Date/Time: Tue, 30 Apr 2024 06:40:33 +0000
Sierra as charting only
View Count: 1051
[2021-05-31 20:09:36] |
User933209 - Posts: 38 |
Hello, how could I purchase monthly data feeds from Sierra to use only for charting. I trade ES / NQ. I would also like to use Footprint / Market profile if there is an additional cost for those. Thanks.
[2021-05-31 20:31:44] |
John - SC Support - Posts: 31189 |
What makes this difficult is that the CME Group, which is where the ES and NQ are traded, has a requirement that in order to qualify for the lower-priced non-professional exchange fees, you have to prove that you have a live, funded, futures trading account. For more information on this, refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you have a trading account with one of the supported trading services that we work with, then you can just connect every month to update the information that you have the account. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Otherwise, we recommend using the following service to open a trading account with a minimal outlay and just leave the funds in that account: Easy Solution to CME Funded Trading Account Requirement Or, you can pay the professional exchange fees. In that case, just follow the setup instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* ---------------- All of that aside, in order to get the Numbers Bars (footprints) and TPO (Market Profile) you will need the Advanced Package of Sierra Chart (Package 5). For more information on the differences in the packages, refer to the following: Description of Service Packages and Pricing: Packages And follow these instructions to add funds to your account and get setup with the specific package after your trial ends: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-31 21:24:18] |
Understood, thank you. Prove to whom? What do I need to show to prove that I have a funded futures account? Might just switch to AMP. Currently using Tradovate.
[2021-05-31 21:30:39] |
Prove to the CME Group. We do this by having you connect to your trading account at least once a month (if you are not constantly connected). If you are using Tradovate, then if they have you setup with CQG for your trading service/order routing, then you can use that connection to verify your Sierra Chart account for the CME Group. To do this, you would follow these instructions: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees And then within the above instructions at Step #3, you would go through these instructions to setup your connection to your CQG account: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-17 20:23:52] |
Got it. Im stuck on "connecting" my trading account. Could I just buy package 5 and it would work off the bat?
[2021-06-17 20:33:15] |
If you want to use Delayed Streaming Data, then yes. You can purchase Package 5, which will give you the studies you want, but the data will be 10 minutes and 10 seconds delayed. Otherwise, if you need to have real-time data from the CME Group, then you need to have a live, funded, trading account to which Sierra Chart can connect and verify the account in order to satisfy the CME Group that you are a non-professional and so that you can pay the lower cost non-professional exchange fees. Or, you can pay the Professional exchange fees and get the real-time data that way. We typically discourage this, as the cost is so high that you are better off establishing a trading account, but it certainly is an option. If you want to do this, then you would follow the Setup Instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-17 20:45:38] |
Okay. But I have a live and funded trading account. With Tradovate. How can I prove to CME with my Tradovate account?
[2021-06-17 21:00:35] |
Is your account with Tradovate using CQG for the order routing? If you do not know, then ask them about this. If it is using CQG, then you will follow these instructions to connect your Sierra Chart to that account: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-01 15:44:15] |
Hello, I just received my CQG connection account and I just purchased a package from you guys. Now, how do I bring up symbols? I trade the ES / YM. When I bring up the ES from "Find a symbol" it states symbol is unknown click for symbol information in orange and download failed in red.
[2021-07-01 18:24:02] |
Refer to the information here: CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-01 21:22:17] |
Got it. Thank you. Question. How do I remove the current candle open high low / Ask volume, etc on top of the chart? Thanks
[2021-07-01 21:53:20] |
Refer to the following: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
