Date/Time: Mon, 28 Sep 2026 23:08:08 +0000
real data feed
View Count: 804
| [2021-12-07 21:42:13] |
| Haxmalaga - Posts: 2 |
I need forex, Gold, CL ans ES to be honest . I have acc on AMP also |
| [2021-12-07 23:08:08] |
| John - SC Support - Posts: 48044 |
We provide real-time Forex data from FXCM with any Sierra Chart package at no additional cost, so you have access to this data already. Refer to the following for more information: Sierra Chart Real Time and Historical Forex and CFD Data Service Gold (GC), Crude Oil (CL) and the S&P 500 Index Futures (ES) are all part of the CME Group. The real-time data for the CME Group is part of our Denali Exchange Data Feed. You will find the Setup Instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-12-08 00:00:29] |
Hi. I dont know what iam doing. My engmish not good. I paid 2 times and made all what there said and still delay on Sierra. What iam doing wrong ? Can you check my acc? |
| [2021-12-08 15:10:09] |
You should be getting real-time data for the EUREX instruments. If not, then let us know. Although you did deactivate that exchange, so you will only get data through the end of this month for EUREX, as it will not automatically renew. If you do want to continue to get EUREX data, then you will want to select the Activate button for the exchange on the following page (you will not be charged again for this exchange until January 1, 2022): https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedEUREX#Exchanges With regards to the CME Data, you must understand that in order to get the data at the much lower cost non-professional rates, you need to have a live, funded, futures trading account that you can connect your Sierra Chart to. As part of this, you also need to specify the broker you are working with for your trading account and your account number in the Exchange Agreements. You did not enter the necessary information in the Exchange Agreement, therefore you are not able to activate the non-professional CME exchanges. For more information on this requirement, refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have a trading account, then we recommend using the Delayed Streaming Data for the CME Group and EUREX, as it acts the same as real-time data, only it is delayed by 10-15 minutes. There is also no additional cost for this data with any Sierra Chart package. Refer to the following for more information: Delayed Exchange Data Feed If you need to have the real-time data and do not have a trading account, then we recommend the service outlined at the following link, which will allow you to create an account for a minimal outlay of funds: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
