Date/Time: Thu, 10 Jul 2025 02:54:11 +0000
Chart Replay Reloads Data Slowly
View Count: 850
[2021-09-15 01:26:23]
Marion2025 - Posts: 14
Hello
I am doing some backtesting using the chart replay on intraday charts with tick data. After I stop a replay, the chart reloads all the historical data, which can take several minutes. In particular, it is the long loading time of the historical market depth data. This make iterative backtesting very slow and tedious. Is there any way to disable this chart reload activity? It shouldn't be necessary to reload the chart data when doing replays.
I've gone through the documentation below but nothing seems to have made a difference
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.3 - Charts Reloading Often
I've also reduce the "Max Depth Levels" to 20 in the "Sierra Chart Server Settings" but the load time for historical depth data is still very slow
Also, I have 128gb of ram, SSD, and a 48 thread Xeon CPU, so I have more than sufficient hardware and do not experience performance issues in any other applications
A simple solution would be to simply have SC load the historical data once, and only once. It shouldn't require reloading all this data when doing replays
Thank you
Date Time Of Last Edit: 2021-09-15 02:10:40
imageCapture.PNG / V - Attached On 2021-09-15 01:25:26 UTC - Size: 2.63 KB - 228 views
[2021-09-15 15:14:04]
When you stop the replay did you need the chart to load data all the way to the current date?
The only way to avoid this is to use what is called bar based back testing:
Auto Trade System Back Testing: Bar Based Back Testing
This is how you avoid the reloading.
It absolutely is necessary to reload the data when doing tick by tick back testing.
For the storage drive, you really want to use an NVME drive. Refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.29 - Solid State Drives / SSD
You can also compress older historical data files to make the loading from them faster:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#IntradayDataFileManagement
[2021-09-22 17:03:31]
I don't understand this question. Here is what I am observing
1) Chart is loaded all the way to current date.
2) When I start a replay, it reloads all the data before starting the replay. This seems completely unnecessary as the data is already loaded.
For the strategy I am testing, bar-based back testing is not an option as it would be highly inaccurate
My drive is an NVME drive, one of the fastest available
I have tried this but found little to no performance improvement
