data for: RTYU9-CME. ID: 4 | 2019-07-01 07:11:55.977 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYU9-CME | 2019-07-01 07:11:55.977 Intraday data recording state for symbol RTYU9-CME is set to download 'Pending'. | 2019-07-01 07:11:55.977 ZNU9-CBOT 30 Min #42 | Started historical data download for additional symbol RTYU9-CME. Download ID: 62 | 2019-07-01 07:11:55.977 Rithmic Trading | Starting real-time market data updates for: CLQ9-NYMEX. ID: 5 Service code: rithmic.trading | 2019-07-01 07:11:55.985 Rithmic Trading | Requesting security definition data for: CLQ9-NYMEX. ID: 5 | 2019-07-01 07:11:55.985 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLQ9-NYMEX | 2019-07-01 07:11:55.985 Intraday data recording state for symbol CLQ9-NYMEX is set to download 'Pending'. | 2019-07-01 07:11:55.985 ZBU9-CBOT 30 Min #18 | Started historical data download for additional symbol CLQ9-NYMEX. Download ID: 63 | 2019-07-01 07:11:55.985 Rithmic Trading | Starting real-time market data updates for: GCQ9-COMEX. ID: 6 Service code: rithmic.trading | 2019-07-01 07:11:55.985 Rithmic Trading | Requesting security definition data for: GCQ9-COMEX. ID: 6 | 2019-07-01 07:11:55.985 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ9-COMEX | 2019-07-01 07:11:55.986 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-07-01 07:11:55.986 ZBU9-CBOT 30 Min #18 | Started historical data download for additional symbol GCQ9-COMEX. Download ID: 64 | 2019-07-01 07:11:55.986 Rithmic Trading | Starting real-time market data updates for: 6EU9-CME. ID: 7 Service code: rithmic.trading | 2019-07-01 07:11:55.986 Rithmic Trading | Requesting security definition data for: 6EU9-CME. ID: 7 | 2019-07-01 07:11:55.986 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6EU9-CME | 2019-07-01 07:11:55.986 Intraday data recording state for symbol 6EU9-CME is set to download 'Pending'. | 2019-07-01 07:11:55.986 ZBU9-CBOT 30 Min #18 | Started historical data download for additional symbol 6EU9-CME. Download ID: 65 | 2019-07-01 07:11:55.986 Rithmic Trading | Starting real-time market data updates for: 6BU9-CME. ID: 8 Service code: rithmic.trading | 2019-07-01 07:11:55.986 Rithmic Trading | Requesting security definition data for: 6BU9-CME. ID: 8 | 2019-07-01 07:11:55.986 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6BU9-CME | 2019-07-01 07:11:55.986 Intraday data recording state for symbol 6BU9-CME is set to download 'Pending'. | 2019-07-01 07:11:55.986 ZBU9-CBOT 30 Min #18 | Started historical data download for additional symbol 6BU9-CME. Download ID: 66 | 2019-07-01 07:11:55.986 Delaying start of download for 6JU9-CME | 2019-07-01 07:11:56.003 Rithmic Trading | Starting real-time market data updates for: $VIX. ID: 9 Service code: cboe.index | 2019-07-01 07:11:56.140 Rithmic Trading | Requesting security definition data for: $VIX. ID: 9 | 2019-07-01 07:11:56.140 Rithmic Trading | Starting real-time market data updates for: ESU9-CME. ID: 10 Service code: rithmic.trading | 2019-07-01 07:11:56.145 Rithmic Trading | Requesting security definition data for: ESU9-CME. ID: 10 | 2019-07-01 07:11:56.145 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU9-CME | 2019-07-01 07:11:56.145 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-07-01 07:11:56.145 Symbol Error - $VIX is unknown, unavailable, or improperly formatted. | 2019-07-01 07:11:56.161 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-07-01 07:11:56.346 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 11 Service code: statscalc | 2019-07-01 07:11:56.505 SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2019-07-01 07:11:56.505 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 11 | 2019-07-01 07:11:56.505 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2019-07-01 07:11:56.505 DTC Client socket (2) | Creating socket. | 2019-07-01 07:11:56.506 DTC Client socket (2) | Connecting to IP: 65.182.172.42. | 2019-07-01 07:11:56.506 Rithmic Trading | Starting real-time market data updates for: ZNU9-CBOT. ID: 12 Service code: rithmic.trading | 2019-07-01 07:11:56.511 Rithmic Trading | Requesting security definition data for: ZNU9-CBOT. ID: 12 | 2019-07-01 07:11:56.511 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZNU9-CBOT | 2019-07-01 07:11:56.511 Intraday data recording state for symbol ZNU9-CBOT is set to download 'Pending'. | 2019-07-01 07:11:56.511 SC DTC Data with Market Depth | Connected to server. | 2019-07-01 07:11:56.544 SC DTC Data with Market Depth | Starting socket receive thread. | 2019-07-01 07:11:56.544 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2019-07-01 07:11:56.544 Rithmic Trading | Starting real-time market data updates for: XLK. ID: 13 Service code: equities.us | 2019-07-01 07:11:56.548 Rithmic Trading | Requesting security definition data for: XLK. ID: 13 | 2019-07-01 07:11:56.548 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: XLK | 2019-07-01 07:11:56.548 Intraday data recording state for symbol XLK is set to download 'Pending'. | 2019-07-01 07:11:56.548 Symbol Error - XLK is unknown, unavailable, or improperly formatted. | 2019-07-01 07:11:56.563 Rithmic Trading | Starting real-time market data updates for: ESM9-CME. ID: 14 Service code: rithmic.trading | 2019-07-01 07:11:56.573 Rithmic Trading | Requesting security definition data for: ESM9-CME. ID: 14 | 2019-07-01 07:11:56.573 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESM9-CME | 2019-07-01 07:11:56.573 Intraday data recording state for symbol ESM9-CME is set to download 'Pending'. | 2019-07-01 07:11:56.573 SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-NYSE. ID: 15 Service code: statscalc | 2019-07-01 07:11:56.586 SC DTC Data with Market Depth | Requesting security definition data for: NISS-NYSE. ID: 15 | 2019-07-01 07:11:56.586 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2019-07-01 07:11:56.586 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2019-07-01 07:11:56.608 SC DTC Data with Market Depth | Sending logon request message. | 2019-07-01 07:11:56.608 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: ESM9-CME | 2019-07-01 07:11:56.608 Symbol Error - ESM9-CME is unknown, unavailable, or improperly formatted. | 2019-07-01 07:11:56.608 Rithmic Trading | Starting real-time market data updates for: ZBU9-CBOT. ID: 16 Service code: rithmic.trading | 2019-07-01 07:11:56.710 Rithmic Trading | Requesting security definition data for: ZBU9-CBOT. ID: 16 | 2019-07-01 07:11:56.710 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZBU9-CBOT | 2019-07-01 07:11:56.710 Intraday data recording state for symbol ZBU9-CBOT is set to download 'Pending'. | 2019-07-01 07:11:56.710 SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-SP. ID: 17 Service code: statscalc | 2019-07-01 07:11:56.757 SC DTC Data with Market Depth | Requesting security definition data for: NISS-SP. ID: 17 | 2019-07-01 07:11:56.757 Intraday data recording state for symbol NISS-SP is set to download 'Pending'. | 2019-07-01 07:11:56.757 SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL-NYSE. ID: 18 Service code: statscalc | 2019-07-01 07:11:56.868 SC DTC Data with Market Depth | Requesting security definition data for: NVOL-NYSE. ID: 18 | 2019-07-01 07:11:56.868 Intraday data recording state for symbol NVOL-NYSE is set to download 'Pending'. | 2019-07-01 07:11:56.869 SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL-SP. ID: 19 Service code: statscalc | 2019-07-01 07:11:57.064 SC DTC Data with Market Depth | Requesting security definition data for: NVOL-SP. ID: 19 | 2019-07-01 07:11:57.064 Intraday data recording state for symbol NVOL-SP is set to download 'Pending'. | 2019-07-01 07:11:57.064 SC DTC Data with Market Depth | Received logon response. | 2019-07-01 07:11:57.066 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2019-07-01 07:11:57.066 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2019-07-01 07:11:57.066 SC DTC Data with Market Depth | Successfully connected. | 2019-07-01 07:11:57.066 SC DTC Data with Market Depth | Trading is not supported. | 2019-07-01 07:11:57.066 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2019-07-01 07:11:57.067 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-SP | 2019-07-01 07:11:57.067 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL-NYSE | 2019-07-01 07:11:57.067 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL-SP | 2019-07-01 07:11:57.067 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2019-07-01 07:11:57.067 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-SP. ID: 20 Service code: statscalc | 2019-07-01 07:11:57.093 SC DTC Data with Market Depth | Requesting security definition data for: TICK-SP. ID: 20 | 2019-07-01 07:11:57.093 Intraday data recording state for symbol TICK-SP is set to download 'Pending'. | 2019-07-01 07:11:57.093 SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2019-07-01 07:11:57.098 SC DTC Data with Market Depth | Received security definition for symbol NISS-SP | 2019-07-01 07:11:57.098 SC DTC Data with Market Depth | Received security definition for symbol NVOL-NYSE | 2019-07-01 07:11:57.098 SC DTC Data with Market Depth | Received security definition for symbol NVOL-SP | 2019-07-01 07:11:57.098 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2019-07-01 07:11:57.098 Requesting market depth updates for: ESU9-CME if supported. | 2019-07-01 07:11:57.124 SC DTC Data with Market Depth | Received security definition for symbol TICK-SP | 2019-07-01 07:11:57.137 Rithmic Trading | Starting real-time market data updates for: ESU9-CM. ID: 21 | 2019-07-01 07:11:57.137 Rithmic Trading | Requesting security definition data for: ESU9-CM. ID: 21 | 2019-07-01 07:11:57.137 Rithmic Trading | Using primary service for historical data for ESU9-CM | 2019-07-01 07:11:57.137 Intraday data recording state for symbol ESU9-CM is set to download 'Pending'. | 2019-07-01 07:11:57.137 Delaying start of download for ESU9-CM | 2019-07-01 07:11:57.137 Opened cached Depth file: E:\SierraChart\Data\MarketDepthData\ESU9-CME.2019-07-01.depth | 2019-07-01 07:11:57.170 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: ESU9-CM | 2019-07-01 07:11:57.170 Symbol Error - ESU9-CM is unknown, unavailable, or improperly formatted. | 2019-07-01 07:11:57.173 HD Request # 59 | Downloading Intraday chart data for ESU9-CM to the file ESU9-CM.scid. Service: rithmic.trading | 2019-07-01 07:11:57.274 HD Request # 59 | Download start date-time: 2019-01-31 06:11:57.000 | 2019-07-01 07:11:57.274 HD Request # 59 | Sending historical data request. Start date-time: 2019-01-31 06:11:57. Record interval: 0. Symbol: ESU9-CM | 2019-07-01 07:11:57.274 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:11:57.277 HD Request # 59 | Error downloading historical Intraday data for ESU9-CM. Error requesting historical Tick data. Error: API_NO_DATA | 2019-07-01 07:11:57.280 HD Request # 59 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESU9-CM | 2019-07-01 07:11:57.280 HD Request # 59 | Completion time: 0s | 2019-07-01 07:11:57.280 HD Request # 59 | Intraday data download complete for ESU9-CM. Unique request ID: 78 | 2019-07-01 07:11:57.280 Removed historical data download ID 78 | 2019-07-01 07:11:57.280 Real-time Intraday chart data file updates started for ESU9-CM | 2019-07-01 07:11:57.280 Intraday chart data file opened for ESU9-CM | 2019-07-01 07:11:57.281 HD Request # 60 | Downloading Intraday chart data for 6JU9-CME to the file 6JU9-CME.scid. Service: cme | 2019-07-01 07:12:01.205 HD Request # 60 | Download start date-time: 2019-07-01 07:10:37.000 | 2019-07-01 07:12:01.205 HD Request # 60 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-07-01 07:12:01.206 Socket (3) | Creating socket. | 2019-07-01 07:12:01.206 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-07-01 07:12:01.206 HD Request # 60 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:01.252 HD Request # 60 | Sending historical data logon request message. | 2019-07-01 07:12:01.252 HD Request # 60 | Requesting Intraday data. Start date-time: 2019-07-01 07:10:37. Record interval: 0. Symbol: 6JU19 | 2019-07-01 07:12:01.276 HD Request # 60 | Decompressing data. | 2019-07-01 07:12:01.293 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:01.293 Historical data download thread signaled to stop. | 2019-07-01 07:12:01.293 HD Request # 60 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6JU9-CME | 2019-07-01 07:12:01.293 HD Request # 60 | Completion time: 0s | 2019-07-01 07:12:01.293 HD Request # 60 | Intraday data download complete for 6JU9-CME. Unique request ID: 59 | 2019-07-01 07:12:01.293 Removed historical data download ID 59 | 2019-07-01 07:12:01.293 Real-time Intraday chart data file updates started for 6JU9-CME | 2019-07-01 07:12:01.293 Intraday chart data file opened for 6JU9-CME | 2019-07-01 07:12:01.293 ZNU9-CBOT 30 Min #42 | Historical data download for additional symbol 6JU9-CME with ID 59 has completed. | 2019-07-01 07:12:01.293 Rithmic Trading | Using primary service for historical data for 6JU9-CME | 2019-07-01 07:12:01.293 Intraday data recording state for symbol 6JU9-CME is set to download 'Pending'. | 2019-07-01 07:12:01.293 HD Request # 61 | Downloading Intraday chart data for 6JU9-CME to the file 6JU9-CME.scid. Service: rithmic.trading | 2019-07-01 07:12:01.294 HD Request # 61 | Download start date-time: 2019-07-01 07:10:37.000 | 2019-07-01 07:12:01.294 HD Request # 61 | Sending historical data request. Start date-time: 2019-07-01 07:10:37. Record interval: 0. Symbol: 6JU9-CME | 2019-07-01 07:12:01.294 HD Request # 62 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: cme | 2019-07-01 07:12:01.294 HD Request # 62 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:01.295 HD Request # 62 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-07-01 07:12:01.295 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:01.295 Socket (4) | Creating socket. | 2019-07-01 07:12:01.295 Socket (4) | Connecting to IP: 8.18.161.135. | 2019-07-01 07:12:01.295 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:01.311 Socket (3) | Closed. | 2019-07-01 07:12:01.311 HD Request # 62 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:01.335 HD Request # 62 | Sending historical data logon request message. | 2019-07-01 07:12:01.335 HD Request # 62 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: NQU19 | 2019-07-01 07:12:01.352 HD Request # 61 | Receiving Intraday data for 6JU9-CME starting at 2019-07-01 07:10:37 | 2019-07-01 07:12:01.426 HD Request # 61 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:06 | 2019-07-01 07:12:01.427 HD Request # 61 | Received 23 records from 2019-07-01 07:10:37.000 to 2019-07-01 07:11:58.000 (81.0 seconds) and wrote 22 records for 6JU9-CME | 2019-07-01 07:12:01.428 HD Request # 61 | Completion time: 0s | 2019-07-01 07:12:01.434 HD Request # 61 | Intraday data download complete for 6JU9-CME. Unique request ID: 79 | 2019-07-01 07:12:01.434 Removed historical data download ID 79 | 2019-07-01 07:12:01.434 Real-time Intraday chart data file updates started for 6JU9-CME | 2019-07-01 07:12:01.434 Intraday chart data file opened for 6JU9-CME | 2019-07-01 07:12:01.434 HD Request # 62 | Decompressing data. | 2019-07-01 07:12:01.492 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:01.492 Socket (4) | Socket gracefully closed by remote side. | 2019-07-01 07:12:01.511 Socket (4) | Closed. | 2019-07-01 07:12:01.511 Historical data download thread signaled to stop. | 2019-07-01 07:12:01.542 HD Request # 62 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NQU9-CME | 2019-07-01 07:12:01.542 HD Request # 62 | Completion time: 0s | 2019-07-01 07:12:01.542 HD Request # 62 | Intraday data download complete for NQU9-CME. Unique request ID: 60 | 2019-07-01 07:12:01.542 Removed historical data download ID 60 | 2019-07-01 07:12:01.542 Real-time Intraday chart data file updates started for NQU9-CME | 2019-07-01 07:12:01.542 Intraday chart data file opened for NQU9-CME | 2019-07-01 07:12:01.542 ZNU9-CBOT 30 Min #42 | Historical data download for additional symbol NQU9-CME with ID 60 has completed. | 2019-07-01 07:12:01.542 Rithmic Trading | Using primary service for historical data for NQU9-CME | 2019-07-01 07:12:01.542 Intraday data recording state for symbol NQU9-CME is set to download 'Pending'. | 2019-07-01 07:12:01.542 HD Request # 63 | Downloading Intraday chart data for NQU9-CME to the file NQU9-CME.scid. Service: rithmic.trading | 2019-07-01 07:12:01.542 HD Request # 63 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:01.543 HD Request # 63 | Sending historical data request. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: NQU9-CME | 2019-07-01 07:12:01.543 HD Request # 64 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: cbot | 2019-07-01 07:12:01.543 HD Request # 64 | Download start date-time: 2019-07-01 07:10:58.000 | 2019-07-01 07:12:01.543 HD Request # 64 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-07-01 07:12:01.544 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:01.544 Socket (3) | Creating socket. | 2019-07-01 07:12:01.544 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-07-01 07:12:01.544 HD Request # 64 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:01.590 HD Request # 64 | Sending historical data logon request message. | 2019-07-01 07:12:01.590 HD Request # 64 | Requesting Intraday data. Start date-time: 2019-07-01 07:10:58. Record interval: 0. Symbol: YMU19 | 2019-07-01 07:12:01.614 HD Request # 64 | Decompressing data. | 2019-07-01 07:12:01.632 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:01.632 Historical data download thread signaled to stop. | 2019-07-01 07:12:01.646 HD Request # 64 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for YMU9-CBOT | 2019-07-01 07:12:01.647 HD Request # 64 | Completion time: 0s | 2019-07-01 07:12:01.647 HD Request # 64 | Intraday data download complete for YMU9-CBOT. Unique request ID: 61 | 2019-07-01 07:12:01.647 Removed historical data download ID 61 | 2019-07-01 07:12:01.647 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-07-01 07:12:01.647 Intraday chart data file opened for YMU9-CBOT | 2019-07-01 07:12:01.647 ZNU9-CBOT 30 Min #42 | Historical data download for additional symbol YMU9-CBOT with ID 61 has completed. | 2019-07-01 07:12:01.647 Rithmic Trading | Using primary service for historical data for YMU9-CBOT | 2019-07-01 07:12:01.647 Intraday data recording state for symbol YMU9-CBOT is set to download 'Pending'. | 2019-07-01 07:12:01.647 HD Request # 63 | Receiving Intraday data for NQU9-CME starting at 2019-07-01 07:11:02 | 2019-07-01 07:12:01.647 HD Request # 63 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:08 | 2019-07-01 07:12:01.648 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:01.648 Socket (3) | Closed. | 2019-07-01 07:12:01.649 HD Request # 63 | Received 98 records from 2019-07-01 07:11:02.000 to 2019-07-01 07:12:00.000 (58.0 seconds) and wrote 95 records for NQU9-CME | 2019-07-01 07:12:01.649 HD Request # 63 | Completion time: 0s | 2019-07-01 07:12:01.655 HD Request # 63 | Intraday data download complete for NQU9-CME. Unique request ID: 80 | 2019-07-01 07:12:01.655 Removed historical data download ID 80 | 2019-07-01 07:12:01.655 Real-time Intraday chart data file updates started for NQU9-CME | 2019-07-01 07:12:01.655 Intraday chart data file opened for NQU9-CME | 2019-07-01 07:12:01.656 HD Request # 65 | Downloading Intraday chart data for YMU9-CBOT to the file YMU9-CBOT.scid. Service: rithmic.trading | 2019-07-01 07:12:01.656 HD Request # 65 | Download start date-time: 2019-07-01 07:10:58.000 | 2019-07-01 07:12:01.656 HD Request # 65 | Sending historical data request. Start date-time: 2019-07-01 07:10:58. Record interval: 0. Symbol: YMU9-CBOT | 2019-07-01 07:12:01.656 HD Request # 66 | Downloading Intraday chart data for RTYU9-CME to the file RTYU9-CME.scid. Service: cme | 2019-07-01 07:12:01.656 HD Request # 66 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:01.656 HD Request # 66 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-07-01 07:12:01.656 Socket (3) | Creating socket. | 2019-07-01 07:12:01.657 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-07-01 07:12:01.657 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:01.672 HD Request # 66 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:01.697 HD Request # 66 | Sending historical data logon request message. | 2019-07-01 07:12:01.697 HD Request # 66 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: RTYU19 | 2019-07-01 07:12:01.714 HD Request # 66 | Decompressing data. | 2019-07-01 07:12:01.731 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:01.731 Historical data download thread signaled to stop. | 2019-07-01 07:12:01.737 HD Request # 66 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for RTYU9-CME | 2019-07-01 07:12:01.737 HD Request # 66 | Completion time: 0s | 2019-07-01 07:12:01.737 HD Request # 66 | Intraday data download complete for RTYU9-CME. Unique request ID: 62 | 2019-07-01 07:12:01.737 Removed historical data download ID 62 | 2019-07-01 07:12:01.737 Real-time Intraday chart data file updates started for RTYU9-CME | 2019-07-01 07:12:01.737 Intraday chart data file opened for RTYU9-CME | 2019-07-01 07:12:01.737 ZNU9-CBOT 30 Min #42 | Historical data download for additional symbol RTYU9-CME with ID 62 has completed. | 2019-07-01 07:12:01.737 Rithmic Trading | Using primary service for historical data for RTYU9-CME | 2019-07-01 07:12:01.737 Intraday data recording state for symbol RTYU9-CME is set to download 'Pending'. | 2019-07-01 07:12:01.737 HD Request # 67 | Downloading Intraday chart data for CLQ9-NYMEX to the file CLQ9-NYMEX.scid. Service: nymex | 2019-07-01 07:12:01.737 HD Request # 67 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:01.738 HD Request # 67 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-07-01 07:12:01.738 Socket (4) | Creating socket. | 2019-07-01 07:12:01.738 Socket (4) | Connecting to IP: 8.18.161.133. | 2019-07-01 07:12:01.738 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:01.748 Socket (3) | Closed. | 2019-07-01 07:12:01.748 HD Request # 65 | Receiving Intraday data for YMU9-CBOT starting at 2019-07-01 07:10:58 | 2019-07-01 07:12:01.772 HD Request # 65 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:09 | 2019-07-01 07:12:01.774 HD Request # 65 | Received 37 records from 2019-07-01 07:10:58.000 to 2019-07-01 07:12:00.000 (62.0 seconds) and wrote 32 records for YMU9-CBOT | 2019-07-01 07:12:01.774 HD Request # 65 | Completion time: 0s | 2019-07-01 07:12:01.781 HD Request # 65 | Intraday data download complete for YMU9-CBOT. Unique request ID: 81 | 2019-07-01 07:12:01.781 Removed historical data download ID 81 | 2019-07-01 07:12:01.781 Real-time Intraday chart data file updates started for YMU9-CBOT | 2019-07-01 07:12:01.781 Intraday chart data file opened for YMU9-CBOT | 2019-07-01 07:12:01.781 HD Request # 68 | Downloading Intraday chart data for RTYU9-CME to the file RTYU9-CME.scid. Service: rithmic.trading | 2019-07-01 07:12:01.781 HD Request # 68 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:01.781 HD Request # 68 | Sending historical data request. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: RTYU9-CME | 2019-07-01 07:12:01.781 HD Request # 67 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:01.783 HD Request # 67 | Sending historical data logon request message. | 2019-07-01 07:12:01.783 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:01.802 HD Request # 67 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: CLQ19 | 2019-07-01 07:12:01.806 HD Request # 67 | Decompressing data. | 2019-07-01 07:12:01.822 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:01.823 Historical data download thread signaled to stop. | 2019-07-01 07:12:01.836 HD Request # 67 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for CLQ9-NYMEX | 2019-07-01 07:12:01.836 HD Request # 67 | Completion time: 0s | 2019-07-01 07:12:01.836 HD Request # 67 | Intraday data download complete for CLQ9-NYMEX. Unique request ID: 63 | 2019-07-01 07:12:01.836 Removed historical data download ID 63 | 2019-07-01 07:12:01.836 Real-time Intraday chart data file updates started for CLQ9-NYMEX | 2019-07-01 07:12:01.836 Intraday chart data file opened for CLQ9-NYMEX | 2019-07-01 07:12:01.836 ZBU9-CBOT 30 Min #18 | Historical data download for additional symbol CLQ9-NYMEX with ID 63 has completed. | 2019-07-01 07:12:01.836 Rithmic Trading | Using primary service for historical data for CLQ9-NYMEX | 2019-07-01 07:12:01.836 Intraday data recording state for symbol CLQ9-NYMEX is set to download 'Pending'. | 2019-07-01 07:12:01.836 HD Request # 69 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: comex | 2019-07-01 07:12:01.836 HD Request # 69 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:01.837 HD Request # 69 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-07-01 07:12:01.837 Socket (3) | Creating socket. | 2019-07-01 07:12:01.837 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-07-01 07:12:01.837 Socket (4) | Socket gracefully closed by remote side. | 2019-07-01 07:12:01.839 Socket (4) | Closed. | 2019-07-01 07:12:01.839 HD Request # 69 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:01.876 HD Request # 69 | Sending historical data logon request message. | 2019-07-01 07:12:01.876 HD Request # 68 | Receiving Intraday data for RTYU9-CME starting at 2019-07-01 07:11:02 | 2019-07-01 07:12:01.892 HD Request # 68 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:09 | 2019-07-01 07:12:01.893 HD Request # 68 | Received 23 records from 2019-07-01 07:11:02.000 to 2019-07-01 07:11:58.000 (56.0 seconds) and wrote 22 records for RTYU9-CME | 2019-07-01 07:12:01.893 HD Request # 69 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: GCQ19 | 2019-07-01 07:12:01.894 HD Request # 68 | Completion time: 0s | 2019-07-01 07:12:01.901 HD Request # 68 | Intraday data download complete for RTYU9-CME. Unique request ID: 82 | 2019-07-01 07:12:01.901 Removed historical data download ID 82 | 2019-07-01 07:12:01.901 Real-time Intraday chart data file updates started for RTYU9-CME | 2019-07-01 07:12:01.901 Intraday chart data file opened for RTYU9-CME | 2019-07-01 07:12:01.901 HD Request # 70 | Downloading Intraday chart data for CLQ9-NYMEX to the file CLQ9-NYMEX.scid. Service: rithmic.trading | 2019-07-01 07:12:01.901 HD Request # 70 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:01.901 HD Request # 70 | Sending historical data request. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: CLQ9-NYMEX | 2019-07-01 07:12:01.901 HD Request # 69 | Decompressing data. | 2019-07-01 07:12:01.912 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:01.912 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:01.918 Historical data download thread signaled to stop. | 2019-07-01 07:12:01.918 HD Request # 69 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GCQ9-COMEX | 2019-07-01 07:12:01.918 HD Request # 69 | Completion time: 0s | 2019-07-01 07:12:01.918 HD Request # 69 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 64 | 2019-07-01 07:12:01.918 Removed historical data download ID 64 | 2019-07-01 07:12:01.918 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-07-01 07:12:01.918 Intraday chart data file opened for GCQ9-COMEX | 2019-07-01 07:12:01.918 ZBU9-CBOT 30 Min #18 | Historical data download for additional symbol GCQ9-COMEX with ID 64 has completed. | 2019-07-01 07:12:01.918 Rithmic Trading | Using primary service for historical data for GCQ9-COMEX | 2019-07-01 07:12:01.918 Intraday data recording state for symbol GCQ9-COMEX is set to download 'Pending'. | 2019-07-01 07:12:01.918 HD Request # 71 | Downloading Intraday chart data for 6EU9-CME to the file 6EU9-CME.scid. Service: cme | 2019-07-01 07:12:01.919 HD Request # 71 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:01.919 HD Request # 71 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-07-01 07:12:01.919 Socket (4) | Creating socket. | 2019-07-01 07:12:01.919 Socket (4) | Connecting to IP: 8.18.161.133. | 2019-07-01 07:12:01.919 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:01.930 Socket (3) | Closed. | 2019-07-01 07:12:01.930 ZNU9-CBOT 30 Min #42 | Reloading chart. | 2019-07-01 07:12:01.953 HD Request # 71 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:01.964 HD Request # 71 | Sending historical data logon request message. | 2019-07-01 07:12:01.964 HD Request # 71 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: 6EU19 | 2019-07-01 07:12:01.987 HD Request # 71 | Decompressing data. | 2019-07-01 07:12:02.004 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:02.004 Historical data download thread signaled to stop. | 2019-07-01 07:12:02.013 HD Request # 71 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6EU9-CME | 2019-07-01 07:12:02.013 HD Request # 71 | Completion time: 1s | 2019-07-01 07:12:02.014 HD Request # 71 | Intraday data download complete for 6EU9-CME. Unique request ID: 65 | 2019-07-01 07:12:02.014 Removed historical data download ID 65 | 2019-07-01 07:12:02.014 Real-time Intraday chart data file updates started for 6EU9-CME | 2019-07-01 07:12:02.014 Intraday chart data file opened for 6EU9-CME | 2019-07-01 07:12:02.014 ZBU9-CBOT 30 Min #18 | Historical data download for additional symbol 6EU9-CME with ID 65 has completed. | 2019-07-01 07:12:02.014 Rithmic Trading | Using primary service for historical data for 6EU9-CME | 2019-07-01 07:12:02.014 Intraday data recording state for symbol 6EU9-CME is set to download 'Pending'. | 2019-07-01 07:12:02.014 HD Request # 70 | Receiving Intraday data for CLQ9-NYMEX starting at 2019-07-01 07:11:02 | 2019-07-01 07:12:02.014 HD Request # 70 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:04 | 2019-07-01 07:12:02.015 HD Request # 70 | Received 154 records from 2019-07-01 07:11:02.000 to 2019-07-01 07:11:58.002 (56.0 seconds) and wrote 153 records for CLQ9-NYMEX | 2019-07-01 07:12:02.015 Socket (4) | Socket gracefully closed by remote side. | 2019-07-01 07:12:02.021 Socket (4) | Closed. | 2019-07-01 07:12:02.022 HD Request # 70 | Completion time: 0s | 2019-07-01 07:12:02.022 HD Request # 70 | Intraday data download complete for CLQ9-NYMEX. Unique request ID: 83 | 2019-07-01 07:12:02.022 Removed historical data download ID 83 | 2019-07-01 07:12:02.022 Real-time Intraday chart data file updates started for CLQ9-NYMEX | 2019-07-01 07:12:02.022 Intraday chart data file opened for CLQ9-NYMEX | 2019-07-01 07:12:02.022 HD Request # 72 | Downloading Intraday chart data for GCQ9-COMEX to the file GCQ9-COMEX.scid. Service: rithmic.trading | 2019-07-01 07:12:02.022 HD Request # 72 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:02.022 HD Request # 72 | Sending historical data request. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: GCQ9-COMEX | 2019-07-01 07:12:02.022 HD Request # 73 | Downloading Intraday chart data for 6BU9-CME to the file 6BU9-CME.scid. Service: cme | 2019-07-01 07:12:02.022 HD Request # 73 | Download start date-time: 2019-07-01 07:10:53.000 | 2019-07-01 07:12:02.023 HD Request # 73 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-07-01 07:12:02.023 Socket (3) | Creating socket. | 2019-07-01 07:12:02.023 Socket (3) | Connecting to IP: 8.18.161.135. | 2019-07-01 07:12:02.023 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:02.027 HD Request # 73 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:02.063 HD Request # 73 | Sending historical data logon request message. | 2019-07-01 07:12:02.063 HD Request # 73 | Requesting Intraday data. Start date-time: 2019-07-01 07:10:53. Record interval: 0. Symbol: 6BU19 | 2019-07-01 07:12:02.080 HD Request # 73 | Decompressing data. | 2019-07-01 07:12:02.097 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:02.097 Historical data download thread signaled to stop. | 2019-07-01 07:12:02.099 HD Request # 73 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for 6BU9-CME | 2019-07-01 07:12:02.099 HD Request # 73 | Completion time: 0s | 2019-07-01 07:12:02.099 HD Request # 73 | Intraday data download complete for 6BU9-CME. Unique request ID: 66 | 2019-07-01 07:12:02.099 Removed historical data download ID 66 | 2019-07-01 07:12:02.099 Real-time Intraday chart data file updates started for 6BU9-CME | 2019-07-01 07:12:02.099 Intraday chart data file opened for 6BU9-CME | 2019-07-01 07:12:02.099 ZBU9-CBOT 30 Min #18 | Historical data download for additional symbol 6BU9-CME with ID 66 has completed. | 2019-07-01 07:12:02.099 Rithmic Trading | Using primary service for historical data for 6BU9-CME | 2019-07-01 07:12:02.099 Intraday data recording state for symbol 6BU9-CME is set to download 'Pending'. | 2019-07-01 07:12:02.099 HD Request # 74 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: cme | 2019-07-01 07:12:02.100 HD Request # 74 | Download start date-time: 2019-07-01 07:11:03.000 | 2019-07-01 07:12:02.100 HD Request # 74 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-07-01 07:12:02.100 Socket (4) | Creating socket. | 2019-07-01 07:12:02.100 Socket (4) | Connecting to IP: 8.18.161.133. | 2019-07-01 07:12:02.100 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:02.115 Socket (3) | Closed. | 2019-07-01 07:12:02.115 HD Request # 72 | Receiving Intraday data for GCQ9-COMEX starting at 2019-07-01 07:11:02 | 2019-07-01 07:12:02.131 HD Request # 72 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:06 | 2019-07-01 07:12:02.132 HD Request # 72 | Received 507 records from 2019-07-01 07:11:02.000 to 2019-07-01 07:12:01.012 (59.0 seconds) and wrote 502 records for GCQ9-COMEX | 2019-07-01 07:12:02.133 HD Request # 72 | Completion time: 0s | 2019-07-01 07:12:02.144 HD Request # 72 | Intraday data download complete for GCQ9-COMEX. Unique request ID: 84 | 2019-07-01 07:12:02.144 Removed historical data download ID 84 | 2019-07-01 07:12:02.144 Real-time Intraday chart data file updates started for GCQ9-COMEX | 2019-07-01 07:12:02.144 Intraday chart data file opened for GCQ9-COMEX | 2019-07-01 07:12:02.144 HD Request # 75 | Downloading Intraday chart data for 6EU9-CME to the file 6EU9-CME.scid. Service: rithmic.trading | 2019-07-01 07:12:02.145 HD Request # 75 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:02.145 HD Request # 75 | Sending historical data request. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: 6EU9-CME | 2019-07-01 07:12:02.145 HD Request # 74 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:02.146 HD Request # 74 | Sending historical data logon request message. | 2019-07-01 07:12:02.147 HD Request # 74 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:03. Record interval: 0. Symbol: ESU19 | 2019-07-01 07:12:02.169 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:02.183 HD Request # 74 | Decompressing data. | 2019-07-01 07:12:02.186 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:02.186 Historical data download thread signaled to stop. | 2019-07-01 07:12:02.204 HD Request # 74 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESU9-CME | 2019-07-01 07:12:02.204 HD Request # 74 | Completion time: 0s | 2019-07-01 07:12:02.204 HD Request # 74 | Intraday data download complete for ESU9-CME. Unique request ID: 67 | 2019-07-01 07:12:02.204 Removed historical data download ID 67 | 2019-07-01 07:12:02.204 Real-time Intraday chart data file updates started for ESU9-CME | 2019-07-01 07:12:02.204 Intraday chart data file opened for ESU9-CME | 2019-07-01 07:12:02.204 Rithmic Trading | Using primary service for historical data for ESU9-CME | 2019-07-01 07:12:02.205 Intraday data recording state for symbol ESU9-CME is set to download 'Pending'. | 2019-07-01 07:12:02.205 HD Request # 76 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2019-07-01 07:12:02.205 HD Request # 76 | Download start date-time: 2019-07-01 07:11:03.000 | 2019-07-01 07:12:02.205 HD Request # 76 | Using server: ds4.sierracharts.com port 10149 | 2019-07-01 07:12:02.205 HD Request # 75 | Receiving Intraday data for 6EU9-CME starting at 2019-07-01 07:11:02 | 2019-07-01 07:12:02.205 Socket (3) | Creating socket. | 2019-07-01 07:12:02.205 Socket (3) | Connecting to IP: 192.81.56.146. | 2019-07-01 07:12:02.205 HD Request # 75 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:05 | 2019-07-01 07:12:02.207 HD Request # 75 | Received 115 records from 2019-07-01 07:11:02.000 to 2019-07-01 07:12:00.001 (58.0 seconds) and wrote 110 records for 6EU9-CME | 2019-07-01 07:12:02.207 Socket (4) | Socket gracefully closed by remote side. | 2019-07-01 07:12:02.208 Socket (4) | Closed. | 2019-07-01 07:12:02.208 HD Request # 75 | Completion time: 0s | 2019-07-01 07:12:02.214 HD Request # 75 | Intraday data download complete for 6EU9-CME. Unique request ID: 85 | 2019-07-01 07:12:02.214 Removed historical data download ID 85 | 2019-07-01 07:12:02.214 Real-time Intraday chart data file updates started for 6EU9-CME | 2019-07-01 07:12:02.214 Intraday chart data file opened for 6EU9-CME | 2019-07-01 07:12:02.214 HD Request # 77 | Downloading Intraday chart data for 6BU9-CME to the file 6BU9-CME.scid. Service: rithmic.trading | 2019-07-01 07:12:02.214 HD Request # 77 | Download start date-time: 2019-07-01 07:10:53.000 | 2019-07-01 07:12:02.214 HD Request # 77 | Sending historical data request. Start date-time: 2019-07-01 07:10:53. Record interval: 0. Symbol: 6BU9-CME | 2019-07-01 07:12:02.214 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:02.218 Opened cached Intraday file: E:\SierraChart\Data\6JU9-CME.scid | 2019-07-01 07:12:02.234 HD Request # 76 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:02.286 HD Request # 76 | Sending historical data logon request message. | 2019-07-01 07:12:02.286 HD Request # 77 | Receiving Intraday data for 6BU9-CME starting at 2019-07-01 07:10:53 | 2019-07-01 07:12:02.320 HD Request # 77 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:20 | 2019-07-01 07:12:02.321 HD Request # 77 | Received 20 records from 2019-07-01 07:10:53.000 to 2019-07-01 07:11:48.006 (55.0 seconds) and wrote 18 records for 6BU9-CME | 2019-07-01 07:12:02.322 HD Request # 77 | Completion time: 0s | 2019-07-01 07:12:02.329 HD Request # 77 | Intraday data download complete for 6BU9-CME. Unique request ID: 86 | 2019-07-01 07:12:02.329 Removed historical data download ID 86 | 2019-07-01 07:12:02.329 Real-time Intraday chart data file updates started for 6BU9-CME | 2019-07-01 07:12:02.329 Intraday chart data file opened for 6BU9-CME | 2019-07-01 07:12:02.329 HD Request # 78 | Downloading Intraday chart data for ESU9-CME to the file ESU9-CME.scid. Service: rithmic.trading | 2019-07-01 07:12:02.329 HD Request # 78 | Download start date-time: 2019-07-01 07:11:03.000 | 2019-07-01 07:12:02.330 HD Request # 78 | Sending historical data request. Start date-time: 2019-07-01 07:11:03. Record interval: 0. Symbol: ESU9-CME | 2019-07-01 07:12:02.330 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:02.333 HD Request # 78 | Receiving Intraday data for ESU9-CME starting at 2019-07-01 07:11:03 | 2019-07-01 07:12:02.451 HD Request # 78 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:05 | 2019-07-01 07:12:02.453 HD Request # 78 | Received 205 records from 2019-07-01 07:11:03.000 to 2019-07-01 07:12:01.000 (58.0 seconds) and wrote 202 records for ESU9-CME | 2019-07-01 07:12:02.453 HD Request # 78 | Completion time: 0s | 2019-07-01 07:12:02.459 HD Request # 78 | Intraday data download complete for ESU9-CME. Unique request ID: 87 | 2019-07-01 07:12:02.459 Removed historical data download ID 87 | 2019-07-01 07:12:02.459 Real-time Intraday chart data file updates started for ESU9-CME | 2019-07-01 07:12:02.459 Intraday chart data file opened for ESU9-CME | 2019-07-01 07:12:02.459 + Loading additional symbol data. | 2019-07-01 07:12:02.486 + Loading additional symbol data. | 2019-07-01 07:12:02.613 HD Request # 76 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:03. Record interval: 0. Symbol: TICK-NYSE | 2019-07-01 07:12:02.802 HD Request # 76 | Decompressing data. | 2019-07-01 07:12:02.828 Chart #5 has tagged chart #9 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:02.828 HD Request # 76 | Receiving Intraday data for TICK-NYSE starting at 2019-07-01 07:11:03 | 2019-07-01 07:12:02.828 HD Request # 76 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:04 | 2019-07-01 07:12:02.830 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:02.830 Historical data download thread signaled to stop. | 2019-07-01 07:12:02.831 HD Request # 76 | Received 58 records from 2019-07-01 07:11:03.000 to 2019-07-01 07:12:00.000 (57.0 seconds) and wrote 57 records for TICK-NYSE | 2019-07-01 07:12:02.831 Added 9 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2019-07-01 07:12:02.838 HD Request # 76 | Completion time: 0s | 2019-07-01 07:12:02.843 HD Request # 76 | Intraday data download complete for TICK-NYSE. Unique request ID: 68 | 2019-07-01 07:12:02.843 Removed historical data download ID 68 | 2019-07-01 07:12:02.843 Real-time Intraday chart data file updates started for TICK-NYSE | 2019-07-01 07:12:02.843 Intraday chart data file opened for TICK-NYSE | 2019-07-01 07:12:02.843 HD Request # 79 | Downloading Intraday chart data for ZNU9-CBOT to the file ZNU9-CBOT.scid. Service: cbot | 2019-07-01 07:12:02.846 HD Request # 79 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:02.847 HD Request # 79 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2019-07-01 07:12:02.847 Socket (4) | Creating socket. | 2019-07-01 07:12:02.847 Socket (4) | Connecting to IP: 8.18.161.135. | 2019-07-01 07:12:02.847 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:02.856 Socket (3) | Closed. | 2019-07-01 07:12:02.856 HD Request # 79 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:02.886 HD Request # 79 | Sending historical data logon request message. | 2019-07-01 07:12:02.886 HD Request # 79 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: ZNU19 | 2019-07-01 07:12:02.903 Chart #20 has tagged chart #3 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:02.934 HD Request # 79 | Decompressing data. | 2019-07-01 07:12:02.974 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:02.974 Historical data download thread signaled to stop. | 2019-07-01 07:12:02.975 HD Request # 79 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZNU9-CBOT | 2019-07-01 07:12:02.975 HD Request # 79 | Completion time: 0s | 2019-07-01 07:12:02.975 HD Request # 79 | Intraday data download complete for ZNU9-CBOT. Unique request ID: 69 | 2019-07-01 07:12:02.975 Removed historical data download ID 69 | 2019-07-01 07:12:02.975 Real-time Intraday chart data file updates started for ZNU9-CBOT | 2019-07-01 07:12:02.975 Intraday chart data file opened for ZNU9-CBOT | 2019-07-01 07:12:02.975 Rithmic Trading | Using primary service for historical data for ZNU9-CBOT | 2019-07-01 07:12:02.975 Intraday data recording state for symbol ZNU9-CBOT is set to download 'Pending'. | 2019-07-01 07:12:02.975 HD Request # 80 | Downloading Intraday chart data for ZNU9-CBOT to the file ZNU9-CBOT.scid. Service: rithmic.trading | 2019-07-01 07:12:02.975 HD Request # 80 | Download start date-time: 2019-07-01 07:11:02.000 | 2019-07-01 07:12:02.975 HD Request # 80 | Sending historical data request. Start date-time: 2019-07-01 07:11:02. Record interval: 0. Symbol: ZNU9-CBOT | 2019-07-01 07:12:02.975 HD Request # 81 | Downloading Intraday chart data for XLK to the file XLK.scid. Service: equities.us | 2019-07-01 07:12:02.975 HD Request # 81 | Download start date-time: 2019-07-01 06:52:20.000 | 2019-07-01 07:12:02.976 HD Request # 81 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2019-07-01 07:12:02.976 Socket (3) | Creating socket. | 2019-07-01 07:12:02.976 Socket (3) | Connecting to IP: 8.18.161.133. | 2019-07-01 07:12:02.977 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:02.979 Socket (4) | Socket gracefully closed by remote side. | 2019-07-01 07:12:02.991 Socket (4) | Closed. | 2019-07-01 07:12:02.991 + Loading additional symbol data. | 2019-07-01 07:12:03.032 HD Request # 81 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:03.032 HD Request # 81 | Sending historical data logon request message. | 2019-07-01 07:12:03.032 HD Request # 81 | Requesting Intraday data. Start date-time: 2019-07-01 06:52:20. Record interval: 0. Symbol: XLK | 2019-07-01 07:12:03.057 HD Request # 80 | Receiving Intraday data for ZNU9-CBOT starting at 2019-07-01 07:11:02 | 2019-07-01 07:12:03.063 HD Request # 80 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:22 | 2019-07-01 07:12:03.064 HD Request # 80 | Received 158 records from 2019-07-01 07:11:02.000 to 2019-07-01 07:12:02.003 (60.0 seconds) and wrote 157 records for ZNU9-CBOT | 2019-07-01 07:12:03.065 HD Request # 80 | Completion time: 0s | 2019-07-01 07:12:03.074 HD Request # 80 | Intraday data download complete for ZNU9-CBOT. Unique request ID: 88 | 2019-07-01 07:12:03.074 Removed historical data download ID 88 | 2019-07-01 07:12:03.074 Real-time Intraday chart data file updates started for ZNU9-CBOT | 2019-07-01 07:12:03.074 Intraday chart data file opened for ZNU9-CBOT | 2019-07-01 07:12:03.074 HD Request # 81 | Decompressing data. | 2019-07-01 07:12:03.074 HD Request # 81 | Receiving Intraday data for XLK starting at 2019-07-01 06:52:20 | 2019-07-01 07:12:03.074 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:03.074 Historical data download thread signaled to stop. | 2019-07-01 07:12:03.077 HD Request # 81 | Received 1 record from 2019-07-01 06:52:20.000 to 2019-07-01 06:52:20.000 (0.0 seconds) and wrote 0 records for XLK | 2019-07-01 07:12:03.077 HD Request # 81 | Completion time: 0s | 2019-07-01 07:12:03.077 HD Request # 81 | Intraday data download complete for XLK. Unique request ID: 70 | 2019-07-01 07:12:03.077 Removed historical data download ID 70 | 2019-07-01 07:12:03.077 Real-time Intraday chart data file updates started for XLK | 2019-07-01 07:12:03.077 Intraday chart data file opened for XLK | 2019-07-01 07:12:03.077 Rithmic Trading | Using primary service for historical data for XLK | 2019-07-01 07:12:03.077 Intraday data recording state for symbol XLK is set to download 'Pending'. | 2019-07-01 07:12:03.077 HD Request # 82 | Downloading Intraday chart data for XLK to the file XLK.scid. Service: equities.us | 2019-07-01 07:12:03.077 HD Request # 82 | Download start date-time: 2019-07-01 06:52:20.000 | 2019-07-01 07:12:03.078 HD Request # 82 | Sending historical data request. Start date-time: 2019-07-01 06:52:20. Record interval: 0. Symbol: XLK | 2019-07-01 07:12:03.078 HD Request # 83 | Downloading Intraday chart data for ESM9-CME to the file ESM9-CME.scid. Service: cme | 2019-07-01 07:12:03.078 HD Request # 83 | Download start date-time: 2019-06-21 08:29:59.000 | 2019-07-01 07:12:03.078 HD Request # 83 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2019-07-01 07:12:03.078 Socket (4) | Creating socket. | 2019-07-01 07:12:03.079 Socket (4) | Connecting to IP: 8.18.161.135. | 2019-07-01 07:12:03.079 HD Request # 82 | Error downloading historical Intraday data for XLK. Historical data request rejected because the symbol is not valid | 2019-07-01 07:12:03.081 HD Request # 82 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for XLK | 2019-07-01 07:12:03.081 HD Request # 82 | Completion time: 0s | 2019-07-01 07:12:03.081 HD Request # 82 | Intraday data download complete for XLK. Unique request ID: 89 | 2019-07-01 07:12:03.081 Removed historical data download ID 89 | 2019-07-01 07:12:03.081 Real-time Intraday chart data file updates started for XLK | 2019-07-01 07:12:03.081 Intraday chart data file opened for XLK | 2019-07-01 07:12:03.081 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:03.092 Socket (3) | Closed. | 2019-07-01 07:12:03.092 HD Request # 83 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:03.119 HD Request # 83 | Sending historical data logon request message. | 2019-07-01 07:12:03.119 HD Request # 83 | Requesting Intraday data. Start date-time: 2019-06-21 08:29:59. Record interval: 0. Symbol: ESM19 | 2019-07-01 07:12:03.136 ZBU9-CBOT 30 Min #18 | Reloading chart. | 2019-07-01 07:12:03.172 ESU9-CME Renko 2t #3 | Performing a full recalculation because it has been tagged. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.204 + Loading additional symbol data. | 2019-07-01 07:12:03.256 Chart #40 has tagged chart #20 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.275 Chart #73 has tagged chart #19 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.324 Chart #73 has tagged chart #3 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.324 Chart #1 has tagged chart #19 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.395 Chart #1 has tagged chart #3 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.395 + Chart Data Loading Thread Stopwatch: 1.4505349369857516 seconds. | 2019-07-01 07:12:03.408 + Loading additional symbol data. | 2019-07-01 07:12:03.418 HD Request # 83 | Decompressing data. | 2019-07-01 07:12:03.473 HD Request # 83 | Receiving Intraday data for ESM9-CME starting at 2019-06-21 08:29:59 | 2019-07-01 07:12:03.473 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:03.474 Historical data download thread signaled to stop. | 2019-07-01 07:12:03.475 HD Request # 83 | Received 1 record from 2019-06-21 08:29:59.000 to 2019-06-21 08:29:59.000 (0.0 seconds) and wrote 0 records for ESM9-CME | 2019-07-01 07:12:03.475 HD Request # 83 | Completion time: 0s | 2019-07-01 07:12:03.476 HD Request # 83 | Intraday data download complete for ESM9-CME. Unique request ID: 71 | 2019-07-01 07:12:03.476 Removed historical data download ID 71 | 2019-07-01 07:12:03.476 Real-time Intraday chart data file updates started for ESM9-CME | 2019-07-01 07:12:03.476 Intraday chart data file opened for ESM9-CME | 2019-07-01 07:12:03.476 Rithmic Trading | Using primary service for historical data for ESM9-CME | 2019-07-01 07:12:03.476 Intraday data recording state for symbol ESM9-CME is set to download 'Pending'. | 2019-07-01 07:12:03.476 HD Request # 84 | Downloading Intraday chart data for ESM9-CME to the file ESM9-CME.scid. Service: rithmic.trading | 2019-07-01 07:12:03.476 HD Request # 84 | Download start date-time: 2019-06-21 08:29:59.000 | 2019-07-01 07:12:03.476 HD Request # 84 | Sending historical data request. Start date-time: 2019-06-21 08:29:59. Record interval: 0. Symbol: ESM9-CME | 2019-07-01 07:12:03.476 HD Request # 85 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2019-07-01 07:12:03.476 HD Request # 85 | Download start date-time: 2019-07-01 07:11:03.000 | 2019-07-01 07:12:03.477 HD Request # 85 | Using server: ds3.sierracharts.com port 10149 | 2019-07-01 07:12:03.477 Socket (3) | Creating socket. | 2019-07-01 07:12:03.478 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:03.478 Socket (3) | Connecting to IP: 65.182.172.42. | 2019-07-01 07:12:03.478 HD Request # 84 | Error downloading historical Intraday data for ESM9-CME. Error requesting historical Tick data. Error: API_NO_DATA | 2019-07-01 07:12:03.481 HD Request # 84 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESM9-CME | 2019-07-01 07:12:03.482 HD Request # 84 | Completion time: 0s | 2019-07-01 07:12:03.482 HD Request # 84 | Intraday data download complete for ESM9-CME. Unique request ID: 90 | 2019-07-01 07:12:03.482 Removed historical data download ID 90 | 2019-07-01 07:12:03.482 Real-time Intraday chart data file updates started for ESM9-CME | 2019-07-01 07:12:03.482 Intraday chart data file opened for ESM9-CME | 2019-07-01 07:12:03.482 Socket (4) | Socket gracefully closed by remote side. | 2019-07-01 07:12:03.490 Socket (4) | Closed. | 2019-07-01 07:12:03.490 Chart #33 has tagged chart #3 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.523 HD Request # 85 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:03.540 HD Request # 85 | Sending historical data logon request message. | 2019-07-01 07:12:03.540 HD Request # 85 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:03. Record interval: 0. Symbol: NISS-NYSE | 2019-07-01 07:12:03.559 HD Request # 85 | Decompressing data. | 2019-07-01 07:12:03.580 HD Request # 85 | Receiving Intraday data for NISS-NYSE starting at 2019-07-01 07:11:03 | 2019-07-01 07:12:03.584 HD Request # 85 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:04 | 2019-07-01 07:12:03.586 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:03.586 Historical data download thread signaled to stop. | 2019-07-01 07:12:03.588 HD Request # 85 | Received 59 records from 2019-07-01 07:11:03.000 to 2019-07-01 07:12:01.000 (58.0 seconds) and wrote 58 records for NISS-NYSE | 2019-07-01 07:12:03.589 Added 8 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2019-07-01 07:12:03.596 HD Request # 85 | Completion time: 0s | 2019-07-01 07:12:03.603 HD Request # 85 | Intraday data download complete for NISS-NYSE. Unique request ID: 72 | 2019-07-01 07:12:03.603 Removed historical data download ID 72 | 2019-07-01 07:12:03.603 Real-time Intraday chart data file updates started for NISS-NYSE | 2019-07-01 07:12:03.603 Intraday chart data file opened for NISS-NYSE | 2019-07-01 07:12:03.604 HD Request # 86 | Downloading Intraday chart data for ZBU9-CBOT to the file ZBU9-CBOT.scid. Service: cbot | 2019-07-01 07:12:03.604 HD Request # 86 | Download start date-time: 2019-07-01 07:10:52.000 | 2019-07-01 07:12:03.604 HD Request # 86 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-07-01 07:12:03.604 Socket (4) | Creating socket. | 2019-07-01 07:12:03.604 Socket (4) | Connecting to IP: 8.18.161.133. | 2019-07-01 07:12:03.605 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:03.606 Socket (3) | Closed. | 2019-07-01 07:12:03.606 ESU9-CME [CB] 15 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.628 Chart: ESU9-CME [CB] 15 Min #9 | Study: StalkZones by @Mike68 | persvars cleared | 2019-07-01 07:12:03.631 Chart #38 has tagged chart #19 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.651 Chart #38 has tagged chart #3 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.651 HD Request # 86 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:03.660 HD Request # 86 | Sending historical data logon request message. | 2019-07-01 07:12:03.660 HD Request # 86 | Requesting Intraday data. Start date-time: 2019-07-01 07:10:52. Record interval: 0. Symbol: ZBU19 | 2019-07-01 07:12:03.684 HD Request # 86 | Decompressing data. | 2019-07-01 07:12:03.702 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:03.702 Historical data download thread signaled to stop. | 2019-07-01 07:12:03.704 HD Request # 86 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZBU9-CBOT | 2019-07-01 07:12:03.704 HD Request # 86 | Completion time: 0s | 2019-07-01 07:12:03.704 HD Request # 86 | Intraday data download complete for ZBU9-CBOT. Unique request ID: 73 | 2019-07-01 07:12:03.704 Removed historical data download ID 73 | 2019-07-01 07:12:03.704 Real-time Intraday chart data file updates started for ZBU9-CBOT | 2019-07-01 07:12:03.704 Intraday chart data file opened for ZBU9-CBOT | 2019-07-01 07:12:03.704 Rithmic Trading | Using primary service for historical data for ZBU9-CBOT | 2019-07-01 07:12:03.704 Intraday data recording state for symbol ZBU9-CBOT is set to download 'Pending'. | 2019-07-01 07:12:03.704 HD Request # 87 | Downloading Intraday chart data for ZBU9-CBOT to the file ZBU9-CBOT.scid. Service: rithmic.trading | 2019-07-01 07:12:03.704 HD Request # 87 | Download start date-time: 2019-07-01 07:10:52.000 | 2019-07-01 07:12:03.705 HD Request # 87 | Sending historical data request. Start date-time: 2019-07-01 07:10:52. Record interval: 0. Symbol: ZBU9-CBOT | 2019-07-01 07:12:03.705 HD Request # 88 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2019-07-01 07:12:03.705 HD Request # 88 | Download start date-time: 2019-07-01 07:11:03.000 | 2019-07-01 07:12:03.705 HD Request # 88 | Using server: ds4.sierracharts.com port 10149 | 2019-07-01 07:12:03.705 Socket (3) | Creating socket. | 2019-07-01 07:12:03.706 Socket (3) | Connecting to IP: 192.81.56.146. | 2019-07-01 07:12:03.706 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-07-01 07:12:03.709 Socket (4) | Socket gracefully closed by remote side. | 2019-07-01 07:12:03.719 Socket (4) | Closed. | 2019-07-01 07:12:03.719 HD Request # 88 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:03.768 HD Request # 88 | Sending historical data logon request message. | 2019-07-01 07:12:03.768 HD Request # 87 | Receiving Intraday data for ZBU9-CBOT starting at 2019-07-01 07:10:52 | 2019-07-01 07:12:03.770 HD Request # 87 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:22 | 2019-07-01 07:12:03.772 HD Request # 87 | Received 45 records from 2019-07-01 07:10:52.000 to 2019-07-01 07:11:45.020 (53.0 seconds) and wrote 44 records for ZBU9-CBOT | 2019-07-01 07:12:03.772 HD Request # 87 | Completion time: 0s | 2019-07-01 07:12:03.781 HD Request # 87 | Intraday data download complete for ZBU9-CBOT. Unique request ID: 91 | 2019-07-01 07:12:03.781 Removed historical data download ID 91 | 2019-07-01 07:12:03.781 Real-time Intraday chart data file updates started for ZBU9-CBOT | 2019-07-01 07:12:03.781 Intraday chart data file opened for ZBU9-CBOT | 2019-07-01 07:12:03.781 ESU9-CME Point & Figure 1-7 #19 | Performing a full recalculation because it has been tagged. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.796 HD Request # 88 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:03. Record interval: 0. Symbol: NISS-SP | 2019-07-01 07:12:03.805 ESU9-CME [CV] 15 Min #20 | Performing a full recalculation because it has been tagged. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.822 Chart: ESU9-CME [CV] 15 Min #20 | Study: StalkZones by @Mike68 | persvars cleared | 2019-07-01 07:12:03.823 Chart #20 has tagged chart #3 for full recalculation. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:03.823 HD Request # 88 | Decompressing data. | 2019-07-01 07:12:03.831 HD Request # 88 | Receiving Intraday data for NISS-SP starting at 2019-07-01 07:11:03 | 2019-07-01 07:12:03.831 HD Request # 88 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:04 | 2019-07-01 07:12:03.832 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:03.832 Historical data download thread signaled to stop. | 2019-07-01 07:12:03.839 HD Request # 88 | Received 60 records from 2019-07-01 07:11:03.000 to 2019-07-01 07:12:02.000 (59.0 seconds) and wrote 59 records for NISS-SP | 2019-07-01 07:12:03.840 Added 5 Time and Sales records to Intraday data file for NISS-SP after download. | 2019-07-01 07:12:03.851 HD Request # 88 | Completion time: 0s | 2019-07-01 07:12:03.858 HD Request # 88 | Intraday data download complete for NISS-SP. Unique request ID: 74 | 2019-07-01 07:12:03.858 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:03.858 Removed historical data download ID 74 | 2019-07-01 07:12:03.858 Real-time Intraday chart data file updates started for NISS-SP | 2019-07-01 07:12:03.858 Intraday chart data file opened for NISS-SP | 2019-07-01 07:12:03.858 Socket (3) | Closed. | 2019-07-01 07:12:03.858 HD Request # 89 | Downloading Intraday chart data for NVOL-NYSE to the file NVOL-NYSE.scid. Service: statscalc | 2019-07-01 07:12:03.858 HD Request # 89 | Download start date-time: 2019-06-28 15:30:00.000 | 2019-07-01 07:12:03.859 HD Request # 89 | Using server: ds3.sierracharts.com port 10150 | 2019-07-01 07:12:03.859 Socket (3) | Creating socket. | 2019-07-01 07:12:03.859 Socket (3) | Connecting to IP: 65.182.172.42. | 2019-07-01 07:12:03.859 HD Request # 89 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:03.921 HD Request # 89 | Sending historical data logon request message. | 2019-07-01 07:12:03.922 HD Request # 89 | Requesting Intraday data. Start date-time: 2019-06-28 15:30:00. Record interval: 0. Symbol: NVOL-NYSE | 2019-07-01 07:12:03.944 HD Request # 89 | Decompressing data. | 2019-07-01 07:12:03.966 HD Request # 89 | Receiving Intraday data for NVOL-NYSE starting at 2019-06-28 15:30:00 | 2019-07-01 07:12:03.966 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:03.966 Historical data download thread signaled to stop. | 2019-07-01 07:12:03.968 HD Request # 89 | Received 1 record from 2019-06-28 15:30:00.000 to 2019-06-28 15:30:00.000 (0.0 seconds) and wrote 0 records for NVOL-NYSE | 2019-07-01 07:12:03.968 HD Request # 89 | Completion time: 0s | 2019-07-01 07:12:03.969 HD Request # 89 | Intraday data download complete for NVOL-NYSE. Unique request ID: 75 | 2019-07-01 07:12:03.969 Removed historical data download ID 75 | 2019-07-01 07:12:03.969 Real-time Intraday chart data file updates started for NVOL-NYSE | 2019-07-01 07:12:03.969 Intraday chart data file opened for NVOL-NYSE | 2019-07-01 07:12:03.969 HD Request # 90 | Downloading Intraday chart data for NVOL-SP to the file NVOL-SP.scid. Service: statscalc | 2019-07-01 07:12:03.969 HD Request # 90 | Download start date-time: 2019-06-28 15:30:00.000 | 2019-07-01 07:12:03.970 HD Request # 90 | Using server: ds4.sierracharts.com port 10149 | 2019-07-01 07:12:03.970 Socket (4) | Creating socket. | 2019-07-01 07:12:03.970 Socket (4) | Connecting to IP: 192.81.56.146. | 2019-07-01 07:12:03.970 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:03.989 Socket (3) | Closed. | 2019-07-01 07:12:03.989 + Loading additional symbol data. | 2019-07-01 07:12:04.012 HD Request # 90 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:04.033 HD Request # 90 | Sending historical data logon request message. | 2019-07-01 07:12:04.033 HD Request # 90 | Requesting Intraday data. Start date-time: 2019-06-28 15:30:00. Record interval: 0. Symbol: NVOL-SP | 2019-07-01 07:12:04.070 ESU9-CME Renko 2t #3 | Performing a full recalculation because it has been tagged. Chartbook: MyWorkSpace-3-24-19.Cht | 2019-07-01 07:12:04.095 HD Request # 90 | Decompressing data. | 2019-07-01 07:12:04.096 HD Request # 90 | Receiving Intraday data for NVOL-SP starting at 2019-06-28 15:30:00 | 2019-07-01 07:12:04.096 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:04.096 Socket (4) | Socket gracefully closed by remote side. | 2019-07-01 07:12:04.121 Socket (4) | Closed. | 2019-07-01 07:12:04.121 Historical data download thread signaled to stop. | 2019-07-01 07:12:04.161 HD Request # 90 | Received 1 record from 2019-06-28 15:30:00.000 to 2019-06-28 15:30:00.000 (0.0 seconds) and wrote 0 records for NVOL-SP | 2019-07-01 07:12:04.161 HD Request # 90 | Completion time: 1s | 2019-07-01 07:12:04.162 HD Request # 90 | Intraday data download complete for NVOL-SP. Unique request ID: 76 | 2019-07-01 07:12:04.162 Removed historical data download ID 76 | 2019-07-01 07:12:04.162 Real-time Intraday chart data file updates started for NVOL-SP | 2019-07-01 07:12:04.162 Intraday chart data file opened for NVOL-SP | 2019-07-01 07:12:04.162 HD Request # 91 | Downloading Intraday chart data for TICK-SP to the file TICK-SP.scid. Service: statscalc | 2019-07-01 07:12:04.162 HD Request # 91 | Download start date-time: 2019-07-01 07:11:03.000 | 2019-07-01 07:12:04.162 HD Request # 91 | Using server: ds3.sierracharts.com port 10150 | 2019-07-01 07:12:04.162 Socket (3) | Creating socket. | 2019-07-01 07:12:04.162 Socket (3) | Connecting to IP: 65.182.172.42. | 2019-07-01 07:12:04.162 HD Request # 91 | Setting DTC encoding to Binary VLS | 2019-07-01 07:12:04.220 HD Request # 91 | Sending historical data logon request message. | 2019-07-01 07:12:04.220 HD Request # 91 | Requesting Intraday data. Start date-time: 2019-07-01 07:11:03. Record interval: 0. Symbol: TICK-SP | 2019-07-01 07:12:04.239 HD Request # 91 | Decompressing data. | 2019-07-01 07:12:04.259 HD Request # 91 | Receiving Intraday data for TICK-SP starting at 2019-07-01 07:11:03 | 2019-07-01 07:12:04.260 HD Request # 91 | Timestamp of first Intraday data file record written: 2019-07-01 07:11:04 | 2019-07-01 07:12:04.261 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-07-01 07:12:04.261 Socket (3) | Socket gracefully closed by remote side. | 2019-07-01 07:12:04.281 Socket (3) | Closed. | 2019-07-01 07:12:04.281 Historical data download thread signaled to stop. | 2019-07-01 07:12:04.281 HD Request # 91 | Received 61 records from 2019-07-01 07:11:03.000 to 2019-07-01 07:12:03.000 (60.0 seconds) and wrote 60 records for TICK-SP | 2019-07-01 07:12:04.282 Added 3 Time and Sales records to Intraday data file for TICK-SP after download. | 2019-07-01 07:12:04.288 HD Request # 91 | Completion time: 0s | 2019-07-01 07:12:04.293 HD Request # 91 | Intraday data download complete for TICK-SP. Unique request ID: 77 | 2019-07-01 07:12:04.293 Removed historical data download ID 77 | 2019-07-01 07:12:04.293 Real-time Intraday chart data file updates started for TICK-SP | 2019-07-01 07:12:04.293 Intraday chart data file opened for TICK-SP | 2019-07-01 07:12:04.293 + Loading additional symbol data. | 2019-07-01 07:12:04.486 + Loading additional symbol data. | 2019-07-01 07:12:04.656 + Chart Data Loading Thread Stopwatch: 1.5497461920000986 seconds. | 2019-07-01 07:12:04.726 Opened cached Intraday file: E:\SierraChart\Data\NQU9-CME.scid | 2019-07-01 07:12:05.234 Opened cached Intraday file: E:\SierraChart\Data\GCQ9-COMEX.scid | 2019-07-01 07:12:05.234 Opened cached Intraday file: E:\SierraChart\Data\6EU9-CME.scid | 2019-07-01 07:12:05.234 Opened cached Intraday file: E:\SierraChart\Data\ESU9-CME.scid | 2019-07-01 07:12:05.234 Opened cached Intraday file: E:\SierraChart\Data\TICK-NYSE.scid | 2019-07-01 07:12:05.234 Opened cached Intraday file: E:\SierraChart\Data\NISS-NYSE.scid | 2019-07-01 07:12:05.235 Opened cached Intraday file: E:\SierraChart\Data\NISS-SP.scid | 2019-07-01 07:12:05.235 Opened cached Intraday file: E:\SierraChart\Data\TICK-SP.scid | 2019-07-01 07:12:05.235 Opened cached Intraday file: E:\SierraChart\Data\RTYU9-CME.scid | 2019-07-01 07:12:08.235 Opened cached Intraday file: E:\SierraChart\Data\CLQ9-NYMEX.scid | 2019-07-01 07:12:08.235 Opened cached Intraday file: E:\SierraChart\Data\YMU9-CBOT.scid | 2019-07-01 07:12:14.235 Opened cached Intraday file: E:\SierraChart\Data\6BU9-CME.scid | 2019-07-01 07:12:14.235 Opened cached Intraday file: E:\SierraChart\Data\ZNU9-CBOT.scid | 2019-07-01 07:12:14.236 Opened cached Intraday file: E:\SierraChart\Data\ZBU9-CBOT.scid | 2019-07-01 07:12:26.236 |
[2019-07-01 13:36:33] |
You are connecting to a paper trading account: Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2019-07-01 07:11:53.954 Do you have a live funded trading account? The CME requires that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-01 13:36:52
[2019-07-01 14:21:05] |
User629089 - Posts: 93 |
Hi, Yes, I do have a live trading account but was in Sim. I'm live now and the "[M]" has appeared so it's looking OK. I think I'm good now. Thanks for your help... |
[2019-07-01 14:26:16] |
Ok good. You just need to connect once a month to your trading account. You can go back to Sim if you want right now.
