Date/Time: Sat, 18 May 2024 18:02:45 +0000
Cannot Connect to TransAct Data Feed
View Count: 398
[2021-10-08 18:22:38] |
lgenna - Posts: 2 |
Hello I am on the Sierra Chart Trial and I am unable to connect to my live trading account with Infinity Futures. Can you help?
[2021-10-08 23:48:28] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-11 15:07:41] |
lgenna - Posts: 2 |
Software version: 2315 64-bit | 2021-10-11 14:57:40.644 Primary Thread ID: 8468 | 2021-10-11 14:57:40.644 Usage end date: 2021-10-21 | 2021-10-11 14:57:40.644 Enabled for: Advanced Features 2. | 2021-10-11 14:57:40.644 Enabled for: Sierra Chart Historical Data Service. | 2021-10-11 14:57:40.644 Enabled for: Delayed Denali Exchange Data Feed. | 2021-10-11 14:57:40.644 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-10-11 14:57:40.644 Current selected Data/Trading service: TransAct WS | 2021-10-11 14:57:40.644 Custom symbol settings values: enabled | 2021-10-11 14:57:40.644 Chart Update Interval: 500 | 2021-10-11 14:57:40.644 Intraday Data Storage Time Unit: 1 | 2021-10-11 14:57:40.644 Time Zone: +00:00:00 (UTC+00) | 2021-10-11 14:57:40.644 2021-10-11 14:57:40 Local computer time in UTC | 2021-10-11 14:57:40.644 2021-10-11 14:57:40 Local computer time in SC Time Zone | 2021-10-11 14:57:40.644 2021-10-11 14:53:27 Server time in UTC | 2021-10-11 14:57:40.644 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-10-11 14:57:40.644 Program path: C:\SierraChart\ | 2021-10-11 14:57:40.644 Data Files path: C:\SierraChart\Data\ | 2021-10-11 14:57:40.644 OS Version Number: 10.0 | 2021-10-11 14:57:40.644 Locale Setting: C | 2021-10-11 14:57:40.644 DLLs: BetterVolume.dll, HindsightTrading.dll, HoffmanStarter.dll, NoTradeZones.dll, SharkBands.dll, TraderSharkMAs.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VCValueLevels.dll | 2021-10-11 14:57:40.645 Allowed protected custom studies: | 2021-10-11 14:57:40.645 Auth Websocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-10-11 14:58:51.072 Auth Websocket socket (1) | Closed. | 2021-10-11 14:58:51.073 Auth Websocket socket (1) | Deleting network socket now after delay. | 2021-10-11 14:59:21.075 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:32.646 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:32.646 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:32.646 Auth Websocket socket (1) | New receive buffer size: 5242880 | 2021-10-11 15:00:32.646 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:32.646 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:32.688 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:32.688 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:32.840 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:32.840 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:32.840 Auth Websocket | Server header | Sec-WebSocket-Accept: g4Ptxq9ZSHVrkAPAa0W63ymoT+E= | 2021-10-11 15:00:32.840 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:32.840 Auth Websocket | Server header | | 2021-10-11 15:00:32.840 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:32.840 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:32.840 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:32.931 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:32.931 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:32.931 TransAct WS | Session key cleared | 2021-10-11 15:00:33.001 Auth Websocket socket (1) | CloseSocket call. | 2021-10-11 15:00:33.001 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:33.001 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:33.001 TransAct WS | Disconnected. | 2021-10-11 15:00:33.001 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:33.001 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:33.038 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:33.039 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:34.001 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:34.001 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:34.002 Auth Websocket socket (2) | New receive buffer size: 5242880 | 2021-10-11 15:00:34.002 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:34.003 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:34.049 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:34.049 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:34.180 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:34.180 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:34.180 Auth Websocket | Server header | Sec-WebSocket-Accept: wrq38aSsxJK3KtIatsdYF3dg/CQ= | 2021-10-11 15:00:34.180 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:34.180 Auth Websocket | Server header | | 2021-10-11 15:00:34.180 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:34.180 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:34.180 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:34.256 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:34.256 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:34.256 TransAct WS | Session key cleared | 2021-10-11 15:00:34.266 Auth Websocket socket (2) | CloseSocket call. | 2021-10-11 15:00:34.266 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:34.266 TransAct WS | Disconnected. | 2021-10-11 15:00:34.267 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:34.267 Auth Websocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:34.267 Auth Websocket socket (2) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:34.302 Auth Websocket socket (2) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:34.303 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:35.265 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:35.265 Auth Websocket socket (3) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:35.265 Auth Websocket socket (3) | New receive buffer size: 5242880 | 2021-10-11 15:00:35.266 Auth Websocket socket (3) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:35.266 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:35.302 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:35.302 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:35.435 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:35.435 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:35.435 Auth Websocket | Server header | Sec-WebSocket-Accept: tjYrRvXfhjb+NAZZFYA9qkYXwJQ= | 2021-10-11 15:00:35.435 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:35.435 Auth Websocket | Server header | | 2021-10-11 15:00:35.435 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:35.435 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:35.435 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:35.550 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:35.550 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:35.550 TransAct WS | Session key cleared | 2021-10-11 15:00:35.561 Auth Websocket socket (3) | CloseSocket call. | 2021-10-11 15:00:35.561 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:35.561 TransAct WS | Disconnected. | 2021-10-11 15:00:35.562 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:35.562 Auth Websocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:35.562 Auth Websocket socket (3) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:35.594 Auth Websocket socket (3) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:35.594 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:36.561 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:36.561 Auth Websocket socket (4) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:36.562 Auth Websocket socket (4) | New receive buffer size: 5242880 | 2021-10-11 15:00:36.562 Auth Websocket socket (4) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:36.562 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:36.614 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:36.614 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:36.752 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:36.752 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:36.752 Auth Websocket | Server header | Sec-WebSocket-Accept: /0ehS7MxTsxzs8gZSZzy3h4Szsk= | 2021-10-11 15:00:36.752 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:36.752 Auth Websocket | Server header | | 2021-10-11 15:00:36.752 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:36.752 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:36.752 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:36.843 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:36.843 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:36.843 TransAct WS | Session key cleared | 2021-10-11 15:00:36.858 Auth Websocket socket (4) | CloseSocket call. | 2021-10-11 15:00:36.858 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:36.858 Auth Websocket socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:36.858 TransAct WS | Disconnected. | 2021-10-11 15:00:36.858 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:36.859 Auth Websocket socket (4) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:36.896 Auth Websocket socket (4) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:36.897 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:37.862 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:37.862 Auth Websocket socket (5) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:37.862 Auth Websocket socket (5) | New receive buffer size: 5242880 | 2021-10-11 15:00:37.862 Auth Websocket socket (5) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:37.862 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:37.909 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:37.909 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:38.038 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:38.038 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:38.038 Auth Websocket | Server header | Sec-WebSocket-Accept: +fe28t4+1XbkX7mtlK9Q2AZPkIQ= | 2021-10-11 15:00:38.038 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:38.038 Auth Websocket | Server header | | 2021-10-11 15:00:38.038 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:38.038 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:38.038 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:38.125 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:38.125 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:38.125 TransAct WS | Session key cleared | 2021-10-11 15:00:38.128 Auth Websocket socket (5) | CloseSocket call. | 2021-10-11 15:00:38.128 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:38.128 TransAct WS | Disconnected. | 2021-10-11 15:00:38.128 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:38.128 Auth Websocket socket (5) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:38.128 Auth Websocket socket (5) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:38.162 Auth Websocket socket (5) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:38.162 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:39.143 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:39.143 Auth Websocket socket (6) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:39.143 Auth Websocket socket (6) | New receive buffer size: 5242880 | 2021-10-11 15:00:39.143 Auth Websocket socket (6) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:39.143 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:39.186 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:39.186 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:39.317 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:39.317 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:39.317 Auth Websocket | Server header | Sec-WebSocket-Accept: wrf+uAQMGaxHjKzd9WAjVFSLohk= | 2021-10-11 15:00:39.317 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:39.317 Auth Websocket | Server header | | 2021-10-11 15:00:39.317 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:39.317 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:39.317 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:39.410 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:39.410 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:39.410 TransAct WS | Session key cleared | 2021-10-11 15:00:39.424 Auth Websocket socket (6) | CloseSocket call. | 2021-10-11 15:00:39.424 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:39.424 TransAct WS | Disconnected. | 2021-10-11 15:00:39.424 Auth Websocket socket (6) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:39.424 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:39.424 Auth Websocket socket (6) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:39.461 Auth Websocket socket (6) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:39.461 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:40.424 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:40.424 Auth Websocket socket (7) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:40.425 Auth Websocket socket (7) | New receive buffer size: 5242880 | 2021-10-11 15:00:40.425 Auth Websocket socket (7) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:40.425 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:40.469 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:40.469 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:40.591 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:40.591 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:40.591 Auth Websocket | Server header | Sec-WebSocket-Accept: o12T5h1uu9MDY3xzD07jpQ+rjY4= | 2021-10-11 15:00:40.591 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:40.591 Auth Websocket | Server header | | 2021-10-11 15:00:40.591 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:40.591 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:40.591 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:40.677 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:40.677 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:40.677 TransAct WS | Session key cleared | 2021-10-11 15:00:40.689 Auth Websocket socket (7) | CloseSocket call. | 2021-10-11 15:00:40.689 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:40.689 TransAct WS | Disconnected. | 2021-10-11 15:00:40.689 Auth Websocket socket (7) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:40.689 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:40.689 Auth Websocket socket (7) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:40.727 Auth Websocket socket (7) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:40.727 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:41.689 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:41.689 Auth Websocket socket (8) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:41.689 Auth Websocket socket (8) | New receive buffer size: 5242880 | 2021-10-11 15:00:41.690 Auth Websocket socket (8) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:41.690 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:41.730 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:41.730 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:41.859 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:41.859 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:41.859 Auth Websocket | Server header | Sec-WebSocket-Accept: /AWTF7Dgc+3oC9xvQ3N0Faa7izM= | 2021-10-11 15:00:41.859 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:41.859 Auth Websocket | Server header | | 2021-10-11 15:00:41.859 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:41.859 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:41.859 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:41.949 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:41.949 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:41.949 TransAct WS | Session key cleared | 2021-10-11 15:00:41.955 Auth Websocket socket (8) | CloseSocket call. | 2021-10-11 15:00:41.955 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:41.955 Auth Websocket socket (8) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:41.955 TransAct WS | Disconnected. | 2021-10-11 15:00:41.955 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:41.955 Auth Websocket socket (8) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:41.992 Auth Websocket socket (8) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:41.992 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:42.955 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:42.955 Auth Websocket socket (9) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:42.956 Auth Websocket socket (9) | New receive buffer size: 5242880 | 2021-10-11 15:00:42.956 Auth Websocket socket (9) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:42.956 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:42.997 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:42.997 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:43.121 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:43.121 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:43.121 Auth Websocket | Server header | Sec-WebSocket-Accept: sU4LUN2eP+A27DY1f7bqauf7cyc= | 2021-10-11 15:00:43.121 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:43.121 Auth Websocket | Server header | | 2021-10-11 15:00:43.121 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:43.121 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:43.121 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:43.212 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:43.212 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:43.212 TransAct WS | Session key cleared | 2021-10-11 15:00:43.220 Auth Websocket socket (9) | CloseSocket call. | 2021-10-11 15:00:43.220 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:43.220 TransAct WS | Disconnected. | 2021-10-11 15:00:43.220 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:43.220 Auth Websocket socket (9) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:43.220 Auth Websocket socket (9) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:43.261 Auth Websocket socket (9) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:43.261 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:44.236 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:44.236 Auth Websocket socket (10) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:44.236 Auth Websocket socket (10) | New receive buffer size: 5242880 | 2021-10-11 15:00:44.237 Auth Websocket socket (10) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:44.237 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:44.278 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:44.278 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:44.417 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:44.417 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:44.417 Auth Websocket | Server header | Sec-WebSocket-Accept: FBEojB5n140DVQiU6Dez+TcIJ+o= | 2021-10-11 15:00:44.417 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:44.417 Auth Websocket | Server header | | 2021-10-11 15:00:44.417 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:44.417 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:44.417 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:44.505 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:44.505 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:44.505 TransAct WS | Session key cleared | 2021-10-11 15:00:44.517 Auth Websocket socket (10) | CloseSocket call. | 2021-10-11 15:00:44.517 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:44.517 TransAct WS | Disconnected. | 2021-10-11 15:00:44.517 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:44.517 Auth Websocket socket (10) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:44.517 Auth Websocket socket (10) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:44.555 Auth Websocket socket (10) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:44.555 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:45.517 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:45.517 Auth Websocket socket (11) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:45.518 Auth Websocket socket (11) | New receive buffer size: 5242880 | 2021-10-11 15:00:45.518 Auth Websocket socket (11) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:45.518 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:45.555 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:45.555 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:45.689 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:45.689 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:45.689 Auth Websocket | Server header | Sec-WebSocket-Accept: M2Xz+lvtqHfFMYCnhJD+HRUeFqw= | 2021-10-11 15:00:45.689 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:45.689 Auth Websocket | Server header | | 2021-10-11 15:00:45.690 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:45.690 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:45.690 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:45.774 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:45.774 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:45.774 TransAct WS | Session key cleared | 2021-10-11 15:00:45.783 Auth Websocket socket (11) | CloseSocket call. | 2021-10-11 15:00:45.783 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:45.783 Auth Websocket socket (11) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:45.783 TransAct WS | Disconnected. | 2021-10-11 15:00:45.783 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:45.784 Auth Websocket socket (11) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:45.819 Auth Websocket socket (11) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:45.819 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:46.783 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:46.783 Auth Websocket socket (12) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:46.783 Auth Websocket socket (12) | New receive buffer size: 5242880 | 2021-10-11 15:00:46.784 Auth Websocket socket (12) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:46.784 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:46.828 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:46.828 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:46.972 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:46.972 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:46.972 Auth Websocket | Server header | Sec-WebSocket-Accept: b8ggs3XDdanPWT1JRzg0nOUrHeY= | 2021-10-11 15:00:46.972 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:46.972 Auth Websocket | Server header | | 2021-10-11 15:00:46.972 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:46.972 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:46.972 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:47.061 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:47.061 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:47.061 TransAct WS | Session key cleared | 2021-10-11 15:00:47.064 Auth Websocket socket (12) | CloseSocket call. | 2021-10-11 15:00:47.064 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:47.064 TransAct WS | Disconnected. | 2021-10-11 15:00:47.064 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:47.064 Auth Websocket socket (12) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:47.064 Auth Websocket socket (12) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:47.107 Auth Websocket socket (12) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:47.107 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:48.064 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:48.064 Auth Websocket socket (13) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:48.064 Auth Websocket socket (13) | New receive buffer size: 5242880 | 2021-10-11 15:00:48.065 Auth Websocket socket (13) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:48.065 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:48.106 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:48.106 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:48.239 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:48.239 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:48.239 Auth Websocket | Server header | Sec-WebSocket-Accept: xdMLZw/KbaOML61HEtGxvAUqmWI= | 2021-10-11 15:00:48.239 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:48.239 Auth Websocket | Server header | | 2021-10-11 15:00:48.239 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:48.239 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:48.239 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:48.330 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:48.330 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:48.330 TransAct WS | Session key cleared | 2021-10-11 15:00:48.345 Auth Websocket socket (13) | CloseSocket call. | 2021-10-11 15:00:48.345 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:48.345 TransAct WS | Disconnected. | 2021-10-11 15:00:48.345 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:48.345 Auth Websocket socket (13) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:48.345 Auth Websocket socket (13) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:48.381 Auth Websocket socket (13) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:48.381 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:49.361 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:49.361 Auth Websocket socket (14) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:49.361 Auth Websocket socket (14) | New receive buffer size: 5242880 | 2021-10-11 15:00:49.362 Auth Websocket socket (14) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:49.362 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:49.406 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:49.406 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:49.549 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:49.549 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:49.549 Auth Websocket | Server header | Sec-WebSocket-Accept: yEDX1hSNJVkNokkdHZzClNbisQc= | 2021-10-11 15:00:49.549 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:49.549 Auth Websocket | Server header | | 2021-10-11 15:00:49.549 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:49.549 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:49.549 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:49.639 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:49.639 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:49.639 TransAct WS | Session key cleared | 2021-10-11 15:00:49.642 Auth Websocket socket (14) | CloseSocket call. | 2021-10-11 15:00:49.642 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:49.643 Auth Websocket socket (14) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:49.643 TransAct WS | Disconnected. | 2021-10-11 15:00:49.643 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:49.643 Auth Websocket socket (14) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:49.681 Auth Websocket socket (14) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:49.681 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:50.643 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:50.643 Auth Websocket socket (15) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:50.643 Auth Websocket socket (15) | New receive buffer size: 5242880 | 2021-10-11 15:00:50.644 Auth Websocket socket (15) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:50.644 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:50.685 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:50.685 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:50.818 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:50.818 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:50.818 Auth Websocket | Server header | Sec-WebSocket-Accept: 5tojVR2NUZhOCg0n10CI0mIAB7w= | 2021-10-11 15:00:50.818 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:50.818 Auth Websocket | Server header | | 2021-10-11 15:00:50.818 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:50.818 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:50.818 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:50.904 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:50.904 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:50.904 TransAct WS | Session key cleared | 2021-10-11 15:00:50.907 Auth Websocket socket (15) | CloseSocket call. | 2021-10-11 15:00:50.907 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:50.907 TransAct WS | Disconnected. | 2021-10-11 15:00:50.907 Auth Websocket socket (15) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:50.907 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:50.907 Auth Websocket socket (15) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:50.945 Auth Websocket socket (15) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:50.945 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:51.907 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:51.907 Auth Websocket socket (16) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:51.908 Auth Websocket socket (16) | New receive buffer size: 5242880 | 2021-10-11 15:00:51.908 Auth Websocket socket (16) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:51.908 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:51.955 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:51.955 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:52.072 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:52.072 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:52.072 Auth Websocket | Server header | Sec-WebSocket-Accept: wXXhkMQIBYyJFe3K4bofhu+ijCM= | 2021-10-11 15:00:52.072 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:52.072 Auth Websocket | Server header | | 2021-10-11 15:00:52.072 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:52.072 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:52.072 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:52.159 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:52.159 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:52.159 TransAct WS | Session key cleared | 2021-10-11 15:00:52.173 Auth Websocket socket (16) | CloseSocket call. | 2021-10-11 15:00:52.173 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:52.173 TransAct WS | Disconnected. | 2021-10-11 15:00:52.173 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:52.173 Auth Websocket socket (16) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:52.173 Auth Websocket socket (16) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:52.207 Auth Websocket socket (16) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:52.207 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:53.174 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:53.174 Auth Websocket socket (17) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:53.174 Auth Websocket socket (17) | New receive buffer size: 5242880 | 2021-10-11 15:00:53.175 Auth Websocket socket (17) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:53.175 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:53.215 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:53.215 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:53.413 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:53.413 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:53.413 Auth Websocket | Server header | Sec-WebSocket-Accept: hzrzO50ocnOJAMvx4OWu97XuHko= | 2021-10-11 15:00:53.413 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:53.413 Auth Websocket | Server header | | 2021-10-11 15:00:53.413 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:53.413 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:53.413 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:53.503 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:53.503 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:53.503 TransAct WS | Session key cleared | 2021-10-11 15:00:53.516 Auth Websocket socket (17) | CloseSocket call. | 2021-10-11 15:00:53.517 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:53.517 Auth Websocket socket (17) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:53.517 TransAct WS | Disconnected. | 2021-10-11 15:00:53.517 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:53.517 Auth Websocket socket (17) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:53.554 Auth Websocket socket (17) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:53.554 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:54.516 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:54.516 Auth Websocket socket (18) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:54.516 Auth Websocket socket (18) | New receive buffer size: 5242880 | 2021-10-11 15:00:54.517 Auth Websocket socket (18) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:54.517 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:54.552 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:54.552 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:54.670 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:54.670 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:54.670 Auth Websocket | Server header | Sec-WebSocket-Accept: lEkQal9zRS81qgMkz+qi+7WWOaQ= | 2021-10-11 15:00:54.670 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:54.670 Auth Websocket | Server header | | 2021-10-11 15:00:54.670 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:54.670 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:54.670 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:54.755 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:54.755 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:54.755 TransAct WS | Session key cleared | 2021-10-11 15:00:54.766 Auth Websocket socket (18) | CloseSocket call. | 2021-10-11 15:00:54.766 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:54.766 TransAct WS | Disconnected. | 2021-10-11 15:00:54.767 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:54.767 Auth Websocket socket (18) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:54.767 Auth Websocket socket (18) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:54.801 Auth Websocket socket (18) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:54.801 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:55.767 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:55.767 Auth Websocket socket (19) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:55.767 Auth Websocket socket (19) | New receive buffer size: 5242880 | 2021-10-11 15:00:55.768 Auth Websocket socket (19) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:55.768 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:55.818 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:55.818 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:55.941 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:55.941 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:55.941 Auth Websocket | Server header | Sec-WebSocket-Accept: Zg0Wv7OGPpmobbTyN8e4itpk/q8= | 2021-10-11 15:00:55.941 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:55.941 Auth Websocket | Server header | | 2021-10-11 15:00:55.942 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:55.942 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:55.942 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:56.031 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:56.031 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:56.031 TransAct WS | Session key cleared | 2021-10-11 15:00:56.032 Auth Websocket socket (19) | CloseSocket call. | 2021-10-11 15:00:56.032 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:56.032 TransAct WS | Disconnected. | 2021-10-11 15:00:56.032 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:56.032 Auth Websocket socket (19) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:56.032 Auth Websocket socket (19) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:56.067 Auth Websocket socket (19) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:56.067 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:57.032 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:57.032 Auth Websocket socket (20) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:57.032 Auth Websocket socket (20) | New receive buffer size: 5242880 | 2021-10-11 15:00:57.032 Auth Websocket socket (20) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:57.032 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:57.067 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:57.067 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:57.186 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:57.187 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:57.187 Auth Websocket | Server header | Sec-WebSocket-Accept: LsS/ICkgBTW3lFz3D6NMXckBfHY= | 2021-10-11 15:00:57.187 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:57.187 Auth Websocket | Server header | | 2021-10-11 15:00:57.187 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:57.187 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:57.187 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:57.271 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:57.271 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:57.271 TransAct WS | Session key cleared | 2021-10-11 15:00:57.282 Auth Websocket socket (20) | CloseSocket call. | 2021-10-11 15:00:57.282 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:57.282 TransAct WS | Disconnected. | 2021-10-11 15:00:57.282 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:57.282 Auth Websocket socket (20) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:57.282 Auth Websocket socket (20) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:57.316 Auth Websocket socket (20) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:57.316 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:58.282 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:58.282 Auth Websocket socket (21) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:58.282 Auth Websocket socket (21) | New receive buffer size: 5242880 | 2021-10-11 15:00:58.282 Auth Websocket socket (21) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:58.282 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:58.319 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:58.319 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:58.452 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:58.452 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:58.452 Auth Websocket | Server header | Sec-WebSocket-Accept: r9Zodd6TMCPqaCsrTxRs8uS4Pyg= | 2021-10-11 15:00:58.452 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:58.452 Auth Websocket | Server header | | 2021-10-11 15:00:58.452 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:58.452 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:58.452 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:58.548 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:58.548 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:58.548 TransAct WS | Session key cleared | 2021-10-11 15:00:58.563 Auth Websocket socket (21) | CloseSocket call. | 2021-10-11 15:00:58.563 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:58.563 TransAct WS | Disconnected. | 2021-10-11 15:00:58.563 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:58.563 Auth Websocket socket (21) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:58.563 Auth Websocket socket (21) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:58.598 Auth Websocket socket (21) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:58.598 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:00:59.563 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:00:59.563 Auth Websocket socket (22) | Creating socket. Using TLS 1.2. | 2021-10-11 15:00:59.564 Auth Websocket socket (22) | New receive buffer size: 5242880 | 2021-10-11 15:00:59.564 Auth Websocket socket (22) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:00:59.564 Auth Websocket | Opening WebSocket. | 2021-10-11 15:00:59.610 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:00:59.610 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:00:59.734 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:00:59.734 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:00:59.734 Auth Websocket | Server header | Sec-WebSocket-Accept: chiZ+bpM6tELJtu3TpEx5jaREcU= | 2021-10-11 15:00:59.734 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:00:59.734 Auth Websocket | Server header | | 2021-10-11 15:00:59.734 Auth Websocket | Web socket state is now open. | 2021-10-11 15:00:59.734 TransAct WS | Sending account logon message. Live | 2021-10-11 15:00:59.734 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:00:59.822 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:00:59.822 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:59.822 TransAct WS | Session key cleared | 2021-10-11 15:00:59.829 Auth Websocket socket (22) | CloseSocket call. | 2021-10-11 15:00:59.829 Auth Websocket | WebSocket closed. | 2021-10-11 15:00:59.829 TransAct WS | Disconnected. | 2021-10-11 15:00:59.829 Auth Websocket socket (22) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:00:59.829 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:00:59.829 Auth Websocket socket (22) | Write has completed. Shutdown being performed. | 2021-10-11 15:00:59.864 Auth Websocket socket (22) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:00:59.864 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:00.829 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:00.829 Auth Websocket socket (23) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:00.829 Auth Websocket socket (23) | New receive buffer size: 5242880 | 2021-10-11 15:01:00.830 Auth Websocket socket (23) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:00.830 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:00.872 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:00.872 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:00.996 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:00.996 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:00.996 Auth Websocket | Server header | Sec-WebSocket-Accept: /TLy0iU72xO82VUztrVBeYmWeyE= | 2021-10-11 15:01:00.996 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:00.996 Auth Websocket | Server header | | 2021-10-11 15:01:00.996 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:00.996 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:00.996 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:01.083 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:01.083 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:01.083 TransAct WS | Session key cleared | 2021-10-11 15:01:01.094 Auth Websocket socket (23) | CloseSocket call. | 2021-10-11 15:01:01.094 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:01.094 TransAct WS | Disconnected. | 2021-10-11 15:01:01.094 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:01.094 Auth Websocket socket (23) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:01.094 Auth Websocket socket (23) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:01.130 Auth Websocket socket (23) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:01.130 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:02.091 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:02.091 Auth Websocket socket (24) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:02.091 Auth Websocket socket (24) | New receive buffer size: 5242880 | 2021-10-11 15:01:02.091 Auth Websocket socket (24) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:02.091 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:02.126 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:02.126 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:02.247 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:02.247 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:02.247 Auth Websocket | Server header | Sec-WebSocket-Accept: P/kLKsqDRfXuYdfFQAiD3GIiQt0= | 2021-10-11 15:01:02.247 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:02.247 Auth Websocket | Server header | | 2021-10-11 15:01:02.247 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:02.247 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:02.247 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:02.333 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:02.333 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:02.333 TransAct WS | Session key cleared | 2021-10-11 15:01:02.341 Auth Websocket socket (24) | CloseSocket call. | 2021-10-11 15:01:02.341 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:02.341 Auth Websocket socket (24) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:02.341 TransAct WS | Disconnected. | 2021-10-11 15:01:02.341 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:02.341 Auth Websocket socket (24) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:02.385 Auth Websocket socket (24) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:02.385 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:03.347 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:03.347 Auth Websocket socket (25) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:03.348 Auth Websocket socket (25) | New receive buffer size: 5242880 | 2021-10-11 15:01:03.348 Auth Websocket socket (25) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:03.348 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:03.389 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:03.389 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:03.523 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:03.523 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:03.523 Auth Websocket | Server header | Sec-WebSocket-Accept: YUURVh8q8oy5uDJUmgWjIgJ+LXc= | 2021-10-11 15:01:03.523 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:03.523 Auth Websocket | Server header | | 2021-10-11 15:01:03.523 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:03.523 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:03.523 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:03.610 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:03.610 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:03.610 TransAct WS | Session key cleared | 2021-10-11 15:01:03.613 Auth Websocket socket (25) | CloseSocket call. | 2021-10-11 15:01:03.613 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:03.613 TransAct WS | Disconnected. | 2021-10-11 15:01:03.613 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:03.613 Auth Websocket socket (25) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:03.614 Auth Websocket socket (25) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:03.650 Auth Websocket socket (25) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:03.650 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:04.612 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:04.612 Auth Websocket socket (26) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:04.613 Auth Websocket socket (26) | New receive buffer size: 5242880 | 2021-10-11 15:01:04.613 Auth Websocket socket (26) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:04.613 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:04.655 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:04.655 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:04.781 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:04.781 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:04.781 Auth Websocket | Server header | Sec-WebSocket-Accept: BhJTL3Khrdx3IlHSq7+GYO9Lc/k= | 2021-10-11 15:01:04.781 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:04.781 Auth Websocket | Server header | | 2021-10-11 15:01:04.781 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:04.781 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:04.782 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:04.872 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:04.872 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:04.872 TransAct WS | Session key cleared | 2021-10-11 15:01:04.878 Auth Websocket socket (26) | CloseSocket call. | 2021-10-11 15:01:04.878 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:04.878 TransAct WS | Disconnected. | 2021-10-11 15:01:04.878 Auth Websocket socket (26) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:04.878 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:04.878 Auth Websocket socket (26) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:04.916 Auth Websocket socket (26) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:04.916 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:05.878 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:05.878 Auth Websocket socket (27) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:05.878 Auth Websocket socket (27) | New receive buffer size: 5242880 | 2021-10-11 15:01:05.879 Auth Websocket socket (27) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:05.879 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:05.921 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:05.921 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:06.048 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:06.048 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:06.048 Auth Websocket | Server header | Sec-WebSocket-Accept: wHv8vNpKd3Iq3MswJd2ujZ2/PLg= | 2021-10-11 15:01:06.048 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:06.048 Auth Websocket | Server header | | 2021-10-11 15:01:06.048 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:06.048 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:06.048 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:06.135 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:06.135 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:06.135 TransAct WS | Session key cleared | 2021-10-11 15:01:06.143 Auth Websocket socket (27) | CloseSocket call. | 2021-10-11 15:01:06.143 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:06.143 TransAct WS | Disconnected. | 2021-10-11 15:01:06.143 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:06.143 Auth Websocket socket (27) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:06.143 Auth Websocket socket (27) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:06.177 Auth Websocket socket (27) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:06.178 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:07.159 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:07.159 Auth Websocket socket (28) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:07.159 Auth Websocket socket (28) | New receive buffer size: 5242880 | 2021-10-11 15:01:07.159 Auth Websocket socket (28) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:07.159 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:07.202 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:07.202 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:07.333 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:07.333 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:07.333 Auth Websocket | Server header | Sec-WebSocket-Accept: +NWqpHoXVABia9C0Bvb6IQeuMPI= | 2021-10-11 15:01:07.333 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:07.333 Auth Websocket | Server header | | 2021-10-11 15:01:07.333 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:07.333 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:07.333 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:07.422 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:07.422 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:07.422 TransAct WS | Session key cleared | 2021-10-11 15:01:07.424 Auth Websocket socket (28) | CloseSocket call. | 2021-10-11 15:01:07.424 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:07.424 TransAct WS | Disconnected. | 2021-10-11 15:01:07.424 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:07.425 Auth Websocket socket (28) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:07.425 Auth Websocket socket (28) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:07.462 Auth Websocket socket (28) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:07.462 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:08.440 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:08.440 Auth Websocket socket (29) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:08.441 Auth Websocket socket (29) | New receive buffer size: 5242880 | 2021-10-11 15:01:08.441 Auth Websocket socket (29) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:08.441 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:08.482 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:08.482 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:08.616 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:08.616 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:08.616 Auth Websocket | Server header | Sec-WebSocket-Accept: dLa2NjJ/RCnEWvNOJaijEkmXUTI= | 2021-10-11 15:01:08.616 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:08.616 Auth Websocket | Server header | | 2021-10-11 15:01:08.616 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:08.616 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:08.616 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:08.703 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:08.703 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:08.703 TransAct WS | Session key cleared | 2021-10-11 15:01:08.705 Auth Websocket socket (29) | CloseSocket call. | 2021-10-11 15:01:08.705 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:08.705 TransAct WS | Disconnected. | 2021-10-11 15:01:08.705 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:08.705 Auth Websocket socket (29) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:08.705 Auth Websocket socket (29) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:08.742 Auth Websocket socket (29) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:08.742 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:09.721 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:09.721 Auth Websocket socket (30) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:09.722 Auth Websocket socket (30) | New receive buffer size: 5242880 | 2021-10-11 15:01:09.722 Auth Websocket socket (30) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:09.722 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:09.771 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:09.771 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:09.902 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:09.902 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:09.902 Auth Websocket | Server header | Sec-WebSocket-Accept: SSyIr0wPCyunIxHFqUHxK1RaXpk= | 2021-10-11 15:01:09.902 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:09.902 Auth Websocket | Server header | | 2021-10-11 15:01:09.902 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:09.902 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:09.902 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:09.991 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:09.991 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:09.991 TransAct WS | Session key cleared | 2021-10-11 15:01:10.002 Auth Websocket socket (30) | CloseSocket call. | 2021-10-11 15:01:10.002 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:10.002 Auth Websocket socket (30) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:10.002 TransAct WS | Disconnected. | 2021-10-11 15:01:10.002 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:10.002 Auth Websocket socket (30) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:10.041 Auth Websocket socket (30) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:10.041 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:11.003 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:11.003 Auth Websocket socket (31) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:11.003 Auth Websocket socket (31) | New receive buffer size: 5242880 | 2021-10-11 15:01:11.004 Auth Websocket socket (31) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:11.004 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:11.057 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:11.057 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:11.173 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:11.173 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:11.173 Auth Websocket | Server header | Sec-WebSocket-Accept: YN2EB/LOXWk3xaC6nEj/ZNIijvE= | 2021-10-11 15:01:11.173 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:11.173 Auth Websocket | Server header | | 2021-10-11 15:01:11.173 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:11.173 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:11.173 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:11.257 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:11.257 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:11.257 TransAct WS | Session key cleared | 2021-10-11 15:01:11.268 Auth Websocket socket (31) | CloseSocket call. | 2021-10-11 15:01:11.268 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:11.268 TransAct WS | Disconnected. | 2021-10-11 15:01:11.268 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:11.268 Auth Websocket socket (31) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:11.268 Auth Websocket socket (31) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:11.301 Auth Websocket socket (31) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:11.301 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:12.284 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:12.284 Auth Websocket socket (32) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:12.284 Auth Websocket socket (32) | New receive buffer size: 5242880 | 2021-10-11 15:01:12.285 Auth Websocket socket (32) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:12.285 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:12.327 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:12.327 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:12.456 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:12.456 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:12.456 Auth Websocket | Server header | Sec-WebSocket-Accept: h+yR8uM6RtFNvzGCaBkFn/2LxK0= | 2021-10-11 15:01:12.456 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:12.456 Auth Websocket | Server header | | 2021-10-11 15:01:12.456 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:12.456 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:12.456 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:12.556 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:12.556 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:12.556 TransAct WS | Session key cleared | 2021-10-11 15:01:12.565 Auth Websocket socket (32) | CloseSocket call. | 2021-10-11 15:01:12.565 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:12.565 TransAct WS | Disconnected. | 2021-10-11 15:01:12.565 Auth Websocket socket (32) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:12.565 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:12.565 Auth Websocket socket (32) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:12.600 Auth Websocket socket (32) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:12.600 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:13.567 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:13.567 Auth Websocket socket (33) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:13.567 Auth Websocket socket (33) | New receive buffer size: 5242880 | 2021-10-11 15:01:13.568 Auth Websocket socket (33) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:13.568 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:13.609 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:13.609 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:13.742 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:13.742 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:13.742 Auth Websocket | Server header | Sec-WebSocket-Accept: V2dx0R2pqYNQSzSOdqGV+h7TN84= | 2021-10-11 15:01:13.742 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:13.742 Auth Websocket | Server header | | 2021-10-11 15:01:13.742 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:13.742 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:13.742 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:13.832 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:13.832 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:13.832 TransAct WS | Session key cleared | 2021-10-11 15:01:13.848 Auth Websocket socket (33) | CloseSocket call. | 2021-10-11 15:01:13.848 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:13.848 Auth Websocket socket (33) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:13.848 TransAct WS | Disconnected. | 2021-10-11 15:01:13.848 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:13.848 Auth Websocket socket (33) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:13.883 Auth Websocket socket (33) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:13.883 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:14.848 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:14.848 Auth Websocket socket (34) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:14.849 Auth Websocket socket (34) | New receive buffer size: 5242880 | 2021-10-11 15:01:14.849 Auth Websocket socket (34) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:14.850 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:14.887 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:14.887 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:15.016 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:15.016 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:15.016 Auth Websocket | Server header | Sec-WebSocket-Accept: XSfNhoLVrz1jc37lzC4aU+wdWJs= | 2021-10-11 15:01:15.016 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:15.016 Auth Websocket | Server header | | 2021-10-11 15:01:15.016 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:15.016 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:15.016 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:15.101 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:15.102 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:15.102 TransAct WS | Session key cleared | 2021-10-11 15:01:15.113 Auth Websocket socket (34) | CloseSocket call. | 2021-10-11 15:01:15.113 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:15.113 TransAct WS | Disconnected. | 2021-10-11 15:01:15.113 Auth Websocket socket (34) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:15.113 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:15.113 Auth Websocket socket (34) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:15.149 Auth Websocket socket (34) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:15.149 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:16.113 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:16.113 Auth Websocket socket (35) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:16.114 Auth Websocket socket (35) | New receive buffer size: 5242880 | 2021-10-11 15:01:16.114 Auth Websocket socket (35) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:16.114 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:16.156 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:16.156 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:16.297 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:16.297 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:16.297 Auth Websocket | Server header | Sec-WebSocket-Accept: SvnR/jjuaQ+KvKsL9Vl61EAvGtg= | 2021-10-11 15:01:16.297 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:16.297 Auth Websocket | Server header | | 2021-10-11 15:01:16.297 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:16.297 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:16.297 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:16.391 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:16.391 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:16.391 TransAct WS | Session key cleared | 2021-10-11 15:01:16.394 Auth Websocket socket (35) | CloseSocket call. | 2021-10-11 15:01:16.394 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:16.394 TransAct WS | Disconnected. | 2021-10-11 15:01:16.395 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:16.395 Auth Websocket socket (35) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:16.395 Auth Websocket socket (35) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:16.432 Auth Websocket socket (35) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:16.432 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:17.410 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:17.411 Auth Websocket socket (36) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:17.411 Auth Websocket socket (36) | New receive buffer size: 5242880 | 2021-10-11 15:01:17.411 Auth Websocket socket (36) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:17.412 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:17.453 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:17.453 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:17.589 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:17.589 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:17.589 Auth Websocket | Server header | Sec-WebSocket-Accept: h0MaAen3f8303UoMH2flO+9LgXc= | 2021-10-11 15:01:17.589 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:17.589 Auth Websocket | Server header | | 2021-10-11 15:01:17.589 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:17.589 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:17.589 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:17.675 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:17.675 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:17.675 TransAct WS | Session key cleared | 2021-10-11 15:01:17.691 Auth Websocket socket (36) | CloseSocket call. | 2021-10-11 15:01:17.691 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:17.691 Auth Websocket socket (36) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:17.691 TransAct WS | Disconnected. | 2021-10-11 15:01:17.691 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:17.692 Auth Websocket socket (36) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:17.726 Auth Websocket socket (36) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:17.726 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:18.691 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:18.691 Auth Websocket socket (37) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:18.692 Auth Websocket socket (37) | New receive buffer size: 5242880 | 2021-10-11 15:01:18.692 Auth Websocket socket (37) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:18.692 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:18.736 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:18.736 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:18.870 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:18.870 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:18.870 Auth Websocket | Server header | Sec-WebSocket-Accept: PdCYYw6Ef+7k/RgwnuOEtqbrCbM= | 2021-10-11 15:01:18.870 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:18.870 Auth Websocket | Server header | | 2021-10-11 15:01:18.870 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:18.870 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:18.870 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:18.961 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:18.961 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:18.961 TransAct WS | Session key cleared | 2021-10-11 15:01:18.972 Auth Websocket socket (37) | CloseSocket call. | 2021-10-11 15:01:18.972 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:18.972 Auth Websocket socket (37) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:18.972 TransAct WS | Disconnected. | 2021-10-11 15:01:18.973 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:18.973 Auth Websocket socket (37) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:19.009 Auth Websocket socket (37) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:19.009 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:19.973 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:19.973 Auth Websocket socket (38) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:19.973 Auth Websocket socket (38) | New receive buffer size: 5242880 | 2021-10-11 15:01:19.973 Auth Websocket socket (38) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:19.973 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:20.014 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:20.014 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:20.149 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:20.149 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:20.149 Auth Websocket | Server header | Sec-WebSocket-Accept: ACnJztRg+fWsZsvGjQ0ODefgbqw= | 2021-10-11 15:01:20.149 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:20.149 Auth Websocket | Server header | | 2021-10-11 15:01:20.149 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:20.149 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:20.149 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:20.242 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:20.242 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:20.242 TransAct WS | Session key cleared | 2021-10-11 15:01:20.254 Auth Websocket socket (38) | CloseSocket call. | 2021-10-11 15:01:20.254 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:20.254 TransAct WS | Disconnected. | 2021-10-11 15:01:20.254 Auth Websocket socket (38) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:20.254 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:20.254 Auth Websocket socket (38) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:20.296 Auth Websocket socket (38) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:20.296 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:21.254 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:21.254 Auth Websocket socket (39) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:21.254 Auth Websocket socket (39) | New receive buffer size: 5242880 | 2021-10-11 15:01:21.255 Auth Websocket socket (39) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:21.255 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:21.296 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:21.296 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:21.425 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:21.425 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:21.425 Auth Websocket | Server header | Sec-WebSocket-Accept: RiTXehk69cah9KjFsEn8/NXC6jU= | 2021-10-11 15:01:21.425 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:21.425 Auth Websocket | Server header | | 2021-10-11 15:01:21.425 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:21.425 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:21.425 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:21.515 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:21.515 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:21.515 TransAct WS | Session key cleared | 2021-10-11 15:01:21.519 Auth Websocket socket (39) | CloseSocket call. | 2021-10-11 15:01:21.519 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:21.519 TransAct WS | Disconnected. | 2021-10-11 15:01:21.519 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:21.519 Auth Websocket socket (39) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:21.519 Auth Websocket socket (39) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:21.554 Auth Websocket socket (39) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:21.555 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:22.535 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:22.535 Auth Websocket socket (40) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:22.536 Auth Websocket socket (40) | New receive buffer size: 5242880 | 2021-10-11 15:01:22.537 Auth Websocket socket (40) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:22.537 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:22.578 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:22.578 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:22.707 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:22.707 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:22.707 Auth Websocket | Server header | Sec-WebSocket-Accept: xW1LBuFdhN6yJ48hSVkgCTK8NCY= | 2021-10-11 15:01:22.707 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:22.707 Auth Websocket | Server header | | 2021-10-11 15:01:22.707 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:22.707 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:22.707 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:22.795 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:22.795 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:22.795 TransAct WS | Session key cleared | 2021-10-11 15:01:22.800 Auth Websocket socket (40) | CloseSocket call. | 2021-10-11 15:01:22.800 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:22.800 TransAct WS | Disconnected. | 2021-10-11 15:01:22.800 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:22.800 Auth Websocket socket (40) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:22.800 Auth Websocket socket (40) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:22.835 Auth Websocket socket (40) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:22.835 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:23.816 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:23.816 Auth Websocket socket (41) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:23.817 Auth Websocket socket (41) | New receive buffer size: 5242880 | 2021-10-11 15:01:23.817 Auth Websocket socket (41) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:23.817 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:23.859 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:23.859 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:24.003 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:24.003 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:24.003 Auth Websocket | Server header | Sec-WebSocket-Accept: 2xF1tk71L6fx6kRE69kJdiUsV2w= | 2021-10-11 15:01:24.003 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:24.003 Auth Websocket | Server header | | 2021-10-11 15:01:24.003 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:24.003 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:24.003 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:24.093 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:24.093 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:24.093 TransAct WS | Session key cleared | 2021-10-11 15:01:24.097 Auth Websocket socket (41) | CloseSocket call. | 2021-10-11 15:01:24.097 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:24.097 Auth Websocket socket (41) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:24.097 TransAct WS | Disconnected. | 2021-10-11 15:01:24.097 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:24.097 Auth Websocket socket (41) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:24.134 Auth Websocket socket (41) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:24.134 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:25.098 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:25.098 Auth Websocket socket (42) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:25.098 Auth Websocket socket (42) | New receive buffer size: 5242880 | 2021-10-11 15:01:25.099 Auth Websocket socket (42) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:25.099 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:25.143 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:25.143 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:25.263 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:25.263 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:25.263 Auth Websocket | Server header | Sec-WebSocket-Accept: 8CiMMNqXjJ3ycngUDTXEEXn8uVA= | 2021-10-11 15:01:25.263 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:25.263 Auth Websocket | Server header | | 2021-10-11 15:01:25.263 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:25.263 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:25.263 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:25.350 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:25.350 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:25.350 TransAct WS | Session key cleared | 2021-10-11 15:01:25.363 Auth Websocket socket (42) | CloseSocket call. | 2021-10-11 15:01:25.363 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:25.363 TransAct WS | Disconnected. | 2021-10-11 15:01:25.363 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:25.363 Auth Websocket socket (42) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:25.363 Auth Websocket socket (42) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:25.397 Auth Websocket socket (42) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:25.397 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:26.363 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:26.363 Auth Websocket socket (43) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:26.363 Auth Websocket socket (43) | New receive buffer size: 5242880 | 2021-10-11 15:01:26.364 Auth Websocket socket (43) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:26.364 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:26.407 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:26.407 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:26.532 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:26.532 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:26.532 Auth Websocket | Server header | Sec-WebSocket-Accept: otSaCQN5Klea/S4DSTFregWi5NU= | 2021-10-11 15:01:26.532 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:26.532 Auth Websocket | Server header | | 2021-10-11 15:01:26.532 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:26.532 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:26.532 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:26.623 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:26.623 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:26.623 TransAct WS | Session key cleared | 2021-10-11 15:01:26.628 Auth Websocket socket (43) | CloseSocket call. | 2021-10-11 15:01:26.628 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:26.628 TransAct WS | Disconnected. | 2021-10-11 15:01:26.628 Auth Websocket socket (43) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:26.628 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:26.628 Auth Websocket socket (43) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:26.666 Auth Websocket socket (43) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:26.666 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:27.628 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:27.628 Auth Websocket socket (45) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:27.629 Auth Websocket socket (45) | New receive buffer size: 5242880 | 2021-10-11 15:01:27.629 Auth Websocket socket (45) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:27.629 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:27.671 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:27.671 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:27.812 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:27.812 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:27.812 Auth Websocket | Server header | Sec-WebSocket-Accept: D0tTeQ3lJciBvjxjyNYkZYaKw0g= | 2021-10-11 15:01:27.812 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:27.812 Auth Websocket | Server header | | 2021-10-11 15:01:27.812 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:27.812 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:27.812 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:27.900 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:27.900 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:27.900 TransAct WS | Session key cleared | 2021-10-11 15:01:27.909 Auth Websocket socket (45) | CloseSocket call. | 2021-10-11 15:01:27.909 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:27.909 Auth Websocket socket (45) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:27.910 TransAct WS | Disconnected. | 2021-10-11 15:01:27.910 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:27.910 Auth Websocket socket (45) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:27.947 Auth Websocket socket (45) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:27.947 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:28.909 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:28.909 Auth Websocket socket (44) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:28.910 Auth Websocket socket (44) | New receive buffer size: 5242880 | 2021-10-11 15:01:28.910 Auth Websocket socket (44) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:28.910 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:28.949 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:28.949 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:29.069 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:29.069 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:29.069 Auth Websocket | Server header | Sec-WebSocket-Accept: M2WtRK/WU2aSeZ7U3hKgEduXhG8= | 2021-10-11 15:01:29.069 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:29.069 Auth Websocket | Server header | | 2021-10-11 15:01:29.069 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:29.069 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:29.069 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:29.153 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:29.153 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:29.153 TransAct WS | Session key cleared | 2021-10-11 15:01:29.159 Auth Websocket socket (44) | CloseSocket call. | 2021-10-11 15:01:29.159 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:29.159 TransAct WS | Disconnected. | 2021-10-11 15:01:29.159 Auth Websocket socket (44) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:29.160 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:29.160 Auth Websocket socket (44) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:29.193 Auth Websocket socket (44) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:29.194 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:30.160 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:30.160 Auth Websocket socket (46) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:30.161 Auth Websocket socket (46) | New receive buffer size: 5242880 | 2021-10-11 15:01:30.161 Auth Websocket socket (46) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:30.161 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:30.200 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:30.200 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:30.330 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:30.330 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:30.330 Auth Websocket | Server header | Sec-WebSocket-Accept: cRh3lSOwUj//ALycxVE0HI9lA4w= | 2021-10-11 15:01:30.330 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:30.330 Auth Websocket | Server header | | 2021-10-11 15:01:30.330 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:30.330 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:30.330 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:30.418 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:30.418 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:30.418 TransAct WS | Session key cleared | 2021-10-11 15:01:30.424 Auth Websocket socket (46) | CloseSocket call. | 2021-10-11 15:01:30.424 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:30.424 TransAct WS | Disconnected. | 2021-10-11 15:01:30.424 Auth Websocket socket (46) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:30.424 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:30.424 Auth Websocket socket (46) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:30.462 Auth Websocket socket (46) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:30.462 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:31.441 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:31.441 Auth Websocket socket (47) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:31.441 Auth Websocket socket (47) | New receive buffer size: 5242880 | 2021-10-11 15:01:31.442 Auth Websocket socket (47) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:31.442 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:31.486 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:31.486 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:31.619 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:31.619 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:31.619 Auth Websocket | Server header | Sec-WebSocket-Accept: Wc0k31cjw5W41g303c2DYzl6gkc= | 2021-10-11 15:01:31.619 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:31.619 Auth Websocket | Server header | | 2021-10-11 15:01:31.619 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:31.619 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:31.619 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:31.707 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:31.707 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:31.707 TransAct WS | Session key cleared | 2021-10-11 15:01:31.722 Auth Websocket socket (47) | CloseSocket call. | 2021-10-11 15:01:31.722 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:31.722 TransAct WS | Disconnected. | 2021-10-11 15:01:31.722 Auth Websocket socket (47) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:31.722 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:31.722 Auth Websocket socket (47) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:31.758 Auth Websocket socket (47) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:31.758 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:32.727 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:32.727 Auth Websocket socket (48) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:32.727 Auth Websocket socket (48) | New receive buffer size: 5242880 | 2021-10-11 15:01:32.728 Auth Websocket socket (48) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:32.728 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:32.772 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:32.772 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:32.901 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:32.901 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:32.901 Auth Websocket | Server header | Sec-WebSocket-Accept: DiQoVDqmKtOD1Q72EGPUGlPqJ9s= | 2021-10-11 15:01:32.901 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:32.901 Auth Websocket | Server header | | 2021-10-11 15:01:32.901 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:32.901 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:32.901 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:32.991 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:32.991 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:32.991 TransAct WS | Session key cleared | 2021-10-11 15:01:32.993 Auth Websocket socket (48) | CloseSocket call. | 2021-10-11 15:01:32.993 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:32.993 TransAct WS | Disconnected. | 2021-10-11 15:01:32.993 Auth Websocket socket (48) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:32.993 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:32.993 Auth Websocket socket (48) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:33.034 Auth Websocket socket (48) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:33.034 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:34.007 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:34.007 Auth Websocket socket (49) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:34.008 Auth Websocket socket (49) | New receive buffer size: 5242880 | 2021-10-11 15:01:34.008 Auth Websocket socket (49) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:34.008 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:34.042 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:34.042 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:34.161 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:34.162 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:34.162 Auth Websocket | Server header | Sec-WebSocket-Accept: jXc9tcFz09Qd+KWF+hlXP4GXE6I= | 2021-10-11 15:01:34.162 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:34.162 Auth Websocket | Server header | | 2021-10-11 15:01:34.162 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:34.162 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:34.162 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:34.238 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:34.238 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:34.238 TransAct WS | Session key cleared | 2021-10-11 15:01:34.247 Auth Websocket socket (49) | CloseSocket call. | 2021-10-11 15:01:34.247 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:34.247 TransAct WS | Disconnected. | 2021-10-11 15:01:34.247 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:34.247 Auth Websocket socket (49) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:34.247 Auth Websocket socket (49) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:34.280 Auth Websocket socket (49) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:34.280 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-10-11 15:01:35.263 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-10-11 15:01:35.263 Auth Websocket socket (50) | Creating socket. Using TLS 1.2. | 2021-10-11 15:01:35.263 Auth Websocket socket (50) | New receive buffer size: 5242880 | 2021-10-11 15:01:35.264 Auth Websocket socket (50) | Connecting to IP: 208.97.219.30. | 2021-10-11 15:01:35.264 Auth Websocket | Opening WebSocket. | 2021-10-11 15:01:35.312 Auth Websocket | Sending WebSocket handshake. | 2021-10-11 15:01:35.312 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-10-11 15:01:35.440 Auth Websocket | Server header | Upgrade: WebSocket | 2021-10-11 15:01:35.441 Auth Websocket | Server header | Connection: Upgrade | 2021-10-11 15:01:35.441 Auth Websocket | Server header | Sec-WebSocket-Accept: M7liGbEmpuepg7glhSHGmAGYvMg= | 2021-10-11 15:01:35.441 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-10-11 15:01:35.441 Auth Websocket | Server header | | 2021-10-11 15:01:35.441 Auth Websocket | Web socket state is now open. | 2021-10-11 15:01:35.441 TransAct WS | Sending account logon message. Live | 2021-10-11 15:01:35.441 TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:35.528 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-11 15:01:35.528 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:35.528 TransAct WS | Session key cleared | 2021-10-11 15:01:35.554 Auth Websocket socket (50) | CloseSocket call. | 2021-10-11 15:01:35.554 Auth Websocket | WebSocket closed. | 2021-10-11 15:01:35.554 TransAct WS | Disconnected. | 2021-10-11 15:01:35.555 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-11 15:01:35.555 Auth Websocket socket (50) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-11 15:01:35.555 Auth Websocket socket (50) | Write has completed. Shutdown being performed. | 2021-10-11 15:01:35.591 Auth Websocket socket (50) | Shutdown started. Waiting for graceful close. | 2021-10-11 15:01:35.591 |
[2021-10-11 15:41:45] |
You are getting the following in your log: TransAct WS | Account logon error: -1(-1) | 2021-10-11 15:01:35.528
This means that either you are not setup with TransAct to use Sierra Chart or that you have your TransAct Username and/or Password entered incorrectly. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
