Date/Time: Fri, 06 Nov 2026 12:55:58 +0000
Data freeze at 7:30am
View Count: 1258
[2026-01-29 12:43:19]
User383986 - Posts: 15
The past couple days i get all data freeze at 7:30am. Also the data misses from 7:30:00 am till 7:31:40 am even after redownload data.
[2026-01-29 14:53:58]
What is one symbol in which you have this issue?
If you have not restarted Sierra Chart since this occurrence, then please get us your Message Log by following these instructions:
[2026-01-29 15:50:59]
nosast - Posts: 327
I also had some issues around the market open 8:31 Central time.
2026-01-29 08:21:57.905 | Saved Chartbook: NQ-VolumeScope.cht. Time: 0.0244 seconds.
2026-01-29 08:31:04.464 | DTC Client socket (5) | Socket gracefully closed by remote side.
2026-01-29 08:31:04.477 | DTC Client socket (5) | CloseSocket call.
2026-01-29 08:31:04.477 | DTC Client socket (5) | Signaling for receive thread to end. Bytes in receive buffer: 0
2026-01-29 08:31:04.506 | DTC Client socket (5) | Max send buffers used during socket life: 4
2026-01-29 08:31:04.506 | DTC Client socket (5) | Max send buffer size during socket life: 490
2026-01-29 08:31:04.506 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-01-29 08:31:04.506 | DTC Client socket (5) | Closed.
2026-01-29 08:31:04.508 | DTC Client socket (0) | CloseSocket call.
2026-01-29 08:31:04.508 | Denali Data Feed | Disconnected from the server.
2026-01-29 08:31:04.508 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-01-29 08:31:07.523 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048
2026-01-29 08:31:07.523 | DTC Client socket (3) | Creating socket.
2026-01-29 08:31:07.523 | DTC Client socket (3) | New receive buffer size: 0
2026-01-29 08:31:07.523 | DTC Client socket (3) | Connecting to IP: 64.152.155.17.
2026-01-29 08:31:07.635 | Denali Data Feed | Network connection to server complete.
2026-01-29 08:31:07.635 | Denali Data Feed | Starting socket receive thread.
2026-01-29 08:31:07.635 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-01-29 08:31:07.770 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-01-29 08:31:07.770 | Denali Data Feed | Sending logon request message.
2026-01-29 08:31:23.055 | Denali Data Feed | Received logon response.
2026-01-29 08:31:23.055 | Denali Data Feed | Server Name: SC Realtime Server.
2026-01-29 08:31:23.055 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-01-29 08:31:23.055 | Denali Data Feed | Successfully connected.
2026-01-29 08:31:23.055 | Denali Data Feed | Trading is not supported.
2026-01-29 08:31:23.055 | Denali Data Feed | MarketDepthIsSupported: 1
2026-01-29 08:31:23.055 | Denali Data Feed | Restarting real-time data updates for symbol: CLH6.NYMEX -> CLH26
2026-01-29 08:31:23.055 | Added historical Intraday data request for ESH6.CME to the queue.
2026-01-29 08:31:23.055 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'.
2026-01-29 08:31:23.055 | Triggering next historical data download in queue.
Socket closed by remote side. Got reconnected 20 seconds later.
[2026-01-29 16:23:05]
nosast:
We see the following in the log:
So there is a disconnection, but there is nothing in the log for any reason why it occurred. The data feed reconnected 3 seconds later as it states that it will do from the log entry.
We simply do not have enough information to point to anything specific. It could be any number of reasons for this at that time. In order to eliminate Rithmic as a possible issue - the data feed will drop if the connection to the trading service is lost - we recommend installing a second Sierra Chart with the "Current Selected Service" set to "SC Data". Then if you see this in the Rithmic installation but not the SC Data installation, then it is an issue with connectivity to Rithmic.
For items like this, please open a new post. Issues like this are very rarely related.
[2026-01-29 17:17:41]
nosast - Posts: 327
The call to close the connection came a few ms earlier from the remote side.
[2026-01-30 12:37:06]
I had a freeze today againat 7:30. Had some premarket stocks open as test. Again freeze from 7:30 on the dot till 07:31:40.
I have also send the whole message log throguh send for analysis.
Here are logs:
2026-01-30 07:29:00.487 |
2026-01-30 07:29:00.487 | No download requests in the queue to start downloads for.
2026-01-30 07:29:00.545 | ORKT_MBO[M] Daily #2 | Reloading chart.
2026-01-30 07:29:00.563 | Chart #2 has tagged chart #4 for full recalculation. Chartbook: Detail_2___.cht
2026-01-30 07:29:00.563 | ORKT_MBO[M] Daily #2 | Chart data loading complete.
2026-01-30 07:29:00.574 | Socket (4) | Socket gracefully closed by remote side.
2026-01-30 07:29:00.574 | Socket (4) | Closed.
2026-01-30 07:29:00.577 | ORKT_MBO[M] 10 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Detail_2___.cht
2026-01-30 07:29:02.614 | Opened cached Intraday file: C:\SierraChart\Data\ORKT_MBO.scid. Thread ID: 12592
2026-01-30 07:29:03.953 | ORKT_MBO[M] Daily #2 | Reloading chart.
2026-01-30 07:29:03.966 | Chart #2 has tagged chart #4 for full recalculation. Chartbook: Detail_2___.cht
2026-01-30 07:29:03.966 | ORKT_MBO[M] Daily #2 | Chart data loading complete.
2026-01-30 07:29:04.086 | ORKT_MBO[M] 10 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Detail_2___.cht
2026-01-30 07:29:59.514 | Denali Data Feed | Real-time data for symbol twnp_MBO is currently unavailable.
2026-01-30 07:29:59.514 | Denali Data Feed | Real-time data for symbol vivs_MBO is currently unavailable.
2026-01-30 07:29:59.601 | Denali Data Feed | Real-time data for symbol JZXN_MBO is currently unavailable.
2026-01-30 07:29:59.694 | Denali Data Feed | Real-time data for symbol radx_MBO is currently unavailable.
2026-01-30 07:29:59.790 | Denali Data Feed | Real-time data for symbol ACCL_MBO is currently unavailable.
2026-01-30 07:29:59.790 | Denali Data Feed | Real-time data for symbol AZI_MBO is currently unavailable.
2026-01-30 07:29:59.977 | Denali Data Feed | Real-time data for symbol lrhc_MBO is currently unavailable.
2026-01-30 07:29:59.977 | Denali Data Feed | Real-time data for symbol ORKT_MBO is currently unavailable.
2026-01-30 07:30:00.409 | Denali Data Feed | Real-time data for symbol ciss_MBO is currently unavailable.
2026-01-30 07:30:00.409 | Denali Data Feed | Real-time data for symbol fatbb_MBO is currently unavailable.
2026-01-30 07:30:22.463 | SOPA_MBO[M] 10 Sec #4 | Reloading chart.
2026-01-30 07:30:22.487 | SOPA_MBO[M] 10 Sec #4 | Chart data loading complete.
2026-01-30 07:30:22.520 | SOPA_MBO[M] 5 Min #10 | Reloading chart.
2026-01-30 07:30:22.526 | SOPA_MBO[M] 1 Min #1 | Reloading chart.
2026-01-30 07:30:22.543 | SOPA_MBO[M] 1 Sec #5 | Reloading chart.
2026-01-30 07:30:22.550 | Chart #1 has tagged chart #4 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:22.550 | Chart #1 has tagged chart #5 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:22.550 | SOPA_MBO[M] 1 Min #1 | Chart data loading complete.
2026-01-30 07:30:22.552 | SOPA_MBO[M] 5 Min #10 | Chart data loading complete.
2026-01-30 07:30:22.554 | SOPA_MBO[M] 1 Sec #5 | Chart data loading complete.
2026-01-30 07:30:22.566 | SOPA_MBO[M] Daily #2 | Reloading chart.
2026-01-30 07:30:22.588 | Chart #2 has tagged chart #4 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:22.588 | Chart #2 has tagged chart #5 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:22.588 | SOPA_MBO[M] Daily #2 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data
2026-01-30 07:30:22.588 | SOPA_MBO[M] Daily #2 | Chart data loading complete.
2026-01-30 07:30:22.612 | Mapping SOPA_MBO to SOPA_MBO. Service code: us_equities_with_depth.data
2026-01-30 07:30:22.612 | Denali Data Feed | Starting real-time market data updates for: SOPA_MBO (SOPA_MBO). ID: 11 Service code: us_equities_with_depth.data
2026-01-30 07:30:22.612 | Denali Data Feed | Requesting security definition data for: SOPA_MBO (SOPA_MBO). ID: 11
2026-01-30 07:30:22.612 | Added historical Intraday data request for SOPA_MBO to the queue.
2026-01-30 07:30:22.612 | Intraday data recording state for symbol SOPA_MBO is set to download 'Pending'.
2026-01-30 07:30:22.612 | Triggering next historical data download in queue.
2026-01-30 07:30:22.612 | SOPA_MBO[M] 10 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Detail_1___.cht
2026-01-30 07:30:22.620 | Delaying start of download for SOPA_MBO.
2026-01-30 07:30:22.656 | SOPA_MBO[M] 1 Sec #5 | Performing a full recalculation because it has been tagged. Chartbook: Detail_1___.cht
2026-01-30 07:30:22.658 | Added historical Daily data request for SOPA_MBO to the queue.
2026-01-30 07:30:22.658 | Triggering next historical data download in queue.
2026-01-30 07:30:22.755 | Denali Data Feed | Real-time data for symbol SOPA_MBO is currently unavailable.
2026-01-30 07:30:22.755 | Denali Data Feed | Setting external service identifier for symbol SOPA_MBO to 803
2026-01-30 07:30:22.755 | Denali Data Feed | Received security definition for symbol SOPA_MBO
2026-01-30 07:30:25.147 | Unsubscribed from market depth data for vivs_MBO
2026-01-30 07:30:25.148 | Denali Data Feed (Market Orders Data) | Stopping market orders updates for: vivs_MBO. Service code: us_equities_with_depth.data
2026-01-30 07:30:25.148 | Requesting market depth updates for: SOPA_MBO if supported. NumLevels=1400
2026-01-30 07:30:25.148 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: SOPA_MBO. MinimumMarketByOrderQuantity: 0. Service code: us_equities_with_depth.data
2026-01-30 07:30:25.253 | Denali Data Feed | Clearing market depth for SOPA_MBO
2026-01-30 07:30:25.333 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: SOPA_MBO. Market orders request not authorized.
2026-01-30 07:30:27.274 | HD Request # 20 | Downloading Intraday chart data for SOPA_MBO to the file SOPA_MBO.scid. Service: us_equities_with_depth.data
2026-01-30 07:30:27.274 | HD Request # 20 | Download start date-time: 2026-01-29 09:23:53.000000. File last date-time: 2026-01-29 09:23:53.771000
2026-01-30 07:30:27.274 | HD Request # 20 | Using server: ds31.sierracharts.com port 10150
2026-01-30 07:30:27.275 | Socket (3) | Creating socket.
2026-01-30 07:30:27.275 | Socket (3) | New receive buffer size: 0
2026-01-30 07:30:27.275 | Socket (3) | Connecting to IP: 64.152.155.116.
2026-01-30 07:30:27.473 | HD Request # 20 | Setting DTC encoding to Binary VLS
2026-01-30 07:30:27.473 | HD Request # 20 | Sending historical data logon request message.
2026-01-30 07:30:27.602 | HD Request # 20 | Requesting Intraday data. Start date-time: 2026-01-29 09:23:53. Record interval: 0. Symbol: SOPA_MBO
2026-01-30 07:30:27.701 | HD Request # 20 | Decompressing data.
2026-01-30 07:30:27.805 | HD Request # 20 | Receiving Intraday data for SOPA_MBO starting at 2026-01-29 09:23:53.771000
2026-01-30 07:30:27.903 | Socket (3) | CloseSocket call.
2026-01-30 07:30:27.903 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-01-30 07:30:27.904 | Historical data download thread signaled to stop.
2026-01-30 07:30:27.904 | HD Request # 20 | Timestamp of first Intraday data file record written: 2026-01-29 09:24:14.835000.
2026-01-30 07:30:27.904 | HD Request # 20 | Received 2949 Intraday data records from 2026-01-29 09:23:53.771000 to 2026-01-30 07:30:00.088005 (22.1 hours. Delay: 27.8 seconds) and wrote 2948 records for SOPA_MBO
2026-01-30 07:30:27.914 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2026-01-30 12:30:00.088005
2026-01-30 07:30:27.914 | HD Request # 20 | Completion time: 0s.
2026-01-30 07:30:27.914 | HD Request # 20 | Intraday data download complete for SOPA_MBO. Unique request ID: 20
2026-01-30 07:30:27.914 | Removing historical data download ID 20.
2026-01-30 07:30:27.914 | Real-time Intraday chart data file updates started for SOPA_MBO
2026-01-30 07:30:27.914 | Intraday chart data file opened for SOPA_MBO
2026-01-30 07:30:27.914 | HD Request # 20 | Enabling Intraday chart updating for symbol.
2026-01-30 07:30:27.914 | Triggering next historical data download in queue.
2026-01-30 07:30:27.915 | HD Request # 21 | Downloading Historical Daily chart data for SOPA_MBO. Starting date: 2026-01-26. Service: us_equities_utp_cta_exchange.data
2026-01-30 07:30:27.915 | HD Request # 21 | Using server: ds33.sierracharts.com port 10149
2026-01-30 07:30:27.915 | Socket (4) | Creating socket.
2026-01-30 07:30:27.915 | Socket (4) | New receive buffer size: 0
2026-01-30 07:30:27.915 | Socket (4) | Connecting to IP: 69.39.70.245.
2026-01-30 07:30:27.930 | Chart #1 has tagged chart #4 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:27.930 | Chart #1 has tagged chart #5 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:27.934 | SOPA_MBO[M] 1 Sec #5 | Performing a full recalculation because it has been tagged. Chartbook: Detail_1___.cht
2026-01-30 07:30:27.972 | SOPA_MBO[M] 10 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Detail_1___.cht
2026-01-30 07:30:28.000 | Socket (3) | Socket gracefully closed by remote side.
2026-01-30 07:30:28.000 | Socket (3) | Closed.
2026-01-30 07:30:28.120 | HD Request # 21 | Setting DTC encoding to Binary VLS
2026-01-30 07:30:28.120 | HD Request # 21 | Sending historical data logon request message.
2026-01-30 07:30:28.258 | HD Request # 21 | Requesting historical Daily data starting at 2026-01-26.
2026-01-30 07:30:28.360 | HD Request # 21 | Decompressing data.
2026-01-30 07:30:28.362 | HD Request # 21 | Receiving historical Daily data for SOPA_MBO starting at 2026-01-26.
2026-01-30 07:30:28.362 | HD Request # 21 | Writing historical Daily data to the file SOPA_MBO.dly.
2026-01-30 07:30:28.370 | Socket (4) | CloseSocket call.
2026-01-30 07:30:28.370 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-01-30 07:30:28.376 | Historical data download thread signaled to stop.
2026-01-30 07:30:28.376 | HD Request # 21 | Received 4 Daily data records from 2026-01-26 00:00:00 to 2026-01-29 00:00:00 (4.0 days) and wrote 4 records for SOPA_MBO
2026-01-30 07:30:28.376 | HD Request # 21 | Completion time: 1s.
2026-01-30 07:30:28.376 | HD Request # 21 | Daily data download complete for SOPA_MBO. Unique request ID: 21
2026-01-30 07:30:28.376 | Removing historical data download ID 21.
2026-01-30 07:30:28.376 | No download requests in the queue to start downloads for.
2026-01-30 07:30:28.392 | SOPA_MBO[M] Daily #2 | Reloading chart.
2026-01-30 07:30:28.408 | Chart #2 has tagged chart #4 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:28.408 | Chart #2 has tagged chart #5 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:28.408 | SOPA_MBO[M] Daily #2 | Chart data loading complete.
2026-01-30 07:30:28.429 | SOPA_MBO[M] 10 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Detail_1___.cht
2026-01-30 07:30:28.471 | Socket (4) | Socket gracefully closed by remote side.
2026-01-30 07:30:28.471 | Socket (4) | Closed.
2026-01-30 07:30:28.480 | SOPA_MBO[M] 1 Sec #5 | Performing a full recalculation because it has been tagged. Chartbook: Detail_1___.cht
2026-01-30 07:30:32.564 | SOPA_MBO[M] Daily #2 | Reloading chart.
2026-01-30 07:30:32.577 | Chart #2 has tagged chart #4 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:32.577 | Chart #2 has tagged chart #5 for full recalculation. Chartbook: Detail_1___.cht
2026-01-30 07:30:32.577 | SOPA_MBO[M] Daily #2 | Chart data loading complete.
2026-01-30 07:30:32.602 | SOPA_MBO[M] 1 Sec #5 | Performing a full recalculation because it has been tagged. Chartbook: Detail_1___.cht
2026-01-30 07:30:32.634 | SOPA_MBO[M] 10 Sec #4 | Performing a full recalculation because it has been tagged. Chartbook: Detail_1___.cht
2026-01-30 07:31:44.505 | Denali Data Feed | Setting external service identifier for symbol fatbb_MBO to 3
2026-01-30 07:31:44.505 | Denali Data Feed | Received security definition for symbol fatbb_MBO
2026-01-30 07:31:44.505 | Denali Data Feed | Real-time data for symbol fatbb_MBO has been restored.
Date Time Of Last Edit: 2026-01-30 12:39:07
[2026-01-30 13:58:27]
User43540 - Posts: 8
Same issue for one minute, another time, Denali, from Europe:
2026-01-29 10:20:44.266 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-01-29 10:20:44.266 | DTC Client socket (3) | CloseSocket call.
2026-01-29 10:20:44.266 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0
2026-01-29 10:20:44.266 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-01-29 10:20:44.266 | DTC Client socket (3) | Closed.
2026-01-29 10:20:44.266 | DTC Client socket (0) | CloseSocket call.
2026-01-29 10:20:44.266 | Denali Data Feed | Disconnected from the server.
2026-01-29 10:20:44.266 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-01-29 10:20:47.265 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10048
2026-01-29 10:20:47.297 | DTC Client socket (2) | Creating socket.
2026-01-29 10:20:47.297 | DTC Client socket (2) | New receive buffer size: 0
2026-01-29 10:20:47.297 | DTC Client socket (2) | Connecting to IP: 69.39.70.249.
2026-01-29 10:20:47.418 | Denali Data Feed | Network connection to server complete.
2026-01-29 10:20:47.418 | Denali Data Feed | Starting socket receive thread.
2026-01-29 10:20:47.418 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-01-29 10:21:07.416 | Denali Data Feed | Did not receive Encoding Response from server. Disconnecting. *
2026-01-29 10:21:07.416 | Denali Data Feed | Waiting for socket receive thread to end
2026-01-29 10:21:07.416 | DTC Client socket (2) | CloseSocket call.
2026-01-29 10:21:07.416 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-01-29 10:21:07.416 | Denali Data Feed | Disconnected from the server.
2026-01-29 10:21:07.416 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-01-29 10:21:10.420 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443
2026-01-29 10:21:10.422 | DTC Client socket (3) | Creating socket.
2026-01-29 10:21:10.422 | DTC Client socket (3) | New receive buffer size: 0
2026-01-29 10:21:10.422 | DTC Client socket (3) | Connecting to IP: 64.152.155.21.
2026-01-29 10:21:10.606 | Denali Data Feed | Network connection to server complete.
2026-01-29 10:21:10.606 | Denali Data Feed | Starting socket receive thread.
2026-01-29 10:21:10.606 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-01-29 10:21:30.617 | Denali Data Feed | Did not receive Encoding Response from server. Disconnecting. *
2026-01-29 10:21:30.617 | Denali Data Feed | Waiting for socket receive thread to end
2026-01-29 10:21:30.617 | DTC Client socket (3) | CloseSocket call.
2026-01-29 10:21:30.617 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2026-01-29 10:21:30.617 | Denali Data Feed | Disconnected from the server.
2026-01-29 10:21:30.617 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-01-29 10:21:33.614 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 443
2026-01-29 10:21:33.616 | DTC Client socket (5) | Creating socket.
2026-01-29 10:21:33.616 | DTC Client socket (5) | New receive buffer size: 0
2026-01-29 10:21:33.616 | DTC Client socket (5) | Connecting to IP: 69.39.70.248.
2026-01-29 10:21:33.750 | Denali Data Feed | Network connection to server complete.
[2026-03-18 11:32:55]
Issue is back. Today _mbo stocks freezing again at 7:30 on the dot for 2 minutes.
Date Time Of Last Edit: 2026-03-18 11:37:29
[2026-03-18 13:59:14]
Sierra_Chart Engineering - Posts: 25390
What time zone are you referring to?
Yesterday, we have to check the time but it was close to 9 AM or might have been around 8:30 AM US Eastern time, we did work on our CTA feeds (NYSE and AMEX).
Our provider of these data feeds, had an issue with one of their circuits in Pennsylvania from their carrier which delivers data, from New York to Chicago. So we were switching to a secondary circuit.
That would have caused an interruption for users of about 30 seconds. Maybe you are referring to that.
[2026-03-18 19:58:43]
7:30 am Eastern Time zone. Take a look at example at BURU_MBO. Data missing from 07:30 AM till 7:32 AM(This was where the disconnect/data freeze comes in). This happened at all the _mbo stocks i had open. It disconnects at 07:30AM and connection comes back at 07:32AM.
Date Time Of Last Edit: 2026-03-18 20:00:02
[2026-03-19 00:28:27]
We are going to check on this and it must be related to a carrier issue. We are checking.
[2026-03-19 05:49:56]
We have looked into this carefully. At 7:30 AM US Eastern time, or at any time, on March 18 there definitely was not a lost connection to the NASDAQ server. There is no data loss at all. If the data feed stopped, there may have been a network connectivity issue, somewhere else, but there was no stopping data feed or lost data on our side.
If you are missing any data, follow the instructions here:
[2026-03-19 06:28:35]
There is 100% a lost connection/and or data issue as seen in the image. Even on another pc and fresh (re)download data, the data is missing from 07:30 am till 07:32 AM. See screenshot: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=135381
Date Time Of Last Edit: 2026-03-19 06:32:07
imagedatastop.jpg / V - Attached On 2026-03-19 06:28:17 UTC - Size: 147.07 KB - 362 views
[2026-03-19 09:01:24]
That is definitely not proof that there is missing data. There may not have been any trades for that stock, on the NASDAQ.
The very same data feed (NASDAQ TotalView) at the same time was also, providing data for SPY at that time and we see the data:
https://www.sierrachart.com/image.php?Image=1773910808879.png
We definitely cannot help with this further.
We cannot identify any issue.
Actually it just occurred to us, that you are not actually referring to NASDAQ TotalView, but the US equities consolidated tape feed. There may very well have been a problem then. We will check.
Date Time Of Last Edit: 2026-03-19 09:02:50
[2026-03-22 05:45:52]
We have looked into this. There was a problem with our wavelength circuit at that time. There is less than two minutes of data, missing at that time.
The carrier did detect the problem and resolve it.
[2026-06-11 12:48:52]
Unfortunately the exact same issue happened again today. freeze at exactly 7:30am. Could not see any new data for a minute. Very frustrating when you're trying to trade.
You can take a look at EDHL_MBO 07:30:00 - 07:31:07 is missing. And any other U.S. Equities Consolidated Tape I was watching freezes.
Date Time Of Last Edit: 2026-06-11 12:58:10
[2026-06-11 14:55:35]
EDHL had odd trading at that time, so there are gaps from 09:30 to 09:32 Eastern US Time. We have looked at charts from other vendors and see the same thing, so this does not appear to be anything about our data feed.
We are not seeing this with other symbols such as AAPL or TSLA.
[2026-06-11 15:27:34]
EDHL had lots of volume, definitely no odd trading.
About AAPL and TSLA and others.
AAPL_MBO and AAPL -> No data 07:30 - 07:31 (AAPL-NQTV has 07:30 data)
TSLA_MBO and TSLA -> No data 07:30 - 07:31 (TSLA-NQTV has 07:30 data)
SPY_MBO and SPY -> No data 07:30 - 07:31 (SPY-NQTV has 07:30 data)
And others...
All these and more have 07:30 data with (-nqtv). You can verify this yourself.
All my (_mbo)charts froze from 07:30-07-07:31. this isn't the first time this happened either.
Date Time Of Last Edit: 2026-06-11 15:29:47
[2026-06-11 18:08:41]
Attached is a chart from Yahoo Finance for EDHL in 1 minute bars (EDHL-1Minute.png). You will see from 09:30 (Eastern US Time) to after 10:30 is slow trading with no bars for several minutes.
Attached is a chart from Sierra Chart for the same time period (08:30 Central US Time) (EDHL[M] 1 Min - SC.png). Where you will see the same information. This is just showing some odd behavior at that time.
Although we do not know what time zone you are referencing when you say 07:30, so we can not be certain that this is exactly what you are referencing. Although we are not seeing any particular issues with missing data around the 30 minute mark for any hour around that same time.
We also looked at AAPL again, and we are not seeing any missing data outside of the lower volume trading hours, for instance there is a missing 10 second bar at 08:25:20, but this is before the main trading started and is not unusual. Otherwise, there is no missing data after that time.
Our point is that we are not seeing anything to believe there was any kind of general outage at that time. If you lost connectivity at that time, it would be due to your Internet connection and not due to our servers serving out the data. We also have not had any other reports of a specific outage at that time.
To fill in missing data, follow these instructions:
imageEDHL[M] 1 Min - SC.png / V - Attached On 2026-06-11 18:08:32 UTC - Size: 23.16 KB - 159 views
imageEDHL-1Minute.png / V - Attached On 2026-06-11 18:08:37 UTC - Size: 61.61 KB - 146 views
[2026-06-11 18:36:00]
The feeze happens at 07:30AM Eastern Time till 07:31AM Eastern time. so for 1 minute. Which is 6:30AM till 6:31AM Central Time. Not 8:30AM Central time.
We had these discussions before a couple months back. And there were issues you guys found. Everything freezes for that 1 minute.
Let me give concrete proof here since I need to proof my claim again..
Please take a look at the sceenshots i have added. I have put up a 1 second chart. Every chart I load the 07:30(Eastern Time) minute is missing. Not much more proof I can give.
Date Time Of Last Edit: 2026-06-11 18:37:12
imageSMCI_MBO.png / V - Attached On 2026-06-11 18:34:15 UTC - Size: 206.51 KB - 160 views
imageTSLA_MBO.png / V - Attached On 2026-06-11 18:34:23 UTC - Size: 180.47 KB - 138 views
imageSPY_MBO.png / V - Attached On 2026-06-11 18:34:26 UTC - Size: 196.11 KB - 145 views
