Date/Time: Mon, 26 Oct 2026 14:33:33 +0000
Transact
View Count: 735
[2021-05-24 16:11:11]
User501366 - Posts: 1
hi,
I have a problem with connection to Transact...I can't connect with version 2253 64 bit... Thay are not quite eager to help so I am openning a new account with Advantage . i have read your post regarding future support services for Transact so my question is should I be able to connect to Transact with latest version or not?
Can I send Message log for analysis? - pls send me a name of supported engeneer.
I also need to buy Denali data feed and if I upgrade package can I run 2 Sierras on different IP adresses and maschinse, i.e. myself in hotel in Germany and Colegue of mine in our Office in Croatia.
What do I need to do for that? (two separate subscriptions and two Denalis?)
Thank you
Srecko
[2021-05-24 19:42:49]
John - SC Support - Posts: 48318
There have been no changes with regards to the connectivity to TransAct. So version 2253 should work just fine.
We would need more information to understand what the issue is with connecting to TransAct. Please give us some information and then supply your message log following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
Your account is setup to allow for 2 Sierra Chart installations on two different computers at no extra cost. But, the issue is related to data and the exchange rules. Therefore, if you are using the Denali Exchange Data Feed, then you will need to add one additional system connection in order to get the data to the two computers at the same time. Refer to the information here:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
