Date/Time: Sun, 05 May 2024 01:27:28 +0000
Historial Data Only Going Back to 2017 on Package 5
View Count: 772
[2018-12-22 01:45:57] |
cmet - Posts: 537 |
Since the latest roll in CME equity products, I am no longer able to pull historical data on any Historical Charts. Daily, Weekly, Monthly, Quarterly, etc. I have Package 5 and thought the CME data went back to 2011. Am I missing something? I've never experienced this problem before in the many years I've used this platform. I've tried with and without continuous contracts, setting days to load really high, nothing works. Any reason why this would suddenly happen? |
[2018-12-22 02:25:38] |
Might be a symbol settings issue. You might be using the wrong symbol. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that re-download the data in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-22 02:50:44] |
cmet - Posts: 537 |
That wouldn't be it. On CQG with auto roll. F.US.EPH19 is the current contract. Nothing works. Port 80, manually deleting all data files and re-downloading This problem has never occurred before. Only after latest roll and upgrade to version 1850 (on 1853 now, no change) Isn't SC Historical Data supposed to merge with with broker data. Only getting one year and that's what CQG gives you. From Message Log: HD Request # 17 | Received 258 records from 2017-12-13 00:00:00 to 2018-12-21 00:00:00 (374.0 days) and wrote 258 records for ES-201903-CME | 2018-12-21 18:56:28 2017-12-13 is as far back as it goes for all Historical Data for the SC symbol Date Time Of Last Edit: 2018-12-22 02:58:59
[2018-12-22 03:14:04] |
The symbol we see in that Message Log is the wrong symbol. Make sure you are using the right symbols. Refer to help topic 1.3: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#Symbols Make sure you are using the right symbols and then follow the instructions here: Continuous Futures Contract Charts And then re-download the data following these instructions: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Do not do anything nonstandard. Just follow our instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-22 13:54:00] |
cmet - Posts: 537 |
I am using the right symbols. All my charts are using F.US.EPH19. ES-201903-CME was just for an example. ESH19 produces no historical data. Those are all the ES symbols listed. I have already deleted/downloaded data for all symbols. It's the same issue every time. Data only goes back to 12/17. If I choose Continuous Contract > Date Rollover, I only get the current contract on a Daily Historical Chart. I didn't change a single thing on my charts. The full data set was there before the roll to F.US.EPH19. This is happening for every CME symbol by the way, not just ES. Which brings me to the next question, did you change Sierra Chart Historical Data Symbols or the way in which they integrate with broker data feeds? Attached are the two symbol settings for ES: Date Time Of Last Edit: 2018-12-22 14:18:46
cqg_symbol.PNG / V - Attached On 2018-12-22 14:18:36 UTC - Size: 13.64 KB - 268 views sc_symbol.PNG / V - Attached On 2018-12-22 14:18:39 UTC - Size: 6.52 KB - 270 views |
[2018-12-22 20:57:03] |
There is no need for all of this information. We just simply need to know that there is missing data and you can post an image of the chart following the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image ---- Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and following these procedures here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Follow those procedures step-by-step. Do not skip any step including optional steps. After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-22 21:58:28] |
cmet - Posts: 537 |
It's a problem with your historical data symbols. I'll try to do the rest of that today. For now, when I use the instructions to "delete and re-download historical data", I get a list of ES contract symbols. They are in the image below. However, when I go to download the data, the Message Log is telling me that those symbols don't exist. Symbol Error - ESU17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 13:46:21 HD Request # 31 | Downloading Historical Daily chart data for ESZ17. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 13:46:21 CQG FIX Trading | Sending symbol resolution request for ESZ17. ID: 793199 | 2018-12-22 13:46:21 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 13:46:21 HD Request # 31 | Error downloading historical Daily data for ESZ17. Requested symbol was not found. | 2018-12-22 13:46:21 HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ17 | 2018-12-22 13:46:21 HD Request # 31 | Completion time: 0s | 2018-12-22 13:46:21 HD Request # 31 | Daily data download complete for ESZ17. Unique request ID: 28 | 2018-12-22 13:46:21 Removed historical data download ID 28 | 2018-12-22 13:46:21 Symbol Error - ESZ17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 13:46:21 HD Request # 32 | Downloading Historical Daily chart data for ESH18. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 13:46:21 CQG FIX Trading | Sending symbol resolution request for ESH18. ID: 793200 | 2018-12-22 13:46:21 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 13:46:21 HD Request # 32 | Error downloading historical Daily data for ESH18. Requested symbol was not found. | 2018-12-22 13:46:21 HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH18 | 2018-12-22 13:46:21 HD Request # 32 | Completion time: 0s | 2018-12-22 13:46:21 HD Request # 32 | Daily data download complete for ESH18. Unique request ID: 29 | 2018-12-22 13:46:21 Removed historical data download ID 29 | 2018-12-22 13:46:21 Symbol Error - ESH18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 13:46:21 HD Request # 33 | Downloading Historical Daily chart data for ESM18. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 13:46:21 HD Request # 33 | Error downloading historical Daily data for ESM18. The symbol is unknown to the server. | 2018-12-22 13:46:21 HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM18 | 2018-12-22 13:46:21 HD Request # 33 | Completion time: 0s | 2018-12-22 13:46:21 HD Request # 33 | Daily data download complete for ESM18. Unique request ID: 30 | 2018-12-22 13:46:21 Removed historical data download ID 30 | 2018-12-22 13:46:21 |
symbols.PNG / V - Attached On 2018-12-22 21:57:44 UTC - Size: 12.51 KB - 257 views |
[2018-12-22 22:12:35] |
We are declining further support because our instructions are not getting followed. There is no point in helping when users do not follow our instructions. This functionality works perfect but you need to use the proper symbol which in this case is the CQG symbol and you need to follow our instructions including the documented instructions and you need to provide the information requested. You are doing things your own way. Do not post here further again if you do not follow our instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-22 22:14:03
[2018-12-22 22:14:03] |
cmet - Posts: 537 |
http://www.sierrachart.com/image.php?Image=1545516549918.png Software version: 1853 64-bit | 2018-12-22 14:11:33 Usage end date: 2019-01-28 | 2018-12-22 14:11:33 Enabled for: Advanced Features. | 2018-12-22 14:11:33 Enabled for: Advanced Features 2. | 2018-12-22 14:11:33 Enabled for: Sierra Chart Historical Data Service. | 2018-12-22 14:11:33 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-12-22 14:11:33 Current selected Data/Trading service: CQG FIX Trading | 2018-12-22 14:11:33 Chart Update Interval: 75 | 2018-12-22 14:11:33 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-12-22 14:11:33 2018-12-22 14:11:32 Local computer time | 2018-12-22 14:11:33 2018-12-22 22:11:32 Local computer time in UTC | 2018-12-22 14:11:33 2018-12-22 14:11:32 Local computer time in SC Time Zone | 2018-12-22 14:11:33 2018-12-22 13:45:54 Server time in UTC | 2018-12-22 14:11:33 Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-12-22 14:11:33 Program path: C:\SierraChart\ | 2018-12-22 14:11:33 Data Files path: C:\SierraChart\Data\ | 2018-12-22 14:11:33 OS Version Number: 10.0 | 2018-12-22 14:11:33 Locale Setting: C | 2018-12-22 14:11:33 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2018-12-22 14:11:33 CQG FIX Trading | Using primary service for historical data for ESZ13 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESH14 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESM14 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESU14 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESZ14 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESH15 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESM15 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESU15 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESZ15 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESH16 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESM16 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESU16 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESZ16 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESH17 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESM17 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESU17 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESZ17 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESH18 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESM18 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESU18 | 2018-12-22 14:12:18 CQG FIX Trading | Using primary service for historical data for ESZ18 | 2018-12-22 14:12:18 HD Request # 36 | Downloading Historical Daily chart data for ESZ13. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:18 CQG FIX Trading | Sending symbol resolution request for ESZ13. ID: 793201 | 2018-12-22 14:12:18 HD Request # 37 | Downloading Historical Daily chart data for F.US.EPH19. Starting date: 1968-12-22. Service: cqg | 2018-12-22 14:12:18 HD Request # 37 | Requesting historical Daily data for ESH19 starting at 1968-12-21 | 2018-12-22 14:12:18 HTTPS historicaldata.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-12-22 14:12:18 HTTPS historicaldata.sierrachart.com:443 (2) | Connecting to IP: 46.4.97.203. | 2018-12-22 14:12:18 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 36 | Error downloading historical Daily data for ESZ13. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 36 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ13 | 2018-12-22 14:12:18 HD Request # 36 | Completion time: 0s | 2018-12-22 14:12:18 HD Request # 36 | Daily data download complete for ESZ13. Unique request ID: 34 | 2018-12-22 14:12:18 Removed historical data download ID 34 | 2018-12-22 14:12:18 Symbol Error - ESZ13 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 38 | Downloading Historical Daily chart data for ESH14. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:18 CQG FIX Trading | Sending symbol resolution request for ESH14. ID: 793202 | 2018-12-22 14:12:18 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 38 | Error downloading historical Daily data for ESH14. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 38 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH14 | 2018-12-22 14:12:18 HD Request # 38 | Completion time: 0s | 2018-12-22 14:12:18 HD Request # 38 | Daily data download complete for ESH14. Unique request ID: 35 | 2018-12-22 14:12:18 Removed historical data download ID 35 | 2018-12-22 14:12:18 Symbol Error - ESH14 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 39 | Downloading Historical Daily chart data for ESM14. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:18 CQG FIX Trading | Sending symbol resolution request for ESM14. ID: 793203 | 2018-12-22 14:12:18 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 39 | Error downloading historical Daily data for ESM14. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 39 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM14 | 2018-12-22 14:12:18 HD Request # 39 | Completion time: 0s | 2018-12-22 14:12:18 HD Request # 39 | Daily data download complete for ESM14. Unique request ID: 36 | 2018-12-22 14:12:18 Removed historical data download ID 36 | 2018-12-22 14:12:18 Symbol Error - ESM14 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 40 | Downloading Historical Daily chart data for ESU14. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:18 CQG FIX Trading | Sending symbol resolution request for ESU14. ID: 793204 | 2018-12-22 14:12:18 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 40 | Error downloading historical Daily data for ESU14. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 40 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU14 | 2018-12-22 14:12:18 HD Request # 40 | Completion time: 0s | 2018-12-22 14:12:18 HD Request # 40 | Daily data download complete for ESU14. Unique request ID: 37 | 2018-12-22 14:12:18 Removed historical data download ID 37 | 2018-12-22 14:12:18 Symbol Error - ESU14 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 41 | Downloading Historical Daily chart data for ESZ14. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:18 CQG FIX Trading | Sending symbol resolution request for ESZ14. ID: 793205 | 2018-12-22 14:12:18 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 41 | Error downloading historical Daily data for ESZ14. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 41 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ14 | 2018-12-22 14:12:18 HD Request # 41 | Completion time: 0s | 2018-12-22 14:12:18 HD Request # 41 | Daily data download complete for ESZ14. Unique request ID: 38 | 2018-12-22 14:12:18 Removed historical data download ID 38 | 2018-12-22 14:12:18 Symbol Error - ESZ14 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 14:12:18 HD Request # 42 | Downloading Historical Daily chart data for ESH15. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:18 CQG FIX Trading | Sending symbol resolution request for ESH15. ID: 793206 | 2018-12-22 14:12:18 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 14:12:19 HD Request # 42 | Error downloading historical Daily data for ESH15. Requested symbol was not found. | 2018-12-22 14:12:19 HD Request # 42 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH15 | 2018-12-22 14:12:19 HD Request # 42 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 42 | Daily data download complete for ESH15. Unique request ID: 39 | 2018-12-22 14:12:19 Removed historical data download ID 39 | 2018-12-22 14:12:19 Symbol Error - ESH15 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 14:12:19 HD Request # 43 | Downloading Historical Daily chart data for ESM15. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 CQG FIX Trading | Sending symbol resolution request for ESM15. ID: 793207 | 2018-12-22 14:12:19 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 14:12:19 HD Request # 43 | Error downloading historical Daily data for ESM15. Requested symbol was not found. | 2018-12-22 14:12:19 HD Request # 43 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM15 | 2018-12-22 14:12:19 HD Request # 43 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 43 | Daily data download complete for ESM15. Unique request ID: 40 | 2018-12-22 14:12:19 Removed historical data download ID 40 | 2018-12-22 14:12:19 Symbol Error - ESM15 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 14:12:19 HD Request # 44 | Downloading Historical Daily chart data for ESU15. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 CQG FIX Trading | Sending symbol resolution request for ESU15. ID: 793208 | 2018-12-22 14:12:19 CQG FIX Trading | Received message: Requested symbol was not found. | 2018-12-22 14:12:19 HD Request # 44 | Error downloading historical Daily data for ESU15. Requested symbol was not found. | 2018-12-22 14:12:19 HD Request # 44 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU15 | 2018-12-22 14:12:19 HD Request # 44 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 44 | Daily data download complete for ESU15. Unique request ID: 41 | 2018-12-22 14:12:19 Removed historical data download ID 41 | 2018-12-22 14:12:19 Symbol Error - ESU15 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2018-12-22 14:12:19 HD Request # 45 | Downloading Historical Daily chart data for ESZ15. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 45 | Error downloading historical Daily data for ESZ15. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 45 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ15 | 2018-12-22 14:12:19 HD Request # 45 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 45 | Daily data download complete for ESZ15. Unique request ID: 42 | 2018-12-22 14:12:19 Removed historical data download ID 42 | 2018-12-22 14:12:19 HD Request # 46 | Downloading Historical Daily chart data for ESH16. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 46 | Error downloading historical Daily data for ESH16. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 46 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH16 | 2018-12-22 14:12:19 HD Request # 46 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 46 | Daily data download complete for ESH16. Unique request ID: 43 | 2018-12-22 14:12:19 Removed historical data download ID 43 | 2018-12-22 14:12:19 HD Request # 47 | Downloading Historical Daily chart data for ESM16. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 47 | Error downloading historical Daily data for ESM16. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 47 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM16 | 2018-12-22 14:12:19 HD Request # 47 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 47 | Daily data download complete for ESM16. Unique request ID: 44 | 2018-12-22 14:12:19 Removed historical data download ID 44 | 2018-12-22 14:12:19 HD Request # 48 | Downloading Historical Daily chart data for ESU16. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 48 | Error downloading historical Daily data for ESU16. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 48 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU16 | 2018-12-22 14:12:19 HD Request # 48 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 48 | Daily data download complete for ESU16. Unique request ID: 45 | 2018-12-22 14:12:19 Removed historical data download ID 45 | 2018-12-22 14:12:19 HD Request # 49 | Downloading Historical Daily chart data for ESZ16. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 49 | Error downloading historical Daily data for ESZ16. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 49 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ16 | 2018-12-22 14:12:19 HD Request # 49 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 49 | Daily data download complete for ESZ16. Unique request ID: 46 | 2018-12-22 14:12:19 Removed historical data download ID 46 | 2018-12-22 14:12:19 HD Request # 50 | Downloading Historical Daily chart data for ESH17. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 50 | Error downloading historical Daily data for ESH17. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 50 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH17 | 2018-12-22 14:12:19 HD Request # 50 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 50 | Daily data download complete for ESH17. Unique request ID: 47 | 2018-12-22 14:12:19 Removed historical data download ID 47 | 2018-12-22 14:12:19 HD Request # 51 | Downloading Historical Daily chart data for ESM17. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 51 | Error downloading historical Daily data for ESM17. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 51 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM17 | 2018-12-22 14:12:19 HD Request # 51 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 51 | Daily data download complete for ESM17. Unique request ID: 48 | 2018-12-22 14:12:19 Removed historical data download ID 48 | 2018-12-22 14:12:19 HD Request # 52 | Downloading Historical Daily chart data for ESU17. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 52 | Error downloading historical Daily data for ESU17. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 52 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU17 | 2018-12-22 14:12:19 HD Request # 52 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 52 | Daily data download complete for ESU17. Unique request ID: 49 | 2018-12-22 14:12:19 Removed historical data download ID 49 | 2018-12-22 14:12:19 HD Request # 53 | Downloading Historical Daily chart data for ESZ17. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 53 | Error downloading historical Daily data for ESZ17. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 53 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ17 | 2018-12-22 14:12:19 HD Request # 53 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 53 | Daily data download complete for ESZ17. Unique request ID: 50 | 2018-12-22 14:12:19 Removed historical data download ID 50 | 2018-12-22 14:12:19 HD Request # 54 | Downloading Historical Daily chart data for ESH18. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 54 | Error downloading historical Daily data for ESH18. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 54 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH18 | 2018-12-22 14:12:19 HD Request # 54 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 54 | Daily data download complete for ESH18. Unique request ID: 51 | 2018-12-22 14:12:19 Removed historical data download ID 51 | 2018-12-22 14:12:19 HD Request # 55 | Downloading Historical Daily chart data for ESM18. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 55 | Error downloading historical Daily data for ESM18. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 55 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM18 | 2018-12-22 14:12:19 HD Request # 55 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 55 | Daily data download complete for ESM18. Unique request ID: 52 | 2018-12-22 14:12:19 Removed historical data download ID 52 | 2018-12-22 14:12:19 HD Request # 56 | Downloading Historical Daily chart data for ESU18. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 56 | Error downloading historical Daily data for ESU18. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 56 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU18 | 2018-12-22 14:12:19 HD Request # 56 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 56 | Daily data download complete for ESU18. Unique request ID: 53 | 2018-12-22 14:12:19 Removed historical data download ID 53 | 2018-12-22 14:12:19 HD Request # 57 | Downloading Historical Daily chart data for ESZ18. Starting date: 1968-12-22. Service: cqgfix | 2018-12-22 14:12:19 HD Request # 57 | Error downloading historical Daily data for ESZ18. The symbol is unknown to the server. | 2018-12-22 14:12:19 HD Request # 57 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ18 | 2018-12-22 14:12:19 HD Request # 57 | Completion time: 0s | 2018-12-22 14:12:19 HD Request # 57 | Daily data download complete for ESZ18. Unique request ID: 54 | 2018-12-22 14:12:19 Removed historical data download ID 54 | 2018-12-22 14:12:19 HD Request # 37 | Receiving historical Daily data for F.US.EPH19 starting at 2017-12-13 | 2018-12-22 14:12:20 HD Request # 37 | Writing historical Daily data to the file F.US.EPH19.dly | 2018-12-22 14:12:20 HD Request # 37 | Received 258 records from 2017-12-13 00:00:00 to 2018-12-21 00:00:00 (374.0 days) and wrote 258 records for F.US.EPH19 | 2018-12-22 14:12:20 HD Request # 37 | Completion time: 2s | 2018-12-22 14:12:20 HD Request # 37 | Daily data download complete for F.US.EPH19. Unique request ID: 55 | 2018-12-22 14:12:20 Removed historical data download ID 55 | 2018-12-22 14:12:20 F.US.EPH19 Daily #11 | Reloading chart. | 2018-12-22 14:12:20 Chart #11 has tagged chart #1 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #14 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #17 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #20 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #28 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #30 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #8 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #1 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #14 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #17 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #20 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #28 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #30 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #8 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #1 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #14 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #17 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #20 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #28 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #30 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #11 has tagged chart #8 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 F.US.EPH19 [C] 1.00 Range #8 | Performing a full recalculation because it has been tagged. Chartbook: DAY.cht | 2018-12-22 14:12:20 F.US.EPH19 Weekly #16 | Reloading chart. | 2018-12-22 14:12:20 F.US.EPH19 Monthly #6 | Reloading chart. | 2018-12-22 14:12:20 F.US.EPH19 [CV] 10000 Trades #17 | Performing a full recalculation because it has been tagged. Chartbook: DAY.cht | 2018-12-22 14:12:20 F.US.EPH19 [CV] 10000 Trades #1 | Performing a full recalculation because it has been tagged. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #1 has tagged chart #17 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #1 has tagged chart #28 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #1 has tagged chart #30 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #1 has tagged chart #8 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 F.US.EPH19 Daily #19 | Reloading chart. | 2018-12-22 14:12:20 F.US.EPH19 [C] 3.00 Range #30 | Performing a full recalculation because it has been tagged. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #30 has tagged chart #28 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #30 has tagged chart #8 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 F.US.EPH19 [C] Daily #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-12-22 14:12:20 F.US.EPH19 [C] Daily #4 | Reloading chart. | 2018-12-22 14:12:20 F.US.EPH19 Quarterly #24 | Reloading chart. | 2018-12-22 14:12:20 F.US.EPH19 Daily #25 | Reloading chart. | 2018-12-22 14:12:20 F.US.EPH19 [C] 406 Min #20 | Performing a full recalculation because it has been tagged. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #20 has tagged chart #17 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #20 has tagged chart #28 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #20 has tagged chart #8 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 F.US.EPH19 [C] 15 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #14 has tagged chart #17 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 Chart #14 has tagged chart #28 for full recalculation. Chartbook: DAY.cht | 2018-12-22 14:12:20 F.US.EPH19 [C] Flex Renko 3-2-3 #28 | Performing a full recalculation because it has been tagged. Chartbook: DAY.cht | 2018-12-22 14:12:20 F.US.EPH19 [C] 1.00 Range #8 | Performing a full recalculation because it has been tagged. Chartbook: DAY.cht | 2018-12-22 14:12:21 F.US.EPH19 [CV] 10000 Trades #17 | Performing a full recalculation because it has been tagged. Chartbook: DAY.cht | 2018-12-22 14:12:21 F.US.EPH19 [C] Daily #4 | Reloading chart. | 2018-12-22 14:12:22 |
[2018-12-22 22:41:01] |
We do not like to advise this, but at this point perform a Full Reset of the Symbol Settings: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps And then follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-22 23:01:29] |
cmet - Posts: 537 |
That fixed it. Thank you.
