Date/Time: Fri, 26 Apr 2024 16:25:18 +0000
Google Search "+ Sierra Chart" Find what you need.
View Count: 2625
[2021-05-08 03:22:24] |
User14953 - Posts: 184 |
Put it right in the Title. Be it known far and wide, lol. THis Tip should Posted Prominently Right Below the Sierra 'Search' Box. Save Everybody Time and Money. *Google Search "+ Sierra Chart"* The Sierra Chart Search returns for: " 50 Simple Moving Average applied to Volume " are suboptimal at best... BUt, when you use a simple google search with "+ sierra chart" the returns are useful. The Second Listed Return, Boom There It Is! From the OP, "...first of all understand that 9 x out of 10 what you are asking for or looking for can be found in the extensive notes and online support manual. it really doesnt get any easier than a simple google search with "+ sierra chart" to find what you need. " Message from a USER to other USERS about SUPPORT at SIERRA CHART what I have learned THanks, OP. +7 more. *Everybody Hates Double Work. This is the SEcond listed Search Return from *Google + Sierra Chart*. DONE. Support Response from [2018-04-25 04:52:17] "Refer to the Based On Setting here: https://www.sierrachart.com/index.php?page=doc/ChartStudies.html#BasedOn" Support Response Current: Refer to the Based On Setting here: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Nobody likes the time-sink on support of a RYFM question. The Google + Sierra Chart can lead you through the Forest to the Tree you want. Date Time Of Last Edit: 2021-05-08 03:49:42
[2021-05-08 12:47:02] |
Sawtooth - Posts: 3976 |
I like the precise result but I can't duplicate what you did. Please provide a search string example without the " and * Please clarify which search field is used. |
[2021-05-08 13:15:18] |
seandunaway - Posts: 213 |
I prefer: site:sierrachart.com <search string> For example: https://www.google.com/search?q=site%3Asierrachart.com+-%22post+from%22+%22DeMark%22 |
[2021-05-08 23:49:05] |
Tomgilb The specific Google search was: "50 Simple Moving Average applied to Volume + Sierra Chart" The second item in the return links to: Volume moving average Try seandunaway's preference too. site:sierrachart.com <search string> I tried sean's preference on DuckDuckGo and it worked but for this particular search the results did not include the money item up top... site:sierrachart.com 50 Simple Moving Average applied to Volume Below is the return page address. https://duckduckgo.com/?q=site%3Asierrachart.com+50+Simple+Moving+Average+applied+to+Volume&t=hc&va=u&ia=web Seems like Sierra Chart might free up some SC Talent and Time if this can be somehow facilitated into the support process. Date Time Of Last Edit: 2021-05-09 00:07:14
[2021-05-09 18:00:08] |
ertrader - Posts: 644 |
Wow.. very helpful.. saves soooo much time...Thank you...This should be pinned for everyone!!
Date Time Of Last Edit: 2021-05-09 18:17:42
[2021-05-10 16:51:31] |
John - SC Support - Posts: 31147 |
Personally, I like to use the following on Google to ensure that I am only getting results from the documentation and not from the Support Board: <search terms> +site:www.sierrachart.com -site:www.sierrachart.com/SupportBoard.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-06 20:29:44] |
Does a button exist to invoke this method of search for finding SC info? A time saver for all concerned. [Locked] - Sierra Chart Google Search! Sierra Chart Google Search! https://www.sierrachart.com/index.php?l=doc/GoogleSearch.php ... If you wish to use google for searching the Sierra Chart website, then you can do so from google by adding site:sierrachart.com to your queries from the google home page. [2013-06-05 18:46:02] Sierra Chart - Max [Direct Messages] - Posts: 4989 |
