Date/Time: Wed, 25 Nov 2026 22:26:04 +0000
Can't Resize the Chart Region for Numbers Bars Calculated Values
View Count: 784
[2025-04-02 09:42:07]
User912596 - Posts: 6
Hello Sierra Chart Support,
I’m using the Numbers Bars Calculated Values (NBCV) study and I have assigned it to Chart Region 2. However, I do not see the region divider bar between regions, and I’m unable to resize the panel.
Thanks!
[2025-04-02 15:40:17]
You can definitely resize the region with a Numbers Bars Calculated Values study displayed. It works the same as with any other study in the region. Refer to the following for the options:
Working With Charts: Chart Window and Regions
[2025-04-04 09:23:20]
I would like to extract total volume and delta volume data by day and by week into a spreadsheet, and export it to Excel. Could you please let me know if Sierra Chart supports this functionality, and if so, how I can set it up?
Thank you for your support.
[2025-04-04 14:49:05]
The way to do this is to setup a chart with the "Numbers Bars Calculated Values" study on it. The study does not need to be displayed, it can be hidden. Then set the chart to the time frame for which you want the data (i.e. daily or weekly). Just be sure to set "Chart >> Chart Settings >> Data Limiting >> Chart Data Type" to "Intraday Chart Only" otherwise you will not get the delta information as it is not available with Daily Historical Data.
Then you can export the information using the "Edit >> Export Bar and Study Data to File".
Refer to the following:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method)
Edit Menu: Edit >> Export Bar and Study Data to Text File
[2025-04-06 10:45:52]
Hi John,
Is there anyway I can extract data to excel file?
Best,
[2025-04-07 13:52:41]
Sierra_Chart Engineering - Posts: 25484
No this is not supported. There is not support for Excel. You can export the chart data to plaintext:
Date Time Of Last Edit: 2025-04-07 14:49:03
