Date/Time: Mon, 29 Apr 2024 13:21:40 +0000
Rithmic Issue
View Count: 1031
[2021-09-27 11:19:56] |
User120666 - Posts: 46 |
Hi, I have been using Rithmic for the last few days for CME data (OneUpTrader evaluation) - the data has been fine but today it's stalling on 'waiting to download data' and has been for an hour+ now? Thanks in advance! |
[2021-09-27 11:43:10] |
Spinoza - Posts: 62 |
Yes, the same with me.
[2021-09-27 12:15:32] |
We do not provide support for Rithmic data. We recommend using the Denali Exchange Data Feed for market data. In both of your cases, you have a Service Package that includes the Denali Data Feed, but both of you do not have any CME exchanges active. You can do that from here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Once you do that the data will come from our Denali Exchange Data Feed and that will solve the market data issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-27 12:15:54
[2021-09-27 12:42:49] |
But what's different today? I have to use Rithmic for CME because it's part of the evaluation. No other days has it not downloaded data - but today it's been nearly 2hrs now and still nothing. Nothing has changed from where I switched off Friday and turned back on today? |
[2021-09-27 13:28:02] |
fcpauldiaz - Posts: 18 |
I have the same problem with Rithmic as well as for Denali. Cannot download data in any of them
[2021-09-27 13:58:39] |
Contact Rithmic: But what's different today? I have to use Rithmic for CME because it's part of the evaluation. No other days has it not downloaded data - but today it's been nearly 2hrs now and still nothing.
This is why we really did not want Rithmic to provide market data for the new connection method. Only trading. But they did it because of CME market data policy. You can see how much problem that causes all of us. In the case of post #5 you are not using the Denali data feed either because of this: Verified trading account ending date: 2021-08-24 . You need to connect your funded trading account: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-27 14:16:51] |
Rithmic issue has been fixed for me.
[2021-09-27 14:19:54] |
Same, the data downloaded after approx 3hrs.
[2021-09-28 13:05:27] |
j_nathan - Posts: 22 |
rithmic sucked on amp and sucks on a combine
