Date/Time: Thu, 19 Nov 2026 12:45:32 +0000
One month data gap
View Count: 615
| [2024-09-12 14:53:20] |
| NeonSkittleCat - Posts: 4 |
Hello, this morning I was missing premarket data so I decided to delete and download all data and now I'm missing a month of data but anything before that loads. For some reason my sub instance works and loads correctly but not my main instance despite having the same settings.
| [2024-09-12 16:46:01] |
| John - SC Support - Posts: 48583 |
Please right click on the chart before the current day's data (so sometime in 8/1 and select "Delete and Download Data". Let us know if you are not getting the data showing after this.
| [2024-09-12 21:34:41] |
I am still not getting the data after performing your instructions.
| [2024-09-13 02:33:13] |
| Sierra_Chart Engineering - Posts: 25441 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". Only use this command from the Edit menu at the top of the main window or chart. Or, in the case of a Continuous Futures Contract chart, follow these instructions: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data After about a minute provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-09-13 07:01:53] |
2024-09-13 06:59:02.794 | Software version: 2674 64-bit 2024-09-13 06:59:02.794 | Primary Thread ID: 3460 2024-09-13 06:59:02.794 | Usage end date: 2024-09-23 2024-09-13 06:59:02.794 | Enabled for: Sierra Chart Historical Data Service. 2024-09-13 06:59:02.794 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-09-13 06:59:02.794 | Enabled for: Delayed Denali Exchange Data Feed. 2024-09-13 06:59:02.794 | Enabled for exchange2: CME 2024-09-13 06:59:02.794 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-09-13 06:59:02.794 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-09-13 06:59:02.794 | Custom symbol settings values: disabled 2024-09-13 06:59:02.794 | Chart Update Interval: 500 2024-09-13 06:59:02.794 | Intraday Data Storage Time Unit: 0 2024-09-13 06:59:02.794 | Time Zone: +00:00:00 (UTC+00) 2024-09-13 06:59:02.794 | 2024-09-13 06:59:02 Local computer time in UTC 2024-09-13 06:59:02.794 | 2024-09-13 06:59:02 Local computer time in SC Time Zone 2024-09-13 06:59:02.794 | 2024-09-13 06:56:31 Server time in UTC 2024-09-13 06:59:02.794 | Local computer UTC time and Server UTC time difference: 1 seconds. 2024-09-13 06:59:02.794 | Program path: D:\SierraChart\ 2024-09-13 06:59:02.794 | Data Files path: D:\SierraChart\Data\ 2024-09-13 06:59:02.794 | OS Version Number: 10.0 2024-09-13 06:59:02.794 | Locale Setting: C 2024-09-13 06:59:02.795 | DLLs: UserContributedStudies_64.dll 2024-09-13 06:59:02.795 | Allowed protected custom studies: 2024-09-13 06:59:02.795 | Crash reporter started: true 2024-09-13 06:59:02.795 | 2024-09-13 06:59:12.002 | Added historical Intraday data request for ESU4.CME to the queue. 2024-09-13 06:59:12.002 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'. 2024-09-13 06:59:12.002 | Triggering next historical data download in queue. 2024-09-13 06:59:12.002 | HD Request # 2 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme 2024-09-13 06:59:12.258 | Reloading all charts with filename: ESU4.CME.scid 2024-09-13 06:59:12.263 | HD Request # 2 | Download start date-time: 2024-03-11 06:59:12.000000. File last date-time: 00:00:00.000000 2024-09-13 06:59:12.263 | HD Request # 2 | Using server: ds13.sierracharts.com port 10149 2024-09-13 06:59:12.263 | Socket (3) | Creating socket. 2024-09-13 06:59:12.263 | Socket (3) | New receive buffer size: 0 2024-09-13 06:59:12.263 | Socket (3) | Connecting to IP: 69.39.70.246. 2024-09-13 06:59:12.327 | ESU4.CME[M] 60 Min #3 | Reloading chart. 2024-09-13 06:59:12.331 | ESU4.CME[M] 60 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU4.CME.scid 2024-09-13 06:59:12.332 | ESU4.CME[M] 60 Min #3 | Chart data loading complete. 2024-09-13 06:59:12.333 | ESU4.CME[M] 5 Min #7 | Reloading chart. 2024-09-13 06:59:12.336 | ESU4.CME[M] 5 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU4.CME.scid 2024-09-13 06:59:12.337 | ESU4.CME[M] 5 Min #7 | Chart data loading complete. 2024-09-13 06:59:12.338 | ESU4.CME[M] 15 Min #4 | Reloading chart. 2024-09-13 06:59:12.341 | ESU4.CME[M] 15 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU4.CME.scid 2024-09-13 06:59:12.341 | ESU4.CME[M] 15 Min #4 | Chart data loading complete. 2024-09-13 06:59:12.347 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-09-13 06:59:12.347 | HD Request # 2 | Sending historical data logon request message. 2024-09-13 06:59:12.361 | ESU4.CME[M] #5 | Reloading chart. 2024-09-13 06:59:12.361 | ESU4.CME[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-09-13 06:59:12.365 | ESU4.CME[M] #5 | Chart data loading complete. 2024-09-13 06:59:12.366 | ESU4.CME[M] 1 Day #6 | Reloading chart. 2024-09-13 06:59:12.371 | ESU4.CME[M] 1 Day #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU4.CME.scid 2024-09-13 06:59:12.373 | ESU4.CME[M] 1 Day #6 | Chart data loading complete. 2024-09-13 06:59:12.375 | ESU4.CME[M] 500 Trades #2 | Reloading chart. 2024-09-13 06:59:12.380 | ESU4.CME[M] 500 Trades #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU4.CME.scid 2024-09-13 06:59:12.380 | ESU4.CME[M] 500 Trades #2 | Chart data loading complete. 2024-09-13 06:59:12.382 | ESU4.CME[M] 1 Min #8 | Reloading chart. 2024-09-13 06:59:12.386 | ESU4.CME[M] 1 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU4.CME.scid 2024-09-13 06:59:12.386 | ESU4.CME[M] 1 Min #8 | Chart data loading complete. 2024-09-13 06:59:12.387 | ESU4.CME[M] 30 Min #1 | Reloading chart. 2024-09-13 06:59:12.391 | ESU4.CME[M] 30 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESU4.CME.scid 2024-09-13 06:59:12.392 | ESU4.CME[M] 30 Min #1 | Chart data loading complete. 2024-09-13 06:59:12.881 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-03-11 06:59:12. Record interval: 0. Symbol: ESU24 2024-09-13 06:59:12.924 | HD Request # 2 | Decompressing data. 2024-09-13 06:59:13.113 | HD Request # 2 | Receiving Intraday data for ESU4.CME starting at 2024-03-11 08:09:03.133000 2024-09-13 06:59:13.319 | HD Request # 2 | Timestamp of first Intraday data file record written: 2024-03-11 08:09:03.133000. 2024-09-13 06:59:13.337 | ESU4.CME[M] 15 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-09-13 06:59:13.370 | ESU4.CME[M] 5 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-09-13 06:59:13.400 | ESU4.CME[M] 1 Day #6 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-09-13 06:59:13.424 | ESU4.CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-09-13 06:59:13.465 | ESU4.CME[M] 1 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-09-13 06:59:13.505 | ESU4.CME[M] 500 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-09-13 06:59:13.842 | ESU4.CME[M] 60 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-09-13 07:01:13.740 | Socket (3) | CloseSocket call. 2024-09-13 07:01:13.740 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-09-13 07:01:13.740 | Historical data download thread signaled to stop. 2024-09-13 07:01:13.778 | Socket (3) | Socket gracefully closed by remote side. 2024-09-13 07:01:13.778 | Socket (3) | Closed. 2024-09-13 07:01:13.801 | HD Request # 2 | Received 34446551 Intraday data records from 2024-03-11 08:09:03.133000 to 2024-08-02 02:29:07.373000 (143.8 days. Delay: 42.2 days) and wrote 34446551 records for ESU4.CME 2024-09-13 07:01:13.844 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2024-08-02 02:29:07.373000 2024-09-13 07:01:13.844 | Added 435 Time and Sales records to Intraday data file for ESU4.CME after download. 2024-09-13 07:01:13.844 | HD Request # 2 | Completion time: 2m 1s. 2024-09-13 07:01:13.844 | HD Request # 2 | Intraday data download complete for ESU4.CME. Unique request ID: 2 2024-09-13 07:01:13.844 | Removing historical data download ID 2. 2024-09-13 07:01:13.844 | Real-time Intraday chart data file updates started for ESU4.CME 2024-09-13 07:01:13.844 | Intraday chart data file opened for ESU4.CME 2024-09-13 07:01:13.844 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2024-09-13 07:01:13.844 | 2024-09-13 07:01:13.844 | No download requests in the queue to start downloads for. 2024-09-13 07:01:16.540 | Opened cached Intraday file: D:\SierraChart\Data\ESU4.CME.scid. Thread ID: 18392 |
| [2024-09-13 15:01:19] |
We understand the reason for the problem. We will resolve this now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-13 15:01:30
| [2024-09-13 15:07:36] |
This issue is now resolved, but the problem must have been that you have set a historical data server for CME data here: Sierra Chart Server Settings: CME Exchange Data Feed Historical Server Address Override (Global Settings >> Sierra Chart Server Settings >> General >> Special) And that server was set to DS13.SierraCharts.com Remove that. Or if that is not the issue restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-09-13 18:00:34] |
Thank you, removing it worked!
