Date/Time: Sun, 05 May 2024 16:14:44 +0000
Data Feed
View Count: 205
[2023-05-22 11:23:23] |
User340834 - Posts: 1 |
Hi, I am using TopStepTrader and updated now for additional 39 Dollar per month Level 2 Data to use the DOM in Sierra. But again, I am having the market depth but I not Live Data to use Pulling and Stacking or Current Bids and Asks. That`s very confusing. Please could you advise me, how to use this live data within my combine? To use Teton etc is not an option for me. Do I have to subscripe to a professional trader and buy the additional data for the exchange? Thanks,best |
[2023-05-22 15:24:38] |
John - SC Support - Posts: 31378 |
To begin with, you have not activated any exchanges for which you want the live data. If you are wanting data for the CME Group, then you need to understand that the CME Group has a requirement that you have a live, funded, futures trading account to which you can connect your Sierra Chart software in order to qualify for the Non-Professional exchange fees. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Also, a Prop Firm account (such as TopStep) does not count towards the above requirement, as you are not trading your own funds. As noted in the above link, if you do not have your own account, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement Once you work out the above for the CME Group, then you can follow through the instructions at the following link to get the data setup: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
