Date/Time: Fri, 13 Nov 2026 22:08:40 +0000
Rela time data
View Count: 886
[2022-11-03 16:19:51]
Sarven k. Kalaygian - Posts: 10
I paid $3.5 for cme real data but it still delayed
[2022-11-03 17:44:43]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2022-11-03 17:48:42]
Denali Data Feed Exchange(s) have been canceled on your account due to Insufficient account balance for renewal.
You can reactivate the recently deactivated exchanges from this page: https://www.sierrachart.com/UserControlPanel.php?page=RecurringServices#RecentlyDeactivatedRecurringServices
To add funds to your account, go to: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
If you have already reactivated the Exchange(s), then ignore this message.
[2022-11-03 20:46:58]
If that was the case when you first posted, then it would explain the situation. When we looked at your account the Full CME Group was activated, therefore we thought there was another issue.
[2022-11-03 20:59:42]
im still getting delayed data.
[2022-11-03 21:53:00]
Then we need to see your Message Log by following these instructions:
[2022-11-04 09:43:29]
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
[2022-11-04 17:04:05]
can you give a link please i cant find it
[2022-11-04 17:10:18]
You need to connect your Sierra Chart to your live trading account. What broker do you have an account with?
[2022-11-04 17:12:32]
transact
[2022-11-04 17:52:40]
We see that your Trading Account Verification is now set to November 30, 2022 so you will be able to get the real-time data from our Denali Exchange Data Feed until that time.
Just be aware that TransAct stopped support for Sierra Chat several months ago. So you will not be able to continue to connect to your TransAct account to verify your non-professional standing for the CME Group.
If you want to continue to use Sierra Chart for trading, then you will need to change brokers. We recommend a broker that supports our Teton Order Routing Service. You will find the list of brokers that support this service at Step #2 of the Setup Instructions for the Teton Order Routing Service here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
If you want to use Sierra Chart just for charting, then you will still need to have a trading account you can use to verify your non-professional status for the CME Group. We recommend the solution outlined at the following link:
