Date/Time: Sat, 27 Apr 2024 05:35:32 +0000
Replay function freezes
View Count: 3443
[2017-07-27 19:23:08] |
User432504 - Posts: 73 |
SC: I have had the function for the reply freeze on two separate computers since I did my last update. I am running version 1586. It just sits there and the windows circle icon spins and the replay control window says (not responding). Then the only way to close that window is to use the 'end task' function in windows Why is this happening? |
[2017-07-27 19:33:26] |
This is not something we would expect. We need to know the steps that you performed before this condition happened. And are you replaying just one chart or all the charts in the Chartbook? We may need to get your Chartbook to test this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-27 21:32:26] |
SC: You wrote above: We need to know the steps that you performed before this condition happened. I scrolled one chart back to where I wanted to begin replaying, then I did chart>replay>replay chart(control panel) > all charts in chartbook > calculate at every tick//trade > play. This is where it froze the replay. Where would you like for me to send you my chartbook. I will send you the whole thing. I think in all the years I have used Sierra Charts, this is the first time I have had any part of it freeze like this. All the other charts seem to keep working fine. It is just the replay screen that freezes and gives the circle icon. The charts that I am trying to replay, just sit there and keep updating, but, the replay screen doesn't work and says (not responding) running window 10 on both puters. |
[2017-07-27 21:51:17] |
Someone else reported the same problem here: Replay Chart Backtesting mode Locks up (Crashes sierra chart) I scrolled one chart back to where I wanted to begin replaying, then I did chart>replay>replay chart(control panel) > all charts in chartbook > calculate at every tick//trade > play. When you see Sierra Chart in a frozen state, press the Stop button 2 times on the Replay window to see if you can stop the replay. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-27 22:05:41] |
SC: You wrote:Someone else reported the same problem here: Replay Chart Backtesting mode Locks up (Crashes sierra chart) It is good see that someone else has experienced this. I think it is an issue with the replay function. Also, remember, it has happened to me on both of my computers at different times when I try the replay function. Also, note, that it does not happen every time. Also, note the only way I could get the spinning circle to stop was to use the windows function to "end the task". You wrote: Doing this could freeze the user interface for a few seconds at a time with higher Speeds. But not continuously. It freezes only the replay screen and not for just a few seconds, it just sits there with the circle spinning and replies that the replay screen is not responding. You wrote: When you see Sierra Chart in a frozen state, press the Stop button 2 times on the Replay window to see if you can stop the replay. I will try this. Who do I bill for my software debugging services? :-) |
[2017-07-28 18:46:48] |
SC: The replay function just froze again. Also, note I can't press the stop button like you instructed above because it is not highlighted. It just remains grey. I even tried pressing it and still nothing. I just get the windows circle icon and the replay function remains froze. The only way to stop the freeze of the replay is to use the windows end task under the task manager
[2017-07-28 19:54:04] |
We do not need any further information at this time. We are not sure of the cause and cannot reproduce it but we should figure it out in the coming days. The only other thing at this time we suggest is to run Sierra Chart in Safe Mode and see if that resolves the issue. Refer to: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-03 00:05:18] |
We still have not been able to reproduce the problem or know what the cause is. We do apologize for the issue. It is going to probably help us if we look at this issue on a users system. Would you be available for us to use remote assistance to look into the problem on your system? We can set up another copy of Sierra Chart on your system to do it so it does not interfere with anything you are currently doing with your main installation of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-04 05:08:06] |
If you cannot reproduce the problem, then there is no point for us to look at this. If someone else reports the problem again, then we can look at it with them. We are just waiting for additional feedback. We may already have it resolved by now anyway. Clearly you are quite busy. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-04 07:14:11
[2018-01-02 10:01:47] |
derik - Posts: 2 |
Hi SC support. I started using replay this week. works fine for small intraday testing. this morning I decided to look at 5000v+100000v+500v and wanted to enter and exit on 100000v chart. I ran it at 10 and place orders at levels, then increase speed to 120. Sierra replay just stalls after first day close (21:00h London time) I am working with 10y German bund futures data and have only 1 moving average indicator on each chart for the replay. my sierra charts is on version 1564. replay charts set for dates 2017/09/11 - 2017/11/30 attached is screen capture of current state. please note that I stopped replay and tried to start it again but nothing happens. it just hangs. all fine clicking buttons and Sierra is Using 0% cpu processing time. got windows 7 running. have microsoft security essentials running. got searchindexing disabled as well. FYI: while typing this message: replay just started working after 10 minutes doing nothing (looks like it got interrupted and just woke up) have skip empty periods checked running +- 4 years old AMD machine with 4 cores. memory on the machine is only on 50% so no issue with the memory while running the replay. CPU usage is minuscule. but did see that sierra regards |
Private File |
[2018-01-02 18:08:15] |
This is a case where you have encountered a period of time in the chart were there has been no trading or bar data. For complete details, refer to: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#SkippingData However, we want you to update to the current version to make sure you have all the latest development relating to replaying charts. Follow the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-14 07:24:21] |
YK - Posts: 33 |
Hello. My problem about replay function is always freez at 8:59:58 and 1x speed. I tested some version of SC but all of version I tested has same issue on my side. I play mini Nikkei futures and Nikkei cash open time is 9:00. There is no problem about over 1x replay speed. win10 SC ver 1689 One chart book and 8 intraday charts. I can accept remote desktop. |
[2018-01-14 11:42:01] |
What you are describing is a different type of condition. This is just a condition where the chart is not advancing because you encountered a period of time where there is no trading. Refer to this section here for an understanding of this and what to do: Replaying Charts: Automatic Skipping of Periods Where There Is No Trading and Synchronization Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-14 15:56:31] |
YK - Posts: 33 |
Nikkei futures open time is 8:45. So the freeze time 8:59:58 is high volume. Because 9:00 is cash open time. You mentioned above is not my case. |
[2018-01-15 06:11:27] |
Describe what you mean by "freeze"?
[2018-01-15 08:28:35] |
YK - Posts: 33 |
Crash, white out screen, not accept any command, not answer any click or keybard command, have to kill application from task manager.
[2018-01-15 09:29:47] |
OK we understand. This was a misunderstanding. This is quite unusual. Remove all studies from the chart to rule out any possibility a study is causing the problem and replay without any studies on the chart. Studies can be removed through Analysis >>Clean Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-16 09:48:15] |
YK - Posts: 33 |
"Remove all studies" is works properly. But I need studies. I reduced "Use Number Of Days To Load" 30 to 20, this is works properly. My case resolved. But I don't understand. Does SC hold to memory all loaded chart data including tick and depth when replay? |
[2018-01-16 20:01:06] |
Are you using the Volume by Price study? We need to understand which study is causing the problem in order for us to provide the solution. And what is the exact symbol of the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-17 14:02:46] |
YK - Posts: 33 |
8 intraday charts. 2 symbols JNKH18, NJNKH8 at CQG. All studies in attached file. 3 Volume at price. |
[2018-01-17 22:34:01] |
Attach the Chartbook you are using the following these instructions here: Support Board Posting Information: Attaching a File (Optional) And tell us the particular Chart Number you are replaying. The chart number is at the top of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-18 03:26:03] |
YK - Posts: 33 |
I Attached Chartbook file. Reduce "Use Number Of Days To Load" is sometime not working, still CRASH happen at 08:59:58. Date Time Of Last Edit: 2018-01-18 06:52:13
Private File |
[2018-01-18 03:58:30] |
YK - Posts: 33 |
I Replay Chart #5. Charts to Replay : All charts in Chartbook. Replay Mode : Standard Replay. |
