Date/Time: Sat, 27 Apr 2024 09:14:42 +0000
Not Updating
View Count: 658
[2021-04-14 12:55:48] |
User664240 - Posts: 206 |
Whether this is related or not??? But I received the message symbol not found etc.(orange highlight} and I lost all NYMEX at 08:47:00 EST but not CME. I Dis and Connected in sub instance no help but it work in the Main instance
[2021-04-14 15:01:43] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-14 15:29:13] |
Done...I'm assuming I was to discoonect prior to clearing.
[2021-04-14 15:49:36] |
We need the Message Log from the Sub-Instance where you are having the issue. Please follow the same process as you did before, but do it in the Sub-Instance that is having the issue.
[2021-04-14 16:09:57] |
Done ..might have accidentally sent it twice
[2021-04-30 12:12:36] |
Sent Message Log from subinstance..Experienced same issue of symbol not found.....
[2021-04-30 14:31:34] |
We are not seeing any issues in the log file you sent. What exactly does the orange box state? We need the exact wording. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-30 16:32:12] |
I can't be sure at this point. The message did not copy with the screen shot. But I did lose connection and I did need to reset(transfer servers) the main instance. It will happen again, until then we wait I guess.
[2021-04-30 17:02:23] |
Ok. Let us know when it occurs.
[2021-04-30 17:11:42] |
What happen with the first batch I sent you back on 04/14/2021..The message was Identical both times?
Date Time Of Last Edit: 2021-04-30 17:12:20
[2021-04-30 17:35:01] |
The Message Log from 4/14/2021 also does not show anything. That is why we need the exact wording of the message, as we are somewhat confused as to what is happening.
[2021-06-04 05:14:57] |
Let us know if you still need help here.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-04 05:15:09
[2021-06-04 11:41:40] |
Coincidentally the Software was not updating the symbol NG N this morning, I sent the log for analysis
[2021-06-04 11:54:13] |
The usual Dis/reconnect did not work but a complete restart did. The orange Label appeared and said ngn21 not known or improperly formatted?
[2021-06-04 16:36:47] |
Make sure you are using the consistent symbol format for that symbol for everywhere it is used within Sierra Chart, and also sub instances. Use this Edit menu command translate the symbols to the correct format: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-04 16:37:14
