Date/Time: Sat, 28 Nov 2026 12:52:11 +0000
slow data on demo account but normal on CQG
View Count: 1024
| [2022-02-07 16:59:31] |
| User181801 - Posts: 47 |
Hello and thank you for your help, I have a live account via GCQ feed which is working well but when I trade on my Trading Evaluator I get a very big delay in all price DOMs an also I place orders and take seconds to go through. What could I do about this? Thanks again Panos |
| [2022-02-07 17:38:48] |
For now close all of the charts you have open and just open a single chart and follow the instructions below. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-07 17:39:24
| [2022-02-08 12:04:31] |
Thanks for your answer. The symbol of the chart is ESH22 and the log is bellow: Software version: 2333 64-bit | 2022-02-08 12:01:04.354 Primary Thread ID: 1996 | 2022-02-08 12:01:04.354 Usage end date: 2022-03-11 | 2022-02-08 12:01:04.354 Enabled for: Advanced Features 2. | 2022-02-08 12:01:04.354 Enabled for: Sierra Chart Historical Data Service. | 2022-02-08 12:01:04.354 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-08 12:01:04.354 Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-08 12:01:04.354 Enabled for exchange2: CME (Trading Account Required) | 2022-02-08 12:01:04.354 Enabled for exchange2: CBOT (Trading Account Required) | 2022-02-08 12:01:04.354 Enabled for exchange2: COMEX (Trading Account Required) | 2022-02-08 12:01:04.354 Enabled for exchange2: NYMEX (Trading Account Required) | 2022-02-08 12:01:04.354 Enabled for exchange2: fairx_exchange.data | 2022-02-08 12:01:04.354 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-08 12:01:04.354 Current selected Data/Trading service: Trading Evaluator | 2022-02-08 12:01:04.354 Custom symbol settings values: enabled | 2022-02-08 12:01:04.354 Chart Update Interval: 200 | 2022-02-08 12:01:04.354 Intraday Data Storage Time Unit: 0 | 2022-02-08 12:01:04.354 Time Zone: +00:00:00 (UTC+00) | 2022-02-08 12:01:04.354 2022-02-08 12:01:04 Local computer time in UTC | 2022-02-08 12:01:04.354 2022-02-08 12:01:04 Local computer time in SC Time Zone | 2022-02-08 12:01:04.354 2022-02-08 11:58:12 Server time in UTC | 2022-02-08 12:01:04.354 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-02-08 12:01:04.354 Program path: C:\SierraChart\ | 2022-02-08 12:01:04.354 Data Files path: C:\SierraChart\Data\ | 2022-02-08 12:01:04.354 OS Version Number: 10.0 | 2022-02-08 12:01:04.354 Locale Setting: C | 2022-02-08 12:01:04.354 DLLs: UserContributedStudies_64.dll | 2022-02-08 12:01:04.355 Allowed protected custom studies: | 2022-02-08 12:01:04.355 ESH22 #1 | Reloading chart. | 2022-02-08 12:01:40.520 ESH22 #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-08 12:01:40.520 Requesting market depth updates for: ESH22 if supported. | 2022-02-08 12:01:41.004 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-02-08 12:01:41.004 SC Data - All Services | Clearing market depth for ESH22 | 2022-02-08 12:01:41.191 File >> Disconnect selected. | 2022-02-08 12:02:39.029 Trading Evaluator | Waiting for socket receive thread to end | 2022-02-08 12:02:39.029 DTC Client socket (1) | CloseSocket call. | 2022-02-08 12:02:39.030 DTC Client socket (1) | Max send buffers used during socket life: 4 | 2022-02-08 12:02:39.030 DTC Client socket (1) | Max send buffer size during socket life: 743 | 2022-02-08 12:02:39.030 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-02-08 12:02:39.030 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-02-08 12:02:39.032 DTC Client socket (6) | CloseSocket call. | 2022-02-08 12:02:39.032 DTC Client socket (6) | Max send buffers used during socket life: 4 | 2022-02-08 12:02:39.032 DTC Client socket (6) | Max send buffer size during socket life: 1086 | 2022-02-08 12:02:39.032 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-02-08 12:02:39.032 WSACleanup called. | 2022-02-08 12:02:39.032 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2022-02-08 12:02:39.033 SC Data - All Services | Waiting for socket receive thread to end | 2022-02-08 12:02:39.033 DTC Client socket (2) | CloseSocket call. | 2022-02-08 12:02:39.034 DTC Client socket (2) | Max send buffers used during socket life: 4 | 2022-02-08 12:02:39.035 DTC Client socket (2) | Max send buffer size during socket life: 2221 | 2022-02-08 12:02:39.035 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-02-08 12:02:39.035 SC Data - All Services | Disconnected from the server. | 2022-02-08 12:02:39.035 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-02-08 12:02:39.035 DTC Client socket (4) | CloseSocket call. | 2022-02-08 12:02:39.036 SC DTC Data with Market Depth | Disconnected from the server. | 2022-02-08 12:02:39.036 Trading Evaluator | Disconnected. | 2022-02-08 12:02:39.036 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-02-08 12:02:39.036 DTC Client socket (6) | Socket gracefully closed by remote side. | 2022-02-08 12:02:39.175 DTC Client socket (6) | Closed. | 2022-02-08 12:02:39.176 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-02-08 12:02:39.182 DTC Client socket (1) | Closed. | 2022-02-08 12:02:39.182 Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2022-02-08 12:02:45.821 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-02-08 12:02:45.822 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-02-08 12:02:45.822 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-02-08 12:02:45.822 Trading Evaluator | Network connection to server complete. | 2022-02-08 12:02:45.971 Trading Evaluator | Starting socket receive thread. | 2022-02-08 12:02:45.971 Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2022-02-08 12:02:45.972 Trading Evaluator | Setting DTC encoding to Binary VLS | 2022-02-08 12:02:46.412 Trading Evaluator | Sending logon request message. | 2022-02-08 12:02:46.412 Trading Evaluator | Received logon response. | 2022-02-08 12:02:47.010 Trading Evaluator | Server Name: SC DTC Server. Build=40925. | 2022-02-08 12:02:47.010 Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2022-02-08 12:02:47.010 Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2022-02-08 12:02:47.010 Trading Evaluator | Trading is supported. | 2022-02-08 12:02:47.010 Trading Evaluator | Order cancel and replace is supported. | 2022-02-08 12:02:47.010 Trading Evaluator | OCO Orders supported. | 2022-02-08 12:02:47.010 Trading Evaluator | Bracket Orders supported. | 2022-02-08 12:02:47.010 Trading Evaluator | Connected to server complete. | 2022-02-08 12:02:47.010 Triggering next historical data download in queue. | 2022-02-08 12:02:47.012 Triggering next historical data download in queue. | 2022-02-08 12:02:47.012 Triggering next historical data download in queue. | 2022-02-08 12:02:47.012 Triggering next historical data download in queue. | 2022-02-08 12:02:47.012 No download requests in the queue to start downloads for. | 2022-02-08 12:02:47.012 No download requests in the queue to start downloads for. | 2022-02-08 12:02:47.012 No download requests in the queue to start downloads for. | 2022-02-08 12:02:47.012 No download requests in the queue to start downloads for. | 2022-02-08 12:02:47.012 Mapping ESH22 to ESH22. Service code: cme | 2022-02-08 12:02:47.191 SC Data - All Services | Starting real-time market data updates for: ESH22 (ESH22). ID: 1 Service code: cme | 2022-02-08 12:02:47.191 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-02-08 12:02:47.191 SC Data - All Services | Requesting security definition data for: ESH22 (ESH22). ID: 1 | 2022-02-08 12:02:47.191 Added historical Intraday data request for ESH22 to the queue. | 2022-02-08 12:02:47.191 Intraday data recording state for symbol ESH22 is set to download 'Pending'. | 2022-02-08 12:02:47.191 Triggering next historical data download in queue. | 2022-02-08 12:02:47.191 Delaying start of download for ESH22 | 2022-02-08 12:02:47.195 DTC Client socket (3) | Creating socket. | 2022-02-08 12:02:47.246 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-02-08 12:02:47.246 DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-02-08 12:02:47.246 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH22 | 2022-02-08 12:02:47.335 Trading Evaluator | Received security definition for symbol ESH22 | 2022-02-08 12:02:47.335 SC Data - All Services | Network connection to server complete. | 2022-02-08 12:02:47.405 SC Data - All Services | Starting socket receive thread. | 2022-02-08 12:02:47.405 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-02-08 12:02:47.405 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-02-08 12:02:47.574 SC Data - All Services | Sending logon request message. | 2022-02-08 12:02:47.574 SC Data - All Services | Received logon response. | 2022-02-08 12:02:48.482 SC Data - All Services | Server Name: SC Realtime Server. | 2022-02-08 12:02:48.482 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-02-08 12:02:48.482 SC Data - All Services | Successfully connected. | 2022-02-08 12:02:48.482 SC Data - All Services | Trading is not supported. | 2022-02-08 12:02:48.482 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22 | 2022-02-08 12:02:48.482 SC Data - All Services | Received security definition for symbol ESH22 | 2022-02-08 12:02:48.699 Requesting market depth updates for: ESH22 if supported. | 2022-02-08 12:02:51.998 SC Data - All Services (Market Orders Data) | Connecting to the server ds22.sierracharts.com. Port 10060 | 2022-02-08 12:02:52.000 DTC Client socket (5) | Creating socket. | 2022-02-08 12:02:52.001 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-02-08 12:02:52.001 DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2022-02-08 12:02:52.002 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-02-08 12:02:52.155 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-02-08 12:02:52.155 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-02-08 12:02:52.156 SC Data - All Services | Clearing market depth for ESH22 | 2022-02-08 12:02:52.231 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-02-08 12:02:52.339 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-02-08 12:02:52.339 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-02-08 12:02:53.235 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-02-08 12:02:53.235 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-02-08 12:02:53.235 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-02-08 12:02:53.235 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-02-08 12:02:53.235 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-02-08 12:02:53.235 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-02-08 12:02:53.235 HD Request # 25 | Downloading Intraday chart data for ESH22 to the file ESH22.scid. Service: cme | 2022-02-08 12:02:53.357 HD Request # 25 | Download start date-time: 2022-02-08 12:02:38.000000. File last date-time: 2022-02-08 12:02:38.343000 | 2022-02-08 12:02:53.358 HD Request # 25 | Using server: ds23.sierracharts.com port 10150 | 2022-02-08 12:02:53.358 Socket (6) | Creating socket. | 2022-02-08 12:02:53.358 Socket (6) | New receive buffer size: 5242880 | 2022-02-08 12:02:53.358 Socket (6) | Connecting to IP: 216.1.90.130. | 2022-02-08 12:02:53.358 HD Request # 25 | Setting DTC encoding to Binary VLS | 2022-02-08 12:02:53.670 HD Request # 25 | Sending historical data logon request message. | 2022-02-08 12:02:53.670 HD Request # 25 | Requesting Intraday data. Start date-time: 2022-02-08 12:02:38. Record interval: 0. Symbol: ESH22 | 2022-02-08 12:02:54.277 HD Request # 25 | Decompressing data. | 2022-02-08 12:02:54.428 HD Request # 25 | Receiving Intraday data for ESH22 starting at 2022-02-08 12:02:38.343000 | 2022-02-08 12:02:54.429 Socket (6) | CloseSocket call. | 2022-02-08 12:02:54.430 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-02-08 12:02:54.430 Historical data download thread signaled to stop. | 2022-02-08 12:02:54.430 HD Request # 25 | Timestamp of first Intraday data file record written: 2022-02-08 12:02:41.571000 | 2022-02-08 12:02:54.431 HD Request # 25 | Received 44 Intraday data records from 2022-02-08 12:02:38.343000 to 2022-02-08 12:02:53.299004 (15.0 seconds) and wrote 43 records for ESH22 | 2022-02-08 12:02:54.431 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2022-02-08 12:02:53.299004 | 2022-02-08 12:02:54.440 HD Request # 25 | Completion time: 1s | 2022-02-08 12:02:54.440 HD Request # 25 | Intraday data download complete for ESH22. Unique request ID: 25 | 2022-02-08 12:02:54.440 Removing historical data download ID 25. | 2022-02-08 12:02:54.440 Real-time Intraday chart data file updates started for ESH22 | 2022-02-08 12:02:54.440 Intraday chart data file opened for ESH22 | 2022-02-08 12:02:54.440 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2022-02-08 12:02:54.440 Triggering next historical data download in queue. | 2022-02-08 12:02:54.440 No download requests in the queue to start downloads for. | 2022-02-08 12:02:54.441 Socket (6) | Socket gracefully closed by remote side. | 2022-02-08 12:02:54.576 Socket (6) | Closed. | 2022-02-08 12:02:54.576 Opened cached Intraday file: C:\SierraChart\Data\ESH22.scid. Thread ID: 2912 | 2022-02-08 12:02:55.378 |
| [2022-02-08 12:45:38] |
Everything looks good in this Message Log. Are you noticing any problem now?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-08 12:45:50
| [2022-02-08 14:33:08] |
Yes, there is a considerable difference between my live account and my Trading Evaluator in how the numbers update on screen on all DOMs. Could I refer to any incoming data settings given my usual internet download speed is 50Mbps? |
| [2022-02-08 15:48:57] |
There must be some settings difference or configuration difference. Refer to the information here: Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-14 14:17:30] |
I have gone through the documentation and settings. The problem still persists. Apart from the DOM's the whole system is lagging when in trading evaluator mode, compared to my live account where things work smooth. I know this is very weird. Charts dont zoom in and out, updates are very slow etc. I am sorry to keep coming back to you, but the difference is huge. I can try recording screen so you can see it yourself if that helps. |
| [2022-02-14 14:25:07] |
It could not have anything to do with the selected Service. This is really impossible. There must be some difference we are not aware of. You need to work out performance issues on your side . We are not going to know about them. Refer to this help topic: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Are you using the same installation of Sierra Chart? It does not help us to show a screen recording. This is meaningless to us. There is a performance issue based upon what you are doing with Sierra Chart and your system. You have to resolve that on your side. We cannot do that. This is for you to solve. It does not help to come back to us. Solve the problem on your side. Start with a new Chartbook. Start with a completely new Chartbook. Start with a single chart and see if you have a problem. If you do not, then your problem is solved and then you can build up from there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-14 14:29:13
