Date/Time: Tue, 27 Oct 2026 21:39:20 +0000
[Sticky] [Locked] - Notice: Solution to: Chart/Chartbook Tabs Visibility Issues, Portions of Chart Window Cut Off
View Count: 18853
[2026-01-07 02:35:47]
Sierra_Chart Engineering - Posts: 25299
We have been contemplating some of these postings about issues with the state of MDI windows when switching between Chartbooks and them not being restored as they were regarding the z-order.
There has been a significant internal change with window handling and internally Sierra Chart is much better organized, with all of this. And has a lot more extended capability compared to what the OS delivered for MDI windows.
However, we realize that we need to have a MDIShowNoActivate function internally implemented. And that would be used when switching among Chartbooks and restoring the current Chartbook.
Date Time Of Last Edit: 2026-06-08 14:23:00
[2026-01-07 08:23:03]
We now understand the reason for the keyboard shortcut issues. This will be resolved, by the end of the day January 8.
[2026-01-07 21:07:05]
Version 2856 has now been released, resolving window state issues, and issues with window states when switching between Chartbooks.
Hopefully, there are no remaining issues.
We do apologize for the window state issues. There are a large amount of scenarios, and as we go through some basic tests related to the development done, we do not encounter them all. And are also more subtle scenarios, that were never even considered. Or even noticeable.
The keyboard issue, involving the Alt key will be resolved later today. We should have a new release out late tonight.
Date Time Of Last Edit: 2026-01-08 00:37:04
[2026-01-09 16:20:03]
Over this weekend, we are going to lock out versions 2814 through version 2858.
Version 2859 resolves various outstanding issues with the recent MDI window development. If you want to go back to a version of Sierra Chart before of all of this development use version 2813.
[2026-01-11 04:54:56]
Some additional issues we are aware of:
Apparently minimized windows, in Chartbooks from 2813 and earlier, do not open in a minimized state.
When a window is minimized, the icon for restoring the window which is the third box from the right side of the chart, might look like two dots at an angle to each other. This is wrong. It is not supposed to look like that. We know why this is the case and that is actually correctable, by changing the width of this graphics setting to 1:
Window System Minimize Maximize Close Foreground
When selecting a tab on the MDI tab bar, and that particular window is minimized, it does not get restored.
When using OpenGL spreadsheet windows do not show the title bar.
All of the above will be resolved.
Also, minimized charts should not be drawn and they will not be. Drawing will be skipped other than the title bar.
Date Time Of Last Edit: 2026-01-11 19:26:18
[2026-01-11 17:56:32]
We are finishing testing of the above and will have a new release out, in about an hour or two.
[2026-01-11 22:43:15]
Version 2861 has now been released. But this is still an outstanding item:
It is released as a Prerelease, for the time being.
Date Time Of Last Edit: 2026-01-11 22:51:11
[2026-01-13 22:06:45]
2862 has been released and this is resolved:
Also, when minimizing a window to the bottom, it is moved to the bottom of the z-order.
The centering of text on the title bar is now perfect when using the GDI. Although when using OpenGL, we have a report, that it is off center. We are looking into that.
[2026-01-19 03:01:27]
There is extensive rework, of the management of chart child windows, like the Time and Sales window, and Market Depth window, and trade window, when a chart is hidden or when switching Chartbooks. This is in version 2865.
Some additional work is going to be done as well.
We will go into more details, but these child windows are always destroyed if the associated chart is hidden or not in the visible Chartbook, in order to minimize what are called operating system "User" objects. This makes Sierra Chart a lot more efficient. You will notice some amount of delay when switching between Chartbooks, but just understand that there is a major efficiency advantage in this.
We will go into more details later.
We can also support, a hiding mode for these child windows, but it does complicate the code. So we are not opposed to that, but until we get this development all finalized, this is not something we want to do. And there is a massive disadvantage in this. Especially with the Trade Window.
2865, also completes development, of the new Ask Volume Bid Volume difference market data columns. There are dedicated color settings for these columns and the diagonal calculations match Numbers Bars.
Date Time Of Last Edit: 2026-08-21 20:18:25
[2026-01-21 18:16:36]
We have released version 2867. Notes about the changes and additions and issues resolved are here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2867
Also take note of the change regarding Sierra Chart Timers.
[2026-02-16 02:52:27]
We have had 2 users report a problem where a MDI child chart window, or maybe it was a spreadsheet window, or both, when hidden, when switching Chartbooks, do not actually hide.
We have seen an issue today, related to a spreadsheet, where it should be hiding but it is not. We are fairly sure, quite sure, we are hiding the window through the operating system, but the operating system is not really hiding it.
We are going to get a good understanding of this, and see exactly where the problem is. It would seem to be at the operating system level. But we probably could implement a workaround once we have a better understanding of it. We should have a solution this week.
Date Time Of Last Edit: 2026-02-17 07:36:50
[2026-02-17 07:36:09]
This is resolved in prerelease version 2883:
Also in post #60, it said 22 users. We meant 2 users. This was a data transmission error.
And this was not an operating system issue. It was an unusual window state issue specific to spreadsheets. This may also resolve the problem with charts that the two users had, but we are not sure. Not sure how that issue could arise with charts when switching Chartbooks.
Date Time Of Last Edit: 2026-02-17 07:39:21
[2026-06-08 14:33:26]
We are confirming that these issues are resolved:
We have had various reports, from time to time and more recently with issues where Chart and Chartbook tabs within the main Sierra Chart window are not visible even though they are enabled:
General Settings Window: Chartbook Tabs (Global Settings >> General Settings >> Windows)
And issues with portions of a chart window being cut off within the main window under certain conditions.
The above problems relate to what is called the MDI Client window which is part of the multiple document interface functionality from Microsoft:
https://learn.microsoft.com/en-us/windows/win32/winmsg/about-the-multiple-document-interface
The reason these issues are now resolved is because the MDI Client window, is created and fully managed by Sierra Chart now in newer versions. The operating system or MFC has no involvement in it at all anymore. The size and position of this MDI client window is controlled by Sierra Chart when the main window size changes.
The operating system no longer controls this. Even though previously Sierra Chart would receive an event from the OS/MFC to set this, and also at other times control the size of the MDI client window, inevitably the operating system is changing the size and position of that window or may ignore what Sierra Chart is setting for the size and position of it, and this is what leads to the problem.
Date Time Of Last Edit: 2026-06-08 14:37:28
[2026-06-22 15:56:33]
We want to describe one issue that has arisen that was unknown to us to have happened when our own MDI functionality was implemented.
The solution is not very easy.
When changing between Chartbooks, and you have set Sierra Chart to not destroy the chart windows when charts are hidden, is the z-order of the chart windows is not necessarily going to be maintained when switching back to a particular Chartbook, as it was before.
One thing we want to make 100% clear, it has always always been the case for all versions of Sierra Chart, going back to the very beginning that when you open a Chartbook, the order of the charts will be according to how they are listed in Window >> Windows and Chartbooks. This has never changed and is 100% the same in current versions.
The only difference is that when you switch between Chartbooks that are already open, the Z order of the charts may be different in a particular Chartbook as it was before when it is hidden. When you switch back to a Chartbook the z-order of the charts will be to how they are listed in Window >> Windows and Chartbooks. If you want a particular order change the order there.
What has changed, and why this is the case we do not know, is that now that the MDI functionality is implemented by Sierra Chart, when we show a window, but not activate it, from a hidden state, the z-order of that window changes. Why that is the case, when the MDI functionality is implemented by Sierra Chart, we do not know. The very same operating system command to show a hidden window is being used. And the very same state is being used.
The solution is simple. Change the order of the charts as you want in Window >> Windows and Chartbooks.
One thing that we can do is add an option so that when you activate a chart, and therefore changing its z-order, we can move it to the bottom of the list in Window >> Windows and Chartbooks. But this would be kind of odd behavior because you would then instantly notice the chart tab for that chart to actually move at that time.
The other possibility is for us to maintain the z-order of the child windows, but this is not very simple.
[2026-06-23 15:23:57]
Regarding, post #63 above, we are working on a solution to maintain the z-order of windows when switching between Chartbooks and also opening a Chartbook.
And we should also be able to have this apply to detached charts as well.
Date Time Of Last Edit: 2026-06-23 15:24:32
[2026-08-16 00:47:47]
We acknowledge that there were two outstanding issues with the MDI functionality that have now been resolved in version 2936 and higher:
Solved two different problems with the state of MDI (Multiple Document Interface) windows (Chart, Spreadsheet, Quote Board) which are part of the main Sierra Chart window. The state of them may not have been saved or restored correctly.
Minimized windows may not have stayed minimized when reopening a Chartbook. This is resolved. The reason for this problem had to do with saving a Chartbook when it is not visible. This was a scenario that was never tested or considered.
The Z-Order of the windows also may not have been restored correctly when reopening a Chartbook or switching between loaded Chartbooks. This issue is also now resolved.
If you have been holding off updating higher than Sierra Chart Version 2813 because you have had problems with the new MDI functionality, please know that these issues are now resolved. You should no longer have any further problems.
And also it will be required anyway for you to update by December 1, 2026. More on that later.
