Date/Time: Fri, 03 May 2024 20:16:16 +0000
need real time cme data but don't understand the differances
View Count: 391
[2021-01-12 15:05:07] |
User61576 - Posts: 418 |
I am using now SC all data service and want to move to real time after reading I (think?) understand there are 3 different real-time feeds through SC: 1. Denali Exchange Data Feed 2. Sierra Chart Exchange Data Feed 3. Sierra Chart / Trading Technologies Futures Order Routing Service my questions are only regarding data feed as the order execution will go through AMP I have the following questions: 1. is Denali is a different company than SC? 2. total cost for Denali (CME non-prof) will be 20 + 3.25+10.4 (CME + depth fee)? 3. do I need any funded account with AMPto get these rates? 4. SC real-time feed for CME costs is 25 + ? (it's not in the table Sierra Chart Exchange Data Feed: Supported Exchanges) 5. is there any reason for me to use the SC order routing and not the current SC connection to AMP? |
[2021-01-12 18:34:05] |
John - SC Support - Posts: 31360 |
First, there are only 2 data feeds. The Sierra Chart Order Routing Feature is for Order Routing, although it does require that you get the data from us as either the Sierra Chart Exchange Data Feed or the Denali Exchange Data Feed. Here are the answers to your questions: 1. No, Denali is just the product name for that data feed. 2. Yes, if you are using the Sierra Chart Order Routing service and you want the data for the full CME Group, but only require Market Depth for symbols on the CME exchange. If you are not using the Sierra Chart Order Routing Service, then the $20 fee changes to $25. 3. Yes, you need to have a funded futures trading account in order to get the Non-Professional exchange rates from the CME Group. 4. You cannot use the Sierra Chart Exchange Data Feed for the CME Group. That is the difference between the two feeds. The Denali Exchange Data Feed is for the CME Group, and the Sierra Chart Exchange Data Feed is for all other exchanges. 5. We do not understand this question. We do not know what you mean by the "current SC Connection to AMP". When using Sierra Chart with AMP, you can get your trades cleared through either CQG or the Sierra Chart Order Routing Service (those are the two services that we both support). We recommend the Sierra Chart Order Routing Service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
