Date/Time: Mon, 29 Apr 2024 09:41:32 +0000
Trail account
View Count: 460
[2021-12-20 15:15:52] |
User284974 - Posts: 6 |
Dear Sirs, I currently have a Trail account setup and would like to clarify if the NYMEX Live feed is active. At this point I'm only interested in Crude oil and hence would like to follow this market specifically before moving forward? If, it's a delayed feed what setup/purchase do I need to a get such a live feed? Thank you |
[2021-12-20 16:26:41] |
What you are getting right now is the Delayed Streaming Data for the CME Group. This data acts in all ways the same as real-time data, only it is delayed by 10 minutes. We really recommend using this delayed data while learning to use Sierra Chart, as there is no additional cost and you do not need to have a trading account. If you really want to have real-time data, then it will be necessary for you to have a live, funded, futures trading account that you can connect to at least once a month for verification. Refer to the following for more information: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have a trading account that we can connect to, then refer to the following service: Easy Solution to CME Funded Trading Account Requirement Once you have the above worked out, then to get the CME Group data, you would need to go through the setup instructions for the Denali Exchange Data Feed for the CME Group at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
