Date/Time: Sat, 18 May 2024 06:01:54 +0000
CQGAPI Feed - Delayed Number Bars
View Count: 483
[2021-02-24 14:54:15] |
User212064 - Posts: 5 |
I recently moved from TT to CQGAPI and the delay in printing number bars takes some getting used to. I know this is a temporary fix (TT to CQGAPI), but will the permanent fix eliminate the number bar delay?
[2021-02-24 15:45:38] |
You should not be seeing any difference in the data, as you should still be getting the data from us via the Denali Exchange Data Feed. Please check to ensure that the option for File >> Data/Trade Service Settings >> Common Settings >> Allow Support For Sierra Chart Data Feeds is set to Yes. Refer to the information here: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) Also, look for the [M] after the symbol in the Chart Header that tells you if the data is coming from Sierra Chart or not. Refer to the information towards the end of this section for further explanation: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-24 15:55:47] |
Both of those criteria are set and showing. This morning I had a trade going and was stopped out before price showed on the chart. Definitely a delay compared to previous setup. Any other ideas? Thanks.
[2021-02-25 20:49:48] |
Doesn't look like you have any other suggestions. I'll change data feeds.
[2021-02-25 22:55:16] |
Refer to help topic 4: Prices / Data Falling Behind And also refer to : Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
