Date/Time: Tue, 30 Apr 2024 10:03:10 +0000
démo
View Count: 985
[2021-08-02 17:57:23] |
John - SC Support - Posts: 31189 |
Is it possible to see its position in the limit orders of the book?
We assume you are asking about your particular orders. The first thing to be aware of is the option to see the Position in Queue. Refer to the following setting: Global Trade Settings Windows: Estimated Position (Q) (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) If you are wanting to actually see the limit orders broken down to the individual items, then you would need the Market by Order data for this. Refer to the following: Market By Order Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-03 15:09:18] |
Libfin - Posts: 20 |
Bonjour, Comment faire pour diminuer les polices de caractères dans le DOM (colonnes PRICE, ASK ...) et faire en sorte que la séparation entre les Bids et les Asks soit toujours au milieu de la fenêtre sans qu'on soit obligé de la remettre au lieu avec la souris ? Merci |
[2021-08-03 16:08:07] |
From Google Translate: Hello,
How to decrease the fonts in the DOM (PRICE, ASK columns ...) and ensure that the separation between Bids and Asks is always in the middle of the window without having to put it back in the place with the mouse? Thank you To change the Price size, you need to change the Chart Text in the Graphics Settings >> Fonts: Graphics Settings: Chart Text - (current font name) To change the other fonts in the DOM you need to change the DOM Quantities and Sizes in the Graphics Settings >> Fonts: Graphics Settings: DOM Quantities/Sizes - (current font name) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-03 16:46:59] |
OK Et les titres peuvent-ils être sur 2 lignes pour pouvoir réduire la largeur des colonnes ? Y a t il un "reset scale" que l'on peut paramètrer en automatique ? |
[2021-08-03 17:22:26] |
From Google Translate: OK
And can the titles be on 2 lines to be able to reduce the width of the columns? Is there a "reset scale" that can be set automatically? There is not support for the titles of the columns to be on two lines. In terms of the price scale, there are a number of options available for the Scale Range depending on exactly how you want it to act. Refer to the settings for the scale range starting here: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-03 19:59:46] |
Lorsque j'enregistre un chartbook, certaines des options que j'avais paramétrées ne sont pas enregistrées. Pourtant je m'assure que les fenêtres concernées étaient ouvertes au moment de la sauvegarde. Quel peut-être le problème ? Merci |
[2021-08-03 20:12:25] |
From Google Translate: When I save a chartbook, some of the options I have set are not saved. However, I make sure that the windows concerned were open when saving. What can be the problem ?
Thank you We need to know the specific items that you are having an issue with. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-03 20:32:12] |
tout le parametrage de mon Time and Sell a été remis à zero. Des colonnse n'apparaissent plus dans le DOM etc ...
[2021-08-03 20:48:08] |
From Google Translate: all my Time and Sell settings have been reset. Columns no longer appear in the DOM etc ...
For the Time and Sales, refer to the following: Time and Sales Window: Using Default Time and Sales Settings When you reference the DOM, we assume you are meaning the Trading DOM. In this case, refer to the following: Chart Trading and the Chart DOM: Saving Trade DOM Configuration If you have other specific items that are not saving, then let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-04 08:39:19] |
Bonjour John, J'ai installé la colonne "Bid Market Order" dans le Trading Dom sur le BUND mais je n'ai aucun chiffre. Pourquoi je ne vois pas les ordres marché ? Comment faire pour paramétrer plusieurs boutons du même objet dans la "control bar" ? -> exemple : "ligne horizontale jaune" + "ligne horizontale verte" etc ... ? Merci |
[2021-08-04 14:36:43] |
From Google Translate: Good morning, John, I installed the "Bid Market Order" column in the Trading Dom on the BUND but I have no numbers. Why can't I see the market orders? How to configure several buttons of the same object in the "control bar"? -> example: "yellow horizontal line" + "green horizontal line" etc ...? Thank you[/quote] With regards to the Market Orders, you should have them showing, as you should be getting the Delayed Streaming data for the EUREX, which does include this information. Go through the information at the following link for the items to look through to help resolve this: File Menu: Not Receiving the Full Number of Market Depth Levels With regards to the Control Bar buttons, refer to the documentation here: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-05 09:40:21] |
Hello John, Au démarrage de la plateforme, est-il possible de créer une alerte (unmessage.wav) pour dire qu'on est en version "REEL" ou en version "SIM" ? Comment mettre une alerte sur un prix ? Merci |
[2021-08-05 14:25:48] |
From Google Translate: Hello John,
When starting the platform, is it possible to create an alert (unmessage.wav) to say that we are in "REAL" or "SIM" version? How to put an alert on a price? Thank you There is not a way to have an alert for being in Real or Sim. But note that there are a few different clues around the charts that do show you this information. Refer to the following: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes There are a number of ways to put an alert on the price. The simplest is to use the Symbol Alerts. Refer to the information here: Alerts Manager: Symbol Alerts In terms of more complex alerts, refer to this documentation: Study/Chart Alerts And Scanning For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-09 08:24:26] |
Bonjour John, Serait-il possible d'avoir une autre session gratuite pour continuer à découvrir SIERRA ? Merci beaucoup |
[2021-08-09 15:22:58] |
From Google Translate: Would it be possible to have another free session to continue discovering SIERRA?
We are sorry, but we only allow for one 15-day trial within a 12-month period. You will have fully used your trial time when it expires in 5 days, therefore to continue to use Sierra Chart, you will need to pay for one of the Packages. Refer to the information here for how to activate a Service Package: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
