Date/Time: Mon, 29 Apr 2024 00:08:06 +0000
Trading stocks
View Count: 373
[2022-03-31 12:30:37] |
BL - Posts: 2 |
Hello, I only trade stocks. I signed up for Real Time Nasdaq Total View. Do I need any other data feed activated to get real time stock data? My account is still not showing data in real time. |
[2022-03-31 15:27:44] |
Your account is properly set up for the NASDAQ TotalView data feed. Make sure you are using the correct symbols. Refer to step 7 here: How to Use New NASDAQ Total View Data Feed | Post: 293421 If you are still receiving delayed data: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-31 15:27:59
