Date/Time: Wed, 04 Nov 2026 15:52:59 +0000
10 seconds chart does not work, it shows me the 1 minute not even in the current day
View Count: 1406
| [2021-01-08 18:26:53] |
| Taylor0F3 - Posts: 7 |
10 seconds chart does not work, it shows me the 1 minute. In market replay it does not work either. Market replay does not replay tick by tick, it does so minute by minute, it does not correspond to the chosen time frame (10 seconds). Live data updates tick by tick and the timeframe is correct.The data provider is CQG. According to recent CQG updates, data older than 5 days is not tick by tick, but this issue occurs within this range of days as well. I put the screenshot link. http://www.sierrachart.com/image.php?Image=1610130099585.png |
| [2021-01-08 18:41:53] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
| [2021-01-08 20:01:04] |
This is an indication that tick by tick data is not provided and we have no control over that. We do not recommend using CQG historical data: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-08 20:01:12
| [2021-01-08 21:01:24] |
| User868741 - Posts: 4 |
Hello, I already entered from my Sierra Chart Desktop (pack 3) provided for Amp broker. CQG provides tick by tick data but only up to the last 5 days. I have clicked on Edit / Delete all data and download and the 10 second chart works and the replay is tick by tick. Everything works fine again, but the next day the problem returns.
| [2021-01-08 23:37:21] |
We definitively do not provide any technical support for CQG historical data as we have made clear in the thread linked above. Use the Denali Exchange Data Feed as explained in the first post here: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG We can help you through the setup process. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-08 23:37:41
| [2021-01-09 00:58:32] |
No, the problem is not with CQG data. I have clicked on Edit / Delete All Data And Download and then the 10 seconds chart appears and the replay is tick by tick. But the next day the problem comes back again, and instead of a 10 second chart, it shows me a 1 minute chart. It is not a problem of historical data, this happens to me with the chart of the current session. Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG in this link clarifies that the tick by tick data is offered up to the last five days, and the problem occurs to me within that period. |
| [2021-01-09 12:37:01] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-11 02:20:24] |
Software version: 2215 64-bit | 2021-01-10 20:52:16.281 Primary Thread ID: 10948 | 2021-01-10 20:52:16.282 Usage end date: 2021-02-05 | 2021-01-10 20:52:16.282 Enabled for: Sierra Chart Historical Data Service. | 2021-01-10 20:52:16.282 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-01-10 20:52:16.282 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-01-10 20:52:16.282 Current selected Data/Trading service: CQG WebAPI | 2021-01-10 20:52:16.282 Custom symbol settings values: enabled | 2021-01-10 20:52:16.282 Chart Update Interval: 500 | 2021-01-10 20:52:16.282 Intraday Data Storage Time Unit: 1 | 2021-01-10 20:52:16.282 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-01-10 20:52:16.282 2021-01-11 01:52:16 Local computer time in UTC | 2021-01-10 20:52:16.282 2021-01-10 20:52:16 Local computer time in SC Time Zone | 2021-01-10 20:52:16.282 2021-01-11 01:43:57 Server time in UTC | 2021-01-10 20:52:16.282 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-01-10 20:52:16.282 Program path: C:\SierraChart\ | 2021-01-10 20:52:16.282 Data Files path: C:\SierraChart\Data\ | 2021-01-10 20:52:16.282 OS Version Number: 10.0 | 2021-01-10 20:52:16.283 Locale Setting: C | 2021-01-10 20:52:16.283 DLLs: UserContributedStudies_64.dll | 2021-01-10 20:52:16.283 Allowed protected custom studies: | 2021-01-10 20:52:16.283 CQG WebAPI | Using primary service for historical data for F.US.EPH21 | 2021-01-10 20:52:30.165 Added historical Intraday data request for F.US.EPH21 to the queue. | 2021-01-10 20:52:30.166 Intraday data recording state for symbol F.US.EPH21 is set to download 'Pending'. | 2021-01-10 20:52:30.166 Triggering next historical data download in queue. | 2021-01-10 20:52:30.166 HD Request # 2 | Downloading Intraday chart data for F.US.EPH21 to the file F.US.EPH21.scid. Service: cqg | 2021-01-10 20:52:30.166 Reloading all charts with filename: F.US.EPH21.scid | 2021-01-10 20:52:30.258 HD Request # 2 | Performing multistage download. Downloading Minute data first. | 2021-01-10 20:52:30.272 HD Request # 2 | Download start date-time: 2020-07-08 21:52:30.000000. File last date-time: 00:00:00.000000 | 2021-01-10 20:52:30.272 HD Request # 2 | Disabling Intraday chart updating for symbol. | 2021-01-10 20:52:30.272 HD Request # 2 | Requesting historical Minute data. | 2021-01-10 20:52:30.272 F.US.EPH21/F.US.MESH21 15 Min #2 | Reloading chart. | 2021-01-10 20:52:30.380 F.US.EPH21/F.US.MESH21 15 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPH21.scid | 2021-01-10 20:52:30.387 F.US.EPH21/F.US.MESH21 10 Sec #3 | Reloading chart. | 2021-01-10 20:52:30.391 F.US.EPH21/F.US.MESH21 3 Min #7 | Reloading chart. | 2021-01-10 20:52:30.397 F.US.EPH21/F.US.MESH21 10 Sec #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPH21.scid | 2021-01-10 20:52:30.403 F.US.EPH21/F.US.MESH21 3 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPH21.scid | 2021-01-10 20:52:30.405 F.US.EPH21/F.US.MESH21 10 Sec #1 | Reloading chart. | 2021-01-10 20:52:30.409 F.US.EPH21/F.US.MESH21 10 Sec #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPH21.scid | 2021-01-10 20:52:30.418 HD Request # 2 | Receiving Intraday data for F.US.EPH21 starting at 2020-10-12 21:52:00.000000 | 2021-01-10 20:53:53.190 HD Request # 2 | Timestamp of first Intraday data file record written: 2020-10-12 21:52:00.000000 | 2021-01-10 20:53:53.202 HD Request # 2 | Received 83926 records from 2020-10-12 21:52:00.000000 to 2021-01-10 20:52:00.000000 (90.0 days) and wrote 83926 records for F.US.EPH21 | 2021-01-10 20:53:53.214 HD Request # 2 | Completion time: 1m 23s | 2021-01-10 20:53:53.290 HD Request # 2 | Intraday data download complete for F.US.EPH21. Unique request ID: 2 | 2021-01-10 20:53:53.290 Added historical Intraday data request for F.US.EPH21 to the queue. | 2021-01-10 20:53:53.290 Triggering next historical data download in queue. | 2021-01-10 20:53:53.290 HD Request # 3 | Downloading Intraday chart data for F.US.EPH21 to the file F.US.EPH21.scid. Service: cqg | 2021-01-10 20:53:53.291 Reloading all charts with filename: F.US.EPH21.scid | 2021-01-10 20:53:53.293 HD Request # 3 | Rounding start date-time down to the minute: 2020-07-08 21:52:00.000 | 2021-01-10 20:53:53.297 HD Request # 3 | Download start date-time: 2020-07-08 21:52:00.000000. File last date-time: 00:00:00.000000 | 2021-01-10 20:53:53.298 HD Request # 3 | Requesting historical Tick data. | 2021-01-10 20:53:53.298 F.US.EPH21/F.US.MESH21 15 Min #2 | Reloading chart. | 2021-01-10 20:53:53.307 F.US.EPH21/F.US.MESH21 15 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPH21.scid | 2021-01-10 20:53:53.315 F.US.EPH21/F.US.MESH21 10 Sec #1 | Reloading chart. | 2021-01-10 20:53:53.319 F.US.EPH21/F.US.MESH21 10 Sec #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPH21.scid | 2021-01-10 20:53:53.330 F.US.EPH21/F.US.MESH21 3 Min #7 | Reloading chart. | 2021-01-10 20:53:53.336 F.US.EPH21/F.US.MESH21 3 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPH21.scid | 2021-01-10 20:53:53.343 F.US.EPH21/F.US.MESH21 10 Sec #3 | Reloading chart. | 2021-01-10 20:53:53.347 F.US.EPH21/F.US.MESH21 10 Sec #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPH21.scid | 2021-01-10 20:53:53.354 HD Request # 3 | Receiving Intraday data for F.US.EPH21 starting at 2021-01-05 20:52:30.120000 | 2021-01-10 21:16:28.513 HD Request # 3 | Timestamp of first Intraday data file record written: 2021-01-05 20:52:30.120000 | 2021-01-10 21:16:28.523 HD Request # 3 | Received 2846234 records from 2021-01-05 20:52:30.120000 to 2021-01-10 20:52:26.296000 (5.0 days) and wrote 2846234 records for F.US.EPH21 | 2021-01-10 21:16:33.909 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2021-01-11 01:52:26.296000 | 2021-01-10 21:16:35.374 Added 433 Time and Sales records to Intraday data file for F.US.EPH21 after download. | 2021-01-10 21:16:35.375 HD Request # 3 | Completion time: 22m 43s | 2021-01-10 21:16:36.301 HD Request # 3 | Intraday data download complete for F.US.EPH21. Unique request ID: 2 | 2021-01-10 21:16:36.301 Removing historical data download ID 2. | 2021-01-10 21:16:36.301 Real-time Intraday chart data file updates started for F.US.EPH21 | 2021-01-10 21:16:36.301 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPH21.scid. Thread ID: 10948 | 2021-01-10 21:16:36.515 Intraday chart data file opened for F.US.EPH21 | 2021-01-10 21:16:36.516 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2021-01-10 21:16:36.516 Triggering next historical data download in queue. | 2021-01-10 21:16:36.516 F.US.EPH21/F.US.MESH21 10 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-01-10 21:16:39.769 F.US.EPH21/F.US.MESH21 10 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-01-10 21:16:41.697 F.US.EPH21/F.US.MESH21 3 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-01-10 21:16:47.518 |
| [2021-01-11 03:36:01] |
This is crazy. The 5 days of tick data from CQG took this amount of time: HD Request # 3 | Completion time: 22m 43s | 2021-01-10 21:16:36.301 22 minutes! Now users can see why we limited the CQG historical tick data to 5 days. Anyway aside from that, this line is missing during the download of tick data: HD Request # 4 | Truncated Intraday data file at 2021-01-05 22:19:00 while receiving initial tick data during multistage download. | 2021-01-10 22:20:19.581 Otherwise, there would be out of order data in the chart. So this is not really making sense to us why you are having an issue with this. You could try updating to the current version, currently 2218, but we do not know why that would make any difference. We really advise using the Denali exchange data feed which you can pay for through your brokerage account: Denali Exchange Data Feed This will resolve the issues for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-11 05:18:45
| [2021-01-12 01:05:27] |
The problem that I have been explaining is that as long as I do not have Sierra Chart open, as long as I am not receiving live data, the bars are not 10 seconds, they are one minute. But when I open the platform (when I log into Sierra), then each bar itself is 10 seconds. If I don't open the platform for two hours, those two hours will give me a one minute chart, and I need this to give me a 10 second chart, not a minute. I show you today's chart, for the whole day I didn't log into Sierra, and instead of showing me the 10 second chart, it shows me the whole day with one minute bars. But now that I log in, it does show me 10 second bars. http://www.sierrachart.com/image.php?Image=161041303262.png In the two squares that I am drawing is the period in which I have bars of 10 seconds because it was the period in which I log in to Sierra, (receiving live data, with connection) the rest of the bars are one minute. I need it to be the entire 10 second chart, even though I have logged out of Sierra. |
